Tjenare, Mimmi.
Yes, you need to watch that Skittles and her USA version of English. Of course, that is what you will get from me as well. If you need help in Swedish, let us know and we can get Die Hard to help.
This information that Die Hard provided may be helpful in your communications with Skittles. Make her learn the Swedish.
These are the Swedish filepaths:
Documents and settings\username\favorites .....Documents and settings\Användarnamn\Favoriter
Documents and settings\username\application data.......Documents and settings\Användarnamn\Application Data
Program Files....Program files That folder exists in the Swedish edition, but a new default program folder is created, called simply "PROGRAM")
Start Menu......Start meny
Desktop.......Skrivbord
To uninstall:
Click Start > Control Panel > Add or Remove Programs. Wait until the menu populates (until the file list is built by the computer). When that is finished, Click on Ad-Aware SE Personal to highlight it. Click Change/Remove and accept the prompts.
I believe this is close in Swedish:
Avinstallera:
* Välj Start - Inställningar (fi. Käynnistä - Asetukset, eng. Start - Settings).
* Öppna Kontrollpanelen (fi. Ohjauspaneeli, eng. Control Panel).
* Välj Svefix.
* Välj Lägg till/Ta bort program (fi. Lisää/Poista sovellus, eng. Add/Remove Programs).
* Klicka på knappen Lägg till/Ta bort.
http://www.lingsoft.fi/svefix/bruk.html#anvandning
