Author Topic: Ad-Aware Update SE1B100  (Read 1484 times)
Offline SpiritWind
« on: March 23, 2006, 12:45:24 AM »
 :D Hi Everyone :
     Got an email notification from Lavasoft of the release of "SE1B100 has been
     released today for beta testing" ; I have never seen such a Release. Beta
     usually means experimental and I usually avoid such "things". What is going
     on with this "Update" ?
For the BEST in what counts in Life :
www.tacf.org
Re: Ad-Aware Update SE1B100
« Reply #1 on: March 23, 2006, 12:48:57 AM »
You apparently signed up for the beta testing program at some point.  What has happened, apparently, is that they found an error in the SE1B100 and re-released it after correcting the error.  This was done, I am sure, in order to prevent problems to beta-tester's PC's and also so more testers would not need to report the error that was already discovered.
Due to an error found in the original 100 Beta file, we are re-releasing it as SE1B100 BETA-2
Please download and test this file
Thanks
//Lavasoft Research Team
Offline mitch
« Reply #2 on: March 23, 2006, 02:31:15 AM »
i got the same e-mail
i am on the normal e-mail update list !
so feeling brave i did do a "check for updates" and it found none so figure someone just hit the wrong buttons on the notification ( i seem to remember in the past they had that trouble with the mailings late,missing,wrong ;~D
« Reply #3 on: March 23, 2006, 11:30:59 AM »
Could be they were covering all bases too.  I would rather see overkill in a situation where an error was found than the reverse.
« Reply #4 on: March 23, 2006, 03:30:25 PM »
Well at least looks like SE1B100 BETA-2 that was released for beta testing has been released ,
see SE1R100 23.03.2006
GR@PH;<'S   :breakkie:
