Kerio Control 7.0.0 Build 896 Released06.01.2010Whats New:+ New Intrusion Prevention System (IPS/IDS)
+ Added MAC Filter
+ Multiple IP addresses on an adapter
* License counting and policy changed
* Rebranding
+ DHCP scopes autoconfiguration (only available in the Kerio Control Administration web interface)
* McAfee Antivirus engine replaced by the new Sophos engine
+ VMware Virtual Appliance available in OVF format
+ Kerio Control Software Appliance: Added SCSI HDD drivers
+ Kerio Control Software Appliance: Added E100 network drivers
+ Kerio Control Software Appliance: Fixed 'winroute blocked for more than 120 seconds' error
+ Kerio Control Administration web interface: DHCP screen added
+ Kerio Control Administration web interface: Advanced Options screen added
+ Kerio Control Administration web interface: Logs viewer added
- Kerio Control Administration web interface: Fixed: Cannot set 0 MB/s as link bandwidth
- Kerio Control Administration web interface: Various design improvements and minor bug fixes
+ Kerio Administration Console: added link to WebFilter recategorization page
- Fixed: DNS forwarder does not work when WAN IP has been changed
- VPN Client for Mac: Fixed DNS problems on Snow Leopard
- VPN Client for Mac: Fixed: It was not possible to use some strong passwords
* Slovak localization was removed from administration interfaces
* Syslog: User cannot change Facility and Severity. These values are reset to Kerio defaults on upgrade. Check warning log after upgrade
* User cannot change paths to Control internal directories. These values are reset to Kerio defaults on upgrade. Check warning log after upgrade
* User cannot change paths to RAS before/after dial scripts. Kerio defined script names are used. Check warning log after upgrade
- Software Appliance: Fixed: Ctrl-C in Kerio Console can terminate Kerio Control
- Administration Console: Fixed: VPN IP Pool Dump crashes engine
- StaR: Fixed: Activity log was off by several hours in some time zones
- Fixed: Kerio Web Filter sometimes failed to categorize long URLs
- Fixed: NTLM authentication does not work if user name contains national characters
- Fixed: Random crash in login to Kerio Control Administration
- Added workaround in HTTP inspector for HTTP servers violating RFC by terminating headers with '0a 0a' (
https://www.katasterportal.sk)
- Fixed potential crash in communication with Domain Controller over LDAP
- Fixed potential memory corruption in HTTP protocol inspector
- Fixed: Kerio Control Software Appliance can crash if a lot of (20) IP addresses are configured on an interface
- Fixed: Kerio Control Software Appliance can crash if Safari browser authenticates using NTLM
More Info: Release History
Download: Kerio Firewall 7.0
Forums: Kerio Support
