LandzDown Forum
September 03, 2010, 03:46:00 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News:
   Home   Help Search Members Staff List Login Register
Pages: [1]   Go Down
  Print
Author Topic: Quintessential Player News  (Read 1768 times)
VoodØØ Child™
Update Moderator
Hero Member
Offline Offline
« on: July 14, 2005, 02:28:14 AM »
It's Time For A Change
Stop what you're doing, find shelter and call your mom, because Quintessential Player 4.5 is here. This version brings you closer to your music than ever before. Stop letting your media player push you around, take control with Quintessential's new and improved arsenal of features.
QCD is still all about you. With its new extended freeform skinning engine and plethora of feature extending plugins Quintessential Player can be whatever you want it to be.
Most importantly you can take control of your listening experience for FREE. How is this possible you ask? It just is. Don't let the price fool you, there are no Pro versions, cripples, nags or spyware. Quintessential is here to be enjoyed without any catches.
For more information take the Quintessential Tour!
Product Info: Quintessential Player
Download: Player v.4.51
Logged
Microsoft® MVP Consumer Security
Jasper The Rasper
Update Moderator
Full Member
Offline Offline
« Reply #1 on: May 01, 2007, 09:45:05 PM »
Build 117 (development)
May 1st, 2007
Changes
  • fixed core - play queue ordering fix
  • fixed core - import from play queue fix (bug #1731)
  • fixed plugin - MediaSource finite streams not reading to end
  • fixed plugin - MP3 seekable streams werent showing progress slider
  • fixed plugin - crash on importing WAV files
  • updated core - moved to SQLite for ML database implementation
  • updated plugin - CDDA device code, separate playback speed setting
  • updated ML - changed DB engine to use SQLite
  • added core - VST DSP plugin hosting support
  • added skinning - title bar control (for double-click maximize)
  • removed Gracenote Auto-Playlist due to inadequacies
  • installer now remembers settings between installations
More Info: Quintessential Player
Last Stable Release: 4.51 (11th May 2004)
Logged
Member of ASAP
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
