A.
Connect to LandzDown Forum IRC via an IRC Client- Server: irc.landzdown.com
- Port: 6667
- Upon connecting, join channel #Landzdown.com
- Sample using Trillian:
B.
Register Your NicknameThis action will register your nickname in the NickServ database. You register your nickname with a password and an email address. Once your nick is registered, you can set the identity in the IRC client to simplify connecting.
- Register: /msg nickserv register PASSWORD EMAIL
- Replace PASSWORD with a password of your choice and EMAIL with a VALID email address.
This action tells NickServ that you are really the owner of this nick. Many commands require you to authenticate yourself with this command before you use them.
- Identify: /msg nickserv identify PASSWORD
- Replace PASSWORD with the same password you used to register your nickname.
C.
Connection Settings After registering your nickname, automate the Identify/logon process by adding the User ID string, as shown in the following sample.
- Ident Settings: /ns identify PASSWORD;/join #LandzDown.com
- Enter the nickname you previously registered.
