Author Topic: TrojanHunter™ Updates  (Read 27842 times)
  • VoodØØ Child™
  • Moderator
« on: July 04, 2005, 05:21:12 PM »
TrojanHunter™
TrojanHunter searches for and removes trojans from your system. With an easy-to-use Scanner and a Guard that scans in the background TrojanHunter is a must-have complement to your virus scanner. If you are downloading files from the Internet, you need TrojanHunter!
Features:
  • High-speed file scan engine capable of detecting modified trojans
  • Memory scanning for detecting any modified variant of a particular build of a trojan
  • Registry scanning for detecting traces of trojans in the registry
  • Inifile scanning for detecting traces of trojans in configuration files
  • Port scanning for detecting open trojan ports
  • The Advanced Trojan Analyzer, an exclusive feature of TrojanHunter, is able to find whole classes of trojans using advanced scanning techniques
  • TrojanHunter Guard for resident memory scanning - detect any trojans if they manage to start up
  • LiveUpdate utility for effortless ruleset updating via the Internet
  • Add custom trojan definitions and detection rules
  • Process list giving details about every running process on the system, including the path to the actual executable file
  • Accurate removal of all detected trojans - even if they are running or if the trojan has injected itself into another process
  • Built-in netstat viewer
  • Extensive help files
  • Free technical support via e-mail
TrojanHunter runs on Windows 95, 98, ME, NT, 2000 and XP
Product Info: TrojanHunter™
Offline roddy32
  • Moderator
Re: TrojanHunter™ Updates
« Reply #1 on: November 08, 2011, 01:49:34 PM »
TrojanHunter V5.5 Build 1002 - Unsure of exact date this was released
To Upgrade:
1.  Save your License.tlf file.
2.  Uninstall the old version of TrojanHunter.
3.  Search for any folder with the word TrojanHunter in the folder name and DELETE any folder found.
4.  Install TrojanHunter V5.5.
NOTE:  When the Install wizard reaches the last window and before you click on "Finish", uncheck the options to start THGuard and TH scanner.  Then click on "Finish".
5.  Move your License.tlf file into TrojanHunter 5.5 folder located at C:\Program Files or C:\Program Files (x86).
6.  Run LiveUpdate to obtain the latest rulesets.
7.  Now run THGuard.exe and TH scanner GUI.
8.  Set up your desired options in THGuard.exe and TrojanHunter scanner GUI.
9.  Run a Full Scan with TrojanHunter scanner.
Direct download link
http://www.trojanhunter.com/products/TrojanHunterSetup.exe
http://www.misec.net/forum/board/Announcements/1319693927
Log'N'Rock Computer Security
Offline Jasper The Rasper
  • Moderator
« Reply #2 on: May 23, 2012, 07:39:24 PM »
TrojanHunter  Ruleset Update -  May 23, 2012
You should have 525783 rules
http://www.misec.net/forum/board/RulesetUpdates/1337772882
Member of ASAP
