Author Topic: Ad-aware & Favouriteman...How to remove?  (Read 2637 times)
Offline 10rand
« on: September 13, 2005, 05:22:59 PM »
On 8/9/2005 Ad-aware found a parasite called Favouriteman.[C:\WINDOWS\iun6002.exe] This was rated as a category 8. After a Google search, I found some information at 'www.doxdesk.com on it. The removal instructions said that I must go Add/Remove and remove  Favouriteman/F1, ZZ, IMZ, Icm/Int and ATPartners or whatever variant it it that was on my system. I didn't find any such applications as mentioned above on Add/Remove. The next step was to deregister Favouriteman's dll. This I was unable to do. The instruction given didn't work on my system:[cd "%WinDir%\System" regsvr32 /u favorite.dll]. Next I instructed Ad-aware to remove it. Which seemed to work. Then I rebooted into Safe Mode and ran Ad-aware again, which found this parasite on 'System restore'. I then disabled and enable system restore. I ran all my antiparasite software in safe mode. {Ad-aware, Spybot, MS antispyware beta, ewido, avast av, cws shredder, etc.} They didn't find anything. I then went into the registry using the Registry Editor and searched for all the dll's mentioned on the instructions from 'doxdesk'. I found and deleted the following: favourite.dl, favboot.dll, favorite.dll, favourite.dll, ofrg.dll, sysfile.dll, *.dll and iun6002.exe. Seeing that I did not go about things correctly, what else can I do, to ensure that I have a pc free of Favouriteman? Hope that I have posted in the correct place. Thanks.  :sos:
Re: Ad-aware & Favouriteman...How to remove?
« Reply #1 on: September 13, 2005, 06:31:41 PM »
Hi, 10rand.  Let's start with a full scan Ad-Aware SE logfile (in normal mode) and see what that shows us.  Also, please let us know if you are having any problems.
Thanks.
Offline 10rand
« Reply #2 on: September 14, 2005, 05:07:52 PM »
No, I don't have problems. I just want to be sure that I don't have a Trojan or something that can transmit data illegally from my pc. Thanks. Here is the logfile:
Ad-Aware SE Build 1.06r1
Logfile Created on:Wednesday, September 14, 2005 6:16:27 PM
Created with Ad-Aware SE Personal, free for private use.
Using definitions file:SE1R65 08.09.2005
References detected during the scan:
None
Definition File:
Definitions File Loaded:
Reference Number : SE1R65 08.09.2005
Internal build : 76
File location : C:\Program Files\Lavasoft\Ad-Aware SE Personal\defs.ref
File size : 518006 Bytes
Total size : 1558638 Bytes
Signature data size : 1525452 Bytes
Reference data size : 32674 Bytes
Signatures total : 43368
CSI Fingerprints total : 1037
CSI data size : 36930 Bytes
Target categories : 15
Target families : 745
Memory + processor status:
Number of processors : 2
Processor architecture : Intel Pentium IV
Memory available:51 %
Total physical memory:523756 kb
Available physical memory:264472 kb
Total page file size:1278952 kb
Available on page file:973276 kb
Total virtual memory:2097024 kb
Available virtual memory:2044040 kb
OS:Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
Ad-Aware SE Settings
Set : Search for low-risk threats
Set : Safe mode (always request confirmation)
Set : Scan active processes
Set : Scan registry
Set : Deep-scan registry
Set : Scan my IE Favorites for banned URLs
Set : Scan within archives
Set : Scan my Hosts file
Extended Ad-Aware SE Settings
Set : Unload recognized processes & modules during scan
Set : Obtain command line of scanned processes
Set : Scan registry for all users instead of current user only
Set : Always try to unload modules before deletion
Set : During removal, unload Explorer and IE if necessary
Set : Let Windows remove files in use at next reboot
Set : Delete quarantined objects after restoring
Set : Write-protect system files after repair (Hosts file, etc.)
Set : Include basic Ad-Aware settings in log file
Set : Include additional Ad-Aware settings in log file
Set : Include reference summary in log file
Set : Include alternate data stream details in log file
Set : Play sound at scan completion if scan locates critical objects
9-14-2005 6:16:27 PM - Scan started. (Full System Scan)
Listing running processes
#:1 [smss.exe]
    ModuleName         : \SystemRoot\System32\smss.exe
    Command Line       : n/a
    ProcessID          : 544
    ThreadCreationTime : 9-14-2005 4:10:23 PM
    BasePriority       : Normal
#:2 [csrss.exe]
    ModuleName         : \??\C:\WINDOWS\system32\csrss.exe
    Command Line       : C:\WINDOWS\system32\csrss.exe ObjectDirectory=\Windows SharedSection=1024,3072,512 Windows=On SubSystemType=Windows ServerDll=basesrv,1 ServerDll=winsrv:UserServerDllInitialization,3 ServerDll=winsrv:ConServerDllInitialization,2 ProfileControl=Off MaxRequestTh
    ProcessID          : 592
    ThreadCreationTime : 9-14-2005 4:10:26 PM
#:3 [winlogon.exe]
    ModuleName         : \??\C:\WINDOWS\system32\winlogon.exe
    Command Line       : winlogon.exe
    ProcessID          : 616
    ThreadCreationTime : 9-14-2005 4:10:28 PM
    BasePriority       : High
#:4 [services.exe]
    ModuleName         : C:\WINDOWS\system32\services.exe
    Command Line       : C:\WINDOWS\system32\services.exe
    ProcessID          : 660
    ThreadCreationTime : 9-14-2005 4:10:30 PM
    FileVersion        : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
    ProductVersion     : 5.1.2600.2180
    ProductName        : Microsoft® Windows® Operating System
    CompanyName        : Microsoft Corporation
    FileDescription    : Services and Controller app
    InternalName       : services.exe
    LegalCopyright     : © Microsoft Corporation. All rights reserved.
    OriginalFilename   : services.exe
#:5 [lsass.exe]
    ModuleName         : C:\WINDOWS\system32\lsass.exe
    Command Line       : C:\WINDOWS\system32\lsass.exe
    ProcessID          : 672
    FileDescription    : LSA Shell (Export Version)
    InternalName       : lsass.exe
    OriginalFilename   : lsass.exe
#:6 [svchost.exe]
    ModuleName         : C:\WINDOWS\system32\svchost.exe
    Command Line       : C:\WINDOWS\system32\svchost -k DcomLaunch
    ProcessID          : 808
    ThreadCreationTime : 9-14-2005 4:10:34 PM
    FileDescription    : Generic Host Process for Win32 Services
    InternalName       : svchost.exe
    OriginalFilename   : svchost.exe
#:7 [svchost.exe]
    Command Line       : C:\WINDOWS\system32\svchost -k rpcss
    ProcessID          : 912
    ThreadCreationTime : 9-14-2005 4:10:35 PM
#:8 [svchost.exe]
    ModuleName         : C:\WINDOWS\System32\svchost.exe
    Command Line       : C:\WINDOWS\System32\svchost.exe -k netsvcs
    ProcessID          : 952
#:9 [smc.exe]
    ModuleName         : C:\Program Files\Sygate\SPF\smc.exe
    Command Line       : n/a
    ProcessID          : 1040
    FileVersion        : 5.6.00.2808
    ProductVersion     : 5.6.00.2808
    ProductName        : Sygate® Security Agent and Personal Firewall
    CompanyName        : Sygate Technologies, Inc.
    FileDescription    : Sygate Agent Firewall
    InternalName       : Smc
    LegalCopyright     : Copyright ©  1999 - 2004 Sygate Technologies, Inc. All rights reserved.
    OriginalFilename   : Smc.EXE
#:10 [svchost.exe]
    Command Line       : C:\WINDOWS\System32\svchost.exe -k NetworkService
    ProcessID          : 1072
    ThreadCreationTime : 9-14-2005 4:10:38 PM
#:11 [svchost.exe]
    Command Line       : C:\WINDOWS\System32\svchost.exe -k LocalService
    ProcessID          : 1104
    ThreadCreationTime : 9-14-2005 4:10:39 PM
#:12 [spoolsv.exe]
    ModuleName         : C:\WINDOWS\system32\spoolsv.exe
    Command Line       : C:\WINDOWS\system32\spoolsv.exe
    ProcessID          : 1224
    ThreadCreationTime : 9-14-2005 4:10:40 PM
    FileVersion        : 5.1.2600.2696 (xpsp_sp2_gdr.050610-1519)
    ProductVersion     : 5.1.2600.2696
    FileDescription    : Spooler SubSystem App
    InternalName       : spoolsv.exe
    OriginalFilename   : spoolsv.exe
#:13 [aswupdsv.exe]
    ModuleName         : C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
    Command Line       : "C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe"
    ProcessID          : 1348
#:14 [ashserv.exe]
    ModuleName         : C:\Program Files\Alwil Software\Avast4\ashServ.exe
    Command Line       : "C:\Program Files\Alwil Software\Avast4\ashServ.exe"
    ProcessID          : 1364
    BasePriority       : High
    FileVersion        : 4, 6, 665, 0
    ProductVersion     : 4, 6, 0, 0
    ProductName        : avast! Antivirus
    FileDescription    : avast! antivirus service
    InternalName       : aswServ
    LegalCopyright     : Copyright (c) 2005 ALWIL Software
    OriginalFilename   : aswServ.exe
#:15 [dkservice.exe]
    ModuleName         : C:\Program Files\Executive Software\Diskeeper\DkService.exe
    Command Line       : "C:\Program Files\Executive Software\Diskeeper\DkService.exe"
    ProcessID          : 1400
    ThreadCreationTime : 9-14-2005 4:10:41 PM
    FileVersion        : 9.0.511.0
    ProductVersion     : 9.0.511.0
    ProductName        : Diskeeper (TM) Disk Defragmenter
    CompanyName        : Executive Software International, Inc.
    FileDescription    : DKSERVICE.EXE
    InternalName       : DKSERVICE
    LegalCopyright     : © 1995-2004 Executive Software Int'l, Inc.
    OriginalFilename   : DKSERVICE
#:16 [ewidoctrl.exe]
    ModuleName         : C:\Program Files\ewido\security suite\ewidoctrl.exe
    Command Line       : "C:\Program Files\ewido\security suite\ewidoctrl.exe"
    ProcessID          : 1424
    ThreadCreationTime : 9-14-2005 4:10:43 PM
    FileVersion        : 3, 0, 0, 1
    ProductVersion     : 3, 0, 0, 1
    ProductName        : ewido control
    CompanyName        : ewido networks
    FileDescription    : ewido control
    InternalName       : ewido control
    LegalCopyright     : Copyright © 2004
    OriginalFilename   : ewidoctrl.exe
#:17 [mdm.exe]
    ModuleName         : C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
    Command Line       : "C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE"
    ProcessID          : 1504
    ThreadCreationTime : 9-14-2005 4:10:45 PM
    FileVersion        : 7.00.9466
    ProductVersion     : 7.00.9466
    ProductName        : Microsoft® Visual Studio .NET
    FileDescription    : Machine Debug Manager
    InternalName       : mdm.exe
    OriginalFilename   : mdm.exe
#:18 [nvsvc32.exe]
    ModuleName         : C:\WINDOWS\system32\nvsvc32.exe
    Command Line       : C:\WINDOWS\system32\nvsvc32.exe
    ProcessID          : 1536
    FileVersion        : 6.14.10.7777
    ProductVersion     : 6.14.10.7777
    ProductName        : NVIDIA Driver Helper Service, Version 77.77
    CompanyName        : NVIDIA Corporation
    FileDescription    : NVIDIA Driver Helper Service, Version 77.77
    InternalName       : NVSVC
    LegalCopyright     : (C) NVIDIA Corporation. All rights reserved.
    OriginalFilename   : nvsvc32.exe
#:19 [snmp.exe]
    ModuleName         : C:\WINDOWS\System32\snmp.exe
    Command Line       : C:\WINDOWS\System32\snmp.exe
    ProcessID          : 1620
    ThreadCreationTime : 9-14-2005 4:10:46 PM
    FileDescription    : SNMP Service
    InternalName       : snmp.exe
    OriginalFilename   : snmp.exe
#:20 [svchost.exe]
    Command Line       : C:\WINDOWS\System32\svchost.exe -k imgsvc
    ProcessID          : 1656
    ThreadCreationTime : 9-14-2005 4:10:47 PM
#:21 [wdfmgr.exe]
    ModuleName         : C:\WINDOWS\system32\wdfmgr.exe
    Command Line       : C:\WINDOWS\system32\wdfmgr.exe
    ProcessID          : 1700
    FileVersion        : 5.2.3790.1230 built by: DNSRV(bld4act)
    ProductVersion     : 5.2.3790.1230
    FileDescription    : Windows User Mode Driver Manager
    InternalName       : WdfMgr
    OriginalFilename   : WdfMgr.exe
#:22 [ashmaisv.exe]
    ModuleName         : C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
    Command Line       : "C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service
    ProcessID          : 456
    ThreadCreationTime : 9-14-2005 4:10:58 PM
#:23 [wmiprvse.exe]
    ModuleName         : C:\WINDOWS\System32\wbem\wmiprvse.exe
    Command Line       : C:\WINDOWS\System32\wbem\wmiprvse.exe -Embedding
    ProcessID          : 492
    ThreadCreationTime : 9-14-2005 4:10:59 PM
    FileDescription    : WMI
    InternalName       : Wmiprvse.exe
    OriginalFilename   : Wmiprvse.exe
#:24 [ashwebsv.exe]
    ModuleName         : C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
    Command Line       : "C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service
    ProcessID          : 584
    ThreadCreationTime : 9-14-2005 4:11:00 PM
#:25 [alg.exe]
    ModuleName         : C:\WINDOWS\System32\alg.exe
    Command Line       : C:\WINDOWS\System32\alg.exe
    ProcessID          : 328
    FileDescription    : Application Layer Gateway Service
    InternalName       : ALG.exe
    OriginalFilename   : ALG.exe
#:26 [explorer.exe]
    ModuleName         : C:\WINDOWS\Explorer.EXE
    Command Line       : C:\WINDOWS\Explorer.EXE
    ProcessID          : 1940
    ThreadCreationTime : 9-14-2005 4:11:02 PM
    FileVersion        : 6.00.2900.2180 (xpsp_sp2_rtm.040803-2158)
    ProductVersion     : 6.00.2900.2180
    FileDescription    : Windows Explorer
    InternalName       : explorer
    OriginalFilename   : EXPLORER.EXE
#:27 [ashdisp.exe]
    ModuleName         : C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
    Command Line       : "C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe"
    ProcessID          : 2488
    ThreadCreationTime : 9-14-2005 4:11:13 PM
    FileDescription    : avast! service GUI component
    InternalName       : aswDisp
    OriginalFilename   : aswDisp.exe
#:28 [startupmonitor.exe]
    ModuleName         : C:\WINDOWS\StartupMonitor.exe
    Command Line       : "C:\WINDOWS\StartupMonitor.exe"
    ProcessID          : 2520
    ThreadCreationTime : 9-14-2005 4:11:14 PM
#:29 [winpatrol.exe]
    ModuleName         : C:\PROGRA~1\BILLPS~1\WINPAT~1\WinPatrol.exe
    Command Line       : "C:\PROGRA~1\BILLPS~1\WINPAT~1\WinPatrol.exe"
    ProcessID          : 2552
    ThreadCreationTime : 9-14-2005 4:11:15 PM
    FileVersion        : 9, 7, 0, 22
    ProductVersion     : 9.7.0.22
    ProductName        :  WinPatrol Monitor
    CompanyName        : BillP Studios
    FileDescription    : WinPatrol System Monitor
    InternalName       : WinPatrol Monitor
    LegalCopyright     : Copyright © 1997- 2005 BillP Studios
    OriginalFilename   : Scotty
    Comments           : Let Scotty the Windows Watchdog patrol your system.
#:30 [rundll32.exe]
    ModuleName         : C:\WINDOWS\system32\RunDLL32.exe
    Command Line       : "C:\WINDOWS\system32\RunDLL32.exe" NvMCTray.dll,NvTaskbarInit
    ProcessID          : 2592
    ThreadCreationTime : 9-14-2005 4:11:16 PM
    FileDescription    : Run a DLL as an App
    InternalName       : rundll
    OriginalFilename   : RUNDLL.EXE
#:31 [jusched.exe]
    ModuleName         : C:\Program Files\Java\jre1.5.0_02\bin\jusched.exe
    Command Line       : "C:\Program Files\Java\jre1.5.0_02\bin\jusched.exe"
    ProcessID          : 2600
#:32 [ctfmon.exe]
    ModuleName         : C:\WINDOWS\system32\ctfmon.exe
    Command Line       : "C:\WINDOWS\system32\ctfmon.exe"
    ProcessID          : 2652
    ThreadCreationTime : 9-14-2005 4:11:17 PM
    FileDescription    : CTF Loader
    InternalName       : CTFMON
    OriginalFilename   : CTFMON.EXE
#:33 [rundll32.exe]
    ModuleName         : C:\WINDOWS\system32\rundll32.exe
    Command Line       : rundll32.exe nview.dll,nViewInitialize
    ProcessID          : 2668
    ThreadCreationTime : 9-14-2005 4:11:18 PM
#:34 [windowssearch.exe]
    ModuleName         : C:\Program Files\MSN Toolbar Suite\DS\02.05.0000.1082\en-us\bin\WindowsSearch.exe
    Command Line       : "C:\Program Files\MSN Toolbar Suite\DS\02.05.0000.1082\en-us\bin\WindowsSearch.exe"  /startup
    ProcessID          : 2692
    ThreadCreationTime : 9-14-2005 4:11:19 PM
    FileVersion        : 02.05.0000.1082
    ProductVersion     : 02.05.0000.1082
    ProductName        : MSN Search Toolbar
    FileDescription    : Windows Desktop Search Tool Tray Admin
    InternalName       : WindowsSearch.exe
    OriginalFilename   : WindowsSearch.exe
#:35 [bhodemon.exe]
    ModuleName         : C:\Program Files\BHODemon 2\BHODemon.exe
    Command Line       : "C:\Program Files\BHODemon 2\BHODemon.exe"
    ProcessID          : 2748
    ThreadCreationTime : 9-14-2005 4:11:21 PM
    FileVersion        : 2.0.0.23
    ProductVersion     : 2.0.0.23
    ProductName        : BHODemon 2.0
    CompanyName        : Definitive Solutions, Inc.
    FileDescription    : BHODemon - Freeware BHO Detection Utility
    InternalName       : BHODemon.exe
    LegalCopyright     : Copyright (c) 2000-2005 Definitive Solutions, Inc.  All rights reserved.
    LegalTrademarks    : www.DefinitiveSolutions.com
    OriginalFilename   : BHODemon.exe
    Comments           : BHODemon - Freeware BHO Detection Utility
#:36 [sgmain.exe]
    ModuleName         : C:\Program Files\SpywareGuard\sgmain.exe
    Command Line       : "C:\Program Files\SpywareGuard\sgmain.exe"
    ProcessID          : 2760
    ThreadCreationTime : 9-14-2005 4:11:22 PM
    FileVersion        : 2.02.0001
    ProductVersion     : 2.02.0001
    ProductName        : SpywareGuard
    FileDescription    : SpywareGuard
    InternalName       : sgmain
    LegalCopyright     : Copyright (C) 2002-2003 Javacool Software LLC
    OriginalFilename   : sgmain.exe
    Comments           : SpywareGuard
#:37 [windowssearchindexer.exe]
    ModuleName         : C:\Program Files\MSN Toolbar Suite\DS\02.05.0000.1082\en-us\bin\WindowsSearchIndexer.exe
    Command Line       : "C:\Program Files\MSN Toolbar Suite\DS\02.05.0000.1082\en-us\bin\WindowsSearchIndexer.exe" -Embedding
    ProcessID          : 2796
    ThreadCreationTime : 9-14-2005 4:11:25 PM
    FileVersion        : 2.5.0.1082
    ProductVersion     : 2.5.0.1082
    ProductName        : Windows Desktop Search
    FileDescription    : Windows Desktop Search executable
    InternalName       : windowssearchindexer.exe
    OriginalFilename   : windowssearchindexer.exe
    Comments           : Windows Desktop Search executable
#:38 [sgbhp.exe]
    ModuleName         : C:\Program Files\SpywareGuard\sgbhp.exe
    Command Line       : "C:\Program Files\SpywareGuard\sgbhp.exe"
    ProcessID          : 2864
    ThreadCreationTime : 9-14-2005 4:11:28 PM
    ProductName        : SG Browser Hijacking Protection
    FileDescription    : SG Browser Hijacking Protection
    InternalName       : sgbhp
    LegalCopyright     : Copyright (C) 2002-2003 Javacool Software LLC.
    OriginalFilename   : sgbhp.exe
    Comments           : SG Browser Hijacking Protection
#:39 [wuauclt.exe]
    ModuleName         : C:\WINDOWS\system32\wuauclt.exe
    Command Line       : "C:\WINDOWS\system32\wuauclt.exe" /RunStoreAsComServer Local\[3b8]SUSDS02509c10bf48004295f1da01ea9b9be5
    ProcessID          : 3060
    ThreadCreationTime : 9-14-2005 4:11:41 PM
    FileVersion        : 5.8.0.2469 built by: lab01_n(wmbla)
    ProductVersion     : 5.8.0.2469
    FileDescription    : Automatic Updates
    InternalName       : wuauclt.exe
    OriginalFilename   : wuauclt.exe
#:40 [ad-aware.exe]
    ModuleName         : C:\Program Files\Lavasoft\Ad-Aware SE Personal\Ad-Aware.exe
    Command Line       : "C:\Program Files\Lavasoft\Ad-Aware SE Personal\Ad-Aware.exe"
    ProcessID          : 1420
    ThreadCreationTime : 9-14-2005 4:16:16 PM
    FileVersion        : 6.2.0.236
    ProductVersion     : SE 106
    ProductName        : Lavasoft Ad-Aware SE
    CompanyName        : Lavasoft Sweden
    FileDescription    : Ad-Aware SE Core application
    InternalName       : Ad-Aware.exe
    LegalCopyright     : Copyright © Lavasoft AB Sweden
    OriginalFilename   : Ad-Aware.exe
    Comments           : All Rights Reserved
Memory scan result:
New critical objects: 0
Objects found so far: 0
Started registry scan
Registry Scan result:
Started deep registry scan
Deep registry scan result:
Started Tracking Cookie scan
Tracking cookie scan result:
Deep scanning and examining files (C:)
Disk Scan Result for C:\
Scanning Hosts file......
Hosts file location:"C:\WINDOWS\system32\drivers\etc\hosts".
Hosts file scan result:
1 entries scanned.
New critical objects:0
6:23:04 PM Scan Complete
Summary Of This Scan
Total scanning time:00:06:37.343
Objects scanned:137305
Objects identified:0
Objects ignored:0
Offline Paddy
« Reply #3 on: September 16, 2005, 03:45:08 PM »
Hello, 10rand, sorry about the delay in replying to your post..
That’s a clean looking logfile I cant see anything strange there ..
You might want to run a web update as a new release has come out .
If that still comes back clean IE finds nothing,  if you wish we can have a HjT
Expert look at it and advise …
Download HiJack This from here:  http://www.thespykiller.co.uk/files/HJTsetup.exe
This will download HiJack This to your computer, choose "Save" and navigate to the folder where it´s saved and doubleclick upon it.
This is a complete installer that installs Hijackthis onto your computer to C:\Program Files\HijackThis and makes an entry in the start menu & allows you to have a shortcut on desktop as well.
then.......
Doubleclick the HJT icon on your desktop, hit "Do a system scan and save logfile". Save the logfile and a txt-file will be produced.. Copy that one and paste it here and we´ll have a HjT
Expert  look at it ..
Regards..
numbnuts.. :breakkie:
« Reply #4 on: September 16, 2005, 03:48:21 PM »
 :oops:  Oh my, I was sure I had responded to 10rand's logfile post.  Thank you, numbnuts.
« Reply #5 on: September 17, 2005, 05:49:41 PM »
10rand ,
I have moved your HijackThis log file to the HijackThis forum.
GR@PH;<'S   :breakkie:
