Hi, walemon. Welcome to LandzDown Forum.
We will do our best to assist you. However, in order to do so, please follow all instructions provided in the sequence given. Do not install/re-install any programs or run any fixes or scanners that you have not been instructed to use. This may cause conflicts with the tools being used in the cleanup process.
Please start Internet Explorer and do the following:
- Click on the Tools menu.
- Select Internet Options.
- Click on the Connections tab.
- Click on the LAN Settings button so you are on the Local Area Network (LAN) settings screen.
- Under the Proxy Server section, please UNCHECK the checkbox labeled "Use a proxy server for your LAN".
- Press OK button to close this screen.
- Press the OK button to close the Internet Options screen.
This should fix the problem with Internet Explorer.
Next, please download rkill from one of the following links and save to your Desktop:
One,
Two,
Three or
Four- Double-click rkill to run.
- A command window will open then disappear upon completion, this is normal.
- Please leave rkill on the Desktop until otherwise advised.
- Do NOT restart your computer after running rkill as the malware program(s) will start again and you will need to run rkill again.
Notes: If you you receive security warnings about rkill, please ignore and allow the download to continue.
Please download
- Double-click mbam-setup.exe and follow the prompts to install the program.
- At the end, be sure a checkmark is placed next to
Launch Malwarebytes' Anti-Malware - Click Finish.
- If an update is found, it will download and install the latest version.
- Once the program has loaded, be sure Quick scan is selected, then click Scan.
- When the scan is complete, click OK, then Show Results to view the results.
- Be sure that everything is checked, EXCEPT items in System Restore as shown in this sample:
- Click Remove Selected.
- When disinfection is completed, a log will open in Notepad and you may be prompted to Restart. (See the Note below)
- The log is automatically saved by MBAM and can be viewed by clicking the Logs tab in MBAM.
- Please post contents of that file in your next reply.
** Note **If MBAM encounters a file that is difficult to remove, you will be presented with 1 of 2 prompts. Click
OK to either and let MBAM proceed with the disinfection process. If asked to restart the computer, please do so immediately.
Following that, Download
DDS.scr by sUBs from one of the following links and save it to your desktop.
Link 1Link 2- Double-Click dds.scr and a command window will appear. This is normal
- Shortly after two logs will appear, DDS.txt & Attach.txt
- A window will open instructing you save & post the logs
- Save the logs to a convenient place such as your desktop
- Copy the contents of both logs & post in your next reply
Due to the length of the logs, it may be necessary to create two replies in order to provide all the requested information.
