Author Topic: Delay in aaw opening  (Read 1722 times)
Offline kenb
« on: February 03, 2006, 09:36:30 AM »
There seems to be an unusual long delay in opening window loading on Ad-Aware Plus.
It takes some time searching for definitions.
This had started happening since reinstalling.
Have I set it up differently?
Help would be very welcome.
Kenb :(
Re: Delay in aaw opening
« Reply #1 on: February 03, 2006, 05:01:24 PM »
kenb,
I recommend that redownload a fresh copy of Ad-aware plus,
(Note you will need your registraion details to get the new copy)
then after doing that un-install the version you have of Ad-aware plus, Then Reboot (ie: Re-start your PC)
 then go and remove any folder that is left behind on the hard drive IE:The orphaned Lavasoft folder.
Then re-install Ad-aware plus.
GR@PH;<'S   :breakkie:
Offline kenb
« Reply #2 on: February 03, 2006, 07:05:24 PM »
Thanks for prompt reply,carried out your instructions but it has not change anything,it still takes about 2 mins. loading definitions before window loads after opening from desktop shortcut.
KenB
I'm sure it did'nt take this long before.
« Reply #3 on: February 03, 2006, 08:10:56 PM »
kenb,
just a thought but have you tried doing a thorough Disk Defragmentation,
if not try one also clear out your cache folder ie: temporary internet folder There are some free programs that you can use that will do that for you if needed like ;)
CCleaner
(Note in CCleaner: go to >options > advanced > Uncheck "Only delete files in Windows Temp folders older than 48 hours"). .
please can you do a"Full Scan" and post it for us by using the Add-Reply Feature .
Also you may want to  download ewido
Offline kenb
« Reply #4 on: February 10, 2006, 02:15:50 PM »
Thanks for all assistance offered,I have finally after what seems like months of problems of various kinds have managed with the help of a computer repair service  to cure the problem. After a quick inspection the motherboard was found to be faulty,there was obvious leakage on several capacitors making the board unstable causing all sorts of alarms and reboots.Motherboard replaced,problem solved :thumbsup:.
Hoping to return to some form of normality
Ken. :gwave: :gwave:
« Reply #5 on: February 10, 2006, 03:29:53 PM »
Hi, Ken. Too bad about the MB, but its great news that your PC is repaired.  Make sure to get all the software updates you may have missed while having PC problems.  :)
