Author Topic: This thing won't let me execute ANY program..  (Read 4922 times)
Offline pnimith
« on: June 23, 2009, 01:46:54 AM »
Hi Gurus,
Pl. Help...
I seem to have acquired this new virus (or a cousin thereof) which has put a black screen on my desktop with red words like "WARNING Your computer may be at risk.." and then goes on with a long narrative.
But that of course is the least of my problems. I am not able to open ANYTHING, let alone AV software.
When I boot in safe mode, it does not seem to be active (no process that seems out of place) and AV scan turns up nothing. However, everytime I run the AV scan in safe mode, it shuts down the pc eventually.
I have the HijackThis exe but not able to run it...
Pl. help
Let me know what other information you may need.
thanx
Nimit
Re: This thing won't let me execute ANY program..
« Reply #1 on: June 23, 2009, 02:15:49 AM »
Hi, pnimith.  Welcome to LandzDown Forum.
Although best run in normal mode, see if you can run Malwarebytes' Anti-Malware -- resorting to Safe Mode if need be.  If not, can you run HijackThis in Safe Mode so we can get an idea of what is happening?
  • Once the program has loaded, select Perform full scan, then click Scan.
  • Be sure that everything is checked, and click Remove Selected.
  • When completed, a log will open in Notepad. Please save it to a convenient location. The log can also be found here: C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt
  • Please post contents of that file in your next reply and a fresh HijackThis log.
If successful running Safe Mode, post the log here and then update and scan again in normal mode, also including that log.
Offline pnimith
« Reply #2 on: June 23, 2009, 02:38:35 AM »
Wow! Corrine, Thanx a bunch for coming to rescue so quickly.
But I am impatient by nature. So I went ahead and ran hijackthis.exe in safe mode (As i could not do anything whatsoever in normal mode) and found the following. Again, As I had seen the logo and exe names of the program that was causing all this, i looked for it and removed the exe (I hope to God I havn't messed up or made complete recovery a bit harder now)
Anyway, I rebooted and it seems to be symptom-free now. However, I still want to make sure that its completely clean.
Should I run the hijackthis again?
Here is the one from before I deleted the .exes (Highlighted in red)
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 10:08:38 PM, on 6/22/2009
MSIE: Internet Explorer v7.00 (7.00.6000.16850)
Boot mode: Safe mode
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
F:\HiJackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page = google.net-studio.org
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://mail.google.com/mail/
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Internet Explorer
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = :0
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\userinit.exe
O1 - Hosts: 82.98.231.89 browser-security.microsoft.com
O1 - Hosts: 82.98.231.89 best-click-scanner.info
O1 - Hosts: 82.98.231.89 antivirus-xp-pro-2009.com
O1 - Hosts: 82.98.231.89 microsoft.infosecuritycenter.com
O1 - Hosts: 82.98.231.89 microsoft.softwaresecurityhelp.com
O1 - Hosts: 82.98.231.89 onlinenotifyq.net
O1 - Hosts: 82.98.231.89 antivirusxp-pro-2009.com
O1 - Hosts: 82.98.231.89 microsoft.browser-security-center.com
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\PROGRA~1\MICROS~4\Office12\GrooveShellExtensions.dll
O2 - BHO: Google Gears Helper - {E0FEFE40-FBF9-42AE-BA58-794CA7E3FB53} - C:\Program Files\Google\Google Gears\Internet Explorer\0.5.23.0\gears.dll
O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe"
O4 - HKLM\..\Run: [hpWirelessAssistant] C:\Program Files\hpq\HP Wireless Assistant\HP Wireless Assistant.exe
O4 - HKLM\..\Run: [SynTPLpr] C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\Hp\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [eabconfg.cpl] C:\Program Files\HPQ\Quick Launch Buttons\EabServr.exe /Start
O4 - HKLM\..\Run: [Cpqset] C:\Program Files\HPQ\Default Settings\cpqset.exe
O4 - HKLM\..\Run: [LSBWatcher] c:\hp\drivers\hplsbwatcher\lsburnwatcher.exe
O4 - HKLM\..\Run: [tgcmd] "C:\Program Files\support.com\bin\tgcmd.exe" /server
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe"  -osboot
O4 - HKLM\..\Run: [SmartRAM] C:\Program Files\IObit\Advanced WindowsCare V2\MemCleaner.exe /m
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [vptray] C:\PROGRA~1\Symantec AntiVirus\VPTray.exe
O4 - HKLM\..\Run: [ArcSoft Connection Service] C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe
O4 - HKLM\..\Run: [GrooveMonitor] "C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe"
O4 - HKLM\..\Run: [10589064] C:\Documents and Settings\All Users\Application Data\10589064\10589064.exe
O4 - HKLM\..\Run: [90599056] C:\Documents and Settings\All Users\Application Data\90599056\90599056.exe
O4 - HKCU\..\Run: [Yahoo! Pager] "C:\PROGRA~1\Yahoo!\MESSEN~1\YAHOOM~1.EXE" -quiet
O4 - HKCU\..\Run: [Google Update] "C:\Documents and Settings\PN228885\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" /c
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O4 - Global Startup: Monitor Apache Servers.lnk = C:\Program Files\Apache Software Foundation\Apache2.2\bin\ApacheMonitor.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~4\Office12\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra button: (no name) - {09C04DA7-5B76-4EBC-BBEE-B25EAC5965F5} - C:\Program Files\Google\Google Gears\Internet Explorer\0.5.23.0\gears.dll
O9 - Extra 'Tools' menuitem: &Gears Settings - {09C04DA7-5B76-4EBC-BBEE-B25EAC5965F5} - C:\Program Files\Google\Google Gears\Internet Explorer\0.5.23.0\gears.dll
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~4\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~4\Office12\ONBttnIE.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~4\Office12\REFIEBAR.DLL
O14 - IERESET.INF: START_PAGE_URL=http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=Q305&bd=presario&pf=laptop
O16 - DPF: {15589FA1-C456-11CE-BF01-00AA0055595A} - http://w4s.work4sure.com/c/ge/w4sgeen9.exe
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {3EA4FA88-E0BE-419A-A732-9B79B87A6ED0} (CTVUAxCtrl Object) - http://dl.tvunetworks.com/TVUAx.cab
O16 - DPF: {49232000-16E4-426C-A231-62846947304B} (SysData Class) - http://ipgweb.cce.hp.com/rdqnbk/downloads/sysinfo.cab
O16 - DPF: {8714912E-380D-11D5-B8AA-00D0B78F3D48} (Yahoo! Webcam Upload Wrapper) - http://chat.yahoo.com/cab/yuplapp.cab
O16 - DPF: {D4003189-95B1-4A2F-9A87-F2B03665960D} (VodClient Control Class) - http://www.tvucricket.com/player/vjocx-en-black.cab
O16 - DPF: {DF780F87-FF2B-4DF8-92D0-73DB16A1543A} (PopCapLoader Object) - http://download.games.yahoo.com/games/web_games/popcap/insaniquarium/popcaploader_v6.cab
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\PROGRA~1\MICROS~4\Office12\GrooveSystemServices.dll
O20 - AppInit_DLLs: karna.dat
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
O23 - Service: ArcSoft Connect Daemon (ACDaemon) - ArcSoft Inc. - C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe
O23 - Service: Apache2.2 - Apache Software Foundation - C:\Program Files\Apache Software Foundation\Apache2.2\bin\httpd.exe
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
O23 - Service: Cisco Systems, Inc. VPN Service (CVPND) - Cisco Systems, Inc. - C:\Program Files\Cisco Systems\VPN Client\cvpnd.exe
O23 - Service: Symantec AntiVirus Definition Watcher (DefWatch) - Symantec Corporation - C:\Program Files\Symantec AntiVirus\DefWatch.exe
O23 - Service: Google Update Service (gupdate1c9f079e3117f14) (gupdate1c9f079e3117f14) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: HP WMI Interface (hpqwmi) - Hewlett-Packard Development Company, L.P. - C:\Program Files\HPQ\SHARED\HPQWMI.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LuComServer_3_1.EXE
O23 - Service: SAVRoam (SavRoam) - symantec - C:\Program Files\Symantec AntiVirus\SavRoam.exe
O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
O23 - Service: Symantec SPBBCSvc (SPBBCSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
O23 - Service: Symantec AntiVirus - Symantec Corporation - C:\Program Files\Symantec AntiVirus\Rtvscan.exe
O23 - Service: SymWMI Service (SymWSC) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
O24 - Desktop Component 0: (no name) - http://www.floridashirdisai.org/florida.html#
End of file - 9455 bytes
Offline Paddy
« Reply #3 on: June 23, 2009, 12:36:26 PM »
Follow Corrines instructions and Run Malwarebytes' Anti-Malware. And post the logfile Please.
Paddy..
« Reply #4 on: June 23, 2009, 12:37:49 PM »
Indeed, MBAM will likely find registry keys, etc, that need to be removed.
It is possible/likely that we'll have to do a few other things, seeing these in your HJT log:
Also, "Boot mode: Safe mode" ... yes, please, run HJT again, but this time boot the computer normally first.
Offline pnimith
« Reply #5 on: June 23, 2009, 06:04:53 PM »
Here is the log from MBAM and HijackThis (Ran MBAM first, and then ran Hijackthis, in normal mode)
Malwarebytes' Anti-Malware 1.38
Database version: 2325
Windows 5.1.2600 Service Pack 2
6/23/2009 2:01:28 PM
mbam-log-2009-06-23 (14-01-28).txt
Scan type: Full Scan (C:\|)
Objects scanned: 186600
Time elapsed: 44 minute(s), 43 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 11
Registry Values Infected: 1
Registry Data Items Infected: 6
Folders Infected: 3
Files Infected: 19
(No malicious items detected)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ModuleUsage\c:/windows/downloaded program files/popcaploader.dll (Adware.PopCap) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{c9c5deaf-0a1f-4660-8279-9edfad6fefe1} (Adware.PopCap) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e4e3e0f8-cd30-4380-8ce9-b96904bdefca} (Adware.PopCap) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{fe8a736f-4124-4d9c-b4b1-3b12381efabe} (Adware.PopCap) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{df780f87-ff2b-4df8-92d0-73db16a1543a} (Adware.PopCap) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{df780f87-ff2b-4df8-92d0-73db16a1543a} (Adware.PopCap) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\systemsecurity2009 (Rogue.SystemSecurity) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\popcaploader.popcaploaderctrl2 (Adware.PopCap) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\popcaploader.popcaploaderctrl2.1 (Adware.PopCap) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Software Notifier (Rogue.Multiple) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\instkey (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs\c:\WINDOWS\downloaded program files\popcaploader.dll (Adware.PopCap) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\AntiVirusDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Security Center\AntiVirusDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
Folders Infected:
c:\documents and settings\PN228885\Application Data\GetModule (Trojan.Agent) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\Start Menu\Programs\System Security (Rogue.SystemSecurity) -> Quarantined and deleted successfully.
C:\Program Files\winupdates (Worm.P2P) -> Quarantined and deleted successfully.
Files Infected:
c:\documents and settings\PN228885\local settings\Temp\incosnet.tmp (Trojan.Vundo) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\local settings\Temp\rasesnet.tmp (Trojan.Vundo) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\local settings\Temp\TDSS2be3.tmp (Trojan.TDSS) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\local settings\Temp\TDSS79b4.tmp (Trojan.TDSS) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\local settings\Temp\xpre.tmp (Trojan.Downloader) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\application data\getmodule\dicik.gz (Trojan.Agent) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\application data\getmodule\kwdik.gz (Trojan.Agent) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\application data\getmodule\ofadik.gz (Trojan.Agent) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\start menu\Programs\system security\System Security 2009 Support.lnk (Rogue.SystemSecurity) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\start menu\Programs\system security\System Security 2009.lnk (Rogue.SystemSecurity) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\SKYNETlog.dat (Trojan.Agent) -> Delete on reboot.
c:\WINDOWS\system32\tdssmain.dll (Trojan.Agent) -> Quarantined and deleted successfully.
c:\WINDOWS\system32\drivers\tdssserv.sys (Trojan.Agent) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\local settings\Temp\.tt8.tmp (Trojan.Downloader) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\Local Settings\Temp\wrdwn4 (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\Local Settings\Temp\wrdwn7 (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\Local Settings\Temp\wrdwn8 (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\documents and settings\PN228885\Local Settings\Temp\wrdwn9 (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HiJackthis Log
Scan saved at 2:04:22 PM, on 6/23/2009
Boot mode: Normal
Running processes:
C:\Program Files\Java\jre1.6.0_07\bin\jucheck.exe
C:\PROGRA~1\Citrix\icaweb32\wfica32.exe
C:\WINDOWS\system32\eolupclnt.exe
C:\WINDOWS\system32\rundll32.exe
C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe
C:\Documents and Settings\PN228885\Desktop\ProcessExplorer\procexp.exe
C:\Documents and Settings\PN228885\Desktop\HiJackThis.exe
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
O4 - HKLM\..\RunOnce: [Malwarebytes Anti-Malware (reboot)] "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
End of file - 11038 bytes
Offline Eric the Red
  • ISO/IEC 27001:2005
« Reply #6 on: June 23, 2009, 08:57:49 PM »
You are showing an old and vulnerable version of SunJava:  Please download JavaRa and unzip it to your desktop.
  • Double-click on JavaRa.exe to start the program.  (Windows Vista users Right-click JavaRa.exe > Select Run as Administrator)
Then download and install Java SE Runtime Environment (JRE) 6 Update 14.
Note:  UNCHECK any pre-checked toolbar and/or software options presented with the update.  They are not part of the software update and are completely optional.
Also, please note that if you register MBAM (at a small one-off cost) you will be able to use its realtime protection module to help prevent situations like this arising.
Proud member Since 2004
« Reply #7 on: June 23, 2009, 09:37:19 PM »
Service Pack 3 has been out for a year, is there a reason you haven't updated to it?
How is the computer running now?
Offline pnimith
« Reply #8 on: June 23, 2009, 09:38:45 PM »
Thanx Eric. I have updated my JRE now, following your steps.
Although my original problem seems to have been cured, I still have an issue. Whenever I search google and click on any results (not all, but most links) it takes me to some other site. Its redirecting it to something totally unrelated and of dubious reputation. What I see in status bar is "overclick.cn"...
Any help with this? Right now I am practically shut out off google...
thanx
Offline pnimith
« Reply #9 on: June 23, 2009, 09:41:16 PM »
Winchester73, I had not paid any attention to it. I will do that today. Thanx
And my PC is running fine now, except for the problem I just posted (google results being redirected)
Offline pnimith
« Reply #10 on: June 23, 2009, 09:45:45 PM »
BTW, Winchester73, would you mind guiding me to the cleanest way of updating to sp3? I am not getting any help with google right now.
thanx
« Reply #11 on: June 23, 2009, 10:21:57 PM »
I've seen a lot of this recently. Please follow the advice below carefully, if the infection is still present it may well stop you from going to the links shown below - if that is the case let us know.
Update Malwarebytes Anti Malware (MBAM) and run the scan again, let it deal with any infections found and keep a copy of the logfile.
Please download ATF Cleaner by Atribune from http://www.atribune.org/index.php?option=c...5&Itemid=25 . Save it to your Desktop.
Run ATF Cleaner
Please do an online scan.  Establish an internet connection & perform an online scan with Internet Explorer at Kaspersky Online Scanner
Your Antivirus and/or Antispyware may give a warning during the scan. This is perfectly normal.
Note:
  • This scan is best done from IE (Internet Explorer)
  • Vista users should start IE by Start(Vista Orb) >> Internet Explorer >> Right-Click Run As Admin
Go Here: http://www.kaspersky.com/kos/eng/partner/default/languages/english/check.html?n=1223851135704
  • Read the Requirements and limitations before you click Accept.
  • Once the database has downloaded, click My Computer in the left pane
  • When the scan has completed, click Save Report As...
  • Enter a name for the file in the Filename: text box and then click the down arrow to the right of Save as type: and select text file (*.txt)
  • Click Save - by default the file will be saved to your Desktop, but you can change this if you wish.
Note: To optimize scanning time and produce a more sensible report for review:
  • Close any open programs.
  • Turn off the real-time scanner of all antivirus or antispyware programs while performing the online scan.
Note for Internet Explorer 7 users: If at any time you have trouble viewing the accept button of the license, click on the Zoom tool located at the bottom right of the IE window and set the zoom to 75%. Once the license is accepted, reset to 100%.
Link 1
Link 2
Link 3
Disable your AntiVirus and AntiSpyware applications. If not disabled, these programs will likely interfere with cleanup process. This can usually be accomplished by a right-click on the icon in the System Tray.  This can usually be accomplished by a right-click on the icon in the System Tray.
Note:  If you use AVG, you must also open the AVG 8 Control Center, by right clicking on the AVG 8 icon on task bar as well as the following:
  • Click on Tools.
  • Select Advanced Settings.
  • In the left hand pane, scroll down to "Resident Shield".
  • In the main pane, deselect the option to "Enable Resident Shield."
  • To re-enable AVG 8, please select "Enable Resident Shield" again.
Now, please run ComboFix:
  • When finished, a log will be produced. Please include the Kaspersky log, C:\ComboFix.txt and the MBAM log in your next reply along with a fresh HijackThis log.
« Reply #12 on: June 23, 2009, 10:25:19 PM »
Yeah, I was afraid there might be something else ...  :(
Please do as ETR says BEFORE you attempt to update to SP3.  I trust you are current on the other security updates?  When we're done, we'll have you run a Secunia Software Inspector scan to see what else is out of date.
« Reply #13 on: June 23, 2009, 11:21:15 PM »
You'll note, Nimit, that at LandzDown we don't just double-team people needing help.  No sireee.  We triple- and quadruple-team.  :lol:
« Reply #14 on: June 24, 2009, 01:54:18 AM »
Well, it is a help to have people in different time zones around the world, across the pond, etc ...  :mitch:
