Author Topic: Virus has shut down all my protection options  (Read 409 times)
Offline solopdle
« on: June 05, 2011, 03:28:31 PM »
I was referred to your website by searching through some other websites, Corrine was mentioned. My computer prompted me to run an update and I guess I wasnt paying attention and let a virus (malware) something very nasty in. I tried to run my AVG scan in safe mode but the virus wont allow it. I went through your post for registry but the virus wont let me in to check if i am running in 32 or 64 bit. Non of my scanning software will work and I managed an internet connection but it took awhile to figure it out and now I assume am running uprotected. Any help is appreciated.
Re: Virus has shut down all my protection options
« Reply #1 on: June 05, 2011, 03:38:04 PM »
Hi, solopdle.  Welcome to LandzDown Forum.
It would be helpful if you know the name of the fake/rogue that was installed.  However, in the meantime, let's see if this will work.
One, Two,Three or Four
  • Double-click rkill to run.
Notes:
  • Click Finish.
  • Click Remove Selected.
** Note **
Please also provide the following two logs.  Note that you may need more than one reply to get all the information posted.
Download DDS.scr by sUBs from one of the following links and save it to your desktop.
Link 1
Link 2
