Computer Woes
Started by Lonestar, June 09, 2010, 04:20:06 AM
Lonestar
Howdy LandzDown Gurus :lol:
   I've somehow become responsible for fixing the "better halfs" computer.  When we try to open any files windows askes to choose a program to open this file(ex: erunt,rootrepeal,rsit).  I was also unable to run AVG except for in safe mode, but I'm not certain I know what to do with the .txt file. Get misdirected when using search engines and I'm certain there's other issue.
  -  Windows XP SP3
  I would appreciate any help possible. Thanks in advance!
Hi, Lonestar.  Welcome to LandzDown Forum.
We will do our best to assist you.  However, in order to do so, please follow all instructions provided in the sequence given.  Do not install/re-install any programs or run any fixes or scanners that you have not been instructed to use.  This may cause conflicts with the tools being used in the cleanup process.
NOTE: If you are using IE and unable to download RKill, please do the following in order to proceed:
Disable Internet Explorer Proxy Settings
It is very important that these steps be carried out exactly as shown otherwise the fix will not work.
If you have any questions please ask before moving on.
  • Please start Notepad and using your mouse make sure you select and copy all the information below in the Code box into your new document.
  • Then save the file as "fixme.bat" to your Desktop
  • In the drop down box for Save as type: make sure you select All Files (*.*) and keep the quotes on the name as well.  Then close the new file.
@ECHO OFF
reg delete "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings" /v ProxyServer /f
reg delete "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings" /v ProxyOverride /f
reg add "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings" /v ProxyEnable  /t REG_DWORD /d 0 /f
reg add "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings" /v GlobalUserOffline /t REG_DWORD /d 0 /f
  • On Windows XP you can double-click the file to run it.
  • On Vista/Win7 you need to Right click the file and choose Run as administrator to run it.  With User Account Control on it should ask permission to run it.  Click Yes
  • This will flash a black DOS box very quickly and go away, this is normal.  Now relaunch Internet Explorer and see if you can connect to the Internet.
One, Two,Three or Four
  • Double-click rkill to run.
Notes:
  • At the end, be sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware, then click Finish.
  • Click Remove Selected.
  • When completed, a log will open in Notepad. Please save it to a convenient location. The log can also be found here on Windows XP: C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt and C:\Users\UserName\AppData\Roaming\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt on Windows Vista and Windows 7.
  • Please post contents of that file in your next reply and the RSIT logs.
Lonestar
Quote from: Corrine on June 09, 2010, 05:27:08 PM
  Corrine,  Thanks for the response. :thumbsup: I have downloaded erunt,rootrepeal,rsit and rkill on an external HD. Although I'm unable to open any files as windows is asking me to choose a program to open said file with.  Just relized I'm able to open files in safe mode. Should I follow the "Log Posting Instructions" in safe mode?
Hi, Lonestar.
Instead of Safe Mode, select Safe Mode with Networking. (To do this, turn your computer off and then back on and immediately when you see anything on the screen, start tapping the F8 key on your keyboard. Using the arrow keys on your keyboard, select Safe Mode with Networking and press Enter on your keyboard. Windows will now boot into safe mode with networking and prompt you to login as a user.)
Please start Internet Explorer, and when the program is open, do the following:
-- click on the Tools menu and then select Internet Options.
-- click on the Connections
-- click on the Lan Settings button tab
-- under the Proxy Server section, please uncheck the checkbox labeled "Use a proxy server for your LAN"
-- press the OK  button to close this screen. Then press the OK button to close the Internet Options screen.
Next, run RKill as instructed above, followed by MBAM and the RSIT logs.
Lonestar
RSIT LOG -
Logfile of random's system information tool 1.07 (written by
random/random)
Run by Administrator at 2010-06-09 14:43:51
Microsoft Windows XP Home Edition Service Pack 3
System drive C: has 6 GB (18%) free of 35 GB
Total RAM: 510 MB (61% free)
Scan saved at 2:55:25 PM, on 6/9/2010
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Safe mode with network support
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\NOTEPAD.EXE
C:\WINDOWS\explorer.exe
C:\Documents and Settings\Administrator\Desktop\RSIT.exe
C:\Program Files\trend micro\Administrator.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.dell4me.com/myway
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://channels.aimtoday.com/search/aimtoolbar.jsp
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://aimhome.netscape.com/aimhome.adp
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://us.rd.yahoo.com/customize/ie/defaults/sb/msgr8/*http://www.yahoo.com/ext/search/search.html
O1 - Hosts: 74.125.45.100 4-open-davinci.com
O1 - Hosts: 74.125.45.100 securitysoftwarepayments.com
O1 - Hosts: 74.125.45.100 privatesecuredpayments.com
O1 - Hosts: 74.125.45.100 secure.privatesecuredpayments.com
O1 - Hosts: 74.125.45.100 getantivirusplusnow.com
O1 - Hosts: 74.125.45.100 secure-plus-payments.com
O1 - Hosts: 74.125.45.100 www.getantivirusplusnow.com
O1 - Hosts: 74.125.45.100 www.secure-plus-payments.com
O1 - Hosts: 74.125.45.100 www.getavplusnow.com
O1 - Hosts: 74.125.45.100 safebrowsing-cache.google.com
O1 - Hosts: 74.125.45.100 urs.microsoft.com
O1 - Hosts: 74.125.45.100 www.securesoftwarebill.com
O1 - Hosts: 74.125.45.100 secure.paysecuresystem.com
O1 - Hosts: 74.125.45.100 paysoftbillsolution.com
O1 - Hosts: 74.125.45.100 protected.maxisoftwaremart.com
O1 - Hosts: 217.23.15.139 www.google.com
O1 - Hosts: 217.23.15.139 google.com
O1 - Hosts: 217.23.15.139 google.com.au
O1 - Hosts: 217.23.15.139 www.google.com.au
O1 - Hosts: 217.23.15.139 google.be
O1 - Hosts: 217.23.15.139 www.google.be
O1 - Hosts: 217.23.15.139 google.com.br
O1 - Hosts: 217.23.15.139 www.google.com.br
O1 - Hosts: 217.23.15.139 google.ca
O1 - Hosts: 217.23.15.139 www.google.ca
O1 - Hosts: 217.23.15.139 google.ch
O1 - Hosts: 217.23.15.139 www.google.ch
O1 - Hosts: 217.23.15.139 google.de
O1 - Hosts: 217.23.15.139 www.google.de
O1 - Hosts: 217.23.15.139 google.dk
O1 - Hosts: 217.23.15.139 www.google.dk
O1 - Hosts: 217.23.15.139 google.fr
O1 - Hosts: 217.23.15.139 www.google.fr
O1 - Hosts: 217.23.15.139 google.ie
O1 - Hosts: 217.23.15.139 www.google.ie
O1 - Hosts: 217.23.15.139 google.it
O1 - Hosts: 217.23.15.139 www.google.it
O1 - Hosts: 217.23.15.139 google.co.jp
O1 - Hosts: 217.23.15.139 www.google.co.jp
O1 - Hosts: 217.23.15.139 google.nl
O1 - Hosts: 217.23.15.139 www.google.nl
O1 - Hosts: 217.23.15.139 google.no
O1 - Hosts: 217.23.15.139 www.google.no
O1 - Hosts: 217.23.15.139 google.co.nz
O1 - Hosts: 217.23.15.139 www.google.co.nz
O1 - Hosts: 217.23.15.139 google.pl
O1 - Hosts: 217.23.15.139 www.google.pl
O1 - Hosts: 217.23.15.139 google.se
O1 - Hosts: 217.23.15.139 www.google.se
O1 - Hosts: 217.23.15.139 google.co.uk
O1 - Hosts: 217.23.15.139 www.google.co.uk
O1 - Hosts: 217.23.15.139 google.co.za
O1 - Hosts: 217.23.15.139 www.google.co.za
O1 - Hosts: 217.23.15.139 www.google-analytics.com
O1 - Hosts: 217.23.15.139 www.bing.com
O1 - Hosts: 217.23.15.139 search.yahoo.com
O1 - Hosts: 217.23.15.139 www.search.yahoo.com
O1 - Hosts: 217.23.15.139 uk.search.yahoo.com
O1 - Hosts: 217.23.15.139 ca.search.yahoo.com
O1 - Hosts: 217.23.15.139 de.search.yahoo.com
O1 - Hosts: 217.23.15.139 fr.search.yahoo.com
O1 - Hosts: 217.23.15.139 au.search.yahoo.com
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Documents and Settings\All Users\Application Data\Real\RealPlayer\BrowserRecordPlugin\IE\rpbrowserrecordplugin.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: DriveLetterAccess - {5CA3D70E-1895-11CF-8E15-001234567890} - C:\WINDOWS\system32\dla\tfswshx.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: Viewpoint Toolbar BHO - {A7327C09-B521-4EDB-8509-7D2660C9EC98} - C:\Program Files\Viewpoint\Viewpoint Toolbar\3.9.0\ViewBarBHO.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O2 - BHO: (no name) - {FDD3B846-8D59-4ffb-8758-209B6AD74ACC} - (no file)
O3 - Toolbar: Viewpoint Toolbar - {F8AD5AA5-D966-4667-9DAF-2561D68B2012} - C:\Program Files\Common Files\Viewpoint\Toolbar Runtime\3.9.0\IEViewBar.dll
O4 - HKLM\..\Run: [EPSON Stylus CX6600 Series (Copy 1)] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATI9EA.EXE /P35 "EPSON Stylus CX6600 Series (Copy 1)" /O5 "LPT1:" /M "Stylus CX6600"
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
O4 - HKLM\..\Run: [dellsupportcenter] "C:\Program Files\Dell Support Center\bin\sprtcmd.exe" /P dellsupportcenter
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe"  -osboot
O4 - HKLM\..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe
O4 - HKLM\..\Run: [QuickTime Task] "C:\PROGRAM FILES\QUICKTIME\QTTASK.EXE" -atboottime
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"
O4 - HKLM\..\Run: [Malwarebytes Anti-Malware (reboot)] "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
O8 - Extra context menu item: E&xport to Microsoft Excel - res://c:\PROGRA~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre6\bin\npjpi160_13.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre6\bin\npjpi160_13.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\OFFICE11\REFIEBAR.DLL
O10 - Unknown file in Winsock LSP: c:\windows\system32\nwprovau.dll
O16 - DPF: {01113300-3E00-11D2-8470-0060089874ED} (Support.com Configuration Class) - http://activation.rr.com/install/download/tgctlcm.cab
O16 - DPF: {6F750200-1362-4815-A476-88533DE61D0C} (Ofoto Upload Manager Class) - http://www.ofoto.com/downloads/BUM/BUM_WIN_IE_1/axofupld.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O20 - Winlogon Notify: avgrsstarter - avgrsstx.dll (file missing)
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\System32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\System32\browseui.dll
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: getPlus(R) Helper - NOS Microsystems Ltd. - C:\Program Files\NOS\bin\getPlus_HelperSvc.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: SiteAdvisor Service - Unknown owner - C:\Program Files\SiteAdvisor\4979\SAService.exe (file missing)
O23 - Service: SupportSoft Sprocket Service (dellsupportcenter) (sprtsvc_dellsupportcenter) - SupportSoft, Inc. - C:\Program Files\Dell Support Center\bin\sprtsvc.exe
O23 - Service: Viewpoint Manager Service - Viewpoint Corporation - C:\Program Files\Viewpoint\Common\ViewpointService.exe
End of file - 9415 bytes
C:\WINDOWS\tasks\AppleSoftwareUpdate.job
C:\WINDOWS\tasks\McDefragTask.job
C:\WINDOWS\tasks\McQcTask.job
C:\WINDOWS\tasks\RealUpgradeLogonTaskS-1-5-21-3111913734-1917848367-1923497382-1008.job
C:\WINDOWS\tasks\RealUpgradeScheduledTaskS-1-5-21-3111913734-1917848367-1923497382-1008.job
======Registry dump======
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}]
Adobe PDF Reader Link Helper - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll [2006-12-18 59032]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3049C3E9-B461-4BC5-8870-4C09146192CA}]
RealPlayer Download and Record Plugin for Internet Explorer - C:\Documents and Settings\All Users\Application Data\Real\RealPlayer\BrowserRecordPlugin\IE\rpbrowserrecordplugin.dll [2010-03-20 341600]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}]
AVG Safe Search - C:\Program Files\AVG\AVG8\avgssie.dll [2009-12-12 1111320]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5CA3D70E-1895-11CF-8E15-001234567890}]
DriveLetterAccess - C:\WINDOWS\system32\dla\tfswshx.dll [2004-03-15 118836]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{761497BB-D6F0-462C-B6EB-D4DAF1D92D43}]
SSVHelper Class - C:\Program Files\Java\jre6\bin\ssv.dll [2009-03-09 320920]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{A7327C09-B521-4EDB-8509-7D2660C9EC98}]
Viewpoint Toolbar BHO - C:\Program Files\Viewpoint\Viewpoint Toolbar\3.9.0\ViewBarBHO.dll [2009-03-02 38320]
Java(tm) Plug-In 2 SSV Helper - C:\Program Files\Java\jre6\bin\jp2ssv.dll [2009-03-09 35840]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{E7E6F031-17CE-4C07-BC86-EABFE594F69C}]
JQSIEStartDetectorImpl Class - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll [2009-03-09 73728]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{FDD3B846-8D59-4ffb-8758-209B6AD74ACC}]
{F8AD5AA5-D966-4667-9DAF-2561D68B2012} - Viewpoint Toolbar - C:\Program Files\Common Files\Viewpoint\Toolbar Runtime\3.9.0\IEViewBar.dll [2009-03-02 333208]
"EPSON Stylus CX6600 Series (Copy 1)"=C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATI9EA.EXE [2004-02-29 98304]
"MSConfig"=C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe [2008-04-13 169984]
"dellsupportcenter"=C:\Program Files\Dell Support Center\bin\sprtcmd.exe [2009-05-21 206064]
"TkBellExe"=C:\Program Files\Common Files\Real\Update_OB\realsched.exe [2010-03-20 202256]
"AppleSyncNotifier"=C:\Program Files\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe [2010-03-16 47392]
"QuickTime Task"=C:\PROGRAM FILES\QUICKTIME\QTTASK.EXE [2010-03-17 421888]
"iTunesHelper"=C:\Program Files\iTunes\iTunesHelper.exe [2010-03-26 142120]
"SunJavaUpdateSched"=C:\Program Files\Java\jre6\bin\jusched.exe [2009-03-09 148888]
"Malwarebytes Anti-Malware (reboot)"=C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe [2010-04-29 1090952]
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunOnce]
"Malwarebytes' Anti-Malware"=C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe [2010-04-29 437584]
"ctfmon.exe"=C:\WINDOWS\system32\ctfmon.exe [2008-04-13 15360]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Aim6]
C:\Program Files\AIM6\aim6.exe /d locale=en-US ee://aol/imApp []
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\AVG8_TRAY]
C:\PROGRA~1\AVG\AVG8\avgtray.exe [2010-03-18 2046816]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ctfmon.exe]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\DellSupportCenter]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\dla]
C:\WINDOWS\system32\dla\tfswctrl.exe [2004-03-15 122933]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\dscactivate]
C:\Program Files\Dell Support Center\gs_agent\custom\dsca.exe [2007-11-15 16384]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\DVDLauncher]
C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe [2004-04-11 53248]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\EPSON Stylus CX6600 Series]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HotKeysCmds]
C:\WINDOWS\system32\hkcmd.exe [2005-10-19 126976]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IgfxTray]
C:\WINDOWS\system32\igfxtray.exe [2005-10-19 155648]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\mmtask]
C:\Program Files\MUSICMATCH\Musicmatch Jukebox\mmtask.exe [2005-03-15 53248]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSMSGS]
C:\Program Files\Messenger\msmsgs.exe [2008-04-13 1695232]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\PCMService]
C:\Program Files\Dell\Media Experience\PCMService.exe [2004-04-11 290816]
C:\Program Files\QuickTime\QTTask.exe [2010-03-17 421888]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RealTray]
C:\Program Files\Real\RealPlayer\RealPlay.exe [2010-03-20 488968]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SiteAdvisor]
C:\Program Files\SiteAdvisor\4979\SiteAdv.exe []
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SunJavaUpdateSched]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\tgcmd]
C:\Program Files\support.com\bin\tgcmd.exe [2003-02-28 1843200]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\UpdateManager]
C:\Program Files\Common Files\Sonic\Update Manager\sgtray.exe [2003-08-19 110592]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Weather]
C:\Program Files\AWS\WeatherBug\Weather.exe [2009-01-30 1347584]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\WildTangent CDA]
C:\Program Files\WildTangent\Apps\CDA\cdaEngine0400.dll,cdaEngineMain []
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Reader Speed Launch.lnk]
C:\PROGRA~1\Adobe\ACROBA~2.0\Reader\READER~1.EXE [2008-04-23 29696]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\avgrsstarter]
C:\WINDOWS\system32\avgrsstx.dll [2009-08-19 11952]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\igfxcui]
C:\WINDOWS\system32\igfxsrvc.dll [2005-10-19 348160]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\WgaLogon]
C:\WINDOWS\system32\WgaLogon.dll [2007-03-15 236928]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\UploadMgr]
"dontdisplaylastusername"=0
"legalnoticecaption"=
"legalnoticetext"=
"shutdownwithoutlogon"=1
"undockwithoutlogon"=1
"NoDriveTypeAutoRun"=145
"HonorAutoRunSetting"=
"%windir%\system32\sessmgr.exe"="%windir%\system32\sessmgr.exe:*:enabled:@xpsp2res.dll,-22019"
"C:\Program Files\America Online 9.0\waol.exe"="C:\Program Files\America Online 9.0\waol.exe:*:Enabled:America Online 9.0"
"C:\Program Files\Common Files\AOL\1126058485\ee\AOLServiceHost.exe"="C:\Program Files\Common Files\AOL\1126058485\ee\AOLServiceHost.exe:*:Enabled:AOL Services"
"C:\Program Files\Common Files\AOL\Loader\aolload.exe"="C:\Program Files\Common Files\AOL\Loader\aolload.exe:*:Enabled:AOL Loader"
"C:\Program Files\Internet Explorer\iexplore.exe"="C:\Program Files\Internet Explorer\iexplore.exe:*:Enabled:Internet Explorer"
"C:\Program Files\Real\RealPlayer\realplay.exe"="C:\Program Files\Real\RealPlayer\realplay.exe:*:Enabled:RealPlayer"
"C:\Program Files\AIM\aim.exe"="C:\Program Files\AIM\aim.exe:*:Enabled:AOL Instant Messenger"
"%windir%\Network Diagnostic\xpnetdiag.exe"="%windir%\Network Diagnostic\xpnetdiag.exe:*:Enabled:@xpsp3res.dll,-20000"
"C:\Program Files\Common Files\McAfee\MNA\McNASvc.exe"="C:\Program Files\Common Files\McAfee\MNA\McNASvc.exe:*:Enabled:McAfee Network Agent"
"C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe"="C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe:*:Enabled:Yahoo! Messenger"
"C:\Program Files\Yahoo!\Messenger\YServer.exe"="C:\Program Files\Yahoo!\Messenger\YServer.exe:*:Enabled:Yahoo! FT Server"
"C:\Program Files\LimeWire\LimeWire.exe"="C:\Program Files\LimeWire\LimeWire.exe:*:Enabled:LimeWire"
"C:\Program Files\Mozilla Firefox\firefox.exe"="C:\Program Files\Mozilla Firefox\firefox.exe:*:Enabled:Mozilla Firefox"
"C:\Program Files\ABBYY FineReader 5.0 Sprint\Sprint.exe"="C:\Program Files\ABBYY FineReader 5.0 Sprint\Sprint.exe:*:Enabled:ABBYY FineReader 5.0 Sprint Plus"
"C:\WINDOWS\SYSTEM32\ZoneLabs\vsmon.exe"="C:\WINDOWS\SYSTEM32\ZoneLabs\vsmon.exe:*:Enabled:TrueVector Service"
"C:\Program Files\AVG\AVG8\avgupd.exe"="C:\Program Files\AVG\AVG8\avgupd.exe:*:Enabled:avgupd.exe"
"C:\Program Files\AIM6\aim6.exe"="C:\Program Files\AIM6\aim6.exe:*:Enabled:AIM"
"C:\WINDOWS\Temp\occ.exe"="C:\WINDOWS\Temp\occ.exe:*:Enabled:OneCC Module"
"C:\Program Files\Bonjour\mDNSResponder.exe"="C:\Program Files\Bonjour\mDNSResponder.exe:*:Enabled:Bonjour Service"
"C:\Program Files\iTunes\iTunes.exe"="C:\Program Files\iTunes\iTunes.exe:*:Enabled:iTunes"
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\E]
shell\AutoRun\command - wd_windows_tools\WDEULA.exe
======List of files/folders created in the last 1 months======
2010-06-09 14:43:52 ----D---- C:\Program Files\trend micro
2010-06-09 14:43:51 ----D---- C:\rsit
2010-06-09 14:12:09 ----D---- C:\Documents and Settings\Administrator\Application Data\Malwarebytes
2010-06-09 14:11:59 ----D---- C:\Program Files\Malwarebytes' Anti-Malware
2010-06-09 14:11:59 ----D---- C:\Documents and Settings\All Users\Application Data\Malwarebytes
2010-06-09 14:03:12 ----D---- C:\Documents and Settings\Administrator\Application Data\Macromedia
2010-06-09 14:03:12 ----D---- C:\Documents and Settings\Administrator\Application Data\Adobe
2010-06-08 21:26:10 ----RHD---- C:\Documents and Settings\Administrator\Application Data\yahoo!
2010-06-08 19:04:02 ----ASH---- C:\Documents and Settings\Administrator\Application Data\DESKTOP.INI
2010-06-08 19:03:25 ----SD---- C:\Documents and Settings\Administrator\Application Data\Microsoft
2010-06-08 19:03:25 ----D---- C:\Documents and Settings\Administrator\Application Data\Sun
2010-06-08 19:03:25 ----D---- C:\Documents and Settings\Administrator\Application Data\Sonic
2010-06-08 19:03:25 ----D---- C:\Documents and Settings\Administrator\Application Data\Jasc Software Inc
2010-06-08 19:03:25 ----D---- C:\Documents and Settings\Administrator\Application Data\Identities
2010-06-08 19:02:53 ----A---- C:\WINDOWS\ntbtlog.txt
2010-06-08 15:49:07 ----A---- C:\WINDOWS\system32\hidserv.dll
2010-05-28 19:09:34 ----A---- C:\WINDOWS\system32\MRT.exe
2010-05-28 19:07:33 ----HDC---- C:\WINDOWS\$NtUninstallKB981793$
2010-05-28 19:07:21 ----HDC---- C:\WINDOWS\$NtUninstallKB978542$
======List of files/folders modified in the last 1 months======
2010-06-09 14:27:55 ----A---- C:\WINDOWS\SchedLgU.Txt
2010-06-09 14:27:07 ----AD---- C:\WINDOWS\system32\DRIVERS
2010-06-09 14:01:29 ----D---- C:\WINDOWS\system32\CatRoot2
2010-06-08 22:15:01 ----SD---- C:\WINDOWS\Tasks
2010-06-08 21:48:34 ----D---- C:\WINDOWS\Prefetch
2010-06-08 21:29:55 ----D---- C:\WINDOWS\Temp
2010-06-08 21:28:49 ----A---- C:\WINDOWS\ModemLog_Conexant D850 56K V.9x DFVc Modem.txt
2010-06-08 21:26:30 ----D---- C:\Program Files\Yahoo!
2010-06-08 21:26:10 ----D---- C:\Documents and Settings\All Users\Application Data\yahoo!
2010-06-08 21:25:45 ----AD---- C:\WINDOWS
2010-06-08 21:24:33 ----D---- C:\Program Files\IrfanView
2010-06-08 21:24:18 ----D---- C:\Program Files\Common Files
2010-06-08 21:21:57 ----AD---- C:\WINDOWS\SYSTEM32
2010-06-08 21:21:04 ----D---- C:\Program Files\Common Files\AOL
2010-06-08 21:20:57 ----D---- C:\Documents and Settings\All Users\Application Data\AOL
2010-06-08 21:14:41 ----SD---- C:\WINDOWS\Downloaded Program Files
2010-06-08 21:13:04 ----SHD---- C:\RECYCLER
2010-06-08 19:03:23 ----D---- C:\Documents and Settings
2010-06-08 15:49:12 ----RSHD---- C:\WINDOWS\system32\DLLCACHE
2010-06-08 15:48:38 ----HD---- C:\WINDOWS\INF
2010-06-01 06:42:29 ----HD---- C:\$AVG8.VAULT$
2010-05-28 19:16:33 ----D---- C:\Config.Msi
2010-05-28 19:16:32 ----SHD---- C:\WINDOWS\Installer
2010-05-28 19:07:31 ----A---- C:\WINDOWS\imsins.BAK
2010-05-28 19:07:24 ----D---- C:\Program Files\Outlook Express
2010-05-28 18:59:45 ----HD---- C:\WINDOWS\$hf_mig$
R1 omci;OMCI WDM Device Driver; C:\WINDOWS\System32\DRIVERS\omci.sys [2002-11-08 17217]
R1 sscdbhk5;sscdbhk5; C:\WINDOWS\system32\drivers\sscdbhk5.sys [2004-01-14 5621]
R1 ssrtln;ssrtln; C:\WINDOWS\system32\drivers\ssrtln.sys [2004-01-14 23219]
R3 bcm4sbxp;Broadcom 440x 10/100 Integrated Controller XP Driver; C:\WINDOWS\System32\DRIVERS\bcm4sbxp.sys [2003-05-23 43136]
R3 GEARAspiWDM;GEAR ASPI Filter Driver; C:\WINDOWS\System32\Drivers\GEARAspiWDM.sys [2009-05-18 26600]
R3 HidUsb;Microsoft HID Class Driver; C:\WINDOWS\system32\DRIVERS\hidusb.sys [2008-04-13 10368]
R3 mouhid;Mouse HID Driver; C:\WINDOWS\System32\DRIVERS\mouhid.sys [2001-08-17 12160]
R3 usbccgp;Microsoft USB Generic Parent Driver; C:\WINDOWS\System32\DRIVERS\usbccgp.sys [2008-04-13 32128]
R3 usbehci;Microsoft USB 2.0 Enhanced Host Controller Miniport Driver; C:\WINDOWS\System32\DRIVERS\usbehci.sys [2008-04-13 30208]
R3 usbhub;USB2 Enabled Hub; C:\WINDOWS\System32\DRIVERS\usbhub.sys [2008-04-13 59520]
R3 USBSTOR;USB Mass Storage Driver; C:\WINDOWS\System32\DRIVERS\USBSTOR.SYS [2008-04-13 26368]
R3 usbuhci;Microsoft USB Universal Host Controller Miniport Driver; C:\WINDOWS\System32\DRIVERS\usbuhci.sys [2008-04-13 20608]
S1 AvgLdx86;AVG Free AVI Loader Driver x86; C:\WINDOWS\System32\Drivers\avgldx86.sys [2009-08-19 335240]
S1 AvgMfx86;AVG Free On-access Scanner Minifilter Driver x86; C:\WINDOWS\System32\Drivers\avgmfx86.sys [2009-08-19 27784]
S1 intelppm;Intel Processor Driver; C:\WINDOWS\System32\DRIVERS\intelppm.sys [2008-04-13 36352]
S1 P3;Intel PentiumIII Processor Driver; C:\WINDOWS\System32\DRIVERS\p3.sys [2008-04-13 42752]
S2 drvnddm;drvnddm; C:\WINDOWS\system32\drivers\drvnddm.sys [2004-02-27 40480]
S2 mdmxsdk;mdmxsdk; C:\WINDOWS\System32\DRIVERS\mdmxsdk.sys [2003-04-09 11043]
S2 NwlnkIpx;NWLink IPX/SPX/NetBIOS Compatible Transport Protocol; C:\WINDOWS\System32\DRIVERS\nwlnkipx.sys [2008-04-13 88320]
S2 NwlnkNb;NWLink NetBIOS; C:\WINDOWS\System32\DRIVERS\nwlnknb.sys [2002-08-29 63232]
S2 NwlnkSpx;NWLink SPX/SPXII Protocol; C:\WINDOWS\System32\DRIVERS\nwlnkspx.sys [2002-08-29 55936]
S2 tfsnboio;tfsnboio; C:\WINDOWS\system32\dla\tfsnboio.sys [2004-03-15 25685]
S2 tfsncofs;tfsncofs; C:\WINDOWS\system32\dla\tfsncofs.sys [2004-03-15 34837]
S2 tfsndrct;tfsndrct; C:\WINDOWS\system32\dla\tfsndrct.sys [2004-03-15 4117]
S2 tfsndres;tfsndres; C:\WINDOWS\system32\dla\tfsndres.sys [2004-03-15 2233]
S2 tfsnifs;tfsnifs; C:\WINDOWS\system32\dla\tfsnifs.sys [2004-03-15 85972]
S2 tfsnopio;tfsnopio; C:\WINDOWS\system32\dla\tfsnopio.sys [2004-03-15 14229]
S2 tfsnpool;tfsnpool; C:\WINDOWS\system32\dla\tfsnpool.sys [2004-03-15 6357]
S2 tfsnudf;tfsnudf; C:\WINDOWS\system32\dla\tfsnudf.sys [2004-03-15 98580]
S2 tfsnudfa;tfsnudfa; C:\WINDOWS\system32\dla\tfsnudfa.sys [2004-03-15 100597]
S3 aeaudio;aeaudio; C:\WINDOWS\system32\drivers\aeaudio.sys [2002-04-01 4816]
S3 ati2mtag;ati2mtag; C:\WINDOWS\System32\DRIVERS\ati2mtag.sys [2004-08-03 701440]
S3 BrScnUsb;Brother USB Still Image driver; C:\WINDOWS\system32\DRIVERS\BrScnUsb.sys [2004-10-14 15295]
S3 BrSerIf;Brother MFC Serial Port Interface WDM Driver; C:\WINDOWS\System32\Drivers\BrSerIf.sys [2006-01-18 53248]
S3 BrUsbSer;Brother MFC USB Serial WDM Driver; C:\WINDOWS\System32\Drivers\BrUsbSer.sys [2006-01-18 11904]
S3 bvrp_pci;bvrp_pci; C:\WINDOWS\system32\drivers\bvrp_pci.sys []
S3 EL90XBC;3Com EtherLink XL 90XB/C Adapter Driver; C:\WINDOWS\System32\DRIVERS\el90xbc5.sys [2001-08-17 66591]
S3 HSF_DP;HSF_DP; C:\WINDOWS\System32\DRIVERS\HSF_DP.sys [2003-11-17 1042432]
S3 HSFHWBS2;HSFHWBS2; C:\WINDOWS\System32\DRIVERS\HSFHWBS2.sys [2003-11-17 212224]
S3 i81x;i81x; C:\WINDOWS\System32\DRIVERS\i81xnt5.sys [2004-08-03 161020]
S3 iAimFP0;iAimFP0; C:\WINDOWS\System32\DRIVERS\wADV01nt.sys [2004-08-03 12415]
S3 iAimFP1;iAimFP1; C:\WINDOWS\System32\DRIVERS\wADV02NT.sys [2004-08-03 12127]
S3 iAimFP2;iAimFP2; C:\WINDOWS\System32\DRIVERS\wADV05NT.sys [2004-08-03 11775]
S3 iAimFP3;iAimFP3; C:\WINDOWS\System32\DRIVERS\wSiINTxx.sys [2004-08-03 12063]
S3 iAimFP4;iAimFP4; C:\WINDOWS\System32\DRIVERS\wVchNTxx.sys [2004-08-03 19455]
S3 iAimTV0;iAimTV0; C:\WINDOWS\System32\DRIVERS\wATV01nt.sys [2004-08-03 29311]
S3 iAimTV1;iAimTV1; C:\WINDOWS\System32\DRIVERS\wATV02NT.sys [2004-08-03 19551]
S3 iAimTV2;iAimTV2; C:\WINDOWS\System32\DRIVERS\wATV03nt.sys []
S3 iAimTV3;iAimTV3; C:\WINDOWS\System32\DRIVERS\wATV04nt.sys [2004-08-03 33599]
S3 iAimTV4;iAimTV4; C:\WINDOWS\System32\DRIVERS\wCh7xxNT.sys [2004-08-03 23615]
S3 ialm;ialm; C:\WINDOWS\System32\DRIVERS\ialmnt5.sys [2005-10-19 807998]
S3 MODEMCSA;Unimodem Streaming Filter Device; C:\WINDOWS\system32\drivers\MODEMCSA.sys [2001-08-17 16128]
S3 nv;nv; C:\WINDOWS\System32\DRIVERS\nv4_mini.sys [2004-08-03 1897408]
S3 smwdm;smwdm; C:\WINDOWS\system32\drivers\smwdm.sys [2003-11-18 591808]
S3 USBAAPL;Apple Mobile USB Driver; C:\WINDOWS\System32\Drivers\usbaapl.sys [2009-10-16 41472]
S3 usbprint;Microsoft USB PRINTER Class; C:\WINDOWS\System32\DRIVERS\usbprint.sys [2008-04-13 25856]
S3 usbscan;USB Scanner Driver; C:\WINDOWS\System32\DRIVERS\usbscan.sys [2008-04-13 15104]
S3 wanatw;WAN Miniport (ATW); C:\WINDOWS\System32\DRIVERS\wanatw4.sys []
S3 winachsf;winachsf; C:\WINDOWS\System32\DRIVERS\HSF_CNXT.sys [2003-11-17 680704]
S4 agp440;Intel AGP Bus Filter; C:\WINDOWS\System32\DRIVERS\agp440.sys [2008-04-13 42368]
S4 agpCPQ;Compaq AGP Bus Filter; C:\WINDOWS\System32\DRIVERS\agpCPQ.sys [2008-04-13 44928]
S4 alim1541;ALI AGP Bus Filter; C:\WINDOWS\System32\DRIVERS\alim1541.sys [2008-04-13 42752]
S4 amdagp;AMD AGP Bus Filter Driver; C:\WINDOWS\System32\DRIVERS\amdagp.sys [2008-04-13 43008]
S4 cbidf;cbidf; C:\WINDOWS\System32\DRIVERS\cbidf2k.sys [2001-08-17 13952]
S4 IntelIde;IntelIde; C:\WINDOWS\System32\DRIVERS\intelide.sys [2008-04-13 5504]
S4 sisagp;SIS AGP Bus Filter; C:\WINDOWS\System32\DRIVERS\sisagp.sys [2008-04-13 40960]
S4 viaagp;VIA AGP Bus Filter; C:\WINDOWS\System32\DRIVERS\viaagp.sys [2008-04-13 42240]
S2 Apple Mobile Device;Apple Mobile Device; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [2010-03-19 144672]
S2 avg8wd;AVG Free8 WatchDog; C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe [2009-08-19 297752]
S2 Bonjour Service;Bonjour Service; C:\Program Files\Bonjour\mDNSResponder.exe [2010-02-12 345376]
S2 Fax;Fax; C:\WINDOWS\system32\fxssvc.exe [2008-04-13 267776]
S2 JavaQuickStarterService;Java Quick Starter; C:\Program Files\Java\jre6\bin\jqs.exe [2009-03-09 152984]
S2 MDM;Machine Debug Manager; C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE [2003-06-19 322120]
S2 NwSapAgent;SAP Agent; C:\WINDOWS\System32\svchost.exe [2008-04-13 14336]
S2 SiteAdvisor Service;SiteAdvisor Service; C:\Program Files\SiteAdvisor\4979\SAService.exe []
S2 sprtsvc_dellsupportcenter;SupportSoft Sprocket Service (dellsupportcenter); C:\Program Files\Dell Support Center\bin\sprtsvc.exe [2008-08-13 201968]
S2 UMWdf;Windows User Mode Driver Framework; C:\WINDOWS\system32\wdfmgr.exe [2004-08-11 38912]
S2 Viewpoint Manager Service;Viewpoint Manager Service; C:\Program Files\Viewpoint\Common\ViewpointService.exe [2008-09-08 24652]
S3 aspnet_state;ASP.NET State Service; C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\aspnet_state.exe [2004-07-15 32768]
S3 getPlus(R) Helper;getPlus(R) Helper; C:\Program Files\NOS\bin\getPlus_HelperSvc.exe [2009-03-03 33176]
S3 IDriverT;InstallDriver Table Manager; C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe [2005-04-04 69632]
S3 iPod Service;iPod Service; C:\Program Files\iPod\bin\iPodService.exe [2010-03-26 545576]
S3 ose;Office Source Engine; C:\Program Files\Common Files\Microsoft Shared\Source Engine\OSE.EXE [2003-07-28 89136]
Lonestar
RSIT INFO -
info.txt logfile of random's system information tool 1.06 2010-06-09 14:55:29
======Uninstall list======
-->C:\WINDOWS\IsUninst.exe -fC:\WINDOWS\orun32.isu
-->C:\WINDOWS\System32\\MSIEXEC.EXE /I {09DA4F91-2A09-4232-AB8C-6BC740096DE3} REMOVE=UpdateMgrFeature
-->C:\WINDOWS\System32\\MSIEXEC.EXE /x {1206EF92-2E83-4859-ACCB-2048C3CB7DA6}
-->C:\WINDOWS\System32\\MSIEXEC.EXE /x {9541FED0-327F-4df0-8B96-EF57EF622F19}
-->rundll32.exe setupapi.dll,InstallHinfSection DefaultUninstall 132 C:\WINDOWS\INF\PCHealth.inf
Adobe Flash Player 10 ActiveX-->C:\WINDOWS\system32\Macromed\Flash\uninstall_activeX.exe
Adobe Flash Player 10 Plugin-->C:\WINDOWS\system32\Macromed\Flash\uninstall_plugin.exe
Adobe Reader 7.1.0-->MsiExec.exe /I{AC76BA86-7AD7-1033-7B44-A71000000002}
Apple Application Support-->MsiExec.exe /I{553255F3-78FD-40F1-A6F8-6882140265FE}
Apple Mobile Device Support-->MsiExec.exe /I{B5C3B892-0849-476C-9F46-B12F84819D57}
Apple Software Update-->MsiExec.exe /I{6956856F-B6B3-4BE0-BA0B-8F495BE32033}
AVG 8.5-->C:\Program Files\AVG\AVG8\setup.exe /UNINSTALL
Bonjour-->MsiExec.exe /X{76BC2442-0002-47FA-9617-43BAD82BEF4C}
Broadcom Management Programs-->C:\PROGRA~1\COMMON~1\INSTAL~1\Driver\7\INTEL3~1\IDriver.exe /M{89EE857B-8970-4F9F-AB58-A1C873AC72B3} /l1033
Conexant D850 56K V.9x DFVc Modem-->C:\Program Files\CONEXANT\CNXT_MODEM_PCI_VEN_14F1&DEV_2F20&SUBSYS_200F14F1\HXFSETUP.EXE -U -Idel200fk.inf
Data Access Objects (DAO) 3.5-->C:\Program Files\Common Files\Microsoft Shared\DAO\Remove.EXE C:\WINDOWS\UNINST.EXE -fC:\PROGRA~1\COMMON~1\MICROS~1\DAO\DeIsL1.isu
Dell Driver Reset Tool-->MsiExec.exe /I{5905F42D-3F5F-4916-ADA6-94A3646AEE76}
Dell Media Experience-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{2637C347-9DAD-11D6-9EA2-00055D0CA761}\setup.exe"  -uninstall
Dell Solution Center-->MsiExec.exe /X{11F1920A-56A2-4642-B6E0-3B31A12C9288}
Dell Support Center (Support Software)-->MsiExec.exe /X{E3BFEE55-39E2-4BE0-B966-89FE583822C1}
Easy Chef's Million Recipes-->C:\CB45\UNWISE.EXE C:\CB45\INSTALL.LOG
getPlus(R) for Adobe-->"C:\Program Files\NOS\bin\getPlus_HelperSvc.exe" /UninstallGet1
Hotfix for Windows Internet Explorer 7 (KB947864)-->"C:\WINDOWS\ie7updates\KB947864-IE7\spuninst\spuninst.exe"
Hotfix for Windows XP (KB952287)-->"C:\WINDOWS\$NtUninstallKB952287$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB970653-v3)-->"C:\WINDOWS\$NtUninstallKB970653-v3$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB976098-v2)-->"C:\WINDOWS\$NtUninstallKB976098-v2$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB979306)-->"C:\WINDOWS\$NtUninstallKB979306$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB981793)-->"C:\WINDOWS\$NtUninstallKB981793$\spuninst\spuninst.exe"
Intel(R) Extreme Graphics Driver-->RUNDLL32.EXE C:\WINDOWS\system32\ialmrem.dll,UninstallW2KIGfx PCI\VEN_8086&DEV_2562
Internet Explorer Default Page-->MsiExec.exe /I{35BDEFF1-A610-4956-A00D-15453C116395}
iTunes-->MsiExec.exe /I{996A2FAA-7514-4628-9D12-A8FC34A0016E}
J2SE Runtime Environment 5.0 Update 11-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0150110}
Jasc Paint Shop Photo Album-->MsiExec.exe /I{CC000127-5E5D-4A1C-90CB-EEAAAC1E3AC0}
Jasc Paint Shop Pro 8 Dell Edition-->MsiExec.exe /I{81A34902-9D0B-4920-A25C-4CDC5D14B328}
Java 2 Runtime Environment, SE v1.4.2_03-->MsiExec.exe /I{7148F0A8-6813-11D6-A77B-00B0D0142030}
Java(TM) 6 Update 13-->MsiExec.exe /X{26A24AE4-039D-4CA4-87B4-2F83216011FF}
Jigs@w Puzzle-->C:\WINDOWS\tbuninst2.exe C:\Program Files\Jigs@w Puzzle\dezo.usc
Learn2 Player (Uninstall Only)-->C:\Program Files\Learn2.com\StRunner\stuninst.exe
Malwarebytes' Anti-Malware-->"C:\Program Files\Malwarebytes' Anti-Malware\unins000.exe"
Microsoft .NET Framework 1.1 Security Update (KB953297)-->"C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Updates\hotfix.exe" "C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Updates\M953297\M953297Uninstall.msp"
Microsoft .NET Framework 1.1-->msiexec.exe /X {CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}
Microsoft .NET Framework 1.1-->MsiExec.exe /X{CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}
Microsoft Internationalized Domain Names Mitigation APIs-->"C:\WINDOWS\$NtServicePackUninstallIDNMitigationAPIs$\spuninst\spuninst.exe"
Microsoft Money 2004 System Pack-->MsiExec.exe /I{8C64E145-54BA-11D6-91B1-00500462BE80}
Microsoft Money 2004-->MsiExec.exe /I{1D643CD7-4DD6-11D7-A4E0-000874180BB3}
Microsoft National Language Support Downlevel APIs-->"C:\WINDOWS\$NtServicePackUninstallNLSDownlevelMapping$\spuninst\spuninst.exe"
Microsoft Office Standard Edition 2003-->MsiExec.exe /I{91120409-6000-11D3-8CFE-0150048383C9}
Microsoft Silverlight-->MsiExec.exe /X{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}
Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053-->MsiExec.exe /X{770657D0-A123-3C07-8E44-1C83EC895118}
Microsoft Visual C++ 2005 Redistributable-->MsiExec.exe /X{7299052b-02a4-4627-81f2-1818da5d550d}
MobileMe Control Panel-->MsiExec.exe /I{51F96AEC-D902-4434-A0DC-B9692A21AE7C}
Modem Helper-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{7F142D56-3326-11D5-B229-002078017FBF}\setup.exe" -l0x9 ControlPanel
Musicmatch® Jukebox-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{8EF1122E-E90C-4EE9-AB0C-7FDE2BA42C26}\setup.exe" -l0x9  -uninst
NetWaiting-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{3F92ABBB-6BBF-11D5-B229-002078017FBF}\setup.exe" -l0x9 ControlPanelAnyText
Ofoto Easy Upload ActiveX Control-->RunDll32 advpack.dll,LaunchINFSection C:\WINDOWS\Downloaded Program Files\axofupld.inf, Uninstall
OLYMPUS CAMEDIA Master 4.1-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{30BB4D60-81DB-11D5-BB77-00400536ABAC}\setup.exe" CAMEDIA Master 4.1
PowerDVD 5.1-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{6811CAA0-BF12-11D4-9EA1-0050BAE317E1}\setup.exe"  -uninstall
QuickTime-->MsiExec.exe /I{28BE306E-5DA6-4F9C-BDB0-DBA3C8C6FFFD}
RealPlayer-->C:\Program Files\Common Files\Real\Update_OB\r1puninst.exe RealNetworks|RealPlayer|12.0
RealUpgrade 1.0-->MsiExec.exe /I{F4F4F84E-804F-4E9A-84D7-C34283F0088F}
Road Runner Medic 5.2-->"C:\Program Files\Support.com\TWC\uninstall.exe" /c "Remove Road Runner Medic 5.2?"
Safari-->MsiExec.exe /I{A67BB21E-D419-45BB-AB86-7D87D14BBCE2}
ScanToWeb-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{EBAE381B-60A6-4863-AA9F-FCAB755BC9E5}\setup.exe" ADDREMOVEDLG
Security Update for Step By Step Interactive Training (KB898458)-->"C:\WINDOWS\$NtUninstallKB898458$\spuninst\spuninst.exe"
Security Update for Step By Step Interactive Training (KB923723)-->"C:\WINDOWS\$NtUninstallKB923723$\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB928090)-->"C:\WINDOWS\ie7updates\KB928090-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB929969)-->"C:\WINDOWS\ie7updates\KB929969\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB931768)-->"C:\WINDOWS\ie7updates\KB931768-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB933566)-->"C:\WINDOWS\ie7updates\KB933566-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB937143)-->"C:\WINDOWS\ie7updates\KB937143-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB938127)-->"C:\WINDOWS\ie7updates\KB938127-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB939653)-->"C:\WINDOWS\ie7updates\KB939653-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB942615)-->"C:\WINDOWS\ie7updates\KB942615-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB944533)-->"C:\WINDOWS\ie7updates\KB944533-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB950759)-->"C:\WINDOWS\ie7updates\KB950759-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB953838)-->"C:\WINDOWS\ie7updates\KB953838-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB956390)-->"C:\WINDOWS\ie7updates\KB956390-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB958215)-->"C:\WINDOWS\ie7updates\KB958215-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB960714)-->"C:\WINDOWS\ie7updates\KB960714-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB961260)-->"C:\WINDOWS\ie7updates\KB961260-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB963027)-->"C:\WINDOWS\ie7updates\KB963027-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB969897)-->"C:\WINDOWS\ie7updates\KB969897-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 8 (KB969897)-->"C:\WINDOWS\ie8updates\KB969897-IE8\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 8 (KB971961)-->"C:\WINDOWS\ie8updates\KB971961-IE8\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 8 (KB972260)-->"C:\WINDOWS\ie8updates\KB972260-IE8\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 8 (KB974455)-->"C:\WINDOWS\ie8updates\KB974455-IE8\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 8 (KB976325)-->"C:\WINDOWS\ie8updates\KB976325-IE8\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 8 (KB978207)-->"C:\WINDOWS\ie8updates\KB978207-IE8\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 8 (KB981332)-->"C:\WINDOWS\ie8updates\KB981332-IE8\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB952069)-->"C:\WINDOWS\$NtUninstallKB952069_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB954155)-->"C:\WINDOWS\$NtUninstallKB954155_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB968816)-->"C:\WINDOWS\$NtUninstallKB968816_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB973540)-->"C:\WINDOWS\$NtUninstallKB973540_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB979402)-->"C:\WINDOWS\$NtUninstallKB979402_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player 9 (KB911565)-->"C:\WINDOWS\$NtUninstallKB911565$\spuninst\spuninst.exe"
Security Update for Windows Media Player 9 (KB917734)-->"C:\WINDOWS\$NtUninstallKB917734_WMP9$\spuninst\spuninst.exe"
Security Update for Windows XP (KB923561)-->"C:\WINDOWS\$NtUninstallKB923561$\spuninst\spuninst.exe"
Security Update for Windows XP (KB938464)-->"C:\WINDOWS\$NtUninstallKB938464$\spuninst\spuninst.exe"
Security Update for Windows XP (KB938464-v2)-->"C:\WINDOWS\$NtUninstallKB938464-v2$\spuninst\spuninst.exe"
Security Update for Windows XP (KB941569)-->"C:\WINDOWS\$NtUninstallKB941569$\spuninst\spuninst.exe"
Security Update for Windows XP (KB946648)-->"C:\WINDOWS\$NtUninstallKB946648$\spuninst\spuninst.exe"
Security Update for Windows XP (KB950760)-->"C:\WINDOWS\$NtUninstallKB950760$\spuninst\spuninst.exe"
Security Update for Windows XP (KB950762)-->"C:\WINDOWS\$NtUninstallKB950762$\spuninst\spuninst.exe"
Security Update for Windows XP (KB950974)-->"C:\WINDOWS\$NtUninstallKB950974$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951066)-->"C:\WINDOWS\$NtUninstallKB951066$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951376)-->"C:\WINDOWS\$NtUninstallKB951376$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951376-v2)-->"C:\WINDOWS\$NtUninstallKB951376-v2$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951698)-->"C:\WINDOWS\$NtUninstallKB951698$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951748)-->"C:\WINDOWS\$NtUninstallKB951748$\spuninst\spuninst.exe"
Security Update for Windows XP (KB952004)-->"C:\WINDOWS\$NtUninstallKB952004$\spuninst\spuninst.exe"
Security Update for Windows XP (KB952954)-->"C:\WINDOWS\$NtUninstallKB952954$\spuninst\spuninst.exe"
Security Update for Windows XP (KB953839)-->"C:\WINDOWS\$NtUninstallKB953839$\spuninst\spuninst.exe"
Security Update for Windows XP (KB954211)-->"C:\WINDOWS\$NtUninstallKB954211$\spuninst\spuninst.exe"
Security Update for Windows XP (KB954459)-->"C:\WINDOWS\$NtUninstallKB954459$\spuninst\spuninst.exe"
Security Update for Windows XP (KB954600)-->"C:\WINDOWS\$NtUninstallKB954600$\spuninst\spuninst.exe"
Security Update for Windows XP (KB955069)-->"C:\WINDOWS\$NtUninstallKB955069$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956391)-->"C:\WINDOWS\$NtUninstallKB956391$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956572)-->"C:\WINDOWS\$NtUninstallKB956572$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956744)-->"C:\WINDOWS\$NtUninstallKB956744$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956802)-->"C:\WINDOWS\$NtUninstallKB956802$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956803)-->"C:\WINDOWS\$NtUninstallKB956803$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956841)-->"C:\WINDOWS\$NtUninstallKB956841$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956844)-->"C:\WINDOWS\$NtUninstallKB956844$\spuninst\spuninst.exe"
Security Update for Windows XP (KB957095)-->"C:\WINDOWS\$NtUninstallKB957095$\spuninst\spuninst.exe"
Security Update for Windows XP (KB957097)-->"C:\WINDOWS\$NtUninstallKB957097$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958644)-->"C:\WINDOWS\$NtUninstallKB958644$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958687)-->"C:\WINDOWS\$NtUninstallKB958687$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958690)-->"C:\WINDOWS\$NtUninstallKB958690$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958869)-->"C:\WINDOWS\$NtUninstallKB958869$\spuninst\spuninst.exe"
Security Update for Windows XP (KB959426)-->"C:\WINDOWS\$NtUninstallKB959426$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960225)-->"C:\WINDOWS\$NtUninstallKB960225$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960715)-->"C:\WINDOWS\$NtUninstallKB960715$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960803)-->"C:\WINDOWS\$NtUninstallKB960803$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960859)-->"C:\WINDOWS\$NtUninstallKB960859$\spuninst\spuninst.exe"
Security Update for Windows XP (KB961371)-->"C:\WINDOWS\$NtUninstallKB961371$\spuninst\spuninst.exe"
Security Update for Windows XP (KB961373)-->"C:\WINDOWS\$NtUninstallKB961373$\spuninst\spuninst.exe"
Security Update for Windows XP (KB961501)-->"C:\WINDOWS\$NtUninstallKB961501$\spuninst\spuninst.exe"
Security Update for Windows XP (KB968537)-->"C:\WINDOWS\$NtUninstallKB968537$\spuninst\spuninst.exe"
Security Update for Windows XP (KB969059)-->"C:\WINDOWS\$NtUninstallKB969059$\spuninst\spuninst.exe"
Security Update for Windows XP (KB969898)-->"C:\WINDOWS\$NtUninstallKB969898$\spuninst\spuninst.exe"
Security Update for Windows XP (KB969947)-->"C:\WINDOWS\$NtUninstallKB969947$\spuninst\spuninst.exe"
Security Update for Windows XP (KB970238)-->"C:\WINDOWS\$NtUninstallKB970238$\spuninst\spuninst.exe"
Security Update for Windows XP (KB970430)-->"C:\WINDOWS\$NtUninstallKB970430$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971468)-->"C:\WINDOWS\$NtUninstallKB971468$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971486)-->"C:\WINDOWS\$NtUninstallKB971486$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971557)-->"C:\WINDOWS\$NtUninstallKB971557$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971633)-->"C:\WINDOWS\$NtUninstallKB971633$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971657)-->"C:\WINDOWS\$NtUninstallKB971657$\spuninst\spuninst.exe"
Security Update for Windows XP (KB972270)-->"C:\WINDOWS\$NtUninstallKB972270$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973346)-->"C:\WINDOWS\$NtUninstallKB973346$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973354)-->"C:\WINDOWS\$NtUninstallKB973354$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973507)-->"C:\WINDOWS\$NtUninstallKB973507$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973525)-->"C:\WINDOWS\$NtUninstallKB973525$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973869)-->"C:\WINDOWS\$NtUninstallKB973869$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973904)-->"C:\WINDOWS\$NtUninstallKB973904$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974112)-->"C:\WINDOWS\$NtUninstallKB974112$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974318)-->"C:\WINDOWS\$NtUninstallKB974318$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974392)-->"C:\WINDOWS\$NtUninstallKB974392$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974571)-->"C:\WINDOWS\$NtUninstallKB974571$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975025)-->"C:\WINDOWS\$NtUninstallKB975025$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975467)-->"C:\WINDOWS\$NtUninstallKB975467$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975560)-->"C:\WINDOWS\$NtUninstallKB975560$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975561)-->"C:\WINDOWS\$NtUninstallKB975561$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975713)-->"C:\WINDOWS\$NtUninstallKB975713$\spuninst\spuninst.exe"
Security Update for Windows XP (KB977165)-->"C:\WINDOWS\$NtUninstallKB977165$\spuninst\spuninst.exe"
Security Update for Windows XP (KB977816)-->"C:\WINDOWS\$NtUninstallKB977816$\spuninst\spuninst.exe"
Security Update for Windows XP (KB977914)-->"C:\WINDOWS\$NtUninstallKB977914$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978037)-->"C:\WINDOWS\$NtUninstallKB978037$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978251)-->"C:\WINDOWS\$NtUninstallKB978251$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978262)-->"C:\WINDOWS\$NtUninstallKB978262$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978338)-->"C:\WINDOWS\$NtUninstallKB978338$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978542)-->"C:\WINDOWS\$NtUninstallKB978542$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978601)-->"C:\WINDOWS\$NtUninstallKB978601$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978706)-->"C:\WINDOWS\$NtUninstallKB978706$\spuninst\spuninst.exe"
Security Update for Windows XP (KB979309)-->"C:\WINDOWS\$NtUninstallKB979309$\spuninst\spuninst.exe"
Security Update for Windows XP (KB979683)-->"C:\WINDOWS\$NtUninstallKB979683$\spuninst\spuninst.exe"
Security Update for Windows XP (KB980232)-->"C:\WINDOWS\$NtUninstallKB980232$\spuninst\spuninst.exe"
Sonic DLA-->MsiExec.exe /I{1206EF92-2E83-4859-ACCB-2048C3CB7DA6}
Sonic RecordNow!-->MsiExec.exe /I{9541FED0-327F-4DF0-8B96-EF57EF622F19}
Sonic Update Manager-->MsiExec.exe /I{09DA4F91-2A09-4232-AB8C-6BC740096DE3}
Tempo On Disk-->C:\WINDOWS\IsUninst.exe -f"C:\Program Files\Taylor Publishing\Tempo On Disk\Uninst.isu"
Update for Windows Internet Explorer 8 (KB971180)-->"C:\WINDOWS\ie8updates\KB971180-IE8\spuninst\spuninst.exe"
Update for Windows Internet Explorer 8 (KB976662)-->"C:\WINDOWS\ie8updates\KB976662-IE8\spuninst\spuninst.exe"
Update for Windows Internet Explorer 8 (KB976749)-->"C:\WINDOWS\ie8updates\KB976749-IE8\spuninst\spuninst.exe"
Update for Windows Internet Explorer 8 (KB980182)-->"C:\WINDOWS\ie8updates\KB980182-IE8\spuninst\spuninst.exe"
Update for Windows XP (KB951072-v2)-->"C:\WINDOWS\$NtUninstallKB951072-v2$\spuninst\spuninst.exe"
Update for Windows XP (KB951978)-->"C:\WINDOWS\$NtUninstallKB951978$\spuninst\spuninst.exe"
Update for Windows XP (KB955759)-->"C:\WINDOWS\$NtUninstallKB955759$\spuninst\spuninst.exe"
Update for Windows XP (KB955839)-->"C:\WINDOWS\$NtUninstallKB955839$\spuninst\spuninst.exe"
Update for Windows XP (KB967715)-->"C:\WINDOWS\$NtUninstallKB967715$\spuninst\spuninst.exe"
Update for Windows XP (KB968389)-->"C:\WINDOWS\$NtUninstallKB968389$\spuninst\spuninst.exe"
Update for Windows XP (KB971737)-->"C:\WINDOWS\$NtUninstallKB971737$\spuninst\spuninst.exe"
Update for Windows XP (KB973687)-->"C:\WINDOWS\$NtUninstallKB973687$\spuninst\spuninst.exe"
Update for Windows XP (KB973815)-->"C:\WINDOWS\$NtUninstallKB973815$\spuninst\spuninst.exe"
Viewpoint Manager (Remove Only)-->C:\Program Files\Viewpoint\Viewpoint Manager\ViewMgrInstaller.exe /u /k
Viewpoint Media Player-->C:\Program Files\Viewpoint\Viewpoint Experience Technology\mtsAxInstaller.exe /u
Viewpoint Toolbar-->C:\Program Files\Viewpoint\Viewpoint Toolbar\3.9.0\Uninstaller.exe /u /k /url "http://www.viewpoint.com/pub/uninstallcompleted.html"
WeatherBug-->MsiExec.exe /X{70DECFBF-9119-4434-B2D3-A3C283D15E45}
Windows Internet Explorer 8-->"C:\WINDOWS\ie8\spuninst\spuninst.exe"
Windows Media Format Runtime-->"C:\Program Files\Windows Media Player\wmsetsdk.exe" /UninstallAll
Windows XP Service Pack 3-->"C:\WINDOWS\$NtServicePackUninstall$\spuninst\spuninst.exe"
======Hosts File======
======Security center information======
AV: AVG Anti-Virus Free
======System event log======
Computer Name: KENDRA
Event Code: 29
Message: The time provider NtpClient is configured to acquire time from one or more
time sources, however none of the sources are currently accessible.
No attempt to contact a source will be made for 14 minutes.
NtpClient has no source of accurate time.
Record Number: 19470
Source Name: W32Time
Time Written: 20091009010923.000000-360
Event Type: error
User:
Event Code: 17
Message: Time Provider NtpClient: An error occurred during DNS lookup of the manually
configured peer 'time.windows.com,0x1'. NtpClient will try the DNS lookup again in 15
minutes.
The error was: A socket operation was attempted to an unreachable host. (0x80072751)
Record Number: 19469
Event Type: error
User:
Event Code: 1002
Message: The IP address lease 66.68.88.88 for the Network Card with network address 000F1F587EE9 has been
denied by the DHCP server 0.0.0.0 (The DHCP Server sent a DHCPNACK message).
Record Number: 19468
Source Name: Dhcp
Time Written: 20091009010918.000000-360
Event Type: error
User:
Event Code: 4
Message: Broadcom 440x 10/100 Integrated Controller: The network link is down.  Check to make sure the network cable is properly connected.
Record Number: 19464
Source Name: bcm4sbxp
Time Written: 20091009010854.000000-360
Event Type: warning
User:
Event Code: 36
Message: The time service has not been able to synchronize the system time
for 49152 seconds because none of the time providers has been able to
provide a usable time stamp. The system clock is unsynchronized.
Record Number: 19463
Time Written: 20091007071820.000000-360
Event Type: warning
User:
Event Code: 1000
Message: Faulting application softwareupdate.exe, version 1.0.0.7, faulting module mshtml.dll, version 7.0.6000.16414, fault address 0x000b1cf2.
Record Number: 410
Source Name: Application Error
Time Written: 20070414150004.000000-360
Event Type: error
User:
Event Code: 1001
Message: Fault bucket 380451481.
Record Number: 409
Time Written: 20070414145347.000000-360
Event Type: error
User:
Event Code: 1000
Record Number: 408
Time Written: 20070414145343.000000-360
Event Type: error
User:
Event Code: 1517
Message: Windows saved user KENDRA\Kendra Daley registry while an application or service was still using the registry during log off. The memory used by the user's registry has not been freed. The registry will be unloaded when it is no longer in use.
This is often caused by services running as a user account, try configuring the services to run in either the LocalService or NetworkService account.
Record Number: 404
Source Name: Userenv
Time Written: 20070414144751.000000-360
Event Type: warning
User: NT AUTHORITY\SYSTEM
Event Code: 1000
Record Number: 400
Time Written: 20070414144430.000000-360
Event Type: error
User:
"Path"=%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Program Files\QuickTime\QTSystem\
"windir"=%SystemRoot%
"OS"=Windows_NT
"PROCESSOR_ARCHITECTURE"=x86
"PROCESSOR_LEVEL"=15
"PROCESSOR_IDENTIFIER"=x86 Family 15 Model 2 Stepping 9, GenuineIntel
"PROCESSOR_REVISION"=0209
"NUMBER_OF_PROCESSORS"=1
"PATHEXT"=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
"TEMP"=%SystemRoot%\TEMP
"TMP"=%SystemRoot%\TEMP
"FP_NO_HOST_CHECK"=NO
"asl.log"=Destination=file;OnFirstLog=command,environment
"CLASSPATH"=.;C:\Program Files\Java\jre6\lib\ext\QTJava.zip
"QTJAVA"=C:\Program Files\Java\jre6\lib\ext\QTJava.zip
"SAFEBOOT_OPTION"=NETWORK
Hi, Lonestar.
You haven't run Malwarebytes yet, have you?  Please do so as instructed above and post the log.  Then we'll continue with the cleanup.  You have extremely outdated and vulnerable software on your computer that we need to address to help prevent further infections like this.
Note:  you may need to run RKill again if you have shutdown the computer before running Malwarebytes.
Lonestar
Yeah I figured any her computer was in need of some help before this happened. Again Thanks for taking the time to help me, I really do appreciate your time!
Malwarebytes' Anti-Malware 1.46
www.malwarebytes.org
Database version: 4184
Windows 5.1.2600 Service Pack 3 (Safe Mode)
6/9/2010 2:25:13 PM
mbam-log-2010-06-09 (14-25-13).txt
Scan type: Quick scan
Objects scanned: 143141
Time elapsed: 10 minute(s), 14 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 6
Registry Values Infected: 0
Registry Data Items Infected: 6
Folders Infected: 1
Files Infected: 1
(No malicious items detected)
HKEY_CLASSES_ROOT\minibugtransporter.minibugtransporterx (Adware.Minibug) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\minibugtransporter.minibugtransporterx.1 (Adware.Minibug) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{04a38f6b-006f-4247-ba4c-02a139d5531c} (Adware.Minibug) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{2b96d5cc-c5b5-49a5-a69d-cc0a30f9028c} (Adware.Minibug) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{3c2d2a1e-031f-4397-9614-87c932a848e0} (Adware.Minibug) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{549b5ca7-4a86-11d7-a4df-000874180bb3} (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\AntiVirusDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\open\command\(default) (Hijack.StartMenuInternet) -> Bad: ("C:\Documents and Settings\Kendra\Local Settings\Application Data\ave.exe" /START "C:\Program Files\Mozilla Firefox\firefox.exe") Good: (firefox.exe) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Clients\StartMenuInternet\FIREFOX.EXE\shell\safemode\command\(default) (Hijack.StartMenuInternet) -> Bad: ("C:\Documents and Settings\Kendra\Local Settings\Application Data\ave.exe" /START "C:\Program Files\Mozilla Firefox\firefox.exe" -safe-mode) Good: (firefox.exe -safe-mode) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Clients\StartMenuInternet\IEXPLORE.EXE\shell\open\command\(default) (Hijack.StartMenuInternet) -> Bad: ("C:\Documents and Settings\Kendra\Local Settings\Application Data\ave.exe" /START "C:\Program Files\Internet Explorer\iexplore.exe") Good: (iexplore.exe) -> Quarantined and deleted successfully.
Folders Infected:
C:\Documents and Settings\Kendra\Application Data\CleanUp Antivirus (Rogue.CleanUpAntivirus) -> Quarantined and deleted successfully.
Files Infected:
C:\Documents and Settings\Kendra\Application Data\CleanUp Antivirus\cookies.sqlite (Rogue.CleanUpAntivirus) -> Quarantined and deleted successfully.
Let's see if you can do this from normal mode.
Link 1
Link 2
Disable your AntiVirus and AntiSpyware applications. If not disabled, these programs will likely interfere with cleanup process. This can usually be accomplished by a right-click on the icon in the System Tray.  This can usually be accomplished by a right-click on the icon in the System Tray.
Note:  If you use AVG, you must also open the AVG 8 Control Center, by right clicking on the AVG 8 icon on task bar as well as the following:
  • Click on Tools.
  • Select Advanced Settings.
  • In the left hand pane, scroll down to "Resident Shield".
  • In the main pane, deselect the option to "Enable Resident Shield."
  • To re-enable AVG 8, please select "Enable Resident Shield" again.
Now, please run ComboFix:
Lonestar
Corrine -  Using AVG. There is no system tray icon and I'm unable to open the program as windows request I pick a program to open avg.  Theres also avgrsx.exe and avgwdsvc.exe both running in task manager that I can't stop, If that matters.  Is this acceptable and should I continue with combofix? Thanks again for your help :goodie:
Can you select "end process" with Task Manager for the AVG items?
Lonestar
I can but the process doesn't seem to stop. When I hit end process it just creates another avgrsx.exe.
Paddy
The first thing you want to try is to locate AVG in the Add/Remove Control Panel and try to remove it from there for now, till Corrine gets on top of this problem you can always reinstall it again if you so wish after you are clean..
Follow these instructions to do this.
1) Click on Start, Control Panel
2) Open Add/Remove Programs
3) Find AVG in the Programs list and highlight it
4) Click Remove and follow the prompts to uninstall AVG Free
Paddy..
Thanks, Paddy.
Lonestar,
AVG does tend to interfere with the running of ComboFix.  Other than the instructions I provided above, this is what I found in the AVG FAQ's for disabling AVG:  http://free.avg.com/us-en/faq.num-1311
If your "better half" wishes to continue using AVG, it should be upgraded to the latest version, AVG 9, which can be downloaded from http://free.avg.com/us-en/homepage
I suggest downloading either AVG 9 or one of the following, which are also free for personal use:
avast! 5 Home Edition
Avira AntiVir PersonalEdition Classic
Microsoft Security Essentials
Next, uninstall AVG 8.5, run ComboFix, post the ComboFix log here and ASAP, install either the updated AVG 9 or one of the other three selections from above.
Lonestar
Paddy - I'm unable to access the "add or remove programs" file - Error C:\WINDOWS\system32\rundll32.exe - application not found....
Corrine - Since I can't seem to remove or open it to disable AVG what are my options?
Sorry to be a bother and I do appreciate all the help!
