Author Topic: Virus that has infected all programs and won't let me run any.  (Read 1231 times)
Offline ralphe23
I had left my laptop on with iTunes running and I come back to it and says that I have a virus and that I have been infected. It won't let me open any program what so ever. Not even my AV Scanner. I need help! :(
Re: Virus that has infected all programs and won't let me run any.
« Reply #1 on: August 12, 2010, 01:23:34 AM »
Hi, ralphe23. Welcome to Landzdown.
I will do our best to assist you.  However, in order to do so, please follow all instructions provided in the sequence given.  Do not install/re-install any programs or run any fixes or scanners that you have not been instructed to use.  This may cause conflicts with the tools being used in the cleanup process.
If you have questions regarding any of the instructions or problems running any tools, please let me know.
One, Two,Three or Four
  • Double-click rkill to run.
Notes:
  • Click Finish.
  • Click Remove Selected.
** Note **
Next, please download random's system information tool (RSIT):
  • Download RSIT by random/random from here and save it to your desktop.
  • Once it has finished, two logs will open. Please post the contents of both log.txt (<<will be maximized) and info.txt (<<will be minimized).
