Author Topic: malware possibly in router?  (Read 370 times)
Offline mjduck
« on: April 02, 2011, 06:50:11 PM »
My computer, along with Ipad, and netbook has what looks to be a redirect browser problem. It doesn't matter which browser we use, chrome, IE, Firfox.  Sometimes a new tab gets openned without us wanting it to.  Sometimes links through a search engine goes to an unwanted site.  We just got my Daughter a laptop and upon turning it on, the same thing happened to her browser.  Any ideas what causes this?  This is my first post, and not sure what all the protocals are.  Could this be a problem with a router instead of a computer?  Also, I took my main computer into work for our IT guy to see, and it worked flawlessly there.
Thanks for your help.
Re: malware possibly in router?
« Reply #1 on: April 02, 2011, 09:59:05 PM »
Hi, mjduck.  Welcome to LandzDown Forum.
1.  Let's start with the router.  Did you change the default password?  See Malware Attacking Your Router.
2.  Let's flush your DNS cache and restore the HOSTS file.  Please copy/paste the lines in bold below to Notepad:
@Echo on
pushd\windows\system32\drivers\etc
attrib -h -s -r hosts
echo 127.0.0.1 localhost>HOSTS
attrib +r +h +s hosts
popd
ipconfig /release
ipconfig /renew
ipconfig /flushdns
netsh winsock reset all
netsh int ip reset all
shutdown -r -t 1
del %0
Save as flush.bat to your desktop.
Double-click flush.bat file to run it. Your computer will reboot.
Note:  For Windows Vista or Windows 7, right-click flush.bat and select "Run as Administrator".
3.  Download DDS.scr by sUBs from one of the following links and save it to your desktop.
Link 1
Link 2
Offline mjduck
« Reply #2 on: April 04, 2011, 01:08:07 AM »
I did step 1-reading the article.  I did step 2 - flush the DNS cache.  I did 3, but it didn't produce any reports.  I went back to article, and then restored my router to factory settings.  Turns out I put a new router in and didn't change the password (from "password").  That's taken care of now, and the browser(s) seems to be working fine.  Thanks for your help, and I'll update if something starts going wacky again.
« Reply #3 on: April 04, 2011, 01:14:22 AM »
Hi, mjduck.
Since both you and your daughter's new laptop were being redirected, I suggest that you run an updated full-system anti-virus scan on all of the devices.  You may also want to scan with an updated anti-malware program, such as Malwarebytes' Anti-Malware.
