Author Topic: Foxit Reader  (Read 6608 times)
Offline roddy32
  • Update Moderator
Foxit Reader
« on: January 12, 2007, 04:28:45 PM »
Foxit Reader 2.0 for Windows
Foxit Reader 2.0 is just released. This new version introduces many exciting features, including multi-language UI, dynamic downloading of add-ons, form filler, better look and feel and much more.
More information is here
http://www.foxitsoftware.com/pdf/rd_intro.php
Download is here
http://www.foxitsoftware.com/downloads/
Log'N'Rock Computer Security
Offline roddy32
  • Update Moderator
Re: Foxit Reader
« Reply #1 on: January 01, 2009, 12:22:09 PM »
Foxit Reader 3.0 Build 1301 released January 1, 2009
Fixed in Foxit Reader 3.0 Build 1301
A dead loop error appears when printing pages or a range of pages by entering 1, 3, 7-10, etc. in the Pages text box within the Print dialog box.
Symptoms: If you print pages or a range of pages by entering 1, 3, 7-10, etc. in the Pages text box within the Print dialog box with Foxit Reader 3.0 Build 1222, the printing doesn’t stop.
http://www.foxitsoftware.com/pdf/reader_2/bugfix.htm
More Info:
Download:
Existing users can update via the program updater
Re: Foxit Reader
« Reply #2 on: February 25, 2009, 07:28:58 PM »
Beware, it has been reported that the new version of Foxit Reader includes the ASK Toolbar.  See http://securitygarden.blogspot.com/2009/02/beware-foxit-reader-includes-asktoolbar.html
Offline roddy32
  • Update Moderator
Re: Foxit Reader
« Reply #3 on: February 27, 2009, 12:46:28 PM »
Thanks for the warning Corinne.
Not sure about the "new" installs" but the updates through the program itself has offered the "Foxit" toolbar among other things for quite some time. That is reported to be the ask.com toolbar but everything offered when you check for updates shows on the left side of the list. You highlight whatever you want on the list and click the arrow to put it on the right side and then click install so anyone that gets the toolbar doing it that way just hasn't paid attention to what they are doing.  :(
Offline MikeW
Re: Foxit Reader
« Reply #4 on: February 27, 2009, 02:36:55 PM »
I have not found any problems with the new installs. Like many other freeware apps the download of the toolbar is optional. As Roddy32 says after initial download any updates can be made within the program. I have been a long time user of Foxit and find it an excellent piece of software and its Free
XP Home SP3 IE8 Nis 2011 Mbam
Offline JonPaulOnLine
Re: Foxit Reader
« Reply #5 on: March 01, 2009, 03:23:30 AM »
Its only a matter of time the advertisers
will not have the funds to payout for the click'S related to the ASk toolbar,
because the world econony is in shambles and the money will dry up!
I expect many advertisers will go bankrupt in 2009
JonPaulOnLine
Offline roddy32
  • Update Moderator
Re: Foxit Reader
« Reply #6 on: March 09, 2009, 02:31:54 PM »
Foxit Reader V3.0 Build 1506 released March 9, 2009
Vulnerabilities Fixed:
    * Fixed the issue of stack-based buffer overflow.
° Foxit PDF files include actions associated with different triggers. If an action (Open/Execute a file, Open a web link, etc.) is defined in the PDF files with an overly long filename argument and the trigger condition is satisfied, it will cause a stack-based buffer overflow.
    * Fixed the issue of security authorization bypass.
° If an action (Open/Execute a file, Open a web link, etc.) is defined in the PDF files and the trigger condition is satisfied, Foxit Reader will do the action defined by the creator of the PDF file without popping up a dialog box to confirm.
    * Fixed the issue of JBIG2 Symbol Dictionary Processing
° While decoding a JBIG2 symbol dictionary segment, an array of 32-bit elements is allocated having a size equal to the number of exported symbols, but left uninitialised if the number of new symbols is zero. The array is later accessed and values from uninitialised memory are used as pointers when reading memory and performing calls.
Foxit Reader V2.3 Build 3902 is also available for users of that version
http://www.foxitsoftware.com/announcements/200939coAT.html
Download
Note; Make sure to UNcheck any unwanted toolbars offered if you don't want them.
Existing users can update via the program updater "Help>>>Check for updates
Offline roddy32
  • Update Moderator
Re: Foxit Reader
« Reply #7 on: October 17, 2009, 03:40:11 AM »
Foxit Reader 3.1.2.1013 released October 16, 2009
Fixed in Foxit Reader 3.1.2.1013
Fix the memory leak issue where the memory usage will continuously grow while viewing PDF files with Foxit Reader.
http://www.foxitsoftware.com/pdf/reader/bugfix.htm
Download
http://www.foxitsoftware.com/downloads/index.php
Offline roddy32
  • Update Moderator
Re: Foxit Reader
« Reply #8 on: November 06, 2009, 05:55:10 PM »
Foxit Reader 3.1.3.1030 released November 5, 2009
Fixed in Foxit Reader 3.1.3.1030
Fixed the issue in Foxit Reader 3.1.2.1013, where the text in PDF documents cannot be printed with specific printers.
Download
Offline roddy32
  • Update Moderator
Re: Foxit Reader
« Reply #9 on: February 22, 2010, 02:50:20 PM »
Foxit Reader 3.1.4.1125 released February 9, 2010
Fixed in Foxit Reader 3.1.4
   1. Now supports opening files containing special Unicode characters in filenames.
   2. Right-clicking the annotation with zoom tool will not popup annotation menu.
   3. When using the Commenting Tools, the color indicator will reflect your color selection.
   4. Now supports simultaneous viewing of multiple documents.
   5. Fixed the issue where some files display slowly in the print preview window.
   6. Fixed the issue where some pdf files cannot be opened in the correct positions.
Download
Offline roddy32
  • Update Moderator
Re: Foxit Reader
« Reply #10 on: March 12, 2010, 06:47:28 PM »
Foxit Reader 3.2.0303 released March 12, 2010
Fixed in Foxit Reader 3.2
   1. Better JavaScript support.
   2. Fixed the crash issue when double clicking to open certain PDFs.
   3. Fixed the issue where cannot correctly display the content copied from Text Viewer mode on popup dialog box.
   4. Better support saving PDF as text.
   5. Fixed the issue where pop multiple message boxes when clicking the bookmarks several times continuously.
   6. Fixed the issues where some PDF documents cannot be associated with Foxit Reader.
   7. Fixed the issue where space may disappear when copying text.
   8. Fixed the crash issue when occasional use of arrow keys on keyboard to turn pages.
   9. Fixed the issue where the text may not be highlighted.
  10. Fixed the issue where the text string starting with a space cannot be searched.
  11. Fixed the issue with vertical text selection and text highlight.
Download
Offline roddy32
  • Update Moderator
Re: Foxit Reader
« Reply #11 on: April 02, 2010, 09:34:30 PM »
Foxit Reader 3.2.1.0401 released April 2, 2010
Fixed in Foxit Reader 3.2.1.0401
   1. Fixed a security issue that Foxit Reader runs an executable embedded program inside a PDF automatically without asking for user’s permission.
Download
Offline roddy32
  • Update Moderator
Re: Foxit Reader
« Reply #12 on: September 29, 2010, 03:10:10 PM »
Foxit Reader v4.2.0 Build 0928 - September 29, 2010
New features:
    * Verify the digital signature
      Foxit Reader 4.2 now features a PDF digital signature verification technology which uses an enhanced, yet ISO 32000 compliant, verification process that ensures the signature is real and neither the document nor the signature have been compromised. This new verification process provides a secure and reliable platform for exchanging electronics documents without putting the user at risk from falsified documents.
    * Enhance security with ASLR & DEP support
      Foxit Reader 4.2 continues to add features that increase security by making it harder for hackers to compromise a PDF document. The current version of the reader includes Address Space Layout Randomization, ASLR, which uses a random algorithm to determine a memory address used to store key file data. A second security feature is Data Execution Prevention, DEP, which simply prevents executing code from a non-executable memory location. ASLR and DEP combine to highly improve Foxit Reader Security and provide a stable platform for enterprise, business and consumer, Foxit Reader users.
More information here
http://www.foxitsoftware.com/pdf/reader/reader4.php
Download
Note: Make sure to UNcheck any unwanted toolbars offered if you don't want them. They are not needed to use the program.
Offline roddy32
  • Update Moderator
Re: Foxit Reader
« Reply #13 on: November 16, 2010, 07:39:19 PM »
Foxit Reader v4.3.0.1110 - November 16, 2010
Foxit Reader 4.3 optimized the PDF reading technology. The new feature enables users to open a PDF Embedded in an HTML, giving users many advantages and flexibility when viewing PDF files.Foxit Reader 4.3 optimized the PDF reading technology. The new feature enables users to open a PDF Embedded in an HTML, giving users many advantages and flexibility when viewing PDF files.
Quote is from the program itself
Download
Offline roddy32
  • Update Moderator
Re: Foxit Reader
« Reply #14 on: February 24, 2011, 05:50:42 PM »
Foxit Reader v4.3.1.0218 - February 24, 2011
Fremont, CA, February 24, 2011 - Foxit Corporation, a leading provider of solutions for reading, editing, creating, organizing, and securing PDF documents, announces today�s maintenance patch for its popular Foxit Reader.
In its ongoing commitment of providing safer, faster and more stable PDF software tools, Foxit is taking a proactive measure in securing its 100 million PDF Reader users. Foxit PDF Reader 4.3.1.0218 fixes an issue which prevents the viewing of certain PDF documents caused by processing specific ICC profiles. An ICC profile is a set of data that describes the color attributes of a device or viewing requirement according to International Color Consortium (ICC) standards.
http://forums.foxitsoftware.com/showthread.php?27221-Foxit-Quickly-Reacts-To-Potential-User-Issue-With-The-Most-Reliable-PDF-Technology
Download
http://www.foxitsoftware.com/pdf/reader/addons.php
or
