Author Topic: "Internet Security 2010" Virus  (Read 2428 times)
Re: "Internet Security 2010" Virus
« Reply #15 on: January 27, 2010, 11:12:42 PM »
Link 1
Link 2
Disable your AntiVirus and AntiSpyware applications. If not disabled, these programs will likely interfere with cleanup process. This can usually be accomplished by a right-click on the icon in the System Tray.  This can usually be accomplished by a right-click on the icon in the System Tray.
Note:  If you use AVG, you must also open the AVG 8 Control Center, by right clicking on the AVG 8 icon on task bar as well as the following:
  • Click on Tools.
  • Select Advanced Settings.
  • In the left hand pane, scroll down to "Resident Shield".
  • In the main pane, deselect the option to "Enable Resident Shield."
  • To re-enable AVG 8, please select "Enable Resident Shield" again.
Now, please run ComboFix:
  • When finished, a log will be produced. Please include the C:\ComboFix.txt in your next reply along with a fresh HijackThis log.
Offline Iowajo
« Reply #16 on: January 28, 2010, 03:39:04 AM »
Thank you Corrine
ComboFix 10-01-27.03 - Owner 01/27/2010  22:22:58.2.1 - x86
Microsoft Windows XP Home Edition  5.1.2600.3.1252.1.1033.18.894.671 [GMT -6:00]
Running from: c:\temp\ComboFix.exe
AV: AVG Anti-Virus Free *On-access scanning disabled* (Updated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
c:\documents and settings\All Users\Start Menu\HP Image Zone .lnk
c:\windows\system32\18467.exe
c:\windows\system32\vclwiz8.dll
c:\windows\Tasks\flbkrblv.job
(((((((((((((((((((((((((   Files Created from 2009-12-28 to 2010-01-28  )))))))))))))))))))))))))))))))
2010-01-28 04:16 . 2010-01-28 04:16   3838755   ----a-r-   c:\temp\ComboFix.exe
2010-01-27 17:53 . 2010-01-27 18:35   --------   d-----w-   c:\program files\a-squared Free
2010-01-27 17:48 . 2010-01-27 17:51   70560496   ----a-w-   c:\temp\a2FreeSetup.exe
2010-01-26 00:50 . 2010-01-26 00:50   0   ----a-w-   c:\temp\settings.dat
2010-01-26 00:16 . 2010-01-26 00:20   --------   d-----w-   c:\program files\ERUNT01252010
2010-01-26 00:13 . 2010-01-26 00:13   791393   ----a-w-   c:\temp\erunt_setup.exe
2010-01-25 21:14 . 2010-01-25 21:14   1924200   ----a-w-   c:\temp\install_flash_player.exe
2010-01-25 21:14 . 2010-01-25 21:14   4515840   ----a-w-   c:\temp\AdbeRdrUpd714_all_incr.msp
2010-01-25 21:10 . 2010-01-25 21:10   1956528   ----a-w-   c:\temp\install_flash_player_ax.exe
2010-01-25 18:01 . 2010-01-25 18:01   --------   d-----w-   c:\documents and settings\Owner\Local Settings\Application Data\Threat Expert
2010-01-25 17:46 . 2010-01-25 17:48   34630056   ----a-w-   c:\temp\sdasetup.exe
2010-01-25 17:36 . 2010-01-25 17:37   5061512   ----a-w-   c:\temp\mbam-setup.exe
2010-01-25 00:38 . 2010-01-25 00:38   --------   d-----w-   c:\program files\CCleaner
2010-01-23 19:55 . 2010-01-25 08:16   --------   d-----w-   C:\$AVG8.VAULT$
2010-01-23 16:56 . 2010-01-23 16:56   --------   d-----w-   c:\windows\system32\wbem\Repository
2010-01-22 14:35 . 2010-01-22 14:41   --------   d-----w-   c:\documents and settings\Owner\Application Data\QuickScan
2010-01-15 17:31 . 2010-01-15 17:31   --------   d-----w-   c:\program files\Common Files\DivX Shared
2010-01-14 01:13 . 2010-01-14 01:15   --------   d-----w-   c:\documents and settings\Owner\Local Settings\Application Data\Temp
2010-01-13 02:58 . 2009-11-21 15:51   471552   -c----w-   c:\windows\system32\dllcache\aclayers.dll
2010-01-08 20:11 . 2010-01-08 20:11   152576   ----a-w-   c:\documents and settings\Owner\Application Data\Sun\Java\jre1.6.0_17\lzma.dll
2010-01-08 20:11 . 2010-01-08 20:11   79488   ----a-w-   c:\documents and settings\Owner\Application Data\Sun\Java\jre1.6.0_17\gtapi.dll
2010-01-27 15:53 . 2007-07-07 22:48   --------   d---a-w-   c:\documents and settings\All Users\Application Data\TEMP
2010-01-25 00:32 . 2006-01-19 21:48   --------   d-----w-   c:\program files\SpywareBlaster
2010-01-24 09:19 . 2008-10-13 20:11   --------   d-----w-   c:\program files\Microsoft Silverlight
2010-01-15 17:31 . 2007-05-06 19:01   --------   d-----w-   c:\program files\DivX
2010-01-08 20:12 . 2007-10-11 22:44   --------   d-----w-   c:\program files\Java
2010-01-05 10:00 . 2005-03-23 16:53   832512   ----a-w-   c:\windows\system32\wininet.dll
2010-01-05 10:00 . 2005-03-23 16:52   78336   ----a-w-   c:\windows\system32\ieencode.dll
2010-01-05 10:00 . 2005-03-23 16:52   17408   ------w-   c:\windows\system32\corpol.dll
2009-11-21 15:51 . 2005-03-23 16:52   471552   ----a-w-   c:\windows\AppPatch\aclayers.dll
2007-05-15 01:27 . 2007-05-15 01:27   21407888   ----a-w-   c:\program files\avg75free_467a1008.exe
2006-04-27 23:45 . 2006-04-27 23:45   10971704   ----a-w-   c:\program files\setupeng.exe
2006-01-19 21:47 . 2006-01-19 21:47   2566736   ----a-w-   c:\program files\spywareblastersetup351.exe
2005-11-13 03:22 . 2005-11-13 03:22   5834344   ----a-w-   c:\program files\winzip100.exe
2005-11-08 02:21 . 2005-11-08 02:21   6635997   ----a-w-   c:\program files\photoshop_album_SE_3_0_ue.zip
REGEDIT4
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
"{A3BC75A2-1F87-4686-AA43-5347D756017C}"= "c:\program files\AVG\AVG8\Toolbar\IEToolbar.dll" [2009-09-02 1107200]
[HKEY_CLASSES_ROOT\clsid\{a3bc75a2-1f87-4686-aa43-5347d756017c}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{A3BC75A2-1F87-4686-AA43-5347D756017C}]
2009-09-02 16:58   1107200   ----a-w-   c:\program files\AVG\AVG8\Toolbar\IEToolbar.dll
"{CCC7A320-B3CA-4199-B1A6-9F516DD69829}"= "c:\program files\AVG\AVG8\Toolbar\IEToolbar.dll" [2009-09-02 1107200]
[HKEY_CLASSES_ROOT\clsid\{ccc7a320-b3ca-4199-b1a6-9f516dd69829}]
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\Webbrowser]
"Google Update"="c:\documents and settings\Owner\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" [2010-01-14 135664]
"SunKistEM"="c:\program files\Digital Media Reader\shwiconem.exe" [2004-11-15 135168]
"NeroFilterCheck"="c:\windows\system32\NeroCheck.exe" [2001-07-09 155648]
"Recguard"="c:\windows\SMINST\RECGUARD.EXE" [2002-09-14 212992]
"Logitech Utility"="Logi_MwX.Exe" [2003-12-17 19968]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2005-05-09 98304]
"AVG8_TRAY"="c:\progra~1\AVG\AVG8\avgtray.exe" [2009-12-12 2043160]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-10-11 149280]
c:\documents and settings\All Users\Start Menu\Programs\Startup\
Adobe Reader Speed Launch.lnk - c:\program files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2008-4-23 29696]
[hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
"{F2A0229A-C4CA-4789-B606-973D24DCDD1C}"= "c:\program files\McAfee\McAfee AntiSpyware\MssShell.dll" [2004-10-19 86016]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\avgrsstarter]
2009-08-16 13:22   11952   ----a-w-   c:\windows\system32\avgrsstx.dll
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Reader Speed Launch.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk
backup=c:\windows\pss\Adobe Reader Speed Launch.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Digital Imaging Monitor.lnk]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Image Zone Fast Start.lnk]
[HKLM\~\startupfolder\C:^Documents and Settings^Owner^Start Menu^Programs^Startup^desktop weather.lnk]
path=c:\documents and settings\Owner\Start Menu\Programs\Startup\desktop weather.lnk
backup=c:\windows\pss\desktop weather.lnkStartup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ATIPTA]
2005-03-18 04:05   339968   ----a-w-   c:\program files\ATI Technologies\ATI Control Panel\atiptaxx.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSMSGS]
2008-04-14 00:12   1695232   ------w-   c:\program files\Messenger\msmsgs.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SoundMan]
2004-12-01 23:54   77824   ----a-w-   c:\windows\SOUNDMAN.EXE
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\updateMgr]
2006-03-30 21:45   313472   ----a-r-   c:\program files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Veoh]
2008-08-28 15:18   3660848   ----a-w-   c:\program files\Veoh Networks\Veoh\VeohClient.exe
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqtra08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqste08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hposid01.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqscnvw.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqkygrp.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqCopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpfccopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqPhUnl.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqDIA.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpoews01.exe"=
"c:\\Program Files\\Yahoo!\\Messenger\\YahooMessenger.exe"=
"c:\\Program Files\\Veoh Networks\\Veoh\\VeohClient.exe"=
"c:\\WS_FTP\\ws_ftp95.exe"=
"%windir%\\Network Diagnostic\\xpnetdiag.exe"=
"c:\\Program Files\\Veoh Networks\\VeohWebPlayer\\veohwebplayer.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgupd.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgnsx.exe"=
"c:\\Program Files\\MSN Messenger\\msnmsgr.exe"=
"c:\\WINDOWS\\system32\\sessmgr.exe"=
"c:\\Program Files\\Mozilla Firefox\\firefox.exe"=
R1 AvgLdx86;AVG Free AVI Loader Driver x86;c:\windows\system32\drivers\avgldx86.sys [3/12/2009 6:30 AM 335240]
R1 AvgTdiX;AVG Free8 Network Redirector;c:\windows\system32\drivers\avgtdix.sys [3/12/2009 6:30 AM 108552]
R2 a2free;a-squared Free Service;c:\program files\a-squared Free\a2service.exe [1/27/2010 11:53 AM 1858144]
R2 avg8wd;AVG Free8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [3/12/2009 6:30 AM 297752]
S2 CSHelper;CopySafe Helper Service;c:\windows\system32\CSHelper.exe [2/13/2009 10:40 PM 266240]
2010-01-28 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-3970769690-232089958-676742549-1003Core.job
- c:\documents and settings\Owner\Local Settings\Application Data\Google\Update\GoogleUpdate.exe [2010-01-14 01:13]
2010-01-28 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-3970769690-232089958-676742549-1003UA.job
uStart Page = hxxp://www.yahoo.com/
uSearchMigratedDefaultURL = hxxp://www.google.com/search?q={searchTerms}&sourceid=ie7&rls=com.microsoft:en-US&ie=utf8&oe=utf8
uInternet Connection Wizard,ShellNext = iexplore
uSearchURL,(Default) = hxxp://www.google.com/search?q=%s
IE: Add to Google Photos Screensa&ver - c:\windows\system32\GPhotos.scr/200
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
DPF: Microsoft XML Parser for Java
DPF: {42544677-805B-4203-BF22-90051EB34A17} - hxxp://www.flexwatch.com/app_link/download/s2nd/S2NDWEB.cab
DPF: {4A33C147-5243-4982-899A-A533BEDA99D1} - hxxp://70.43.125.20/wespliveviewer.cab
FF - ProfilePath - c:\documents and settings\Owner\Application Data\Mozilla\Firefox\Profiles\707k5ohw.default\
FF - prefs.js: browser.startup.homepage - hxxp://ipb.quicksilverscreen.com/index.php?showforum=21
FF - component: c:\program files\AVG\AVG8\Firefox\components\avgssff.dll
FF - component: c:\program files\AVG\AVG8\Toolbar\Firefox\avg@igeared\components\IGeared_tavgp_xputils2.dll
FF - component: c:\program files\AVG\AVG8\Toolbar\Firefox\avg@igeared\components\IGeared_tavgp_xputils3.dll
FF - component: c:\program files\AVG\AVG8\Toolbar\Firefox\avg@igeared\components\IGeared_tavgp_xputils35.dll
FF - component: c:\program files\AVG\AVG8\Toolbar\Firefox\avg@igeared\components\xpavgtbapi.dll
FF - plugin: c:\documents and settings\Owner\Application Data\Mozilla\Firefox\Profiles\707k5ohw.default\extensions\moveplayer@movenetworks.com\platform\WINNT_x86-msvc\plugins\npmnqmp071101000055.dll
FF - plugin: c:\documents and settings\Owner\Local Settings\Application Data\Google\Update\1.2.183.13\npGoogleOneClick8.dll
FF - plugin: c:\program files\DivX\DivX Plus Web Player\npdivx32.dll
FF - plugin: c:\program files\Google\Picasa3\npPicasa3.dll
FF - plugin: c:\program files\Veoh Networks\Veoh\Plugins\noreg\NPVeohVersion.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\NPVeohTVPlugin.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\npWebPlayerVideoPluginATL.dll
FF - plugin: c:\program files\Viewpoint\Viewpoint Experience Technology\npViewpoint.dll
SharedTaskScheduler-{012c864c-0549-4700-8c48-a427b5a3a400} - (no file)
SSODL-metusuwol-{012c864c-0549-4700-8c48-a427b5a3a400} - (no file)
AddRemove-User's Guide - c:\program files\Logitech\UsrGuide\UGUninst.isu
Rootkit scan 2010-01-27 22:29
Windows 5.1.2600 Service Pack 3 NTFS
scanning hidden processes ...
scanning hidden files ...
scan completed successfully
hidden files: 0
- - - - - - - > 'winlogon.exe'(556)
c:\windows\system32\Ati2evxx.dll
Completion time: 2010-01-27  22:31:40
ComboFix-quarantined-files.txt  2010-01-28 04:31
ComboFix2.txt  2009-03-11 02:05
Pre-Run: 53,678,153,728 bytes free
Post-Run: 53,639,110,656 bytes free
- - End Of File - - 36667A183A3BC0684E884E12522F50FB
and...
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 10:36:17 PM, on 1/27/2010
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16981)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\Program Files\a-squared Free\a2service.exe
C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
C:\Program Files\Digital Media Reader\shwiconem.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\Program Files\Logitech\MouseWare\system\em_exec.exe
C:\WINDOWS\system32\HPZipm12.exe
C:\PROGRA~1\AVG\AVG8\avgtray.exe
C:\Program Files\Java\jre6\bin\jusched.exe
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\PROGRA~1\AVG\AVG8\avgnsx.exe
C:\WINDOWS\explorer.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R3 - URLSearchHook: AVG Security Toolbar BHO - {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll
R3 - URLSearchHook: (no name) - *{CFBFAE00-17A6-11D0-99CB-00C04FD64497} - (no file)
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: AVG Security Toolbar BHO - {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O3 - Toolbar: Veoh Web Player Video Finder - {0FBB9689-D3D7-4f7a-A2E2-585B10099BFC} - C:\Program Files\Veoh Networks\VeohWebPlayer\VeohIEToolbar.dll
O3 - Toolbar: AVG Security Toolbar - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll
O4 - HKLM\..\Run: [SunKistEM] "C:\Program Files\Digital Media Reader\shwiconem.exe"
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [Recguard] %WINDIR%\SMINST\RECGUARD.EXE
O4 - HKLM\..\Run: [Logitech Utility] Logi_MwX.Exe
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"
O4 - HKCU\..\Run: [Google Update] "C:\Documents and Settings\Owner\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" /c
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O8 - Extra context menu item: Add to Google Photos Screensa&ver - res://C:\WINDOWS\system32\GPhotos.scr/200
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: Outpost Firewall Pro Quick Tune - {44627E97-789B-40d4-B5C2-58BD171129A1} - C:\WINDOWS\system32\shdocvw.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
O16 - DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} (Facebook Photo Uploader 5 Control) - http://upload.facebook.com/controls/2008.10.10_v5.5.8/FacebookPhotoUploader5.cab
O16 - DPF: {0E5F0222-96B9-11D3-8997-00104BD12D94} (PCPitstop Utility) - http://www.pcpitstop.com/pcpitstop/PCPitStop.CAB
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {1F2F4C9E-6F09-47BC-970D-3C54734667FE} - https://www-secure.symantec.com/techsupp/asa/ctrl/LSSupCtl.cab
O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} (Snapfish Activia) - http://www1.snapfish.com/SnapfishActivia.cab
O16 - DPF: {42544677-805B-4203-BF22-90051EB34A17} (DQViewer Control) - http://www.flexwatch.com/app_link/download/s2nd/S2NDWEB.cab
O16 - DPF: {4A33C147-5243-4982-899A-A533BEDA99D1} (LoginControllerCtrl Class) - http://70.43.125.20/wespliveviewer.cab
O16 - DPF: {56762DEC-6B0D-4AB4-A8AD-989993B5D08B} (OnlineScanner Control) - http://www.eset.eu/buxus/docs/OnlineScanner.cab
O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} (Windows Live Safety Center Base Module) - http://cdn.scan.safety.live.com/resource/download/scanner/wlscbase969.cab
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1161052365671
O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} (HouseCall Control) - http://a840.g.akamai.net/7/840/537/2005111401/housecall.trendmicro.com/housecall/xscan53.cab
O16 - DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} (Facebook Photo Uploader 5 Control) - http://upload.facebook.com/controls/2009.07.28_v5.5.8.1/FacebookPhotoUploader55.cab
O16 - DPF: {9600F64D-755F-11D4-A47F-0001023E6D5A} (Shutterfly Picture Upload Plugin) - http://web1.shutterfly.com/downloads/Uploader.cab
O16 - DPF: {A8739816-022C-11D6-A85D-00C04F9AEAFB} (Web Camera Server Control) - http://72.129.165.146/wg_webeye.cab
O16 - DPF: {A922B6AB-3B87-11D3-B3C2-0008C7DA6CB9} (InetDownload Class) - https://media.pineconeresearch.com/ActiveX/downloadcontrol.cab
O16 - DPF: {CE28D5D2-60CF-4C7D-9FE8-0F47A3308078} (ActiveDataInfo Class) - https://www-secure.symantec.com/techsupp/asa/ctrl/SymAData.cab
O16 - DPF: {EF791A6B-FC12-4C68-99EF-FB9E207A39E6} (McFreeScan Class) - http://download.mcafee.com/molbin/iss-loc/mcfscan/2,1,0,4749/mcfscan.cab
O16 - DPF: {FFB3A759-98B1-446F-BDA9-909C6EB18CC7} (PCPitstop Exam) - http://utilities.pcpitstop.com/Optimize2/pcpitstop2.dll
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O20 - Winlogon Notify: avgrsstarter - C:\WINDOWS\SYSTEM32\avgrsstx.dll
O23 - Service: a-squared Free Service (a2free) - Emsi Software GmbH - C:\Program Files\a-squared Free\a2service.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: CopySafe Helper Service (CSHelper) - Unknown owner - C:\WINDOWS\system32\CSHelper.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
End of file - 8559 bytes
« Reply #17 on: January 28, 2010, 01:31:55 PM »
Hi, Jo.
and
!!! IMPORTANT !!! Save ComboFix.exe to your Desktop.
Unless you want a rather useless paper weight, I need to know you will follow the instructions exactly as provided.
Please move ComboFix to your desktop and let me know when that has been completed.
Thank you.
Offline Iowajo
« Reply #18 on: January 28, 2010, 01:55:46 PM »
I'm sorry. I have moved it to desktop.
Offline Iowajo
« Reply #19 on: January 28, 2010, 02:17:11 PM »
New logs:
ComboFix 10-01-27.06 - Owner 01/28/2010   9:04.3.1 - x86
Running from: c:\documents and settings\Owner\Desktop\ComboFix.exe
2010-01-05 10:00 . 2005-03-23 16:53   832512   ------w-   c:\windows\system32\wininet.dll
REGEDIT4
Rootkit scan 2010-01-28 09:10
hidden files: 0
- - - - - - - > 'explorer.exe'(3712)
c:\windows\system32\WININET.dll
c:\program files\Logitech\MouseWare\System\LgWndHk.dll
c:\windows\system32\ieframe.dll
c:\windows\system32\mshtml.dll
c:\program files\Common Files\Logitech\Scrolling\LgMsgHk.dll
c:\windows\system32\WPDShServiceObj.dll
c:\windows\system32\PortableDeviceTypes.dll
c:\windows\system32\PortableDeviceApi.dll
Completion time: 2010-01-28  09:12:58
ComboFix-quarantined-files.txt  2010-01-28 15:12
ComboFix2.txt  2010-01-28 04:31
ComboFix3.txt  2009-03-11 02:05
Pre-Run: 53,596,434,432 bytes free
Post-Run: 53,578,702,848 bytes free
- - End Of File - - 5F22807D3E17F285A65F420B176DC0AF
and
Scan saved at 9:15:20 AM, on 1/28/2010
Boot mode: Normal
Running processes:
C:\WINDOWS\system32\wscntfy.exe
End of file - 8591 bytes
Offline Iowajo
« Reply #20 on: February 02, 2010, 02:14:25 AM »
Am I done?
« Reply #21 on: February 02, 2010, 05:07:18 PM »
Hi, Jo.
Close all programs leaving only HijackThis running.  Place a check against the following, making sure you do not any others by mistake:
Click on Fix Checked when finished and exit HijackThis.
Next, you have a vulnerable version of Adobe Reader installed on your computer.
1.  Go to add/remove programs and uninstall Adobe Reader
2.  Install the latest version of Adobe Reader from http://www.adobe.com/products/reader/
or
3.  Switch to an alternate PDF reader.  There are a number of open source readers available from http://pdfreaders.org/.
Please do the following to implement cleanup procedures and also to reset System Restore points:
ComboFix /Uninstall
Internet Explorer 8 has replaced IE7.  Is there some reason why you have not updated to IE8?
SunJava  has been updated to JRE6u18, although it was a stabilization update, not a security update.  You should, however, ensure t hat not just Microsoft security updates are installed, but all added software.
To check if your system is missing security updates or has insecure applications installed, visit http://secunia.com/software_inspector/ .  The Secunia Software Inspector runs through your browser with no installation or download required and does the following:
Offline Iowajo
« Reply #22 on: February 04, 2010, 07:48:26 PM »
Thank you so much for all your help Corrine.
I have done everything on the list.
I so appreciate everything!
Jo
« Reply #23 on: February 04, 2010, 10:22:12 PM »
You are very welcome, Jo!
Safe surfing!
