Author Topic: Malware which seems to Primarily Affect PaleMoon (Blue Screen, Audio Alert, etc)  (Read 13009 times)
Offline Nissi1
MSI (s) (60:80) [10:54:01:835]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=1,Remove=1)
MSI (s) (60:80) [10:54:01:835]: Executing op: CleanupConfigData(RemovingProduct=1)
MSI (s) (60:80) [10:54:01:835]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\F228BC5F563B1D34CB0CF4ADA102717A\Patches 3: 2
MSI (s) (60:80) [10:54:01:835]: Executing op: ActionStart(Name=Nero_CA_UninstallSetAssociationsRollback,,)
MSI (s) (60:80) [10:54:01:835]: Executing op: CustomActionSchedule(Action=Nero_CA_UninstallSetAssociationsRollback,ActionType=1281,Source=BinaryData,Target=CA_UninstallSetAssociationsRollback,)
MSI (s) (60:80) [10:54:01:852]: Executing op: ActionStart(Name=Nero_CA_UninstallSetAssociations,,)
MSI (s) (60:80) [10:54:01:853]: Executing op: CustomActionSchedule(Action=Nero_CA_UninstallSetAssociations,ActionType=1025,Source=BinaryData,Target=CA_UninstallSetAssociations,)
MSI (s) (60:8C) [10:54:01:857]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSID98.tmp, Entrypoint: CA_UninstallSetAssociations
MSI (s) (60:80) [10:54:01:919]: Executing op: ActionStart(Name=Nero_CA_DeleteAssociationsBackup,,)
CA_UninstallSetAssociations: CustomActions.cpp : 1016 :  Succeeded
MSI (s) (60:80) [10:54:01:919]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteAssociationsBackup,ActionType=1537,Source=BinaryData,Target=CA_DeleteAssociationsBackup,CustomActionData={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}|)
MSI (s) (60:80) [10:54:01:935]: Executing op: ActionStart(Name=Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore,,)
MSI (s) (60:80) [10:54:01:935]: Executing op: CustomActionSchedule(Action=Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore,ActionType=1537,Source=BinaryData,Target=CA_MergeLocalFileAssociationDbToGlobalAndRestore,CustomActionData={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:935]: Executing op: ActionStart(Name=InstallFinalize,,)
MSI (s) (60:80) [10:54:01:935]: Executing op: CleanupTempFiles(TempFiles=C:\WINDOWS\Installer\33a1c1a9.mst)
MSI (s) (60:80) [10:54:01:935]: Scheduling file 'C:\WINDOWS\Installer\33a1c1a9.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:80) [10:54:01:935]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=43522000)
MSI (s) (60:80) [10:54:01:954]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:80) [10:54:01:973]: User policy value 'DisableRollback' is 0
MSI (s) (60:80) [10:54:01:973]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:80) [10:54:01:973]: Unlocking Server
MSI (s) (60:80) [10:54:01:973]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
Action ended 10:54:01: InstallFinalize. Return value 1.
Action ended 10:54:01: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): UpgradeCode = {403096B5-2B75-4FAE-BC57-6535C9E50B79}
Property(S): ROOTDRIVE = C:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): UILevel = 3
Property(S): OriginalDatabase = C:\Windows\Installer\11a68.msi
Property(S): ProductCode = {F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}
Property(S): DATABASE = C:\Windows\Installer\11a68.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.3.14393.0
Property(S): MsiNetAssemblySupport = 4.6.1586.0
Property(S): Date = 6/11/2017
Property(S): Time = 10:54:01
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 23
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 1033
Property(S): ComputerName = ZANDRAJONES-PC
Property(S): UserLanguageID = 1033
Property(S): UserSID = S-1-5-21-3088507388-2561779440-336279174-1001
Property(S): LogonUser = Zandra Jones
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 5078
Property(S): PhysicalMemory = 3839
Property(S): Intel = 16
Property(S): Msix64 = 16
Property(S): MsiAMD64 = 16
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): Installed = 2010/10/07 12:23:02
Property(S): RecentFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): WindowsVolume = C:\
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 9600
Property(S): VersionNT64 = 603
Property(S): VersionMsi = 5.00
Property(S): VersionDatabase = 200
Property(S): PRODUCTLANGUAGE = 0
Property(S): MsiSystemRebootPending = 1
Property(S): CLIENTPROCESSID = 8728
Property(S): CLIENTUILEVEL = 2
Property(S): CURRENTDIRECTORY = C:\WINDOWS\system32
Property(S): REMOVE = ALL
Property(S): ISCHAINER = 1
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): REBOOT = ReallySuppress
Property(S): NERO.IS_CHAINED = YES
Property(S): ProductState = 5
Property(S): TRANSFORMS = C:\Windows\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst
Property(S): PackageCode = {B9F7A147-EE44-48AE-B20E-9D2DCE597782}
Property(S): VersionNT = 603
Property(S): Nero_CA_DeleteAssociationsBackup = {F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}|
Property(S): Nero_CA_DeleteLocalFileAssociationDb = {F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}
Property(S): Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore = {F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}
Property(S): TARGETDIR = C:\
Property(S): ALLUSERSPROFILE = C:\ProgramData\
Property(S): CONTENT_PACK_BASE_DIR = C:\Program Files (x86)\Nero\NeroContent\
Property(S): AUDIO = C:\Program Files (x86)\Nero\NeroContent\Audio\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): AppDataFolder = C:\Users\Zandra Jones\AppData\Roaming\
Property(S): INSTALLDIR = C:\Program Files (x86)\Nero\Nero 10\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Nero\Nero 10\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Nero\Nero 10\Database\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FavoritesFolder = C:\Users\Zandra Jones\Favorites\
Property(S): FontsFolder = C:\WINDOWS\Fonts\
Property(S): GlobalAssemblyCache = C:\
Property(S): NERO_PRODUCT = C:\Program Files (x86)\Nero\Nero 10\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Zandra Jones\AppData\Local\
Property(S): MOVIEWIZARD = C:\Program Files (x86)\Nero\NeroContent\MovieWizard\
Property(S): MyPicturesFolder = C:\Users\Zandra Jones\Pictures\
Property(S): NERO = C:\Program Files (x86)\Nero\
Property(S): PersonalFolder = C:\Users\Zandra Jones\Documents\
Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): SMART3D = C:\Program Files (x86)\Nero\NeroContent\Smart3D\
Property(S): STANDARD2D = C:\Program Files (x86)\Nero\NeroContent\Standard2D\
Property(S): SendToFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System16Folder = C:\
Property(S): System64Folder = C:\WINDOWS\SysWOW64\
Property(S): SystemFolder = C:\WINDOWS\SysWOW64\
Property(S): TempFolder = C:\Users\ZANDRA~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = C:\Users\Zandra Jones\
Property(S): WindowsFolder = C:\WINDOWS\
Property(S): _24CFE834C76B4F6987AC58D563593FC5 = C:\Program Files (x86)\Nero\NeroContent\Audio\movingwalls_nsla\
Property(S): _AC8A68EFFC2D4D25AAA0384E2B4B91A4 = C:\Program Files (x86)\Nero\NeroContent\Audio\oldfilm_nsla\
Property(S): _422AE2E4A86D48A09F91523B7851F097 = C:\Program Files (x86)\Nero\NeroContent\Audio\slideshow1_nsla\
Property(S): _DDBAFAAB8CD94096A2D8C92FD3AEADBE = C:\Program Files (x86)\Nero\NeroContent\MovieWizard\MovingWalls\
Property(S): _06CD8A166C7145FE9968183A70A191DC = C:\Program Files (x86)\Nero\NeroContent\MovieWizard\OldFilm\
Property(S): _FCDAB9BD86B24530912B860B63967352 = C:\Program Files (x86)\Nero\NeroContent\MovieWizard\Slideshow1\
Property(S): _5FE23C7D36F5473188A6DEF41E840A6C = C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\
Property(S): _A384339D049443119A845059E6673E1E = C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\
Property(S): _44225752A7854E158523D3F2082B3147 = C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\MovingWalls\
Property(S): _6951875C8E0E44288D34383F087AD2CE = C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\
Property(S): _04FA6424B4D64411A91974F6800FC99E = C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\MovingWalls\
Property(S): _F44BBEC9DB4242DD87260C130A11364F = C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\
Property(S): _214B79D549344F3B8180698D7739C937 = C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Movement\
Property(S): _D9352A49F30E437AB4881AD615C5115A = C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\OldFilm\
Property(S): _F0254BC6E7DB4E22B65B700B589ECA4D = C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Slideshow\
Property(S): _4E0ABE6DA6CD40198A39C791D3B1DDF3 = C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\
Property(S): _A8FC11ED064B4065A0CA4C4CA3AB98E6 = C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Movement\
Property(S): _E3A68969D2AE4B35AE3CDE3E6D33CE19 = C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\OldFilm\
Property(S): _CFC2AE216EB7495D8A422FB00B5EC54F = C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Slideshow\
Property(S): COMP_INSTALL_DIR.E455A55D_C7C4_4A4C_8F90_B137097E5BCF = C:\Program Files (x86)\Nero\NeroContent\
Property(S): IS_CONTENT_PACK_LOC_FOUND.E455A55D_C7C4_4A4C_8F90_B137097E5BCF = 0
Property(S): Nero.MainComponent = {4C4F1A46-D98F-4176-83F0-1F38CF332AC4}
Property(S): ARPURLINFOABOUT = http://www.nero.com/
Property(S): BROWSERPATH = C:\Program Files (x86)\Mozilla Firefox\firefox.exe
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): _IsMaintenance = Change
Property(S): RestartManagerOption = CloseRestart
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): Display_IsBitmapDlg = 1
Property(S): NERO.INSTALL_AUTOPLAY = 1
Property(S): NERO.INSTALL_DESKTOPSHORTCUT = 1
Property(S): NERO.INSTALL_EXTENSIONS = 1
Property(S): ALLUSERS = 1
Property(S): ARPNOMODIFY = 1
Property(S): ARPNOREPAIR = 0
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): AgreeToLicense = No
Property(S): DWUSINTERVAL = 30
Property(S): DWUSLINK = CEDC87AF3EEC9728FEACA09FCECC978F3E1CA78FDEFBD0E8CEFC97BFAEABF0CFBECCF098D9AC
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): ErrorDialog = SetupError
Property(S): INSTALLLEVEL = 100
Property(S): ISVROOT_PORT_NO = 0
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PREVENT_DOWNGRADE_EXIT = A newer version of this application is already installed on this computer. If you wish to install this version, please uninstall the newer version first. Click OK to exit the wizard.
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): InstallChoice = AR
Property(S): MSIDISABLERMRESTART = 0
Property(S): MSIRMSHUTDOWN = 0
Property(S): Manufacturer = Nero AG
Property(S): NERO.APPID = 94
Property(S): NERO.INSTALLER_CATEGORY = 2
Property(S): NERO.LANGUAGES_INSTALL = zh-TW,cs-CZ,da-DK,de-DE,el-GR,en-US,es-ES,fi-FI,fr-FR,hu-HU,it-IT,ja-JP,ko-KR,nl-NL,nb-NO,pl-PL,pt-BR,pt-PT,ru-RU,sv-SE,th-TH,tr-TR,zh-CN
Property(S): NERO.LANGUAGE_CURRENT = en-US
Property(S): NERO.PRODUCT_LINE = NeroX
Property(S): Nero.AppDesc = Apply clever abstract 2D and 3D scenery effects, titles, credit screens, and audio tracks to your movie.
Property(S): Nero.AppSubKey = Nero Movie ThemePack Basic
Property(S): Nero.GenerationId = 10
Property(S): Nero.GenerationName = Nero 10
Property(S): Nero.PackageName = NPMOVB
Property(S): Nero.TemplateRev = 162991
Property(S): Nero.mediaPath = \moviethemepackbasic\
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = Nero 10 Movie ThemePack Basic
Property(S): ProductVersion = 10.2.10200.0.0
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): SecureCustomProperties = INSTALLDIR;ISFOUNDNEWERPRODUCTVERSION;IS_MINOR_UPGRADE;MEDIAPACKAGEPATH;MSIRESTARTMANAGERCONTROL;MSIDISABLERMRESTART;MSIRMSHUTDOWN;NERO.INSTALL_DESKTOPSHORTCUT;NERO.INCLUDED_KEY;NERO.INSTALL_AUTOPLAY;NERO.INSTALL_EXTENSIONS;NERO.INSTALLER_CATEGORY;NERO.IS_EULA_ACCEPTED;NERO.LANGUAGE_CURRENT;NERO.PRODUCT_LINE;NERO.IS_CHAINED;REBOOT;REINSTALL;REINSTALLMODE;SUPPORTDIR;TRANSFORMS
Property(S): ISReleaseFlags = Application,Languages,SystemIntegration
Property(S): MsiLogFileLocation = C:\Users\ZANDRA~1\AppData\Local\Temp\MSI1b9f9.LOG
Property(S): ARPINSTALLLOCATION = C:\Program Files (x86)\Nero\Nero 10\
Property(S): COMPANYNAME = Microsoft
Property(S): USERNAME = AutoBVT
MSI (s) (60:80) [10:54:02:035]: Note: 1: 1724
MSI (s) (60:80) [10:54:02:035]: Product: Nero 10 Movie ThemePack Basic -- Removal completed successfully.
MSI (s) (60:80) [10:54:02:035]: Windows Installer removed the product. Product Name: Nero 10 Movie ThemePack Basic. Product Version: 10.2.10200.0.0. Product Language: 1033. Manufacturer: Nero AG. Removal success or error status: 0.
MSI (s) (60:80) [10:54:02:035]: Attempting to delete file C:\WINDOWS\Installer\33a1c1a9.mst
MSI (s) (60:80) [10:54:02:076]: Deferring clean up of packages/files, if any exist
MSI (s) (60:80) [10:54:02:076]: Attempting to delete file C:\WINDOWS\Installer\33a1c1a9.mst
MSI (s) (60:80) [10:54:02:077]: Unable to delete the file outside of the engine. LastError = 2
MSI (s) (60:80) [10:54:02:077]: MainEngineThread is returning 0
=== Logging stopped: 6/11/2017  10:54:02 ===
MSI (c) (18:18) [10:54:02:077]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (c) (18:18) [10:54:02:077]: MainEngineThread is returning 0
=== Verbose logging stopped: 6/11/2017  10:54:02 ===
=== Verbose logging started: 6/11/2017  10:54:02  Build type: SHIP UNICODE 5.00.10011.00  Calling process: C:\Users\ZANDRA~1\AppData\Local\Temp\MSIE858.tmp ===
MSI (c) (18:98) [10:54:02:108]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (18:DC) [10:54:02:108]: Resetting cached policy values
MSI (c) (18:DC) [10:54:02:108]: Machine policy value 'Debug' is 0
MSI (c) (18:DC) [10:54:02:108]: ******* RunEngine:
           ******* Product: C:\Windows\Installer\11a60.msi
           ******* Action:
           ******* CommandLine: **********
MSI (c) (18:DC) [10:54:02:124]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (18:DC) [10:54:05:128]: Failed to grab execution mutex. System error 258.
MSI (c) (18:DC) [10:54:05:135]: Cloaking enabled.
MSI (c) (18:DC) [10:54:05:135]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (18:DC) [10:54:05:135]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (60:38) [10:54:05:135]: Running installation inside multi-package transaction C:\Windows\Installer\11a49.msi
MSI (s) (60:38) [10:54:05:135]: Grabbed execution mutex.
MSI (s) (60:AC) [10:54:05:135]: Resetting cached policy values
MSI (s) (60:AC) [10:54:05:135]: Machine policy value 'Debug' is 0
MSI (s) (60:AC) [10:54:05:135]: ******* RunEngine:
           ******* Action:
MSI (s) (60:AC) [10:54:05:150]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (60:AC) [10:54:05:166]: MSCOREE not loaded loading copy from system32
MSI (s) (60:AC) [10:54:05:166]: End dialog not enabled
MSI (s) (60:AC) [10:54:05:166]: Original package ==> C:\Windows\Installer\11a60.msi
MSI (s) (60:AC) [10:54:05:166]: Package we're running from ==> C:\Windows\Installer\11a60.msi
MSI (s) (60:AC) [10:54:05:166]: APPCOMPAT: Uninstall Flags override found.
MSI (s) (60:AC) [10:54:05:166]: APPCOMPAT: Uninstall VersionNT override found.
MSI (s) (60:AC) [10:54:05:166]: APPCOMPAT: Uninstall ServicePackLevel override found.
MSI (s) (60:AC) [10:54:05:166]: APPCOMPAT: looking for appcompat database entry with ProductCode '{237CCB62-8454-43E3-B158-3ACD0134852E}'.
MSI (s) (60:AC) [10:54:05:166]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (60:AC) [10:54:05:213]: Machine policy value 'DisablePatch' is 0
MSI (s) (60:AC) [10:54:05:213]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (60:AC) [10:54:05:213]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (60:AC) [10:54:05:213]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (60:AC) [10:54:05:213]: Looking for file transform: C:\Windows\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\1033.mst
MSI (s) (60:AC) [10:54:05:230]: File will have security applied from OpCode.
MSI (s) (60:AC) [10:54:05:235]: Original transform ==> C:\Windows\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\1033.mst
MSI (s) (60:AC) [10:54:05:235]: Transform we're running from ==> C:\WINDOWS\Installer\33a1c1ad.mst
MSI (s) (60:AC) [10:54:05:235]: SOFTWARE RESTRICTION POLICY: Verifying transform --> 'C:\Windows\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\1033.mst' against software restriction policy
MSI (s) (60:AC) [10:54:05:235]: SOFTWARE RESTRICTION POLICY: C:\Windows\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\1033.mst has a digital signature
MSI (s) (60:AC) [10:54:05:251]: SOFTWARE RESTRICTION POLICY: C:\Windows\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\1033.mst is permitted to run at the 'unrestricted' authorization level.
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: _Tables 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: _Columns 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Media 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: File 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: TRANSFORM: 'PatchPackage' table is missing or empty.  No pre-transform fixup necessary.
MSI (s) (60:AC) [10:54:05:251]: TRANSFORM: Applying regular transform to database.
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: ActionText 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: AdminExecuteSequence 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Condition 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: AdminUISequence 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: AdvtExecuteSequence 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: AdvtUISequence 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: AppSearch 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Feature 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Binary 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: CheckBox 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Component 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Icon 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: ComboBox 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Directory 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Control 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Dialog 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: ControlCondition 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: ControlEvent 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: CreateFolder 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: CustomAction 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: ModuleSignature 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Error 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: EventMapping 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: FeatureComponents 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: InstallExecuteSequence 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: InstallUISequence 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: LaunchCondition 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: ListBox 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: ListView 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: ModuleComponents 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: MsiFileHash 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: RadioButton 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Registry 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: RegLocator 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: TextStyle 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: UIText 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: Upgrade 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: _Validation 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: ISComponentExtended 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: ISCustomActionReference 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: _MsiPatchTransformView 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: #_BaselineCost 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: #_BaselineFile 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: #_BaselineData 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: #_PatchCache 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: MsiPatchCertificate 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: MsiDigitalCertificate 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: APPCOMPAT: looking for appcompat database entry with ProductCode '{237CCB62-8454-43E3-B158-3ACD0134852E}'.
MSI (s) (60:AC) [10:54:05:251]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (60:AC) [10:54:05:251]: Transforms are not secure.
MSI (s) (60:AC) [10:54:05:251]: Transforming table Property.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\ZANDRA~1\AppData\Local\Temp\MSI1b9f9.LOG'.
MSI (s) (60:AC) [10:54:05:251]: Command Line: NERO.IS_CHAINED=YES REBOOT=ReallySuppress MSIRESTARTMANAGERCONTROL=Disable ISCHAINER=1 REMOVE=ALL CURRENTDIRECTORY=C:\WINDOWS\system32 CLIENTUILEVEL=2 CLIENTPROCESSID=8728
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{19C411BD-15F8-4A1D-9D1B-94CA36079589}'.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding TRANSFORMS property. Its value is 'C:\Windows\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\1033.mst'.
MSI (s) (60:AC) [10:54:05:251]: Product Code passed to Engine.Initialize:           '{237CCB62-8454-43E3-B158-3ACD0134852E}'
MSI (s) (60:AC) [10:54:05:251]: Product Code from property table before transforms: '{237CCB62-8454-43E3-B158-3ACD0134852E}'
MSI (s) (60:AC) [10:54:05:251]: Product Code from property table after transforms:  '{237CCB62-8454-43E3-B158-3ACD0134852E}'
MSI (s) (60:AC) [10:54:05:251]: Product registered: entering maintenance mode
MSI (s) (60:AC) [10:54:05:251]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI (s) (60:AC) [10:54:05:251]: Product {237CCB62-8454-43E3-B158-3ACD0134852E} is admin assigned: LocalSystem owns the publish key.
MSI (s) (60:AC) [10:54:05:251]: Product {237CCB62-8454-43E3-B158-3ACD0134852E} is managed.
MSI (s) (60:AC) [10:54:05:251]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding ProductState property. Its value is '5'.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI (s) (60:AC) [10:54:05:251]: Package name retrieved from configuration data: 'Nero.BDCore.msi'
MSI (s) (60:AC) [10:54:05:251]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (60:AC) [10:54:05:251]: Machine policy value 'DisableMsi' is 0
MSI (s) (60:AC) [10:54:05:251]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:AC) [10:54:05:251]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:AC) [10:54:05:251]: Running product '{237CCB62-8454-43E3-B158-3ACD0134852E}' with elevated privileges: Product is assigned.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding NERO.IS_CHAINED property. Its value is 'YES'.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding REBOOT property. Its value is 'ReallySuppress'.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding MSIRESTARTMANAGERCONTROL property. Its value is 'Disable'.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding ISCHAINER property. Its value is '1'.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding REMOVE property. Its value is 'ALL'.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\WINDOWS\system32'.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '2'.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '8728'.
MSI (s) (60:AC) [10:54:05:251]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (60:AC) [10:54:05:251]: RESTART MANAGER: Disabled by MSIRESTARTMANAGERCONTROL property; Windows Installer will use the built-in FilesInUse functionality.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (s) (60:AC) [10:54:05:251]: TRANSFORMS property is now: C:\Windows\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\1033.mst
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '0'.
MSI (s) (60:AC) [10:54:05:251]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (60:AC) [10:54:05:251]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming
MSI (s) (60:AC) [10:54:05:266]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Favorites
MSI (s) (60:AC) [10:54:05:266]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (60:AC) [10:54:05:266]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Documents
MSI (s) (60:AC) [10:54:05:266]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (60:AC) [10:54:05:266]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (60:AC) [10:54:05:266]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (60:AC) [10:54:05:266]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (60:AC) [10:54:05:266]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (60:AC) [10:54:05:282]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Local
MSI (s) (60:AC) [10:54:05:282]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Pictures
MSI (s) (60:AC) [10:54:05:282]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (60:AC) [10:54:05:282]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (60:AC) [10:54:05:298]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (60:AC) [10:54:05:298]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (60:AC) [10:54:05:298]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (60:AC) [10:54:05:298]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Desktop
MSI (s) (60:AC) [10:54:05:313]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (s) (60:AC) [10:54:05:313]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (s) (60:AC) [10:54:05:313]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (60:AC) [10:54:05:313]: MSI_LUA: Setting AdminUser property to 1 because the product is already installed managed and per-machine
MSI (s) (60:AC) [10:54:05:313]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (60:AC) [10:54:05:313]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (s) (60:AC) [10:54:05:313]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (60:AC) [10:54:05:313]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'AutoBVT'.
MSI (s) (60:AC) [10:54:05:313]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Microsoft'.
MSI (s) (60:AC) [10:54:05:313]: PROPERTY CHANGE: Adding Installed property. Its value is '2010/12/21 09:38:40'.
MSI (s) (60:AC) [10:54:05:313]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\11a60.msi'.
MSI (s) (60:AC) [10:54:05:313]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Windows\Installer\11a60.msi'.
MSI (s) (60:AC) [10:54:05:313]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (s) (60:AC) [10:54:05:330]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:AC) [10:54:05:330]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:AC) [10:54:05:330]: User policy value 'DisableRollback' is 0
MSI (s) (60:AC) [10:54:05:330]: PROPERTY CHANGE: Adding UILevel property. Its value is '3'.
=== Logging started: 6/11/2017  10:54:05 ===
MSI (s) (60:AC) [10:54:05:335]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:AC) [10:54:05:335]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
MSI (s) (60:AC) [10:54:05:335]: APPCOMPAT: [DetectVersionLaunchCondition] Launch condition already passes.
MSI (s) (60:AC) [10:54:05:335]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (60:AC) [10:54:05:335]: Doing action: INSTALL
Action start 10:54:05: INSTALL.
MSI (s) (60:AC) [10:54:05:335]: Running ExecuteSequence
MSI (s) (60:AC) [10:54:05:335]: Skipping action: ISSetAllUsers (condition is false)
MSI (s) (60:AC) [10:54:05:335]: Doing action: AppSearch
Action start 10:54:05: AppSearch.
MSI (s) (60:AC) [10:54:05:335]: PROPERTY CHANGE: Modifying BROWSERPATH property. Its current value is 'c:\program files\internet explorer\iexplore.exe'. Its new value: 'C:\Program Files (x86)\Mozilla Firefox\firefox.exe'.
MSI (s) (60:AC) [10:54:05:335]: Skipping action: LaunchConditions (condition is false)
MSI (s) (60:AC) [10:54:05:335]: Doing action: FindRelatedProducts
Action ended 10:54:05: AppSearch. Return value 1.
MSI (s) (60:AC) [10:54:05:335]: Skipping FindRelatedProducts action: not run in maintenance mode
Action start 10:54:05: FindRelatedProducts.
MSI (s) (60:AC) [10:54:05:335]: Skipping action: ISPreventDowngrade (condition is false)
MSI (s) (60:AC) [10:54:05:335]: Skipping action: CCPSearch (condition is false)
MSI (s) (60:AC) [10:54:05:335]: Skipping action: RMCCPSearch (condition is false)
MSI (s) (60:AC) [10:54:05:335]: Doing action: ValidateProductID
Action ended 10:54:05: FindRelatedProducts. Return value 0.
Action start 10:54:05: ValidateProductID.
MSI (s) (60:AC) [10:54:05:335]: Skipping action: Nero_CA_SetExtensions (condition is false)
MSI (s) (60:AC) [10:54:05:335]: Skipping action: Nero_CA_SetDesktopShortcuts (condition is false)
MSI (s) (60:AC) [10:54:05:335]: Skipping action: Nero_CA_SetAutoplay (condition is false)
MSI (s) (60:AC) [10:54:05:335]: Skipping action: Nero_CA_SetUserProperties (condition is false)
MSI (s) (60:AC) [10:54:05:335]: Doing action: Nero_CAD_DeleteLocalFileAssociationDb
Action ended 10:54:05: ValidateProductID. Return value 1.
MSI (s) (60:AC) [10:54:05:335]: PROPERTY CHANGE: Adding Nero_CA_DeleteLocalFileAssociationDb property. Its value is '{237CCB62-8454-43E3-B158-3ACD0134852E}'.
Action start 10:54:05: Nero_CAD_DeleteLocalFileAssociationDb.
MSI (s) (60:AC) [10:54:05:335]: Doing action: Nero_CA_GenerateFileAssociationList
Action ended 10:54:05: Nero_CAD_DeleteLocalFileAssociationDb. Return value 1.
MSI (s) (60:74) [10:54:05:367]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI1B45.tmp, Entrypoint: CA_GenerateFileAssociationList
Action start 10:54:05: Nero_CA_GenerateFileAssociationList.
MSI (s) (60:AC) [10:54:05:413]: Doing action: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore
Action ended 10:54:05: Nero_CA_GenerateFileAssociationList. Return value 1.
MSI (s) (60:AC) [10:54:05:413]: PROPERTY CHANGE: Adding Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore property. Its value is '{237CCB62-8454-43E3-B158-3ACD0134852E}'.
Action start 10:54:05: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore.
MSI (s) (60:AC) [10:54:05:413]: Doing action: Nero_CAD_DeleteAssociationsBackup
Action ended 10:54:05: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore. Return value 1.
MSI (s) (60:AC) [10:54:05:413]: PROPERTY CHANGE: Adding Nero_CA_DeleteAssociationsBackup property. Its value is '{237CCB62-8454-43E3-B158-3ACD0134852E}|'.
Action start 10:54:05: Nero_CAD_DeleteAssociationsBackup.
MSI (s) (60:AC) [10:54:05:413]: Doing action: Nero_CAD_Install_SetAssociations
Action ended 10:54:05: Nero_CAD_DeleteAssociationsBackup. Return value 1.
Action start 10:54:05: Nero_CAD_Install_SetAssociations.
MSI (s) (60:AC) [10:54:05:413]: Doing action: Nero_CAD_Install_SetAssociationsRollback
Action ended 10:54:05: Nero_CAD_Install_SetAssociations. Return value 1.
Action start 10:54:05: Nero_CAD_Install_SetAssociationsRollback.
MSI (s) (60:AC) [10:54:05:413]: Doing action: Nero_CAD_Uninstall_SetAssociations
Action ended 10:54:05: Nero_CAD_Install_SetAssociationsRollback. Return value 1.
Action start 10:54:05: Nero_CAD_Uninstall_SetAssociations.
MSI (s) (60:AC) [10:54:05:413]: Doing action: Nero_CAD_Uninstall_SetAssociationsRollback
Action ended 10:54:05: Nero_CAD_Uninstall_SetAssociations. Return value 1.
Action start 10:54:05: Nero_CAD_Uninstall_SetAssociationsRollback.
MSI (s) (60:AC) [10:54:05:429]: Doing action: CostInitialize
Action ended 10:54:05: Nero_CAD_Uninstall_SetAssociationsRollback. Return value 1.
MSI (s) (60:AC) [10:54:05:430]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (s) (60:AC) [10:54:05:432]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI (s) (60:AC) [10:54:05:433]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (60:AC) [10:54:05:433]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (60:AC) [10:54:05:433]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:AC) [10:54:05:433]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (60:AC) [10:54:05:433]: Note: 1: 2205 2:  3: __MsiPatchFileList
MSI (s) (60:AC) [10:54:05:433]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
Action start 10:54:05: CostInitialize.
MSI (s) (60:AC) [10:54:05:434]: Skipping action: ResolveSource (condition is false)
MSI (s) (60:AC) [10:54:05:434]: Doing action: FileCost
Action ended 10:54:05: CostInitialize. Return value 1.
MSI (s) (60:AC) [10:54:05:435]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:AC) [10:54:05:435]: Note: 1: 2205 2:  3: Class
MSI (s) (60:AC) [10:54:05:435]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:AC) [10:54:05:435]: Note: 1: 2205 2:  3: TypeLib
Action start 10:54:05: FileCost.
MSI (s) (60:AC) [10:54:05:435]: Doing action: IsolateComponents
Action ended 10:54:05: FileCost. Return value 1.
Action start 10:54:05: IsolateComponents.
MSI (s) (60:AC) [10:54:05:436]: Doing action: setUserProfileNT
Action ended 10:54:05: IsolateComponents. Return value 0.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Zandra Jones'.
Action start 10:54:05: setUserProfileNT.
MSI (s) (60:AC) [10:54:05:436]: Skipping action: SetAllUsersProfileNT (condition is false)
MSI (s) (60:AC) [10:54:05:436]: Doing action: setAllUsersProfile2K
Action ended 10:54:05: setUserProfileNT. Return value 1.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
Action start 10:54:05: setAllUsersProfile2K.
MSI (s) (60:AC) [10:54:05:436]: Doing action: CostFinalize
Action ended 10:54:05: setAllUsersProfile2K. Return value 1.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (60:AC) [10:54:05:436]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:AC) [10:54:05:436]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding BDCORE10 property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding ASIA property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\Asia'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding ZI property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding AMERICA property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\America'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding SECURITY property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding LIB property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding EXT property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\ext'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding IMAGE property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\image'.
MSI (s) (60:AC) [10:54:05:436]: PROPERTY CHANGE: Adding TargetFolder.C9525E77.3ECDB9B9_ECD5_4F78_8BDC_16E4E198F3A6 property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10'.
Action start 10:54:05: CostFinalize.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Zandra Jones'. Its new value: 'C:\Users\Zandra Jones\'.
MSI (s) (60:AC) [10:54:05:482]: WIN64DUALFOLDERS: 'C:\WINDOWS\SysWOW64\' will substitute 20 characters in 'C:\WINDOWS\system32\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 1).
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying System64Folder property. Its current value is 'C:\WINDOWS\system32\'. Its new value: 'C:\WINDOWS\SysWOW64\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding System16Folder property. Its value is 'C:\'.
MSI (s) (60:AC) [10:54:05:482]: WIN64DUALFOLDERS: 'C:\Program Files (x86)\' will substitute 17 characters in 'C:\Program Files\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying ProgramFiles64Folder property. Its current value is 'C:\Program Files\'. Its new value: 'C:\Program Files (x86)\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding ISMyCompanyDir property. Its value is 'C:\Program Files (x86)\My Company Name\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding ISMyProductDir property. Its value is 'C:\Program Files (x86)\My Company Name\My Product Name\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding GlobalAssemblyCache property. Its value is 'C:\'.
MSI (s) (60:AC) [10:54:05:482]: WIN64DUALFOLDERS: 'C:\Program Files (x86)\' will substitute 17 characters in 'C:\Program Files\Common Files\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying CommonFiles64Folder property. Its current value is 'C:\Program Files\Common Files\'. Its new value: 'C:\Program Files (x86)\Common Files\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding NERO1 property. Its value is 'C:\Program Files (x86)\Common Files\Nero\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding NERO_10 property. Its value is 'C:\Program Files (x86)\Common Files\Nero\Nero 10\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding SHARED property. Its value is 'C:\Program Files (x86)\Common Files\Nero\Nero 10\Shared\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding BDCORE1 property. Its value is 'C:\Program Files (x86)\Common Files\Nero\Nero 10\Shared\BDCore\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying BDCORE10 property. Its current value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10'. Its new value: 'C:\Program Files (x86)\Common Files\Nero\BDCore10\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying TargetFolder.C9525E77.3ECDB9B9_ECD5_4F78_8BDC_16E4E198F3A6 property. Its current value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10'. Its new value: 'C:\Program Files (x86)\Common Files\Nero\BDCore10\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding ISYourDataBaseDir property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\Database\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Adding DATABASEDIR property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\Database\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying LIB property. Its current value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib'. Its new value: 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying SECURITY property. Its current value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security'. Its new value: 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying IMAGE property. Its current value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\image'. Its new value: 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\image\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying EXT property. Its current value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\ext'. Its new value: 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\ext\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying ZI property. Its current value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi'. Its new value: 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying ASIA property. Its current value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\Asia'. Its new value: 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\Asia\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying AMERICA property. Its current value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\America'. Its new value: 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\America\'.
MSI (s) (60:AC) [10:54:05:482]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
MSI (s) (60:AC) [10:54:05:482]: Target path resolution complete. Dumping Directory table...
MSI (s) (60:AC) [10:54:05:482]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: TARGETDIR   , Object: C:\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: WindowsFolder   , Object: C:\WINDOWS\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: USERPROFILE   , Object: C:\Users\Zandra Jones\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: TemplateFolder   , Object: C:\ProgramData\Microsoft\Windows\Templates\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: TempFolder   , Object: C:\Users\ZANDRA~1\AppData\Local\Temp\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: SystemFolder   , Object: C:\WINDOWS\SysWOW64\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: System64Folder   , Object: C:\WINDOWS\SysWOW64\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: System16Folder   , Object: C:\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: StartupFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: StartMenuFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: SendToFolder   , Object: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: ProgramMenuFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: ProgramFiles64Folder   , Object: C:\Program Files (x86)\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: PersonalFolder   , Object: C:\Users\Zandra Jones\Documents\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: MyPicturesFolder   , Object: C:\Users\Zandra Jones\Pictures\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: LocalAppDataFolder   , Object: C:\Users\Zandra Jones\AppData\Local\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: ProgramFilesFolder   , Object: C:\Program Files (x86)\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: ISMyCompanyDir   , Object: C:\Program Files (x86)\My Company Name\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: ISMyProductDir   , Object: C:\Program Files (x86)\My Company Name\My Product Name\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: GlobalAssemblyCache   , Object: C:\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: FontsFolder   , Object: C:\WINDOWS\Fonts\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: FavoritesFolder   , Object: C:\Users\Zandra Jones\Favorites\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: DesktopFolder   , Object: C:\Users\Public\Desktop\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: CommonFiles64Folder   , Object: C:\Program Files (x86)\Common Files\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: CommonAppDataFolder   , Object: C:\ProgramData\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: AppDataFolder   , Object: C:\Users\Zandra Jones\AppData\Roaming\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: AdminToolsFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: CommonFilesFolder   , Object: C:\Program Files (x86)\Common Files\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: ISCommonFilesFolder   , Object: C:\Program Files (x86)\Common Files\InstallShield\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: ISUpdateServiceFolder   , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: NERO1   , Object: C:\Program Files (x86)\Common Files\Nero\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: NERO_10   , Object: C:\Program Files (x86)\Common Files\Nero\Nero 10\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: SHARED   , Object: C:\Program Files (x86)\Common Files\Nero\Nero 10\Shared\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: BDCORE1   , Object: C:\Program Files (x86)\Common Files\Nero\Nero 10\Shared\BDCore\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: BDCORE10   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: TargetFolder.C9525E77.3ECDB9B9_ECD5_4F78_8BDC_16E4E198F3A6   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: INSTALLDIR   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: ISYourDataBaseDir   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\Database\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: DATABASEDIR   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\Database\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: LIB   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: SECURITY   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: IMAGE   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\image\
Offline Nissi1
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: EXT   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\ext\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: ZI   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: ASIA   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\Asia\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: AMERICA   , Object: C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\America\
MSI (s) (60:AC) [10:54:05:482]: Dir (target): Key: ALLUSERSPROFILE   , Object: C:\ProgramData\
MSI (s) (60:AC) [10:54:05:482]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:482]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\sunrsasign.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:498]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\ext\sunjce_provider.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:498]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\nanoxml-2.2.3.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:498]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\image\logo.gif' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:498]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\localedata.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:498]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security\local_policy.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:498]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\jsse-cdc.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\jce.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security\java_permissive.policy' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security\java.security' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security\java.policy' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\jakarta-regexp-1.4.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\jaas.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\font.properties' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\cvmi.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\content-types.properties' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\commons-codec-1.3.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\charsets.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security\cacerts' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\btclasses.zip' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\bdj.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\bdj.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\ext\bcprov-ext-jdk14-145.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\basis.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\ZoneInfoMappings' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security\US_export_policy.jar' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\Asia\Novosibirsk' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\America\Los_Angeles' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\GMT' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\Asia\Calcutta' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\BD_NeSoundProc.ax' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\BD_NeHDAudioMixer.ax' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\BD_NeDTSHDDec.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\BD_NeAudioRender.ax' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\BD_NeAudio2.ax' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:514]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Common Files\Nero\BDCore10\BDCore.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:AC) [10:54:05:530]: Doing action: Nero_CA_PrepareShortCuts
Action ended 10:54:05: CostFinalize. Return value 1.
MSI (s) (60:C4) [10:54:05:536]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI1C02.tmp, Entrypoint: CA_PrepareShortCuts
Action start 10:54:05: Nero_CA_PrepareShortCuts.
CA_PrepareShortCuts: CustomActions.cpp : 1505 :  NERO.INSTALL_DESKTOPSHORTCUT: YES
CA_PrepareShortCuts: CustomActions.cpp : 1515 :  Shortcut table does not exist. Nothing to do.
CA_PrepareShortCuts: CustomActions.cpp : 1607 :  Succeeded
MSI (s) (60:AC) [10:54:05:583]: Skipping action: Nero_CA_CheckProductConflicts (condition is false)
MSI (s) (60:AC) [10:54:05:583]: Skipping action: Nero_CA_CheckRebootPending (condition is false)
MSI (s) (60:AC) [10:54:05:583]: Doing action: MigrateFeatureStates
Action ended 10:54:05: Nero_CA_PrepareShortCuts. Return value 1.
MSI (s) (60:AC) [10:54:05:583]: Skipping MigrateFeatureStates action: not run in maintenance mode
Action start 10:54:05: MigrateFeatureStates.
MSI (s) (60:AC) [10:54:05:583]: Doing action: SetARPINSTALLLOCATION
Action ended 10:54:05: MigrateFeatureStates. Return value 0.
MSI (s) (60:AC) [10:54:05:583]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Program Files (x86)\Common Files\Nero\BDCore10\'.
Action start 10:54:05: SetARPINSTALLLOCATION.
MSI (s) (60:AC) [10:54:05:583]: Doing action: SetODBCFolders
Action ended 10:54:05: SetARPINSTALLLOCATION. Return value 1.
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
Action start 10:54:05: SetODBCFolders.
MSI (s) (60:AC) [10:54:05:583]: Doing action: InstallValidate
Action ended 10:54:05: SetODBCFolders. Return value 0.
MSI (s) (60:AC) [10:54:05:583]: Feature: Languages; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Feature: SystemIntegration; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: AutoPlay; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: FileAssociations; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: Application; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Feature: CHS; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: CHT; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: CSY; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: DAN; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: DEU; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: ELL; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: ENU; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: ESP; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: FIN; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: FRA; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: HUN; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: ITA; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: JPN; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: KOR; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: NLD; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: NOR; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: PLK; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: PTB; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: RUS; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: SVE; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: THA; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Feature: TRK; Installed: Null;   Request: Null;   Action: Null
MSI (s) (60:AC) [10:54:05:583]: Component: __RegInstaller65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: BDCore.dll; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: BD_NeAudio2.ax; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: BD_NeAudioRender.ax; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: BD_NeDTSHDDec.dll; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: BD_NeHDAudioMixer.ax; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: BD_NeSoundProc.ax; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: Calcutta; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: GMT; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: Los_Angeles; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: Novosibirsk; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: RegInstaller; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: US_export_policy.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: ZoneInfoMappings; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: basis.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: bcprov_ext_jdk14_145.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: bdj.dll; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: bdj.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: btclasses.zip; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: cacerts; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: charsets.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: commons_codec_1.3.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: content_types.properties; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: cvmi.dll; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: font.properties; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: jaas.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: jakarta_regexp_1.4.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: java.policy; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: java.security; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: java_permissive.policy; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: jce.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: jsse_cdc.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: local_policy.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: localedata.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: logo.gif; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: nanoxml_2.2.3.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: sunjce_provider.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: sunrsasign.jar; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Component: NEBOPA_FLS.3ECDB9B9_ECD5_4F78_8BDC_16E4E198F3A6; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2205 2:  3: BindImage
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2205 2:  3: Font
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2205 2:  3: Class
MSI (s) (60:AC) [10:54:05:583]: Note: 1: 2205 2:  3: TypeLib
Action start 10:54:05: InstallValidate.
MSI (s) (60:AC) [10:54:05:598]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI (s) (60:AC) [10:54:05:614]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (60:AC) [10:54:05:614]: Note: 1: 2205 2:  3: BindImage
MSI (s) (60:AC) [10:54:05:614]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:AC) [10:54:05:614]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:AC) [10:54:05:614]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:AC) [10:54:05:614]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:AC) [10:54:05:614]: Note: 1: 2205 2:  3: Font
MSI (s) (60:AC) [10:54:05:614]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:AC) [10:54:05:614]: Note: 1: 2205 2:  3: Class
MSI (s) (60:AC) [10:54:05:614]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:AC) [10:54:05:614]: Note: 1: 2727 2:
MSI (s) (60:AC) [10:54:05:614]: Doing action: RemoveExistingProducts
Action ended 10:54:05: InstallValidate. Return value 1.
MSI (s) (60:AC) [10:54:05:614]: Skipping RemoveExistingProducts action: current configuration is maintenance mode or an uninstall
Action start 10:54:05: RemoveExistingProducts.
MSI (s) (60:AC) [10:54:05:614]: Skipping action: Nero_CA_SetMediaPackage (condition is false)
MSI (s) (60:AC) [10:54:05:614]: Skipping action: Nero_CAData_RestoreMediaPackage (condition is false)
MSI (s) (60:AC) [10:54:05:614]: Doing action: InstallInitialize
Action ended 10:54:05: RemoveExistingProducts. Return value 0.
MSI (s) (60:AC) [10:54:05:614]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:AC) [10:54:05:614]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:AC) [10:54:05:614]: BeginTransaction: Locking Server
MSI (s) (60:AC) [10:54:05:614]: Transforming table Property.
MSI (s) (60:AC) [10:54:05:636]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:AC) [10:54:05:636]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
MSI (s) (60:AC) [10:54:05:636]: SRSetRestorePoint skipped for this transaction.
MSI (s) (60:AC) [10:54:05:636]: Server not locked: locking for product {237CCB62-8454-43E3-B158-3ACD0134852E}
Action start 10:54:05: InstallInitialize.
MSI (s) (60:AC) [10:54:05:652]: PROPERTY CHANGE: Deleting ProductToBeRegistered property. Its current value is '1'.
MSI (s) (60:AC) [10:54:05:652]: Note: 1: 2205 2:  3: Class
MSI (s) (60:AC) [10:54:05:652]: Note: 1: 2228 2:  3: Class 4: SELECT `CLSID` FROM `Class` WHERE `Icon_`=? AND `Class`.`Attributes`=1
MSI (s) (60:AC) [10:54:05:652]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:AC) [10:54:05:652]: Note: 1: 2228 2:  3: Shortcut 4: SELECT `Component`,`Shortcut`,`Target` FROM `Component`,`Shortcut` WHERE `Component`=`Component_` AND `Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:AC) [10:54:05:652]: Note: 1: 2228 2:  3: Class 4: SELECT `Component`,`CLSID` FROM `Component`,`Class` WHERE `Component`=`Component_` AND `Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:AC) [10:54:05:652]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:AC) [10:54:05:652]: Note: 1: 2228 2:  3: Extension 4: SELECT `Component`,`Extension` FROM `Component`,`Extension`,`ProgId` WHERE `Component`.`Component`=`Extension`.`Component_` AND `ProgId`.`ProgId`=`Extension`.`ProgId_` AND `ProgId`.`Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:AC) [10:54:05:652]: 'ARPPRODUCTICON.exe' icon will be removed.
MSI (s) (60:AC) [10:54:05:652]: Doing action: Nero_CA_DeleteLocalFileAssociationDb
Action ended 10:54:05: InstallInitialize. Return value 1.
Action start 10:54:05: Nero_CA_DeleteLocalFileAssociationDb.
MSI (s) (60:AC) [10:54:05:667]: Doing action: Nero_CA_GatherOriginalFileAssociation
Action ended 10:54:05: Nero_CA_DeleteLocalFileAssociationDb. Return value 1.
Action start 10:54:05: Nero_CA_GatherOriginalFileAssociation.
MSI (s) (60:AC) [10:54:05:667]: Skipping action: Nero_CA_RestoreMediaPackage (condition is false)
MSI (s) (60:AC) [10:54:05:667]: Skipping action: AllocateRegistrySpace (condition is false)
MSI (s) (60:AC) [10:54:05:667]: Doing action: ProcessComponents
Action ended 10:54:05: Nero_CA_GatherOriginalFileAssociation. Return value 1.
Action start 10:54:05: ProcessComponents.
MSI (s) (60:AC) [10:54:05:683]: Doing action: UnpublishComponents
Action ended 10:54:05: ProcessComponents. Return value 1.
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:05: UnpublishComponents.
MSI (s) (60:AC) [10:54:05:683]: Doing action: MsiUnpublishAssemblies
Action ended 10:54:05: UnpublishComponents. Return value 0.
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:05: MsiUnpublishAssemblies.
MSI (s) (60:AC) [10:54:05:683]: Doing action: UnpublishFeatures
Action ended 10:54:05: MsiUnpublishAssemblies. Return value 0.
Action start 10:54:05: UnpublishFeatures.
MSI (s) (60:AC) [10:54:05:683]: Doing action: StopServices
Action ended 10:54:05: UnpublishFeatures. Return value 1.
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 10:54:05: StopServices.
MSI (s) (60:AC) [10:54:05:683]: Doing action: DeleteServices
Action ended 10:54:05: StopServices. Return value 1.
Action start 10:54:05: DeleteServices.
MSI (s) (60:AC) [10:54:05:683]: Doing action: UnregisterComPlus
Action ended 10:54:05: DeleteServices. Return value 1.
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2205 2:  3: Complus
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
Action start 10:54:05: UnregisterComPlus.
MSI (s) (60:AC) [10:54:05:683]: Doing action: SelfUnregModules
Action ended 10:54:05: UnregisterComPlus. Return value 0.
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
Action start 10:54:05: SelfUnregModules.
MSI (s) (60:AC) [10:54:05:683]: Doing action: UnregisterTypeLibraries
Action ended 10:54:05: SelfUnregModules. Return value 1.
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
Action start 10:54:05: UnregisterTypeLibraries.
MSI (s) (60:AC) [10:54:05:683]: Doing action: RemoveODBC
Action ended 10:54:05: UnregisterTypeLibraries. Return value 0.
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:AC) [10:54:05:683]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2711 2: ODBCDriverManager
Action start 10:54:05: RemoveODBC.
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (60:AC) [10:54:05:699]: Doing action: UnregisterFonts
Action ended 10:54:05: RemoveODBC. Return value 1.
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2205 2:  3: Font
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
Action start 10:54:05: UnregisterFonts.
MSI (s) (60:AC) [10:54:05:699]: Doing action: RemoveRegistryValues
Action ended 10:54:05: UnregisterFonts. Return value 1.
Action start 10:54:05: RemoveRegistryValues.
MSI (s) (60:AC) [10:54:05:699]: Doing action: UnregisterClassInfo
Action ended 10:54:05: RemoveRegistryValues. Return value 1.
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2205 2:  3: Class
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:05: UnregisterClassInfo.
MSI (s) (60:AC) [10:54:05:699]: Doing action: UnregisterExtensionInfo
Action ended 10:54:05: UnregisterClassInfo. Return value 0.
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:05: UnregisterExtensionInfo.
MSI (s) (60:AC) [10:54:05:699]: Doing action: UnregisterProgIdInfo
Action ended 10:54:05: UnregisterExtensionInfo. Return value 0.
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:05: UnregisterProgIdInfo.
MSI (s) (60:AC) [10:54:05:699]: Doing action: UnregisterMIMEInfo
Action ended 10:54:05: UnregisterProgIdInfo. Return value 0.
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2205 2:  3: MIME
MSI (s) (60:AC) [10:54:05:699]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:05: UnregisterMIMEInfo.
MSI (s) (60:AC) [10:54:05:714]: Doing action: RemoveIniValues
Action ended 10:54:05: UnregisterMIMEInfo. Return value 0.
MSI (s) (60:AC) [10:54:05:714]: Note: 1: 2205 2:  3: IniFile
MSI (s) (60:AC) [10:54:05:714]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
Action start 10:54:05: RemoveIniValues.
MSI (s) (60:AC) [10:54:05:714]: Doing action: RemoveShortcuts
Action ended 10:54:05: RemoveIniValues. Return value 1.
MSI (s) (60:AC) [10:54:05:714]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:AC) [10:54:05:714]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:05: RemoveShortcuts.
MSI (s) (60:AC) [10:54:05:714]: Doing action: RemoveEnvironmentStrings
Action ended 10:54:05: RemoveShortcuts. Return value 0.
MSI (s) (60:AC) [10:54:05:714]: Note: 1: 2205 2:  3: Environment
MSI (s) (60:AC) [10:54:05:714]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
Action start 10:54:05: RemoveEnvironmentStrings.
MSI (s) (60:AC) [10:54:05:714]: Doing action: RemoveDuplicateFiles
Action ended 10:54:05: RemoveEnvironmentStrings. Return value 1.
Action start 10:54:05: RemoveDuplicateFiles.
MSI (s) (60:AC) [10:54:05:714]: Doing action: RemoveFiles
Action ended 10:54:05: RemoveDuplicateFiles. Return value 1.
MSI (s) (60:AC) [10:54:05:714]: Note: 1: 2205 2:  3: RemoveFile
Action start 10:54:05: RemoveFiles.
MSI (s) (60:AC) [10:54:05:714]: Doing action: RemoveFolders
Action ended 10:54:05: RemoveFiles. Return value 0.
Action start 10:54:05: RemoveFolders.
MSI (s) (60:AC) [10:54:05:731]: Doing action: CreateFolders
Action ended 10:54:05: RemoveFolders. Return value 1.
Action start 10:54:05: CreateFolders.
MSI (s) (60:AC) [10:54:05:732]: Doing action: MoveFiles
Action ended 10:54:05: CreateFolders. Return value 1.
Action start 10:54:05: MoveFiles.
MSI (s) (60:AC) [10:54:05:733]: Doing action: InstallFiles
Action ended 10:54:05: MoveFiles. Return value 1.
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2205 2:  3: MsiSFCBypass
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
Action start 10:54:05: InstallFiles.
MSI (s) (60:AC) [10:54:05:736]: Doing action: PatchFiles
Action ended 10:54:05: InstallFiles. Return value 1.
Action start 10:54:05: PatchFiles.
MSI (s) (60:AC) [10:54:05:736]: Doing action: DuplicateFiles
Action ended 10:54:05: PatchFiles. Return value 1.
Action start 10:54:05: DuplicateFiles.
MSI (s) (60:AC) [10:54:05:736]: Doing action: BindImage
Action ended 10:54:05: DuplicateFiles. Return value 1.
Action start 10:54:05: BindImage.
MSI (s) (60:AC) [10:54:05:736]: Doing action: CreateShortcuts
Action ended 10:54:05: BindImage. Return value 1.
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action start 10:54:05: CreateShortcuts.
MSI (s) (60:AC) [10:54:05:736]: Doing action: RegisterClassInfo
Action ended 10:54:05: CreateShortcuts. Return value 0.
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2205 2:  3: Class
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:54:05: RegisterClassInfo.
MSI (s) (60:AC) [10:54:05:736]: Doing action: RegisterExtensionInfo
Action ended 10:54:05: RegisterClassInfo. Return value 0.
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:54:05: RegisterExtensionInfo.
MSI (s) (60:AC) [10:54:05:736]: Doing action: RegisterProgIdInfo
Action ended 10:54:05: RegisterExtensionInfo. Return value 0.
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:54:05: RegisterProgIdInfo.
MSI (s) (60:AC) [10:54:05:736]: Doing action: RegisterMIMEInfo
Action ended 10:54:05: RegisterProgIdInfo. Return value 0.
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2205 2:  3: MIME
MSI (s) (60:AC) [10:54:05:736]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:54:05: RegisterMIMEInfo.
MSI (s) (60:AC) [10:54:05:736]: Doing action: WriteRegistryValues
Action ended 10:54:05: RegisterMIMEInfo. Return value 0.
Action start 10:54:05: WriteRegistryValues.
MSI (s) (60:AC) [10:54:05:752]: Doing action: WriteIniValues
Action ended 10:54:05: WriteRegistryValues. Return value 1.
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: IniFile
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
Action start 10:54:05: WriteIniValues.
MSI (s) (60:AC) [10:54:05:752]: Doing action: WriteEnvironmentStrings
Action ended 10:54:05: WriteIniValues. Return value 1.
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: Environment
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
Action start 10:54:05: WriteEnvironmentStrings.
MSI (s) (60:AC) [10:54:05:752]: Doing action: RegisterFonts
Action ended 10:54:05: WriteEnvironmentStrings. Return value 1.
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: Font
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
Action start 10:54:05: RegisterFonts.
MSI (s) (60:AC) [10:54:05:752]: Doing action: InstallODBC
Action ended 10:54:05: RegisterFonts. Return value 1.
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2711 2: ODBCDriverManager
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
Action start 10:54:05: InstallODBC.
MSI (s) (60:AC) [10:54:05:752]: Doing action: RegisterTypeLibraries
Action ended 10:54:05: InstallODBC. Return value 0.
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
Action start 10:54:05: RegisterTypeLibraries.
MSI (s) (60:AC) [10:54:05:752]: Doing action: SelfRegModules
Action ended 10:54:05: RegisterTypeLibraries. Return value 0.
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
Action start 10:54:05: SelfRegModules.
MSI (s) (60:AC) [10:54:05:752]: Doing action: RegisterComPlus
Action ended 10:54:05: SelfRegModules. Return value 1.
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: Complus
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action start 10:54:05: RegisterComPlus.
MSI (s) (60:AC) [10:54:05:752]: Doing action: InstallServices
Action ended 10:54:05: RegisterComPlus. Return value 0.
MSI (s) (60:AC) [10:54:05:752]: Detected older ServiceInstall table schema
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: ServiceInstall
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
Action start 10:54:05: InstallServices.
MSI (s) (60:AC) [10:54:05:752]: Doing action: StartServices
Action ended 10:54:05: InstallServices. Return value 1.
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 10:54:05: StartServices.
MSI (s) (60:AC) [10:54:05:752]: Doing action: RegisterUser
Action ended 10:54:05: StartServices. Return value 1.
Action start 10:54:05: RegisterUser.
MSI (s) (60:AC) [10:54:05:752]: Doing action: RegisterProduct
Action ended 10:54:05: RegisterUser. Return value 0.
Action start 10:54:05: RegisterProduct.
MSI (s) (60:AC) [10:54:05:752]: Doing action: PublishComponents
Action ended 10:54:05: RegisterProduct. Return value 1.
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action start 10:54:05: PublishComponents.
MSI (s) (60:AC) [10:54:05:752]: Doing action: MsiPublishAssemblies
Action ended 10:54:05: PublishComponents. Return value 0.
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:AC) [10:54:05:752]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action start 10:54:05: MsiPublishAssemblies.
MSI (s) (60:AC) [10:54:05:752]: Doing action: PublishFeatures
Action ended 10:54:05: MsiPublishAssemblies. Return value 0.
Action start 10:54:05: PublishFeatures.
MSI (s) (60:AC) [10:54:05:752]: Doing action: PublishProduct
Action ended 10:54:05: PublishFeatures. Return value 1.
Action start 10:54:05: PublishProduct.
MSI (s) (60:AC) [10:54:05:752]: Doing action: Nero_CA_UninstallSetAssociationsRollback
Action ended 10:54:05: PublishProduct. Return value 1.
Action start 10:54:05: Nero_CA_UninstallSetAssociationsRollback.
MSI (s) (60:AC) [10:54:05:768]: Doing action: Nero_CA_UninstallSetAssociations
Action ended 10:54:05: Nero_CA_UninstallSetAssociationsRollback. Return value 1.
Action start 10:54:05: Nero_CA_UninstallSetAssociations.
MSI (s) (60:AC) [10:54:05:768]: Skipping action: Nero_CA_InstallSetAssociationsRollback (condition is false)
MSI (s) (60:AC) [10:54:05:768]: Skipping action: Nero_CA_InstallSetAssociations (condition is false)
MSI (s) (60:AC) [10:54:05:768]: Doing action: Nero_CA_DeleteAssociationsBackup
Action ended 10:54:05: Nero_CA_UninstallSetAssociations. Return value 1.
Action start 10:54:05: Nero_CA_DeleteAssociationsBackup.
MSI (s) (60:AC) [10:54:05:768]: Doing action: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore
Action ended 10:54:05: Nero_CA_DeleteAssociationsBackup. Return value 1.
Action start 10:54:05: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore.
MSI (s) (60:AC) [10:54:05:783]: Skipping action: ScheduleReboot (condition is false)
MSI (s) (60:AC) [10:54:05:783]: Doing action: InstallFinalize
Action ended 10:54:05: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore. Return value 1.
Action start 10:54:05: InstallFinalize.
MSI (s) (60:AC) [10:54:05:783]: Running Script: C:\WINDOWS\Installer\MSI1C70.tmp
MSI (s) (60:AC) [10:54:05:783]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (60:AC) [10:54:05:783]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:AC) [10:54:05:783]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:AC) [10:54:05:799]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1254840003,LangId=0,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (60:AC) [10:54:05:799]: Executing op: ProductInfo(ProductKey={237CCB62-8454-43E3-B158-3ACD0134852E},ProductName=High-Definition Video Playback,PackageName=Nero.BDCore.msi,Language=0,Version=117647120,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,PackageMediaPath=\applications\bdcore\,PackageCode={19C411BD-15F8-4A1D-9D1B-94CA36079589},,,InstanceType=0,LUASetting=1,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (s) (60:AC) [10:54:05:799]: Executing op: DialogInfo(Type=0,Argument=0)
MSI (s) (60:AC) [10:54:05:799]: Executing op: DialogInfo(Type=1,Argument=High-Definition Video Playback)
MSI (s) (60:AC) [10:54:05:799]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (60:AC) [10:54:05:799]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (60:AC) [10:54:05:799]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (60:AC) [10:54:05:799]: Executing op: ActionStart(Name=InstallInitialize,,)
MSI (s) (60:AC) [10:54:05:799]: Executing op: ProductUnregister(UpgradeCode={E662C6C7-F7AE-455D-AF35-8FA0A484DE90})
MSI (s) (60:AC) [10:54:05:799]: Note: 1: 1402 2: UNKNOWN\Products\26BCC73245483E341B85A3DC104358E2\Transforms 3: 2
MSI (s) (60:AC) [10:54:05:799]: Scheduling file 'C:\Windows\Installer\11a60.msi' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:AC) [10:54:05:837]: Note: 1: 1402 2: UNKNOWN\Products\26BCC73245483E341B85A3DC104358E2\Usage 3: 2
MSI (s) (60:AC) [10:54:05:837]: Executing op: ProductCPDisplayInfoUnregister()
MSI (s) (60:AC) [10:54:05:837]: Executing op: ProductUnpublish(PackageKey={19C411BD-15F8-4A1D-9D1B-94CA36079589})
MSI (s) (60:AC) [10:54:05:837]: Transforms are not secure.
MSI (s) (60:AC) [10:54:05:837]: Processing cached transform: C:\WINDOWS\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\1033.mst
MSI (s) (60:AC) [10:54:05:837]: Scheduling file 'C:\WINDOWS\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\1033.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:AC) [10:54:05:837]: Registering cached transform: C:\WINDOWS\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\1033.mst
MSI (s) (60:AC) [10:54:05:837]: Executing op: UpgradeCodeUnpublish(UpgradeCode={E662C6C7-F7AE-455D-AF35-8FA0A484DE90})
MSI (s) (60:AC) [10:54:05:837]: Executing op: IconRemove(Icon=ARPPRODUCTICON.exe,)
MSI (s) (60:AC) [10:54:05:837]: Scheduling file 'C:\WINDOWS\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\ARPPRODUCTICON.exe' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:AC) [10:54:05:852]: Executing op: ProductUnpublishClient(,,)
MSI (s) (60:AC) [10:54:05:852]: Note: 1: 1402 2: UNKNOWN\Installer\Products\26BCC73245483E341B85A3DC104358E2 3: 2
MSI (s) (60:AC) [10:54:05:852]: Executing op: SourceListUnpublish(,)
MSI (s) (60:AC) [10:54:05:852]: Note: 1: 1402 2: UNKNOWN\Installer\Products\26BCC73245483E341B85A3DC104358E2\SourceList 3: 2
MSI (s) (60:AC) [10:54:05:852]: Executing op: ActionStart(Name=Nero_CA_DeleteLocalFileAssociationDb,,)
MSI (s) (60:AC) [10:54:05:852]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteLocalFileAssociationDb,ActionType=1281,Source=BinaryData,Target=CA_DeleteLocalFileAssociationDb,CustomActionData={237CCB62-8454-43E3-B158-3ACD0134852E})
MSI (s) (60:AC) [10:54:05:852]: Executing op: ActionStart(Name=Nero_CA_GatherOriginalFileAssociation,,)
MSI (s) (60:AC) [10:54:05:852]: Executing op: CustomActionSchedule(Action=Nero_CA_GatherOriginalFileAssociation,ActionType=1025,Source=BinaryData,Target=CA_GatherOriginalFileAssociation,)
MSI (s) (60:74) [10:54:05:852]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI1D3D.tmp, Entrypoint: CA_GatherOriginalFileAssociation
MSI (s) (60:AC) [10:54:05:899]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (60:AC) [10:54:05:899]: Executing op: ProgressTotal(Total=38,Type=1,ByteEquivalent=24000)
MSI (s) (60:AC) [10:54:05:899]: Executing op: UnregisterSharedComponentProvider(Component={BFCC60DB-3E65-49E1-8D80-5149234A3907},ProductCode={237CCB62-8454-43E3-B158-3ACD0134852E})
MSI (s) (60:AC) [10:54:05:915]: Executing op: ComponentUnregister(ComponentId=
Offline Nissi1
MSI (s) (60:AC) [10:54:05:984]: Note: 1: 1402 2: UNKNOWN\Installer\Features\26BCC73245483E341B85A3DC104358E2 3: 2
MSI (s) (60:AC) [10:54:05:984]: Executing op: FeatureUnpublish(Feature=NOR,Parent=Languages,Absent=2,)
MSI (s) (60:AC) [10:54:05:984]: Executing op: FeatureUnpublish(Feature=PLK,Parent=Languages,Absent=2,)
MSI (s) (60:AC) [10:54:05:984]: Executing op: FeatureUnpublish(Feature=PTB,Parent=Languages,Absent=2,)
MSI (s) (60:AC) [10:54:05:999]: Executing op: FeatureUnpublish(Feature=RUS,Parent=Languages,Absent=2,)
MSI (s) (60:AC) [10:54:05:999]: Note: 1: 1402 2: UNKNOWN\Installer\Features\26BCC73245483E341B85A3DC104358E2 3: 2
MSI (s) (60:AC) [10:54:05:999]: Executing op: FeatureUnpublish(Feature=SVE,Parent=Languages,Absent=2,)
MSI (s) (60:AC) [10:54:05:999]: Executing op: FeatureUnpublish(Feature=THA,Parent=Languages,Absent=2,)
MSI (s) (60:AC) [10:54:05:999]: Executing op: FeatureUnpublish(Feature=TRK,Parent=Languages,Absent=2,)
MSI (s) (60:AC) [10:54:05:999]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
MSI (s) (60:AC) [10:54:05:999]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (60:AC) [10:54:05:999]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (60:AC) [10:54:05:999]: Executing op: ActionStart(Name=RemoveRegistryValues,Description=Removing system registry values,Template=Key: [1], Name: [2])
MSI (s) (60:AC) [10:54:05:999]: Executing op: ProgressTotal(Total=13,Type=1,ByteEquivalent=13200)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Nero\Nero 10\Installer\Applications\{E662C6C7-F7AE-455D-AF35-8FA0A484DE90},,BinaryType=0,,)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=NERO.APPID,Value=#[NERO.APPID],)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=Nero.MainComponent,Value=[Nero.MainComponent],)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=PackageName,Value=[Nero.PackageName],)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=ProductCode,Value=[ProductCode],)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=NERO.PRODUCT_LINE,Value=[NERO.PRODUCT_LINE],)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=ProductName,Value=[ProductName],)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=ProductVersion,Value=[ProductVersion],)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\Applications\{E662C6C7-F7AE-455D-AF35-8FA0A484DE90}\UserProperties,,BinaryType=0,,)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=ARPNOREPAIR,Value=[ARPNOREPAIR],)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=NERO.INSTALL_AUTOPLAY,Value=[NERO.INSTALL_AUTOPLAY],)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=NERO.INSTALL_DESKTOPSHORTCUT,Value=[NERO.INSTALL_DESKTOPSHORTCUT],)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=NERO.INSTALL_EXTENSIONS,Value=[NERO.INSTALL_EXTENSIONS],)
MSI (s) (60:AC) [10:54:05:999]: Executing op: RegRemoveValue(Name=INSTALLDIR,Value=[INSTALLDIR],)
MSI (s) (60:AC) [10:54:06:015]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Nero\Nero 10\Installer\Packages\{E662C6C7-F7AE-455D-AF35-8FA0A484DE90},,BinaryType=0,,)
MSI (s) (60:AC) [10:54:06:015]: Executing op: RegRemoveValue(Name=NBDCORE,Value=[UpgradeCode],)
MSI (s) (60:AC) [10:54:06:015]: Executing op: ActionStart(Name=RemoveFiles,Description=Removing files,Template=File: [1], Directory: [9])
MSI (s) (60:AC) [10:54:06:015]: Executing op: ProgressTotal(Total=57,Type=1,ByteEquivalent=175000)
MSI (s) (60:AC) [10:54:06:015]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\)
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=basis.jar,,ComponentId={274AC19B-A167-47C6-931D-5B3121048016})
MSI (s) (60:AC) [10:54:06:015]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\ext\)
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=bcprov-ext-jdk14-145.jar,,ComponentId={5F0610FA-4197-44D3-AF80-7694CAA2465F})
MSI (s) (60:AC) [10:54:06:015]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\)
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=bdj.dll,,ComponentId={069103C4-26BA-45C1-877B-7E5FC5C2CCD3})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=bdj.jar,,ComponentId={EFC13B2A-A347-4478-9847-39C9B912304C})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=btclasses.zip,,ComponentId={7018F10F-FE9F-4D98-9043-9531F6E2BBD8})
MSI (s) (60:AC) [10:54:06:015]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security\)
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=cacerts,,ComponentId={8D9529CA-CD5A-480B-ACC5-8D015865B4F1})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=charsets.jar,,ComponentId={3DF4EFED-7CBA-4BB6-9EF5-34ADA03CCD7C})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=commons-codec-1.3.jar,,ComponentId={07D27FE4-D84B-4690-928B-12C880571885})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=content-types.properties,,ComponentId={1C589A5E-AB21-4BBC-8D2B-511A17E1B4EB})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=cvmi.dll,,ComponentId={F494E54F-D5AB-464F-984F-16DE1B05C273})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=font.properties,,ComponentId={17C12675-F9CA-4A06-B7A4-EC3C37202E82})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=jaas.jar,,ComponentId={36B0CD14-0209-4A5C-95D8-951A7CB74ED6})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=jakarta-regexp-1.4.jar,,ComponentId={176CBC99-A713-44DF-B464-E763B327B1E9})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=java.policy,,ComponentId={98CBA3D2-526D-492B-A140-0A4FA03173C4})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=java.security,,ComponentId={AE193D09-F14D-4959-AF57-AFA76FF01CE9})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=java_permissive.policy,,ComponentId={3A725D25-AB6B-42F7-9394-6770F16F9654})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=jce.jar,,ComponentId={F9A930C3-9318-47C7-9CF0-5C5A113A4086})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=jsse-cdc.jar,,ComponentId={251E69E9-830A-4EB7-ACD2-E1DED4F3A8CD})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=local_policy.jar,,ComponentId={97888ADB-036B-401C-A09E-53A8B74575B6})
MSI (s) (60:AC) [10:54:06:015]: Executing op: FileRemove(,FileName=localedata.jar,,ComponentId={62F07090-4148-4F4E-9F19-ECABB58E6CFD})
MSI (s) (60:AC) [10:54:06:015]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\image\)
MSI (s) (60:AC) [10:54:06:031]: Executing op: FileRemove(,FileName=logo.gif,,ComponentId={3460D23A-F579-4B9B-B4AB-445F0BAB4CA9})
MSI (s) (60:AC) [10:54:06:032]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\)
MSI (s) (60:AC) [10:54:06:032]: Executing op: FileRemove(,FileName=nanoxml-2.2.3.jar,,ComponentId={6D64C678-139F-43A3-93C8-89D5E606D539})
MSI (s) (60:AC) [10:54:06:032]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\ext\)
MSI (s) (60:AC) [10:54:06:032]: Executing op: FileRemove(,FileName=sunjce_provider.jar,,ComponentId={D90EDC54-7757-4F94-80F9-80B665CABD2E})
MSI (s) (60:AC) [10:54:06:033]: Executing op: FileRemove(,FileName=sunrsasign.jar,,ComponentId={21936CA6-FAB1-4A3E-80A8-DA4918E3AD44})
MSI (s) (60:AC) [10:54:06:033]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\)
MSI (s) (60:AC) [10:54:06:033]: Executing op: FileRemove(,FileName=BDCore.dll,,ComponentId={BFCC60DB-3E65-49E1-8D80-5149234A3907})
MSI (s) (60:AC) [10:54:06:033]: Executing op: FileRemove(,FileName=BD_NeAudio2.ax,,ComponentId={4A29539D-6CAA-4CC6-AE84-4A0C067B5035})
MSI (s) (60:AC) [10:54:06:034]: Executing op: FileRemove(,FileName=BD_NeAudioRender.ax,,ComponentId={90D346E5-DF4E-4094-8491-5C8FA0664697})
MSI (s) (60:AC) [10:54:06:034]: Executing op: FileRemove(,FileName=BD_NeDTSHDDec.dll,,ComponentId={29E3D8FC-F623-4916-8C1A-0CF36CD64465})
MSI (s) (60:AC) [10:54:06:034]: Executing op: FileRemove(,FileName=BD_NeHDAudioMixer.ax,,ComponentId={EAE1A1A2-3885-4B32-BAAB-C736273E7792})
MSI (s) (60:AC) [10:54:06:035]: Executing op: FileRemove(,FileName=BD_NeSoundProc.ax,,ComponentId={D4077805-9351-42E6-A1FC-CF9E452A2DDE})
MSI (s) (60:AC) [10:54:06:035]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\Asia\)
MSI (s) (60:AC) [10:54:06:035]: Executing op: FileRemove(,FileName=Calcutta,,ComponentId={AECEB547-3783-4C76-ADF4-CF1FD6CA2608})
MSI (s) (60:AC) [10:54:06:035]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\)
MSI (s) (60:AC) [10:54:06:035]: Executing op: FileRemove(,FileName=GMT,,ComponentId={68233185-EA3B-4F4E-8350-C8445F37C6E3})
MSI (s) (60:AC) [10:54:06:036]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\America\)
MSI (s) (60:AC) [10:54:06:036]: Executing op: FileRemove(,FileName=Los_Angeles,,ComponentId={AC6570C0-DAC4-459B-93E2-E2E4A71A1DBA})
MSI (s) (60:AC) [10:54:06:037]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\Asia\)
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=Novosibirsk,,ComponentId={E2CFBC07-044A-4AF5-A856-7940A8BD55AC})
MSI (s) (60:AC) [10:54:06:037]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security\)
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=US_export_policy.jar,,ComponentId={E7D2587E-E096-4FA2-ACF7-253F80CD6DFC})
MSI (s) (60:AC) [10:54:06:037]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\)
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=ZoneInfoMappings,,ComponentId={9E2A2C11-E469-4537-8BBA-8DD2A7AEF4CF})
MSI (s) (60:AC) [10:54:06:037]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\)
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_date_time-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_filesystem-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_graph-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_iostreams-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_math_c99-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_math_c99f-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_math_c99l-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_math_tr1-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_math_tr1f-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_math_tr1l-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_prg_exec_monitor-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_program_options-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_random-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_regex-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_serialization-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_signals-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_system-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_thread-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_unit_test_framework-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_wave-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: FileRemove(,FileName=boost_wserialization-mt.dll,,ComponentId={8A4EF3D8-2765-43A1-93BD-785FA792AEC4})
MSI (s) (60:AC) [10:54:06:037]: Executing op: ActionStart(Name=RemoveFolders,Description=Removing folders,Template=Folder: [1])
MSI (s) (60:AC) [10:54:06:037]: Executing op: FolderRemove(Folder=C:\Program Files (x86)\Common Files\Nero\BDCore10\,Foreign=0)
MSI (s) (60:AC) [10:54:06:037]: Executing op: ActionStart(Name=PublishProduct,Description=Publishing product information,)
MSI (s) (60:AC) [10:54:06:037]: Executing op: CleanupConfigData()
MSI (s) (60:AC) [10:54:06:037]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=0,Remove=1)
MSI (s) (60:AC) [10:54:06:037]: Note: 1: 1402 2: UNKNOWN\Installer\Products\26BCC73245483E341B85A3DC104358E2\Patches 3: 2
MSI (s) (60:AC) [10:54:06:037]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=1,Remove=1)
MSI (s) (60:AC) [10:54:06:053]: Executing op: CleanupConfigData(RemovingProduct=1)
MSI (s) (60:AC) [10:54:06:053]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\26BCC73245483E341B85A3DC104358E2\Patches 3: 2
MSI (s) (60:AC) [10:54:06:053]: Executing op: ActionStart(Name=Nero_CA_UninstallSetAssociationsRollback,,)
MSI (s) (60:AC) [10:54:06:053]: Executing op: CustomActionSchedule(Action=Nero_CA_UninstallSetAssociationsRollback,ActionType=1281,Source=BinaryData,Target=CA_UninstallSetAssociationsRollback,)
MSI (s) (60:AC) [10:54:06:053]: Executing op: ActionStart(Name=Nero_CA_UninstallSetAssociations,,)
MSI (s) (60:AC) [10:54:06:053]: Executing op: CustomActionSchedule(Action=Nero_CA_UninstallSetAssociations,ActionType=1025,Source=BinaryData,Target=CA_UninstallSetAssociations,)
MSI (s) (60:94) [10:54:06:053]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI1E0A.tmp, Entrypoint: CA_UninstallSetAssociations
MSI (s) (60:AC) [10:54:06:153]: Executing op: ActionStart(Name=Nero_CA_DeleteAssociationsBackup,,)
CA_UninstallSetAssociations: CustomActions.cpp : 1016 :  Succeeded
MSI (s) (60:AC) [10:54:06:153]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteAssociationsBackup,ActionType=1537,Source=BinaryData,Target=CA_DeleteAssociationsBackup,CustomActionData={237CCB62-8454-43E3-B158-3ACD0134852E}|)
MSI (s) (60:AC) [10:54:06:169]: Executing op: ActionStart(Name=Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore,,)
MSI (s) (60:AC) [10:54:06:169]: Executing op: CustomActionSchedule(Action=Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore,ActionType=1537,Source=BinaryData,Target=CA_MergeLocalFileAssociationDbToGlobalAndRestore,CustomActionData={237CCB62-8454-43E3-B158-3ACD0134852E})
MSI (s) (60:AC) [10:54:06:169]: Executing op: ActionStart(Name=InstallFinalize,,)
MSI (s) (60:AC) [10:54:06:169]: Executing op: CleanupTempFiles(TempFiles=C:\WINDOWS\Installer\33a1c1ad.mst)
MSI (s) (60:AC) [10:54:06:169]: Scheduling file 'C:\WINDOWS\Installer\33a1c1ad.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:AC) [10:54:06:169]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=11058600)
MSI (s) (60:AC) [10:54:06:200]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:AC) [10:54:06:216]: User policy value 'DisableRollback' is 0
MSI (s) (60:AC) [10:54:06:216]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:AC) [10:54:06:216]: Unlocking Server
MSI (s) (60:AC) [10:54:06:216]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
Action ended 10:54:06: InstallFinalize. Return value 1.
Action ended 10:54:06: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {E662C6C7-F7AE-455D-AF35-8FA0A484DE90}
Property(S): ProductCode = {237CCB62-8454-43E3-B158-3ACD0134852E}
Property(S): Installed = 2010/12/21 09:38:40
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): ROOTDRIVE = C:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): UILevel = 3
Property(S): OriginalDatabase = C:\Windows\Installer\11a60.msi
Property(S): DATABASE = C:\Windows\Installer\11a60.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.3.14393.0
Property(S): MsiNetAssemblySupport = 4.6.1586.0
Property(S): Date = 6/11/2017
Property(S): Time = 10:54:06
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 23
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 1033
Property(S): ComputerName = ZANDRAJONES-PC
Property(S): UserLanguageID = 1033
Property(S): UserSID = S-1-5-21-3088507388-2561779440-336279174-1001
Property(S): LogonUser = Zandra Jones
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 5062
Property(S): PhysicalMemory = 3839
Property(S): Intel = 16
Property(S): Msix64 = 16
Property(S): MsiAMD64 = 16
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): RecentFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): VersionNT = 603
Property(S): Nero_CA_DeleteAssociationsBackup = {237CCB62-8454-43E3-B158-3ACD0134852E}|
Property(S): Nero_CA_DeleteLocalFileAssociationDb = {237CCB62-8454-43E3-B158-3ACD0134852E}
Property(S): Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore = {237CCB62-8454-43E3-B158-3ACD0134852E}
Property(S): TARGETDIR = C:\
Property(S): ALLUSERSPROFILE = C:\ProgramData\
Property(S): ZI = C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\
Property(S): AMERICA = C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\America\
Property(S): ASIA = C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\zi\Asia\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): AppDataFolder = C:\Users\Zandra Jones\AppData\Roaming\
Property(S): SHARED = C:\Program Files (x86)\Common Files\Nero\Nero 10\Shared\
Property(S): BDCORE1 = C:\Program Files (x86)\Common Files\Nero\Nero 10\Shared\BDCore\
Property(S): NERO1 = C:\Program Files (x86)\Common Files\Nero\
Property(S): BDCORE10 = C:\Program Files (x86)\Common Files\Nero\BDCore10\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Common Files\Nero\BDCore10\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Common Files\Nero\BDCore10\Database\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): LIB = C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\
Property(S): EXT = C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\ext\
Property(S): FavoritesFolder = C:\Users\Zandra Jones\Favorites\
Property(S): FontsFolder = C:\WINDOWS\Fonts\
Property(S): GlobalAssemblyCache = C:\
Property(S): IMAGE = C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\image\
Property(S): INSTALLDIR = C:\Program Files (x86)\Common Files\Nero\BDCore10\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Zandra Jones\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Zandra Jones\Pictures\
Property(S): NERO_10 = C:\Program Files (x86)\Common Files\Nero\Nero 10\
Property(S): PersonalFolder = C:\Users\Zandra Jones\Documents\
Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): SECURITY = C:\Program Files (x86)\Common Files\Nero\BDCore10\lib\security\
Property(S): SendToFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System16Folder = C:\
Property(S): System64Folder = C:\WINDOWS\SysWOW64\
Property(S): SystemFolder = C:\WINDOWS\SysWOW64\
Property(S): TempFolder = C:\Users\ZANDRA~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = C:\Users\Zandra Jones\
Property(S): WindowsFolder = C:\WINDOWS\
Property(S): NetHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): TargetFolder.C9525E77.3ECDB9B9_ECD5_4F78_8BDC_16E4E198F3A6 = C:\Program Files (x86)\Common Files\Nero\BDCore10\
Property(S): ALLUSERS = 1
Property(S): RemoteAdminTS = 1
Property(S): WindowsVolume = C:\
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 9600
Property(S): VersionNT64 = 603
Property(S): VersionMsi = 5.00
Property(S): VersionDatabase = 200
Property(S): PRODUCTLANGUAGE = 0
Property(S): BROWSERPATH = C:\Program Files (x86)\Mozilla Firefox\firefox.exe
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): _IsMaintenance = Change
Property(S): RestartManagerOption = CloseRestart
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): Display_IsBitmapDlg = 1
Property(S): NERO.INSTALL_AUTOPLAY = 1
Property(S): NERO.INSTALL_DESKTOPSHORTCUT = 1
Property(S): NERO.INSTALL_EXTENSIONS = 1
Property(S): ARPNOMODIFY = 1
Property(S): ARPNOREPAIR = 0
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): MsiSystemRebootPending = 1
Property(S): ARPURLINFOABOUT = http://www.nero.com
Property(S): AgreeToLicense = No
Property(S): DWUSINTERVAL = 30
Property(S): DWUSLINK = CEDC87AF3EEC9728FEACA09FCECC978F3E1CA78FDEFBD0E8CEFC97BFAEABF0CFBECCF098D9AC
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): ErrorDialog = SetupError
Property(S): INSTALLLEVEL = 100
Property(S): ISVROOT_PORT_NO = 0
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PREVENT_DOWNGRADE_EXIT = A newer version of this application is already installed on this computer. If you wish to install this version, please uninstall the newer version first. Click OK to exit the wizard.
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): InstallChoice = AR
Property(S): MSIDISABLERMRESTART = 0
Property(S): MSIRMSHUTDOWN = 0
Property(S): Manufacturer = Nero AG
Property(S): NERO.APPID = 99
Property(S): NERO.INSTALLER_CATEGORY = 2
Property(S): NERO.LANGUAGES_INSTALL = zh-TW,cs-CZ,da-DK,de-DE,el-GR,en-US,es-ES,fi-FI,fr-FR,hu-HU,it-IT,ja-JP,ko-KR,nl-NL,nb-NO,pl-PL,pt-BR,pt-PT,ru-RU,sv-SE,th-TH,tr-TR,zh-CN
Property(S): NERO.LANGUAGE_CURRENT = en-US
Property(S): NERO.PRODUCT_LINE = NeroX
Property(S): Nero.AppDesc = Nero High-Definition Video Playback
Property(S): Nero.AppSubKey = BDCore
Property(S): Nero.GenerationId = 10
Property(S): Nero.GenerationName = Nero 10
Property(S): Nero.MainComponent = {BFCC60DB-3E65-49E1-8D80-5149234A3907}
Property(S): Nero.PackageName = NBDCORE
Property(S): Nero.TemplateRev = 162991
Property(S): Nero.mediaPath = \bdcore\
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): CLIENTPROCESSID = 8728
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = High-Definition Video Playback
Property(S): ProductVersion = 7.3.10000.0.0
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): SecureCustomProperties = INSTALLDIR;ISFOUNDNEWERPRODUCTVERSION;IS_MINOR_UPGRADE;MEDIAPACKAGEPATH;MSIRESTARTMANAGERCONTROL;MSIDISABLERMRESTART;MSIRMSHUTDOWN;NERO.INSTALL_DESKTOPSHORTCUT;NERO.INCLUDED_KEY;NERO.INSTALL_AUTOPLAY;NERO.INSTALL_EXTENSIONS;NERO.INSTALLER_CATEGORY;NERO.IS_EULA_ACCEPTED;NERO.LANGUAGE_CURRENT;NERO.PRODUCT_LINE;NERO.IS_CHAINED;REBOOT;REINSTALL;REINSTALLMODE;SUPPORTDIR;TRANSFORMS
Property(S): ISReleaseFlags = Application,Languages,SystemIntegration
Property(S): MsiLogFileLocation = C:\Users\ZANDRA~1\AppData\Local\Temp\MSI1b9f9.LOG
Property(S): ARPINSTALLLOCATION = C:\Program Files (x86)\Common Files\Nero\BDCore10\
Property(S): CLIENTUILEVEL = 2
Property(S): CURRENTDIRECTORY = C:\WINDOWS\system32
Property(S): REMOVE = ALL
Property(S): ISCHAINER = 1
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): REBOOT = ReallySuppress
Property(S): NERO.IS_CHAINED = YES
Property(S): ProductState = 5
Property(S): TRANSFORMS = C:\Windows\Installer\{237CCB62-8454-43E3-B158-3ACD0134852E}\1033.mst
Property(S): PackageCode = {19C411BD-15F8-4A1D-9D1B-94CA36079589}
Property(S): COMPANYNAME = Microsoft
Property(S): USERNAME = AutoBVT
MSI (s) (60:AC) [10:54:06:269]: Note: 1: 1724
MSI (s) (60:AC) [10:54:06:269]: Product: High-Definition Video Playback -- Removal completed successfully.
MSI (s) (60:AC) [10:54:06:269]: Windows Installer removed the product. Product Name: High-Definition Video Playback. Product Version: 7.3.10000.0.0. Product Language: 1033. Manufacturer: Nero AG. Removal success or error status: 0.
MSI (s) (60:AC) [10:54:06:269]: Attempting to delete file C:\WINDOWS\Installer\33a1c1ad.mst
MSI (s) (60:AC) [10:54:06:335]: Deferring clean up of packages/files, if any exist
MSI (s) (60:AC) [10:54:06:336]: Attempting to delete file C:\WINDOWS\Installer\33a1c1ad.mst
MSI (s) (60:AC) [10:54:06:336]: Unable to delete the file outside of the engine. LastError = 2
MSI (s) (60:AC) [10:54:06:336]: MainEngineThread is returning 0
=== Logging stopped: 6/11/2017  10:54:06 ===
MSI (c) (18:DC) [10:54:06:339]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (c) (18:DC) [10:54:06:340]: MainEngineThread is returning 0
=== Verbose logging stopped: 6/11/2017  10:54:06 ===
=== Verbose logging started: 6/11/2017  10:54:06  Build type: SHIP UNICODE 5.00.10011.00  Calling process: C:\Users\ZANDRA~1\AppData\Local\Temp\MSIE858.tmp ===
MSI (c) (18:98) [10:54:06:370]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (18:18) [10:54:06:384]: Resetting cached policy values
MSI (c) (18:18) [10:54:06:384]: Machine policy value 'Debug' is 0
MSI (c) (18:18) [10:54:06:384]: ******* RunEngine:
           ******* Product: C:\Windows\Installer\11a58.msi
           ******* Action:
           ******* CommandLine: **********
MSI (c) (18:18) [10:54:06:384]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (18:18) [10:54:09:393]: Failed to grab execution mutex. System error 258.
MSI (c) (18:18) [10:54:09:409]: Cloaking enabled.
MSI (c) (18:18) [10:54:09:409]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (18:18) [10:54:09:409]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (60:38) [10:54:09:409]: Running installation inside multi-package transaction C:\Windows\Installer\11a49.msi
MSI (s) (60:38) [10:54:09:409]: Grabbed execution mutex.
MSI (s) (60:08) [10:54:09:424]: Resetting cached policy values
MSI (s) (60:08) [10:54:09:424]: Machine policy value 'Debug' is 0
MSI (s) (60:08) [10:54:09:424]: ******* RunEngine:
           ******* Action:
MSI (s) (60:08) [10:54:09:447]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (60:08) [10:54:09:478]: MSCOREE not loaded loading copy from system32
MSI (s) (60:08) [10:54:09:493]: End dialog not enabled
MSI (s) (60:08) [10:54:09:493]: Original package ==> C:\Windows\Installer\11a58.msi
MSI (s) (60:08) [10:54:09:493]: Package we're running from ==> C:\Windows\Installer\11a58.msi
MSI (s) (60:08) [10:54:09:509]: APPCOMPAT: Uninstall Flags override found.
MSI (s) (60:08) [10:54:09:509]: APPCOMPAT: Uninstall VersionNT override found.
MSI (s) (60:08) [10:54:09:509]: APPCOMPAT: Uninstall ServicePackLevel override found.
MSI (s) (60:08) [10:54:09:509]: APPCOMPAT: looking for appcompat database entry with ProductCode '{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}'.
MSI (s) (60:08) [10:54:09:509]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (60:08) [10:54:09:525]: Machine policy value 'DisablePatch' is 0
MSI (s) (60:08) [10:54:09:525]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (60:08) [10:54:09:525]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (60:08) [10:54:09:525]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (60:08) [10:54:09:525]: Looking for file transform: C:\Windows\Installer\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}\1033.mst
MSI (s) (60:08) [10:54:09:525]: File will have security applied from OpCode.
MSI (s) (60:08) [10:54:09:547]: Original transform ==> C:\Windows\Installer\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}\1033.mst
MSI (s) (60:08) [10:54:09:547]: Transform we're running from ==> C:\WINDOWS\Installer\33a1c1b1.mst
MSI (s) (60:08) [10:54:09:547]: SOFTWARE RESTRICTION POLICY: Verifying transform --> 'C:\Windows\Installer\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}\1033.mst' against software restriction policy
MSI (s) (60:08) [10:54:09:547]: SOFTWARE RESTRICTION POLICY: C:\Windows\Installer\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}\1033.mst has a digital signature
MSI (s) (60:08) [10:54:09:562]: SOFTWARE RESTRICTION POLICY: C:\Windows\Installer\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}\1033.mst is permitted to run at the 'unrestricted' authorization level.
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: _Tables 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: _Columns 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Media 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: File 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: TRANSFORM: 'PatchPackage' table is missing or empty.  No pre-transform fixup necessary.
MSI (s) (60:08) [10:54:09:562]: TRANSFORM: Applying regular transform to database.
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ActionText 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: AdminExecuteSequence 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: AdminUISequence 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: AdvtExecuteSequence 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: AdvtUISequence 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: AppId 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: AppSearch 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Feature 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Binary 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: CheckBox 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Class 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Component 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ProgId 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ComboBox 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Directory 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Control 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Dialog 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ControlCondition 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ControlEvent 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: CustomAction 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ModuleSignature 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Error 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: EventMapping 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: FeatureComponents 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: InstallExecuteSequence 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: InstallUISequence 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: LaunchCondition 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ListBox 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ListView 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ModuleComponents 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ModuleDependency 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: MsiFileHash 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: RadioButton 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Registry 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: RegLocator 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: TextStyle 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: UIText 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: Upgrade 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: _Validation 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ISComponentExtended 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: ISCustomActionReference 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: _MsiPatchTransformView 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: #_BaselineCost 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: #_BaselineFile 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: #_BaselineData 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: #_PatchCache 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: MsiPatchCertificate 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: MsiDigitalCertificate 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: APPCOMPAT: looking for appcompat database entry with ProductCode '{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}'.
MSI (s) (60:08) [10:54:09:562]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (60:08) [10:54:09:562]: Transforms are not secure.
MSI (s) (60:08) [10:54:09:562]: Transforming table Property.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\ZANDRA~1\AppData\Local\Temp\MSI1b9f9.LOG'.
MSI (s) (60:08) [10:54:09:562]: Command Line: NERO.IS_CHAINED=YES REBOOT=ReallySuppress MSIRESTARTMANAGERCONTROL=Disable ISCHAINER=1 REMOVE=ALL CURRENTDIRECTORY=C:\WINDOWS\system32 CLIENTUILEVEL=2 CLIENTPROCESSID=8728
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{A8DDE995-BF2A-467D-9EE5-7CC747A47ED8}'.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding TRANSFORMS property. Its value is 'C:\Windows\Installer\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}\1033.mst'.
MSI (s) (60:08) [10:54:09:562]: Product Code passed to Engine.Initialize:           '{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}'
MSI (s) (60:08) [10:54:09:562]: Product Code from property table before transforms: '{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}'
MSI (s) (60:08) [10:54:09:562]: Product Code from property table after transforms:  '{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}'
MSI (s) (60:08) [10:54:09:562]: Product registered: entering maintenance mode
MSI (s) (60:08) [10:54:09:562]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI (s) (60:08) [10:54:09:562]: Product {2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F} is admin assigned: LocalSystem owns the publish key.
MSI (s) (60:08) [10:54:09:562]: Product {2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F} is managed.
MSI (s) (60:08) [10:54:09:562]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding ProductState property. Its value is '5'.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI (s) (60:08) [10:54:09:562]: Package name retrieved from configuration data: 'Nero.CoreComponents.msi'
MSI (s) (60:08) [10:54:09:562]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (60:08) [10:54:09:562]: Machine policy value 'DisableMsi' is 0
MSI (s) (60:08) [10:54:09:562]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:08) [10:54:09:562]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:08) [10:54:09:562]: Running product '{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}' with elevated privileges: Product is assigned.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding NERO.IS_CHAINED property. Its value is 'YES'.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding REBOOT property. Its value is 'ReallySuppress'.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding MSIRESTARTMANAGERCONTROL property. Its value is 'Disable'.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding ISCHAINER property. Its value is '1'.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding REMOVE property. Its value is 'ALL'.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\WINDOWS\system32'.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '2'.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '8728'.
MSI (s) (60:08) [10:54:09:562]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (60:08) [10:54:09:562]: RESTART MANAGER: Disabled by MSIRESTARTMANAGERCONTROL property; Windows Installer will use the built-in FilesInUse functionality.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (s) (60:08) [10:54:09:562]: TRANSFORMS property is now: C:\Windows\Installer\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}\1033.mst
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '0'.
MSI (s) (60:08) [10:54:09:562]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '400'.
MSI (s) (60:08) [10:54:09:562]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming
MSI (s) (60:08) [10:54:09:562]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Favorites
MSI (s) (60:08) [10:54:09:578]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (60:08) [10:54:09:578]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Documents
MSI (s) (60:08) [10:54:09:578]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (60:08) [10:54:09:578]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (60:08) [10:54:09:578]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (60:08) [10:54:09:578]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (60:08) [10:54:09:578]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (60:08) [10:54:09:578]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Local
MSI (s) (60:08) [10:54:09:594]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Pictures
MSI (s) (60:08) [10:54:09:594]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (60:08) [10:54:09:594]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (60:08) [10:54:09:594]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (60:08) [10:54:09:609]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (60:08) [10:54:09:609]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (60:08) [10:54:09:609]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Desktop
MSI (s) (60:08) [10:54:09:609]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (s) (60:08) [10:54:09:609]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (s) (60:08) [10:54:09:609]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (60:08) [10:54:09:625]: MSI_LUA: Setting AdminUser property to 1 because the product is already installed managed and per-machine
MSI (s) (60:08) [10:54:09:625]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (60:08) [10:54:09:625]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (s) (60:08) [10:54:09:625]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (60:08) [10:54:09:625]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'AutoBVT'.
MSI (s) (60:08) [10:54:09:625]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Microsoft'.
MSI (s) (60:08) [10:54:09:625]: PROPERTY CHANGE: Adding Installed property. Its value is '2011/05/31 13:27:46'.
MSI (s) (60:08) [10:54:09:625]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\11a58.msi'.
MSI (s) (60:08) [10:54:09:625]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Windows\Installer\11a58.msi'.
MSI (s) (60:08) [10:54:09:625]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (s) (60:08) [10:54:09:625]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:08) [10:54:09:625]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:08) [10:54:09:625]: User policy value 'DisableRollback' is 0
MSI (s) (60:08) [10:54:09:625]: PROPERTY CHANGE: Adding UILevel property. Its value is '3'.
=== Logging started: 6/11/2017  10:54:09 ===
MSI (s) (60:08) [10:54:09:642]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:08) [10:54:09:645]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
MSI (s) (60:08) [10:54:09:645]: APPCOMPAT: [DetectVersionLaunchCondition] Launch condition already passes.
MSI (s) (60:08) [10:54:09:646]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (60:08) [10:54:09:646]: Doing action: INSTALL
Action start 10:54:09: INSTALL.
MSI (s) (60:08) [10:54:09:647]: Running ExecuteSequence
MSI (s) (60:08) [10:54:09:647]: Skipping action: ISSetAllUsers (condition is false)
MSI (s) (60:08) [10:54:09:647]: Doing action: AppSearch
Action start 10:54:09: AppSearch.
MSI (s) (60:08) [10:54:09:647]: PROPERTY CHANGE: Modifying BROWSERPATH property. Its current value is 'c:\program files\internet explorer\iexplore.exe'. Its new value: 'C:\Program Files (x86)\Mozilla Firefox\firefox.exe'.
MSI (s) (60:08) [10:54:09:647]: Skipping action: LaunchConditions (condition is false)
MSI (s) (60:08) [10:54:09:647]: Doing action: FindRelatedProducts
Action ended 10:54:09: AppSearch. Return value 1.
MSI (s) (60:08) [10:54:09:647]: Skipping FindRelatedProducts action: not run in maintenance mode
Action start 10:54:09: FindRelatedProducts.
MSI (s) (60:08) [10:54:09:647]: Skipping action: ISPreventDowngrade (condition is false)
MSI (s) (60:08) [10:54:09:647]: Skipping action: CCPSearch (condition is false)
MSI (s) (60:08) [10:54:09:647]: Skipping action: RMCCPSearch (condition is false)
MSI (s) (60:08) [10:54:09:647]: Doing action: ValidateProductID
Action ended 10:54:09: FindRelatedProducts. Return value 0.
Action start 10:54:09: ValidateProductID.
MSI (s) (60:08) [10:54:09:647]: Skipping action: Nero_CA_SetExtensions (condition is false)
MSI (s) (60:08) [10:54:09:647]: Skipping action: Nero_CA_SetDesktopShortcuts (condition is false)
MSI (s) (60:08) [10:54:09:647]: Skipping action: Nero_CA_SetAutoplay (condition is false)
MSI (s) (60:08) [10:54:09:647]: Skipping action: Nero_CA_SetUserProperties (condition is false)
MSI (s) (60:08) [10:54:09:647]: Doing action: Nero_CAD_DeleteLocalFileAssociationDb
Action ended 10:54:09: ValidateProductID. Return value 1.
MSI (s) (60:08) [10:54:09:647]: PROPERTY CHANGE: Adding Nero_CA_DeleteLocalFileAssociationDb property. Its value is '{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}'.
Action start 10:54:09: Nero_CAD_DeleteLocalFileAssociationDb.
MSI (s) (60:08) [10:54:09:647]: Doing action: Nero_CA_GenerateFileAssociationList
Action ended 10:54:09: Nero_CAD_DeleteLocalFileAssociationDb. Return value 1.
MSI (s) (60:34) [10:54:09:663]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI2C14.tmp, Entrypoint: CA_GenerateFileAssociationList
Action start 10:54:09: Nero_CA_GenerateFileAssociationList.
MSI (s) (60:08) [10:54:09:710]: Doing action: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore
Action ended 10:54:09: Nero_CA_GenerateFileAssociationList. Return value 1.
MSI (s) (60:08) [10:54:09:710]: PROPERTY CHANGE: Adding Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore property. Its value is '{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}'.
Action start 10:54:09: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore.
MSI (s) (60:08) [10:54:09:710]: Doing action: Nero_CAD_DeleteAssociationsBackup
Action ended 10:54:09: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore. Return value 1.
MSI (s) (60:08) [10:54:09:710]: PROPERTY CHANGE: Adding Nero_CA_DeleteAssociationsBackup property. Its value is '{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}|'.
Action start 10:54:09: Nero_CAD_DeleteAssociationsBackup.
MSI (s) (60:08) [10:54:09:710]: Doing action: Nero_CAD_Install_SetAssociations
Action ended 10:54:09: Nero_CAD_DeleteAssociationsBackup. Return value 1.
Action start 10:54:09: Nero_CAD_Install_SetAssociations.
MSI (s) (60:08) [10:54:09:710]: Doing action: Nero_CAD_Install_SetAssociationsRollback
Action ended 10:54:09: Nero_CAD_Install_SetAssociations. Return value 1.
Action start 10:54:09: Nero_CAD_Install_SetAssociationsRollback.
MSI (s) (60:08) [10:54:09:710]: Doing action: Nero_CAD_Uninstall_SetAssociations
Action ended 10:54:09: Nero_CAD_Install_SetAssociationsRollback. Return value 1.
Action start 10:54:09: Nero_CAD_Uninstall_SetAssociations.
MSI (s) (60:08) [10:54:09:710]: Doing action: Nero_CAD_Uninstall_SetAssociationsRollback
Action ended 10:54:09: Nero_CAD_Uninstall_SetAssociations. Return value 1.
Action start 10:54:09: Nero_CAD_Uninstall_SetAssociationsRollback.
MSI (s) (60:08) [10:54:09:725]: Doing action: CostInitialize
Action ended 10:54:09: Nero_CAD_Uninstall_SetAssociationsRollback. Return value 1.
MSI (s) (60:08) [10:54:09:725]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (60:08) [10:54:09:725]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (60:08) [10:54:09:725]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:08) [10:54:09:725]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (60:08) [10:54:09:725]: Note: 1: 2205 2:  3: __MsiPatchFileList
MSI (s) (60:08) [10:54:09:725]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
Action start 10:54:09: CostInitialize.
MSI (s) (60:08) [10:54:09:725]: Skipping action: ResolveSource (condition is false)
MSI (s) (60:08) [10:54:09:725]: Doing action: FileCost
Action ended 10:54:09: CostInitialize. Return value 1.
MSI (s) (60:08) [10:54:09:725]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:08) [10:54:09:725]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (60:08) [10:54:09:725]: Note: 1: 2205 2:  3: TypeLib
Action start 10:54:09: FileCost.
MSI (s) (60:08) [10:54:09:725]: Doing action: IsolateComponents
Action ended 10:54:09: FileCost. Return value 1.
Action start 10:54:09: IsolateComponents.
MSI (s) (60:08) [10:54:09:725]: Doing action: setUserProfileNT
Action ended 10:54:09: IsolateComponents. Return value 0.
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Zandra Jones'.
Action start 10:54:09: setUserProfileNT.
MSI (s) (60:08) [10:54:09:725]: Skipping action: SetAllUsersProfileNT (condition is false)
MSI (s) (60:08) [10:54:09:725]: Doing action: setAllUsersProfile2K
Action ended 10:54:09: setUserProfileNT. Return value 1.
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
Action start 10:54:09: setAllUsersProfile2K.
MSI (s) (60:08) [10:54:09:725]: Doing action: CostFinalize
Action ended 10:54:09: setAllUsersProfile2K. Return value 1.
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (60:08) [10:54:09:725]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding COMP_INSTALL_DIR.00474EC1_5A5B_4CC6_B44B_B587A0F57A8F property. Its value is 'C:\Program Files (x86)\Common Files\Nero\AdvrCntr5'.
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding INSTALLDIR.D39B4B65_3692_4292_833F_2C81D15845EB property. Its value is 'C:\Program Files (x86)\Common Files\Nero\AdvrCntr5'.
MSI (s) (60:08) [10:54:09:725]: Note: 1: 2205 2:  3: Condition
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Zandra Jones'. Its new value: 'C:\Users\Zandra Jones\'.
MSI (s) (60:08) [10:54:09:725]: WIN64DUALFOLDERS: 'C:\WINDOWS\SysWOW64\' will substitute 20 characters in 'C:\WINDOWS\system32\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 1).
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Modifying System64Folder property. Its current value is 'C:\WINDOWS\system32\'. Its new value: 'C:\WINDOWS\SysWOW64\'.
MSI (s) (60:08) [10:54:09:725]: PROPERTY CHANGE: Adding System16Folder property. Its value is 'C:\'.
MSI (s) (60:08) [10:54:09:741]: PROPERTY CHANGE: Adding ScNeroFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\'.
MSI (s) (60:08) [10:54:09:741]: PROPERTY CHANGE: Adding ScProductFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\'.
MSI (s) (60:08) [10:54:09:741]: WIN64DUALFOLDERS: 'C:\Program Files (x86)\' will substitute 17 characters in 'C:\Program Files\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 0).
MSI (s) (60:08) [10:54:09:741]: PROPERTY CHANGE: Modifying ProgramFiles64Folder property. Its current value is 'C:\Program Files\'. Its new value: 'C:\Program Files (x86)\'.
MSI (s) (60:08) [10:54:09:742]: PROPERTY CHANGE: Adding GlobalAssemblyCache property. Its value is 'C:\'.
MSI (s) (60:08) [10:54:09:742]: PROPERTY CHANGE: Adding ISMyCompanyDir property. Its value is 'C:\Program Files (x86)\My Company Name\'.
MSI (s) (60:08) [10:54:09:742]: PROPERTY CHANGE: Adding ISMyProductDir property. Its value is 'C:\Program Files (x86)\My Company Name\My Product Name\'.
MSI (s) (60:08) [10:54:09:742]: PROPERTY CHANGE: Adding NERO property. Its value is 'C:\Program Files (x86)\Nero\'.
MSI (s) (60:08) [10:54:09:742]: PROPERTY CHANGE: Adding NERO_PRODUCT property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\'.
MSI (s) (60:08) [10:54:09:742]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\'.
MSI (s) (60:08) [10:54:09:742]: PROPERTY CHANGE: Adding NERO_CORE_COMPONENTS property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\Nero Core Components\'.
MSI (s) (60:08) [10:54:09:742]: PROPERTY CHANGE: Adding ISYourDataBaseDir property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\Database\'.
MSI (s) (60:08) [10:54:09:742]: PROPERTY CHANGE: Adding DATABASEDIR proper
Offline Nissi1
I ran ESET again with the same results. Almost immediately after the scan begin there is a gree check mark and the words:  Current Scan Result: No threats found.
Hi, Nissi1.  I have no idea what those logs are that you posted as they are not the results of the ESET scans.  Did you run ESET from the computer or from the USB?
Can you update Pale Moon now?  Click Help > About Pale Moon > Check for Updates.
Offline Nissi1
Corrine, I ran the logs from my document folder. That is really weird you do not know what they are (Twilight Zone music again) :'(.  I will try again but do you have any idea what keeps interupting the scans? Prior to this MBAM did not complete its scans and in the Eset logs I noticed many  Windows Defender's scans were also incomplete.  Yet every day Defender's Virus and Protection automatic scans reported No Action Needed.
I have not used PaleMoon nor have I turned of my computer for fear both may make things wose. Before I run another scan I need to know do I simply copy the entire log then post it or do I highlight  and post it in sections (which is what I did with the last log)?
Thank you for your patience.
That was not a list of threats found.  Rather than asking you to go back to find the instructions, I've added them again below but changed the information about the log to be posted to green.  What you provided was "verbose logging" not the log of threats found.
Please do a scan with ESET Online Scanner
Temporarily disable your AntiVirus and AntiSpyware protection - instructions here.
  • Please visit the ESET Online Scanner website
  • Click the SCAN NOW button to download the esetonlinescanner_enu.exe file to the Desktop
  • Double click esetonlinescanner_enu.exe. Accept the Terms of Use
  • Select Enable detection of potentially unwanted applications
  • In Advanced Settings: make sure that Clean threats automatically is unchecked
  • And Enable detection of potentially unsafe applications, Enable detection of suspicious applications, Scan archives, and Enable Anti-Stealth technology are all checked.
  • Click Scan
  • The program will begin to download it's virus database. The speed may vary depending on your Internet connection.
  • When completed, the program will begin to scan. This may take several hours. Please, be patient.
  • Do not do anything on your machine as it may interrupt the scan.
  • When completed it'll show a list of "Threats found", click beneath it on Save to text file.... and save it as ESET log.txt on your Desktop.
  • Then click Do not clean. Place a checkmark at Delete application's data on close, click Finish and close the program.
Don't forget to re-enable previously switched-off protection software!
Offline Nissi1
Thank you Corrine.  I have started another scan and again after scanning only 21 files ESET reports 'No Threats Found' but it continues to scan.  After 1 hour ESET stops scanning and reports it is unable to complete the scan.  No logs this time.  Can you suggest another scanner?
See if F-Secure will work.
Go to F-Secure Online Scanner and click the "Run now" button.  Save the file and follow the instructions provided by the scanner.
They have changed the set-up since I last had someone use it.  Watch for an option to "Show Report".  Highlight and copy the report, pasting it as reply here.
Offline Nissi1
Again, 'No Threats Found' appeared after F-Secure's database download and before the actual scan started. A hour later the scan stopped unfinished. A log was not produced.
When running F-Secure from my desktop I received a popup which read:  Controlled folder Access blocked C:\Users\Zan...\FRST64.exe from making changess to the %desktopdirectory%    Palemoon was blocked from making changes to the folder %userprofile%\desktop when I attempted the new update.  Will either turning off Defender's  protected folders or adding them to the procted folders list make a difference?
Corrine, I must take a break for the rest of the night and return tomorrow. I am not sure if I should leave my computer on or turn it off since it might not boot up again.
Goodnight
Offline Nissi1
Should F-Secure indicate 'No Threats Found' right after the downloading of its database but before the actual scan?
Offline MikeW
Yes, same as eset it will change if a threat is found
Well, that explains it!  "Controlled folder access" is indeed blocking Pale Moon, etc. from completing.  Yes, disable Controlled folder access and then see if you can update Pale Moon.
Offline Nissi1
Controlled Folder Access (CAF) is grayed out, I cannot turn it off.  Pale Moon is up to date.  Still cannot run ESET to completion. CAF continues to block some websites and the app Gramarly.
Offline Nissi1
Still cannot get a complete scan from ESET.  F-Secure finally completed a scan.  Nothing was found but it did not produce a log.
