Author Topic: Windows 7 (something) 2012 rogue  (Read 3613 times)
Offline Golden
Re: Windows 7 (something) 2012 rogue
« Reply #105 on: January 04, 2012, 10:58:30 AM »
Hi Donna,
Yes, unfortunately you cannot repair a x86 (32 bit installation) with a x64 (64 bit) system repair disk  :(
OK, this is a OEM System Builder Pack, so that a bit different....its not your bulk standard OEM installation, and thats a good thing. I have a very strong suspicion that the OEM System Builder Pack is actually just a Windows Home Premium x86 "retail" version. To test this, can you say whether the laptop come preinstalled with trials of MSOffice, Norton, McAfee or similar products?
Looking at the screen capture image of your Disk Management you posted earlier, I also notice a 20GB partition at the front of the disk, and I think there is a very good chance that this 20GB partition may be the OEM recovery partition. I did say it would be labelled as Q: drive, but I think I might be confusing some recovery partitions I have seen on Acer laptops.
When you boot the laptop, are there any options like "F11 Recovery" or something similar? If not, could you do this test for me:
1. Boot as normal
2. During the boot, hit F8 continually until a menu option comes up called "Advanced Boot Options"
3. You will see a number of options listed - is Repair Your Computer one of these options?
4. If it is, then this laptop has preinstalled recovery options aka Recovery Partition.
Before we actually try the recovery from this partition, if thats what it is, we need an opinion from Corinne as to whether there is any chance the malware could have infected this partition.
Regards,
Golden
Offline DonnaB
« Reply #106 on: January 04, 2012, 11:57:28 AM »
Morning Golden,
I have a very strong suspicion that the OEM System Builder Pack is actually just a Windows Home Premium x86 "retail" version.To test this, can you say whether the laptop come preinstalled with trials of MSOffice, Norton, McAfee or similar products?
I bought the OEM Retail disk so my boyfriend could install over Vista 32-bit on his home built desktop computer. That desktop computer is disassembled at this time due to Joe relocating for a job opportunity. I'll have to ask Joe what came with the installation. I can also ask my Tech friend who I bought the disk from.
The ASUS laptop does have the Repair your computer option on the Advanced Boot Options menu. There is no option to press F11 Recovery at boot. Goes straight from splash screen into the Welcome screen, then into Windows once password is typed in.
If the 20GB partition is the Recovery why does it say 100% Free?
Late for work.
Thanks Golden. :)
Offline Golden
« Reply #107 on: January 04, 2012, 12:06:21 PM »
Donna, I have good news!
You can simply install Windows Home Premium x86 from any installation media, and then simply activate it with the OEM key. All perfectly fine and confirmed to me by some friends over at SevenForums  :thumbsup:
I am writing some detailed steps for you at the minute, but its really quite easy. have a look when you get back from work, and poot any questions you may have.
Regards,
Golden
PS Well spotted on the empty recovery partition - I missed that  :shock:
Offline Golden
« Reply #108 on: January 04, 2012, 12:33:54 PM »
Donna,
I have good news : you can install a retail version of Windows Home Premium x86 and simply activate it with your legitimate OEM key :thumbsup: I had this confirmed by some associates over at SevenForums and am confident its a go.
Steps:
1. Backup any data required off the laptop.
2. Make a note of the OEM key.
3. On a clean computer, download the following (all legitimate):
- Windows Home Premium x86 SP1
You want the English x86:X17-58996.ISO
http://www.mydigitallife.info/official-windows-7-sp1-iso-from-digital-river/
- Microsoft USB Installer
http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool
4. You will need a 4GB USB thumb/flash drive. Install and run the USB installer, and when prompted point it to the .ISO file you downloaded. This will format the USB drive and then write the .ISO to this USB and make it bootable. You will install Windows from this USB drive.
5. Boot the laptop, and enter the BIOS by repeatedly hitting the DEL key. Once in the BIOS, find the setting that lets the laptop boot from a USB flash drive before any HDD. Save the BIOS settings and then exit the BIOS.
6. Plug in the USB drive and then reboot the PC.
7. Windows installation will start.
To ensure all traces of the malware are removed, I recommend doing the following:
a. At the first screen that prompts for language preferences, hold SHIFT and then press F10.
b. You will now see a CMD window with the prompt X:\Sources.
c. Type DISKPART and hit enter.
d. Type list disk and hit enter. It looks like you only have 1 physical disk which should be numbered Disk 0
e. Type select disk 0 and hit enter.
f. Type clean all and hit enter - this will completely wipe every sector of the disk and is more thorough than a format. It may take a few hoyrs.
g. When finished, type exit and hit enter.
h. Type exit and hit enter once more.
8. You will now be back at the first screen, the language preferences screen. Now proceed with installation as normal.
-  Do NOT choose online activation - you have 30 days to do that - and you may need to do that via phone. We will cover that later.
- Choose the CUSTOM install option when prompted.
Let us know how you get on.
Regards,
Golden
« Reply #109 on: January 04, 2012, 02:21:01 PM »
G'day, Golden!  Excellent instructions.  Thank you.
Donna's son's laptop/OEM key is 64-bit so will need to select that version from the list of ISO's.
Offline DonnaB
« Reply #110 on: January 05, 2012, 12:34:55 AM »
I could not agree more! Gives new definition to the word "Excellent"!
Only thing missing are the pictures and a hand to hold....HA! Just kidding.  :laughing:
I do have a 4GB USB handy that I need to format before I begin this process.
I also have a 4.7GB DVD-R. Can I also burn that ISO to the DVDV-R for future use if my son needs it as a backup of some sort? I was prepared to actually buy a Win7 retail in case he ever needed it since the disks I made from the recovery restore image obviously is of no use.
I'm going to wait till Friday to do this, that way I can devote my full attention to this project from beginning to end without interference. I may have questions, but I'll read your instructions thoroughly before I begin.
Why....uh....thank you!  :hug:  Confidence booster!  Coming from you, that means everything!!!!! :)
And yes, of course. I'll let you know how I get on.
Thank you so kindly Golden...Corrine.
Donna
Offline Golden
« Reply #111 on: January 05, 2012, 03:33:52 AM »
No worries at all. Yes - if your Windows is 64 bit, then you need to download the 64 bit ISO.
The USB installer will actually format the USB drive for you before it loads the .ISO to it, so no need to pre-format it. Yes, you can also burn the .ISO to a DVD if you like - no problems at all. If you don't have a DVD burning software handy, I recommend using IMGBURN at 4x speed only to ensure you get a good DVD - its a free, lightweight burner - of course you can always use whatever you are comfortable with.
http://www.imgburn.com/
I'll visit back here regularly in case you have any questions.
Regards,
Golden
Offline DonnaB
« Reply #112 on: January 06, 2012, 03:00:58 AM »
Acknowledged!
Ow...I just read that! What a time saver!
Great! That way I can burn him a disk for future use since the 4 Recovery disks are obviously no good.
I am not familiar with IMGBURN. I have used ISO Recorder by Alex Feinman though it has been quite awhile. I shouldn't have any trouble figuring it out, but would you be willing to guide me if I install IMGBURN for the disk?  I'll do that after I finish the install with the USB and let you know how it goes. I realize that I could just use the disk for this purpose, but for continuing education I'd like to experience first hand how to achieve this feat with USB and disk so I can use that knowledge in the future once I graduate from my GeekU malware removal training. I'm quite sure I'll come across someone who doesn't have one or the other. I'd truly appreciate your time and guidance.  :hug:
Offline Golden
« Reply #113 on: January 06, 2012, 12:21:42 PM »
No worries. Let me know when you are ready to try IMGBURN.
Regards,
Golden
Offline DonnaB
« Reply #114 on: January 08, 2012, 05:18:34 PM »
Ok. After finally finding a way to download such a large file without violating my download limit and getting kicked off line by my ISP, for some reason when I browse to the desktop with the WINDOWS 7 USB/DVD DOWNLOAD TOOL and click Next it says the following:
Invalid ISO file
The selected file is not a valid ISO file. Please select a valid ISO file and try again.
I've tried this twice now. The file that is downloaded to the desktop is 1.95 GB's. Is something wrong with the file? Did it not download successfully? I could have sworn that while it was downloading the file was supposed to be 3.1GB's.
Any ideas?
Offline DonnaB
« Reply #115 on: January 08, 2012, 05:37:21 PM »
Update. Tried something different:
I right clicked on the ISO file that is on the desktop then followed the path below and pasted it?
C:\Users\Donna\AppData\Local\Apps\Windows7 USB DVD Download Tool
The 1.95GB file now resides there. I realize that I may have to manually format the USB now but once I do that can I then right click/drag and drop that file to the USB and proceed from there?
Offline Golden
« Reply #116 on: January 09, 2012, 10:51:05 AM »
Hi Donna,
It sounds to me as if the download is imcomplete - the full size of the .ISO is 3.09GB. This explains the errors you get when you try to run the USB tool. You will have to delete the incomplete .ISO, and download the full .ISO again.
You MUST use the USB tool to burn the .ISO, since it is setup to make the USB bootable for the installation - dragging and dropping the .ISO to the USB drive using Windows Explorer simply copies it to the USB drive, but it doesn't make it bootable. If it isn't bootable, you will not be able to install Window s7.
Summary:
- Download the full 3.09GB .ISO completely
- Use the USB tool to copy the .ISO to the USB drive AND make it bootable in order to install Windows 7 from it.
Regards,
Golden
Offline DonnaB
« Reply #117 on: January 09, 2012, 11:32:46 AM »
Hi Golden,
That's the conclusion I came to as well. Incomplete download. :(
Mistakenly, I took my laptop to my friends house and had him download it for me. He downloaded Win7 Professional 64-bit instead of Win7 Home Premium 64-bit. The Win7 Profession 64-bit version ISO was accessible when browsed for and was 2.79GB's.
I'll ask him if I can use his connection again to get the correct download for my purpose.
Thank you. I'll post back.
Donna
Offline DonnaB
« Reply #118 on: January 09, 2012, 07:03:45 PM »
I have success in downloading the 3.9GB file to my desktop and I'm in the process of transferring it to the USB drive. I noticed that on the USB is a file known as AUTORUN.INF (16bytes-1KB) which I know is the primary instruction file associated with the Autorun function. Will that interfere with the installation of the ISO once I configure the BIOS to boot from the USB drive?
I did try to delete the AUTORUN.INF file but can not due to permissions not granted. I do not recall the file being there prior to installing Panda USB vaccine.
Also, the current boot order is CD/DVD ROM Drive BBS Priorities. I do not see anything in the Aptio Boot Menu that specifically states USB Drive for selection as a boot order.
My options are as shown in the image in this post. I can get a better/fuller image of that screen if needed.
Thanks! :)
Offline DonnaB
« Reply #119 on: January 09, 2012, 07:37:55 PM »
Sorry to post yet again but I have an update:
Transfer of ISO file to USB is complete. Results below:
I'm assuming this means the USB device is not bootable.
Wouldn't it be easier to just go ahead and burn the ISO onto a disk since I do have one handy and I intended to create one anyway?
Just a thought.
