Author Topic: 1.06r1 Personal; can't retrieve new definitions  (Read 4267 times)
Offline dan2
« on: July 21, 2005, 06:15:29 PM »
I've been updating 1.06r1 Personal without a problem all along, but today, get an error message, "The downloaded definitions file cound not be read, please update again." Is there a setting I have to adjust to get the July 21 definitions updates?
[attachment deleted by admin]
Re: 1.06r1 Personal; can't retrieve new definitions
« Reply #1 on: July 21, 2005, 06:18:48 PM »
Hi, dan2.  Welcome to LandzDown Forum.
Most frequently when this happens it is because the ISP is using cached pages.  The easiest solution then is to go to http://www.lavasoftusa.com/support/download/ and download the zip file.
Please let us know if you still have problems, as there are other options we can try too.
Offline dan2
« Reply #2 on: July 21, 2005, 07:34:06 PM »
Thanks for the info. As it turns out, just moments after I posted my message, the new definitions loaded. Thanks for your prompt reply.
« Reply #3 on: July 21, 2005, 07:52:55 PM »
Thanks for letting us know!
Offline Felburg
    • Jeffrey Alan Felburg's Computer Help Website
« Reply #4 on: August 02, 2005, 04:38:22 PM »
I had this problem on another computer.  I got around it by deleting the referencefile manually, then chosing WebUpdate in Ad-Aware.
Need computer help?  Get it for FREE at: http://www.Felburg.com
Offline Old Charlie
« Reply #5 on: August 02, 2005, 10:13:31 PM »
Hi all,
This happens all the time (on this box) if CCleaner is used with the check mark in Adaware SE on the "Application tab > Utilities.  It deletes the def.ref.old file.
OC
« Reply #6 on: August 06, 2005, 05:33:31 PM »
Since the release of Build 1.06r1, it seems that there has been a significant increase in the number of people having problems getting the updates.  Many people have report that the update starts at 5% and stalls, never going further.  Most generally have to end task.  Others have been able to "cancel" the update, restart it and it seems to work -- although it may take 2 or 3 tries.
Sadly, many people experiencing this problem think there is a problem with their computer.  There are just too many people experiencing this for that to be the case.
Offline TROOPCARRIER
« Reply #7 on: August 06, 2005, 09:08:18 PM »
hello . . .New to this forum and not really sharp on PC's.
WinXp Home . . .ran SETUP over the top.
New DL of AdAware . . .got the "Def file could not be read" . . . removed and reinstalled . . .same result.
Used regedit on AdAware and LavaSoft . . .removed all keys etc.
New DL and install . . .tried to UD . . . same result
Tried the "fixes" shown here ( the "old file" key is still there)  and I still cannot DL the new UD's
Any help will be appreciated. . .
« Reply #8 on: August 06, 2005, 09:37:04 PM »
Hi, TROOPCARRIER!  Welcome!  You're not the only one new to this forum -- its only been public for a few weeks.  :)
I must say, for someone not to sharp on PC's to do a regedit, I'd say you're doing just fine.
As to the updates, please make sure that your firewall is allowing Ad-Aware access to the internet.
Next, you could try deselecting the "surpress webubdate confirmation dialogues" option in tweak> webupdate settings.
Also, check the WebUpdate configuration to ensure that you didn't inadvertently click on "Use HTTP Proxy". If so, deselect that option and try again.
If that doesn't work, close Ad-Aware, go to C:\Program Files\Lavasoft\Ad-Aware SE Personal and delete defs.ref. Launch Ad-Aware again, ignoring the error message.  Try the WebUpdate again.
If all else fails, please go to http://www.lavasoft.de/support/download/ and download the zip file, upgrade the Definition Files and run a Full System scan.
Please let us know how you make out.  Thanks!
Offline Eric the Red
  • ISO/IEC 27001:2005
« Reply #9 on: August 06, 2005, 10:00:48 PM »
TROOPCARRIER,
The latest definitions file may be downloaded from:
http://download.lavasoft.de.edgesuite.net/public/defs.zip
They come in a compressed archive file, just uncompress to the main Lavasoft\Ad Aware SE directory and overwrite the currently installed defs.ref file
Proud member Since 2004
Offline Blue55
« Reply #10 on: August 08, 2005, 06:50:01 AM »
Any luck TROOPCARRIER?
Once you get the first sucessful download, the rest should go smoothly.
(Many have had this problem, myself included)
Offline jat38
« Reply #11 on: September 02, 2005, 04:39:05 AM »
This happened to me as well. It started and stalled at 5%, and I had to end task. I tried 3 times to update all with the same result. I then logged off from the internet, reconnected and ran WebUpdate again, and it worked just fine then.  :D
~What's with today today?~
