Author Topic: cannot open any software programs on the computer  (Read 411 times)
Offline marinelaxox
« on: December 09, 2011, 11:01:49 PM »
i cannot even prepare my computer.  i am unable to open "add or remove programs"
i am unable to run AVG
i am unable to open the internet explorer.
i am using the internet by typing the addresses on a "my computer" window rather than internet explorer window.
i cannot even open microsoft office programs.
i am very frustrated please help me!  :(
Re: cannot open any software programs on the computer
« Reply #1 on: December 10, 2011, 01:48:24 AM »
Hi, marinelaxox.  Welcome to LandzDown Forum.
1.  Please restart the computer in Safe Mode with Networking. (To do this, turn your computer off and then back on and immediately when you see anything on the screen, start tapping the F8 key on your keyboard. Using the arrow keys on your keyboard, select Safe Mode with Networking and press Enter on your keyboard. Windows will now boot into safe mode with networking and prompt you to login as a user.)
2.  Please download rkill from one of the following links and save to your Desktop:
One, Two,Three or Four
  • Double-click rkill to run.
Note: If you you receive security warnings about rkill, please ignore and allow the download to continue.
3.  Please download Malwarebytes' Anti-Malware to your desktop.
  • Click Finish.
  • Click Remove Selected.
** Note **
4.  Download DDS.scr by sUBs from one of the following links and save it to your desktop.
Link 1
Link 2
5.  Download Security Check by screen317 from here or here.
  • Save it to your Desktop.
  • Double click SecurityCheck.exe and follow the onscreen instructions inside of the black box.
  • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
Requested logs:
Malwarebytes
Both DDS.txt and Attach.txt
checkup.txt
