Author Topic: Microsoft Windows Vista Security 2012  (Read 263 times)
Offline WalnutCreek
« on: January 11, 2012, 09:37:56 PM »
This past weekend a terrible thing happened to my old computer (thanks be to God that is was not my new computer). When I opened up the computer, in the lower right hand corner was a program running a "scan" of my computer - I knew I had not loaded such a program, but I could not stop it. I tried to open Malwarebytes, but got a message from that it was a Trojan. Tried to open a Word document, got the same message. Then tried to open IE and got the same message. By that time I knew I had a problem. So shut down the computer, unplugged it, and the CPU is now just sitting.
Does anyone know how I can rid the computer of this malware? Since I have a new computer, I normally would not be concerned; however, I have not transferred all of my data files (documents, pictures, etc.) to my new computer.
Any ideas will be appreciated.
Re: Microsoft Windows Vista Security 2012
« Reply #1 on: January 11, 2012, 09:47:24 PM »
Hi, WalnutCreek.  Welcome to LandzDown Forum.
1)  Please download the following two files.  In the event you are blocked by the malware from downloading, it will be necessary to go to an uninfected computer and then transfer the files to the infected computer via CD/DVD, external drive, or USB flash drive.
FixNCR.reg
Bleeping Computer Downloads: RKill
2)  Insert the removable device into the infected computer and open the folder the drive letter associated with it. Double-click the FixNCR.reg file to fix the Registry on your infected computer.  Click OK to authorize the the FixNCR.reg file.
3)  Copy the downloaded RKill file to the desktop of the infected computer.
  • Double-click rkill to run.
Notes:
4)  You should now be able to update MBAM.
  • Launch Malwarebytes' Anti-Malware then click the Update tab and "Check for Updates
  • Once the update has been installed and the program has loaded, select Quick scan
  • Click Remove Selected.
** Note **
In addition to the MBAM log, please return to the "Log Posting Instructions" topic and provide the requested logs from that topic, noting that it may take more than one reply.
Thank you.
Offline WalnutCreek
« Reply #2 on: January 11, 2012, 10:19:45 PM »
Thank you so much.  I will purchase a new USB drive to download these two programs.
