Author Topic: Security Protection Virus  (Read 533 times)
Offline Cory
« on: August 30, 2011, 10:39:08 PM »
Security Protection - Virus Solution and Removal
My mom has this virus on her computer and she can't open any browser to download a new anti virus software and SUPERAntiSpyware didn't detect anything. The task manager won't open either. I'm afraid to use a flash drive to move an anti virus software from my computer to her computer because I'm afraid the flash drive will then be effected.
She's using Windows Vista Home Premium.
How do I remove this virus?
Re: Security Protection Virus
« Reply #1 on: August 30, 2011, 11:12:16 PM »
Hi, Cory.  Welcome to LandzDown Forum.
We will do our best to assist you clean your Mom's computer.  However, in order to do so, please follow all instructions provided in the sequence given.  Do not install/re-install any programs or run any fixes or scanners that you have not been instructed to use.  This may cause conflicts with the tools being used in the cleanup process.
Due to the numerous instructions, I suggest you print these instructions before beginning.
Although transferring programs to your Mom's computer via flash drive should not be a problem, in the event you need to download any of the programs to your flash drive and transfer them to your Mom's computer, you can install dr_Bora's program, MCShield::Anti-Malware Tool::.  This tool will block the autorun.inf, preventing any transferred infected files from automatically opening on your computer.   (Yes, I know dr_Bora.  He is a respected member of the security community and his tool is safe to use.)
1.  Please restart the computer in Safe Mode with Networking. (To do this, turn your computer off and then back on and immediately when you see anything on the screen, start tapping the F8 key on your keyboard. Using the arrow keys on your keyboard, select Safe Mode with Networking and press Enter on your keyboard. Windows will now boot into safe mode with networking and prompt you to login as a user.)
2.  Please download the TDSSKiller.exe by Kaspersky... save it to your Desktop. <-Important!!!
  • Double-click on TDSSKiller.exe to run the tool for known TDSS variants.
    Vista - W7 users: Right-click and select "Run As Administrator".
    If TDSSKiller does not run... rename it. Right-click on TDSSKiller.exe, select Rename and give it a random name with the .com file extension (i.e. ektfhtw.com).
    If you don't see file extensions, please see:  How to change the file extension.
  • Click the Start Scan button.  Do not use the computer during the scan!
  • If the scan completes with nothing found, click Close to exit.
  • If malicious objects are found, they will show in the "Scan results - Select action for found objects[/b]" and offer 3 options.
    • Ensure Cure (default) is selected... then click Continue > Reboot now to finish the cleaning process.
  • A log file named TDSSKiller_version_dd.mm.yyyy_hh.mm.ss_log.txt will be created and saved to the root directory. (usually Local Disk C:).
  • Copy and paste the contents of that file in your next reply.
3.  Please download rkill from one of the following links and save to your Desktop:
One, Two,Three or Four
  • Double-click rkill to run.
Note: If you you receive security warnings about rkill, please ignore and allow the download to continue.
4.  Please download Malwarebytes' Anti-Malware to your desktop.
  • Click Finish.
  • Click Remove Selected.
** Note **
5.  Download DDS.scr by sUBs from one of the following links and save it to your desktop.
Link 1
Link 2
6.  Download Security Check by screen317 from here or here.
  • Save it to your Desktop.
  • Double click SecurityCheck.exe and follow the onscreen instructions inside of the black box.
  • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
Requested logs:
TDSSKiller
Malwarebytes
Both DDS.txt and Attach.txt
checkup.txt
Note:  Due to the number of logs requested, it is likely you will need to create more than one reply in order to get all the logs posted.
Offline Cory
« Reply #2 on: August 31, 2011, 02:15:43 AM »
Thank you very much, how exactly do you find the logs after everything is completed and closed?
Offline Cory
« Reply #3 on: August 31, 2011, 03:05:39 AM »
DDS.txt and Attach.txt didn't come up, here's the others:
TDSSKiller:
2011/08/30 20:36:35.0557 1384   TDSS rootkit removing tool 2.5.17.0 Aug 22 2011 15:46:57
2011/08/30 20:36:37.0570 1384   ================================================================================
2011/08/30 20:36:37.0570 1384   SystemInfo:
2011/08/30 20:36:37.0570 1384   OS Version: 6.0.6002 ServicePack: 2.0
2011/08/30 20:36:37.0570 1384   Product type: Workstation
2011/08/30 20:36:37.0570 1384   ComputerName: CHRISTY-PC
2011/08/30 20:36:37.0570 1384   UserName: Christy
2011/08/30 20:36:37.0570 1384   Windows directory: C:\Windows
2011/08/30 20:36:37.0570 1384   System windows directory: C:\Windows
2011/08/30 20:36:37.0570 1384   Processor architecture: Intel x86
2011/08/30 20:36:37.0570 1384   Number of processors: 2
2011/08/30 20:36:37.0570 1384   Page size: 0x1000
2011/08/30 20:36:37.0570 1384   Boot type: Safe boot with network
2011/08/30 20:36:38.0521 1384   Initialize success
2011/08/30 20:36:42.0390 2012   ================================================================================
2011/08/30 20:36:42.0390 2012   Scan started
2011/08/30 20:36:42.0390 2012   Mode: Manual;
2011/08/30 20:36:42.0827 2012   ACPI            (82b296ae1892fe3dbee00c9cf92f8ac7) C:\Windows\system32\drivers\acpi.sys
2011/08/30 20:36:42.0905 2012   adp94xx         (2edc5bbac6c651ece337bde8ed97c9fb) C:\Windows\system32\drivers\adp94xx.sys
2011/08/30 20:36:42.0967 2012   adpahci         (b84088ca3cdca97da44a984c6ce1ccad) C:\Windows\system32\drivers\adpahci.sys
2011/08/30 20:36:42.0983 2012   adpu160m        (7880c67bccc27c86fd05aa2afb5ea469) C:\Windows\system32\drivers\adpu160m.sys
2011/08/30 20:36:43.0030 2012   adpu320         (9ae713f8e30efc2abccd84904333df4d) C:\Windows\system32\drivers\adpu320.sys
2011/08/30 20:36:43.0217 2012   AFD             (3911b972b55fea0478476b2e777b29fa) C:\Windows\system32\drivers\afd.sys
2011/08/30 20:36:43.0295 2012   agp440          (8b10ce1c1f9f1d47e4deb1a547a00cd4) C:\Windows\system32\drivers\agp440.sys
2011/08/30 20:36:43.0342 2012   aic78xx         (ae1fdf7bf7bb6c6a70f67699d880592a) C:\Windows\system32\drivers\djsvs.sys
2011/08/30 20:36:43.0389 2012   aliide          (dc67a153fdb8105b25d05334b5e1d8e2) C:\Windows\system32\drivers\aliide.sys
2011/08/30 20:36:43.0435 2012   amacpi          (c5dbbcda07d780bda9b685df333bb41e) C:\Windows\system32\DRIVERS\null.sys
2011/08/30 20:36:43.0482 2012   amdagp          (848f27e5b27c1c253f6cefdc1a5d8f21) C:\Windows\system32\drivers\amdagp.sys
2011/08/30 20:36:43.0498 2012   amdide          (835c4c3355088298a5ebd818fa31430f) C:\Windows\system32\drivers\amdide.sys
2011/08/30 20:36:43.0529 2012   AmdK7           (dc487885bcef9f28eece6fac0e5ddfc5) C:\Windows\system32\drivers\amdk7.sys
2011/08/30 20:36:43.0576 2012   AmdK8           (93ae7f7dd54ab986a6f1a1b37be7442d) C:\Windows\system32\DRIVERS\amdk8.sys
2011/08/30 20:36:43.0701 2012   arc             (5f673180268bb1fdb69c99b6619fe379) C:\Windows\system32\drivers\arc.sys
2011/08/30 20:36:43.0763 2012   arcsas          (957f7540b5e7f602e44648c7de5a1c05) C:\Windows\system32\drivers\arcsas.sys
2011/08/30 20:36:43.0841 2012   AsyncMac        (53b202abee6455406254444303e87be1) C:\Windows\system32\DRIVERS\asyncmac.sys
2011/08/30 20:36:43.0888 2012   atapi           (1f05b78ab91c9075565a9d8a4b880bc4) C:\Windows\system32\drivers\atapi.sys
2011/08/30 20:36:43.0966 2012   Beep            (67e506b75bd5326a3ec7b70bd014dfb6) C:\Windows\system32\drivers\Beep.sys
2011/08/30 20:36:44.0106 2012   bowser          (35f376253f687bde63976ccb3f2108ca) C:\Windows\system32\DRIVERS\bowser.sys
2011/08/30 20:36:44.0200 2012   BrFiltLo        (9f9acc7f7ccde8a15c282d3f88b43309) C:\Windows\system32\drivers\brfiltlo.sys
2011/08/30 20:36:44.0262 2012   BrFiltUp        (56801ad62213a41f6497f96dee83755a) C:\Windows\system32\drivers\brfiltup.sys
2011/08/30 20:36:44.0325 2012   Brserid         (b304e75cff293029eddf094246747113) C:\Windows\system32\drivers\brserid.sys
2011/08/30 20:36:44.0387 2012   BrSerWdm        (203f0b1e73adadbbb7b7b1fabd901f6b) C:\Windows\system32\drivers\brserwdm.sys
2011/08/30 20:36:44.0465 2012   BrUsbMdm        (bd456606156ba17e60a04e18016ae54b) C:\Windows\system32\drivers\brusbmdm.sys
2011/08/30 20:36:44.0496 2012   BrUsbSer        (af72ed54503f717a43268b3cc5faec2e) C:\Windows\system32\drivers\brusbser.sys
2011/08/30 20:36:44.0559 2012   BTHMODEM        (ad07c1ec6665b8b35741ab91200c6b68) C:\Windows\system32\drivers\bthmodem.sys
2011/08/30 20:36:44.0605 2012   cdfs            (7add03e75beb9e6dd102c3081d29840a) C:\Windows\system32\DRIVERS\cdfs.sys
2011/08/30 20:36:44.0652 2012   cdrom           (6b4bffb9becd728097024276430db314) C:\Windows\system32\DRIVERS\cdrom.sys
2011/08/30 20:36:44.0730 2012   cfwids          (7fd604cd7a7a0ff8975af61bdf64c577) C:\Windows\system32\drivers\cfwids.sys
2011/08/30 20:36:44.0793 2012   circlass        (da8e0afc7baa226c538ef53ac2f90897) C:\Windows\system32\drivers\circlass.sys
2011/08/30 20:36:44.0855 2012   CLFS            (d7659d3b5b92c31e84e53c1431f35132) C:\Windows\system32\CLFS.sys
2011/08/30 20:36:44.0933 2012   cmdide          (e79cbb2195e965f6e3256e2c1b23fd1c) C:\Windows\system32\drivers\cmdide.sys
2011/08/30 20:36:44.0964 2012   Compbatt        (82b8c91d327cfecf76cb58716f7d4997) C:\Windows\system32\drivers\compbatt.sys
2011/08/30 20:36:45.0011 2012   crcdisk         (2a213ae086bbec5e937553c7d9a2b22c) C:\Windows\system32\drivers\crcdisk.sys
2011/08/30 20:36:45.0058 2012   Crusoe          (22a7f883508176489f559ee745b5bf5d) C:\Windows\system32\drivers\crusoe.sys
2011/08/30 20:36:45.0198 2012   DfsC            (622c41a07ca7e6dd91770f50d532cb6c) C:\Windows\system32\Drivers\dfsc.sys
2011/08/30 20:36:45.0292 2012   disk            (5d4aefc3386920236a548271f8f1af6a) C:\Windows\system32\drivers\disk.sys
2011/08/30 20:36:45.0417 2012   Dot4            (4f59c172c094e1a1d46463a8dc061cbd) C:\Windows\system32\DRIVERS\Dot4.sys
2011/08/30 20:36:45.0463 2012   Dot4Print       (80bf3ba09f6f2523c8f6b7cc6dbf7bd5) C:\Windows\system32\DRIVERS\Dot4Prt.sys
2011/08/30 20:36:45.0510 2012   dot4usb         (c55004ca6b419b6695970dfe849b122f) C:\Windows\system32\DRIVERS\dot4usb.sys
2011/08/30 20:36:45.0604 2012   drmkaud         (97fef831ab90bee128c9af390e243f80) C:\Windows\system32\drivers\drmkaud.sys
2011/08/30 20:36:45.0682 2012   DSproct         (413f2d5f9d802688242c23b38f767ecb) C:\Program Files\DellSupport\GTAction\triggers\DSproct.sys
2011/08/30 20:36:45.0744 2012   dsunidrv        (dfeabb7cfffadea4a912ab95bdc3177a) C:\Windows\system32\DRIVERS\dsunidrv.sys
2011/08/30 20:36:45.0822 2012   DXGKrnl         (c68ac676b0ef30cfbb1080adce49eb1f) C:\Windows\System32\drivers\dxgkrnl.sys
2011/08/30 20:36:45.0916 2012   e1express       (7505290504c8e2d172fa378cc0497bcc) C:\Windows\system32\DRIVERS\e1e6032.sys
2011/08/30 20:36:45.0994 2012   E1G60           (f88fb26547fd2ce6d0a5af2985892c48) C:\Windows\system32\DRIVERS\E1G60I32.sys
2011/08/30 20:36:46.0056 2012   Ecache          (7f64ea048dcfac7acf8b4d7b4e6fe371) C:\Windows\system32\drivers\ecache.sys
2011/08/30 20:36:46.0165 2012   elxstor         (e8f3f21a71720c84bcf423b80028359f) C:\Windows\system32\drivers\elxstor.sys
2011/08/30 20:36:46.0275 2012   exfat           (22b408651f9123527bcee54b4f6c5cae) C:\Windows\system32\drivers\exfat.sys
2011/08/30 20:36:46.0337 2012   fastfat         (1e9b9a70d332103c52995e957dc09ef8) C:\Windows\system32\drivers\fastfat.sys
2011/08/30 20:36:46.0384 2012   fdc             (63bdada84951b9c03e641800e176898a) C:\Windows\system32\DRIVERS\fdc.sys
2011/08/30 20:36:46.0446 2012   FileInfo        (a8c0139a884861e3aae9cfe73b208a9f) C:\Windows\system32\drivers\fileinfo.sys
2011/08/30 20:36:46.0477 2012   Filetrace       (0ae429a696aecbc5970e3cf2c62635ae) C:\Windows\system32\drivers\filetrace.sys
2011/08/30 20:36:46.0618 2012   flpydisk        (6603957eff5ec62d25075ea8ac27de68) C:\Windows\system32\DRIVERS\flpydisk.sys
2011/08/30 20:36:46.0665 2012   FltMgr          (01334f9ea68e6877c4ef05d3ea8abb05) C:\Windows\system32\drivers\fltmgr.sys
2011/08/30 20:36:46.0743 2012   Fs_Rec          (65ea8b77b5851854f0c55c43fa51a198) C:\Windows\system32\drivers\Fs_Rec.sys
2011/08/30 20:36:46.0774 2012   gagp30kx        (4e1cd0a45c50a8882616cae5bf82f3c5) C:\Windows\system32\drivers\gagp30kx.sys
2011/08/30 20:36:46.0852 2012   GEARAspiWDM     (8182ff89c65e4d38b2de4bb0fb18564e) C:\Windows\system32\Drivers\GEARAspiWDM.sys
2011/08/30 20:36:46.0914 2012   HDAudBus        (062452b7ffd68c8c042a6261fe8dff4a) C:\Windows\system32\DRIVERS\HDAudBus.sys
2011/08/30 20:36:46.0945 2012   HidBth          (1338520e78d90154ed6be8f84de5fceb) C:\Windows\system32\drivers\hidbth.sys
2011/08/30 20:36:46.0961 2012   HidIr           (ff3160c3a2445128c5a6d9b076da519e) C:\Windows\system32\drivers\hidir.sys
2011/08/30 20:36:47.0008 2012   HidUsb          (cca4b519b17e23a00b826c55716809cc) C:\Windows\system32\DRIVERS\hidusb.sys
2011/08/30 20:36:47.0055 2012   HpCISSs         (df353b401001246853763c4b7aaa6f50) C:\Windows\system32\drivers\hpcisss.sys
2011/08/30 20:36:47.0179 2012   HSF_DPV         (53229dcf431d76434816cd29251168a0) C:\Windows\system32\DRIVERS\HSX_DPV.sys
2011/08/30 20:36:47.0226 2012   HSXHWBS2        (ed98350ecd4a5a9c9f1e641c09872bb2) C:\Windows\system32\DRIVERS\HSXHWBS2.sys
2011/08/30 20:36:47.0273 2012   HTTP            (f870aa3e254628ebeafe754108d664de) C:\Windows\system32\drivers\HTTP.sys
2011/08/30 20:36:47.0335 2012   i2omp           (324c2152ff2c61abae92d09f3cca4d63) C:\Windows\system32\drivers\i2omp.sys
2011/08/30 20:36:47.0413 2012   i8042prt        (22d56c8184586b7a1f6fa60be5f5a2bd) C:\Windows\system32\DRIVERS\i8042prt.sys
2011/08/30 20:36:47.0460 2012   iaStorV         (c957bf4b5d80b46c5017bf0101e6c906) C:\Windows\system32\drivers\iastorv.sys
2011/08/30 20:36:47.0507 2012   iirsp           (2d077bf86e843f901d8db709c95b49a5) C:\Windows\system32\drivers\iirsp.sys
2011/08/30 20:36:47.0601 2012   IntcAzAudAddService (f8f53c5449f15b23d4c61d51d2701da8) C:\Windows\system32\drivers\RTKVHDA.sys
2011/08/30 20:36:47.0710 2012   intelide        (0084046c084d68e494f8cf36bcf08186) C:\Windows\system32\drivers\intelide.sys
2011/08/30 20:36:47.0788 2012   intelppm        (ce44cc04262f28216dd4341e9e36a16f) C:\Windows\system32\DRIVERS\intelppm.sys
2011/08/30 20:36:47.0850 2012   IpFilterDriver  (62c265c38769b864cb25b4bcf62df6c3) C:\Windows\system32\DRIVERS\ipfltdrv.sys
2011/08/30 20:36:47.0944 2012   IPMIDRV         (40f34f8aba2a015d780e4b09138b6c17) C:\Windows\system32\drivers\ipmidrv.sys
2011/08/30 20:36:48.0006 2012   IPNAT           (8793643a67b42cec66490b2a0cf92d68) C:\Windows\system32\DRIVERS\ipnat.sys
2011/08/30 20:36:48.0069 2012   IRENUM          (109c0dfb82c3632fbd11949b73aeeac9) C:\Windows\system32\drivers\irenum.sys
2011/08/30 20:36:48.0115 2012   isapnp          (2f8ece2699e7e2070545e9b0960a8ed2) C:\Windows\system32\drivers\isapnp.sys
2011/08/30 20:36:48.0162 2012   iScsiPrt        (232fa340531d940aac623b121a595034) C:\Windows\system32\DRIVERS\msiscsi.sys
2011/08/30 20:36:48.0193 2012   iteatapi        (bced60d16156e428f8df8cf27b0df150) C:\Windows\system32\drivers\iteatapi.sys
2011/08/30 20:36:48.0240 2012   iteraid         (06fa654504a498c30adca8bec4e87e7e) C:\Windows\system32\drivers\iteraid.sys
2011/08/30 20:36:48.0318 2012   kbdclass        (37605e0a8cf00cbba538e753e4344c6e) C:\Windows\system32\DRIVERS\kbdclass.sys
2011/08/30 20:36:48.0365 2012   kbdhid          (ede59ec70e25c24581add1fbec7325f7) C:\Windows\system32\DRIVERS\kbdhid.sys
2011/08/30 20:36:48.0412 2012   KSecDD          (86165728af9bf72d6442a894fdfb4f8b) C:\Windows\system32\Drivers\ksecdd.sys
2011/08/30 20:36:48.0537 2012   lltdio          (d1c5883087a0c3f1344d9d55a44901f6) C:\Windows\system32\DRIVERS\lltdio.sys
2011/08/30 20:36:48.0615 2012   LSI_FC          (a2262fb9f28935e862b4db46438c80d2) C:\Windows\system32\drivers\lsi_fc.sys
2011/08/30 20:36:48.0693 2012   LSI_SAS         (30d73327d390f72a62f32c103daf1d6d) C:\Windows\system32\drivers\lsi_sas.sys
2011/08/30 20:36:48.0739 2012   LSI_SCSI        (e1e36fefd45849a95f1ab81de0159fe3) C:\Windows\system32\drivers\lsi_scsi.sys
2011/08/30 20:36:48.0802 2012   luafv           (8f5c7426567798e62a3b3614965d62cc) C:\Windows\system32\drivers\luafv.sys
2011/08/30 20:36:48.0958 2012   mdmxsdk         (0cea2d0d3fa284b85ed5b68365114f76) C:\Windows\system32\DRIVERS\mdmxsdk.sys
2011/08/30 20:36:49.0020 2012   megasas         (d153b14fc6598eae8422a2037553adce) C:\Windows\system32\drivers\megasas.sys
2011/08/30 20:36:49.0067 2012   mfeapfk         (113445fc6a858ef453cded5b0a0df665) C:\Windows\system32\drivers\mfeapfk.sys
2011/08/30 20:36:49.0098 2012   mfeavfk         (dbf6e1b388d5c070d438c61adb990c30) C:\Windows\system32\drivers\mfeavfk.sys
2011/08/30 20:36:49.0145 2012   mfebopk         (a528b15e330edb83ea649be318d841d5) C:\Windows\system32\drivers\mfebopk.sys
2011/08/30 20:36:49.0207 2012   mfefirek        (c7da1b8003c89acedaa13768f7a1c622) C:\Windows\system32\drivers\mfefirek.sys
2011/08/30 20:36:49.0254 2012   mfehidk         (5e9679bb2fc4fa38ec8ca906c47acd46) C:\Windows\system32\drivers\mfehidk.sys
2011/08/30 20:36:49.0285 2012   mfenlfk         (3a1aa28066785449da570462e0532d0c) C:\Windows\system32\DRIVERS\mfenlfk.sys
2011/08/30 20:36:49.0332 2012   mferkdet        (ce1711f7c3f72f6762abd241dcfd5ee1) C:\Windows\system32\drivers\mferkdet.sys
2011/08/30 20:36:49.0410 2012   mfewfpk         (b2baac6bbedda3e26e82db13fa0e5bee) C:\Windows\system32\drivers\mfewfpk.sys
2011/08/30 20:36:49.0457 2012   Modem           (e13b5ea0f51ba5b1512ec671393d09ba) C:\Windows\system32\drivers\modem.sys
2011/08/30 20:36:49.0519 2012   monitor         (0a9bb33b56e294f686abb7c1e4e2d8a8) C:\Windows\system32\DRIVERS\monitor.sys
2011/08/30 20:36:49.0566 2012   mouclass        (5bf6a1326a335c5298477754a506d263) C:\Windows\system32\DRIVERS\mouclass.sys
2011/08/30 20:36:49.0582 2012   mouhid          (93b8d4869e12cfbe663915502900876f) C:\Windows\system32\DRIVERS\mouhid.sys
2011/08/30 20:36:49.0613 2012   MountMgr        (bdafc88aa6b92f7842416ea6a48e1600) C:\Windows\system32\drivers\mountmgr.sys
2011/08/30 20:36:49.0660 2012   mpio            (583a41f26278d9e0ea548163d6139397) C:\Windows\system32\drivers\mpio.sys
2011/08/30 20:36:49.0722 2012   mpsdrv          (22241feba9b2defa669c8cb0a8dd7d2e) C:\Windows\system32\drivers\mpsdrv.sys
2011/08/30 20:36:49.0769 2012   Mraid35x        (4fbbb70d30fd20ec51f80061703b001e) C:\Windows\system32\drivers\mraid35x.sys
2011/08/30 20:36:49.0816 2012   MRxDAV          (82cea0395524aacfeb58ba1448e8325c) C:\Windows\system32\drivers\mrxdav.sys
2011/08/30 20:36:49.0894 2012   mrxsmb          (1e94971c4b446ab2290deb71d01cf0c2) C:\Windows\system32\DRIVERS\mrxsmb.sys
2011/08/30 20:36:49.0925 2012   mrxsmb10        (4fccb34d793b116423209c0f8b7a3b03) C:\Windows\system32\DRIVERS\mrxsmb10.sys
2011/08/30 20:36:49.0956 2012   mrxsmb20        (c3cb1b40ad4a0124d617a1199b0b9d7c) C:\Windows\system32\DRIVERS\mrxsmb20.sys
2011/08/30 20:36:50.0003 2012   msahci          (d420bc42a637ac3cc4f411220549c0dc) C:\Windows\system32\drivers\msahci.sys
2011/08/30 20:36:50.0019 2012   msdsm           (3fc82a2ae4cc149165a94699183d3028) C:\Windows\system32\drivers\msdsm.sys
2011/08/30 20:36:50.0081 2012   Msfs            (a9927f4a46b816c92f461acb90cf8515) C:\Windows\system32\drivers\Msfs.sys
2011/08/30 20:36:50.0190 2012   msisadrv        (0f400e306f385c56317357d6dea56f62) C:\Windows\system32\drivers\msisadrv.sys
2011/08/30 20:36:50.0268 2012   MSKSSRV         (d8c63d34d9c9e56c059e24ec7185cc07) C:\Windows\system32\drivers\MSKSSRV.sys
2011/08/30 20:36:50.0315 2012   MSPCLOCK        (1d373c90d62ddb641d50e55b9e78d65e) C:\Windows\system32\drivers\MSPCLOCK.sys
2011/08/30 20:36:50.0362 2012   MSPQM           (b572da05bf4e098d4bba3a4734fb505b) C:\Windows\system32\drivers\MSPQM.sys
2011/08/30 20:36:50.0409 2012   MsRPC           (b49456d70555de905c311bcda6ec6adb) C:\Windows\system32\drivers\MsRPC.sys
2011/08/30 20:36:50.0471 2012   mssmbios        (e384487cb84be41d09711c30ca79646c) C:\Windows\system32\DRIVERS\mssmbios.sys
2011/08/30 20:36:50.0533 2012   MSTEE           (7199c1eec1e4993caf96b8c0a26bd58a) C:\Windows\system32\drivers\MSTEE.sys
2011/08/30 20:36:50.0565 2012   Mup             (6a57b5733d4cb702c8ea4542e836b96c) C:\Windows\system32\Drivers\mup.sys
2011/08/30 20:36:50.0643 2012   NativeWifiP     (85c44fdff9cf7e72a40dcb7ec06a4416) C:\Windows\system32\DRIVERS\nwifi.sys
2011/08/30 20:36:50.0705 2012   NDIS            (1357274d1883f68300aeadd15d7bbb42) C:\Windows\system32\drivers\ndis.sys
2011/08/30 20:36:50.0767 2012   NdisTapi        (0e186e90404980569fb449ba7519ae61) C:\Windows\system32\DRIVERS\ndistapi.sys
2011/08/30 20:36:50.0814 2012   Ndisuio         (d6973aa34c4d5d76c0430b181c3cd389) C:\Windows\system32\DRIVERS\ndisuio.sys
2011/08/30 20:36:50.0861 2012   NdisWan         (818f648618ae34f729fdb47ec68345c3) C:\Windows\system32\DRIVERS\ndiswan.sys
2011/08/30 20:36:50.0923 2012   NDProxy         (71dab552b41936358f3b541ae5997fb3) C:\Windows\system32\drivers\NDProxy.sys
2011/08/30 20:36:51.0001 2012   NetBIOS         (bcd093a5a6777cf626434568dc7dba78) C:\Windows\system32\DRIVERS\netbios.sys
2011/08/30 20:36:51.0033 2012   netbt           (ecd64230a59cbd93c85f1cd1cab9f3f6) C:\Windows\system32\DRIVERS\netbt.sys
2011/08/30 20:36:51.0142 2012   nfrd960         (2e7fb731d4790a1bc6270accefacb36e) C:\Windows\system32\drivers\nfrd960.sys
2011/08/30 20:36:51.0204 2012   Npfs            (d36f239d7cce1931598e8fb90a0dbc26) C:\Windows\system32\drivers\Npfs.sys
2011/08/30 20:36:51.0267 2012   nsiproxy        (609773e344a97410ce4ebf74a8914fcf) C:\Windows\system32\drivers\nsiproxy.sys
2011/08/30 20:36:51.0345 2012   Ntfs            (6a4a98cee84cf9e99564510dda4baa47) C:\Windows\system32\drivers\Ntfs.sys
2011/08/30 20:36:51.0407 2012   ntrigdigi       (e875c093aec0c978a90f30c9e0dfbb72) C:\Windows\system32\drivers\ntrigdigi.sys
2011/08/30 20:36:51.0469 2012   Null            (c5dbbcda07d780bda9b685df333bb41e) C:\Windows\system32\drivers\Null.sys
2011/08/30 20:36:51.0547 2012   NVENETFD        (a1108084b0d2fc43dcc401735770e2a3) C:\Windows\system32\DRIVERS\nvmfdx32.sys
2011/08/30 20:36:51.0828 2012   nvlddmkm        (e572ebf0a86a76e7cfcaab00648f0f83) C:\Windows\system32\DRIVERS\nvlddmkm.sys
2011/08/30 20:36:52.0125 2012   nvraid          (e69e946f80c1c31c53003bfbf50cbb7c) C:\Windows\system32\drivers\nvraid.sys
2011/08/30 20:36:52.0203 2012   nvstor          (4a5fcab82d9bf6af8a023a66802fe9e9) C:\Windows\system32\drivers\nvstor.sys
2011/08/30 20:36:52.0249 2012   nvstor32        (dc5f166422beebf195e3e4bb8ab4ee22) C:\Windows\system32\DRIVERS\nvstor32.sys
2011/08/30 20:36:52.0312 2012   nv_agp          (055081fd5076401c1ee1bcab08d81911) C:\Windows\system32\drivers\nv_agp.sys
2011/08/30 20:36:52.0437 2012   ohci1394        (be32da025a0be1878f0ee8d6d9386cd5) C:\Windows\system32\drivers\ohci1394.sys
2011/08/30 20:36:52.0515 2012   Parport         (0fa9b5055484649d63c303fe404e5f4d) C:\Windows\system32\drivers\parport.sys
2011/08/30 20:36:52.0561 2012   partmgr         (57389fa59a36d96b3eb09d0cb91e9cdc) C:\Windows\system32\drivers\partmgr.sys
2011/08/30 20:36:52.0593 2012   Parvdm          (4f9a6a8a31413180d0fcb279ad5d8112) C:\Windows\system32\drivers\parvdm.sys
2011/08/30 20:36:52.0639 2012   pci             (941dc1d19e7e8620f40bbc206981efdb) C:\Windows\system32\drivers\pci.sys
2011/08/30 20:36:52.0671 2012   pciide          (1636d43f10416aeb483bc6001097b26c) C:\Windows\system32\drivers\pciide.sys
2011/08/30 20:36:52.0749 2012   pcmcia          (e6f3fb1b86aa519e7698ad05e58b04e5) C:\Windows\system32\drivers\pcmcia.sys
2011/08/30 20:36:52.0827 2012   PEAUTH          (6349f6ed9c623b44b52ea3c63c831a92) C:\Windows\system32\drivers\peauth.sys
2011/08/30 20:36:52.0983 2012   PptpMiniport    (ecfffaec0c1ecd8dbc77f39070ea1db1) C:\Windows\system32\DRIVERS\raspptp.sys
2011/08/30 20:36:53.0014 2012   Processor       (0e3cef5d28b40cf273281d620c50700a) C:\Windows\system32\drivers\processr.sys
2011/08/30 20:36:53.0076 2012   PSched          (99514faa8df93d34b5589187db3aa0ba) C:\Windows\system32\DRIVERS\pacer.sys
2011/08/30 20:36:53.0154 2012   PxHelp20        (d86b4a68565e444d76457f14172c875a) C:\Windows\system32\Drivers\PxHelp20.sys
2011/08/30 20:36:53.0248 2012   ql2300          (ccdac889326317792480c0a67156a1ec) C:\Windows\system32\drivers\ql2300.sys
2011/08/30 20:36:53.0326 2012   ql40xx          (81a7e5c076e59995d54bc1ed3a16e60b) C:\Windows\system32\drivers\ql40xx.sys
2011/08/30 20:36:53.0404 2012   QWAVEdrv        (9f5e0e1926014d17486901c88eca2db7) C:\Windows\system32\drivers\qwavedrv.sys
2011/08/30 20:36:53.0513 2012   R300            (e642b131fb74caf4bb8a014f31113142) C:\Windows\system32\DRIVERS\atikmdag.sys
2011/08/30 20:36:53.0622 2012   RasAcd          (147d7f9c556d259924351feb0de606c3) C:\Windows\system32\DRIVERS\rasacd.sys
2011/08/30 20:36:53.0669 2012   Rasl2tp         (a214adbaf4cb47dd2728859ef31f26b0) C:\Windows\system32\DRIVERS\rasl2tp.sys
2011/08/30 20:36:53.0778 2012   RasPppoe        (509a98dd18af4375e1fc40bc175f1def) C:\Windows\system32\DRIVERS\raspppoe.sys
2011/08/30 20:36:53.0825 2012   RasSstp         (2005f4a1e05fa09389ac85840f0a9e4d) C:\Windows\system32\DRIVERS\rassstp.sys
2011/08/30 20:36:53.0856 2012   rdbss           (b14c9d5b9add2f84f70570bbbfaa7935) C:\Windows\system32\DRIVERS\rdbss.sys
2011/08/30 20:36:53.0919 2012   RDPCDD          (89e59be9a564262a3fb6c4f4f1cd9899) C:\Windows\system32\DRIVERS\RDPCDD.sys
2011/08/30 20:36:53.0981 2012   rdpdr           (0245418224cfa77bf4b41c2fe0622258) C:\Windows\system32\drivers\rdpdr.sys
2011/08/30 20:36:54.0012 2012   RDPENCDD        (9d91fe5286f748862ecffa05f8a0710c) C:\Windows\system32\drivers\rdpencdd.sys
2011/08/30 20:36:54.0121 2012   RDPWD           (30bfbdfb7f95559ede971f9ddb9a00ba) C:\Windows\system32\drivers\RDPWD.sys
2011/08/30 20:36:54.0262 2012   rspndr          (9c508f4074a39e8b4b31d27198146fad) C:\Windows\system32\DRIVERS\rspndr.sys
2011/08/30 20:36:54.0340 2012   rt61x86         (92f0efc2d29d2b38adf9fe49701523c1) C:\Windows\system32\DRIVERS\netr61.sys
2011/08/30 20:36:54.0418 2012   SASDIFSV        (a3281aec37e0720a2bc28034c2df2a56) C:\Program Files\SUPERAntiSpyware\SASDIFSV.SYS
2011/08/30 20:36:54.0449 2012   SASENUM         (7ce61c25c159f50f9eaf6d77fc83fa35) C:\Program Files\SUPERAntiSpyware\SASENUM.SYS
2011/08/30 20:36:54.0480 2012   SASKUTIL        (67d2688756dd304af655349baad82bff) C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS
2011/08/30 20:36:54.0605 2012   sbp2port        (3ce8f073a557e172b330109436984e30) C:\Windows\system32\drivers\sbp2port.sys
2011/08/30 20:36:54.0683 2012   secdrv          (90a3935d05b494a5a39d37e71f09a677) C:\Windows\system32\drivers\secdrv.sys
2011/08/30 20:36:54.0745 2012   Serenum         (68e44e331d46f0fb38f0863a84cd1a31) C:\Windows\system32\drivers\serenum.sys
2011/08/30 20:36:54.0777 2012   Serial          (c70d69a918b178d3c3b06339b40c2e1b) C:\Windows\system32\drivers\serial.sys
2011/08/30 20:36:54.0823 2012   sermouse        (8af3d28a879bf75db53a0ee7a4289624) C:\Windows\system32\drivers\sermouse.sys
2011/08/30 20:36:54.0886 2012   sffdisk         (51cf56aa8bcc241f134b420b8f850406) C:\Windows\system32\drivers\sffdisk.sys
2011/08/30 20:36:54.0917 2012   sffp_mmc        (96ded8b20c734ac41641ce275250e55d) C:\Windows\system32\drivers\sffp_mmc.sys
2011/08/30 20:36:54.0964 2012   sffp_sd         (8b08cab1267b2c377883fc9e56981f90) C:\Windows\system32\drivers\sffp_sd.sys
2011/08/30 20:36:55.0011 2012   sfloppy         (46ed8e91793b2e6f848015445a0ac188) C:\Windows\system32\drivers\sfloppy.sys
2011/08/30 20:36:55.0073 2012   sisagp          (08072b2fb92477fc813271a84b3a8698) C:\Windows\system32\drivers\sisagp.sys
2011/08/30 20:36:55.0151 2012   SiSRaid2        (cedd6f4e7d84e9f98b34b3fe988373aa) C:\Windows\system32\drivers\sisraid2.sys
2011/08/30 20:36:55.0167 2012   SiSRaid4        (df843c528c4f69d12ce41ce462e973a7) C:\Windows\system32\drivers\sisraid4.sys
2011/08/30 20:36:55.0229 2012   Smb             (7b75299a4d201d6a6533603d6914ab04) C:\Windows\system32\DRIVERS\smb.sys
2011/08/30 20:36:55.0323 2012   spldr           (7aebdeef071fe28b0eef2cdd69102bff) C:\Windows\system32\drivers\spldr.sys
2011/08/30 20:36:55.0401 2012   srv             (41987f9fc0e61adf54f581e15029ad91) C:\Windows\system32\DRIVERS\srv.sys
2011/08/30 20:36:55.0479 2012   srv2            (ff33aff99564b1aa534f58868cbe41ef) C:\Windows\system32\DRIVERS\srv2.sys
2011/08/30 20:36:55.0557 2012   srvnet          (7605c0e1d01a08f3ecd743f38b834a44) C:\Windows\system32\DRIVERS\srvnet.sys
2011/08/30 20:36:55.0603 2012   StillCam        (ef70b3d22b4bffda6ea851ecb063efaa) C:\Windows\system32\DRIVERS\serscan.sys
2011/08/30 20:36:55.0635 2012   swenum          (7ba58ecf0c0a9a69d44b3dca62becf56) C:\Windows\system32\DRIVERS\swenum.sys
2011/08/30 20:36:55.0681 2012   Symc8xx         (192aa3ac01df071b541094f251deed10) C:\Windows\system32\drivers\symc8xx.sys
2011/08/30 20:36:55.0713 2012   Sym_hi          (8c8eb8c76736ebaf3b13b633b2e64125) C:\Windows\system32\drivers\sym_hi.sys
2011/08/30 20:36:55.0744 2012   Sym_u3          (8072af52b5fd103bbba387a1e49f62cb) C:\Windows\system32\drivers\sym_u3.sys
2011/08/30 20:36:55.0837 2012   Tcpip           (2756186e287139310997090797e0182b) C:\Windows\system32\drivers\tcpip.sys
2011/08/30 20:36:55.0884 2012   Tcpip6          (2756186e287139310997090797e0182b) C:\Windows\system32\DRIVERS\tcpip.sys
2011/08/30 20:36:55.0947 2012   tcpipreg        (608c345a255d82a6289c2d468eb41fd7) C:\Windows\system32\drivers\tcpipreg.sys
2011/08/30 20:36:55.0978 2012   TDPIPE          (5dcf5e267be67a1ae926f2df77fbcc56) C:\Windows\system32\drivers\tdpipe.sys
2011/08/30 20:36:56.0025 2012   TDTCP           (389c63e32b3cefed425b61ed92d3f021) C:\Windows\system32\drivers\tdtcp.sys
2011/08/30 20:36:56.0071 2012   tdx             (76b06eb8a01fc8624d699e7045303e54) C:\Windows\system32\DRIVERS\tdx.sys
2011/08/30 20:36:56.0118 2012   TermDD          (3cad38910468eab9a6479e2f01db43c7) C:\Windows\system32\DRIVERS\termdd.sys
2011/08/30 20:36:56.0196 2012   tssecsrv        (dcf0f056a2e4f52287264f5ab29cf206) C:\Windows\system32\DRIVERS\tssecsrv.sys
2011/08/30 20:36:56.0243 2012   tunmp           (caecc0120ac49e3d2f758b9169872d38) C:\Windows\system32\DRIVERS\tunmp.sys
2011/08/30 20:36:56.0274 2012   tunnel          (300db877ac094feab0be7688c3454a9c) C:\Windows\system32\DRIVERS\tunnel.sys
2011/08/30 20:36:56.0321 2012   uagp35          (c3ade15414120033a36c0f293d4a4121) C:\Windows\system32\drivers\uagp35.sys
2011/08/30 20:36:56.0368 2012   udfs            (d9728af68c4c7693cb100b8441cbdec6) C:\Windows\system32\DRIVERS\udfs.sys
2011/08/30 20:36:56.0415 2012   uliagpkx        (6d72ef05921abdf59fc45c7ebfe7e8dd) C:\Windows\system32\drivers\uliagpkx.sys
2011/08/30 20:36:56.0508 2012   uliahci         (3cd4ea35a6221b85dcc25daa46313f8d) C:\Windows\system32\drivers\uliahci.sys
2011/08/30 20:36:56.0586 2012   UlSata          (8514d0e5cd0534467c5fc61be94a569f) C:\Windows\system32\drivers\ulsata.sys
2011/08/30 20:36:56.0633 2012   ulsata2         (38c3c6e62b157a6bc46594fada45c62b) C:\Windows\system32\drivers\ulsata2.sys
2011/08/30 20:36:56.0695 2012   umbus           (32cff9f809ae9aed85464492bf3e32d2) C:\Windows\system32\DRIVERS\umbus.sys
2011/08/30 20:36:56.0758 2012   USBAAPL         (83cafcb53201bbac04d822f32438e244) C:\Windows\system32\Drivers\usbaapl.sys
2011/08/30 20:36:56.0805 2012   usbccgp         (caf811ae4c147ffcd5b51750c7f09142) C:\Windows\system32\DRIVERS\usbccgp.sys
2011/08/30 20:36:56.0851 2012   usbcir          (e9476e6c486e76bc4898074768fb7131) C:\Windows\system32\drivers\usbcir.sys
2011/08/30 20:36:56.0898 2012   usbehci         (79e96c23a97ce7b8f14d310da2db0c9b) C:\Windows\system32\DRIVERS\usbehci.sys
2011/08/30 20:36:56.0945 2012   usbhub          (4673bbcb006af60e7abddbe7a130ba42) C:\Windows\system32\DRIVERS\usbhub.sys
2011/08/30 20:36:56.0976 2012   usbohci         (ce697fee0d479290d89bec80dfe793b7) C:\Windows\system32\DRIVERS\usbohci.sys
2011/08/30 20:36:57.0007 2012   usbprint        (e75c4b5269091d15a2e7dc0b6d35f2f5) C:\Windows\system32\DRIVERS\usbprint.sys
2011/08/30 20:36:57.0054 2012   usbscan         (a508c9bd8724980512136b039bba65e9) C:\Windows\system32\DRIVERS\usbscan.sys
2011/08/30 20:36:57.0085 2012   USBSTOR         (be3da31c191bc222d9ad503c5224f2ad) C:\Windows\system32\DRIVERS\USBSTOR.SYS
2011/08/30 20:36:57.0148 2012   usbuhci         (325dbbacb8a36af9988ccf40eac228cc) C:\Windows\system32\DRIVERS\usbuhci.sys
2011/08/30 20:36:57.0210 2012   vga             (7d92be0028ecdedec74617009084b5ef) C:\Windows\system32\DRIVERS\vgapnp.sys
2011/08/30 20:36:57.0257 2012   VgaSave         (2e93ac0a1d8c79d019db6c51f036636c) C:\Windows\System32\drivers\vga.sys
2011/08/30 20:36:57.0288 2012   viaagp          (d5929a28bdff4367a12caf06af901971) C:\Windows\system32\drivers\viaagp.sys
2011/08/30 20:36:57.0335 2012   ViaC7           (56a4de5f02f2e88182b0981119b4dd98) C:\Windows\system32\drivers\viac7.sys
2011/08/30 20:36:57.0366 2012   viaide          (f3b4762eb85a2aff4999401f14c3262b) C:\Windows\system32\drivers\viaide.sys
2011/08/30 20:36:57.0413 2012   volmgr          (69503668ac66c77c6cd7af86fbdf8c43) C:\Windows\system32\drivers\volmgr.sys
2011/08/30 20:36:57.0460 2012   volmgrx         (23e41b834759917bfd6b9a0d625d0c28) C:\Windows\system32\drivers\volmgrx.sys
2011/08/30 20:36:57.0522 2012   volsnap         (147281c01fcb1df9252de2a10d5e7093) C:\Windows\system32\drivers\volsnap.sys
2011/08/30 20:36:57.0569 2012   vsmraid         (d984439746d42b30fc65a4c3546c6829) C:\Windows\system32\drivers\vsmraid.sys
2011/08/30 20:36:57.0631 2012   WacomPen        (48dfee8f1af7c8235d4e626f0c4fe031) C:\Windows\system32\drivers\wacompen.sys
2011/08/30 20:36:57.0694 2012   Wanarp          (55201897378cca7af8b5efd874374a26) C:\Windows\system32\DRIVERS\wanarp.sys
2011/08/30 20:36:57.0709 2012   Wanarpv6        (55201897378cca7af8b5efd874374a26) C:\Windows\system32\DRIVERS\wanarp.sys
2011/08/30 20:36:57.0803 2012   Wd              (afc5ad65b991c1e205cf25cfdbf7a6f4) C:\Windows\system32\drivers\wd.sys
2011/08/30 20:36:57.0850 2012   Wdf01000        (b6f0a7ad6d4bd325fbcd8bac96cd8d96) C:\Windows\system32\drivers\Wdf01000.sys
2011/08/30 20:36:57.0990 2012   winachsf        (6d2350bb6e77e800fc4be4e5b7a2e89a) C:\Windows\system32\DRIVERS\HSX_CNXT.sys
2011/08/30 20:36:58.0099 2012   WmiAcpi         (701a9f884a294327e9141d73746ee279) C:\Windows\system32\drivers\wmiacpi.sys
2011/08/30 20:36:58.0193 2012   WpdUsb          (de9d36f91a4df3d911626643debf11ea) C:\Windows\system32\DRIVERS\wpdusb.sys
2011/08/30 20:36:58.0240 2012   ws2ifsl         (e3a3cb253c0ec2494d4a61f5e43a389c) C:\Windows\system32\drivers\ws2ifsl.sys
2011/08/30 20:36:58.0380 2012   WUDFRd          (ac13cb789d93412106b0fb6c7eb2bcb6) C:\Windows\system32\DRIVERS\WUDFRd.sys
2011/08/30 20:36:58.0443 2012   XAudio          (5a7ff9a18ff6d7e0527fe3abf9204ef8) C:\Windows\system32\DRIVERS\xaudio.sys
2011/08/30 20:36:58.0489 2012   MBR (0x1B8)     (5c616939100b85e558da92b899a0fc36) \Device\Harddisk0\DR0
2011/08/30 20:36:58.0521 2012   Boot (0x1200)   (31ecf664959a3fd7286568f42773ad81) \Device\Harddisk0\DR0\Partition0
2011/08/30 20:36:58.0536 2012   Boot (0x1200)   (f346d154e10d085b401f8e73044c478b) \Device\Harddisk0\DR0\Partition1
2011/08/30 20:36:58.0536 2012   ================================================================================
2011/08/30 20:36:58.0536 2012   Scan finished
2011/08/30 20:36:58.0567 0456   Detected object count: 0
2011/08/30 20:36:58.0567 0456   Actual detected object count: 0
2011/08/30 20:37:41.0561 1104   Deinitialize success
Offline Cory
« Reply #4 on: August 31, 2011, 03:10:38 AM »
Malwarebytes
Malwarebytes' Anti-Malware 1.51.1.1800
www.malwarebytes.org
Database version: 7615
Windows 6.0.6002 Service Pack 2 (Safe Mode)
Internet Explorer 9.0.8112.16421
8/30/2011 8:55:13 PM
mbam-log-2011-08-30 (20-55-13).txt
Scan type: Quick scan
Objects scanned: 209462
Time elapsed: 5 minute(s), 41 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 1
Folders Infected: 0
Files Infected: 6
(No malicious items detected)
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\Security Protection (Rogue.SecurityProtection) -> Value: Security Protection -> Quarantined and deleted successfully.
Folders Infected:
Files Infected:
c:\Users\Christy\AppData\Roaming\defender.exe (Rogue.SecurityProtection) -> Quarantined and deleted successfully.
c:\Users\Christy\AppData\Roaming\4356.tmp (Rogue.SecurityProtection) -> Quarantined and deleted successfully.
c:\Users\Christy\AppData\Local\Temp\3FBE.tmp (Malware.Gen) -> Quarantined and deleted successfully.
c:\Users\Christy\AppData\Local\Temp\423D.tmp (Malware.Gen) -> Quarantined and deleted successfully.
c:\Users\Christy\AppData\Local\Temp\4F49.tmp (Malware.Gen) -> Quarantined and deleted successfully.
c:\Users\Christy\AppData\Local\Temp\5004.tmp (Malware.Gen) -> Quarantined and deleted successfully.
Offline Cory
« Reply #5 on: August 31, 2011, 03:14:28 AM »
checkup.txt:
Results of screen317's Security Check version 0.99.18
 Windows Vista Service Pack 2 (UAC is enabled)
 Internet Explorer 8
Antivirus/Firewall Check:
 Windows Security Center service is not running! This report may not be accurate!
 Windows Firewall Disabled!
 McAfee Security Scan Plus
 McAfee SecurityCenter
 WMI entry may not exist for antivirus; attempting automatic update.
Anti-malware/Other Utilities Check:
 Java(TM) 6 Update 26
 Java(TM) SE Runtime Environment 6
 Adobe Flash Player    10.3.183.5
Process Check:
objlist.exe by Laurent
``````````End of Log````````````
« Reply #6 on: August 31, 2011, 02:34:12 PM »
Hi, Cory.  You should have received a prompt to safe the logs.  If you didn't save them, go ahead and run DDS.scr again and copy/paste the resultant log as a reply.  (Note:  if DDS ran properly the first time, you will only see the DDS.txt.  Don't worry if you don't get the Attach.txt log.)
Offline Cory
« Reply #7 on: August 31, 2011, 07:01:23 PM »
I ran it again, but nothing happens.
« Reply #8 on: August 31, 2011, 07:45:21 PM »
Ok, delete the copy of DDS.scr that you downloaded and try a fresh copy:
Link 1
Link 2
  • Copy the contents of both DDS.txt and Attach.txt logs and post in your next reply.
NOTEOnly if you still have problems with DDS, do the following, being sure to allow RSIT to download HijackThis if prompted to do so:
Please download random's system information tool (RSIT):
  • Download RSIT by random/random from here and save it to your desktop.
    Note:  For users with 64-bit systems, please download RSIT from here.
  • Once it has finished, two logs will open. Please post the contents of both log.txt (<<will be maximized) and info.txt (<<will be minimized).
Offline Cory
« Reply #9 on: August 31, 2011, 11:16:36 PM »
DDS.scr failed again, here's the two RSIT logs:
log.txt:
Logfile of random's system information tool 1.09 (written by random/random)
Run by Christy at 2011-08-31 18:06:39
Microsoft® Windows Vista™ Home Premium  Service Pack 2
System drive C: has 141 GB (62%) free of 228 GB
Total RAM: 1982 MB (64% free)
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 6:06:56 PM, on 8/31/2011
Platform: Windows Vista SP2 (WinNT 6.00.1906)
MSIE: Internet Explorer v9.00 (9.00.8112.16421)
Boot mode: Safe mode with network support
Running processes:
C:\Windows\Explorer.EXE
c:\PROGRA~1\mcafee.com\agent\mcagent.exe
C:\Program Files\Mozilla Firefox\plugin-container.exe
C:\Users\Christy\Downloads\RSIT.exe
C:\Program Files\trend micro\Christy.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://att.my.yahoo.com/
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Internet Explorer provided by Dell
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
R3 - URLSearchHook: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O1 - Hosts: ::1 localhost
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - (no file)
O2 - BHO: HP Print Enhancer - {0347C33E-8762-4905-BF09-768834316C61} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_printenhancer.dll
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\Common Files\McAfee\SystemCore\ScriptSn.20110510005028.dll
O2 - BHO: McAfee SiteAdvisor BHO - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: HP Smart BHO Class - {FFFFFFFF-CF4E-4F2B-BDC2-0E72E116A856} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O3 - Toolbar: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
O4 - HKLM\..\Run: [RtHDVCpl] RtHDVCpl.exe
O4 - HKLM\..\Run: [ISUSScheduler] "C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" -start
O4 - HKLM\..\Run: [ISUSPM Startup] C:\PROGRA~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe -startup
O4 - HKLM\..\Run: [ECenter] C:\Dell\E-Center\EULALauncher.exe
O4 - HKLM\..\Run: [dscactivate] "C:\Program Files\Dell Support Center\gs_agent\custom\dsca.exe"
O4 - HKLM\..\Run: [Adobe Photo Downloader] "C:\Program Files\Adobe\Photoshop Elements 6.0\apdproxy.exe"
O4 - HKLM\..\Run: [Symantec PIF AlertEng] "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" /a /m "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\AlertEng.dll"
O4 - HKLM\..\Run: [DellSupportCenter] "C:\Program Files\Dell Support Center\bin\sprtcmd.exe" /P DellSupportCenter
O4 - HKLM\..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe
O4 - HKLM\..\Run: [hpqSRMon] C:\Program Files\HP\Digital Imaging\bin\hpqSRMon.exe
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [mcui_exe] "C:\Program Files\McAfee.com\Agent\mcagent.exe" /runkey
O4 - HKLM\..\Run: [RIMBBLaunchAgent.exe] C:\Program Files\Common Files\Research In Motion\USB Drivers\RIMBBLaunchAgent.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Common Files\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [Malwarebytes' Anti-Malware (reboot)] "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
O4 - HKLM\..\RunOnce: [GrpConv] grpconv -o
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
O4 - HKCU\..\Run: [DellSupportCenter] "C:\Program Files\Dell Support Center\bin\sprtcmd.exe" /P DellSupportCenter
O4 - HKCU\..\Run: [ISUSPM] "C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe" -scheduler
O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
O4 - HKCU\..\RunOnce: [Shockwave Updater] C:\Windows\system32\Adobe\Shockwave 11\SwHelper_1150600.exe -Update -1150600 -"Mozilla/5.0_(Windows;_U;_Windows_NT_6.0;_en-US;_rv:1.9.2.10)_Gecko/20100914_YFF35_Firefox/3.6.10_(_.NET_CLR_3.5.30729;" -"http://www.classzone.com/books/earth_science/terc/content/investigations/es0810/es0810page08.cfm"
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
O4 - Startup: OneNote 2007 Screen Clipper and Launcher.lnk = C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE
O4 - Global Startup: Digital Line Detect.lnk = C:\Program Files\Digital Line Detect\DLG.exe
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O4 - Global Startup: Kodak EasyShare software.lnk = C:\Program Files\Kodak\Kodak EasyShare software\bin\EasyShare.exe
O4 - Global Startup: McAfee Security Scan Plus.lnk = ?
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office12\EXCEL.EXE/3000
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL
O9 - Extra button: Show or hide HP Smart Web Printing - {DDE87865-83C5-48c4-8357-2F5B1AA84522} - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O16 - DPF: {48DD0448-9209-4F81-9F6D-D83562940134} (MySpace Uploader Control) - http://lads.myspace.com/upload/MySpaceUploader1006.cab
O16 - DPF: {D0C0F75C-683A-4390-A791-1ACFD5599AB8} (Oberon Flash Game Host) - http://games.myspace.com/Gameshell/GameHost/1.0/OberonGameHost.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O18 - Protocol: dssrequest - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O18 - Protocol: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\Windows\system32\browseui.dll
O23 - Service: Adobe Active File Monitor V6 (AdobeActiveFileMonitor6.0) - Unknown owner - C:\Program Files\Adobe\Photoshop Elements 6.0\PhotoshopElementsFileAgent.exe
O23 - Service: Andrea RT Filters Service (AERTFilters) - Andrea Electronics Corporation - C:\Windows\system32\AERTSrv.exe
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: DSBrokerService - Unknown owner - C:\Program Files\DellSupport\brkrsvc.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: LiveUpdate Notice Service Ex (LiveUpdate Notice Ex) - Unknown owner - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe (file missing)
O23 - Service: LiveUpdate Notice Service - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe
O23 - Service: MBAMService - Malwarebytes Corporation - C:\Program Files\Malwarebytes' Anti-Malware\mbamservice.exe
O23 - Service: McAfee SiteAdvisor Service - McAfee, Inc. - C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
O23 - Service: McAfee Security Scan Component Host Service (McComponentHostService) - McAfee, Inc. - C:\Program Files\McAfee Security Scan\2.0.181\McCHSvc.exe
O23 - Service: McAfee Personal Firewall Service (McMPFSvc) - McAfee, Inc. - C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee VirusScan Announcer (McNaiAnn) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\Program Files\McAfee\VirusScan\mcods.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McShield - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe
O23 - Service: McAfee Firewall Core Service (mfefire) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mfefire.exe
O23 - Service: McAfee Validation Trust Protection Service (mfevtp) - McAfee, Inc. - C:\Windows\system32\mfevtps.exe
O23 - Service: NVIDIA Display Driver Service (nvsvc) - NVIDIA Corporation - C:\Windows\system32\nvvsvc.exe
O23 - Service: RoxMediaDB9 - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe
O23 - Service: Roxio Hard Drive Watcher 9 (RoxWatch9) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatch9.exe
O23 - Service: SupportSoft Sprocket Service (dellsupportcenter) (sprtsvc_dellsupportcenter) - SupportSoft, Inc. - C:\Program Files\Dell Support Center\bin\sprtsvc.exe
O23 - Service: stllssvr - MicroVision Development, Inc. - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe
O23 - Service: XAudioService - Conexant Systems, Inc. - C:\Windows\system32\DRIVERS\xaudio.exe
End of file - 11847 bytes
C:\Windows\tasks\EasyShare Registration Task.job
=========Mozilla firefox=========
ProfilePath - C:\Users\Christy\AppData\Roaming\Mozilla\Firefox\Profiles\6evwqrab.default
prefs.js - "browser.search.suggest.enabled" -  false
prefs.js - "browser.search.useDBForOrder" -  true
prefs.js - "browser.startup.homepage" -  "http://m.www.yahoo.com/"
prefs.js - "extensions.enabledItems" -  "copylinktext@brett.zamir:1.4.9, {CAFEEFAC-0016-0000-0012-ABCDEFFEDCBA}:6.0.12, {CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA}:6.0.13, {CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA}:6.0.15, {CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA}:6.0.17, kodak-companion@mozilla.com:1.9.1, {B7082FAA-CB62-4872-9106-E42DD88EDE45}:3.3.1, {20a82645-c095-46ed-80e3-08825760534b}:1.2.1, moveplayer@movenetworks.com:7, {635abd67-4fe9-1b23-4f01-e679fa7484c1}:2.1.3.20100310105313, {CAFEEFAC-0016-0000-0019-ABCDEFFEDCBA}:6.0.19, {CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}:6.0.20, {7b13ec3e-999a-4b70-b9cb-2617b8323822}:2.7.1.3, {CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA}:6.0.21, {CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}:6.0.22, {CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}:6.0.23, {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}:6.0.24, {972ce4c6-7e08-4474-a285-3208198ce6fd}:3.6.16"
prefs.js - "keyword.URL" -  "data:text/plain, keyword.URL=http://search.yahoo.com/search?ei=UTF-8&fr=yff35awe&p="
"{20a82645-c095-46ed-80e3-08825760534b}"=c:\Windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\
"smartwebprinting@hp.com"=C:\Program Files\HP\Digital Imaging\Smart Web Printing\MozillaAddOn3
"{B7082FAA-CB62-4872-9106-E42DD88EDE45}"=C:\Program Files\McAfee\SiteAdvisor
[HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer]
"Description"=Adobe® Flash® Player 10.1 Plugin
"Path"=C:\Windows\system32\Macromed\Flash\NPSWF32.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@adobe.com/ShockwavePlayer]
"Description"=Adobe Shockwave Player
"Path"=C:\Windows\system32\Adobe\Director\np32dsw.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@Apple.com/iTunes,version=]
"Description"=iTunes Detector Plug-in
"Path"=
[HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@Apple.com/iTunes,version=1.0]
"Description"=
"Path"=C:\Program Files\iTunes\Mozilla Plugins\npitunes.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@java.com/JavaPlugin]
"Description"=Oracle® Next Generation Java™ Plug-In
"Path"=C:\Program Files\Java\jre6\bin\new_plugin\npjp2.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@microsoft.com/WPF,version=3.5]
"Description"=Windows Presentation Foundation plug-in for Mozilla browsers
"Path"=c:\Windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\NPWPF.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@movenetworks.com/Quantum Media Player]
"Description"=npmnqmp
"Path"=C:\Users\Christy\AppData\Roaming\Move Networks\plugins\npqmp071505000010.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@rim.com/npappworld]
"Description"=
"Path"=C:\Program Files\Research In Motion Limited\BlackBerry App World Browser Plugin\npappworld.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@RIM.com/WebSLLauncher,version=1.0]
"Description"=BlackBerry Web Software Loading Helper Plug-In for Mozilla browsers
"Path"=C:\Program Files\Common Files\Research In Motion\BBWebSLLauncher\NPWebSLLauncher.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\Adobe Reader]
"Description"=Handles PDFs in-place in Firefox
"Path"=C:\Program Files\Adobe\Reader 9.0\Reader\AIR\nppdf32.dll
C:\Program Files\Mozilla Firefox\extensions\
{CAFEEFAC-0016-0000-0026-ABCDEFFEDCBA}
C:\Program Files\Mozilla Firefox\components\
binary.manifest
browsercomps.dll
npCouponPrinter.xpt
nsIMediaPlugin.xpt
nsIQTScriptablePlugin.xpt
Scriptff.dll
C:\Program Files\Mozilla Firefox\plugins\
install.js
np-mswmp.dll
npCouponPrinter.dll
npdeployJava1.dll
npGoogleGadgetPluginFirefoxWin.dll
npMozCouponPrinter.dll
NPOFF12.DLL
nppdf32.dll
npqtplugin.dll
npqtplugin2.dll
npqtplugin3.dll
npqtplugin4.dll
npqtplugin5.dll
npqtplugin6.dll
npqtplugin7.dll
NPTURNMED.dll
QuickTimePlugin.class
WMP Firefox Plugin License.rtf
WMP Firefox Plugin RelNotes.txt
C:\Program Files\Mozilla Firefox\searchplugins\
amazondotcom.xml
bing.xml
eBay.xml
google.xml
wikipedia.xml
yahoo.xml
C:\Users\Christy\AppData\Roaming\Mozilla\Firefox\Profiles\6evwqrab.default\extensions\
{77b819fa-95ad-4f2c-ac7c-486b356188a9}
C:\Users\Christy\AppData\Roaming\Mozilla\Firefox\Profiles\6evwqrab.default\searchplugins\
search-the-web.xml
======Registry dump======
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4efb-9B51-7695ECA05670}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{0347C33E-8762-4905-BF09-768834316C61}]
HP Print Enhancer - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_printenhancer.dll [2009-10-22 328248]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{18DF081C-E8AD-4283-A596-FA578C2EBDC3}]
Adobe PDF Link Helper - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll [2010-09-22 75200]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{7DB2D5A0-7241-4E79-B68D-6309F01C5231}]
scriptproxy - C:\Program Files\Common Files\McAfee\SystemCore\ScriptSn.20110510005028.dll [2011-04-14 75848]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{B164E929-A1B6-4A06-B104-2CD0E90A88FF}]
McAfee SiteAdvisor BHO - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll [2011-04-08 251928]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DBC80044-A445-435b-BC74-9C25C1C588A9}]
Java(tm) Plug-In 2 SSV Helper - C:\Program Files\Java\jre6\bin\jp2ssv.dll [2011-06-14 42272]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{FFFFFFFF-CF4E-4F2B-BDC2-0E72E116A856}]
HP Smart BHO Class - C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll [2009-10-22 517688]
{0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - McAfee SiteAdvisor Toolbar - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll [2011-04-08 251928]
"Windows Defender"=C:\Program Files\Windows Defender\MSASCui.exe [2008-01-19 1008184]
"RtHDVCpl"=C:\Windows\RtHDVCpl.exe [2008-01-17 4907008]
"ISUSScheduler"=C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe [2006-03-20 86960]
"ISUSPM Startup"=C:\PROGRA~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe [2006-03-20 213936]
"ECenter"=C:\Dell\E-Center\EULALauncher.exe [2007-05-25 17920]
"dscactivate"=C:\Program Files\Dell Support Center\gs_agent\custom\dsca.exe [2007-11-15 16384]
"Adobe Photo Downloader"=C:\Program Files\Adobe\Photoshop Elements 6.0\apdproxy.exe [2007-09-11 67488]
"Symantec PIF AlertEng"=C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe [2008-01-29 583048]
"DellSupportCenter"=C:\Program Files\Dell Support Center\bin\sprtcmd.exe [2009-05-21 206064]
"AppleSyncNotifier"=C:\Program Files\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe [2011-04-20 58656]
"hpqSRMon"=C:\Program Files\HP\Digital Imaging\bin\hpqSRMon.exe [2008-08-20 150016]
"Adobe Reader Speed Launcher"=C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe [2011-06-07 37296]
"Adobe ARM"=C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2011-03-29 937920]
"mcui_exe"=C:\Program Files\McAfee.com\Agent\mcagent.exe [2011-06-28 1195408]
"RIMBBLaunchAgent.exe"=C:\Program Files\Common Files\Research In Motion\USB Drivers\RIMBBLaunchAgent.exe [2011-02-18 79192]
"SunJavaUpdateSched"=C:\Program Files\Common Files\Java\Java Update\jusched.exe [2011-04-08 254696]
"QuickTime Task"=C:\Program Files\QuickTime\QTTask.exe [2011-07-05 421888]
"iTunesHelper"=C:\Program Files\iTunes\iTunesHelper.exe [2011-08-19 421736]
"Malwarebytes' Anti-Malware (reboot)"=C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe [2011-07-06 1047656]
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunOnce]
"GrpConv"=grpconv -o []
"Malwarebytes' Anti-Malware"=C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe [2011-07-06 449584]
"ISUSPM"=C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe [2006-03-20 213936]
"ehTray.exe"=C:\Windows\ehome\ehTray.exe [2008-01-19 125952]
"WMPNSCFG"=C:\Program Files\Windows Media Player\WMPNSCFG.exe [2008-01-19 202240]
"SUPERAntiSpyware"=C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe [2010-02-18 2012912]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\RunOnce]
"Shockwave Updater"=C:\Windows\system32\Adobe\Shockwave 11\SwHelper_1150600.exe [2009-06-05 468408]
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Digital Line Detect.lnk - C:\Program Files\Digital Line Detect\DLG.exe
HP Digital Imaging Monitor.lnk - C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
Kodak EasyShare software.lnk - C:\Program Files\Kodak\Kodak EasyShare software\bin\EasyShare.exe
McAfee Security Scan Plus.lnk - C:\Program Files\McAfee Security Scan\2.0.181\SSScheduler.exe
C:\Users\Christy\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\StartUp
OneNote 2007 Screen Clipper and Launcher.lnk - C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\!SASWinLogon]
C:\Program Files\SUPERAntiSpyware\SASWINLO.dll [2009-09-03 548352]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ShellExecuteHooks]
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"=C:\Program Files\SUPERAntiSpyware\SASSEH.DLL [2008-05-13 77824]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\mcmscsvc]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MCODS]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\McMPFSvc]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mcmscsvc]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\MCODS]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfefire]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfefirek]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfefirek.sys]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfehidk]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfehidk.sys]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mfevtp]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\WudfPf]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\WudfRd]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\WudfSvc]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\WudfUsbccidDriver]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"LogonHoursAction"=2
"DontDisplayLogonHoursWarnings"=1
"dontdisplaylastusername"=0
"legalnoticecaption"=
"legalnoticetext"=
"shutdownwithoutlogon"=1
"undockwithoutlogon"=1
"EnableUIADesktopToggle"=0
"NoDriveTypeAutoRun"=145
"BindDirectlyToPropertySetStorage"=0
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32]
"vidc.mrle"=msrle32.dll
"vidc.msvc"=msvidc32.dll
"msacm.imaadpcm"=imaadp32.acm
"msacm.msg711"=msg711.acm
"msacm.msgsm610"=msgsm32.acm
"msacm.msadpcm"=msadp32.acm
"midimapper"=midimap.dll
"wavemapper"=msacm32.drv
"vidc.uyvy"=msyuv.dll
"vidc.yuy2"=msyuv.dll
"vidc.yvyu"=msyuv.dll
"vidc.iyuv"=iyuv_32.dll
"vidc.i420"=iyuv_32.dll
"vidc.yvu9"=tsbyuv.dll
"msacm.l3acm"=C:\Windows\System32\l3codeca.acm
"vidc.cvid"=iccvid.dll
"wave"=wdmaud.drv
"midi"=wdmaud.drv
"mixer"=wdmaud.drv
"aux"=wdmaud.drv
======File associations======
.js - edit - C:\Windows\System32\Notepad.exe %1
.js - open - C:\Windows\System32\WScript.exe "%1" %*
======List of files/folders created in the last 1 month======
2011-08-31 18:06:39 ----D---- C:\rsit
2011-08-31 18:06:39 ----D---- C:\Program Files\trend micro
2011-08-30 20:47:38 ----D---- C:\Users\Christy\AppData\Roaming\Malwarebytes
2011-08-30 20:47:31 ----A---- C:\Windows\system32\drivers\mbamswissarmy.sys
2011-08-30 20:47:30 ----D---- C:\ProgramData\Malwarebytes
2011-08-30 20:47:27 ----D---- C:\Program Files\Malwarebytes' Anti-Malware
2011-08-30 20:47:27 ----A---- C:\Windows\system32\drivers\mbam.sys
2011-08-30 20:36:35 ----A---- C:\TDSSKiller.2.5.17.0_30.08.2011_20.36.35_log.txt
2011-08-30 20:22:34 ----A---- C:\Windows\ntbtlog.txt
2011-08-25 18:30:01 ----D---- C:\Program Files\iPod
2011-08-23 14:08:30 ----A---- C:\Windows\system32\tzres.dll
2011-08-10 18:25:56 ----A---- C:\Windows\system32\mshtmled.dll
2011-08-10 18:25:55 ----A---- C:\Windows\system32\jscript.dll
2011-08-10 18:25:55 ----A---- C:\Windows\system32\ieui.dll
2011-08-10 18:25:55 ----A---- C:\Windows\system32\iertutil.dll
2011-08-10 18:25:54 ----A---- C:\Windows\system32\wininet.dll
2011-08-10 18:25:54 ----A---- C:\Windows\system32\jsproxy.dll
2011-08-10 18:25:54 ----A---- C:\Windows\system32\jscript9.dll
2011-08-10 18:25:53 ----A---- C:\Windows\system32\urlmon.dll
2011-08-10 18:25:53 ----A---- C:\Windows\system32\url.dll
2011-08-10 18:25:53 ----A---- C:\Windows\system32\ieframe.dll
2011-08-10 18:25:51 ----A---- C:\Windows\system32\mshtml.dll
2011-08-09 17:09:25 ----A---- C:\Windows\system32\winsrv.dll
2011-08-09 17:09:22 ----A---- C:\Windows\system32\drivers\mrxsmb10.sys
2011-08-09 17:09:16 ----A---- C:\Windows\system32\xmllite.dll
2011-08-09 17:08:51 ----A---- C:\Windows\system32\ntkrnlpa.exe
2011-08-09 17:08:50 ----A---- C:\Windows\system32\ntoskrnl.exe
2011-08-09 17:08:47 ----A---- C:\Windows\system32\drivers\tcpip.sys
2011-08-05 17:02:28 ----D---- C:\Program Files\QuickTime
======List of files/folders modified in the last 1 month======
2011-08-31 18:06:42 ----D---- C:\Windows\Temp
2011-08-31 18:06:39 ----RD---- C:\Program Files
2011-08-31 08:13:03 ----D---- C:\Program Files\Mozilla Firefox
2011-08-30 20:56:48 ----D---- C:\Windows\system32\drivers
2011-08-30 20:56:48 ----D---- C:\Windows\LiveKernelReports
2011-08-30 20:47:30 ----HD---- C:\ProgramData
2011-08-30 20:22:34 ----D---- C:\Windows
2011-08-30 18:34:15 ----D---- C:\Windows\Prefetch
2011-08-30 16:21:21 ----D---- C:\Program Files\SUPERAntiSpyware
2011-08-30 13:57:06 ----SHD---- C:\System Volume Information
2011-08-30 13:51:40 ----D---- C:\Windows\system32\catroot2
2011-08-30 12:14:06 ----SHD---- C:\Windows\Installer
2011-08-30 12:14:04 ----HD---- C:\Config.Msi
2011-08-26 18:56:47 ----D---- C:\Windows\System32
2011-08-25 18:31:46 ----D---- C:\Program Files\iTunes
2011-08-25 18:29:59 ----D---- C:\Program Files\Common Files\Apple
2011-08-24 14:40:32 ----D---- C:\Windows\rescache
2011-08-24 14:29:55 ----D---- C:\Windows\winsxs
2011-08-24 14:29:43 ----D---- C:\Windows\system32\en-US
2011-08-23 14:05:04 ----D---- C:\Windows\system32\catroot
2011-08-11 21:46:36 ----D---- C:\Windows\Microsoft.NET
2011-08-11 21:46:00 ----RSD---- C:\Windows\assembly
2011-08-11 00:02:39 ----D---- C:\Windows\system32\migration
2011-08-11 00:02:38 ----D---- C:\Program Files\Internet Explorer
2011-08-11 00:02:37 ----D---- C:\Program Files\Windows Mail
2011-08-10 18:22:34 ----A---- C:\Windows\system32\mrt.exe
2011-08-10 18:16:25 ----A---- C:\Windows\system32\PerfStringBackup.INI
2011-08-10 18:16:24 ----D---- C:\Windows\inf
R0 amacpi;Microsoft Away Mode System; C:\Windows\system32\DRIVERS\null.sys [2008-01-19 4608]
R0 mfehidk;McAfee Inc. mfehidk; C:\Windows\system32\drivers\mfehidk.sys [2011-04-14 387480]
R0 nvstor32;nvstor32; C:\Windows\system32\DRIVERS\nvstor32.sys [2007-08-09 110624]
R0 PxHelp20;PxHelp20; C:\Windows\System32\Drivers\PxHelp20.sys [2007-12-25 43528]
R1 mfenlfk;McAfee NDIS Light Filter; C:\Windows\system32\DRIVERS\mfenlfk.sys [2011-04-14 64584]
R1 mfewfpk;McAfee Inc. mfewfpk; C:\Windows\system32\drivers\mfewfpk.sys [2011-04-14 165032]
R3 GEARAspiWDM;GEAR ASPI Filter Driver; C:\Windows\System32\Drivers\GEARAspiWDM.sys [2009-05-18 26600]
R3 mfefirek;McAfee Inc. mfefirek; C:\Windows\system32\drivers\mfefirek.sys [2011-04-14 314088]
R3 NVENETFD;NVIDIA nForce Networking Controller Driver; C:\Windows\system32\DRIVERS\nvmfdx32.sys [2007-03-15 1059112]
R3 rt61x86;RT61 Wireless Driver for Windows Vista; C:\Windows\system32\DRIVERS\netr61.sys [2008-11-26 333824]
S1 SASDIFSV;SASDIFSV; \??\C:\Program Files\SUPERAntiSpyware\SASDIFSV.SYS [2010-02-17 12872]
S1 SASKUTIL;SASKUTIL; \??\C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS [2010-02-17 66632]
S2 dsunidrv;DellSupport UniDriver; C:\Windows\system32\DRIVERS\dsunidrv.sys [2007-02-25 5376]
S2 mdmxsdk;mdmxsdk; C:\Windows\system32\DRIVERS\mdmxsdk.sys [2006-06-19 12672]
S2 XAudio;XAudio; C:\Windows\system32\DRIVERS\xaudio.sys [2006-08-04 8192]
S3 cfwids;McAfee Inc. cfwids; C:\Windows\system32\drivers\cfwids.sys [2011-04-14 56064]
S3 Dot4;MS IEEE-1284.4 Driver; C:\Windows\system32\DRIVERS\Dot4.sys [2008-01-19 131584]
S3 Dot4Print;Print Class Driver for IEEE-1284.4; C:\Windows\system32\DRIVERS\Dot4Prt.sys [2008-01-19 16384]
S3 dot4usb;MS Dot4USB Filter Dot4USB Filter; C:\Windows\system32\DRIVERS\dot4usb.sys [2008-01-19 36864]
S3 drmkaud;Microsoft Kernel DRM Audio Descrambler; C:\Windows\system32\drivers\drmkaud.sys [2008-01-19 5632]
S3 DSproct;DSproct; \??\C:\Program Files\DellSupport\GTAction\triggers\DSproct.sys [2006-10-05 4736]
S3 e1express;Intel(R) PRO/1000 PCI Express Network Connection Driver; C:\Windows\system32\DRIVERS\e1e6032.sys [2006-11-02 200704]
S3 HSF_DPV;HSF_DPV; C:\Windows\system32\DRIVERS\HSX_DPV.sys [2006-10-18 986624]
S3 HSXHWBS2;HSXHWBS2; C:\Windows\system32\DRIVERS\HSXHWBS2.sys [2006-10-18 258048]
S3 IntcAzAudAddService;Service for Realtek HD Audio (WDM); C:\Windows\system32\drivers\RTKVHDA.sys [2008-01-24 2054872]
S3 MBAMProtector;MBAMProtector; \??\C:\Windows\system32\drivers\mbam.sys [2011-07-06 22712]
S3 MBAMSwissArmy;MBAMSwissArmy; \??\C:\Windows\system32\drivers\mbamswissarmy.sys [2011-07-06 41272]
S3 mfeapfk;McAfee Inc. mfeapfk; C:\Windows\system32\drivers\mfeapfk.sys [2011-04-14 95824]
S3 mfeavfk;McAfee Inc. mfeavfk; C:\Windows\system32\drivers\mfeavfk.sys [2011-04-14 153280]
S3 mfebopk;McAfee Inc. mfebopk; C:\Windows\system32\drivers\mfebopk.sys [2011-04-14 52320]
S3 mferkdet;McAfee Inc. mferkdet; C:\Windows\system32\drivers\mferkdet.sys [2011-04-14 84488]
S3 MSKSSRV;Microsoft Streaming Service Proxy; C:\Windows\system32\drivers\MSKSSRV.sys [2008-01-19 8192]
S3 MSPCLOCK;Microsoft Streaming Clock Proxy; C:\Windows\system32\drivers\MSPCLOCK.sys [2008-01-19 5888]
S3 MSPQM;Microsoft Streaming Quality Manager Proxy; C:\Windows\system32\drivers\MSPQM.sys [2008-01-19 5504]
S3 MSTEE;Microsoft Streaming Tee/Sink-to-Sink Converter; C:\Windows\system32\drivers\MSTEE.sys [2008-01-19 6016]
S3 nvlddmkm;nvlddmkm; C:\Windows\system32\DRIVERS\nvlddmkm.sys [2009-07-14 9557216]
S3 R300;R300; C:\Windows\system32\DRIVERS\atikmdag.sys [2006-11-02 2028032]
S3 RimUsb;BlackBerry Smartphone; C:\Windows\System32\Drivers\RimUsb.sys []
S3 SASENUM;SASENUM; \??\C:\Program Files\SUPERAntiSpyware\SASENUM.SYS [2010-02-17 12872]
S3 StillCam;Still Serial Digital Camera Driver; C:\Windows\system32\DRIVERS\serscan.sys [2008-01-19 9216]
S3 USBAAPL;Apple Mobile USB Driver; C:\Windows\System32\Drivers\usbaapl.sys [2011-05-10 42496]
S3 usbscan;USB Scanner Driver; C:\Windows\system32\DRIVERS\usbscan.sys [2008-01-19 35328]
S3 winachsf;winachsf; C:\Windows\system32\DRIVERS\HSX_CNXT.sys [2006-10-18 659968]
S3 WpdUsb;WpdUsb; C:\Windows\system32\DRIVERS\wpdusb.sys [2009-09-30 40448]
S3 WUDFRd;WUDFRd; C:\Windows\system32\DRIVERS\WUDFRd.sys [2008-01-19 83328]
R2 McMPFSvc;McAfee Personal Firewall Service; C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe [2010-03-10 271480]
R2 mcmscsvc;McAfee Services; C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 271480]
R2 mfefire;McAfee Firewall Core Service; C:\Program Files\Common Files\McAfee\SystemCore\\mfefire.exe [2011-04-14 188136]
R2 mfevtp;McAfee Validation Trust Protection Service; C:\Windows\system32\mfevtps.exe [2011-04-14 141792]
S2 AdobeActiveFileMonitor6.0;Adobe Active File Monitor V6; C:\Program Files\Adobe\Photoshop Elements 6.0\PhotoshopElementsFileAgent.exe [2007-09-11 124832]
S2 AERTFilters;Andrea RT Filters Service; C:\Windows\system32\AERTSrv.exe [2007-12-05 77824]
S2 Apple Mobile Device;Apple Mobile Device; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [2011-02-18 37664]
S2 Automatic LiveUpdate Scheduler;Automatic LiveUpdate Scheduler; C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe [2007-09-12 554352]
S2 Bonjour Service;Bonjour Service; C:\Program Files\Bonjour\mDNSResponder.exe [2011-07-12 387944]
S2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86; C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
S2 FontCache;@%systemroot%\system32\FntCache.dll,-100; C:\Windows\system32\svchost.exe [2008-01-19 21504]
S2 hpqddsvc;HP CUE DeviceDiscovery Service; C:\Windows\system32\svchost.exe [2008-01-19 21504]
S2 LiveUpdate Notice Ex;LiveUpdate Notice Service Ex; C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe /h ccCommon []
S2 LiveUpdate Notice Service;LiveUpdate Notice Service; C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe [2008-01-29 583048]
S2 MBAMService;MBAMService; C:\Program Files\Malwarebytes' Anti-Malware\mbamservice.exe [2011-07-06 366640]
S2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service; C:\Program Files\McAfee\SiteAdvisor\McSACore.exe [2011-02-16 88176]
S2 McNaiAnn;McAfee VirusScan Announcer; C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 271480]
S2 McNASvc;McAfee Network Agent; C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 271480]
S2 McProxy;McAfee Proxy Service; C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 271480]
S2 McShield;McShield; C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe [2011-04-14 171168]
S2 Net Driver HPZ12;Net Driver HPZ12; C:\Windows\System32\svchost.exe [2008-01-19 21504]
S2 nvsvc;NVIDIA Display Driver Service; C:\Windows\system32\nvvsvc.exe [2008-05-03 118784]
S2 Pml Driver HPZ12;Pml Driver HPZ12; C:\Windows\System32\svchost.exe [2008-01-19 21504]
S2 RoxWatch9;Roxio Hard Drive Watcher 9; C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatch9.exe [2006-11-05 159744]
S2 sprtsvc_dellsupportcenter;SupportSoft Sprocket Service (dellsupportcenter); C:\Program Files\Dell Support Center\bin\sprtsvc.exe [2008-08-13 201968]
S2 XAudioService;XAudioService; C:\Windows\system32\DRIVERS\xaudio.exe [2006-08-04 386560]
S3 DSBrokerService;DSBrokerService; C:\Program Files\DellSupport\brkrsvc.exe [2007-03-19 70656]
S3 FLEXnet Licensing Service;FLEXnet Licensing Service; C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe [2007-12-25 654848]
S3 hpqcxs08;hpqcxs08; C:\Windows\system32\svchost.exe [2008-01-19 21504]
S3 IDriverT;InstallDriver Table Manager; C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe [2004-10-22 73728]
S3 iPod Service;iPod Service; C:\Program Files\iPod\bin\iPodService.exe [2011-08-19 821096]
S3 LiveUpdate;LiveUpdate; C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE [2007-09-12 2999664]
S3 McComponentHostService;McAfee Security Scan Component Host Service; C:\Program Files\McAfee Security Scan\2.0.181\McCHSvc.exe [2010-01-15 227232]
S3 McODS;McAfee Scanner; C:\Program Files\McAfee\VirusScan\mcods.exe [2010-10-07 364216]
S3 odserv;Microsoft Office Diagnostics Service; C:\Program Files\Common Files\Microsoft Shared\OFFICE12\ODSERV.EXE [2008-11-04 441712]
S3 ose;Office Source Engine; C:\Program Files\Common Files\Microsoft Shared\Source Engine\OSE.EXE [2006-10-26 145184]
S3 RoxMediaDB9;RoxMediaDB9; C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe [2006-11-05 880640]
S3 stllssvr;stllssvr; C:\Program Files\Common Files\SureThing Shared\stllssvr.exe [2006-09-14 73728]
S3 WPFFontCache_v0400;@c:\Windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe,-100; C:\Windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe [2010-03-18 753504]
Offline Cory
Re: Security Protection Virus
« Reply #10 on: August 31, 2011, 11:16:59 PM »
info.txt:
info.txt logfile of random's system information tool 1.09 2011-08-31 18:06:58
======Uninstall list======
 Update for Microsoft Office 2007 (KB2508958)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {0C5823AA-7B6F-44E1-8D5B-8FD1FF0E6438}
32 Bit HP CIO Components Installer-->MsiExec.exe /I{2614F54E-A828-49FA-93BA-45A3F756BFAA}
Acrobat.com-->msiexec /qb /x {6421F085-1FAA-DE13-D02A-CFB412C522A4}
Acrobat.com-->MsiExec.exe /I{6421F085-1FAA-DE13-D02A-CFB412C522A4}
Adobe AIR-->c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater.exe -arp:uninstall
Adobe AIR-->MsiExec.exe /I{A2BCA9F1-566C-4805-97D1-7FDC93386723}
Adobe Flash Player 10 ActiveX-->C:\Windows\system32\Macromed\Flash\FlashUtil10q_ActiveX.exe -maintain activex
Adobe Flash Player 10 Plugin-->C:\Windows\system32\Macromed\Flash\FlashUtil10v_Plugin.exe -maintain plugin
Adobe Photoshop Elements 6.0-->msiexec /I {F54AC413-D2C6-4A24-B324-370C223C6250}
Adobe Reader 9.4.5-->MsiExec.exe /I{AC76BA86-7AD7-1033-7B44-A94000000001}
Adobe Shockwave Player 11.5-->"C:\Windows\system32\Adobe\Shockwave 11\uninstaller.exe"
Apple Application Support-->MsiExec.exe /I{6A3F9D74-BB80-4451-8CA1-4B3A857F1359}
Apple Mobile Device Support-->MsiExec.exe /I{C23CD6DA-1958-43A5-ADD0-59396572E02E}
Apple Software Update-->MsiExec.exe /I{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}
BlackBerry App World Browser Plugin-->MsiExec.exe /X{598420E8-E9F9-4FAE-9B6C-599FDF2F611A}
BlackBerry Device Software Updater-->MsiExec.exe /X{B0A92733-C870-415C-A494-DF72C2C58402}
Bonjour-->MsiExec.exe /X{D03482C5-9AD8-496D-B388-692AE04C93AF}
CCScore-->MsiExec.exe /I{B4B44FE7-41FF-4DAD-8C0A-E406DDA72992}
Compatibility Pack for the 2007 Office system-->MsiExec.exe /X{90120000-0020-0409-0000-0000000FF1CE}
Conexant D850 PCI V.92 Modem-->C:\Program Files\CONEXANT\CNXT_MODEM_PCI_VEN_14F1&DEV_2F20&SUBSYS_200F14F1\HXFSETUP.EXE -U -IDel200fz.inf
Coupon Printer for Windows-->"C:\Program Files\Coupons\uninstall.exe" "/U:C:\Program Files\Coupons\Uninstall\uninstall.xml"
Dell Support Center (Support Software)-->MsiExec.exe /X{E3BFEE55-39E2-4BE0-B966-89FE583822C1}
Dell System Customization Wizard-->MsiExec.exe /I{13BA7B44-B712-4DEE-A7B8-1DD564F37AE5}
DellSupport-->MsiExec.exe /X{7EFA5E6F-74F7-4AFB-8AEA-AA790BD3A76D}
Digital Line Detect-->C:\Program Files\InstallShield Installation Information\{E646DCF0-5A68-11D5-B229-002078017FBF}\setup.exe -runfromtemp -l0x0009 -removeonly
EarthLink Setup Files-->MsiExec.exe /X{5E68BB65-4059-4FE5-AAC4-0CD1D79BBDE2}
ESSBrwr-->MsiExec.exe /I{643EAE81-920C-4931-9F0B-4B343B225CA6}
ESSCDBK-->MsiExec.exe /I{AE1FA02D-E6A4-4EA0-8E58-6483CAC016DD}
ESScore-->MsiExec.exe /I{42938595-0D83-404D-9F73-F8177FDD531A}
ESSgui-->MsiExec.exe /I{91517631-A9F3-4B7C-B482-43E0068FD55A}
ESSini-->MsiExec.exe /I{8E92D746-CD9F-4B90-9668-42B74C14F765}
ESSPCD-->MsiExec.exe /I{14D4ED84-6A9A-45A0-96F6-1753768C3CB5}
ESSPDock-->MsiExec.exe /I{FCDB1C92-03C6-4C76-8625-371224256091}
ESSSONIC-->MsiExec.exe /I{073F22CE-9A5B-4A40-A604-C7270AC6BF34}
ESSTOOLS-->MsiExec.exe /I{8A502E38-29C9-49FA-BCFA-D727CA062589}
essvatgt-->MsiExec.exe /I{2D03B6F8-DF36-4980-B7B6-5B93D5BA3A8F}
fflink-->MsiExec.exe /I{608D2A3C-6889-4C11-9B54-A42F45ACBFDB}
Games, Music, & Photos Launcher-->MsiExec.exe /I{3E25E350-949F-4DB7-8288-2A60E018B4C1}
Hotfix for Microsoft .NET Framework 3.5 SP1 (KB953595)-->C:\Windows\system32\msiexec.exe /package {CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9} /uninstall  /qb+ REBOOTPROMPT=""
Hotfix for Microsoft .NET Framework 3.5 SP1 (KB958484)-->C:\Windows\system32\msiexec.exe /package {CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9} /uninstall {A7EEA2F2-BFCD-4A54-A575-7B81A786E658} /qb+ REBOOTPROMPT=""
HP Customer Participation Program 10.0-->C:\Program Files\HP\Digital Imaging\ExtCapUninstall\hpzscr01.exe -datfile hpqhsc01.dat
HP Deskjet F2200 All-In-One Driver Software 10.0 Rel .3-->C:\Program Files\HP\Digital Imaging\{D77D43B5-ED55-426b-B67B-E21F804F6102}\setup\hpzscr01.exe -datfile hposcr27.dat -onestop
HP Imaging Device Functions 10.0-->C:\Program Files\HP\Digital Imaging\DeviceManagement\hpzscr01.exe -datfile hpqbud01.dat
HP Photosmart Essential 3.5-->C:\Program Files\HP\Digital Imaging\PhotosmartEssential\hpzscr01.exe -datfile hpqbud13.dat
HP Smart Web Printing 4.60-->C:\Program Files\HP\Digital Imaging\Smart Web Printing\hpzscr01.exe -datfile hpqbud15.dat
HP Solution Center 13.0-->C:\Program Files\HP\Digital Imaging\eSupport\hpzscr01.exe -datfile hpqbud05.dat -forcereboot
HP Update-->MsiExec.exe /X{787D1A33-A97B-4245-87C0-7174609A540C}
Internet Service Offers Launcher-->MsiExec.exe /I{CCFF1E13-77A2-4032-8B12-7566982A27DF}
iPhone Configuration Utility-->MsiExec.exe /I{FA54AFB1-5745-4389-B8C1-9F7509672ED1}
iTunes-->MsiExec.exe /I{69995C7A-062A-4A90-A4DF-8C22895DF522}
Java(TM) 6 Update 26-->MsiExec.exe /X{26A24AE4-039D-4CA4-87B4-2F83216012FF}
Java(TM) SE Runtime Environment 6-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160000}
kgcbaby-->MsiExec.exe /I{E18B549C-5D15-45DA-8D8F-8FD2BD946344}
kgcbase-->MsiExec.exe /I{F22C222C-3CE2-4A4B-A83F-AF4681371ABE}
kgchday-->MsiExec.exe /I{11F3F858-4131-4FFA-A560-3FE282933B6E}
kgchlwn-->MsiExec.exe /I{03EDED24-8375-407D-A721-4643D9768BE1}
kgcinvt-->MsiExec.exe /I{9BD54685-1496-46A5-AB62-357CD140ED8B}
kgckids-->MsiExec.exe /I{693C08A7-9E76-43FF-B11E-9A58175474C4}
kgcmove-->MsiExec.exe /I{A1588373-1D86-4D44-86C9-78ABD190F9CC}
kgcvday-->MsiExec.exe /I{8A8664E1-84C8-4936-891C-BC1F07797549}
Kodak EasyShare software-->C:\ProgramData\Kodak\EasyShareSetup\$SETUP_140002_33bf49\Setup.exe /APR-REMOVE
Linksys Wireless-G PCI Adapter Driver - WMP54Gv4.1-->C:\Program Files\InstallShield Installation Information\{4DDC3BED-CC68-44AA-B435-D727B620CA5B}\setup.exe -runfromtemp -l0x0009 -removeonly
LiveUpdate 3.2 (Symantec Corporation)-->"C:\Program Files\Symantec\LiveUpdate\LSETUP.EXE" /U
LiveUpdate Notice (Symantec Corporation)-->MsiExec.exe /X{DBA4DB9D-EE51-4944-A419-98AB1F1249C8}
Malwarebytes' Anti-Malware version 1.51.1.1800-->"C:\Program Files\Malwarebytes' Anti-Malware\unins000.exe"
McAfee Security Scan Plus-->"C:\Program Files\McAfee Security Scan\uninstall.exe"
McAfee SecurityCenter-->C:\Program Files\McAfee\MSC\mcuihost.exe /body:misp://MSCJsRes.dll::uninstall.html /id:uninstall
Microsoft .NET Framework 3.5 SP1-->c:\Windows\Microsoft.NET\Framework\v3.5\Microsoft .NET Framework 3.5 SP1\setup.exe
Microsoft .NET Framework 3.5 SP1-->MsiExec.exe /I{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}
Microsoft .NET Framework 4 Client Profile-->C:\Windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\Setup.exe /repair /x86 /parameterfolder Client
Microsoft .NET Framework 4 Client Profile-->MsiExec.exe /X{3C3901C5-3455-3E0A-A214-0B093A5070A6}
Microsoft Office 2007 Service Pack 2 (SP2)-->msiexec /package {90120000-0016-0409-0000-0000000FF1CE} /uninstall {2FC4457D-409E-466F-861F-FB0CB796B53E}
Microsoft Office 2007 Service Pack 2 (SP2)-->msiexec /package {90120000-0018-0409-0000-0000000FF1CE} /uninstall {2FC4457D-409E-466F-861F-FB0CB796B53E}
Microsoft Office 2007 Service Pack 2 (SP2)-->msiexec /package {90120000-001B-0409-0000-0000000FF1CE} /uninstall {2FC4457D-409E-466F-861F-FB0CB796B53E}
Microsoft Office 2007 Service Pack 2 (SP2)-->msiexec /package {90120000-006E-0409-0000-0000000FF1CE} /uninstall {DE5A002D-8122-4278-A7EE-3121E7EA254E}
Microsoft Office 2007 Service Pack 2 (SP2)-->msiexec /package {90120000-00A1-0409-0000-0000000FF1CE} /uninstall {2FC4457D-409E-466F-861F-FB0CB796B53E}
Microsoft Office 2007 Service Pack 2 (SP2)-->msiexec /package {90120000-0115-0409-0000-0000000FF1CE} /uninstall {DE5A002D-8122-4278-A7EE-3121E7EA254E}
Microsoft Office 2007 Service Pack 2 (SP2)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}
Microsoft Office Excel MUI (English) 2007-->MsiExec.exe /X{90120000-0016-0409-0000-0000000FF1CE}
Microsoft Office File Validation Add-In-->MsiExec.exe /I{90140000-2005-0000-0000-0000000FF1CE}
Microsoft Office Home and Student 2007-->"C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\setup.exe" /uninstall HOMESTUDENTR /dll OSETUP.DLL
Microsoft Office Home and Student 2007-->MsiExec.exe /X{91120000-002F-0000-0000-0000000FF1CE}
Microsoft Office OneNote MUI (English) 2007-->MsiExec.exe /X{90120000-00A1-0409-0000-0000000FF1CE}
Microsoft Office PowerPoint MUI (English) 2007-->MsiExec.exe /X{90120000-0018-0409-0000-0000000FF1CE}
Microsoft Office Proof (English) 2007-->MsiExec.exe /X{90120000-001F-0409-0000-0000000FF1CE}
Microsoft Office Proof (French) 2007-->MsiExec.exe /X{90120000-001F-040C-0000-0000000FF1CE}
Microsoft Office Proof (Spanish) 2007-->MsiExec.exe /X{90120000-001F-0C0A-0000-0000000FF1CE}
Microsoft Office Proofing (English) 2007-->MsiExec.exe /X{90120000-002C-0409-0000-0000000FF1CE}
Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)-->msiexec /package {90120000-001F-0409-0000-0000000FF1CE} /uninstall {ABDDE972-355B-4AF1-89A8-DA50B7B5C045}
Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)-->msiexec /package {90120000-001F-040C-0000-0000000FF1CE} /uninstall {F580DDD5-8D37-4998-968E-EBB76BB86787}
Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)-->msiexec /package {90120000-001F-0C0A-0000-0000000FF1CE} /uninstall {187308AB-5FA7-4F14-9AB9-D290383A10D9}
Microsoft Office Shared MUI (English) 2007-->MsiExec.exe /X{90120000-006E-0409-0000-0000000FF1CE}
Microsoft Office Shared Setup Metadata MUI (English) 2007-->MsiExec.exe /X{90120000-0115-0409-0000-0000000FF1CE}
Microsoft Office Word MUI (English) 2007-->MsiExec.exe /X{90120000-001B-0409-0000-0000000FF1CE}
Microsoft Office Word Viewer 2003-->MsiExec.exe /I{90850409-6000-11D3-8CFE-0150048383C9}
Microsoft Works-->MsiExec.exe /I{6D52C408-B09A-4520-9B18-475B81D393F1}
Modem Diagnostic Tool-->MsiExec.exe /I{F63A3748-B93D-4360-9AD4-B064481A5C7B}
Mozilla Firefox 6.0 (x86 en-US)-->C:\Program Files\Mozilla Firefox\uninstall\helper.exe
MSXML 4.0 SP2 (KB973688)-->MsiExec.exe /I{F662A8E6-F4DC-41A2-901E-8C11F044BDEC}
MuggleNet.com's Harry Potter and the Prisoner of Azkaban Screensaver-->C:\WINDOWS\st6unst.exe -n "C:\Windows\System32\ST6UNST.LOG"
netbrdg-->MsiExec.exe /I{4537EA4B-F603-4181-89FB-2953FC695AB1}
NVIDIA Drivers-->C:\Windows\system32\nvuninst.exe UninstallGUI
NVIDIANetworkDiagnostic-->C:\PROGRA~1\COMMON~1\INSTAL~1\Driver\9\INTEL3~1\IDriver.exe /M{EFAD4066-CAF3-4B27-9669-12EED352C376}
OfotoXMI-->MsiExec.exe /I{B162D0A6-9A1D-4B7C-91A5-88FB48113C45}
OGA Notifier 2.0.0048.0-->MsiExec.exe /I{B2544A03-10D0-4E5E-BA69-0362FFC20D18}
PowerPaint 2.50-->"C:\Program Files\FLISoft\PowerPaint\unins000.exe"
Product Documentation Launcher-->MsiExec.exe /I{89CEAE14-DD0F-448E-9554-15781EC9DB24}
QuickTime-->MsiExec.exe /I{C9E14402-3631-4182-B377-6B0DFB1C0339}
Realtek High Definition Audio Driver-->RtlUpd.exe -r -m
Roxio Creator Audio-->MsiExec.exe /I{83FFCFC7-88C6-41c6-8752-958A45325C82}
Roxio Creator BDAV Plugin-->MsiExec.exe /I{880AF49C-34F7-4285-A8AD-8F7A3D1C33DC}
Roxio Creator Copy-->MsiExec.exe /I{619CDD8A-14B6-43a1-AB6C-0F4EE48CE048}
Roxio Creator Data-->MsiExec.exe /I{0D397393-9B50-4c52-84D5-77E344289F87}
Roxio Creator DE-->MsiExec.exe /I{C8B0680B-CDAE-4809-9F91-387B6DE00F7C}
Roxio Creator Tools-->MsiExec.exe /I{0394CDC8-FABD-4ed8-B104-03393876DFDF}
Roxio Express Labeler-->MsiExec.exe /I{6675CA7F-E51B-4F6A-99D4-F8F0124C6EAA}
Roxio MyDVD DE-->MsiExec.exe /I{D639085F-4B6E-4105-9F37-A0DBB023E2FB}
Roxio Update Manager-->MsiExec.exe /I{30465B6C-B53F-49A1-9EBA-A3F187AD502E}
Safari-->MsiExec.exe /I{735619D4-B42A-437A-958C-199BFCAEDB38}
SBC Yahoo! DSL Home Networking Installer-->C:\Program Files\2Wire\Uninstaller.exe
Security Update for 2007 Microsoft Office System (KB2288621)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {5C497F0B-2061-4CC9-A61C-6B45B867354D}
Security Update for 2007 Microsoft Office System (KB2288931)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {CD769337-C8AC-46DB-A7DC-643E50089263}
Security Update for 2007 Microsoft Office System (KB2345043)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {536FB502-775F-4494-BACE-C02CC90B7A5B}
Security Update for 2007 Microsoft Office System (KB2509488)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {AD0DE453-0804-4495-9C91-33D0F9AA5463}
Security Update for 2007 Microsoft Office System (KB969559)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {69F52148-9BF6-4CDC-BF76-103DEAF3DD08}
Security Update for 2007 Microsoft Office System (KB976321)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {7F207DCA-3399-40CB-A968-6E5991B1421A}
Security Update for Microsoft .NET Framework 3.5 SP1 (KB2416473)-->C:\Windows\system32\msiexec.exe /package {CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9} /uninstall {A8894F19-59C8-38D2-8A75-36C0CCE56A5B} /qb+ REBOOTPROMPT=""
Security Update for Microsoft .NET Framework 4 Client Profile (KB2446708)-->c:\Windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\setup.exe /uninstallpatch {3E0806DB-3085-378A-840A-F0D3AE3609D1} /parameterfolder Client
Security Update for Microsoft .NET Framework 4 Client Profile (KB2478663)-->c:\Windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\setup.exe /uninstallpatch {728D9A6A-2206-31E8-9F65-C3EABEFCF53E} /parameterfolder Client
Security Update for Microsoft .NET Framework 4 Client Profile (KB2518870)-->c:\Windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\setup.exe /uninstallpatch {2CE2EB39-45C8-32D4-8A99-5529C38F1B99} /parameterfolder Client
Security Update for Microsoft .NET Framework 4 Client Profile (KB2539636)-->c:\Windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\setup.exe /uninstallpatch {7E97AB83-C1FE-38DE-B848-877E0A4BD81E} /parameterfolder Client
Security Update for Microsoft Office 2007 System (KB2541012)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {CD907315-705A-4475-A1A0-2A1245803E4D}
Security Update for Microsoft Office Excel 2007 (KB2541007)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {A0173254-F442-4D04-9154-43FA157B83D0}
Security Update for Microsoft Office InfoPath 2007 (KB979441)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {8CCB781A-CF6B-4FCB-B6D8-59C64DF5C6DB}
Security Update for Microsoft Office PowerPoint 2007 (KB2535818)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {8588DD11-6BD7-4400-B55C-DD5AB74B43E1}
Security Update for Microsoft Office PowerPoint Viewer 2007 (KB2464623)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {D75E6D0C-BADF-4F41-98B2-0C0F02C15062}
Security Update for Microsoft Office system 2007 (972581)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {3D019598-7B59-447A-80AE-815B703B84FF}
Security Update for Microsoft Office system 2007 (KB974234)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {FCD742B9-7A55-44BC-A776-F795F21FEDDC}
Security Update for Microsoft Office Visio Viewer 2007 (KB973709)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {71127777-8B2C-4F97-AF7A-6CF8CAC8224D}
Security Update for Microsoft Office Word 2007 (KB2344993)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {7A5B74FA-7A92-4FC9-821A-2DD5D4E73E48}
SFR-->MsiExec.exe /I{DB02F716-6275-42E9-B8D2-83BA2BF5100B}
SHASTA-->MsiExec.exe /I{605A4E39-613C-4A12-B56F-DEFBE6757237}
skin0001-->MsiExec.exe /I{5316DFC9-CE99-4458-9AB3-E8726EDE0210}
SKINXSDK-->MsiExec.exe /I{F4A2E7CC-60CA-4AFA-B67F-AD5E58173C3F}
Sonic Activation Module-->MsiExec.exe /I{35E1EC43-D4FC-4E4A-AAB3-20DDA27E8BB0}
staticcr-->MsiExec.exe /I{8943CE61-53BD-475E-90E1-A580869E98A2}
SUPERAntiSpyware Free Edition-->MsiExec.exe /X{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}
TBS WMP Plug-in-->C:\PROGRA~1\COMMON~1\INSTAL~1\Driver\1050\INTEL3~1\IDriver.exe /M{13515135-48BB-4184-8C1F-2FAE0138E200}
tooltips-->MsiExec.exe /I{E79987F0-0E34-42CC-B8FF-6C860AEEB26A}
Update for 2007 Microsoft Office System (KB967642)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {C444285D-5E4F-48A4-91DD-47AAAA68E92D}
Update for Microsoft .NET Framework 3.5 SP1 (KB963707)-->C:\Windows\system32\msiexec.exe /package {CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9} /uninstall {B2AE9C82-DC7B-3641-BFC8-87275C4F3607} /qb+ REBOOTPROMPT=""
Update for Microsoft Office 2007 Help for Common Features (KB963673)-->msiexec /package {90120000-006E-0409-0000-0000000FF1CE} /uninstall {AB365889-0395-4FAD-B702-CA5985D53D42}
Update for Microsoft Office 2007 System (KB2539530)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {0B4CEEAE-AA88-490C-BCB2-AAC3421981A4}
Update for Microsoft Office Excel 2007 Help (KB963678)-->msiexec /package {90120000-0016-0409-0000-0000000FF1CE} /uninstall {199DF7B6-169C-448C-B511-1054101BE9C9}
Update for Microsoft Office OneNote 2007 (KB980729)-->msiexec /package {91120000-002F-0000-0000-0000000FF1CE} /uninstall {329050A9-EF80-40F9-B633-74508F54C1FF}
Update for Microsoft Office OneNote 2007 Help (KB963670)-->msiexec /package {90120000-00A1-0409-0000-0000000FF1CE} /uninstall {2744EF05-38E1-4D5D-B333-E021EDAEA245}
Update for Microsoft Office Powerpoint 2007 Help (KB963669)-->msiexec /package {90120000-0018-0409-0000-0000000FF1CE} /uninstall {397B1D4F-ED7B-4ACA-A637-43B670843876}
Update for Microsoft Office Script Editor Help (KB963671)-->msiexec /package {90120000-006E-0409-0000-0000000FF1CE} /uninstall {CD11C6A2-FFC6-4271-8EAB-79C3582F505C}
Update for Microsoft Office Word 2007 Help (KB963665)-->msiexec /package {90120000-001B-0409-0000-0000000FF1CE} /uninstall {80E762AA-C921-4839-9D7D-DB62A72C0726}
User's Guides-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{5CD29180-A95E-11D3-A4EB-00C04F7BDB2C}\setup.exe"
VPRINTOL-->MsiExec.exe /I{999D43F4-9709-4887-9B1A-83EBB15A8370}
Walmart MP3 Music Downloads-->C:\Program Files\Walmart MP3 Music Downloads\uninstall.exe
Windows Media Player Firefox Plugin-->MsiExec.exe /I{69FDFBB6-351D-4B8C-89D8-867DC9D0A2A4}
WIRELESS-->MsiExec.exe /I{F9593CFB-D836-49BC-BFF1-0E669A411D9F}
======Security center information======
AS: Windows Defender (disabled) (outdated)
AS: SUPERAntiSpyware (disabled)
======System event log======
Computer Name: CHRISTY-PC
Event Code: 4001
Message: WLAN AutoConfig service has successfully stopped.
Record Number: 654469
Source Name: Microsoft-Windows-WLAN-AutoConfig
Time Written: 20110120001148.696200-000
Event Type: Warning
User: NT AUTHORITY\SYSTEM
Event Code: 129
Message: Reset to device, \Device\RaidPort0, was issued.
Record Number: 654454
Source Name: nvstor
Time Written: 20110119215510.745529-000
Event Type: Warning
User:
Event Code: 7022
Message: The HP CUE DeviceDiscovery Service service hung on starting.
Record Number: 654423
Source Name: Service Control Manager
Time Written: 20110119190249.000000-000
Event Type: Error
User:
Event Code: 7000
Message: The Parallel port driver service failed to start due to the following error:
The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
Record Number: 654384
Event Type: Error
User:
Event Code: 4001
Record Number: 654325
Time Written: 20110119162718.505525-000
Event Type: Warning
Event Code: 1004
Message: Detection of product '{30465B6C-B53F-49A1-9EBA-A3F187AD502E}', feature 'SoleFeature', component '{B7195B4D-220F-4055-B216-675DFB956538}' failed.  The resource 'C:\Program Files\Common Files\InstallShield\UpdateService\_ispmres.dll' does not exist.
Record Number: 128031
Source Name: MsiInstaller
Time Written: 20100902163017.000000-000
Event Type: Warning
User: Christy-PC\Christy
Event Code: 1542
Message: Windows cannot load classes registry file.
 DETAIL - The system cannot find the file specified.
Record Number: 128028
Source Name: Microsoft-Windows-User Profiles Service
Time Written: 20100902163013.000000-000
Event Type: Error
Event Code: 1542
Record Number: 128025
Time Written: 20100902163011.000000-000
Event Type: Error
Event Code: 1542
Record Number: 128024
Event Type: Error
Event Code: 64
Message: Certificate for local system with Thumbprint 4e 7c 54 42 2a 43 1a db de 20 36 77 0e b2 fa 58 fb 58 cd 44 is about to expire or already expired.
Record Number: 128020
Source Name: Microsoft-Windows-CertificateServicesClient-AutoEnrollment
Time Written: 20100902162942.000000-000
Event Type: Warning
User:
=====Security event log=====
Event Code: 4672
Message: Special privileges assigned to new logon.
Subject:
   Security ID:      S-1-5-18
   Account Name:      SYSTEM
   Account Domain:      NT AUTHORITY
   Logon ID:      0x3e7
Privileges:      SeAssignPrimaryTokenPrivilege
         SeTcbPrivilege
         SeSecurityPrivilege
         SeTakeOwnershipPrivilege
         SeLoadDriverPrivilege
         SeBackupPrivilege
         SeRestorePrivilege
         SeDebugPrivilege
         SeAuditPrivilege
         SeSystemEnvironmentPrivilege
         SeImpersonatePrivilege
Record Number: 97385
Source Name: Microsoft-Windows-Security-Auditing
Time Written: 20100624230741.734251-000
Event Type: Audit Success
User:
Event Code: 4624
Message: An account was successfully logged on.
Subject:
   Account Name:      CHRISTY-PC$
   Account Domain:      HOME
   Logon ID:      0x3e7
Logon Type:         5
New Logon:
   Logon ID:      0x3e7
   Logon GUID:      {00000000-0000-0000-0000-000000000000}
Process Information:
   Process ID:      0x290
   Process Name:      C:\Windows\System32\services.exe
Network Information:
   Workstation Name:
   Source Network Address:   -
   Source Port:      -
Detailed Authentication Information:
   Logon Process:      Advapi
   Authentication Package:   Negotiate
   Transited Services:   -
   Package Name (NTLM only):   -
   Key Length:      0
This event is generated when a logon session is created. It is generated on the computer that was accessed.
The subject fields indicate the account on the local system which requested the logon. This is most commonly a service such as the Server service, or a local process such as Winlogon.exe or Services.exe.
The logon type field indicates the kind of logon that occurred. The most common types are 2 (interactive) and 3 (network).
The New Logon fields indicate the account for whom the new logon was created, i.e. the account that was logged on.
The network fields indicate where a remote logon request originated. Workstation name is not always available and may be left blank in some cases.
The authentication information fields provide detailed information about this specific logon request.
   - Logon GUID is a unique identifier that can be used to correlate this event with a KDC event.
   - Transited services indicate which intermediate services have participated in this logon request.
   - Package name indicates which sub-protocol was used among the NTLM protocols.
   - Key length indicates the length of the generated session key. This will be 0 if no session key was requested.
Record Number: 97384
User:
Event Code: 4648
Message: A logon was attempted using explicit credentials.
Subject:
   Logon ID:      0x3e7
Account Whose Credentials Were Used:
Target Server:
   Target Server Name:   localhost
   Additional Information:   localhost
   Process ID:      0x290
   Network Address:   -
   Port:         -
This event is generated when a process attempts to log on an account by explicitly specifying that account’s credentials.  This most commonly occurs in batch-type configurations such as scheduled tasks, or when using the RUNAS command.
Record Number: 97383
User:
Event Code: 4672
Subject:
   Security ID:      S-1-5-19
   Account Name:      LOCAL SERVICE
   Logon ID:      0x3e5
         SeAuditPrivilege
Record Number: 97382
Time Written: 20100624230741.593850-000
User:
Event Code: 4624
Subject:
   Logon ID:      0x3e7
Logon Type:         5
New Logon:
   Logon ID:      0x3e5
   Process ID:      0x290
   Workstation Name:
   Source Port:      -
   Key Length:      0
Record Number: 97381
User:
"FP_NO_HOST_CHECK"=NO
"OS"=Windows_NT
"Path"=%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\9.0\DLLShared\;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files\QuickTime\QTSystem\
"PATHEXT"=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
"PROCESSOR_ARCHITECTURE"=x86
"TEMP"=%SystemRoot%\TEMP
"TMP"=%SystemRoot%\TEMP
"USERNAME"=SYSTEM
"windir"=%SystemRoot%
"PROCESSOR_LEVEL"=15
"PROCESSOR_IDENTIFIER"=x86 Family 15 Model 75 Stepping 2, AuthenticAMD
"PROCESSOR_REVISION"=4b02
"NUMBER_OF_PROCESSORS"=2
"RoxioCentral"=C:\Program Files\Common Files\Roxio Shared\9.0\Roxio Central33\
"asl.log"=Destination=file;OnFirstLog=command,environment
"PSModulePath"=%SystemRoot%\system32\WindowsPowerShell\v1.0\Modules\
"CLASSPATH"=.;C:\Program Files\Java\jre6\lib\ext\QTJava.zip
"QTJAVA"=C:\Program Files\Java\jre6\lib\ext\QTJava.zip
"SAFEBOOT_OPTION"=NETWORK
« Reply #11 on: September 01, 2011, 01:19:04 AM »
Hi, Cory.
Can you surf in normal mode on your Mom's computer now rather than Safe Mode with Networking?  Please give it a try and let me know.
Old versions of Java are a major source of infection.  Please go to add/remove programs and uninstall Java(TM) SE Runtime Environment 6 .  Next, Please download JavaRa and unzip it to your desktop.
  • Double-click on JavaRa.exe to start the program.  (Windows Vista users Right-click JavaRa.exe > Select Run as Administrator)
Then download and install Java SE Runtime Environment 6u27.
Note:  UNCHECK any pre-checked toolbar and/or software options presented with the update.  They are not part of the software update and are completely optional.
Unfortunately, uninstalling older versions of JRE may not uninstall the Java Console for that version, causing Firefox to accumulate multiple Java Console extensions located in the Firefox > Tools > Add-ons list.
  • Make sure you already have the most recent version, Java SE Runtime Environment 6u27.
  • Go to C:\Program Files > Mozilla Firefox > extensions.
  • Delete the folders the following folders:
Download TFC to your desktop
  • Open the file and close any other windows.
  • It will close all programs itself when run, make sure to let it run uninterrupted.
  • Click the Start button to begin the process. The program should not take long to finish its job
  • Once its finished it should reboot your machine, if not, do this yourself to ensure a complete clean
Please tell me how the computer is working after completing the above cleanup.
Offline Cory
« Reply #12 on: September 01, 2011, 03:12:41 AM »
It seems to be running well with no virus notifications. Do I need to post the JavaRa log?
« Reply #13 on: September 01, 2011, 03:24:32 PM »
Hi, Cory.
No, you don't need to post the JavaRa log.  You can delete TDSSKiller, RKill, Security Check and the (failed) DDS.scr.
Having a firewall, anti-virus and anti-malware software are not enough.  You also need to stay current with security updates.  If you don't have your computer set to automatically install the Microsoft Security Updates, please check for updates now.
To check if your system is missing security updates or has insecure applications, install Secunia Personal Software Inspector or, alternatively, visit http://secunia.com/software_inspector/ .  The Secunia Software Inspector runs through your browser with no installation or download required and does the following:
My favorite security software is WinPatrol which includes the features described at http://www.winpatrol.com/features.html .  We also have a WinPatrol help forum here at LandzDown Forum, should you have questions about WinPatrol.
