Author Topic: Not sure if I have a problem or not.... Windows2008Antivirus?  (Read 7843 times)
« on: October 20, 2008, 02:01:38 PM »
I got a pop up screen a while ago instructing me I had a trojan and should clean it up by downloading something called Windows Antivirus 2008.  Seemed suspicious, but while I was clicking around, I found that an exe file had appeared on my desktop....I didn't open it, just trashed it.
I did a google search and found it was some kind of bogus program.   (I had been using the free AVG antivirus program at the time.)  I have since changed virus programs to CA which comes with our cable provider.  I checked on the CA site and this is what they said about Windows 2008 Antivirus:
Rogue Security Software:  Security software that uses deceptive means for installation and purpose. Once installed, the rogue software usually uses scare tactics to inform the user that spyware or malware is installed on their system. The rogue security software then claims to offer remediation in exchange of payment. These applications can come bundled with other malware that serve other purposes. This software usually comes in the form of Anti-spyware, or Anti-virus applications.
http://www.ca.com/securityadvisor/pest/pest.aspx?id=453134939#section7
All the checks, including AdAware and the CA scan showed no infections. Since the scans were showing clean, I didn't think anymore about it until I ran a Spybot check.
The Spybot check also gave a clean result....except, I noticed these files appearing during the check:
zlob.downloader
zlob.downloader.bs
smitfraud***
virtumonde.dll
virtumonde.sci
virtumonde.sdn
the above series of files took almost 20 minutes to scan (pre-file numbers were flying through...does that mean there are thousands of them?)
I can't find any of these files, or any of the ones listed by CA to remove in regards to Windows 2008 Antivirus by using windows explorer's search function.
Is this something I should be concerned about?
Re: Not sure if I have a problem or not.... Windows2008Antivirus?
« Reply #1 on: October 20, 2008, 02:16:36 PM »
What operating system are you using?
  • Once the program has loaded, select Perform full scan, then click Scan.
  • Be sure that everything is checked, and click Remove Selected.
  • When completed, a log will open in Notepad. Please save it to a convenient location. The log can also be found here: C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt
  • Please post contents of that file in your next reply
« Reply #2 on: October 20, 2008, 02:31:01 PM »
BTW, don't be too hard on yourself ...
Antivirus 2008 tricks the user via deceptive pop-up ads that mimic Windows notifications ... it doesn't matter whether you click the Yes and No button, either way a download starts.
« Reply #3 on: October 20, 2008, 04:35:57 PM »
Thanks for your help. I did exactly as you directed because my friend R-C says that is safe. Thanks R-C for directing me to this site.  :wub:
Windows XP Pro
Intel Pentium Dual Core CPU 2GB RAM
FireFox3
Malwarebytes' Anti-Malware 1.29
Database version: 1298
Windows 5.1.2600 Service Pack 3
10/20/2008 11:23:01 AM
mbam-log-2008-10-20 (11-23-01).txt
Scan type: Full Scan (C:\|D:\|E:\|)
Objects scanned: 129401
Time elapsed: 20 minute(s), 28 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
Folders Infected:
Files Infected:
OK...I'm assuming this is a good thing? Or is something hiding?
If so, what about the files I listed in my first post...what are they?  when I searched the CA site for them, there were entries on each one, but I didn't know how to interpret them.  Please forgive my ignorance...I can get around my computer pretty well, but I don't always know what I'm doing.
Offline R-C
  • Laissez les bons temps rouler!
« Reply #4 on: October 20, 2008, 06:00:21 PM »
Hey gurl! the antivirusxp is a really prevalent nasty lately it seems to be everywhere.  Luckily the great folks here can clean it up. Usually malwarebytes does  good job.
You might find this article of interest it is about this specific infection type.
http://www.theregister.co.uk/2008/08/22/anatomy_of_a_hack/print.html
If you go to any of the help forums like here and BBR etc and look for antivirusxp you will see dozens of them asking for help.
When you see that type of thing pop up do not click anything at all instead do a control alt delete and close out your browser instead that is about the only way to kill it, if you click it automatically starts to install.
You should also go read the articles posted here on clickjacking,  if you have not updated your flash you will want to.
« Reply #5 on: October 20, 2008, 07:04:38 PM »
Installing and Scanning with HijackThis©
  • At the download prompt from one of the above locations, choose "Save"
  • Navigate to the saved file and double-click the installer, HJTsetup.exe
  • By default, HijackThis© will be installed on your computer at C:\Program Files\Trend Micro\HijackThis, making an entry in the Start menu and also providing a Desktop shortcut
  • When the installation is complete, double-click the HijackThis© icon on your Desktop
  • Select "Do a system scan and save the Logfile"
  • When the scan is completed, Notepad will launch with the log.   Please UNcheck Word Wrap in Notepad (Click Format > UNcheck Word Wrap)
  • Do not fix anything that you see in the log. (Scanning will not make any changes to your computer.  Most of what is found is harmless or even required.)
  • Copy/Paste the log here.  (Select Edit > Select All > Edit Copy)
[/list]
« Reply #6 on: October 20, 2008, 07:59:54 PM »
R-C, thanks for the tip on how to deal with antivirusxp. I will remember that!
As Spybot is scanning, a running list of the files appears in the frame's taskbar area.  The file names I listed were ones that appeared there for a longtime during the scan.
The CA scan I ran was totally clean.
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 2:52:11 PM, on 10/20/2008
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16735)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe
C:\Program Files\CA\SharedComponents\HIPSEngine\UmxCfg.exe
C:\Program Files\CA\SharedComponents\HIPSEngine\UmxFwHlp.exe
C:\Program Files\CA\SharedComponents\HIPSEngine\UmxPol.exe
C:\Program Files\CA\SharedComponents\HIPSEngine\UmxAgent.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\ISafe.exe
C:\Program Files\CA\SharedComponents\PPRT\bin\ITMRTSVC.exe
C:\Program Files\Nero\Nero8\Nero BackItUp\NBService.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\VetMsg.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\CA\CA Internet Security Suite\CA Personal Firewall\capfsem.exe
C:\WINDOWS\RTHDCPL.EXE
C:\Program Files\ImageShack\QuickShot\QuickShot.exe
C:\WINDOWS\Samsung\PanelMgr\SSMMgr.exe
C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe
C:\WINDOWS\system32\RUNDLL32.EXE
C:\Program Files\CA\CA Internet Security Suite\cctray\cctray.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spam\QSP-5.1.18.0\QOELoader.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\CAVRID.exe
C:\Program Files\CA\CA Internet Security Suite\CA Personal Firewall\capfasem.exe
C:\Program Files\Common Files\Nero\Lib\NMBgMonitor.exe
C:\Program Files\CA\CA Internet Security Suite\ccprovsp.exe
C:\Program Files\Messenger\msmsgs.exe
C:\Documents and Settings\Helena\Desktop\desktopsV1.01.exe
C:\Program Files\Windows Live\Messenger\MsnMsgr.Exe
C:\Program Files\Common Files\Nero\Lib\NMIndexingService.exe
C:\Program Files\Common Files\Nero\Lib\NMIndexStoreSvr.exe
C:\Program Files\Microsoft Office\Office\1033\msoffice.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\CAPPActiveProtection.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\PPCtlPriv.exe
C:\Program Files\Windows Live\Messenger\usnsvc.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://windowsupdate.microsoft.com/
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [ImageShackUtil] C:\Program Files\ImageShack\QuickShot\QuickShot.exe
O4 - HKLM\..\Run: [Samsung PanelMgr] C:\WINDOWS\Samsung\PanelMgr\SSMMgr.exe /autorun
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe"
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Nero\Lib\NeroCheck.exe
O4 - HKLM\..\Run: [cctray] "C:\Program Files\CA\CA Internet Security Suite\cctray\cctray.exe"
O4 - HKLM\..\Run: [QOELOADER] "C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spam\QSP-5.1.18.0\QOELoader.exe"
O4 - HKLM\..\Run: [CAVRID] "C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\CAVRID.exe"
O4 - HKLM\..\Run: [cafwc] C:\Program Files\CA\CA Internet Security Suite\CA Personal Firewall\cafw.exe -cl
O4 - HKLM\..\Run: [capfasem] C:\Program Files\CA\CA Internet Security Suite\CA Personal Firewall\capfasem.exe
O4 - HKLM\..\Run: [capfupgrade] C:\Program Files\CA\CA Internet Security Suite\CA Personal Firewall\capfupgrade.exe
O4 - HKCU\..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Common Files\Nero\Lib\NMBgMonitor.exe"
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [Sysinternals Desktops] C:\Documents and Settings\Helena\Desktop\desktopsV1.01.exe
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\Windows Live\Messenger\MsnMsgr.Exe" /background
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Reader 8.0\Reader\reader_sl.exe
O4 - Global Startup: Adobe Reader Synchronizer.lnk = C:\Program Files\Adobe\Reader 8.0\Reader\AdobeCollabSync.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O16 - DPF: {56393399-041A-4650-94C7-13DFCB1F4665} (PSFormX Control) - http://www.ca.com/us/securityadvisor/pestscan/pestscan.cab
O16 - DPF: {7B297BFD-85E4-4092-B2AF-16A91B2EA103} (WScanCtl Class) - http://www.ca.com/us/securityadvisor/virusinfo/webscan.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O23 - Service: Lavasoft Ad-Aware Service (aawservice) - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe
O23 - Service: CaCCProvSP - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\ccprovsp.exe
O23 - Service: CAISafe - Computer Associates International, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\ISafe.exe
O23 - Service: CA Pest Patrol Realtime Protection Service (ITMRTSVC) - CA, Inc. - C:\Program Files\CA\SharedComponents\PPRT\bin\ITMRTSVC.exe
O23 - Service: Nero BackItUp Scheduler 3 - Nero AG - C:\Program Files\Nero\Nero8\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Nero\Lib\NMIndexingService.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: PPCtlPriv - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\PPCtlPriv.exe
O23 - Service: HIPS Event Manager (UmxAgent) - CA - C:\Program Files\CA\SharedComponents\HIPSEngine\UmxAgent.exe
O23 - Service: HIPS Configuration Interpreter (UmxCfg) - CA - C:\Program Files\CA\SharedComponents\HIPSEngine\UmxCfg.exe
O23 - Service: HIPS Firewall Helper (UmxFwHlp) - CA - C:\Program Files\CA\SharedComponents\HIPSEngine\UmxFwHlp.exe
O23 - Service: HIPS Policy Manager (UmxPol) - CA - C:\Program Files\CA\SharedComponents\HIPSEngine\UmxPol.exe
O23 - Service: VET Message Service (VETMSGNT) - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\VetMsg.exe
End of file - 8383 bytes
nothing was checked.
« Reply #7 on: October 20, 2008, 10:49:49 PM »
Hi, pastywhitegurl.  Welcome to WebGarden's subforum.  :lol:
Your logs look pretty good but there is one item that I cannot find anything on so would like to take this to another level.
Link 1
Link 2
Link 3
!!! IMPORTANT !!!   Save ComboFix.exe to your Desktop
  • Disable your AntiVirus and AntiSpyware applications. If not disabled, these programs will likely interfere with cleanup process. This can usually be accomplished by a right-click on the icon in the System Tray.
  • As part of the process, ComboFix will check to see if the Microsoft Windows Recovery Console is installed. With malware infections being as they are today, it is strongly recommended to have this pre-installed on your machine before doing any malware removal.  The Recovery Console will allow you to start up the computer in a special recovery/repair mode that will allow us to more easily help you should your computer have a problem after an attempted removal of malware.
    Please note:  If the Microsoft Windows Recovery Console is already installed on the computer, ComboFix will continue the malware removal procedures.
  • When finished, a log will be produced.  Please include the C:\ComboFix.txt in your next reply along with a fresh HijackThis log.
« Reply #8 on: October 21, 2008, 01:28:30 AM »
I don't think I can do the next step as I do not have the Windows XP Pro disc that was used to install xp on my machine to run the Windows Recovery Console. The person that assembled my machine did not give me the disc.
Is it possible that the Windows Recovery Console is already on my machine? If so, where would I look for it?
I'm also nervous about turning off my anti-virus for any length of time.  My computer is networked with another one in our house...would that affect the other computer?  This is sounding like a dangerous operation if I am needing a recovery console. (I'm sorry if these are dumb questions.)
« Reply #9 on: October 21, 2008, 01:50:21 AM »
Hi, pastywhitegurl.
If the Microsoft Windows Recovery Console is already installed on the computer, ComboFix will continue the malware removal procedures.  If it is not installed, ComboFix will download the correct version and install it prior to cleaning.
That said, as it turns out, Winchester73 located what I hadn't found when researching -- which was why I suggested ComboFix.  What I was questioning is actually part of SysInternals.
So, you are off the hook -- with this machine except for just a small cleanup.
Start HijackThis, close all open windows leaving only HijackThis running. Place a check against the following and press "Fix Checked":
Since another machine is networked, I suggest that you scan that machine with MBAM and let us know if there are any problems.
« Reply #10 on: October 21, 2008, 02:28:24 AM »
Can you tell me what you think that 02-BHO.... file is, please?
This whole post was started because of the file names I saw in the Spybot scan. I'd still like to know what those files are and what they are for. I don't seem to have anything affecting my computer function that would suggest any slowing down or redirecting.
Offline R-C
« Reply #11 on: October 21, 2008, 04:44:56 AM »
You don't have to have the xp disc, if you follow the directions through combo fix it links to where you can get it online for your version of OS, it is actually a good idea to install the Recovery console should you ever need it in the future you have it.  But looks like you don't have to do that now so you are clear.
it sounds to me like you were watching spybot do the scan and it was showing its database of what it has listed to look for??? I don't think it was seeing that stuff on your pc because believe me it would have shown up on these logs and your pc would not be functioning if you had all that crud on it LOL.
« Reply #12 on: October 21, 2008, 05:18:46 AM »
Is that what was going by during the scan, what it was looking for?  I couldn't find any documentation about that display to say what it was one way or the other.
And BTW, I've never had that Windows2008Antivirus screen ever pop up again after that first time.
Thank you, everyone, who is trying to help me here. :)
Offline Eric the Red
  • ISO/IEC 27001:2005
« Reply #13 on: October 21, 2008, 06:57:18 AM »
Be assured that that is the case. The scan was displaying the names of the files that it was checking for, like it was ticking them off a list. You now have one of the best tools on the market installed on your machine - MBAM. Registering (buying) MBAM will activate the real time protection module that will protect your computer even further in future (and no, I don't have shares in MBAM!).
Proud member Since 2004
« Reply #14 on: October 21, 2008, 02:51:45 PM »
Actually, what that file was ...
In this case, the "no file" at the end of the line means that this is an orphaned entry.  This BHO was part of Windows Live Messenger and is no longer present, it was left behind when the program was removed, updated, whatever.  Specifically, it was the Windows Live Call HoverToCall class BHO, which is a legitimate item (well, at least, if it was there it would be).
It is perfectly safe to have HJT delete that item.  It is mostly a matter of clean-up and tidying things.  Leaving it alone won't cause any problems since it isn't there.  Your choice.
