Hi Friends,
I don't think this is a problem, but need to be sure.
I installed SpywareGuard not too long ago, but soon after that, I read that one should only have one real-time spyware protection enabled. I already had Tea Timer enabled, so I then disabled my new SpywareGuard.
Now I just ran a HijackThis scan, and the log shows SpywareGuard as a running process:
C:\Program Files\Javacool\SpywareGuard\sgmain.exe
It also shows it is set to run on startup:
O4 - Startup: SpywareGuard.lnk = C:\Program Files\Javacool\SpywareGuard\sgmain.exe
I opened SG to confirm everything is disabled, and it appears to be completely disabled. So I don't understand why HT shows it is
currently running and running at startup???
Can someone explain this to me? Do these HT entries mean that some parts of SG are enabled, even though all the settings appear to be disabled? If so, could I be at risk by having 2 real-time spyware programs running? Should I go ahead and delete SG to avoid conflict? Or have I just overlooked some settings in SG?
Thanks very much.
