Author Topic: WinSpyareProtect and other rogue anti-spyware programs  (Read 5188 times)
Offline Mike D
« on: July 06, 2008, 04:35:39 PM »
Greetings all,
I'm looking for a bit of advice on how to purge my laptop of a couple of unwanted rogue anti-spyware programs.  My machine was recently infected with adware from two websites, www.winspywareprotect.com and www.antispycheck.com.  I looked these sites up on McAfee Site Advisor and both of them were shown to contain unwanted adware, spyware and other unwated programs.
I get frequent bogus system alerts ("spyware alert") suggesting that I my computer may be susceptible to spyware or malware.  Clicking on these alerts leads of course to the websites for these rogue anti-spyware programs.  The other annoying feature is that when browsing on the web, every third or fourth page I access brings up a warning for "insecure internet activity, threat of virus attack", where I am given the option of accessing protective anti-spyware programs (WinSpywareProtect), or continuing unprotected.  This is more than a little irritating.
I've tried scanning my machine with Webroot SpySweeper and Advanced Antivirus software, but neither seems to be capable of locating the source of the programs.  Any ideas on how to identify and exterminate these rogue anti-spyware programs?
Thanks,
Mike D
Re: WinSpyareProtect and other rogue anti-spyware programs
« Reply #1 on: July 06, 2008, 05:17:45 PM »
Please can you try at least two if not more of these  On-line scans, Removing any items that are found
Panda
TrendMicro
Bit Defender
Kaspersky
Symantec
McAfee
CyberTechHelp
PC Pitstop
Stinger
Also please use one or both of  these Trojan scanners
a2
or download and try
TrojanHunter (Note Trojan Scanner 30 day Trial)
Once you have done that can you clear out your cache folder again ie: Run
CCleaner
(Note in CCleaner: go to >options > advanced > Uncheck "Only delete files in Windows Temp folders older than 48 hours").
Now can you scan for Spy/Malware there are a number of programs that you can use for free Malwarebytes' Anti-Malware is one of them that i recommend after running the program you can post the logfile here.
« Reply #2 on: July 06, 2008, 06:11:08 PM »
I agree.  MBAM is great with the rogues.
Hi, Mike D.
Welcome to LandzDown Forum.  I would definitely go with GR@PH;<'S recommendation to use MBAM.  I've posted the instructions below so you can provide an MBAM log for review along with a HijackThis log.
  • Once the program has loaded, select Perform quick scan, then click Scan.
  • Be sure that everything is checked, and click Remove Selected.
  • When completed, a log will open in Notepad. Please save it to a convenient location. The log can also be found here: C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt
  • Please post contents of that file in your next reply and a HijackThis log.
Please download HijackThis© from one of the following sites:  Note:  If you have used any anti-spyware applications, please shutdown/restart the computer before scanning with HijackThis©.
At the download prompt, choose "Save"
  • Navigate to the saved file and double-click the installer, HJTsetup.exe
  • By default, HijackThis© will be installed on your computer at C:\Program Files\Trend Micro\HijackThis, making an entry in the Start menu and also providing a Desktop shortcut
  • When the installation is complete, double-click the HijackThis icon on your desktop
  • Select "Do a system scan and save the Logfile"
  • When the scan is completed, Notepad will launch with the log.   Please UNcheck Word Wrap in Notepad (Click Format > UNcheck Word Wrap)
  • Do not fix anything that you see in the log. (Scanning will not make any changes to your computer.  Most of what is found is harmless or even required.)
  • Copy/Paste the log as a reply  (Select Edit > Select All > Edit Copy)
  • Close HijackThis and Notepad
Offline Mike D
« Reply #3 on: July 07, 2008, 03:46:24 AM »
GR@PH;<'S and Corrine,
Thanks so much for the advice.
I ran both the MBAM and HijackThis scans.  The log files are attached.
I don't think I read the entire list of programs that MBAM deleted, but I think one of them might have been Advanced Antivirus, since I no longer see it on my desktop or among the programs in the 'Start' menu.  Have either of you heard anything about this program being identified as malware?  If so, that may have been part of the problem.  I looked it up before on McAfee SiteAdvisor, but I believe it came up clean.
Anyway, the problem may have been solved.  I had to restart my computer before running one of the scans, and I didn't see any of the annoying ads or phony system alerts upon restarting and opening my web browser.  So far, so good...
Cheers,
Mike D  :Hammys pint:
[attachment deleted by admin]
Offline Mike D
« Reply #4 on: July 07, 2008, 03:53:13 AM »
It appears that I couldn't send the HijackThis log file as an attachment (the link didn't work), so I've copied the text below.
--Mike D
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 10:12:00 PM, on 7/6/2008
MSIE: Internet Explorer v7.00 (7.00.6000.16674)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\TOSHIBA\TOSHIBA Controls\TFncKy.exe
C:\WINDOWS\system32\TDispVol.exe
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
C:\WINDOWS\system32\igfxtray.exe
C:\Program Files\Synaptics\SynTP\Toshiba.exe
C:\WINDOWS\system32\hkcmd.exe
C:\WINDOWS\system32\igfxpers.exe
C:\WINDOWS\ehome\ehtray.exe
C:\Program Files\Toshiba\Toshiba Applet\thotkey.exe
C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
C:\WINDOWS\AGRSMMSG.exe
C:\Program Files\Toshiba\Tvs\TvsTray.exe
C:\WINDOWS\system32\TPSMain.exe
C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe
C:\WINDOWS\system32\dla\DLACTRLW.exe
C:\Program Files\Intel\Wireless\bin\ZCfgSvc.exe
C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe
C:\Program Files\Trend Micro\Antivirus\pccguide.exe
C:\Program Files\Trend Micro\Antivirus\PCClient.exe
C:\WINDOWS\system32\DVDRAMSV.exe
C:\Program Files\Trend Micro\Antivirus\TMOAgent.exe
C:\WINDOWS\system32\TPSBattM.exe
C:\Program Files\Qwest\QuickCare\bin\sprtcmd.exe
C:\WINDOWS\eHome\ehRecvr.exe
C:\Program Files\QuickTime\qttask.exe
C:\WINDOWS\eHome\ehSched.exe
C:\Program Files\McAfee.com\Agent\mcagent.exe
C:\Program Files\SiteAdvisor\6261\SiteAdv.exe
C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
C:\Program Files\Webroot\Spy Sweeper\SpySweeperUI.exe
C:\Program Files\TOSHIBA\TOSCDSPD\toscdspd.exe
C:\Program Files\Messenger\msmsgs.exe
C:\PROGRA~1\Yahoo!\MESSEN~1\YAHOOM~1.EXE
c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
C:\Program Files\Belkin\F5D8013\Belkinwcui.exe
C:\Program Files\FinePixViewerS\QuickDCF2.exe
C:\WINDOWS\system32\RAMASST.exe
C:\Program Files\Microsoft Office\OFFICE11\ONENOTEM.EXE
c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
C:\Program Files\McAfee\MPF\MPFSrv.exe
C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
C:\Program Files\SiteAdvisor\6261\SAService.exe
c:\TOSHIBA\IVP\swupdate\swupdtmr.exe
C:\Program Files\TOSHIBA\TOSHIBA Applet\TAPPSRV.exe
C:\Program Files\Trend Micro\Antivirus\Tmntsrv.exe
C:\Program Files\Trend Micro\Antivirus\tmproxy.exe
C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
C:\WINDOWS\system32\dllhost.exe
C:\PROGRA~1\Intel\Wireless\Bin\Dot1XCfg.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\WINDOWS\eHome\ehmsas.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe
C:\Program Files\Webroot\Spy Sweeper\SSU.EXE
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.toshibadirect.com/dpdstart
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = :
R3 - URLSearchHook: Yahoo! ¤u¨ã¦C - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn\yt.dll
R3 - URLSearchHook: (no name) - {0579B4B6-0293-4d73-B02D-5EBB0BA0F0A2} - C:\Program Files\AskSBar\SrchAstt\1.bin\A2SRCHAS.DLL
O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn\yt.dll
O2 - BHO: Ask Search Assistant BHO - {0579B4B1-0293-4d73-B02D-5EBB0BA0F0A2} - C:\Program Files\AskSBar\SrchAstt\1.bin\A2SRCHAS.DLL
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {089FD14D-132B-48FC-8861-0048AE113215} - C:\Program Files\SiteAdvisor\6261\SiteAdv.dll
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O2 - BHO: DriveLetterAccess - {5CA3D70E-1895-11CF-8E15-001234567890} - C:\WINDOWS\System32\DLA\DLASHX_W.DLL
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\McAfee\VirusScan\scriptsn.dll
O2 - BHO: Ask Toolbar BHO - {F0D4B231-DA4B-4daf-81E4-DFEE4931A4AA} - C:\Program Files\AskSBar\bar\1.bin\ASKSBAR.DLL (file missing)
O3 - Toolbar: Ask Toolbar - {F0D4B239-DA4B-4daf-81E4-DFEE4931A4AA} - C:\Program Files\AskSBar\bar\1.bin\ASKSBAR.DLL (file missing)
O3 - Toolbar: McAfee SiteAdvisor - {0BF43445-2F28-4351-9252-17FE6E806AA0} - C:\Program Files\SiteAdvisor\6261\SiteAdv.dll
O4 - HKLM\..\Run: [TFncKy] TFncKy.exe
O4 - HKLM\..\Run: [tdispVol] TDispVol.exe
O4 - HKLM\..\Run: [SynTPEnh] "C:\Program Files\Synaptics\SynTP\SynTPEnh.exe"
O4 - HKLM\..\Run: [igfxtray] C:\WINDOWS\system32\igfxtray.exe
O4 - HKLM\..\Run: [igfxhkcmd] C:\WINDOWS\system32\hkcmd.exe
O4 - HKLM\..\Run: [igfxpers] C:\WINDOWS\system32\igfxpers.exe
O4 - HKLM\..\Run: [ehTray] C:\WINDOWS\ehome\ehtray.exe
O4 - HKLM\..\Run: [THotkey] "C:\Program Files\Toshiba\Toshiba Applet\thotkey.exe"
O4 - HKLM\..\Run: [SynTPLpr] "C:\Program Files\Synaptics\SynTP\SynTPLpr.exe"
O4 - HKLM\..\Run: [LtMoh] "C:\Program Files\ltmoh\Ltmoh.exe"
O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM\..\Run: [Tvs] "C:\Program Files\Toshiba\Tvs\TvsTray.exe"
O4 - HKLM\..\Run: [TPSMain] TPSMain.exe
O4 - HKLM\..\Run: [PadTouch] C:\Program Files\TOSHIBA\Touch and Launch\PadExe.exe
O4 - HKLM\..\Run: [SmoothView] "C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe"
O4 - HKLM\..\Run: [dla] C:\WINDOWS\system32\dla\DLACTRLW.exe
O4 - HKLM\..\Run: [IntelZeroConfig] "C:\Program Files\Intel\Wireless\bin\ZCfgSvc.exe"
O4 - HKLM\..\Run: [IntelWireless] "C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe" /tf Intel PROSet/Wireless
O4 - HKLM\..\Run: [pccguide.exe] "C:\Program Files\Trend Micro\Antivirus\pccguide.exe"
O4 - HKLM\..\Run: [PCClient.exe] "C:\Program Files\Trend Micro\Antivirus\PCClient.exe"
O4 - HKLM\..\Run: [TM Outbreak Agent] "C:\Program Files\Trend Micro\Antivirus\TMOAgent.exe" /run
O4 - HKLM\..\Run: [QuickCare2.2] "C:\Program Files\Qwest\QuickCare\bin\sprtcmd.exe" /P QuickCare2.2
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [AntiSpywareMaster] C:\Program Files\AntiSpywareMaster\asm.exe
O4 - HKLM\..\Run: [mcagent_exe] "C:\Program Files\McAfee.com\Agent\mcagent.exe" /runkey
O4 - HKLM\..\Run: [SiteAdvisor] "C:\Program Files\SiteAdvisor\6261\SiteAdv.exe"
O4 - HKLM\..\Run: [SpySweeper] "C:\Program Files\Webroot\Spy Sweeper\SpySweeperUI.exe" /startintray
O4 - HKCU\..\Run: [TOSCDSPD] "C:\Program Files\TOSHIBA\TOSCDSPD\toscdspd.exe"
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [Yahoo! Pager] "C:\PROGRA~1\Yahoo!\MESSEN~1\YAHOOM~1.EXE" -quiet
O4 - HKCU\..\Run: [e©ùýùäûïÞóÎéøøíøôÞÊýùñûïÞó] "C:\Program Files\XP Antivirus\xpscanner.exe"
O4 - HKCU\..\Run: [30465995306012014977879104955686] "C:\Program Files\XP Antivirus\xpscanner.exe"
O4 - Startup: Microsoft Office OneNote 2003 Quick Launch.lnk = C:\Program Files\Microsoft Office\OFFICE11\ONENOTEM.EXE
O4 - Global Startup: Belkin F5D8013 N Wireless Notebook Card Utility.lnk = C:\Program Files\Belkin\F5D8013\Belkinwcui.exe
O4 - Global Startup: Exif Launcher S.lnk = ?
O4 - Global Startup: RAMASST.lnk = C:\WINDOWS\system32\RAMASST.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_04\bin\npjpi150_04.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_04\bin\npjpi150_04.dll
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
O14 - IERESET.INF: START_PAGE_URL=http://www.toshibadirect.com/dpdstart
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper.dll
O20 - AppInit_DLLs: C:\PROGRA~1\Google\GOOGLE~1\GOEC62~1.DLL
O23 - Service: AOL Connectivity Service (AOL ACS) - America Online - C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
O23 - Service: AOL TopSpeed Monitor (AOL TopSpeedMonitor) - America Online, Inc - C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
O23 - Service: ConfigFree Service (CFSvcs) - TOSHIBA CORPORATION - C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
O23 - Service: DVD-RAM_Service - Matsu****a Electric Industrial Co., Ltd. - C:\WINDOWS\system32\DVDRAMSV.exe
O23 - Service: Intel(R) PROSet/Wireless Event Log (EvtEng) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
O23 - Service: McAfee Real-time Scanner (McShield) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
O23 - Service: McAfee SystemGuards (McSysmon) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe
O23 - Service: McAfee Personal Firewall Service (MpfService) - McAfee, Inc. - C:\Program Files\McAfee\MPF\MPFSrv.exe
O23 - Service: Intel(R) PROSet/Wireless Registry Service (RegSrvc) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
O23 - Service: Intel(R) PROSet/Wireless Service (S24EventMonitor) - Intel Corporation  - C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
O23 - Service: SiteAdvisor Service - Unknown owner - C:\Program Files\SiteAdvisor\6261\SAService.exe
O23 - Service: SupportSoft Listener Service (sprtlisten) - SupportSoft, Inc. - C:\Program Files\Common Files\supportsoft\bin\sprtlisten.exe
O23 - Service: SupportSoft RemoteAssist - SupportSoft, Inc. - C:\Program Files\Common Files\SupportSoft\bin\ssrc.exe
O23 - Service: Swupdtmr - Unknown owner - c:\TOSHIBA\IVP\swupdate\swupdtmr.exe
O23 - Service: TOSHIBA Application Service (TAPPSRV) - TOSHIBA Corp. - C:\Program Files\TOSHIBA\TOSHIBA Applet\TAPPSRV.exe
O23 - Service: Trend NT Realtime Service (Tmntsrv) - Trend Micro Incorporated. - C:\Program Files\Trend Micro\Antivirus\Tmntsrv.exe
O23 - Service: Trend Micro Proxy Service (tmproxy) - Trend Micro Incorporated. - C:\Program Files\Trend Micro\Antivirus\tmproxy.exe
O23 - Service: Webroot Spy Sweeper Engine (WebrootSpySweeperService) - Webroot Software, Inc. - C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
End of file - 12150 bytes
« Reply #5 on: July 07, 2008, 11:45:24 AM »
Mike D,
Advanced Antivirus is fake anti-spyware..
you get fake security alerts to try and trick you into buying Advanced Antivirus it may also have downloaded itself onto your computer through a Trojan, it can and does launch when you start up your PC and you may receive tons of ads that are hard to close.
Someone will be long and let you know what to do about what was found in your logfile,
GR@:PH;<'S   :Hammys pint:
Offline Paddy
« Reply #6 on: July 07, 2008, 05:06:23 PM »
Mike D, I've posted your MBAM logfile for ease of reading ..
numbnuts:
Malwarebytes' Anti-Malware 1.19
Database version: 929
Windows 5.1.2600 Service Pack 2
9:56:28 PM 7/6/2008
mbam-log-7-6-2008 (21-56-28).txt
Scan type: Quick Scan
Objects scanned: 44530
Time elapsed: 11 minute(s), 49 second(s)
Memory Processes Infected: 2
Memory Modules Infected: 1
Registry Keys Infected: 5
Registry Values Infected: 15
Registry Data Items Infected: 8
Folders Infected: 8
Files Infected: 32
C:\Documents and Settings\All Users\Application Data\Adsl Software Ltd\WinSpywareProtect\Winspywareprotect.exe (Rogue.Installer) -> Unloaded process successfully.
C:\Program Files\AAV\aav.exe (Rogue.AdvancedAntivirus) -> Unloaded process successfully.
C:\WINDOWS\system32\jhzpcn.dll (Trojan.Zlob) -> Unloaded module successfully.
HKEY_CLASSES_ROOT\CLSID\{2a7a8ce2-1eaf-4fc0-9158-958bb6bfa5c4} (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7bc9c2e2-73a6-4fcf-b73d-cbaa20b31c9b} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\AntiSpyCheck 2.1 (Rogue.AntiSpyCheck) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Adsl Software Ltd (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IExplorer Bar (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler\{2a7a8ce2-1eaf-4fc0-9158-958bb6bfa5c4} (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\WinSpywareProtect (Rogue.Installer) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser\{07aa283a-43d7-4cbe-a064-32a21112d94d} (Adware.Zango) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\Antivirus (Rogue.AdvancedAntivirus) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\AUTORUN_VAL (Rogue.AntiSpyCheck) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\SearchMigratedDefaultURL (Trojan.Zlob) -> Delete on reboot.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\Default_Search_URL (Trojan.Zlob) -> Delete on reboot.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchUrl\w\ (Trojan.Zlob) -> Delete on reboot.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchURL (Trojan.Zlob) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\SearchMigratedDefaultURL (Trojan.Zlob) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchUrl\w\ (Trojan.Zlob) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchURL (Trojan.Zlob) -> Delete on reboot.
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\New Windows\Allow\*.securewebinfo.com (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\New Windows\Allow\*.safetyincludes.com (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\New Windows\Allow\*.securemanaging.com (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchUrl\w\ (Hijack.Search) -> Bad: (http://internetsearchservice.com/search?q=%s) Good: (http://www.google.com/) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchUrl\w\ (Hijack.Search) -> Bad: (http://internetsearchservice.com/search?q=%s) Good: (http://www.google.com/) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\SearchURL (Hijack.Search) -> Bad: (http://internetsearchservice.com) Good: (http://www.google.com/) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\SearchURL (Hijack.Search) -> Bad: (http://internetsearchservice.com) Good: (http://www.google.com/) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\SearchMigratedDefaultURL (Hijack.Search) -> Bad: (http://internetsearchservice.com/search?q={searchTerms}) Good: (http://www.google.com/) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\Default_Search_URL (Hijack.Search) -> Bad: (http://internetsearchservice.com) Good: (http://www.google.com/) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main\SearchMigratedDefaultURL (Hijack.Search) -> Bad: (http://internetsearchservice.com/search?q={searchTerms}) Good: (http://www.google.com/) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\ForceActiveDesktopOn (Hijack.Desktop) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
Folders Infected:
C:\Program Files\AAV (Rogue.AdvancedAntivirus) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\788877 (Trojan.BHO) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\BASE (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\DELETED (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\SAVED (Rogue.Multiple) -> Quarantined and deleted successfully.
Files Infected:
C:\WINDOWS\system32\jhzpcn.dll (Trojan.Zlob) -> Delete on reboot.
C:\Documents and Settings\All Users\Application Data\Adsl Software Ltd\WinSpywareProtect\Winspywareprotect.exe (Rogue.Installer) -> Quarantined and deleted successfully.
C:\Program Files\AAV\aav.cpl (Rogue.AdvancedAntivirus) -> Quarantined and deleted successfully.
C:\Program Files\AAV\aav.exe (Rogue.AdvancedAntivirus) -> Quarantined and deleted successfully.
C:\Program Files\AAV\aav.ooo (Rogue.AdvancedAntivirus) -> Quarantined and deleted successfully.
C:\Program Files\AAV\aav0.dat (Rogue.AdvancedAntivirus) -> Quarantined and deleted successfully.
C:\Program Files\AAV\aav1.dat (Rogue.AdvancedAntivirus) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080629094756187.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080629101018421.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080630085543437.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080630113054906.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080630131412578.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080630204859750.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080701000700875.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080701202058437.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080703195004750.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080704103240328.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080705065737656.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080705102753062.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080705164332390.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ADSL Software Ltd\WinSpywareProtect\LOG\20080706180512281.log (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\aav.cpl (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Documents and Settings\home\Desktop\Advanced Antivirus.lnk (Rogue.AdvancedAntivirus) -> Quarantined and deleted successfully.
C:\Documents and Settings\home\My Documents\My Music\My Music.url (Trojan.Zlob) -> Quarantined and deleted successfully.
C:\Documents and Settings\home\My Documents\My Pictures\My Pictures.url (Trojan.Zlob) -> Quarantined and deleted successfully.
C:\Documents and Settings\home\My Documents\My Videos\My Video.url (Trojan.Zlob) -> Quarantined and deleted successfully.
C:\Documents and Settings\home\My Documents\My Documents.url (Trojan.Zlob) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Antivirus Scan.url (Trojan.Zlob) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Online Spyware Test.url (Trojan.Zlob) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Desktop\Antivirus Scan.url (Rogue.Link) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Desktop\Online Spyware Test.url (Rogue.Link) -> Quarantined and deleted successfully.
C:\Documents and Settings\home\Favorites\Antivirus Scan.url (Rogue.Link) -> Quarantined and deleted successfully.
« Reply #7 on: July 07, 2008, 09:31:15 PM »
Just as well, Mike.  Having the logs posted makes analysis easier and, as you can see, we work as a team.
Work is still needed to clean up your machine.  Please follow the instructions below, in the order presented and post the requested logs as a reply.
First, please go to add/remove programs and check for an uninstaller for the following programs and uninstall them:
AskSBar
AntiSpywareMaster
XP Antivirus
Next, close all programs leaving only HijackThis running.  Place a check against each of the following, making sure you get them all and not any others by mistake:
Click on Fix Checked when finished and exit HijackThis.
Please navigate to Program files and delete any left behind folder for the following:
SunJava is out of date.  As older versions are vulnerable to the Virtumundo infection, I suggest you uninstall the old version(s) and update to the latest.  Illustrated instructions are available at my Security Garden blog http://securitygarden.blogspot.com/2006/09/sunflowers-and-sunjava-update.html .
Next, please download ATF Cleaner by Atribune from http://www.atribune.org/index.php?option=com_content&task=view&id=25&Itemid=25 .  Save it to your Desktop.
Run ATF Cleaner
Because two of those rogues were not included in the MBAM results, I want to be sure all the remnants are removed that and there isn't something else lurking in the background.
Please follow these instructions carefully:
Download Combofix from any of the links below, and save it to your desktop.  For information regarding this download, please visit this webpage: http://www.bleepingcomputer.com/combofix/how-to-use-combofix
            Link 1
            Link 2
            Link 3
**Note:  It is important that it is saved directly to your desktop**
1. Close any open browsers.
2. Close/disable all anti virus and anti malware programs so they do not interfere with the running of ComboFix.
Double click on combofix.exe & follow the prompts.
    When finished, it will produce a report for you.
  • Please post the "C:\ComboFix.txt" along with a new HijackThis log for further review.
Note: Do not mouse click the combofix window while it is running. That may cause it to stall.  Run ComboFix ONLY one time.
Offline Mike D
« Reply #8 on: August 21, 2008, 12:46:31 AM »
Corrine,
I'm part of the way there.  I didn't find any of the three programs (AskSBar, AntiSpywareMaster or XP Antivirus) in the add/remove programs list.  I did however find a folder with some residual content under C:\Program Files\AskSBar, and deleted it.  I also 'fixed' the seven items listed using HijackThis.
I've hit a roadblock trying to install a newer version of SunJava, though.  When I try to uninstall the older version (J2SE Runtime Environment 5.0 Update 4), I get an error message reading: "Fatal error during installation".  Not very descriptive.  Any ideas on how to get around this?
Thanks,
Mike D
« Reply #9 on: August 21, 2008, 11:11:51 AM »
Hi, Mike.  It has been so long since you first came to us with your problem, a new tool is now available for removing the old versions of SunJava.
Please download JavaRa and unzip it to your desktop.
  • Double-click on JavaRa.exe to start the program.
Then download and install Java Runtime Environment (JRE) 6 Update 7.
After that, if you still need assistance, please proceed with ATF Cleaner and the remaining instructions.
Offline Mike D
« Reply #10 on: September 09, 2008, 03:07:56 AM »
Hi Corrine,
I've run the new scans.  The HijackThis and ComboFix logs are posted below.
HijackThis
Scan saved at 7:09:56 PM, on 8/20/2008
MSIE: Internet Explorer v7.00 (7.00.6000.16705)
Boot mode: Normal
Running processes:
C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
C:\Program Files\Bonjour\mDNSResponder.exe
C:\Program Files\QuickTime\QTTask.exe
c:\PROGRA~1\mcafee\msc\mcuimgr.exe
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
O4 - HKLM\..\Run: [AppleSyncNotifier] "C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe"
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
End of file - 12928 bytes
ComboFix
ComboFix 08-09-05.10 - home 2008-09-08 21:13:30.1 - NTFSx86
Microsoft Windows XP Professional  5.1.2600.2.1252.1.1033.18.418 [GMT -5:00]
Running from: C:\Documents and Settings\home\Desktop\ComboFix.exe
 * Created a new restore point
 * Resident AV is active
WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
C:\WINDOWS\system32\actskn43.ocx
(((((((((((((((((((((((((   Files Created from 2008-08-09 to 2008-09-09  )))))))))))))))))))))))))))))))
2008-09-05 09:38 . 2008-09-07 23:34   <DIR>   d--------   C:\Documents and Settings\LocalService\Application Data\SACore
2008-08-26 01:28 . 2008-08-26 01:28   <DIR>   d--------   C:\Program Files\Sun
2008-08-26 01:28 . 2008-06-10 02:32   73,728   --a------   C:\WINDOWS\system32\javacpl.cpl
2008-08-13 08:39 . 2008-05-01 09:30   331,776   -----c---   C:\WINDOWS\system32\dllcache\msadce.dll
2008-09-06 21:41   ---------   d-----w   C:\Program Files\McAfee
2008-09-05 14:05   ---------   d-----w   C:\Documents and Settings\All Users\Application Data\SiteAdvisor
2008-09-05 14:04   ---------   d-----w   C:\Documents and Settings\All Users\Application Data\McAfee
2008-08-26 06:27   ---------   d-----w   C:\Program Files\Java
2008-08-26 06:23   ---------   d-----w   C:\Program Files\Common Files\Java
2008-07-29 04:35   ---------   d-----w   C:\Documents and Settings\home\Application Data\Apple Computer
2008-07-23 03:20   ---------   d-----w   C:\Program Files\Common Files\SunnComm Shared
2008-07-20 23:00   ---------   d-----w   C:\Program Files\iTunes
2008-07-20 23:00   ---------   d-----w   C:\Program Files\iPod
2008-07-20 23:00   ---------   d-----w   C:\Documents and Settings\All Users\Application Data\Apple Computer
2008-07-20 22:59   ---------   d-----w   C:\Program Files\QuickTime
2008-07-20 22:59   ---------   d-----w   C:\Program Files\Bonjour
2008-07-20 22:57   ---------   d-----w   C:\Program Files\Apple Software Update
2008-07-20 22:55   ---------   d-----w   C:\Program Files\Common Files\Apple
2008-07-20 22:55   ---------   d-----w   C:\Documents and Settings\All Users\Application Data\Apple
2008-07-10 14:35   32,000   ----a-w   C:\WINDOWS\system32\drivers\usbaapl.sys
REGEDIT4
"ctfmon.exe"="C:\WINDOWS\system32\ctfmon.exe" [2004-08-10 15360]
"TOSCDSPD"="C:\Program Files\TOSHIBA\TOSCDSPD\toscdspd.exe" [2004-12-30 65536]
"MSMSGS"="C:\Program Files\Messenger\msmsgs.exe" [2004-10-13 1694208]
"Yahoo! Pager"="C:\PROGRA~1\Yahoo!\MESSEN~1\YAHOOM~1.EXE" [2007-08-30 4670704]
"SynTPEnh"="C:\Program Files\Synaptics\SynTP\SynTPEnh.exe" [2005-12-16 761945]
"igfxtray"="C:\WINDOWS\system32\igfxtray.exe" [2005-11-28 98304]
"igfxhkcmd"="C:\WINDOWS\system32\hkcmd.exe" [2005-11-28 77824]
"igfxpers"="C:\WINDOWS\system32\igfxpers.exe" [2005-11-28 118784]
"ehTray"="C:\WINDOWS\ehome\ehtray.exe" [2005-08-05 64512]
"THotkey"="C:\Program Files\Toshiba\Toshiba Applet\thotkey.exe" [2006-01-05 352256]
"SynTPLpr"="C:\Program Files\Synaptics\SynTP\SynTPLpr.exe" [2005-12-16 82009]
"LtMoh"="C:\Program Files\ltmoh\Ltmoh.exe" [2004-08-18 184320]
"Tvs"="C:\Program Files\Toshiba\Tvs\TvsTray.exe" [2005-11-30 73728]
"SmoothView"="C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe" [2005-04-26 122880]
"dla"="C:\WINDOWS\system32\dla\DLACTRLW.exe" [2005-10-06 122940]
"IntelZeroConfig"="C:\Program Files\Intel\Wireless\bin\ZCfgSvc.exe" [2005-12-05 667718]
"IntelWireless"="C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe" [2005-11-28 602182]
"pccguide.exe"="C:\Program Files\Trend Micro\Antivirus\pccguide.exe" [2006-09-14 950337]
"PCClient.exe"="C:\Program Files\Trend Micro\Antivirus\PCClient.exe" [2006-09-14 634949]
"TM Outbreak Agent"="C:\Program Files\Trend Micro\Antivirus\TMOAgent.exe" [2006-09-14 290816]
"QuickCare2.2"="C:\Program Files\Qwest\QuickCare\bin\sprtcmd.exe" [2007-05-04 198184]
"QuickTime Task"="C:\Program Files\QuickTime\QTTask.exe" [2008-05-27 413696]
"Adobe Reader Speed Launcher"="C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-11 39792]
"mcagent_exe"="C:\Program Files\McAfee.com\Agent\mcagent.exe" [2007-11-01 582992]
"AppleSyncNotifier"="C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2008-07-10 116040]
"iTunesHelper"="C:\Program Files\iTunes\iTunesHelper.exe" [2008-07-10 289064]
"SunJavaUpdateSched"="C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe" [2008-06-10 144784]
"SpySweeper"="C:\Program Files\Webroot\Spy Sweeper\SpySweeperUI.exe" [2008-01-04 5367664]
"TFncKy"="TFncKy.exe" [BU]
"TDispVol"="TDispVol.exe" [2005-03-11 C:\WINDOWS\system32\TDispVol.exe]
"AGRSMMSG"="AGRSMMSG.exe" [2005-10-15 C:\WINDOWS\agrsmmsg.exe]
"TPSMain"="TPSMain.exe" [2005-06-01 C:\WINDOWS\system32\TPSMain.exe]
C:\Documents and Settings\home\Start Menu\Programs\Startup\
Microsoft Office OneNote 2003 Quick Launch.lnk - C:\Program Files\Microsoft Office\OFFICE11\ONENOTEM.EXE [2004-06-12 59080]
C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Belkin F5D8013 N Wireless Notebook Card Utility.lnk - C:\Program Files\Belkin\F5D8013\Belkinwcui.exe [2007-05-18 1716224]
Exif Launcher S.lnk - C:\Program Files\FinePixViewerS\QuickDCF2.exe [2008-07-05 303104]
RAMASST.lnk - C:\WINDOWS\system32\RAMASST.exe [2006-02-15 155648]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
"InstallVisualStyle"= C:\WINDOWS\Resources\Themes\Royale\Royale.msstyles
"InstallTheme"= C:\WINDOWS\Resources\Themes\Royale.theme
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSKDetectorExe]
--a------ 2005-08-12 18:16 1121792 C:\Program Files\McAfee\SpamKiller\MSKDetct.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSMSGS]
--------- 2004-10-13 11:24 1694208 C:\Program Files\Messenger\msmsgs.exe
[HKEY_LOCAL_MACHINE\software\microsoft\security center]
"AntiVirusDisableNotify"=dword:00000001
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeAntiVirus]
"DisableMonitoring"=dword:00000001
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeFirewall]
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
"EnableFirewall"= 0 (0x0)
"%windir%\\system32\\sessmgr.exe"=
"C:\\TOSHIBA\\ivp\\NetInt\\Netint.exe"=
"C:\\TOSHIBA\\Ivp\\ISM\\pinger.exe"= C:\\TOSHIBA\\IVP\\ISM\\pinger.exe
"C:\\Program Files\\Common Files\\AOL\\Loader\\aolload.exe"=
"C:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe"=
"C:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe"=
"C:\\Program Files\\America Online 9.0\\waol.exe"=
"C:\\Program Files\\Common Files\\AOL\\TopSpeed\\2.0\\aoltsmon.exe"=
"C:\\Program Files\\Common Files\\AOL\\TopSpeed\\2.0\\aoltpspd.exe"=
"C:\\Program Files\\Common Files\\AOL\\System Information\\sinf.exe"=
"C:\\Program Files\\Common Files\\AOL\\AOL Spyware Protection\\AOLSP Scheduler.exe"=
"C:\\Program Files\\Common Files\\AOL\\AOL Spyware Protection\\asp.exe"=
"C:\\Program Files\\Common Files\\AolCoach\\en_en\\player\\AOLNySEV.exe"=
"C:\\Program Files\\Messenger\\msmsgs.exe"=
"C:\\Program Files\\Common Files\\AOL\\1147563008\\EE\\AOLServiceHost.exe"=
"C:\\Program Files\\Yahoo!\\Yahoo! Music Engine\\YahooMusicEngine.exe"=
"%windir%\\Network Diagnostic\\xpnetdiag.exe"=
"C:\\Program Files\\Yahoo!\\Messenger\\YahooMessenger.exe"=
"C:\\Program Files\\Yahoo!\\Messenger\\YServer.exe"=
"C:\\Program Files\\Real\\RealPlayer\\realplay.exe"=
"C:\\Program Files\\Common Files\\McAfee\\MNA\\McNASvc.exe"=
"C:\\Program Files\\Bonjour\\mDNSResponder.exe"=
"C:\\Program Files\\iTunes\\iTunes.exe"=
R2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;C:\Program Files\McAfee\SiteAdvisor\McSACore.exe [2008-08-18 211232]
R2 sprtlisten;SupportSoft Listener Service;C:\Program Files\Common Files\supportsoft\bin\sprtlisten.exe [2008-01-08 1213728]
S3 IO_Memory;IO_Memory;c:\sysprep\Drivers\ioport.sys [ ]
S3 RT80x86;Ralink 802.11n Wireless Driver;C:\WINDOWS\system32\DRIVERS\RT2860.sys [2007-03-12 507264]
S3 SVRPEDRV;SVRPEDRV;C:\SYSPREP\PEDrv.sys [ ]
HKLM-Run-PadTouch - C:\Program Files\TOSHIBA\Touch and Launch\PadExe.exe
R0 -: HKCU-Main,Start Page = hxxp://www.yahoo.com/
R0 -: HKCU-Main,Search Page = hxxp://www.google.com
R0 -: HKCU-Main,SearchMigratedDefaultURL = 687474703a2f2f7777772e676f6f676c652e636f6d2f
R0 -: HKCU-Main,Default_Search_URL = 687474703a2f2f7777772e676f6f676c652e636f6d2f
R0 -: HKCU-Main,Search Bar = hxxp://www.google.com/ie
R0 -: HKLM-Main,Default_Page_URL = hxxp://www.toshibadirect.com/dpdstart
R0 -: HKLM-Main,SearchMigratedDefaultURL = 687474703a2f2f7777772e676f6f676c652e636f6d2f
R1 -: HKCU-Internet Settings,ProxyOverride = *.local
R1 -: HKLM-Internet Explorer,SearchURL = 687474703a2f2f7777772e676f6f676c652e636f6d2f
R0 -: HKLM-Search,SearchAssistant = hxxp://www.google.com/ie
O8 -: E&xport to Microsoft Excel - C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O18 -: Handler: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\McAfee\SITEAD~1\McIEPlg.dll
catchme 0.3.1361 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-09-08 21:26:54
Windows 5.1.2600 Service Pack 2 NTFS
scanning hidden processes ...
scanning hidden files ...
scan completed successfully
hidden files: 0
PROCESS: C:\WINDOWS\explorer.exe
-> C:\Program Files\McAfee\SiteAdvisor\saHook.dll
-> C:\WINDOWS\system32\TDispVol.dll
C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe
C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltpspd.exe
C:\WINDOWS\ehome\ehrecvr.exe
C:\WINDOWS\ehome\ehSched.exe
C:\PROGRA~1\COMMON~1\McAfee\MNA\McNASvc.exe
C:\PROGRA~1\COMMON~1\McAfee\McProxy\McProxy.exe
C:\PROGRA~1\McAfee\VIRUSS~1\Mcshield.exe
C:\Program Files\McAfee\MPF\MpfSrv.exe
C:\TOSHIBA\IVP\swupdate\swupdtmr.exe
C:\WINDOWS\ehome\mcrdsvc.exe
C:\WINDOWS\ehome\ehmsas.exe
C:\WINDOWS\system32\wscntfy.exe
C:\PROGRA~1\McAfee\MSC\mcuimgr.exe
C:\Program Files\Webroot\Spy Sweeper\ssu.exe
C:\WINDOWS\system32\igfxsrvc.exe
Completion time: 2008-09-08 21:34:09 - machine was rebooted
ComboFix-quarantined-files.txt  2008-09-09 02:33:55
Pre-Run: 131,457,945,600 bytes free
Post-Run: 131,512,340,480 bytes free
205   --- E O F ---   2008-08-14 06:40:42
Please let me know if anything unusual turns up in either of the logs.
Thanks,
Mike D
Offline Paddy
« Reply #11 on: September 09, 2008, 06:18:04 PM »
I suspect we would need to see a fresh HjT logfile that one you posted is out
of date..
HijackThis
Also a fresh logfile from Malwarebytes' Anti-Malware, be sure to update the programe
before you scan please...
numbnuts...
