I cant connect to Microsoft any antivirus on line scans
Started by Deb, July 08, 2010, 06:50:50 AM
Deb
Hi, am I glad to have found your forum. I have been battling a virus that wont allow me to connect to Microsoft, on line scans, or download them without error and now the PC freezes from a disk anti virus. This is obviously a serious virus. E scan is being replaced by Trend Micro and so the lapse between them must have allowed this to occur also windows update has nothing in the folder. Please help me and thank you
Deb
I cant find where to add to my original post I down loaded combo fix renamed it and ran it showed escan on tried to uninstall but file corrupt and can not turn it off as can not access any part of it. Combo says if I continue I could destroy my machine and at my own risk. I can not simply delete the file escan as it says programs may not work I feel like I am being backed into a cornor here
MikeW
Hi, Deb.  Welcome to LandzDown Forum.
We will do our best to assist you.  However, in order to do so, please follow all instructions provided in the sequence given.  Do not install/re-install any programs or run any fixes or scanners that you have not been instructed to use. This may cause conflicts with the tools being used in the cleanup process.
Select Safe Mode with Networking. (To do this, turn your computer off and then back on and immediately when you see anything on the screen, start tapping the F8 key on your keyboard. Using the arrow keys on your keyboard, select Safe Mode with Networking and press Enter on your keyboard. Windows will now boot into safe mode with networking and prompt you to login as a user.)
Please start Internet Explorer, and when the program is open, do the following:
-- click on the Tools menu and then select Internet Options.
-- click on the Connections
-- click on the Lan Settings button tab
-- under the Proxy Server section, please uncheck the checkbox labeled "Use a proxy server for your LAN"
-- press the OK  button to close this screen. Then press the OK button to close the Internet Options screen.
One, Two,Three or Four
  • Double-click rkill to run.
Notes:
  • Click Finish.
  • Click Remove Selected.
  • When completed, a log will open in Notepad. Please save it to a convenient location. The log can also be found here on Windows XP: C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt and C:\Users\UserName\AppData\Roaming\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt on Windows Vista and Windows 7.
Deb
Hi Internet connection wont work on safe mode and shows nothing  in its file to change lan with
IE also has nothing in it, I did download combofix.exe and ran it in desperation last night so I have likely stuffed up majorly  also i had previously run MBAM over this last week trying to sort out problem. I believe escan being out of date has a lot to do with some of this as it shows as still active on my firewall and the uninstall file for it is corrupt also keep getting chkdsk request for corrupt files. Any how below is the results of both logs and hey thanks for trying to help me out here I am following instruction to the letter now just hope its not too late
This log file is located at C:\rkill.log.
Please post this only if requested to by the person helping you.
Otherwise you can close this log when you wish.
Ran as Owner on 09/07/2010 at 13:09:21.
Processes terminated by Rkill or while it was running:
C:\Documents and Settings\Owner\My Documents\Downloads\rkill.exe
Rkill completed on 09/07/2010  at 13:09:22.
An error occurred mbam error updating 12007, 0,WinHTTP send request
Malwarebytes' Anti-Malware 1.46
www.malwarebytes.org
Database version: 4052
Windows 5.1.2600 Service Pack 3 (Safe Mode)
9/07/2010 1:40:16 p.m.
mbam-log-2010-07-09 (13-40-16).txt
Scan type: Full scan (C:\|E:\|)
Objects scanned: 230436
Time elapsed: 27 minute(s), 32 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
Folders Infected:
Files Infected:
Hi, Deb.
Please do not run ComboFix again without instructions.  Let's see the log.
Hold down the Windows Key and the "R" key.  A run box will appear.  Copy and paste the following:  C:\Qoobox\ComboFix.txt then click OK.
Notepad will open with a log.  Post the contents of that log in your next reply.
Deb
Hi
ComboFix 10-07-07.01 - Owner 09/07/2010   1:13.1.2 - x86
Microsoft Windows XP Home Edition  5.1.2600.3.1252.1.1033.18.1022.643 [GMT 12:00]
Running from: c:\documents and settings\Owner\Desktop\Clark76.exe
AV: eScan for Windows *On-access scanning enabled* (Outdated) {E25EE26A-7512-411E-BAF6-D9AFA504A475}
C:\Documents
c:\windows\regedit.com
c:\windows\system32\taskmgr.com
(((((((((((((((((((((((((   Files Created from 2010-06-08 to 2010-07-08  )))))))))))))))))))))))))))))))
2010-07-06 02:06 . 2010-07-06 02:06   --------   d-----w-   c:\documents and settings\NetworkService\Local Settings\Application Data\Google
2010-07-06 01:47 . 2010-07-06 01:47   --------   d-sh--w-   c:\documents and settings\LocalService\IECompatCache
2010-07-06 01:46 . 2010-07-06 01:46   --------   d-sh--w-   c:\documents and settings\LocalService\PrivacIE
2010-07-06 01:46 . 2010-07-06 01:47   --------   d-----w-   c:\documents and settings\LocalService\Local Settings\Application Data\AskToolbar
2010-07-06 01:46 . 2010-07-06 01:46   --------   d-----w-   c:\documents and settings\LocalService\Local Settings\Application Data\Google
2010-07-05 11:06 . 2010-07-05 11:06   0   ----a-w-   c:\windows\system32\MsiExec.dat
2010-07-05 11:06 . 2010-07-05 11:06   0   ----a-w-   c:\windows\UNRecode.dat
2010-07-05 11:06 . 2010-07-05 11:06   0   ----a-w-   c:\windows\UNNeroVision.dat
2010-07-05 11:06 . 2010-07-05 11:06   0   ----a-w-   c:\windows\UNNeroShowTime.dat
2010-07-05 11:06 . 2010-07-05 11:06   0   ----a-w-   c:\windows\UNNeroMediaHome.dat
2010-07-05 11:06 . 2010-07-05 11:06   0   ----a-w-   c:\windows\UNNeroBackItUp.dat
2010-07-05 11:06 . 2010-07-05 11:06   0   ----a-w-   c:\windows\uninst.dat
2010-07-05 11:06 . 2010-07-05 11:06   0   ----a-w-   c:\windows\system32\rundll32.dat
2010-07-05 11:06 . 2010-07-05 11:06   0   ----a-w-   c:\windows\system32\nvudisp.dat
2010-07-05 11:06 . 2010-07-05 11:06   0   ----a-w-   c:\windows\system32\KmRemove.dat
2010-07-05 11:06 . 2010-07-05 11:06   --------   d-----w-   c:\windows\$$$Temp_&&&_Hives
2010-07-05 11:06 . 2010-07-05 22:04   --------   d-----w-   c:\documents and settings\Owner\Local Settings\Application Data\ExpertScan
2010-07-04 09:50 . 2010-07-04 09:50   --------   d-----w-   c:\windows\system32\URTTEMP
2010-07-04 09:00 . 2010-07-04 09:03   71680   ----a-w-   c:\documents and settings\All Users\Application Data\NOS\Adobe_Downloads\arh.exe
2010-07-04 06:57 . 2010-07-04 08:38   --------   d-----w-   c:\documents and settings\Owner\Local Settings\Application Data\Temp
2010-07-02 09:07 . 2010-07-02 09:07   --------   d-----w-   c:\documents and settings\All Users\Application Data\McAfee
2010-07-02 08:56 . 2010-07-02 09:17   2568656   ----a-w-   c:\documents and settings\All Users\Application Data\NOS\Adobe_Downloads\install_flash_player.exe
2010-07-02 08:56 . 2010-07-02 09:07   1025992   ----a-w-   c:\documents and settings\All Users\Application Data\NOS\Adobe_Downloads\SecurityScan_Release.exe
2010-06-30 06:27 . 1996-11-21 22:15   92208   ----a-w-   c:\windows\system\WING.DLL
2010-06-30 06:27 . 1996-11-21 22:15   6736   ----a-w-   c:\windows\system\WINGDIB.DRV
2010-06-30 06:27 . 1996-11-21 22:15   27648   ----a-w-   c:\windows\system\WAVMIX16.DLL
2010-06-30 06:27 . 1996-11-21 22:15   188960   ----a-w-   c:\windows\system\WINGDE.DLL
2010-06-30 06:27 . 1996-11-21 22:15   12800   ----a-w-   c:\windows\system\WING32.DLL
2010-06-24 00:03 . 2010-06-24 00:03   --------   d-----w-   c:\documents and settings\samp\Local Settings\Application Data\Ahead
2010-06-16 01:40 . 2010-06-16 01:40   --------   d-----w-   C:\New Folder
2010-06-16 01:39 . 2010-06-16 01:39   --------   d-----w-   c:\documents and settings\samp\Local Settings\Application Data\Adobe
2010-06-10 22:47 . 2010-06-10 22:47   --------   d-----w-   c:\documents and settings\Owner\Application Data\Uniblue
2010-07-08 12:03 . 2009-08-25 04:08   --------   d-----w-   c:\program files\eScan
2010-07-08 06:59 . 2010-03-06 12:40   --------   d-----w-   c:\program files\Free Window Registry Repair
2010-07-07 05:02 . 2010-01-07 06:54   664   ----a-w-   c:\windows\system32\d3d9caps.dat
2010-07-06 11:28 . 2007-08-06 21:28   70416   -c--a-w-   c:\documents and settings\Owner\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2010-07-06 09:19 . 2007-08-09 00:52   --------   d-----w-   c:\program files\EPSON
2010-07-06 02:00 . 2008-06-28 20:36   --------   d-----w-   c:\program files\Google
2010-07-05 11:06 . 2008-07-24 04:37   --------   d-----w-   c:\program files\yWriter2
2010-07-05 11:06 . 2010-04-03 12:49   --------   d-----w-   c:\program files\CoreFTP
2010-07-04 09:07 . 2008-09-14 01:19   --------   d-----w-   c:\documents and settings\All Users\Application Data\NOS
2010-07-04 01:31 . 2009-05-13 04:54   --------   d-----w-   c:\documents and settings\All Users\Application Data\ParetoLogic
2010-06-30 05:48 . 2007-09-10 05:57   --------   d-----w-   c:\program files\Microsoft Kids
2010-06-10 21:22 . 2010-04-10 04:49   --------   d-----w-   c:\program files\Yahoo!
2010-06-08 09:13 . 2010-06-07 01:13   --------   d-----w-   c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
2010-06-06 10:47 . 2010-06-06 03:51   --------   d-----w-   c:\documents and settings\All Users\Application Data\Common Toolkit Suite
2010-06-06 10:40 . 2010-06-06 10:40   --------   dc----w-   c:\documents and settings\All Users\Application Data\{69F69AB0-8485-4B45-A118-148977C1651A}
2010-06-06 10:39 . 2010-06-06 03:50   --------   d-----w-   c:\documents and settings\Owner\Application Data\Fighters
2010-06-06 03:52 . 2010-06-06 03:51   --------   d-----w-   c:\documents and settings\All Users\Application Data\clp
2010-06-05 07:45 . 2010-06-05 07:45   70528   ----a-w-   c:\documents and settings\samp\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2010-06-05 07:08 . 2010-06-05 07:08   --------   d-----w-   c:\documents and settings\All Users\Application Data\XoftSpySE
2010-06-05 05:40 . 2010-06-05 05:39   --------   d-----w-   c:\documents and settings\Owner\Application Data\PCFix
2010-05-31 22:34 . 2010-05-31 22:34   --------   d-----w-   c:\documents and settings\samp\Application Data\.clamwin
2010-05-31 20:57 . 2010-05-31 20:56   --------   d-----w-   c:\program files\Ask.com
2010-05-30 21:16 . 2010-05-30 21:16   --------   d-----w-   c:\documents and settings\samp\Application Data\Yahoo!
2010-05-30 09:28 . 2010-05-30 09:28   --------   d-----w-   c:\documents and settings\samp\Application Data\Xerox
2010-05-30 03:53 . 2010-05-30 03:53   --------   d-----w-   c:\documents and settings\Owner\Application Data\Malwarebytes
2010-05-30 03:53 . 2010-05-30 03:53   --------   d-----w-   c:\documents and settings\All Users\Application Data\Malwarebytes
2010-05-29 20:53 . 2007-08-06 21:25   --------   d-----w-   c:\program files\KMaestro
2010-05-29 06:35 . 2007-08-06 03:48   196608   -c--a-w-   c:\windows\system32\drivers\nStandard.bin
2010-05-25 06:33 . 2007-08-06 03:25   --------   d--h--w-   c:\program files\InstallShield Installation Information
2010-05-25 06:33 . 2007-08-06 03:48   --------   d-----w-   c:\program files\ASUS
2010-04-03 12:49 . 2010-04-03 12:09   3520550   -c--a-w-   c:\program files\coreftplite.exe
2010-03-29 07:37 . 2010-03-29 05:53   15331909   -c--a-w-   c:\program files\AVSVideoEditor.exe.part
2010-03-07 03:24 . 2010-03-07 03:23   1666   -c--a-w-   c:\program files\SOUNDMAXINTEGRATEDDIGITALHDAUDIO6.10.1.6585f40fd54c64fbb86b9f465bee20651a0a.dmx-info
2010-03-07 02:50 . 2010-03-07 02:50   3874552   -c--a-w-   c:\program files\drivermax.exe
2010-03-04 10:42 . 2010-03-04 10:38   1146184   -c--a-w-   c:\program files\wlsetup-web.exe
2009-03-21 14:06 . 2006-02-28 12:00   159084   --sha-r-   c:\windows\system32\dkzjpky.dll
REGEDIT4
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{D4027C7F-154A-4066-A1AD-4243D8127440}]
2010-02-04 04:50   1197448   ----a-w-   c:\program files\Ask.com\GenericAskToolbar.dll
"{D4027C7F-154A-4066-A1AD-4243D8127440}"= "c:\program files\Ask.com\GenericAskToolbar.dll" [2010-02-04 1197448]
[HKEY_CLASSES_ROOT\clsid\{d4027c7f-154a-4066-a1ad-4243d8127440}]
[HKEY_CLASSES_ROOT\GenericAskToolbar.ToolbarWnd.1]
[HKEY_CLASSES_ROOT\TypeLib\{2996F0E7-292B-4CAE-893F-47B8B1C05B56}]
[HKEY_CLASSES_ROOT\GenericAskToolbar.ToolbarWnd]
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\Webbrowser]
"BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}"="c:\program files\Common Files\Ahead\Lib\NMBgMonitor.exe" [2006-12-23 143360]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-07-05 68856]
"High Definition Audio Property Page Shortcut"="HDAShCut.exe" [2004-10-27 61952]
"JMB36X Configure"="c:\windows\system32\JMRaidTool.exe" [2006-07-12 352256]
"XeroxScannerDaemon"="c:\program files\Xerox\NWWia\XrxFTPLt.exe" [2001-08-17 27648]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2007-04-12 8429568]
"nwiz"="nwiz.exe" [2007-04-12 1626112]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2007-04-12 81920]
"eScan CleanUp"="c:\progra~1\eScan\Cleanup.exe" [2005-04-04 486400]
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
"CTFMON.EXE"="c:\windows\system32\CTFMON.EXE" [2008-04-14 15360]
Microsoft Office.lnk - c:\program files\Microsoft Office\Office10\OSA.EXE [2001-2-13 83360]
"SynchronousMachineGroupPolicy"= 0 (0x0)
"SynchronousUserGroupPolicy"= 0 (0x0)
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\session manager]
BootExecute   REG_MULTI_SZ      \0
"c:\\Program Files\\wlsetup-web.exe"=
"c:\\Program Files\\Microsoft Silverlight\\sllauncher.exe"=
"c:\\Program Files\\EPSON\\Creativity Suite\\Attach To Email\\AttachToEmail.exe"=
"c:\\Program Files\\EPSON\\Creativity Suite\\Easy Photo Print\\EEasyPhotoPrint.exe"=
"c:\\Program Files\\EPSON\\Creativity Suite\\File Manager\\EFileManager.exe"=
"c:\\Program Files\\EPSON Print CD\\EPSONCD.exe"=
"c:\\Program Files\\InterActual\\InterActual Player\\iPlayer.exe"=
"c:\\Program Files\\InterActual\\InterActual Player\\inuninst.exe"=
"c:\\Program Files\\Straighthold Trader\\MetaEditor.exe"=
"c:\\Program Files\\Mozilla Firefox\\firefox.exe"=
"c:\\Program Files\\Outlook Express\\msimn.exe"=
"c:\\Program Files\\EPSON\\PIF DESIGNER\\PIF DESIGNER.exe"=
"c:\\Program Files\\EPSON\\Creativity Suite\\Scan Assistant\\EScanAssist.exe"=
"c:\\Program Files\\CoreFTP\\UNWISE.EXE"=
"c:\\Program Files\\eScan\\unins000.exe"=
"c:\\Program Files\\Messenger\\msmsgs.exe"=
"c:\\Program Files\\Movie Maker\\moviemk.exe"=
"c:\\Program Files\\xerox\\nwwia\\XrxFTPLt.exe"=
"c:\\Program Files\\CoreFTP\\coreftp.exe"=
"c:\\WINDOWS\\system32\\mmc.exe"=
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
"5750:TCP"= 5750:TCP:haivgfe
"3389:TCP"= 3389:TCP:@xpsp2res.dll,-22009
R1 ShldDrv;Panda File Shield Driver;c:\windows\system32\drivers\ShlDrv51.sys [28/08/2009 2:46 p.m. 38968]
R2 eScan-trayicos;eScan Server-Updater;c:\progra~1\eScan\TRAYSSER.EXE [7/08/2007 9:36 a.m. 110592]
R2 ESCANMX;eScan Monitor Extension;c:\windows\system32\drivers\escanmxx.sys [7/08/2007 10:05 a.m. 33792]
R2 PavProc;Panda Process Protection Driver;c:\windows\system32\drivers\PavProc.sys [28/08/2009 2:46 p.m. 178872]
S2 exwklhtf;Image Windows;c:\windows\system32\svchost.exe -k netsvcs [1/03/2006 14336]
S2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [6/07/2010 2:00 p.m. 135664]
S2 KAVMonitorService;eScan Monitor Service;c:\progra~1\eScan\avpm.exe [7/08/2007 9:36 a.m. 622750]
S3 MBAMSwissArmy;MBAMSwissArmy;\??\c:\windows\system32\drivers\mbamswissarmy.sys --> c:\windows\system32\drivers\mbamswissarmy.sys [?]
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Svchost  - NetSvcs
exwklhtf
2010-07-08 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2010-07-06 02:00]
2010-07-08 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-07-04 c:\windows\Tasks\User_Feed_Synchronization-{50A9C00E-06C1-442E-8161-44D674D61CD3}.job
- c:\windows\system32\msfeedssync.exe [2007-08-13 15:31]
uSearchMigratedDefaultURL = hxxp://search.live.com/results.aspx?q={searchTerms}&src={referrer:source?}
uStart Page = hxxp://msn.co.nz/
mStart Page = hxxp://msn.co.nz/
IE: Google Sidewiki... - c:\program files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_96D6FF0C6D236BF8.dll/cmsidewiki.html
LSP: %SystemRoot%\system32\mwtsp.dll
FF - ProfilePath - c:\documents and settings\Owner\Application Data\Mozilla\Firefox\Profiles\d2wlnfy9.default\
FF - prefs.js: browser.search.selectedEngine - Ask.com
FF - prefs.js: browser.startup.homepage - hxxp://msn.co.nz/
FF - prefs.js: keyword.URL - hxxp://websearch.ask.com/redirect?client=ff&src=kw&tb=CLA&o=15306&locale=en_US&q=
FF - prefs.js: network.proxy.type - 4
FF - plugin: c:\program files\Google\Update\1.2.183.13\npGoogleOneClick8.dll
FF - HiddenExtension: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\
---- FIREFOX POLICIES ----
c:\program files\Mozilla Firefox\greprefs\all.js - pref("ui.use_native_colors", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.lu", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.nu", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.nz", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgberp4a5d4ar", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--p1ai", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbayh7gpa", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.tel", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.auth.force-generic-ntlm", false);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.proxy.type",                  5);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("dom.ipc.plugins.timeoutSecs", 45);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("svg.smil.enabled", false);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("accelerometer.enabled", true);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.allow_unrestricted_renego_everywhere__temporarily_available_pref", true);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.renego_unrestricted_hosts", "");
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.treat_unsafe_negotiation_as_broken", false);
c:\program files\Mozilla Firefox\greprefs\security-prefs.js - pref("security.ssl.require_safe_negotiation",  false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.name", "chrome://browser/locale/browser.properties");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("extensions.{972ce4c6-7e08-4474-a285-3208198ce6fd}.description", "chrome://browser/locale/browser.properties");
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("plugins.update.notifyUser", false);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.nptest.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npswf32.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npctrl.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled.npqtplugin.dll", true);
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled", false);
Toolbar-Locked - (no file)
AddRemove-PConPoint_is1 - c:\program files\PConPoint\unins000.exe
Rootkit scan 2010-07-09 01:17
scanning hidden processes ...
scanning hidden files ...
scan completed successfully
hidden files: 0
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\exwklhtf]
"ServiceDll"="c:\windows\system32\dkzjpky.dll"
[HKEY_USERS\.Default\Software\Microsoft\Internet Explorer\User Preferences]
@Denied: (2) (LocalSystem)
"88D7D0879DAB32E14DE5B3A805A34F98AFF34F5977"=hex:01,00,00,00,d0,8c,9d,df,01,15,
   d1,11,8c,7a,00,c0,4f,c2,97,eb,01,00,00,00,e3,5c,5e,e3,ac,7a,b1,48,bb,c3,48,\
"2D53CFFC5C1A3DD2E97B7979AC2A92BD59BC839E81"=hex:01,00,00,00,d0,8c,9d,df,01,15,
[HKEY_USERS\S-1-5-21-854245398-162531612-682003330-1003\Software\Microsoft\SystemCertificates\AddressBook*]
@Allowed: (Read) (RestrictedCode)
- - - - - - - > 'lsass.exe'(812)
c:\windows\system32\mwtsp.dll
Completion time: 2010-07-09  01:19:49
ComboFix-quarantined-files.txt  2010-07-08 13:19
Pre-Run: 58,085,769,216 bytes free
Post-Run: 58,069,913,600 bytes free
WindowsXP-KB310994-SP2-Home-BootDisk-ENU.exe
[boot loader]
timeout=2
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /Execute /fastdetect
- - End Of File - - 416AA1E6DEF81F2AEDFB29492FC61F8B
thanks
Hi, Deb.
Why did you rename ComboFix as Clark76.exe"?
Please take care of escan before proceeding further!  Here is a link for the escan removal tool:  http://www.microworldsystems.com/download/tools/esremove.exe  Before you use it, be sure to have a replacement anti-virus software downloaded and ready to install.  The following are A/V and Firewalls are free for personal use.
Free Antivirus Software:
avast! 5 Home Edition
Avira AntiVir PersonalEdition Classic
Microsoft Security Essentials
Free Firewalls:
It appears you have been using a registry cleaner.  I strongly advise you to reconsider that as registry cleaners tend to do more harm than good.
I also note the AskToolbar installed on your computer.  You may want to read Current Practices of IAC/Ask Toolbars.  If you decide to remove it, check Add/Remove programs for an uninstall option.
Custom CFScript
File::
Folder::
  • Close any open browsers.
  • Click Start
  • When asked, allow the activex control to install
  • Click Start
  • Click Scan
  • Wait for the scan to finish
Deb
HI
Windows firewall is still showing escan may be out of date but the remove was successful and all clear in both control panel and program folder. Here is combo log off to run scan now thanks for all your help - amazing
ComboFix 10-07-07.01 - Owner 10/07/2010  16:10:03.2.2 - x86
Microsoft Windows XP Home Edition  5.1.2600.3.1252.1.1033.18.1022.749 [GMT 12:00]
Running from: c:\documents and settings\Owner\Desktop\ComboFix.exe.exe
Command switches used :: c:\documents and settings\Owner\Desktop\CFScript.txt
FILE ::
"c:\windows\system32\KmRemove.dat"
"c:\windows\system32\MsiExec.dat"
"c:\windows\system32\nvudisp.dat"
"c:\windows\system32\rundll32.dat"
"c:\windows\uninst.dat"
"c:\windows\UNNeroBackItUp.dat"
"c:\windows\UNNeroMediaHome.dat"
"c:\windows\UNNeroShowTime.dat"
"c:\windows\UNNeroVision.dat"
"c:\windows\UNRecode.dat"
(((((((((((((((((((((((((((((((((((((((   Drivers/Services   )))))))))))))))))))))))))))))))))))))))))))))))))
-------\Legacy_exwklhtf
-------\Service_exwklhtf
(((((((((((((((((((((((((   Files Created from 2010-06-10 to 2010-07-10  )))))))))))))))))))))))))))))))
2010-07-10 03:38 . 2010-07-10 03:39   6203745   ----a-w-   c:\windows\REGBK10.ZIP
2010-07-10 03:35 . 2010-07-10 03:37   --------   d-----w-   c:\documents and settings\Owner\Application Data\Download Manager
2010-07-09 01:10 . 2010-04-29 03:39   38224   ----a-w-   c:\windows\system32\drivers\mbamswissarmy.sys
2010-07-09 01:10 . 2010-07-09 01:10   --------   d-----w-   c:\program files\Malwarebytes' Anti-Malware
2010-07-09 01:10 . 2010-04-29 03:39   20952   ----a-w-   c:\windows\system32\drivers\mbam.sys
2010-07-09 00:19 . 2010-07-09 00:19   --------   d-sh--w-   c:\documents and settings\Administrator\IECompatCache
2010-07-09 00:18 . 2010-07-09 00:18   --------   d-sh--w-   c:\documents and settings\Administrator\PrivacIE
2010-07-08 12:04 . 2010-07-10 04:00   --------   d-----w-   C:\ComboFix.exe
2010-07-04 06:57 . 2010-07-10 04:06   --------   d-----w-   c:\documents and settings\Owner\Local Settings\Application Data\Temp
2010-07-10 03:34 . 2010-01-07 06:54   664   ----a-w-   c:\windows\system32\d3d9caps.dat
2010-07-04 09:03 . 2010-07-04 09:00   71680   ----a-w-   c:\documents and settings\All Users\Application Data\NOS\Adobe_Downloads\arh.exe
2010-07-02 09:17 . 2010-07-02 08:56   2568656   ----a-w-   c:\documents and settings\All Users\Application Data\NOS\Adobe_Downloads\install_flash_player.exe
2010-07-02 09:07 . 2010-07-02 08:56   1025992   ----a-w-   c:\documents and settings\All Users\Application Data\NOS\Adobe_Downloads\SecurityScan_Release.exe
REGEDIT4
exwklhtf
2010-07-10 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
2010-07-10 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-07-09 c:\windows\Tasks\User_Feed_Synchronization-{50A9C00E-06C1-442E-8161-44D674D61CD3}.job
Rootkit scan 2010-07-10 16:16
hidden files: 0
- - - - - - - > 'explorer.exe'(4004)
c:\windows\system32\AEADISRV.EXE
c:\windows\ATKKBService.exe
c:\program files\Java\jre6\bin\jqs.exe
c:\program files\Common Files\LightScribe\LSSrvc.exe
c:\program files\Common Files\Microsoft Shared\VS7Debug\mdm.exe
c:\program files\Common Files\Panda Software\PavShld\pavprsrv.exe
c:\windows\system32\wscntfy.exe
c:\program files\Common Files\Ahead\Lib\NMIndexStoreSvr.exe
c:\program files\Common Files\Ahead\Lib\NMIndexingService.exe
Completion time: 2010-07-10  16:22:32 - machine was rebooted
ComboFix-quarantined-files.txt  2010-07-10 04:22
ComboFix2.txt  2010-07-08 13:19
Pre-Run: 58,016,800,768 bytes free
Post-Run: 57,920,765,952 bytes free
- - End Of File - - C274F6E32B2820ECBC499F51F69C7697
Deb
C:\System Volume Information\_restore{24ECAB32-E39B-4E0A-A332-0A948B9D6334}\RP54\A0111992.exe   a variant of Win32/Adware.ErrorClean application   cleaned by deleting - quarantined
System is running much better no reset of servers seem to be able to connect to sites again and update is down loading. Have removed ask tool bar yet it is still on google even though disabled I removed it through control panel
Thanks
Deb
Hi, Deb.
We can take care of the leftover ASK and escan entry with Combofix.  What antivirus software are you installing to replace escan?
Custom CFScript
SecCenter::
Folder::
Registry::
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{D4027C7F-154A-4066-A1AD-4243D8127440}]
"{D4027C7F-154A-4066-A1AD-4243D8127440}"=-
[-HKEY_CLASSES_ROOT\clsid\{d4027c7f-154a-4066-a1ad-4243d8127440}]
[-HKEY_CLASSES_ROOT\GenericAskToolbar.ToolbarWnd.1]
[-HKEY_CLASSES_ROOT\TypeLib\{2996F0E7-292B-4CAE-893F-47B8B1C05B56}]
[-HKEY_CLASSES_ROOT\GenericAskToolbar.ToolbarWnd]
Firefox::
Firefox -: Profile - c:\documents and settings\Owner\Application Data\Mozilla\Firefox\Profiles\d2wlnfy9.default\
Firefox -: prefs.js: browser.search.selectedEngine - Ask.com
Deb
Hi
Trend Micro Professional I have installed and it has removed the escan message plus ask has gone from firefox browser all running aok - thank you so much for all you have done to help me
Deb
Hi, Deb.
Please post the last Combofix log so we can finish.
Deb
Hi
I have been trying to download another combofix.exe as mine saying it is out of date can you please supply the link as I am not getting anywhere my computer is so slow I could sleep for the night wake up and it would still be trying. thats a joke, do you want me to add the special script again or run combofix without it
Than
ks Deb
Hi, Deb.
Too much time has passed for you to be running ComboFix again unless we know what is happening.
Please download random's system information tool (RSIT):
  • Download RSIT by random/random from here and save it to your desktop.
  • Double-click RSIT.exe to run RSIT.
  • Once it has finished, two logs will open. Please post the contents of both log.txt (<<will be maximized) and info.txt (<<will be minimized).
