Hello, davcho not sure but I think it might have something to do with TrueVector service running in the back ground thus, you cant install the update till you kill that service first , can you try this please and see if its causing the problem …also "Process Explorer" might be helpful
In finding out if it running in the back ground .. then if it is running can you follow the instructions below to kill it …
http://www.sysinternals.com/Utilities/ProcessExplorer.htmlI don't think you realized it, but you have windows fire wall running also ,
You can locate the "Security Center" from Start > Control Panel and turn off the Windows Firewall from there.
#:15 [alg.exe]
FilePath : C:\WINDOWS\System32\
ProcessID : 1352
ThreadCreationTime : 2-26-2006 6:39:36 AM
BasePriority : Normal
FileVersion : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
ProductVersion : 5.1.2600.2180
ProductName : Microsoft® Windows® Operating System
CompanyName : Microsoft Corporation
FileDescription : Application Layer Gateway Service
InternalName : ALG.exe
LegalCopyright : © Microsoft Corporation. All rights reserved.
OriginalFilename : ALG.exe
If you used the built-in uninstaller for ZoneAlarm, the TrueVector service was not disabled and removed. This can result in loss of network access. To prevent that service from causing the same problem in the future, follow the steps below.
To disable TrueVector at startup:1. Click
Start >Control Panel (Windows XP), or
Start >Settings >Control Panel (all other versions of Windows).
2. Open the Services tool as described below:
(Classic View)
Double-click Administrative Tools. Then, double-click
Services.(Category View) Click
Performance and Maintenance. Then, click Administrative Tools and double-click
Services. d. Double-click on the entry named
TrueVector Internet Monitor.e.Select
Disable from the
Startup Type drop-down menu.
f. Close the Services Control Panel.
To properly uninstall ZoneAlarm:To correctly uninstall ZoneAlarm, use the Add and Remove Programs control panel. Also, for Windows NT, 2000, and XP, you must first disable the True Vector Service (Steps 1 and 2, below).
1. Click
Start, then
Run. 2. Type
net stop "TrueVector Internet Monitor" just as it appears then press
OK. 3. Click
4. Click
Add or Remove Programs. 5. Click on the entry for ZoneAlarm.
6. Click
Change/Remove to uninstall the program.
7.
Restart your system..Link:
http://www.utexas.edu/its/bevoware/faq/symprobs.html#q1numbnuts...
