This is how I removed this crap. The method is probably different from case to case, depending on what the downloader is fetching.
So I will keep strictly to how I did:
Tools needed:
Ewido malware-remover
http://www.ewido.net/en/download/datFind.bat :
http://virus-protect.net/bat/datFind.bat Blacklight Beta by F-Secure:
http://www.f-secure.com/blacklight/help/HiJackThis :
http://www.thespykiller.co.uk/files/HJTsetup.exeTaskmanager (Ctrl+Alt+Del)
In my case it installed "UnSpy", which sent up a baloon in the taskbar.It could just as well look like this:
http://sunbeltblog.blogspot.com/2005/12/new-exploit-blows-by-fully-patched.htmlStart by going to the control panel applet and uninstall whatever strange "antispyware" that is present.
Then HiJack This showed those details, fix them:
O2 - BHO: SearchToolbar - {08BEC6AA-49FC-4379-3587-4B21E286C19E} - C:\WINNT\system32\gvhfx.dll
O3 - Toolbar: SearchToolbar - {08BEC6AA-49FC-4379-3587-4B21E286C19E} - C:\WINNT\system32\gvhfx.dll
O4 - HKCU\..\Run: [UnSpyPC] "C:\Program\UnSpyPC\UnSpyPC.exe"
O9 - Extra button: Scan and protect your PC - {BF69DF00-4734-477F-8257-27CD04F88779} - C:\Program\UnSpyPC\UnSpyPC.exe (HKCU)
O9 - Extra 'Tools' menuitem: Scan and protect your PC - {BF69DF00-4734-477F-8257-27CD04F88779} - C:\Program\UnSpyPC\UnSpyPC.exe (HKCU)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: Domain =
O17 - HKLM\Software\..\Telephony: DomainName =
O17 - HKLM\System\CCS\Services\Tcpip\..\{48B1CBE5-F7C9-4647-9E5A-CB28ADE3C636}: NameServer = 85.255.115.3,85.255.112.12
O17 - HKLM\System\CCS\Services\Tcpip\..\{50A7A9D9-4795-4D70-B1FD-83183E8A934A}: NameServer = 85.255.115.3,85.255.112.12
O17 - HKLM\System\CCS\Services\Tcpip\..\{5CE88FF2-E304-47EE-B024-D4E0F2170FB3}: NameServer = 85.255.115.3,85.255.112.12
O17 - HKLM\System\CCS\Services\Tcpip\..\{73486B9A-079D-480E-95D2-0B27292DD2EB}: NameServer = 85.255.115.3,85.255.112.12
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: Domain =
O17 - HKLM\System\CS1\Services\Tcpip\..\{48B1CBE5-F7C9-4647-9E5A-CB28ADE3C636}: NameServer = 85.255.115.3,85.255.112.12
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: Domain =
Reboot into safe mode and remove the UnSpy Folder.
If it´s like in my case, Explorer will act awkwardly. You have to use the taskmanager to terminate and start Explorer, many times when it stops responding
Run Ewido, still in safe mode.
Reboot normally.
Run datFind.bat
It will sort newly installed/changed files by date, in "System" , "System32" ,"Windows\Temp" and the "Windows" folder.
Open the "datFind.bat" and it will sort the files by date, in the different folders.To create them, collapse the open log and click any key and a new log is created. Copy the recent month/2 months of each log into the thread.
Look for suspicious files installed simultaniously, the user should have a rather good opinion of when he was hit by this crap.
The logs are by default stored directly under C:\
Navigate to the suspicious files seen in the logs and remoove them. All of them wont however be found.
Run Blacklight and reboot. Run Ewido again.
If datFind.bat is run now, there should be files in the system32-log that aren´t visible
therefore....
Run Blacklight and this time use the option "Rename" of the files it finds, reboot. For simplicity, write down all filenames before it renames and reboots. If this isn´t done, a search can be done for files with the extension ".exe.ren" after Blacklight is run.
Open Explorer and navigate to the system32- folder and remove the remaining files of the infection, all with file-extendions ".exe.ren"
On thing is still to be made. A registry-key at HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
will have a value of , in my case , csajj.exe (this is one of the files that had to be renamed by Blacklight)
This is how I did to remove the infection installed by the WMF Exploit , which opened the viewer for fax.
Another strange thing that occured while it was installing, was that AVG flagged WISPIS.EXE as infected. I believe that is the program that handles the mouse. I never realized if it was healed or not, but it still works flawlessly.
Die Hard
