Thank you all, so much. Corrine's fix worked and my husband can now click on icons and have applications open the way they should. Even then, I did get a message from "XUL runner" saying (when I tried to open FireFox) "Couldn't read application ini." But after I deleted the program and downloaded it again from Mozilla and reinstalled it, if began working fine, like all the other programs.
So I guess that problem is solved. Now there is one new one. The Systray has that red shield with an X on it and claims that Automatic updates is turned off. Even though I went to the Control Panel> System > Automatic Updates and turned the automatic updates on, the Security section in the control panel continues to report Automatic Updates as turned off, while the System section claims they are turned on. This inconsistency persists, even though I have restarted the computer.
Here is the MBAM log:
Malwarebytes' Anti-Malware 1.51.0.1200
www.malwarebytes.orgDatabase version: 6923
Windows 5.1.2600 Service Pack 3
Internet Explorer 8.0.6001.18702
6/22/2011 7:32:30 PM
mbam-log-2011-06-22 (19-32-30).txt
Scan type: Quick scan
Objects scanned: 174016
Time elapsed: 7 minute(s), 55 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 3
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\AntiVirusDisableNotify (PUM.Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (PUM.Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (PUM.Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
Folders Infected:
Files Infected:
And here are the other things that are in the Log Posting Instructions:
But I do not understand whether MBAM and SuperAntiSpyware are considered to be antivirus applications that must be uninstalled before the next step here, but I will assume that it's all right to leave them in. My husband's computer has MSE as its antivirus.
DDS (Ver_2011-06-12.02) - NTFSx86
Internet Explorer: 8.0.6001.18702 BrowserJavaVersion: 1.6.0_23
Run by Minoru at 20:22:18 on 2011-06-22
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1022.172 [GMT -7:00]
AV: Microsoft Security Essentials *Enabled/Updated* {EDB4FA23-53B8-4AFA-8C5D-99752CCA7095}
AV: Microsoft Security Essentials *Disabled/Updated* {BCF43643-A118-4432-AEDE-D861FCBCFCDF}
FW: ZoneAlarm Firewall *Enabled*
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost -k DcomLaunch
svchost.exe
c:\Program Files\Microsoft Security Client\Antimalware\MsMpEng.exe
C:\WINDOWS\System32\svchost.exe -k netsvcs
svchost.exe
svchost.exe
C:\WINDOWS\system32\ZoneLabs\vsmon.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\CheckPoint\ZAForceField\IswSvc.exe
svchost.exe
C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
C:\Program Files\Bonjour\mDNSResponder.exe
C:\WINDOWS\system32\DRIVERS\CDANTSRV.EXE
C:\WINDOWS\eHome\ehRecvr.exe
C:\WINDOWS\eHome\ehSched.exe
C:\Program Files\Intel\Intel Matrix Storage Manager\iaantmon.exe
C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\Program Files\Malwarebytes' Anti-Malware\mbamservice.exe
svchost.exe
C:\WINDOWS\system32\svchost.exe -k imgsvc
C:\WINDOWS\system32\dllhost.exe
C:\WINDOWS\system32\wscntfy.exe
C:\WINDOWS\ehome\ehtray.exe
C:\WINDOWS\stsystra.exe
C:\WINDOWS\eHome\ehmsas.exe
C:\Program Files\Real\RealPlayer\RealPlay.exe
C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
C:\WINDOWS\System32\DLA\DLACTRLW.EXE
C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
C:\Program Files\HP\HP Software Update\HPWuSchd.exe
C:\Program Files\HP\hpcoretech\hpcmpmgr.exe
C:\Program Files\Common Files\Microsoft Shared\Works Shared\WkUFind.exe
C:\Program Files\Microsoft Security Client\msseces.exe
C:\Program Files\Microsoft IntelliType Pro\itype.exe
C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe
C:\Program Files\Microsoft IntelliType Pro\dpupdchk.exe
C:\Program Files\Digital Line Detect\DLG.exe
C:\Program Files\CheckPoint\ZAForceField\ForceField.exe
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\WINDOWS\system32\HPZipm12.exe
C:\Program Files\Mozilla Firefox\plugin-container.exe
uStart Page = hxxp://www.dell.com
uURLSearchHooks: ZoneAlarm Toolbar: {66f2e20d-0da8-4c11-a9c8-dd8477b88acd} - c:\program files\zonealarm\tbZone.dll
BHO: AcroIEHlprObj Class: {06849e9f-c8d7-4d59-b87d-784b7d6be0b3} - c:\program files\adobe\acrobat 7.0\activex\AcroIEHelper.dll
BHO: DriveLetterAccess: {5ca3d70e-1895-11cf-8e15-001234567890} - c:\windows\system32\dla\DLASHX_W.DLL
BHO: ZoneAlarm Toolbar: {66f2e20d-0da8-4c11-a9c8-dd8477b88acd} - c:\program files\zonealarm\tbZone.dll
BHO: ZoneAlarm Security Engine Registrar: {8a4a36c2-0535-4d2c-bd3d-496cb7eed6e3} - c:\program files\checkpoint\zaforcefield\trustchecker\bin\TrustCheckerIEPlugin.dll
BHO: QUICKfind BHO Object: {c08df07a-3e49-4e25-9ab0-d3882835f153} - c:\progra~1\textware\quickf~1\plugins\IEHelp.dll
BHO: Java(tm) Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - c:\program files\java\jre6\bin\jp2ssv.dll
BHO: JQSIEStartDetectorImpl Class: {e7e6f031-17ce-4c07-bc86-eabfe594f69c} - c:\program files\java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
TB: ZoneAlarm Toolbar: {66f2e20d-0da8-4c11-a9c8-dd8477b88acd} - c:\program files\zonealarm\tbZone.dll
TB: ZoneAlarm Security Engine: {ee2ac4e5-b0b0-4ec6-88a9-bca1a32ab107} - c:\program files\checkpoint\zaforcefield\trustchecker\bin\TrustCheckerIEPlugin.dll
EB: Real.com: {fe54fa40-d68c-11d2-98fa-00c0f0318afe} - c:\windows\system32\Shdocvw.dll
uRun: [ctfmon.exe] c:\windows\system32\ctfmon.exe
uRun: [MSMSGS] "c:\program files\messenger\msmsgs.exe" /background
uRun: [SUPERAntiSpyware] c:\program files\superantispyware\SUPERAntiSpyware.exe
mRun: [ehTray] c:\windows\ehome\ehtray.exe
mRun: [SigmatelSysTrayApp] stsystra.exe
mRun: [ATIPTA] "c:\program files\ati technologies\ati control panel\atiptaxx.exe"
mRun: [RealTray] c:\program files\real\realplayer\RealPlay.exe SYSTEMBOOTHIDEPLAYER
mRun: [ISUSPM Startup] "c:\program files\common files\installshield\updateservice\isuspm.exe" -startup
mRun: [ISUSScheduler] "c:\program files\common files\installshield\updateservice\issch.exe" -start
mRun: [DLA] c:\windows\system32\dla\DLACTRLW.EXE
mRun: [IMJPMIG8.1] "c:\windows\ime\imjp8_1\IMJPMIG.EXE" /Spoil /RemAdvDef /Migration32
mRun: [IMEKRMIG6.1] c:\windows\ime\imkr6_1\IMEKRMIG.EXE
mRun: [MSPY2002] c:\windows\system32\ime\pintlgnt\ImScInst.exe /SYNC
mRun: [PHIME2002ASync] c:\windows\system32\ime\tintlgnt\TINTSETP.EXE /SYNC
mRun: [PHIME2002A] c:\windows\system32\ime\tintlgnt\TINTSETP.EXE /IMEName
mRun: [ZoneAlarm Client] "c:\program files\zone labs\zonealarm\zlclient.exe"
mRun: [ISW] "c:\program files\checkpoint\zaforcefield\ForceField.exe" /icon="hidden"
mRun: [HP Software Update] "c:\program files\hp\hp software update\HPWuSchd.exe"
mRun: [HP Component Manager] "c:\program files\hp\hpcoretech\hpcmpmgr.exe"
mRun: [DXDllRegExe] dxdllreg.exe
mRun: [QuickTime Task] "c:\program files\quicktime\QTTask.exe" -atboottime
mRun: [iTunesHelper] "c:\program files\itunes\iTunesHelper.exe"
mRun: [Microsoft Works Update Detection] c:\program files\common files\microsoft shared\works shared\WkUFind.exe
mRun: [<NO NAME>]
mRun: [MSC] "c:\program files\microsoft security client\msseces.exe" -hide -runkey
mRun: [SunJavaUpdateSched] c:\program files\java\jre6\bin\jusched.exe
mRun: [itype] "c:\program files\microsoft intellitype pro\itype.exe"
mRun: [Malwarebytes' Anti-Malware] "c:\program files\malwarebytes' anti-malware\mbamgui.exe" /starttray
dRun: [DWQueuedReporting] "c:\progra~1\common~1\micros~1\dw\dwtrig20.exe" -t
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\adober~1.lnk - c:\program files\adobe\acrobat 7.0\reader\reader_sl.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\digita~1.lnk - c:\program files\digital line detect\DLG.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\hpdigi~1.lnk - c:\program files\hp\digital imaging\bin\hpqtra08.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\micros~1.lnk - c:\program files\microsoft office\office10\OSA.EXE
IE: E&xport to Microsoft Excel - c:\progra~1\mi1933~1\office10\EXCEL.EXE/3000
IE: {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe
IE: {FB5F1910-F110-11d2-BB9E-00C04F795683} - c:\program files\messenger\msmsgs.exe
IE: {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - {08B0E5C0-4FCB-11CF-AAA5-00401C608501}
IE: {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - {FE54FA40-D68C-11d2-98FA-00C0F0318AFE} - c:\windows\system32\Shdocvw.dll
Trusted Zone: intuit.com\ttlc
Trusted Zone: musicmatch.com\online
DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/products/plugin/autodl/jinstall-160-windows-i586.cab
DPF: {CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA} - hxxp://java.sun.com/products/plugin/autodl/jinstall-160-windows-i586.cab
DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_23-windows-i586.cab
TCP: DhcpNameServer = 68.105.28.11 68.105.29.11 68.105.28.12
TCP: Interfaces\{94942CD0-124C-4722-9329-AFF679F61E44} : DhcpNameServer = 68.105.28.11 68.105.29.11 68.105.28.12
Handler: cetihpz - {CF184AD3-CDCB-4168-A3F7-8E447D129300} - c:\program files\hp\hpcoretech\comp\hpuiprot.dll
Handler: textwareilluminatorbase - {CE5CD329-1650-414A-8DB0-4CBF72FAED87} - c:\windows\system32\textwareilluminatorbaseProtocol.dll
Notify: !SASWinLogon - c:\program files\superantispyware\SASWINLO.DLL
SEH: SABShellExecuteHook Class: {5ae067d3-9afb-48e0-853a-ebb7f4a000da} - c:\program files\superantispyware\SASSEH.DLL
FF - ProfilePath - c:\documents and settings\minoru\application data\mozilla\firefox\profiles\n4ks25yu.hlbeqoh\
FF - prefs.js: browser.startup.homepage - hxxps://mail.google.com/mail/?shva=1#inbox
FF - component: c:\documents and settings\minoru\application data\mozilla\firefox\profiles\n4ks25yu.hlbeqoh\extensions\{66f2e20d-0da8-4c11-a9c8-dd8477b88acd}\components\RadioWMPCoreGecko19.dll
FF - component: c:\program files\checkpoint\zaforcefield\trustchecker\components\TrustCheckerMozillaPlugin.dll
FF - plugin: c:\program files\checkpoint\zaforcefield\trustchecker\bin\npFFApi.dll
FF - plugin: c:\program files\java\jre6\bin\new_plugin\npdeployJava1.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npdeployJava1.dll
FF - plugin: c:\program files\viewpoint\viewpoint experience technology\npViewpoint.dll
R1 MpFilter;Microsoft Malware Protection Driver;c:\windows\system32\drivers\MpFilter.sys [2010-3-25 165264]
R1 MpKsl189c7bb5;MpKsl189c7bb5;c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{1073bf20-809b-44e0-9cff-41b5b920d4c6}\MpKsl189c7bb5.sys [2011-6-22 28752]
R1 SASDIFSV;SASDIFSV;c:\program files\superantispyware\sasdifsv.sys [2010-2-17 12872]
R1 SASKUTIL;SASKUTIL;c:\program files\superantispyware\SASKUTIL.SYS [2010-5-10 67656]
R1 vsdatant;vsdatant;c:\windows\system32\vsdatant.sys [2010-9-27 532224]
R2 ISWKL;ZoneAlarm Toolbar ISWKL;c:\program files\checkpoint\zaforcefield\ISWKL.sys [2010-5-26 26352]
R2 IswSvc;ZoneAlarm Toolbar IswSvc;c:\program files\checkpoint\zaforcefield\ISWSVC.exe [2010-5-26 493032]
R2 MBAMService;MBAMService;c:\program files\malwarebytes' anti-malware\mbamservice.exe [2011-6-22 366640]
R2 McrdSvc;Media Center Extender Service;c:\windows\ehome\mcrdsvc.exe [2005-8-5 99328]
R2 npf;NetGroup Packet Filter Driver;c:\windows\system32\drivers\npf.sys [2010-1-26 50704]
R2 vsmon;TrueVector Internet Monitor;c:\windows\system32\zonelabs\vsmon.exe -service --> c:\windows\system32\zonelabs\vsmon.exe -service [?]
R3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [2011-6-22 22712]
S1 MpKsl011c3b70;MpKsl011c3b70;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{0ad00b92-5c49-41bf-a10b-8398e834ab5c}\mpksl011c3b70.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{0ad00b92-5c49-41bf-a10b-8398e834ab5c}\MpKsl011c3b70.sys [?]
S1 MpKsl1cc0058a;MpKsl1cc0058a;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{76c6a266-3760-4615-bb3a-eb3ae411cb6a}\mpksl1cc0058a.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{76c6a266-3760-4615-bb3a-eb3ae411cb6a}\MpKsl1cc0058a.sys [?]
S1 MpKsl26554662;MpKsl26554662;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{6015f208-4465-4ac3-8cd5-ca891809decf}\mpksl26554662.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{6015f208-4465-4ac3-8cd5-ca891809decf}\MpKsl26554662.sys [?]
S1 MpKsl43d98934;MpKsl43d98934;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{f06ea956-0c55-4ecd-9de1-c98468010f99}\mpksl43d98934.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{f06ea956-0c55-4ecd-9de1-c98468010f99}\MpKsl43d98934.sys [?]
S1 MpKsl4487a25e;MpKsl4487a25e;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{6015f208-4465-4ac3-8cd5-ca891809decf}\mpksl4487a25e.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{6015f208-4465-4ac3-8cd5-ca891809decf}\MpKsl4487a25e.sys [?]
S1 MpKsl57e96f3d;MpKsl57e96f3d;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{29bdad1b-6877-4a40-b663-e107445a3c05}\mpksl57e96f3d.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{29bdad1b-6877-4a40-b663-e107445a3c05}\MpKsl57e96f3d.sys [?]
S1 MpKsl6588535d;MpKsl6588535d;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{252d6ead-6ab3-4dfd-bf6b-bf7aa70b7d32}\mpksl6588535d.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{252d6ead-6ab3-4dfd-bf6b-bf7aa70b7d32}\MpKsl6588535d.sys [?]
S1 MpKsl7736982a;MpKsl7736982a;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{2eca3bf6-27f3-4f11-8fbe-ede403c796a7}\mpksl7736982a.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{2eca3bf6-27f3-4f11-8fbe-ede403c796a7}\MpKsl7736982a.sys [?]
S1 MpKsl7ad2a8d5;MpKsl7ad2a8d5;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{4a48c95f-f7a0-430a-a971-19c9e080ffb8}\mpksl7ad2a8d5.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{4a48c95f-f7a0-430a-a971-19c9e080ffb8}\MpKsl7ad2a8d5.sys [?]
S1 MpKsl80b42e4a;MpKsl80b42e4a;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{8b66a68d-09a8-4c48-84d8-121ab903dc83}\mpksl80b42e4a.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{8b66a68d-09a8-4c48-84d8-121ab903dc83}\MpKsl80b42e4a.sys [?]
S1 MpKsl841b97b5;MpKsl841b97b5;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{7475d733-b2a7-46b7-945f-6d17898d45e1}\mpksl841b97b5.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{7475d733-b2a7-46b7-945f-6d17898d45e1}\MpKsl841b97b5.sys [?]
S1 MpKsl84f18fed;MpKsl84f18fed;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{f1202147-ad2f-42de-bbfe-17dde3871110}\mpksl84f18fed.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{f1202147-ad2f-42de-bbfe-17dde3871110}\MpKsl84f18fed.sys [?]
S1 MpKsl9a3dd37c;MpKsl9a3dd37c;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{8b25cc25-4ea9-42ed-98bc-9d1075e12a60}\mpksl9a3dd37c.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{8b25cc25-4ea9-42ed-98bc-9d1075e12a60}\MpKsl9a3dd37c.sys [?]
S1 MpKsl9dcbdb2a;MpKsl9dcbdb2a;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{cc38391d-fd10-4cfc-adb4-c1387a9e0205}\mpksl9dcbdb2a.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{cc38391d-fd10-4cfc-adb4-c1387a9e0205}\MpKsl9dcbdb2a.sys [?]
S1 MpKsl9f9f5dea;MpKsl9f9f5dea;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{0f5038bf-c9d3-48c6-a6b8-48e8cab99f52}\mpksl9f9f5dea.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{0f5038bf-c9d3-48c6-a6b8-48e8cab99f52}\MpKsl9f9f5dea.sys [?]
S1 MpKslb8ca715c;MpKslb8ca715c;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{c048d7fa-c07b-4b62-8951-34d4d58a330e}\mpkslb8ca715c.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{c048d7fa-c07b-4b62-8951-34d4d58a330e}\MpKslb8ca715c.sys [?]
S1 MpKslbd62f5d9;MpKslbd62f5d9;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{f06ea956-0c55-4ecd-9de1-c98468010f99}\mpkslbd62f5d9.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{f06ea956-0c55-4ecd-9de1-c98468010f99}\MpKslbd62f5d9.sys [?]
S1 MpKsle2a1dc4c;MpKsle2a1dc4c;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{18e17006-58aa-436a-8c69-340cb6643643}\mpksle2a1dc4c.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{18e17006-58aa-436a-8c69-340cb6643643}\MpKsle2a1dc4c.sys [?]
S1 MpKsle47a795d;MpKsle47a795d;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d9a5581e-caee-4f04-bab3-84d37b568e0c}\mpksle47a795d.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{d9a5581e-caee-4f04-bab3-84d37b568e0c}\MpKsle47a795d.sys [?]
S1 MpKslf1d7f0f9;MpKslf1d7f0f9;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{8f6fd37f-46f1-4980-9670-be91d16f407d}\mpkslf1d7f0f9.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{8f6fd37f-46f1-4980-9670-be91d16f407d}\MpKslf1d7f0f9.sys [?]
S1 MpKslf376c4b3;MpKslf376c4b3;\??\c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{192abc23-44bf-4d53-802c-de593e09b4b2}\mpkslf376c4b3.sys --> c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{192abc23-44bf-4d53-802c-de593e09b4b2}\MpKslf376c4b3.sys [?]
S3 MBAMSwissArmy;MBAMSwissArmy;c:\windows\system32\drivers\mbamswissarmy.sys [2011-6-22 39984]
2011-06-23 02:44:54 28752 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{1073bf20-809b-44e0-9cff-41b5b920d4c6}\MpKsl189c7bb5.sys
2011-06-23 01:59:02 -------- d-----w- c:\documents and settings\minoru\application data\Malwarebytes
2011-06-23 01:58:51 39984 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2011-06-23 01:58:50 -------- d-----w- c:\documents and settings\all users\application data\Malwarebytes
2011-06-23 01:58:46 22712 ----a-w- c:\windows\system32\drivers\mbam.sys
2011-06-23 01:58:46 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2011-06-21 23:32:50 -------- d-----w- c:\documents and settings\minoru\application data\SUPERAntiSpyware.com
2011-06-21 23:32:36 -------- d-----w- c:\program files\SUPERAntiSpyware
2011-06-20 08:44:34 6962000 ----a-w- c:\documents and settings\all users\application data\microsoft\microsoft antimalware\definition updates\{1073bf20-809b-44e0-9cff-41b5b920d4c6}\mpengine.dll
2011-06-17 12:48:21 105472 ------w- c:\windows\system32\dllcache\mup.sys
2011-06-09 18:31:00 -------- d-----w- c:\documents and settings\minoru\local settings\application data\Intuit
2011-06-09 18:29:31 -------- d-----w- c:\program files\common files\AnswerWorks 5.0
2011-06-09 18:25:08 -------- d-----w- c:\documents and settings\minoru\local settings\application data\IsolatedStorage
2011-06-09 18:17:53 -------- d-----w- c:\program files\TurboTax
==================== Find3M ====================
2011-05-02 15:31:52 692736 ----a-w- c:\windows\system32\inetcomm.dll
2011-04-29 16:19:43 456320 ----a-w- c:\windows\system32\drivers\mrxsmb.sys
2011-04-25 16:11:12 916480 ----a-w- c:\windows\system32\wininet.dll
2011-04-25 16:11:11 43520 ----a-w- c:\windows\system32\licmgr10.dll
2011-04-25 16:11:11 1469440 ------w- c:\windows\system32\inetcpl.cpl
2011-04-25 12:01:22 385024 ----a-w- c:\windows\system32\html.iec
2011-04-21 13:37:43 105472 ----a-w- c:\windows\system32\drivers\mup.sys
2010-01-26 18:11:08 444283 ----a-w- c:\program files\common files\WinPcapNmap.exe
============= FINISH: 20:23:31.70 ===============
I got a message saying not to post "Attach.text" unless told to do so. Do you want me to post it?
Results of screen317's Security Check version 0.99.15
Windows XP Service Pack 3
Internet Explorer 8
Antivirus/Firewall Check: ZoneAlarm
ZoneAlarm Toolbar
Antivirus up to date! (On Access scanning
disabled!)
Anti-malware/Other Utilities Check: Malwarebytes' Anti-Malware
Java(TM) 6 Update 23
Out of date Java installed! Flash Player Out of Date! Adobe Flash Player 10.2.159.1
Mozilla Firefox (x86 en-US..)
Process Check:
objlist.exe by Laurent Windows Defender MSMpEng.exe
Malwarebytes' Anti-Malware mbamservice.exe
Malwarebytes' Anti-Malware mbamgui.exe
Microsoft Security Essentials msseces.exe
Microsoft Security Client Antimalware MsMpEng.exe
Zone Labs ZoneAlarm zlclient.exe
``````````End of Log```````````` Again, thank you very much. Just in case, and to save time, I think I will try to zip "Attach.text" and post it in a new reply here, since I noticed that the Log Posting Instructions do say to post it.
Jan
