Author Topic: Help with Virus/Malware please!!  (Read 1165 times)
Offline a-mazing
« on: June 28, 2011, 01:18:12 AM »
My daughter's laptop has a virus/malware problem.  When you turn the computer on a page opens that says "Malware Protection"  It looks like a legitimate computer anti-virus program but I'm sure it's not.  Any attempt you make to open a program whether it's internet or otherwise a box pops up that says "Security Warning!  Malicious program has been detected. Click here to protect your computer"  I was going to run a virus scan, but I can't.  What do I do??  Thank you very much for your help!  After I get rid of it, what anti-virus and anti-malware programs would you recommend?  The operating system is Windows 7.
Re: Help with Virus/Malware please!!
« Reply #1 on: June 28, 2011, 01:43:38 AM »
Hi, a-mazing.
Let's take care of the rogue first and then we'll take a look at security programs for your daughter's laptop.  Please follow the instructions below in the order provided.  Note that it may take more than one reply to get all the requested logs to post.
1.  Please restart the computer in Safe Mode with Networking. (To do this, turn your computer off and then back on and immediately when you see anything on the screen, start tapping the F8 key on your keyboard. Using the arrow keys on your keyboard, select Safe Mode with Networking and press Enter on your keyboard. Windows will now boot into safe mode with networking and prompt you to login as a user.)
2)  Please download the TDSSKiller.exe by Kaspersky... save it to your Desktop. <-Important!!!
  • Double-click on TDSSKiller.exe to run the tool for known TDSS variants.
    Vista - W7 users: Right-click and select "Run As Administrator".
    If TDSSKiller does not run... rename it. Right-click on TDSSKiller.exe, select Rename and give it a random name with the .com file extension (i.e. ektfhtw.com).
    If you don't see file extensions, please see:  How to change the file extension.
  • Click the Start Scan button.  Do not use the computer during the scan!
  • If the scan completes with nothing found, click Close to exit.
  • If malicious objects are found, they will show in the "Scan results - Select action for found objects[/b]" and offer 3 options.
    • Ensure Cure (default) is selected... then click Continue > Reboot now to finish the cleaning process.
  • A log file named TDSSKiller_version_dd.mm.yyyy_hh.mm.ss_log.txt will be created and saved to the root directory. (usually Local Disk C:).
  • Copy and paste the contents of that file in your next reply.
Note:  If TDSSKiller requires you to reboot, please allow it to do so. After you reboot, reboot back into Safe Mode with Networking again.
3.  Please download rkill from one of the following links and save to your Desktop:
One, Two,Three or Four
  • Double-click rkill to run.
Note: If you you receive security warnings about rkill, please ignore and allow the download to continue.
4.  Please download Malwarebytes' Anti-Malware to your desktop.
  • Click Finish.
  • Click Remove Selected.
** Note **
5.  Download DDS.scr by sUBs from one of the following links and save it to your desktop.
Link 1
Link 2
6.  Download Security Check by screen317 from here or here.
  • Save it to your Desktop.
  • Double click SecurityCheck.exe and follow the onscreen instructions inside of the black box.
  • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
Requested logs:
TDSSKiller
Malwarebytes
Both DDS.txt and Attach.txt
checkup.txt
Offline a-mazing
« Reply #2 on: June 28, 2011, 03:14:36 AM »
Malwarebytes' Anti-Malware 1.51.0.1200
www.malwarebytes.org
Database version: 6964
Windows 6.1.7600 (Safe Mode)
Internet Explorer 8.0.7600.16385
6/27/2011 11:03:27 PM
mbam-log-2011-06-27 (23-03-27).txt
Scan type: Quick scan
Objects scanned: 166285
Time elapsed: 3 minute(s), 36 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 1
Folders Infected: 0
Files Infected: 9
(No malicious items detected)
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\Malware Protection (Trojan.FakeAlert) -> Value: Malware Protection -> Quarantined and deleted successfully.
Folders Infected:
Files Infected:
c:\Users\hellacious\AppData\Roaming\defender.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\hellacious\AppData\Local\Temp\37C8.tmp (Spyware.Passwords.XGen) -> Quarantined and deleted successfully.
c:\Users\hellacious\AppData\Local\Temp\42D0.tmp (Spyware.Passwords.XGen) -> Quarantined and deleted successfully.
c:\Users\hellacious\AppData\Local\Temp\Low\9b88.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\hellacious\AppData\Local\Temp\Low\oxn.dll (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\hellacious\AppData\Local\Temp\Low\oxn.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\hellacious\AppData\Local\Temp\Low\qgl.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\hellacious\AppData\Local\Temp\Low\R66v.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\hellacious\AppData\Local\Temp\Low\jymagvksb\kpqpufyxsik.exe (Trojan.FakeAlertRP.Gen) -> Quarantined and deleted successfully.
this is the results of the malwarebytes scan.  I'm still working
Offline a-mazing
« Reply #3 on: June 28, 2011, 03:43:47 AM »
DDS (Ver_2011-06-23.01) - NTFSAMD64
Internet Explorer: 8.0.7600.16385
Run by Hellacious at 23:37:48 on 2011-06-27
Microsoft Windows 7 Home Premium   6.1.7600.0.1252.1.1033.18.2811.1514 [GMT -4:00]
SP: Windows Defender *Enabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
C:\Windows\system32\lsm.exe
C:\Windows\system32\svchost.exe -k RPCSS
C:\Windows\system32\atiesrxx.exe
C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted
C:\Windows\system32\atieclxx.exe
C:\Windows\system32\WLANExt.exe
C:\Windows\system32\conhost.exe
C:\Windows\System32\spoolsv.exe
C:\Windows\system32\atibtmon.exe
C:\Windows\system32\svchost.exe -k LocalServiceAndNoImpersonation
C:\Program Files\Realtek\Audio\HDA\AERTSr64.exe
C:\Program Files (x86)\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe
C:\Program Files (x86)\Hewlett-Packard\Shared\HPDrvMntSvc.exe
C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch\HPWMISVC.exe
C:\Program Files (x86)\Common Files\LightScribe\LSSrvc.exe
C:\Program Files (x86)\Norton Internet Security\Engine\18.6.0.29\ccSvcHst.exe
C:\Program Files (x86)\Symantec\Norton Online Backup\NOBuAgent.exe
C:\Program Files (x86)\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
C:\Program Files (x86)\Microsoft Application Virtualization Client\sftvsa.exe
C:\Windows\system32\svchost.exe -k imgsvc
C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE
C:\Program Files (x86)\Microsoft Application Virtualization Client\sftlist.exe
C:\Program Files (x86)\Common Files\Microsoft Shared\Virtualization Handler\CVHSVC.EXE
C:\Windows\system32\taskhost.exe
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Windows\system32\SearchIndexer.exe
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
C:\Program Files (x86)\Hewlett-Packard\HP Advisor\Dock\HPAdvisorDock.exe
C:\Program Files (x86)\Common Files\LightScribe\LightScribeControlPanel.exe
C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe
C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch\HPMSGSVC.exe
C:\Program Files (x86)\Hewlett-Packard\Shared\hpqwmiex.exe
C:\Program Files\Synaptics\SynTP\SynTPHelper.exe
C:\Program Files\Windows Media Player\wmpnetwk.exe
C:\Windows\System32\svchost.exe -k LocalServicePeerNet
C:\Windows\system32\DllHost.exe
C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\MOM.exe
C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CCC.exe
C:\Windows\system32\taskeng.exe
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe
C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
C:\Program Files\Hewlett-Packard\HP Wireless Assistant\HPWA_Main.exe
C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbam.exe
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe
C:\Program Files (x86)\Hewlett-Packard\HP Health Check\hphc_service.exe
C:\Program Files (x86)\Hewlett-Packard\HP Advisor\HPAdvisor.exe
C:\Program Files\Hewlett-Packard\HP Wireless Assistant\HPWA_Service.exe
C:\Program Files\Realtek\RtVOsd\RtVOsdService.exe
C:\Program Files\Realtek\RtVOsd\RtVOsd.exe
C:\Windows\System32\svchost.exe -k secsvcs
C:\Program Files (x86)\Hewlett-Packard\Shared\hpCaslNotification.exe
C:\Windows\Microsoft.Net\Framework64\v3.0\WPF\PresentationFontCache.exe
C:\Program Files (x86)\Internet Explorer\iexplore.exe
C:\Program Files (x86)\Microsoft\Search Enhancement Pack\SCServer\SCServer.exe
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil10h_ActiveX.exe
C:\Windows\system32\wuauclt.exe
C:\Windows\system32\svchost.exe -k SDRSVC
C:\Windows\system32\consent.exe
C:\Windows\SysWOW64\cmd.exe
C:\Windows\SysWOW64\cscript.exe
uStart Page = hxxp://www.theinfamousmag.com/
mWinlogon: Userinit=userinit.exe,
BHO: Adobe PDF Link Helper: {18df081c-e8ad-4283-a596-fa578c2ebdc3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
BHO: {5C255C8A-E604-49b4-9D64-90988571CECB} - No File
BHO: Symantec NCO BHO: {602adb0e-4aff-4217-8aa1-95dac4dfa408} - C:\Program Files (x86)\Norton Internet Security\Engine\18.6.0.29\coIEPlg.dll
BHO: Symantec Intrusion Prevention: {6d53ec84-6aae-4787-aeee-f4628f01010c} - C:\Program Files (x86)\Norton Internet Security\Engine\18.6.0.29\IPS\IPSBHO.DLL
BHO: Search Helper: {6ebf7485-159f-4bff-a14f-b9e3aac4465b} - C:\Program Files (x86)\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
BHO: Windows Live ID Sign-in Helper: {9030d464-4c02-4abf-8ecc-5164760863c6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
BHO: Skype Plug-In: {ae805869-2e5c-4ed4-8f7b-f1f7851a4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
BHO: Bing Bar BHO: {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - c:\Program Files (x86)\MSN Toolbar\Platform\6.3.2380.0\npwinext.dll
BHO: Java(tm) Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
TB: Norton Toolbar: {7febefe3-6b19-4349-98d2-ffb09d4b49ca} - C:\Program Files (x86)\Norton Internet Security\Engine\18.6.0.29\coIEPlg.dll
TB: @c:\Program Files (x86)\MSN Toolbar\Platform\6.3.2380.0\npwinext.dll,-100: {8dcb7100-df86-4384-8842-8fa844297b3f} - c:\Program Files (x86)\MSN Toolbar\Platform\6.3.2380.0\npwinext.dll
uRun: [HPAdvisorDock] C:\Program Files (x86)\Hewlett-Packard\HP Advisor\Dock\HPAdvisorDock.exe
uRun: [LightScribe Control Panel] C:\Program Files (x86)\Common Files\LightScribe\LightScribeControlPanel.exe -hidden
mRun: [StartCCC] "C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" MSRun
mRun: [Microsoft Default Manager] "C:\Program Files (x86)\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" -resume
mRun: [Norton Online Backup] C:\Program Files (x86)\Symantec\Norton Online Backup\NOBuClient.exe
mRun: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
mRun: [Adobe Reader Speed Launcher] "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe"
mRun: [HP Quick Launch] C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch\HPMSGSVC.exe
mPolicies-explorer: NoActiveDesktop = 1 (0x1)
mPolicies-system: ConsentPromptBehaviorAdmin = 5 (0x5)
mPolicies-system: ConsentPromptBehaviorUser = 3 (0x3)
IE: {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - {5F7B1267-94A9-47F5-98DB-E99415F33AEC} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
IE: {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_20-windows-i586.cab
DPF: {CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_20-windows-i586.cab
DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_20-windows-i586.cab
TCP: DhcpNameServer = 10.0.0.1
TCP: Interfaces\{B46B8EEB-761B-4C75-880E-C8734A28A45A} : DhcpNameServer = 10.0.0.1
TCP: Interfaces\{B46B8EEB-761B-4C75-880E-C8734A28A45A}\24C4B4245616E6 : DhcpNameServer = 10.0.0.1
TCP: Interfaces\{B46B8EEB-761B-4C75-880E-C8734A28A45A}\7416277237 : DhcpNameServer = 192.168.1.1
TCP: Interfaces\{B46B8EEB-761B-4C75-880E-C8734A28A45A}\E4164756058656C60737 : DhcpNameServer = 10.0.1.1
TCP: Interfaces\{C05AD519-926E-46DA-A286-D6B3A0E85834} : DhcpNameServer = 40.1.1.100
Handler: skype-ie-addon-data - {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
Handler: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~2\COMMON~1\Skype\SKYPE4~1.DLL
mASetup: {10880D85-AAD9-4558-ABDC-2AB1552D831F} - "C:\Program Files (x86)\Common Files\LightScribe\LSRunOnce.exe"
BHO-X64: Adobe PDF Link Helper: {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
BHO-X64:     AcroIEHelperStub - No File
BHO-X64: {5C255C8A-E604-49b4-9D64-90988571CECB} - No File
BHO-X64: Symantec NCO BHO: {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files (x86)\Norton Internet Security\Engine\18.6.0.29\coIEPlg.dll
BHO-X64:     Symantec NCO BHO - No File
BHO-X64: Symantec Intrusion Prevention: {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files (x86)\Norton Internet Security\Engine\18.6.0.29\IPS\IPSBHO.DLL
BHO-X64:     Symantec Intrusion Prevention - No File
BHO-X64: Search Helper: {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files (x86)\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
BHO-X64:     Search Helper - No File
BHO-X64: Windows Live ID Sign-in Helper: {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
BHO-X64: Skype Plug-In: {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
BHO-X64:     SkypeIEPluginBHO - No File
BHO-X64: Bing Bar BHO: {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - c:\Program Files (x86)\MSN Toolbar\Platform\6.3.2380.0\npwinext.dll
BHO-X64: Java(tm) Plug-In 2 SSV Helper: {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
TB-X64: Norton Toolbar: {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files (x86)\Norton Internet Security\Engine\18.6.0.29\coIEPlg.dll
TB-X64: @c:\Program Files (x86)\MSN Toolbar\Platform\6.3.2380.0\npwinext.dll,-100: {8dcb7100-df86-4384-8842-8fa844297b3f} - c:\Program Files (x86)\MSN Toolbar\Platform\6.3.2380.0\npwinext.dll
mRun-x64: [StartCCC] "C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" MSRun
mRun-x64: [Microsoft Default Manager] "C:\Program Files (x86)\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" -resume
mRun-x64: [Norton Online Backup] C:\Program Files (x86)\Symantec\Norton Online Backup\NOBuClient.exe
mRun-x64: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
mRun-x64: [Adobe Reader Speed Launcher] "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe"
mRun-x64: [HP Quick Launch] C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch\HPMSGSVC.exe
and Attach:
Boot Device: \Device\HarddiskVolume1
Install Date: 2/12/2011 9:17:08 AM
System Uptime: 6/27/2011 11:06:38 PM (0 hours ago)
Motherboard: Hewlett-Packard |  | 1444
Processor: AMD Athlon(tm) II P340 Dual-Core Processor | Socket S1G4 | 792/200mhz
C: is FIXED (NTFS) - 280 GiB total, 233.607 GiB free.
D: is FIXED (NTFS) - 17 GiB total, 2.509 GiB free.
E: is CDROM ()
RP48: 5/29/2011 8:41:15 PM - Windows Backup
RP49: 5/31/2011 2:27:22 PM - Windows Update
RP50: 6/3/2011 6:28:57 PM - Windows Update
RP51: 6/5/2011 8:24:43 PM - Windows Backup
RP52: 6/7/2011 5:32:30 PM - Windows Update
RP53: 6/11/2011 2:53:55 PM - Windows Update
RP54: 6/12/2011 7:00:14 PM - Windows Backup
RP55: 6/15/2011 8:10:02 PM - Windows Update
RP56: 6/16/2011 1:16:19 AM - Windows Update
RP57: 6/17/2011 4:35:24 PM - Windows Update
RP58: 6/18/2011 12:21:24 PM - Windows Update
RP59: 6/18/2011 7:55:27 PM - Windows Update
RP60: 6/21/2011 12:18:14 PM - Windows Update
RP61: 6/21/2011 12:23:40 PM - Windows Backup
RP62: 6/26/2011 11:49:48 PM - Removed Norton Online Backup
RP63: 6/27/2011 9:21:54 PM - Windows Backup
RP64: 6/27/2011 11:11:55 PM - Windows Update
Acrobat.com
ActiveCheck component for HP Active Support Library
Adobe AIR
Adobe Flash Player 10 ActiveX
Adobe Reader 9.3 MUI
Adobe Shockwave Player 11.5
AIM 7
AMD USB Filter Driver
Atheros Driver Installation Program
Bejeweled 2 Deluxe
Bing Bar
Bing Bar Platform
Bing Rewards Client Installer
Blackhawk Striker 2
Build-a-lot 2
Catalyst Control Center - Branding
Catalyst Control Center Core Implementation
Catalyst Control Center Graphics Full Existing
Catalyst Control Center Graphics Full New
Catalyst Control Center Graphics Light
Catalyst Control Center Graphics Previews Common
Catalyst Control Center Graphics Previews Vista
Catalyst Control Center InstallProxy
Catalyst Control Center Localization All
ccc-core-static
CCC Help Chinese Standard
CCC Help Chinese Traditional
CCC Help Czech
CCC Help Danish
CCC Help Dutch
CCC Help English
CCC Help Finnish
CCC Help French
CCC Help German
CCC Help Greek
CCC Help Hungarian
CCC Help Italian
CCC Help Japanese
CCC Help Korean
CCC Help Norwegian
CCC Help Polish
CCC Help Portuguese
CCC Help Russian
CCC Help Spanish
CCC Help Swedish
CCC Help Thai
CCC Help Turkish
Chuzzle Deluxe
Cisco Connect
Cisco EAP-FAST Module
Cisco LEAP Module
Cisco PEAP Module
CyberLink DVD Suite
CyberLink MediaShow
CyberLink PowerDVD 9
CyberLink YouCam
Diner Dash 2 Restaurant Rescue
Dora's Carnival Adventure
Download Updater (AOL LLC)
Energy Star Digital Logo
Escape Rosecliff Island
ESU for Microsoft Windows 7
FATE
Final Drive Nitro
Google Earth Plug-in
Google Update Helper
Heroes of Hellas 2 - Olympia
HP Advisor
HP Customer Experience Enhancements
HP Documentation
HP Game Console
HP Games
HP MediaSmart CinemaNow 2.0
HP Photo Creations
HP Power Manager
HP Quick Launch
HP Setup
HP Software Framework
HP Support Assistant
HPAsset component for HP Active Support Library
Java Auto Updater
Java(TM) 6 Update 20
Jewel Quest 3
Jewel Quest Solitaire 2
Junk Mail filter update
LabelPrint
LightScribe System Software
Malwarebytes' Anti-Malware version 1.51.0.1200
Microsoft Choice Guard
Microsoft Office 2010
Microsoft Office Click-to-Run 2010
Microsoft Office Starter 2010 - English
Microsoft Search Enhancement Pack
Microsoft Silverlight
Microsoft SQL Server 2005 Compact Edition [ENU]
Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
Microsoft WSE 3.0 Runtime
MSVCRT
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 (KB973688)
Penguins!
PhotoNow!
Plants vs. Zombies
Poker Superstars III
Polar Bowler
Polar Golfer
Power2Go
PowerDirector
Realtek Ethernet Controller Driver For Windows 7
Realtek High Definition Audio Driver
Realtek USB 2.0 Card Reader
Recovery Manager
Roxio CinemaNow 2.0
Security Update for Microsoft .NET Framework 4 Client Profile (KB2446708)
Security Update for Microsoft .NET Framework 4 Client Profile (KB2478663)
Security Update for Microsoft .NET Framework 4 Client Profile (KB2518870)
Skype Toolbars
Skype™ 5.1
Virtual Families
Virtual Villagers - The Secret City
Wheel of Fortune 2
Windows Live Call
Windows Live Communications Platform
Windows Live Essentials
Windows Live Mail
Windows Live Messenger
Windows Live Movie Maker
Windows Live Photo Gallery
Windows Live Sync
Windows Live Upload Tool
Windows Live Writer
Yahoo! BrowserPlus 2.9.8
Zuma Deluxe
6/27/2011 11:09:06 PM, Error: NetBT [4321]  - The name "WORKGROUP      :1d" could not be registered on the interface with IP address 10.0.0.30. The computer with the IP address 10.0.0.5 did not allow the name to be claimed by this computer.
6/27/2011 11:03:30 PM, Error: Service Control Manager [7001]  - The Computer Browser service depends on the Server service which failed to start because of the following error:  The dependency service or group failed to start.
6/27/2011 10:36:36 PM, Error: Microsoft-Windows-DistributedCOM [10005]  - DCOM got error "1068" attempting to start the service fdPHost with arguments "" in order to run the server: {D3DCB472-7261-43CE-924B-0704BD730D5F}
6/27/2011 10:36:36 PM, Error: Microsoft-Windows-DistributedCOM [10005]  - DCOM got error "1068" attempting to start the service fdPHost with arguments "" in order to run the server: {145B4335-FE2A-4927-A040-7C35AD3180EF}
6/27/2011 10:32:55 PM, Error: Service Control Manager [7001]  - The HomeGroup Provider service depends on the Function Discovery Provider Host service which failed to start because of the following error:  The dependency service or group failed to start.
6/27/2011 10:29:51 PM, Error: Microsoft-Windows-WLAN-AutoConfig [10000]  - WLAN Extensibility Module has failed to start. Module Path: C:\Windows\system32\athihvs.dll Error Code: 21
6/27/2011 10:29:50 PM, Error: Microsoft-Windows-DistributedCOM [10005]  - DCOM got error "1084" attempting to start the service WSearch with arguments "" in order to run the server: {9E175B6D-F52A-11D8-B9A5-505054503030}
6/27/2011 10:29:49 PM, Error: Microsoft-Windows-DistributedCOM [10005]  - DCOM got error "1084" attempting to start the service WSearch with arguments "" in order to run the server: {7D096C5F-AC08-4F1F-BEB7-5C22C517CE39}
6/27/2011 10:29:48 PM, Error: Microsoft-Windows-DistributedCOM [10005]  - DCOM got error "1084" attempting to start the service EventSystem with arguments "" in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
6/27/2011 10:29:43 PM, Error: Microsoft-Windows-DistributedCOM [10005]  - DCOM got error "1084" attempting to start the service ShellHWDetection with arguments "" in order to run the server: {DD522ACC-F821-461A-A407-50B198B896DC}
6/27/2011 10:29:34 PM, Error: Service Control Manager [7026]  - The following boot-start or system-start driver(s) failed to load:  BHDrvx64 discache eeCtrl IDSVia64 spldr SRTSPX SymIRON SymNetS Wanarpv6
6/27/2011 10:29:33 PM, Error: Service Control Manager [7001]  - The Client Virtualization Handler service depends on the Application Virtualization Client service which failed to start because of the following error:  The dependency service or group failed to start.
Offline a-mazing
« Reply #4 on: June 28, 2011, 03:49:13 AM »
Results of screen317's Security Check version 0.99.17
 Windows 7  (UAC is enabled)
 Internet Explorer 8
Antivirus/Firewall Check:
 Windows Firewall Enabled!
 WMI entry may not exist for antivirus; attempting automatic update.
Anti-malware/Other Utilities Check:
 Out of date Java installed!
 Adobe Flash Player
Process Check:
objlist.exe by Laurent
 Norton ccSvcHst.exe
``````````End of Log````````````
Offline a-mazing
« Reply #5 on: June 28, 2011, 03:52:29 AM »
 :mitch: I've completed everything and think I have all the logs.  The TDSSkiller didn't find anything so there was no log.  I'm ready for the next set of instructions.
Thank you so much!  You're an angel!
« Reply #6 on: June 28, 2011, 02:14:56 PM »
That was fast work!
Please download JavaRa and unzip it to your desktop.
  • Double-click on JavaRa.exe to start the program.  (Windows Vista users Right-click JavaRa.exe > Select Run as Administrator)
Then download and install Java SE Runtime Environment 6u26.
Note:  UNCHECK any pre-checked toolbar and/or software options presented with the update.  They are not part of the software update and are completely optional.
Next, since the Malware Protection rogue is particularly nasty, please do the folloiwng:
Link 1
Link 2
Now, please run ComboFix:
Offline a-mazing
« Reply #7 on: June 29, 2011, 09:53:02 PM »
ComboFix 11-06-29.06 - Hellacious 06/29/2011  17:33:03.4.2 - x64
Microsoft Windows 7 Home Premium   6.1.7600.0.1252.1.1033.18.2811.1852 [GMT -4:00]
Running from: c:\users\Hellacious\Desktop\ComboFix.exe
   /wow section - STAGE 50
The process cannot access the file because it is being used by another process.
The system cannot find the file LockedB.
The system cannot find the file lockedB.
'.d.a.1.a.3.f.f.' is not recognized as an internal or external command
'.0.\\.' is not recognized as an internal or external command
(((((((((((((((((((((((((   Files Created from 2011-05-28 to 2011-06-29  )))))))))))))))))))))))))))))))
2011-06-29 21:40 . 2011-06-29 21:40   --------   d-----w-   c:\users\Default\AppData\Local\temp
2011-06-29 01:16 . 2011-06-29 01:16   --------   d-----w-   c:\program files (x86)\Common Files\Java
2011-06-29 01:15 . 2011-06-29 01:15   --------   d-----w-   c:\program files (x86)\Java
2011-06-28 02:58 . 2011-06-28 02:58   --------   d-----w-   c:\users\Hellacious\AppData\Roaming\Malwarebytes
2011-06-28 02:58 . 2011-05-29 13:11   39984   ----a-w-   c:\windows\SysWow64\drivers\mbamswissarmy.sys
2011-06-28 02:58 . 2011-06-28 02:58   --------   d-----w-   c:\programdata\Malwarebytes
2011-06-28 02:58 . 2011-05-29 13:11   25912   ----a-w-   c:\windows\system32\drivers\mbam.sys
2011-06-28 02:58 . 2011-06-28 02:58   --------   d-----w-   c:\program files (x86)\Malwarebytes' Anti-Malware
2011-06-28 02:27 . 2011-06-28 02:27   --------   d-----w-   c:\users\Hellacious\AppData\Local\ElevatedDiagnostics
2011-06-19 00:45 . 2011-06-19 00:45   --------   d-----w-   c:\programdata\Recovery
2011-06-16 00:12 . 2011-04-27 02:57   102400   ----a-w-   c:\windows\system32\drivers\dfsc.sys
2011-06-16 00:12 . 2011-04-25 05:32   1896832   ----a-w-   c:\windows\system32\drivers\tcpip.sys
2011-06-16 00:12 . 2011-04-25 02:44   499712   ----a-w-   c:\windows\system32\drivers\afd.sys
2011-06-16 00:12 . 2011-04-29 05:47   1110528   ----a-w-   c:\program files\Common Files\Microsoft Shared\VGX\VGX.dll
2011-06-16 00:12 . 2011-04-29 05:08   759296   ----a-w-   c:\program files (x86)\Common Files\Microsoft Shared\VGX\VGX.dll
2011-06-16 00:10 . 2011-04-29 03:12   399872   ----a-w-   c:\windows\system32\drivers\srv2.sys
2011-06-16 00:10 . 2011-04-29 03:13   461312   ----a-w-   c:\windows\system32\drivers\srv.sys
2011-06-16 00:10 . 2011-04-29 03:12   161792   ----a-w-   c:\windows\system32\drivers\srvnet.sys
2011-06-16 00:10 . 2010-12-18 06:13   861184   ----a-w-   c:\windows\system32\oleaut32.dll
2011-06-16 00:10 . 2010-12-18 05:31   571904   ----a-w-   c:\windows\SysWow64\oleaut32.dll
2011-06-16 00:10 . 2011-05-03 05:21   976896   ----a-w-   c:\windows\system32\inetcomm.dll
2011-06-16 00:10 . 2011-05-03 04:50   740864   ----a-w-   c:\windows\SysWow64\inetcomm.dll
2011-06-13 04:50 . 2011-06-13 04:50   --------   d-----w-   c:\program files (x86)\Google
2011-06-13 04:50 . 2011-06-13 04:50   --------   d-----w-   c:\users\Hellacious\AppData\Local\Google
2011-06-29 01:15 . 2010-07-11 05:29   472808   ----a-w-   c:\windows\SysWow64\deployJava1.dll
2011-05-24 23:14 . 2011-04-14 05:11   270720   ------w-   c:\windows\system32\MpSigStub.exe
2011-04-30 18:03 . 2011-04-30 18:04   2048104   ----a-w-   c:\windows\system32\RtPgEx64.dll
2011-04-30 18:03 . 2011-04-30 18:04   1146984   ----a-w-   c:\windows\system32\RTSnMg64.cpl
2011-04-30 18:03 . 2011-04-30 18:04   332392   ----a-w-   c:\windows\system32\RtlCPAPI64.dll
2011-04-30 18:03 . 2011-04-30 18:04   569960   ----a-w-   c:\windows\system32\RtkApi64.dll
2011-04-30 18:03 . 2011-04-30 18:04   2625640   ----a-w-   c:\windows\system32\RtkAPO64.dll
2011-04-30 18:03 . 2011-04-30 18:04   2494056   ----a-w-   c:\windows\system32\drivers\RTKVHD64.sys
2011-04-30 18:03 . 2011-04-30 18:04   149608   ----a-w-   c:\windows\system32\RtkCfg64.dll
2011-04-30 18:03 . 2011-04-30 18:04   1215592   ----a-w-   c:\windows\system32\RTCOM64.dll
2011-04-30 18:03 . 2011-04-30 18:04   80488   ----a-w-   c:\windows\system32\RCoInst64.dll
2011-04-30 18:02 . 2011-04-30 18:04   200800   ----a-w-   c:\windows\system32\AERTAC64.dll
2011-04-30 18:02 . 2010-11-20 08:42   1251944   ----a-w-   c:\windows\RtlExUpd.dll
2011-04-22 20:18 . 2011-05-24 21:33   27008   ----a-w-   c:\windows\system32\drivers\Diskdump.sys
2011-04-09 06:58 . 2011-05-17 12:20   142336   ----a-w-   c:\windows\system32\poqexec.exe
2011-04-09 06:45 . 2011-05-10 23:37   5509504   ----a-w-   c:\windows\system32\ntoskrnl.exe
2011-04-09 06:13 . 2011-05-10 23:37   3957632   ----a-w-   c:\windows\SysWow64\ntkrnlpa.exe
2011-04-09 06:13 . 2011-05-10 23:37   3901824   ----a-w-   c:\windows\SysWow64\ntoskrnl.exe
2011-04-09 05:56 . 2011-05-17 12:20   123904   ----a-w-   c:\windows\SysWow64\poqexec.exe
(((((((((((((((((((((((((((((   SnapShot_2011-06-29_04.57.38   )))))))))))))))))))))))))))))))))))))))))
+ 2011-06-29 01:04 . 2011-05-04 04:52   86528              c:\windows\SysWOW64\SearchFilterHost.exe
- 2009-07-14 00:13 . 2009-07-14 01:14   86528              c:\windows\SysWOW64\SearchFilterHost.exe
- 2009-07-14 00:12 . 2009-07-14 01:15   59392              c:\windows\SysWOW64\msscntrs.dll
+ 2011-06-29 01:04 . 2011-05-04 04:52   59392              c:\windows\SysWOW64\msscntrs.dll
+ 2011-06-29 01:04 . 2011-05-24 10:34   44544              c:\windows\SysWOW64\devrtl.dll
- 2009-07-13 23:16 . 2009-07-14 01:15   44544              c:\windows\SysWOW64\devrtl.dll
- 2009-07-13 23:16 . 2009-07-14 01:15   64512              c:\windows\SysWOW64\devobj.dll
+ 2011-06-29 01:04 . 2011-05-24 10:34   64512              c:\windows\SysWOW64\devobj.dll
+ 2011-06-29 21:41 . 2011-06-29 21:41   13366              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\SoftGrid Client\Icon Cache\icon_ex.dat
- 2011-06-29 04:55 . 2011-06-29 04:55   13366              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\SoftGrid Client\Icon Cache\icon_ex.dat
+ 2009-07-14 04:54 . 2011-06-29 21:41   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2009-07-14 04:54 . 2011-06-29 04:56   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2009-07-14 04:54 . 2011-06-29 04:56   32768              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2009-07-14 04:54 . 2011-06-29 21:41   32768              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2009-07-14 04:54 . 2011-06-29 21:41   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
- 2009-07-14 04:54 . 2011-06-29 04:56   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2010-07-11 03:12 . 2011-06-29 21:43   44762              c:\windows\system32\wdi\ShutdownPerformanceDiagnostics_SystemData.bin
+ 2009-07-14 05:10 . 2011-06-29 21:43   37054              c:\windows\system32\wdi\BootPerformanceDiagnostics_SystemData.bin
- 2009-07-14 05:10 . 2011-06-29 04:59   37054              c:\windows\system32\wdi\BootPerformanceDiagnostics_SystemData.bin
+ 2011-02-12 14:18 . 2011-06-29 21:43   14724              c:\windows\system32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-1227915785-3733434846-2752287559-1001_UserData.bin
+ 2011-06-29 01:04 . 2011-05-04 05:28   75264              c:\windows\system32\msscntrs.dll
- 2009-07-14 00:29 . 2009-07-14 01:41   75264              c:\windows\system32\msscntrs.dll
+ 2011-02-12 18:14 . 2011-06-29 21:29   16384              c:\windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2011-02-12 18:14 . 2011-06-29 01:29   16384              c:\windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2011-02-12 18:14 . 2011-06-29 21:29   32768              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2011-02-12 18:14 . 2011-06-29 01:29   32768              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2009-07-14 04:54 . 2011-06-29 21:29   16384              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
- 2009-07-14 04:54 . 2011-06-29 01:29   16384              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2011-02-13 16:01 . 2011-06-29 21:43   16384              c:\windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2011-02-13 16:01 . 2011-06-29 04:58   16384              c:\windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2009-07-14 04:46 . 2011-06-29 21:35   78344              c:\windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareProtectionPlatform\Cache\cache.dat
+ 2011-02-13 16:01 . 2011-06-29 21:43   32768              c:\windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2011-02-13 16:01 . 2011-06-29 04:58   32768              c:\windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2011-02-13 16:01 . 2011-06-29 04:58   16384              c:\windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2011-02-13 16:01 . 2011-06-29 21:43   16384              c:\windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
- 2011-02-12 14:18 . 2011-06-29 04:58   16384              c:\windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2011-02-12 14:18 . 2011-06-29 21:43   16384              c:\windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2011-02-12 14:18 . 2011-06-29 21:43   16384              c:\windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
- 2011-02-12 14:18 . 2011-06-29 04:58   16384              c:\windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
- 2011-06-29 04:56 . 2011-06-29 04:56   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
+ 2011-06-29 21:41 . 2011-06-29 21:41   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
- 2011-06-29 04:56 . 2011-06-29 04:56   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2011-06-29 21:41 . 2011-06-29 21:41   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2011-06-29 01:04 . 2011-05-04 04:52   164352              c:\windows\SysWOW64\SearchProtocolHost.exe
- 2009-07-14 00:14 . 2009-07-14 01:14   164352              c:\windows\SysWOW64\SearchProtocolHost.exe
+ 2011-06-29 01:04 . 2011-05-04 04:52   428032              c:\windows\SysWOW64\SearchIndexer.exe
- 2009-07-14 00:14 . 2009-07-14 01:14   428032              c:\windows\SysWOW64\SearchIndexer.exe
- 2009-07-14 00:13 . 2009-07-14 01:15   666624              c:\windows\SysWOW64\mssvp.dll
+ 2011-06-29 01:04 . 2011-05-04 04:52   666624              c:\windows\SysWOW64\mssvp.dll
+ 2011-06-29 01:04 . 2011-05-04 04:52   197120              c:\windows\SysWOW64\mssphtb.dll
- 2009-07-14 00:14 . 2009-07-14 01:15   197120              c:\windows\SysWOW64\mssphtb.dll
+ 2011-06-29 01:04 . 2011-05-04 04:52   337408              c:\windows\SysWOW64\mssph.dll
- 2009-07-14 00:13 . 2009-07-14 01:15   337408              c:\windows\SysWOW64\mssph.dll
- 2009-07-13 23:16 . 2009-07-14 01:14   252928              c:\windows\SysWOW64\drvinst.exe
+ 2011-06-29 01:04 . 2011-05-24 10:32   252928              c:\windows\SysWOW64\drvinst.exe
- 2009-07-13 23:16 . 2009-07-14 01:15   145920              c:\windows\SysWOW64\cfgmgr32.dll
+ 2011-06-29 01:04 . 2011-05-24 10:34   145920              c:\windows\SysWOW64\cfgmgr32.dll
+ 2011-02-12 02:48 . 2011-06-29 21:26   258680              c:\windows\system32\wdi\SuspendPerformanceDiagnostics_SystemData_S3.bin
+ 2011-06-29 01:04 . 2011-05-24 11:21   404992              c:\windows\system32\umpnpmgr.dll
- 2009-07-14 00:30 . 2009-07-14 01:39   249856              c:\windows\system32\SearchProtocolHost.exe
+ 2011-06-29 01:04 . 2011-05-04 05:24   249856              c:\windows\system32\SearchProtocolHost.exe
- 2009-07-14 00:32 . 2009-07-14 01:39   593408              c:\windows\system32\SearchIndexer.exe
+ 2011-06-29 01:04 . 2011-05-04 05:24   593408              c:\windows\system32\SearchIndexer.exe
+ 2011-06-29 01:04 . 2011-05-04 05:24   113664              c:\windows\system32\SearchFilterHost.exe
- 2009-07-14 00:29 . 2009-07-14 01:39   113664              c:\windows\system32\SearchFilterHost.exe
- 2009-07-14 02:36 . 2011-06-29 03:50   624622              c:\windows\system32\perfh009.dat
+ 2009-07-14 02:36 . 2011-06-29 21:27   624622              c:\windows\system32\perfh009.dat
+ 2009-07-14 02:36 . 2011-06-29 21:27   106708              c:\windows\system32\perfc009.dat
- 2009-07-14 02:36 . 2011-06-29 03:50   106708              c:\windows\system32\perfc009.dat
- 2009-07-14 00:30 . 2009-07-14 01:41   779264              c:\windows\system32\mssvp.dll
+ 2011-06-29 01:04 . 2011-05-04 05:28   779264              c:\windows\system32\mssvp.dll
- 2009-07-14 00:32 . 2009-07-14 01:41   288256              c:\windows\system32\mssphtb.dll
+ 2011-06-29 01:04 . 2011-05-04 05:28   288256              c:\windows\system32\mssphtb.dll
+ 2011-06-29 01:04 . 2011-05-04 05:28   491520              c:\windows\system32\mssph.dll
- 2009-07-14 00:30 . 2009-07-14 01:41   491520              c:\windows\system32\mssph.dll
- 2009-07-14 04:45 . 2011-06-16 19:55   285448              c:\windows\system32\FNTCACHE.DAT
+ 2009-07-14 04:45 . 2011-06-29 21:29   285448              c:\windows\system32\FNTCACHE.DAT
+ 2009-07-14 05:01 . 2011-06-29 21:41   234640              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-System.dat
+ 2011-02-12 03:22 . 2011-06-29 21:41   679392              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-S-1-5-21-1227915785-3733434846-2752287559-1001-8192.dat
+ 2011-06-29 01:04 . 2011-05-04 04:53   1553920              c:\windows\SysWOW64\tquery.dll
+ 2011-06-29 01:04 . 2011-05-04 04:52   1401856              c:\windows\SysWOW64\mssrch.dll
- 2009-07-14 00:13 . 2009-07-14 01:15   1401856              c:\windows\SysWOW64\mssrch.dll
+ 2011-06-29 01:04 . 2011-05-04 05:30   2326016              c:\windows\system32\tquery.dll
+ 2009-07-14 02:34 . 2011-06-29 21:40   9961472              c:\windows\system32\SMI\Store\Machine\SCHEMA.DAT
- 2009-07-14 02:34 . 2011-06-29 03:06   9961472              c:\windows\system32\SMI\Store\Machine\SCHEMA.DAT
+ 2011-06-29 01:04 . 2011-05-04 05:28   2228224              c:\windows\system32\mssrch.dll
- 2009-07-14 00:35 . 2009-07-14 01:41   2228224              c:\windows\system32\mssrch.dll
+ 2009-07-14 04:45 . 2011-06-29 21:35   3777877              c:\windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareProtectionPlatform\tokens.dat
- 2009-07-14 04:45 . 2011-06-19 00:15   3777877              c:\windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareProtectionPlatform\tokens.dat
-- Snapshot reset to current date --
REGEDIT4
"HPAdvisorDock"="c:\program files (x86)\Hewlett-Packard\HP Advisor\Dock\HPAdvisorDock.exe" [2010-02-10 1712184]
"LightScribe Control Panel"="c:\program files (x86)\Common Files\LightScribe\LightScribeControlPanel.exe" [2010-05-19 2736128]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run]
"StartCCC"="c:\program files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" [2010-06-17 98304]
"Microsoft Default Manager"="c:\program files (x86)\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" [2010-05-10 439568]
"Adobe ARM"="c:\program files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2009-12-11 948672]
"Adobe Reader Speed Launcher"="c:\program files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-12-22 35760]
"HP Quick Launch"="c:\program files (x86)\Hewlett-Packard\HP Quick Launch\HPMSGSVC.exe" [2010-11-09 586296]
"SunJavaUpdateSched"="c:\program files (x86)\Common Files\Java\Java Update\jusched.exe" [2011-04-08 254696]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
"ConsentPromptBehaviorAdmin"= 5 (0x5)
"ConsentPromptBehaviorUser"= 3 (0x3)
"EnableUIADesktopToggle"= 0 (0x0)
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa]
Security Packages   REG_MULTI_SZ      kerberos msv1_0 schannel wdigest tspkg pku2u livessp
R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
R2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;c:\windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-03-18 138576]
R2 gupdate;Google Update Service (gupdate);c:\program files (x86)\Google\Update\GoogleUpdate.exe [2011-06-13 136176]
R2 HP Wireless Assistant Service;HP Wireless Assistant Service;c:\program files\Hewlett-Packard\HP Wireless Assistant\HPWA_Service.exe [2010-06-18 103992]
R2 RtVOsdService;RtVOsdService Installer;c:\program files\Realtek\RtVOsd\RtVOsdService.exe [2010-06-24 315392]
R3 gupdatem;Google Update Service (gupdatem);c:\program files (x86)\Google\Update\GoogleUpdate.exe [2011-06-13 136176]
R3 netw5v64;Intel(R) Wireless WiFi Link 5000 Series Adapter Driver for Windows Vista 64 Bit;c:\windows\system32\DRIVERS\netw5v64.sys
R3 osppsvc;Office Software Protection Platform;c:\program files\Common Files\Microsoft Shared\OfficeSoftwareProtectionPlatform\OSPPSVC.EXE [2010-01-10 4925184]
R3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;c:\windows\system32\Drivers\RtsUStor.sys
R3 SrvHsfHDA;SrvHsfHDA;c:\windows\system32\DRIVERS\VSTAZL6.SYS
R3 SrvHsfV92;SrvHsfV92;c:\windows\system32\DRIVERS\VSTDPV6.SYS
R3 SrvHsfWinac;SrvHsfWinac;c:\windows\system32\DRIVERS\VSTCNXT6.SYS
R3 WatAdminSvc;Windows Activation Technologies Service;c:\windows\system32\Wat\WatAdminSvc.exe
R3 yukonw7;NDIS6.2 Miniport Driver for Marvell Yukon Ethernet Controller;c:\windows\system32\DRIVERS\yk62x64.sys
S1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\DRIVERS\vwififlt.sys
S2 AERTFilters;Andrea RT Filters Service;c:\program files\Realtek\Audio\HDA\AERTSr64.exe [2009-11-18 98208]
S2 AMD External Events Utility;AMD External Events Utility;c:\windows\system32\atiesrxx.exe
S2 CinemaNow Service;CinemaNow Service;c:\program files (x86)\CinemaNow\CinemaNow Media Manager\CinemanowSvc.exe [2010-05-21 140272]
S2 cvhsvc;Client Virtualization Handler;c:\program files (x86)\Common Files\Microsoft Shared\Virtualization Handler\CVHSVC.EXE [2010-02-28 821664]
S2 HPDrvMntSvc.exe;HP Quick Synchronization Service;c:\program files (x86)\Hewlett-Packard\Shared\HPDrvMntSvc.exe [2011-02-04 92216]
S2 HPWMISVC;HPWMISVC;c:\program files (x86)\Hewlett-Packard\HP Quick Launch\HPWMISVC.exe [2010-11-09 26680]
S2 sftlist;Application Virtualization Client;c:\program files (x86)\Microsoft Application Virtualization Client\sftlist.exe [2010-04-24 483688]
S3 amdkmdag;amdkmdag;c:\windows\system32\DRIVERS\atipmdag.sys
S3 amdkmdap;amdkmdap;c:\windows\system32\DRIVERS\atikmpag.sys
S3 RTL8167;Realtek 8167 NT Driver;c:\windows\system32\DRIVERS\Rt64win7.sys
S3 Sftfs;Sftfs;c:\windows\system32\DRIVERS\Sftfslh.sys
S3 Sftplay;Sftplay;c:\windows\system32\DRIVERS\Sftplaylh.sys
S3 Sftredir;Sftredir;c:\windows\system32\DRIVERS\Sftredirlh.sys
S3 Sftvol;Sftvol;c:\windows\system32\DRIVERS\Sftvollh.sys
S3 sftvsa;Application Virtualization Service Agent;c:\program files (x86)\Microsoft Application Virtualization Client\sftvsa.exe [2010-04-24 209768]
S3 usbfilter;AMD USB Filter Driver;c:\windows\system32\DRIVERS\usbfilter.sys
[HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\active setup\installed components\{10880D85-AAD9-4558-ABDC-2AB1552D831F}]
2010-05-19 18:36   451872   ----a-w-   c:\program files (x86)\Common Files\LightScribe\LSRunOnce.exe
2011-06-29 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files (x86)\Google\Update\GoogleUpdate.exe [2011-06-13 04:50]
2011-06-29 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2011-06-06 c:\windows\Tasks\HPCeeScheduleForHellacious.job
- c:\program files (x86)\Hewlett-Packard\HP Ceement\HPCEE.exe [2010-01-05 10:53]
--------- x86-64 -----------
"SynTPEnh"="c:\program files (x86)\Synaptics\SynTP\SynTPEnh.exe" [BU]
"RTHDVCPL"="c:\program files\Realtek\Audio\HDA\RtkNGUI64.exe" [2011-04-30 6489704]
"HPWirelessAssistant"="c:\program files\Hewlett-Packard\HP Wireless Assistant\DelayedAppStarter.exe" [2010-06-18 8192]
uLocal Page = c:\windows\system32\blank.htm
mLocal Page = c:\windows\SysWOW64\blank.htm
--------------------- LOCKED REGISTRY KEYS ---------------------
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10h_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\LocalServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10h_ActiveX.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\TypeLib]
@="{FAB3E735-69C7-453B-A446-B6823C6DF1C9}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}]
@="Shockwave Flash Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10h.ocx"
"ThreadingModel"="Apartment"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID]
@="ShockwaveFlash.ShockwaveFlash.10"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10h.ocx, 1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib]
@="{D27CDB6B-AE6D-11cf-96B8-444553540000}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="ShockwaveFlash.ShockwaveFlash"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}]
@="Macromedia Flash Factory Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\InprocServer32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ProgID]
@="FlashFactory.FlashFactory.1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="FlashFactory.FlashFactory"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}]
@="IFlashBroker4"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\ProxyStubClsid32]
@="{00020424-0000-0000-C000-000000000046}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\PCW\Security]
@Denied: (Full) (Everyone)
c:\windows\system32\atibtmon.exe
c:\program files (x86)\Common Files\LightScribe\LSSrvc.exe
c:\program files (x86)\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
c:\program files (x86)\Hewlett-Packard\Shared\hpqwmiex.exe
Completion time: 2011-06-29  17:47:41 - machine was rebooted
ComboFix-quarantined-files.txt  2011-06-29 21:47
ComboFix2.txt  2011-06-29 05:02
Pre-Run: 251,100,827,648 bytes free
Post-Run: 250,670,796,800 bytes free
- - End Of File - - C124E90F56EE901D457D8BD4ED54322E
not sure about the javara, had trouble with it
« Reply #8 on: June 30, 2011, 12:53:04 AM »
Hi, a-mazing.
In that case, just go to Add/Remove programs and uninstall Java(TM) 6 Update 20.  Then download and install Java SE Runtime Environment 6u26
I am investigating the information about the Stage 50 message in your log and will follow up in due course.
Offline a-mazing
« Reply #9 on: June 30, 2011, 04:15:08 AM »
OK.  Fixed the java issue.  Ready for my next assignment! :thumbsup:
« Reply #10 on: June 30, 2011, 04:38:33 PM »
Hi, a-mazing.
Let's see if a new build of ComboFix solves the errors shown in the log.  Please delete the ComboFix icon on your desktop and download an updated version, running it again, as instructed above and post the resultant log.
Offline a-mazing
« Reply #11 on: July 01, 2011, 02:58:39 AM »
ComboFix 11-06-30.03 - Hellacious 06/30/2011  22:43:58.5.2 - x64
Microsoft Windows 7 Home Premium   6.1.7600.0.1252.1.1033.18.2811.1632 [GMT -4:00]
c:\users\HELLAC~1\AppData\Local\Temp\E1D5.tmp
c:\users\Hellacious\AppData\Local\Temp\E1D5.tmp
(((((((((((((((((((((((((   Files Created from 2011-06-01 to 2011-07-01  )))))))))))))))))))))))))))))))
2011-07-01 02:50 . 2011-07-01 02:50   --------   d-----w-   c:\users\Default\AppData\Local\temp
2011-06-30 04:11 . 2011-06-30 04:11   --------   d-----w-   c:\program files\Java
2011-06-29 04:45 . 2011-06-29 04:45   --------   d-----w-   C:\HP_TOOLS_mountHPSF
2011-06-30 04:11 . 2010-07-11 05:29   525544   ----a-w-   c:\windows\system32\deployJava1.dll
(((((((((((((((((((((((((((((   SnapShot_2011-06-29_21.42.25   )))))))))))))))))))))))))))))))))))))))))
+ 2011-07-01 02:50 . 2011-07-01 02:50   13366              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\SoftGrid Client\Icon Cache\icon_ex.dat
- 2011-06-29 21:41 . 2011-06-29 21:41   13366              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\SoftGrid Client\Icon Cache\icon_ex.dat
+ 2009-07-14 04:54 . 2011-07-01 02:51   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2009-07-14 04:54 . 2011-06-29 21:41   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2009-07-14 04:54 . 2011-06-29 21:41   32768              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2009-07-14 04:54 . 2011-07-01 02:51   32768              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2009-07-14 04:54 . 2011-06-29 21:41   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2009-07-14 04:54 . 2011-07-01 02:51   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2010-07-11 03:12 . 2011-07-01 02:52   44940              c:\windows\system32\wdi\ShutdownPerformanceDiagnostics_SystemData.bin
+ 2009-07-14 05:10 . 2011-07-01 02:52   37054              c:\windows\system32\wdi\BootPerformanceDiagnostics_SystemData.bin
- 2009-07-14 05:10 . 2011-06-29 21:43   37054              c:\windows\system32\wdi\BootPerformanceDiagnostics_SystemData.bin
+ 2011-02-12 14:18 . 2011-07-01 02:52   14796              c:\windows\system32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-1227915785-3733434846-2752287559-1001_UserData.bin
- 2011-02-12 18:14 . 2011-06-29 21:29   16384              c:\windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2011-02-12 18:14 . 2011-06-30 20:00   16384              c:\windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2011-02-12 18:14 . 2011-06-30 20:00   32768              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2011-02-12 18:14 . 2011-06-29 21:29   32768              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2009-07-14 04:54 . 2011-06-30 20:00   16384              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
- 2009-07-14 04:54 . 2011-06-29 21:29   16384              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2011-02-13 16:01 . 2011-07-01 02:52   16384              c:\windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2011-02-13 16:01 . 2011-06-29 21:43   16384              c:\windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2009-07-14 04:46 . 2011-06-29 21:51   78552              c:\windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareProtectionPlatform\Cache\cache.dat
- 2011-02-13 16:01 . 2011-06-29 21:43   32768              c:\windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2011-02-13 16:01 . 2011-07-01 02:52   32768              c:\windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2011-02-13 16:01 . 2011-06-29 21:43   16384              c:\windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2011-02-13 16:01 . 2011-07-01 02:52   16384              c:\windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2011-02-12 14:18 . 2011-07-01 02:52   16384              c:\windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2011-02-12 14:18 . 2011-06-29 21:43   16384              c:\windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2011-02-12 14:18 . 2011-06-29 21:43   16384              c:\windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2011-02-12 14:18 . 2011-07-01 02:52   16384              c:\windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2011-05-30 05:29 . 2011-06-30 04:16   3860              c:\windows\system32\wdi\ERCQueuedResolutions.dat
- 2011-06-29 21:41 . 2011-06-29 21:41   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
+ 2011-07-01 02:50 . 2011-07-01 02:50   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
+ 2011-07-01 02:50 . 2011-07-01 02:50   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
- 2011-06-29 21:41 . 2011-06-29 21:41   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2011-02-12 02:48 . 2011-07-01 00:13   258680              c:\windows\system32\wdi\SuspendPerformanceDiagnostics_SystemData_S3.bin
- 2011-02-12 02:48 . 2011-06-29 21:26   258680              c:\windows\system32\wdi\SuspendPerformanceDiagnostics_SystemData_S3.bin
+ 2009-07-14 02:36 . 2011-07-01 00:15   624622              c:\windows\system32\perfh009.dat
- 2009-07-14 02:36 . 2011-06-29 21:27   624622              c:\windows\system32\perfh009.dat
- 2009-07-14 02:36 . 2011-06-29 21:27   106708              c:\windows\system32\perfc009.dat
+ 2009-07-14 02:36 . 2011-07-01 00:15   106708              c:\windows\system32\perfc009.dat
+ 2011-06-30 04:11 . 2011-06-30 04:11   190752              c:\windows\system32\javaws.exe
+ 2011-06-30 04:11 . 2011-06-30 04:11   171808              c:\windows\system32\javaw.exe
+ 2011-06-30 04:11 . 2011-06-30 04:11   171808              c:\windows\system32\java.exe
+ 2010-11-20 09:21 . 2011-07-01 02:50   757760              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache3.0.0.0.dat
- 2009-07-14 05:01 . 2011-06-29 21:41   234640              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-System.dat
+ 2009-07-14 05:01 . 2011-07-01 02:50   234640              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-System.dat
+ 2011-02-12 03:22 . 2011-07-01 02:50   679392              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-S-1-5-21-1227915785-3733434846-2752287559-1001-8192.dat
- 2011-02-12 03:22 . 2011-06-29 21:41   679392              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-S-1-5-21-1227915785-3733434846-2752287559-1001-8192.dat
+ 2011-06-30 04:10 . 2011-06-30 04:10   683520              c:\windows\Installer\161d44d.msi
- 2009-07-14 02:34 . 2011-06-29 21:40   9961472              c:\windows\system32\SMI\Store\Machine\SCHEMA.DAT
+ 2009-07-14 02:34 . 2011-06-30 19:54   9961472              c:\windows\system32\SMI\Store\Machine\SCHEMA.DAT
REGEDIT4
2011-07-01 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
2011-07-01 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
@="FlashBroker"
@="0"
@="1.0"
@="1.0"
@="IFlashBroker4"
"Version"="1.0"
Completion time: 2011-06-30  22:56:21 - machine was rebooted
ComboFix-quarantined-files.txt  2011-07-01 02:56
ComboFix2.txt  2011-06-29 21:47
ComboFix3.txt  2011-06-29 05:02
Pre-Run: 250,738,491,392 bytes free
Post-Run: 250,694,217,728 bytes free
- - End Of File - - BD8574836DBC009EECDB16DBD551F56C
Re: Help with Virus/Malware please!!
« Reply #12 on: July 01, 2011, 01:54:13 PM »
Thank you, a-mazing.  That is much better.
How is your daughter's laptop now?
Offline a-mazing
« Reply #13 on: July 01, 2011, 08:32:55 PM »
It seems to be running fine  Just need to download anti-virus/malware software.
Thanks so much for your help
« Reply #14 on: July 01, 2011, 09:28:06 PM »
Hi, a-mazing.
Your daughter has Norton Internet Security installed on the laptop for antivirus and firewall protection.  Since that is a suite, if it is expired and being replaced, the Windows 7 Firewall needs to be turned on.
Malwarebytes Anti-Malware is an anti-malware software.
The following antivirus software programs are free for personal use, with Microsoft Security Essentials my favorite.
avast! 5 Home Edition
