seathach,
ZA says the virus is active and is in file path:
C:\System Volume Information\_restore(F46579BE...
The item or items that are displaying are in the restore folder.
XP has the capability called System Restore. My advice is to empty the system restore folder and the create a new restore point. To do this
Click Start, and then right-click My Computer.
Click Properties.
Click the System Restore tab.
Check Turn off System Restore.
Click Apply, and then click OK.
Restart the computer.
All data, including the items and registry entries will be removed from the restore folder.
After restarting the computer,
"Re-enable System Restore" before going any further you need now to create a fresh restore point after you have done this please can you download
Ad-aware SE Build 106 once installed use the
WebUpDateto get the latest Definition file
SE1R101 27.03.2006) then scan doing a
"Full Scan" and
then post your logfile here by using the
Add-Reply Feature .
