Author Topic: Malware which seems to Primarily Affect PaleMoon (Blue Screen, Audio Alert, etc)  (Read 22479 times)
By "grayed out", do you mean that it is toggled Off?
Select Start  > Settings
Choose Update & security  > Windows Defender.
Select Open Windows Defender Security Center.
Select Virus & threat protection, and then choose Virus & threat protection settings.
Under Controlled folder access, what does it show?
Offline Nissi1
I see what happened.  I turned off Windows Defender Real Time Protection to run scans.  When this is off, Controlled Folder Access is grayed out!
Since Pale Moon is up to date, I will attempt to run F-Secure again.
Offline Nissi1
(Yes, grayed out meant toggled off.  I discovered to have the Controlled Access Folder and Windows Defender Real Time Protection disabled at the same time, Controlled Access Folder had to be disabled first.)
Ran ESET again and just as it was about to reach the end it stopped working! But no virus was found.   According to the first erroneous ESET scan I sent you several of the Windows Defender's scan also did not complete yet as with ESET nothing was found. Could these be false reading?
As for now, though a few addons are not working (Pale Moon and Fire Fox), I cannot access a few websites such as my supermarket (Pale Moon) and I lost audio twice but got it back, my computer seems to be working fine. But is there another scan I can run to get a log?
Let's see if a Malwarebytes scan will complete now.
Please open Malwarebytes and do the following:
  • Select Scan Now on the Dashboard. Or select the Threat Scan from the Scan menu.
  • If an update of the definitions is available, it will be implemented before the rest of the scanning procedure.
  • When the scan is complete, make sure that all Threats are selected, and click Remove Selected.
  • Restart your computer when prompted to do so.
  • The log is available from the History tab.  Please post it contents in your next reply.
Please do the following to provide fresh FRST logs:
  • Right click to run as administrator. When the tool opens click Yes to disclaimer.
  • Note:  After FRST completes updating and the tool appears, check the box next to Addition.txt under the "Optional Scan" section
  • Press Scan button.
  • Please copy/paste both logs in your reply.
Offline Nissi1
Good morning, I will do as you asked. I was looking through the first FRST log I posted and saw something which concerns me very much.  "Nero" a program installed in my computer.  I nor anyone in my home has ever used Nero or heard of it until I Googled it. Why would Nero be listed as a program in my computer?
Nero is best known as software for burning CDs, DVDs, or Blu-rays.  It appears that it may not have been cleanly uninstalled.  We'll see what shows up with the fresh logs.
Nero is added on by a few computer companies, when you purchase a new one. Acer is almost a guarntee, it's been installed since the first day you turned it on.
Offline Nissi1
Corinne, I am the only user of the pc and I have never burned a CD or DVD in my life or installed NERO.  I do have Spectrum cable, telephone and internet service. Could someone be connected to my computer?
@Techie, thank you. Not only is my computer a Dell but also I searched through the programs and Nero is absolutely nowhere to be found. :o
Here is the Malwarebyte's log.  Still the Controlled Folder Access blocked anything from making changes to the desktop directory folder, preventing me from saving anything to the desktop.
Malwarebytes
www.malwarebytes.com
-Log Details-
Scan Date: 3/11/18
Scan Time: 12:59 PM
Log File: 8c0ddba6-254d-11e8-837c-d4bed9b7a1b8.json
Administrator: Yes
-Software Information-
Version: 3.3.1.2183
Components Version: 1.0.262
Update Package Version: 1.0.4302
License: Premium
-System Information-
OS: Windows 10 (Build 16299.248)
CPU: x64
File System: NTFS
User: ZANDRAJONES-PC\Zandra Jones
-Scan Summary-
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 377993
Threats Detected: 0
(No malicious items detected)
Threats Quarantined: 0
Time Elapsed: 10 min, 23 sec
-Scan Options-
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Detect
PUM: Detect
-Scan Details-
Process: 0
Module: 0
Registry Key: 0
Registry Value: 0
Registry Data: 0
Data Stream: 0
Folder: 0
File: 0
Physical Sector: 0
(end)
Below is the result of a scan ran earlier this morning after trying ESET for the umpteenth time:
Malwarebytes
-Log Details-
Protection Event Date: 2/6/18
Protection Event Time: 6:55 AM
Log File: aae3976a-0b34-11e8-90b8-d4bed9b7a1b8.json
Administrator: Yes
Version: 3.3.1.2183
Update Package Version: 1.0.3881
License: Premium
OS: Windows 10 (Build 16299.192)
CPU: x64
File System: NTFS
User: System
-Blocked Website Details-
Malicious Website: 1
, , Blocked, [-1], [-1],0.0.0
-Website Data-
Category: Unspecified
Domain: pascal5.science
IP Address: 137.74.201.240
Port: [61974]
Type: Outbound
File: C:\Program Files\Pale Moon\palemoon.exe
(end)
 I am now working on the FRST logs.
Yes, Dell did install Nero essential on new PC's as well. What you are seeing is from Dell I would suspect. This was especially true on Windows 7 systems.
If you had Win 8 it was also installed by Dell as well. It's not compatible with WIN 10, so if you upgraded from a previous windows version, it was removed by Win 10
Have you followed my previous instructions to disable Controlled Folder Access, at least until we have completed this process?  If not, please disable.
Offline Nissi1
Yes, the original program was Windows 7. Thats a relief. Here is the FRST log.  I did not add the code you wrote because you did not say to do so.
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 11.03.2018 01
Ran by Zandra Jones (administrator) on ZANDRAJONES-PC (11-03-2018 19:07:02)
Running from C:\Users\Zandra Jones\Desktop
Loaded Profiles: Zandra Jones (Available Profiles: Zandra Jones & defaultuser1 & DefaultAppPool)
Platform: Windows 10 Home Version 1709 16299.248 (X64) Language: English (United States)
Internet Explorer Version 11 (Default browser: FF)
Boot Mode: Normal
Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic/335081-frst-tutorial-how-to-use-farbar-recovery-scan-tool/
==================== Processes (Whitelisted) =================
(If an entry is included in the fixlist, the process will be closed. The file will not be moved.)
(AMD) C:\Windows\System32\atiesrxx.exe
(AMD) C:\Windows\System32\atieclxx.exe
(Memeo) C:\Program Files (x86)\Memeo\AutoBackup\MemeoBackgroundService.exe
(Microsoft Corporation) C:\Windows\System32\mqsvc.exe
(Microsoft Corporation) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\SMSvcHost.exe
(Microsoft Corporation) C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\RemindersServer.exe
(Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe
(Microsoft Corporation) C:\Windows\System32\Speech_OneCore\common\SpeechRuntime.exe
(Dell Inc.) C:\Program Files (x86)\Dell\SupportAssistAgent\bin\SupportAssistAgent.exe
(Microsoft Corporation) C:\Windows\System32\dllhost.exe
(Microsoft Corporation) C:\Windows\System32\DataExchangeHost.exe
(Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe
Failed to access process -> MBAMService.exe
(Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe
(Mozilla Corporation) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
(Moonchild Productions) C:\Program Files\Pale Moon\palemoon.exe
(Microsoft Corporation) C:\Program Files\WindowsApps\Microsoft.WindowsStore_11802.1001.8.0_x64__8wekyb3d8bbwe\WinStore.App.exe
(Microsoft Corporation) C:\Windows\ImmersiveControlPanel\SystemSettings.exe
(Microsoft Corporation) C:\Windows\System32\smartscreen.exe
==================== Registry (Whitelisted) ===========================
(If an entry is included in the fixlist, the registry item will be restored to default or removed. The file will not be moved.)
HKLM\...\Run: [SecurityHealth] => C:\Program Files\Windows Defender\MSASCuiL.exe [630168 2017-09-29] (Microsoft Corporation)
HKLM\...\Run: [RtHDVCpl] => C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe [8321568 2009-11-09] (Realtek Semiconductor)
HKLM\...\Run: [Logitech Download Assistant] => C:\Windows\system32\rundll32.exe C:\Windows\System32\LogiLDA.dll,LogiFetch
Winlogon\Notify\LBTWlgn: c:\program files\common files\logishrd\bluetooth\LBTWlgn.dll (Logitech, Inc.)
HKLM\...\Policies\Explorer: [NoActiveDesktop] 1 [0 2014-06-01] ()
HKLM\...\Policies\Explorer: [NoActiveDesktopChanges] 1 [0 2014-06-01] ()
HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\Run: [WinPatrol] => C:\Program Files (x86)\Ruiware\WinPatrol\winpatrol.exe [1223560 2017-05-07] (Ruiware)
HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\Run: [CCleaner Monitoring] => C:\Program Files\CCleaner\CCleaner64.exe [10290608 2018-02-07] (Piriform Ltd)
==================== Internet (Whitelisted) ====================
(If an item is included in the fixlist, if it is a registry item it will be removed or restored to default.)
Tcpip\Parameters: [DhcpNameServer] 209.18.47.62 209.18.47.61
Tcpip\..\Interfaces\{9917f4ef-bff4-454c-8981-86fb49609358}: [DhcpNameServer] 209.18.47.62 209.18.47.61
Internet Explorer:
HKU\S-1-5-21-3088507388-2561779440-336279174-1001\Software\Microsoft\Internet Explorer\Main,Search Page = hxxps://search.yahoo.com/yhs/search?type=avastbcl&hspart=avast&hsimp=yhs-001&p={searchTerms}
HKU\S-1-5-21-3088507388-2561779440-336279174-1001\Software\Microsoft\Internet Explorer\Main,Start Page = icefilms.info
SearchScopes: HKLM -> DefaultScope {49606DC7-976D-4030-A74E-9FB5C842FA68} URL =
SearchScopes: HKLM-x32 -> {49606DC7-976D-4030-A74E-9FB5C842FA68} URL = hxxp://www.bing.com/search?q={searchTerms}&form=DLCDF8&pc=MDDC&src=IE-SearchBox
SearchScopes: HKU\S-1-5-21-3088507388-2561779440-336279174-1001 -> DefaultScope {6343EB9B-5D5D-41D3-9D2F-D0A85CCD468C} URL = hxxps://www.google.com/search?q={searchTerms}
SearchScopes: HKU\S-1-5-21-3088507388-2561779440-336279174-1001 -> {6343EB9B-5D5D-41D3-9D2F-D0A85CCD468C} URL = hxxps://www.google.com/search?q={searchTerms}
BHO: LastPass Vault -> {95D9ECF5-2A4D-4550-BE49-70D42F71296E} -> C:\Program Files (x86)\LastPass\LPToolbar_x64.dll [2014-02-08] (LastPass)
BHO: Logitech SetPoint -> {AF949550-9094-4807-95EC-D1C317803333} -> C:\Program Files\Logitech\SetPointP\SetPointSmooth.dll [2015-08-25] (Logitech, Inc.)
BHO-x32: LastPass Vault -> {95D9ECF5-2A4D-4550-BE49-70D42F71296E} -> C:\Program Files (x86)\LastPass\LPToolbar.dll [2014-02-08] (LastPass)
BHO-x32: Logitech SetPoint -> {AF949550-9094-4807-95EC-D1C317803333} -> C:\Program Files\Logitech\SetPointP\32-bit\SetPointSmooth.dll [2015-08-25] (Logitech, Inc.)
Toolbar: HKLM - LastPass Toolbar - {9f6b5cc3-5c7b-4b5c-97af-19dec1e380e5} - C:\Program Files (x86)\LastPass\LPToolbar_x64.dll [2014-02-08] (LastPass)
Toolbar: HKLM-x32 - LastPass Toolbar - {9f6b5cc3-5c7b-4b5c-97af-19dec1e380e5} - C:\Program Files (x86)\LastPass\LPToolbar.dll [2014-02-08] (LastPass)
DPF: HKLM {166B1BCA-3F9C-11CF-8075-444553540000} hxxp://fpdownload.macromedia.com/pub/shockwave/cabs/director/sw.cab
DPF: HKLM {49312E18-AA92-4CC2-BB97-55DEA7BCADD6} hxxps://support.dell.com/systemprofiler/SysProExe.CAB
DPF: HKLM-x32 {49312E18-AA92-4CC2-BB97-55DEA7BCADD6} hxxps://support.dell.com/systemprofiler/SysProExe.CAB
Edge:
Edge Extension: (Adguard AdBlocker) -> EdgeExtension_AdguardAdguardAdBlocker_m055xr0c82818 => C:\Program Files\WindowsApps\Adguard.AdguardAdBlocker_2.8.4.0_neutral__m055xr0c82818 [2018-01-19]
Edge Extension: (LastPass: Free Password Manager) -> hdokiejnpimakedhajhdlcegeplioahd_LastPassLastPassFreePasswordManager_qq0fmhteeht3j => C:\Program Files\WindowsApps\LastPass.LastPassFreePasswordManager_4.7.1.0_neutral__qq0fmhteeht3j [2018-03-08]
FireFox:
FF DefaultProfile: cp39zz57.default-1478596356892
FF DefaultProfile: i2t9zhy6.default
FF ProfilePath: C:\Users\Zandra Jones\AppData\Roaming\Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361 [2018-03-11]
FF Homepage: Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361 -> hxxp://www.icefilms.info/
FF NewTabOverride: Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361 -> Enabled: uBlock0@raymondhill.net
FF Extension: (Brief) - C:\Users\Zandra Jones\AppData\Roaming\Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361\Extensions\brief@mozdev.org.xpi [2017-11-30]
FF Extension: (Personas Plus) - C:\Users\Zandra Jones\AppData\Roaming\Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361\Extensions\personas@christopher.beard.xpi [2018-03-06]
FF Extension: (Search image) - C:\Users\Zandra Jones\AppData\Roaming\Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361\Extensions\searchimage@searchimage.fr.xpi [2017-11-04]
FF Extension: (LastPass: Free Password Manager) - C:\Users\Zandra Jones\AppData\Roaming\Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361\Extensions\support@lastpass.com.xpi [2018-03-08]
FF Extension: (Tab Open/Close Control) - C:\Users\Zandra Jones\AppData\Roaming\Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361\Extensions\tab_open_close_control@felix-kolbe.de.xpi [2017-11-26]
FF Extension: (uBlock Origin) - C:\Users\Zandra Jones\AppData\Roaming\Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361\Extensions\uBlock0@raymondhill.net.xpi [2018-02-21]
FF Extension: (__MSG_extensionName__) - C:\Users\Zandra Jones\AppData\Roaming\Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361\Extensions\{2e5ff8c8-32fe-46d0-9fc8-6b8986621f3c}.xpi [2018-03-02]
FF Extension: (Adblock Plus) - C:\Users\Zandra Jones\AppData\Roaming\Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361\Extensions\{d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}.xpi [2018-02-27]
FF SearchPlugin: C:\Users\Zandra Jones\AppData\Roaming\Mozilla\Firefox\Profiles\ro3arqlx.default-1428285543361\searchplugins\duckduckgo.xml [2015-08-15]
FF ProfilePath: C:\Users\Zandra Jones\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892 [2018-03-11]
FF Homepage: Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892 -> hxxp://www.icefilms.info/
FF Extension: (Adblock Latitude) - C:\Users\Zandra Jones\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892\Extensions\adblocklatitude@addons.palemoon.org.xpi [2017-02-21] [Legacy] [not signed]
FF Extension: (Personas Plus) - C:\Users\Zandra Jones\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892\Extensions\personas@christopher.beard.xpi [2017-05-20] [Legacy]
FF Extension: (LastPass) - C:\Users\Zandra Jones\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892\Extensions\support@lastpass.com [2017-03-26] [Legacy]
FF Extension: (uBlock Origin) - C:\Users\Zandra Jones\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892\Extensions\uBlock0@raymondhill.net.xpi [2017-07-20] [Legacy]
FF Extension: (ColorfulTabs) - C:\Users\Zandra Jones\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892\Extensions\{0545b830-f0aa-4d7e-8820-50a4629a56fe} [2017-07-08] [Legacy]
FF Extension: (Search By Image (by Google)) - C:\Users\Zandra Jones\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892\Extensions\{ce7e73df-6a44-4028-8079-5927a588c948}.xpi [2017-05-26] [Legacy]
FF Extension: (Tab Mix Plus) - C:\Users\Zandra Jones\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892\Extensions\{dc572301-7619-498c-a57d-39143191b318}.xpi [2017-08-29] [Legacy] [not signed]
FF Extension: (DownThemAll!) - C:\Users\Zandra Jones\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892\Extensions\{DDC359D1-844A-42a7-9AA1-88A850A938A8}.xpi [2017-02-22] [Legacy]
FF SearchPlugin: C:\Users\Zandra Jones\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892\searchplugins\youtube-video-search.xml [2016-11-12]
FF ProfilePath: C:\Users\Zandra Jones\AppData\Roaming\candyrain-debd7be26eb46da9b1801b3d1e5447b4\Profiles\i2t9zhy6.default [2015-11-12]
FF HKLM-x32\...\Firefox\Extensions: [{F003DA68-8256-4b37-A6C4-350FA04494DF}] - C:\Program Files\Logitech\SetPointP\LogiSmoothFirefoxExt
FF Extension: (Logitech SetPoint) - C:\Program Files\Logitech\SetPointP\LogiSmoothFirefoxExt [2016-07-01] [Legacy] [not signed]
FF HKLM-x32\...\Thunderbird\Extensions: [msktbird@mcafee.com] - C:\Program Files\McAfee\MSK => not found
FF Plugin: @adobe.com/FlashPlayer -> C:\WINDOWS\system32\Macromed\Flash\NPSWF64_28_0_0_161.dll [2018-02-13] ()
FF Plugin: @lastpass.com/NPLastPass -> C:\Program Files (x86)\LastPass\nplastpass64.dll [2014-02-08] (LastPass)
FF Plugin-x32: @adobe.com/FlashPlayer -> C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_28_0_0_161.dll [2018-02-13] ()
FF Plugin-x32: @lastpass.com/NPLastPass -> C:\Program Files (x86)\LastPass\nplastpass.dll [2014-02-08] (LastPass)
FF Plugin-x32: @microsoft.com/WLPG,version=15.4.3502.0922 -> C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll [No File]
FF Plugin-x32: @tools.google.com/Google Update;version=3 -> C:\Program Files (x86)\Google\Update\1.3.33.7\npGoogleUpdate3.dll [2017-11-14] (Google Inc.)
FF Plugin-x32: @tools.google.com/Google Update;version=9 -> C:\Program Files (x86)\Google\Update\1.3.33.7\npGoogleUpdate3.dll [2017-11-14] (Google Inc.)
FF Plugin-x32: samsung.com/AllSharePlayPCPlugin -> C:\Program Files\Samsung\AllShare Play\utils\npAllSharePlayPCPlugin.dll [No File]
FF Plugin HKU\S-1-5-21-3088507388-2561779440-336279174-1001: @talk.google.com/GoogleTalkPlugin -> C:\Users\Zandra Jones\AppData\Roaming\Mozilla\plugins\npgoogletalk.dll [2015-12-08] (Google)
FF Plugin HKU\S-1-5-21-3088507388-2561779440-336279174-1001: @talk.google.com/O1DPlugin -> C:\Users\Zandra Jones\AppData\Roaming\Mozilla\plugins\npo1d.dll [2015-12-08] (Google)
FF Plugin HKU\S-1-5-21-3088507388-2561779440-336279174-1001: @tools.google.com/Google Update;version=3 -> C:\Users\Zandra Jones\AppData\Local\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-04-28] (Google Inc.)
FF Plugin HKU\S-1-5-21-3088507388-2561779440-336279174-1001: @tools.google.com/Google Update;version=9 -> C:\Users\Zandra Jones\AppData\Local\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-04-28] (Google Inc.)
FF Plugin ProgramFiles/Appdata: C:\Users\Zandra Jones\AppData\Roaming\mozilla\plugins\npgoogletalk.dll [2015-12-08] (Google)
FF Plugin ProgramFiles/Appdata: C:\Users\Zandra Jones\AppData\Roaming\mozilla\plugins\npo1d.dll [2015-12-08] (Google)
FF Plugin ProgramFiles/Appdata: C:\Users\Zandra Jones\AppData\Roaming\mozilla\plugins\xnpgoogletalk.dll [2014-05-15] (Google)
FF Plugin ProgramFiles/Appdata: C:\Users\Zandra Jones\AppData\Roaming\mozilla\plugins\xnpo1d.dll [2014-05-15] (Google)
Chrome:
CHR Profile: C:\Users\Zandra Jones\AppData\Local\Google\Chrome\User Data\Default [2018-03-07]
CHR Extension: (Slides) - C:\Users\Zandra Jones\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2017-11-06]
CHR Extension: (Docs) - C:\Users\Zandra Jones\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfilokake [2017-11-06]
CHR Extension: (Google Drive) - C:\Users\Zandra Jones\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigkjlhalf [2017-10-11]
CHR Extension: (YouTube) - C:\Users\Zandra Jones\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2017-10-11]
CHR Extension: (Sheets) - C:\Users\Zandra Jones\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2017-11-06]
CHR Extension: (Google Docs Offline) - C:\Users\Zandra Jones\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2017-11-06]
CHR Extension: (Chrome Web Store Payments) - C:\Users\Zandra Jones\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2017-10-11]
CHR Extension: (Gmail) - C:\Users\Zandra Jones\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2017-10-11]
CHR Extension: (Chrome Media Router) - C:\Users\Zandra Jones\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm [2017-11-06]
CHR HKLM\...\Chrome\Extension: [flliilndjeohchalpbbcdekjklbdgfkk] - hxxps://clients2.google.com/service/update2/crx
==================== Services (Whitelisted) ====================
(If an entry is included in the fixlist, it will be removed from the registry. The file will not be moved unless listed separately.)
S2 DellDataVault; C:\Program Files\Dell\DellDataVault\DellDataVault.exe [2573520 2015-05-22] (Dell Inc.)
S4 DellUpdate; C:\Program Files (x86)\Dell Update\DellUpService.exe [237272 2015-08-27] (Dell Inc.)
R2 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe [6234056 2017-11-01] (Malwarebytes)
R2 SupportAssistAgent; C:\Program Files (x86)\Dell\SupportAssistAgent\bin\SupportAssistAgent.exe [31928 2016-04-22] (Dell Inc.)
S3 WdNisSvc; C:\ProgramData\Microsoft\Windows Defender\platform\4.12.17007.18022-0\NisSrv.exe [356152 2018-03-01] (Microsoft Corporation)
S3 WinDefend; C:\ProgramData\Microsoft\Windows Defender\platform\4.12.17007.18022-0\MsMpEng.exe [106280 2018-03-01] (Microsoft Corporation)
===================== Drivers (Whitelisted) ======================
S3 DDDriver; C:\WINDOWS\System32\drivers\DDDriver64Dcsa.sys [23760 2015-01-30] (Dell Computer Corporation)
S3 DellProf; C:\WINDOWS\System32\drivers\DellProf.sys [24240 2015-05-22] (Dell Computer Corporation)
S3 dg_ssudbus; C:\WINDOWS\system32\DRIVERS\ssudbus.sys [131984 2017-05-18] (Samsung Electronics Co., Ltd.)
R1 ESProtectionDriver; C:\WINDOWS\system32\drivers\mbae64.sys [77432 2017-12-21] ()
R3 MBAMFarflt; C:\WINDOWS\system32\DRIVERS\farflt.sys [110016 2018-03-11] (Malwarebytes)
R3 MBAMProtection; C:\WINDOWS\system32\DRIVERS\mbam.sys [46008 2018-03-11] (Malwarebytes)
R3 MBAMSwissArmy; C:\WINDOWS\System32\Drivers\mbamswissarmy.sys [253880 2018-03-11] (Malwarebytes)
R3 MBAMWebProtection; C:\WINDOWS\system32\DRIVERS\mwac.sys [94144 2018-03-11] (Malwarebytes)
S3 ssudmdm; C:\WINDOWS\system32\DRIVERS\ssudmdm.sys [166288 2017-05-18] (Samsung Electronics Co., Ltd.)
S3 WdBoot; C:\WINDOWS\system32\drivers\wd\WdBoot.sys [46072 2018-03-01] (Microsoft Corporation)
S3 WdFilter; C:\WINDOWS\system32\drivers\wd\WdFilter.sys [288296 2018-03-01] (Microsoft Corporation)
S3 WdNisDrv; C:\WINDOWS\System32\drivers\wd\WdNisDrv.sys [129568 2018-03-01] (Microsoft Corporation)
R1 wppvcy; C:\WINDOWS\System32\drivers\wppvcy.sys [49944 2015-08-27] (Ruiware, LLC)
==================== NetSvcs (Whitelisted) ===================
==================== One Month Created files and folders ========
(If an entry is included in the fixlist, the file/folder will be moved.)
2018-03-11 19:07 - 2018-03-11 19:07 - 000017974 _____ C:\Users\Zandra Jones\Desktop\FRST.txt
2018-03-11 17:46 - 2018-03-11 17:47 - 002402816 _____ (Farbar) C:\Users\Zandra Jones\Desktop\FRST64.exe
2018-03-11 15:36 - 2018-03-11 15:36 - 002402816 _____ (Farbar) C:\Users\Zandra Jones\Downloads\FRST64.exe
2018-03-11 14:14 - 2018-03-11 14:14 - 000001255 _____ C:\Users\Zandra Jones\Documents\mal1.txt
2018-03-11 13:34 - 2018-03-11 13:34 - 000001255 _____ C:\Users\Zandra Jones\Downloads\MalScan.txt
2018-03-11 12:57 - 2018-03-11 13:00 - 000094144 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mwac.sys
2018-03-11 12:57 - 2018-03-11 12:57 - 000253880 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbamswissarmy.sys
2018-03-11 12:57 - 2018-03-11 12:57 - 000110016 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\farflt.sys
2018-03-11 12:57 - 2018-03-11 12:57 - 000046008 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbam.sys
2018-03-10 06:46 - 2018-03-10 06:46 - 006968952 _____ (ESET spol. s r.o.) C:\Users\Zandra Jones\Desktop\esetonlinescanner_enu.exe
2018-03-10 06:01 - 2018-03-10 06:01 - 000524248 _____ (F-Secure Corporation) C:\Users\Zandra Jones\Downloads\F-SecureOnlineScanner.exe
2018-03-09 21:38 - 2018-03-09 21:45 - 000001204 _____ C:\Users\Zandra Jones\Documents\ESET and F-Secure.txt
2018-03-08 19:50 - 2018-03-11 05:13 - 000000000 ____D C:\Users\Zandra Jones\AppData\Local\FSDART
2018-03-08 19:50 - 2018-03-11 00:14 - 000000000 ____D C:\ProgramData\F-Secure
2018-03-08 19:50 - 2018-03-08 19:50 - 000000000 ____D C:\Users\Zandra Jones\AppData\Local\F-Secure
2018-03-06 19:53 - 2018-03-11 19:07 - 000000000 ____D C:\FRST
2018-03-01 20:40 - 2018-03-11 14:15 - 000000683 _____ C:\Users\Zandra Jones\Downloads\mal.txt
2018-02-28 15:40 - 2018-03-01 18:56 - 000000000 ____D C:\WINDOWS\system32\Drivers\wd
2018-02-24 20:28 - 2018-02-24 20:30 - 000000000 ____D C:\Users\defaultuser1\AppData\Local\Packages
2018-02-24 20:28 - 2018-02-24 20:28 - 000000020 ___SH C:\Users\defaultuser1\ntuser.ini
2018-02-24 20:28 - 2018-02-24 20:28 - 000000000 ____D C:\Users\defaultuser1\AppData\Local\VirtualStore
2018-02-24 20:28 - 2018-02-24 20:28 - 000000000 ____D C:\Users\defaultuser1\AppData\Local\ConnectedDevicesPlatform
2018-02-24 20:28 - 2016-09-23 03:44 - 000000000 ____D C:\Users\defaultuser1\AppData\Roaming\Media Center Programs
2018-02-24 20:28 - 2016-09-23 03:44 - 000000000 ____D C:\Users\defaultuser1\AppData\Local\SoftThinks
2018-02-24 20:28 - 2016-09-23 03:44 - 000000000 ____D C:\Users\defaultuser1\AppData\Local\Google
2018-02-24 20:27 - 2018-02-24 20:56 - 000000000 ____D C:\Users\defaultuser1
2018-02-24 20:27 - 2016-09-23 03:44 - 000000000 ____D C:\Users\defaultuser1\Desktop\Play Games
2018-02-24 20:27 - 2016-09-23 03:44 - 000000000 ____D C:\Users\defaultuser1\AppData\Roaming\TuneUp Software
2018-02-14 12:25 - 2018-02-10 02:21 - 000279456 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\msiscsi.sys
2018-02-14 12:25 - 2018-02-10 02:20 - 001206680 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvix64.exe
2018-02-14 12:25 - 2018-02-10 02:20 - 001055640 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvax64.exe
2018-02-14 12:25 - 2018-02-10 02:20 - 000599448 _____ (Microsoft Corporation) C:\WINDOWS\system32\securekernel.exe
2018-02-14 12:25 - 2018-02-10 02:20 - 000077208 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.dll
2018-02-14 12:25 - 2018-02-10 02:18 - 001193192 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryPS.dll
2018-02-14 12:25 - 2018-02-10 02:18 - 000319864 _____ (Microsoft Corporation) C:\WINDOWS\system32\wow64.dll
2018-02-14 12:25 - 2018-02-10 02:16 - 008603032 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
2018-02-14 12:25 - 2018-02-10 02:16 - 002406456 _____ (Microsoft Corporation) C:\WINDOWS\system32\msmpeg2vdec.dll
2018-02-14 12:25 - 2018-02-10 02:16 - 000739696 _____ (Microsoft Corporation) C:\WINDOWS\system32\dnsapi.dll
2018-02-14 12:25 - 2018-02-10 02:15 - 001954048 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntdll.dll
2018-02-14 12:25 - 2018-02-10 02:15 - 000471968 _____ (Microsoft Corporation) C:\WINDOWS\system32\hal.dll
2018-02-14 12:25 - 2018-02-10 02:14 - 004504464 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppsvc.exe
2018-02-14 12:25 - 2018-02-10 02:14 - 002395032 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ntfs.sys
2018-02-14 12:25 - 2018-02-10 02:13 - 001416392 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3D12.dll
2018-02-14 12:25 - 2018-02-10 02:13 - 000408984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms1.sys
2018-02-14 12:25 - 2018-02-10 02:13 - 000373656 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\clfs.sys
2018-02-14 12:25 - 2018-02-10 02:12 - 004537040 _____ (Microsoft Corporation) C:\WINDOWS\system32\setupapi.dll
2018-02-14 12:25 - 2018-02-10 02:12 - 001313016 _____ (Microsoft Corporation) C:\WINDOWS\system32\Taskmgr.exe
2018-02-14 12:25 - 2018-02-10 02:12 - 001277848 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ndis.sys
2018-02-14 12:25 - 2018-02-10 02:12 - 000712600 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vhdmp.sys
2018-02-14 12:25 - 2018-02-10 02:10 - 000749976 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
2018-02-14 12:25 - 2018-02-10 02:10 - 000614160 _____ (Microsoft Corporation) C:\WINDOWS\system32\StateRepository.Core.dll
2018-02-14 12:25 - 2018-02-10 02:10 - 000154520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryClient.dll
2018-02-14 12:25 - 2018-02-10 02:09 - 003904296 _____ (Microsoft Corporation) C:\WINDOWS\explorer.exe
2018-02-14 12:25 - 2018-02-10 02:09 - 000755712 _____ (Microsoft Corporation) C:\WINDOWS\system32\evr.dll
2018-02-14 12:25 - 2018-02-10 02:09 - 000075160 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecurityHealthProxyStub.dll
2018-02-14 12:25 - 2018-02-10 02:08 - 021351624 _____ (Microsoft Corporation) C:\WINDOWS\system32\shell32.dll
2018-02-14 12:25 - 2018-02-10 02:08 - 007675784 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
2018-02-14 12:25 - 2018-02-10 02:08 - 003010248 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d11.dll
2018-02-14 12:25 - 2018-02-10 02:08 - 002574232 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
2018-02-14 12:25 - 2018-02-10 02:08 - 000096200 _____ (Microsoft Corporation) C:\WINDOWS\system32\winbrand.dll
2018-02-14 12:25 - 2018-02-10 02:08 - 000048112 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuauclt.exe
2018-02-14 12:25 - 2018-02-10 02:07 - 004506576 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfcore.dll
2018-02-14 12:25 - 2018-02-10 02:07 - 002710728 _____ (Microsoft Corporation) C:\WINDOWS\system32\iertutil.dll
2018-02-14 12:25 - 2018-02-10 02:06 - 004486904 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepository.dll
2018-02-14 12:25 - 2018-02-10 02:06 - 000824896 _____ (Microsoft Corporation) C:\WINDOWS\system32\ClipSVC.dll
2018-02-14 12:25 - 2018-02-10 02:06 - 000727448 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fvevol.sys
2018-02-14 12:25 - 2018-02-10 02:06 - 000494488 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb.sys
2018-02-14 12:25 - 2018-02-10 02:06 - 000362904 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\pci.sys
2018-02-14 12:25 - 2018-02-10 02:06 - 000100248 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryBroker.dll
2018-02-14 12:25 - 2018-02-10 02:06 - 000087384 _____ (Microsoft Corporation) C:\WINDOWS\system32\remoteaudioendpoint.dll
2018-02-14 12:25 - 2018-02-10 02:05 - 000688064 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentClient.dll
2018-02-14 12:25 - 2018-02-10 02:05 - 000413888 _____ (Microsoft Corporation) C:\WINDOWS\system32\AUDIOKSE.dll
2018-02-14 12:25 - 2018-02-10 02:05 - 000097176 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\sdstor.sys
2018-02-14 12:25 - 2018-02-10 02:04 - 007384576 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Protection.PlayReady.dll
2018-02-14 12:25 - 2018-02-10 02:04 - 006791984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.dll
2018-02-14 12:25 - 2018-02-10 02:04 - 001430760 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpcMon.exe
2018-02-14 12:25 - 2018-02-10 02:04 - 001254144 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsvr.dll
2018-02-14 12:25 - 2018-02-10 02:04 - 001170008 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioSes.dll
2018-02-14 12:25 - 2018-02-10 02:04 - 000614296 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\afd.sys
2018-02-14 12:25 - 2018-02-10 02:04 - 000603920 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiodg.exe
2018-02-14 12:25 - 2018-02-10 02:04 - 000260896 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfps.dll
2018-02-14 12:25 - 2018-02-10 02:04 - 000093592 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpudd.dll
2018-02-14 12:25 - 2018-02-10 02:03 - 000404888 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudExperienceHost.dll
2018-02-14 12:25 - 2018-02-10 02:02 - 002773400 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tcpip.sys
2018-02-14 12:25 - 2018-02-10 02:02 - 001103768 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\http.sys
2018-02-14 12:25 - 2018-02-10 02:02 - 000617304 _____ (Microsoft Corporation) C:\WINDOWS\system32\TextInputFramework.dll
2018-02-14 12:25 - 2018-02-10 01:21 - 001615712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntdll.dll
2018-02-14 12:25 - 2018-02-10 01:17 - 002255112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msmpeg2vdec.dll
2018-02-14 12:25 - 2018-02-10 01:17 - 000597160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dnsapi.dll
2018-02-14 12:25 - 2018-02-10 01:17 - 000542856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryPS.dll
2018-02-14 12:25 - 2018-02-10 01:12 - 004382032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\setupapi.dll
2018-02-14 12:25 - 2018-02-10 01:11 - 001250528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Taskmgr.exe
2018-02-14 12:25 - 2018-02-10 01:09 - 006092152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
2018-02-14 12:25 - 2018-02-10 01:09 - 003485392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\explorer.exe
2018-02-14 12:25 - 2018-02-10 01:09 - 002338776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d11.dll
2018-02-14 12:25 - 2018-02-10 01:09 - 001123456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3D12.dll
2018-02-14 12:25 - 2018-02-10 01:08 - 003980720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepository.dll
2018-02-14 12:25 - 2018-02-10 01:08 - 002193168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iertutil.dll
2018-02-14 12:25 - 2018-02-10 01:07 - 025253376 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
2018-02-14 12:25 - 2018-02-10 01:07 - 020286120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shell32.dll
2018-02-14 12:25 - 2018-02-10 01:07 - 000543920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll
2018-02-14 12:25 - 2018-02-10 01:07 - 000527864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\StateRepository.Core.dll
2018-02-14 12:25 - 2018-02-10 01:07 - 000123808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryClient.dll
2018-02-14 12:25 - 2018-02-10 01:07 - 000089504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryBroker.dll
2018-02-14 12:25 - 2018-02-10 01:07 - 000083216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winbrand.dll
2018-02-14 12:25 - 2018-02-10 01:06 - 006481640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayReady.dll
2018-02-14 12:25 - 2018-02-10 01:06 - 006014688 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.dll
2018-02-14 12:25 - 2018-02-10 01:06 - 004670728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfcore.dll
2018-02-14 12:25 - 2018-02-10 01:06 - 000982528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioSes.dll
2018-02-14 12:25 - 2018-02-10 01:05 - 001149272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsvr.dll
2018-02-14 12:25 - 2018-02-10 01:05 - 000662208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\evr.dll
2018-02-14 12:25 - 2018-02-10 01:05 - 000386424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AUDIOKSE.dll
2018-02-14 12:25 - 2018-02-10 01:05 - 000129184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfps.dll
2018-02-14 12:25 - 2018-02-10 01:05 - 000077552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CloudNotifications.exe
2018-02-14 12:25 - 2018-02-10 01:05 - 000074992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\remoteaudioendpoint.dll
2018-02-14 12:25 - 2018-02-10 00:50 - 003665408 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
2018-02-14 12:25 - 2018-02-10 00:50 - 001294848 _____ (Microsoft Corporation) C:\WINDOWS\system32\usocore.dll
2018-02-14 12:25 - 2018-02-10 00:50 - 000849920 _____ (Microsoft Corporation) C:\WINDOWS\system32\uDWM.dll
2018-02-14 12:25 - 2018-02-10 00:49 - 000536576 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgeIso.dll
2018-02-14 12:25 - 2018-02-10 00:49 - 000385536 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cldflt.sys
2018-02-14 12:25 - 2018-02-10 00:49 - 000329728 _____ (Microsoft Corporation) C:\WINDOWS\system32\AcGenral.dll
2018-02-14 12:25 - 2018-02-10 00:49 - 000326656 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusNotification.exe
2018-02-14 12:25 - 2018-02-10 00:49 - 000232960 _____ (Microsoft Corporation) C:\WINDOWS\system32\convertvhd.exe
2018-02-14 12:25 - 2018-02-10 00:47 - 017160704 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.dll
2018-02-14 12:25 - 2018-02-10 00:47 - 013704192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll
2018-02-14 12:25 - 2018-02-10 00:47 - 000201728 _____ (Microsoft Corporation) C:\WINDOWS\system32\EdgeManager.dll
2018-02-14 12:25 - 2018-02-10 00:47 - 000201216 _____ (Microsoft Corporation) C:\WINDOWS\system32\SharedPCCSP.dll
2018-02-14 12:25 - 2018-02-10 00:47 - 000143872 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssprxy.dll
2018-02-14 12:25 - 2018-02-10 00:46 - 002902528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32kfull.sys
2018-02-14 12:25 - 2018-02-10 00:46 - 002393600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AcGenral.dll
2018-02-14 12:25 - 2018-02-10 00:46 - 000344576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgeIso.dll
2018-02-14 12:25 - 2018-02-10 00:46 - 000225792 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\winnat.sys
2018-02-14 12:25 - 2018-02-10 00:46 - 000169472 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhosdeployment.dll
2018-02-14 12:25 - 2018-02-10 00:46 - 000018432 _____ (Microsoft Corporation) C:\WINDOWS\system32\PCShellCommonProxyStub.dll
2018-02-14 12:25 - 2018-02-10 00:46 - 000004608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\user.exe
2018-02-14 12:25 - 2018-02-10 00:45 - 007545344 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.dll
2018-02-14 12:25 - 2018-02-10 00:45 - 000288768 _____ (Microsoft Corporation) C:\WINDOWS\system32\authz.dll
2018-02-14 12:25 - 2018-02-10 00:45 - 000115200 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatepolicy.dll
2018-02-14 12:25 - 2018-02-10 00:45 - 000093696 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtmled.dll
2018-02-14 12:25 - 2018-02-10 00:45 - 000079872 _____ (Microsoft Corporation) C:\WINDOWS\system32\nlaapi.dll
2018-02-14 12:25 - 2018-02-10 00:45 - 000066048 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsrv.dll
2018-02-14 12:25 - 2018-02-10 00:45 - 000043008 _____ (Microsoft Corporation) C:\WINDOWS\system32\nshhttp.dll
2018-02-14 12:25 - 2018-02-10 00:44 - 001498112 _____ (Microsoft Corporation) C:\WINDOWS\system32\WebRuntimeManager.dll
2018-02-14 12:25 - 2018-02-10 00:44 - 000800768 _____ (Microsoft Corporation) C:\WINDOWS\system32\Magnify.exe
2018-02-14 12:25 - 2018-02-10 00:44 - 000539136 _____ (Microsoft Corporation) C:\WINDOWS\system32\HolographicExtensions.dll
2018-02-14 12:25 - 2018-02-10 00:44 - 000503296 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_User.dll
2018-02-14 12:25 - 2018-02-10 00:44 - 000431616 _____ (Microsoft Corporation) C:\WINDOWS\system32\msIso.dll
2018-02-14 12:25 - 2018-02-10 00:44 - 000427008 _____ (Microsoft Corporation) C:\WINDOWS\system32\OneCoreCommonProxyStub.dll
2018-02-14 12:25 - 2018-02-10 00:44 - 000388608 _____ (Microsoft Corporation) C:\WINDOWS\system32\Search.ProtocolHandler.MAPI2.dll
2018-02-14 12:25 - 2018-02-10 00:44 - 000336896 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppLockerCSP.dll
2018-02-14 12:25 - 2018-02-10 00:44 - 000276480 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxtrans.dll
2018-02-14 12:25 - 2018-02-10 00:44 - 000208384 _____ (Microsoft Corporation) C:\WINDOWS\system32\tetheringservice.dll
2018-02-14 12:25 - 2018-02-10 00:44 - 000155648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EdgeManager.dll
2018-02-14 12:25 - 2018-02-10 00:44 - 000059392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssprxy.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 018923008 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 008020480 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Data.Pdf.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 006466560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 003756032 _____ (Microsoft Corporation) C:\WINDOWS\system32\bootux.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 000580608 _____ (Microsoft Corporation) C:\WINDOWS\system32\webio.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 000566272 _____ (Microsoft Corporation) C:\WINDOWS\system32\DevicePairing.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 000456704 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxtmsft.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 000394752 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ks.sys
2018-02-14 12:25 - 2018-02-10 00:43 - 000391168 _____ (Microsoft Corporation) C:\WINDOWS\system32\iedkcs32.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 000311808 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeveloperOptionsSettingsHandlers.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 000268288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxtrans.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 000147456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryUpgrade.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 000084480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppCapture.dll
2018-02-14 12:25 - 2018-02-10 00:43 - 000013312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PCShellCommonProxyStub.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 023671808 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 001425408 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettings.Handlers.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 001216000 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.Vpn.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 001113600 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcastdvr.exe
2018-02-14 12:25 - 2018-02-10 00:42 - 000975872 _____ (Microsoft Corporation) C:\WINDOWS\system32\wbiosrvc.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 000813568 _____ (Microsoft Corporation) C:\WINDOWS\system32\bisrv.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 000792064 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssvp.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 000731136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Magnify.exe
2018-02-14 12:25 - 2018-02-10 00:42 - 000708096 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9diag.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 000403968 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpAXHolder.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 000397824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxtmsft.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 000270336 _____ (Microsoft Corporation) C:\WINDOWS\system32\ListSvc.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 000236032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\FSClient.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 000233984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppLockerCSP.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 000228352 _____ (Microsoft Corporation) C:\WINDOWS\system32\ie4uinit.exe
2018-02-14 12:25 - 2018-02-10 00:42 - 000225280 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchFilterHost.exe
2018-02-14 12:25 - 2018-02-10 00:42 - 000078336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtmled.dll
2018-02-14 12:25 - 2018-02-10 00:42 - 000035328 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\nshhttp.dll
2018-02-14 12:25 - 2018-02-10 00:41 - 019352576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
2018-02-14 12:25 - 2018-02-10 00:41 - 000859648 _____ (Microsoft Corporation) C:\WINDOWS\system32\appwiz.cpl
2018-02-14 12:25 - 2018-02-10 00:41 - 000820224 _____ (Microsoft Corporation) C:\WINDOWS\system32\netlogon.dll
2018-02-14 12:25 - 2018-02-10 00:41 - 000815616 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieproxy.dll
2018-02-14 12:25 - 2018-02-10 00:41 - 000721408 _____ (Microsoft Corporation) C:\WINDOWS\system32\LogonController.dll
2018-02-14 12:25 - 2018-02-10 00:41 - 000504832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DevicePairing.dll
2018-02-14 12:25 - 2018-02-10 00:41 - 000451072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TileDataRepository.dll
2018-02-14 12:25 - 2018-02-10 00:41 - 000401408 _____ (Microsoft Corporation) C:\WINDOWS\system32\ncsi.dll
2018-02-14 12:25 - 2018-02-10 00:41 - 000377856 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchProtocolHost.exe
2018-02-14 12:25 - 2018-02-10 00:41 - 000369152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msIso.dll
2018-02-14 12:25 - 2018-02-10 00:41 - 000365568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieproxy.dll
2018-02-14 12:25 - 2018-02-10 00:41 - 000288768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Search.ProtocolHandler.MAPI2.dll
2018-02-14 12:25 - 2018-02-10 00:41 - 000063488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\nlaapi.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 012831744 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 008110080 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 004113408 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_nt.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 003405824 _____ (Microsoft Corporation) C:\WINDOWS\system32\tquery.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 003367936 _____ (Microsoft Corporation) C:\WINDOWS\system32\SyncCenter.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 002873344 _____ (Microsoft Corporation) C:\WINDOWS\system32\themeui.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 001234432 _____ (Microsoft Corporation) C:\WINDOWS\system32\SEMgrSvc.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 001002496 _____ (Microsoft Corporation) C:\WINDOWS\system32\modernexecserver.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000940544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Networking.Vpn.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000939520 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasdlg.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000930816 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasmans.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000886784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcastdvr.exe
2018-02-14 12:25 - 2018-02-10 00:40 - 000756736 _____ (Microsoft Corporation) C:\WINDOWS\system32\msfeeds.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000601088 _____ (Microsoft Corporation) C:\WINDOWS\system32\ipnathlp.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000559104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9diag.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000508416 _____ (Microsoft Corporation) C:\WINDOWS\system32\timedate.cpl
2018-02-14 12:25 - 2018-02-10 00:40 - 000499200 _____ (Microsoft Corporation) C:\WINDOWS\system32\rastls.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000463360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\timedate.cpl
2018-02-14 12:25 - 2018-02-10 00:40 - 000421376 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputSwitch.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000386560 _____ (Microsoft Corporation) C:\WINDOWS\system32\zipfldr.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000366080 _____ (Microsoft Corporation) C:\WINDOWS\system32\nlasvc.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000343040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iedkcs32.dll
2018-02-14 12:25 - 2018-02-10 00:40 - 000195072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\OneCoreCommonProxyStub.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 011925504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 005500928 _____ (Microsoft Corporation) C:\WINDOWS\system32\aclui.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 004748288 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 004592640 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettingsThresholdAdminFlowUI.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 002976256 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.pcshell.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 002741248 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssrch.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 002677760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tquery.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 002490880 _____ (Microsoft Corporation) C:\WINDOWS\system32\themecpl.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 001669120 _____ (Microsoft Corporation) C:\WINDOWS\system32\Wpc.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 000908800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fontext.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 000721920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssvp.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 000680960 _____ (Microsoft Corporation) C:\WINDOWS\system32\sud.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 000658432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netlogon.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 000648704 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserLanguagesCpl.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 000621056 _____ (Microsoft Corporation) C:\WINDOWS\system32\hgcpl.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 000462848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webio.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 000447488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rastls.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 000346112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\zipfldr.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 006722560 _____ (Microsoft Corporation) C:\WINDOWS\system32\mspaint.exe
2018-02-14 12:25 - 2018-02-10 00:38 - 006567936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 005833216 _____ (Microsoft Corporation) C:\WINDOWS\system32\dbgeng.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 004815360 _____ (Microsoft Corporation) C:\WINDOWS\system32\MFMediaEngine.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 003334144 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininet.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 003125760 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputService.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 002857984 _____ (Microsoft Corporation) C:\WINDOWS\system32\dwmcore.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 002184192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssrch.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 002086400 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
2018-02-14 12:25 - 2018-02-10 00:38 - 002082304 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetcpl.cpl
2018-02-14 12:25 - 2018-02-10 00:38 - 001597952 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieapfltr.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 001547776 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsasrv.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 001228800 _____ (Microsoft Corporation) C:\WINDOWS\system32\TokenBroker.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 001167360 _____ (Microsoft Corporation) C:\WINDOWS\system32\ISM.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 001166336 _____ (Microsoft Corporation) C:\WINDOWS\system32\localspl.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 001057792 _____ (Microsoft Corporation) C:\WINDOWS\system32\comdlg32.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000982016 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchIndexer.exe
2018-02-14 12:25 - 2018-02-10 00:38 - 000939520 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasapi32.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000885248 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Search.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000863744 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntshrui.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000755712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\appwiz.cpl
2018-02-14 12:25 - 2018-02-10 00:38 - 000699904 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsm.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000668160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msfeeds.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000653312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sud.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000556544 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockAppBroker.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000524800 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.immersiveshell.serviceprovider.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000509440 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSync.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000506880 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinapi.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000462336 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhext.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000401920 _____ (Microsoft Corporation) C:\WINDOWS\system32\rascustom.dll
2018-02-14 12:25 - 2018-02-10 00:38 - 000324608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchProtocolHost.exe
2018-02-14 12:25 - 2018-02-10 00:37 - 004839424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dbgeng.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 004772352 _____ (Microsoft Corporation) C:\WINDOWS\system32\ExplorerFrame.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 003678720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 003578368 _____ (Microsoft Corporation) C:\WINDOWS\system32\SRH.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 003287040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SyncCenter.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 002784256 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 002523648 _____ (Microsoft Corporation) C:\WINDOWS\system32\gameux.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 001822208 _____ (Microsoft Corporation) C:\WINDOWS\system32\urlmon.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 001488384 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiosrv.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 000965632 _____ (Microsoft Corporation) C:\WINDOWS\system32\fontext.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 000862208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasdlg.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 000456704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LockAppBroker.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 000417792 _____ (Microsoft Corporation) C:\WINDOWS\system32\stobject.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 000365568 _____ (Microsoft Corporation) C:\WINDOWS\system32\srchadmin.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 000308224 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetSetupSvc.dll
2018-02-14 12:25 - 2018-02-10 00:37 - 000199680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchFilterHost.exe
2018-02-14 12:25 - 2018-02-10 00:37 - 000198656 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingMonitor.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 006031360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 002869760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wininet.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 002859520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SRH.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 002464768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dwmcore.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 002462208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\themecpl.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 002035712 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpcorets.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 001759744 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpncore.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 001739264 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Immersive.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 001559552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\urlmon.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 001342464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Wpc.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 000695296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Search.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 000685056 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEndpointBuilder.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 000666624 _____ (Microsoft Corporation) C:\WINDOWS\system32\DbgModel.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 000599552 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Core.TextInput.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 000576512 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\hgcpl.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 000559104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UserLanguagesCpl.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 000383488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\stobject.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 005388800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aclui.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 004384768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ExplorerFrame.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 002814976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\themeui.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 002413568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gameux.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 002349568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputService.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 002013184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\inetcpl.cpl
2018-02-14 12:25 - 2018-02-10 00:35 - 001474560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieapfltr.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 000963584 _____ (Microsoft Corporation) C:\WINDOWS\system32\StorSvc.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 000943104 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.BackgroundMediaPlayback.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 000941568 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Playback.BackgroundMediaPlayer.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 000918528 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Playback.MediaPlayer.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 000862208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasapi32.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 000842240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\comdlg32.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 000826880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchIndexer.exe
2018-02-14 12:25 - 2018-02-10 00:35 - 000796160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntshrui.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 000433664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinapi.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 000402944 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSync.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 000332288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\srchadmin.dll
2018-02-14 12:25 - 2018-02-10 00:35 - 000329728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputSwitch.dll
2018-02-14 12:25 - 2018-02-10 00:34 - 006532096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mspaint.exe
2018-02-14 12:25 - 2018-02-10 00:34 - 004249600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFMediaEngine.dll
2018-02-14 12:25 - 2018-02-10 00:34 - 002983936 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmcndmgr.dll
2018-02-14 12:25 - 2018-02-10 00:34 - 000624640 _____ (Microsoft Corporation) C:\WINDOWS\system32\WMVXENCD.DLL
2018-02-14 12:25 - 2018-02-10 00:34 - 000433152 _____ (Microsoft Corporation) C:\WINDOWS\system32\WMVSENCD.DLL
2018-02-14 12:25 - 2018-02-10 00:34 - 000111104 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Playback.ProxyStub.dll
2018-02-14 12:25 - 2018-02-10 00:33 - 001936384 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmc.exe
2018-02-14 12:25 - 2018-02-10 00:33 - 001661440 _____ (Microsoft Corporation) C:\WINDOWS\system32\vssapi.dll
2018-02-14 12:25 - 2018-02-10 00:33 - 001557504 _____ (Microsoft Corporation) C:\WINDOWS\system32\VSSVC.exe
2018-02-14 12:25 - 2018-02-10 00:33 - 001509888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Immersive.dll
2018-02-14 12:25 - 2018-02-10 00:33 - 000621568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.BackgroundMediaPlayback.dll
2018-02-14 12:25 - 2018-02-10 00:33 - 000620544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Playback.BackgroundMediaPlayer.dll
2018-02-14 12:25 - 2018-02-10 00:33 - 000604672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Playback.MediaPlayer.dll
2018-02-14 12:25 - 2018-02-10 00:33 - 000482816 _____ (Microsoft Corporation) C:\WINDOWS\system32\srcore.dll
2018-02-14 12:25 - 2018-02-10 00:33 - 000341504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmcbase.dll
2018-02-14 12:25 - 2018-02-10 00:33 - 000266752 _____ (Microsoft Corporation) C:\WINDOWS\system32\rstrui.exe
2018-02-14 12:25 - 2018-02-10 00:32 - 002427904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmcndmgr.dll
2018-02-14 12:25 - 2018-02-10 00:32 - 000681472 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WMVXENCD.DLL
2018-02-14 12:25 - 2018-02-10 00:32 - 000392704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WMVSENCD.DLL
2018-02-14 12:25 - 2018-02-10 00:32 - 000056832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Playback.ProxyStub.dll
2018-02-14 12:25 - 2018-02-10 00:31 - 001488896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmc.exe
2018-02-14 12:25 - 2018-02-10 00:31 - 001159680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\vssapi.dll
2018-02-14 12:25 - 2018-02-10 00:31 - 000301056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmcbase.dll
2018-02-14 12:24 - 2018-02-10 02:24 - 000270744 _____ (Microsoft Corporation) C:\WINDOWS\system32\acmigration.dll
2018-02-14 12:24 - 2018-02-10 02:23 - 001577880 _____ (Microsoft Corporation) C:\WINDOWS\system32\appraiser.dll
2018-02-14 12:24 - 2018-02-10 02:23 - 000758168 _____ (Microsoft Corporation) C:\WINDOWS\system32\generaltel.dll
2018-02-14 12:24 - 2018-02-10 02:23 - 000613272 _____ (Microsoft Corporation) C:\WINDOWS\system32\devinv.dll
2018-02-14 12:24 - 2018-02-10 02:23 - 000138136 _____ (Microsoft Corporation) C:\WINDOWS\system32\CompatTelRunner.exe
2018-02-14 12:24 - 2018-02-10 02:22 - 002003352 _____ (Microsoft Corporation) C:\WINDOWS\system32\aitstatic.exe
2018-02-14 12:24 - 2018-02-10 02:22 - 000662936 _____ (Microsoft Corporation) C:\WINDOWS\system32\aeinv.dll
2018-02-14 12:24 - 2018-02-10 02:22 - 000460696 _____ (Microsoft Corporation) C:\WINDOWS\system32\dcntel.dll
2018-02-14 12:24 - 2018-02-10 02:22 - 000387480 _____ (Microsoft Corporation) C:\WINDOWS\system32\invagent.dll
2018-02-14 12:24 - 2018-02-10 02:22 - 000272800 _____ (Microsoft Corporation) C:\WINDOWS\system32\aepic.dll
2018-02-14 12:24 - 2018-02-10 02:22 - 000070040 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32appinventorycsp.dll
2018-02-14 12:24 - 2018-02-10 02:22 - 000035224 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceCensus.exe
2018-02-14 12:24 - 2018-02-10 02:21 - 001092016 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.efi
2018-02-14 12:24 - 2018-02-10 02:21 - 000479912 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase_enclave.dll
2018-02-14 12:24 - 2018-02-10 02:20 - 000924648 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.exe
2018-02-14 12:24 - 2018-02-10 02:19 - 001133888 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVP9DEC.dll
2018-02-14 12:24 - 2018-02-10 02:18 - 000098272 _____ (Microsoft Corporation) C:\WINDOWS\system32\FsIso.exe
2018-02-14 12:24 - 2018-02-10 02:18 - 000022400 _____ (Microsoft Corporation) C:\WINDOWS\system32\wow64cpu.dll
2018-02-14 12:24 - 2018-02-10 02:17 - 001209240 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.exe
2018-02-14 12:24 - 2018-02-10 02:15 - 002514944 _____ (Microsoft Corporation) C:\WINDOWS\system32\KernelBase.dll
2018-02-14 12:24 - 2018-02-10 02:15 - 001415296 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.efi
2018-02-14 12:24 - 2018-02-10 02:14 - 001002592 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase.dll
2018-02-14 12:24 - 2018-02-10 02:13 - 000535960 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netio.sys
2018-02-14 12:24 - 2018-02-10 02:11 - 001029528 _____ (Microsoft Corporation) C:\WINDOWS\system32\efscore.dll
2018-02-14 12:24 - 2018-02-10 02:11 - 000711432 _____ (Microsoft Corporation) C:\WINDOWS\system32\ci.dll
2018-02-14 12:24 - 2018-02-10 02:11 - 000677784 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cng.sys
2018-02-14 12:24 - 2018-02-10 02:11 - 000494496 _____ (Microsoft Corporation) C:\WINDOWS\system32\pcasvc.dll
2018-02-14 12:24 - 2018-02-10 02:10 - 002447768 _____ (Microsoft Corporation) C:\WINDOWS\system32\UpdateAgent.dll
2018-02-14 12:24 - 2018-02-10 02:10 - 000246168 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserbroker.dll
2018-02-14 12:24 - 2018-02-10 02:09 - 000525208 _____ (Microsoft Corporation) C:\WINDOWS\system32\wimserv.exe
2018-02-14 12:24 - 2018-02-10 02:09 - 000491264 _____ (Microsoft Corporation) C:\WINDOWS\system32\policymanager.dll
2018-02-14 12:24 - 2018-02-10 02:08 - 000687552 _____ (Microsoft Corporation) C:\WINDOWS\system32\StructuredQuery.dll
2018-02-14 12:24 - 2018-02-10 02:08 - 000398824 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettingsAdminFlows.exe
2018-02-14 12:24 - 2018-02-10 02:07 - 000705944 _____ (Microsoft Corporation) C:\WINDOWS\system32\wimgapi.dll
2018-02-14 12:24 - 2018-02-10 02:07 - 000436632 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudExperienceHostCommon.dll
2018-02-14 12:24 - 2018-02-10 02:06 - 000594048 _____ (Microsoft Corporation) C:\WINDOWS\system32\mf.dll
2018-02-14 12:24 - 2018-02-10 02:06 - 000519144 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecurityHealthService.exe
2018-02-14 12:24 - 2018-02-10 02:06 - 000356952 _____ (Microsoft Corporation) C:\WINDOWS\system32\wintrust.dll
2018-02-14 12:24 - 2018-02-10 02:06 - 000189336 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecurityHealthAgent.dll
2018-02-14 12:24 - 2018-02-10 02:05 - 000070856 _____ (Microsoft Corporation) C:\WINDOWS\system32\wldp.dll
2018-02-14 12:24 - 2018-02-10 02:04 - 001426672 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEng.dll
2018-02-14 12:24 - 2018-02-10 02:04 - 000374032 _____ (Microsoft Corporation) C:\WINDOWS\system32\vac.exe
2018-02-14 12:24 - 2018-02-10 02:04 - 000339872 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkBindingEngineMigPlugin.dll
2018-02-14 12:24 - 2018-02-10 02:04 - 000212880 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsensorgroup.dll
2018-02-14 12:24 - 2018-02-10 02:03 - 001619808 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppobjs.dll
2018-02-14 12:24 - 2018-02-10 02:03 - 000849304 _____ (Microsoft Corporatio
Offline Nissi1
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 11.03.2018 01
Ran by Zandra Jones (11-03-2018 19:08:32)
Running from C:\Users\Zandra Jones\Desktop
Windows 10 Home Version 1709 16299.248 (X64) (2017-12-16 17:21:59)
Boot Mode: Normal
==================== Accounts: =============================
Administrator (S-1-5-21-3088507388-2561779440-336279174-500 - Administrator - Disabled)
DefaultAccount (S-1-5-21-3088507388-2561779440-336279174-503 - Limited - Disabled)
defaultuser1 (S-1-5-21-3088507388-2561779440-336279174-1014 - Limited - Enabled) => C:\Users\defaultuser1
Guest (S-1-5-21-3088507388-2561779440-336279174-501 - Limited - Disabled)
HomeGroupUser$ (S-1-5-21-3088507388-2561779440-336279174-1013 - Limited - Enabled)
WDAGUtilityAccount (S-1-5-21-3088507388-2561779440-336279174-504 - Limited - Disabled)
Zandra Jones (S-1-5-21-3088507388-2561779440-336279174-1001 - Administrator - Enabled) => C:\Users\Zandra Jones
==================== Security Center ========================
(If an entry is included in the fixlist, it will be removed.)
AV: Windows Defender (Disabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
AV: Malwarebytes (Enabled - Up to date) {23007AD3-69FE-687C-2629-D584AFFAF72B}
AS: Malwarebytes (Enabled - Up to date) {98619B37-4FC4-67F2-1C99-EEF6D47DBD96}
AS: Windows Defender (Disabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
==================== Installed Programs ======================
(Only the adware programs with "Hidden" flag could be added to the fixlist to unhide them. The adware programs should be uninstalled manually.)
Adobe Flash Player 28 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 28.0.0.161 - Adobe Systems Incorporated)
ccc-core-static (HKLM-x32\...\{EBF60699-3D2E-6677-D504-5B4846171C8E}) (Version: 2009.0714.2132.36830 - ATI) Hidden
CCleaner (HKLM\...\CCleaner) (Version: 5.40 - Piriform)
D3DX10 (HKLM-x32\...\{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
Dell Data Vault (HKLM\...\{2E55EEFD-2162-4A7D-9158-EDB0305603A6}) (Version: 4.3.4.0 - Dell Inc.) Hidden
Dell Edoc Viewer (HKLM\...\{8EBA8727-ADC2-477B-9D9A-1A1836BE4E05}) (Version: 1.0.0 - Dell Inc)
Dell SupportAssist (HKLM\...\PC-Doctor for Windows) (Version: 2.0.6875.668 - Dell)
Dell SupportAssistAgent (HKLM-x32\...\{B57A8AFE-6735-4497-BD52-BD2F838F5CF0}) (Version: 1.2.1.31 - Dell)
Dell Update (HKLM-x32\...\{DB82968B-57A4-4397-81A5-ECAB21B5DFCD}) (Version: 1.7.1015.0 - Dell Inc.)
eReg (HKLM-x32\...\{3EE9BCAE-E9A9-45E5-9B1C-83A4D357E05C}) (Version: 1.20.138.34 - Logitech, Inc.) Hidden
Google Drive (HKLM-x32\...\{9BC95947-92FD-438B-A168-C01F9A5B7292}) (Version: 2.34.7529.6838 - Google, Inc.)
Google Talk Plugin (HKLM-x32\...\{F9B579C2-D854-300A-BE62-A09EB9D722E4}) (Version: 5.41.3.0 - Google)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.7 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.25.11 - Google Inc.) Hidden
Internet TV for Windows Media Center (HKLM-x32\...\{9D318C86-AF4C-409F-A6AC-7183FF4CF424}) (Version: 4.2.2.0 - Microsoft Corporation)
Junk Mail filter update (HKLM-x32\...\{0BE9E708-5DC0-4963-9CFD-0AA519090E79}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
LastPass (uninstall only) (HKLM-x32\...\LastPass) (Version:  - LastPass)
Malwarebytes version 3.3.1.2183 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.3.1.2183 - Malwarebytes)
Memeo Instant Backup (HKLM-x32\...\{8E666407-AC41-46a2-9692-6C7BFCBFDD37}) (Version: 4.60.0.7252 - Memeo Inc.)
Microsoft Office 2010 (HKLM-x32\...\{95140000-0070-0000-0000-0000000FF1CE}) (Version: 14.0.4763.1000 - Microsoft Corporation)
Microsoft OneDrive (HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\OneDriveSetup.exe) (Version: 17.3.7294.0108 - Microsoft Corporation)
Microsoft PowerPoint Viewer (HKLM-x32\...\{95140000-00AF-0409-0000-0000000FF1CE}) (Version: 14.0.7015.1000 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}) (Version: 8.0.61001 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{7299052b-02a4-4627-81f2-1818da5d550d}) (Version: 8.0.56336 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{837b34e3-7c30-493c-8f6a-2b0f04e2912c}) (Version: 8.0.59193 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161 (HKLM\...\{5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729 (HKLM-x32\...\{820B6609-4C97-3A2B-B644-573B06A0F0CC}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 (HKLM-x32\...\{9A25302D-30C0-39D9-BD6F-21E6EC160475}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32\...\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 (HKLM-x32\...\{9BE518E6-ECC6-35A9-88E4-87755C07200F}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2010  x86 Redistributable - 10.0.40219 (HKLM-x32\...\{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}) (Version: 10.0.40219 - Microsoft Corporation)
Mozilla Firefox 58.0.2 (x64 en-US) (HKLM\...\Mozilla Firefox 58.0.2 (x64 en-US)) (Version: 58.0.2 - Mozilla)
Mozilla Maintenance Service (HKLM-x32\...\MozillaMaintenanceService) (Version: 58.0.2.6611 - Mozilla)
Pale Moon (x64 en-US) (HKLM\...\Pale Moon (x64 en-US)) (Version: 27.8.1 - Moonchild Productions)
PlayReady PC Runtime amd64 (HKLM\...\{BCA9334F-B6C9-4F65-9A73-AC5A329A4D04}) (Version: 1.3.0 - Microsoft Corporation)
PlayReady PC Runtime x86 (HKLM-x32\...\{CCA5EAAD-92F4-4B7A-B5EE-14294C66AB61}) (Version: 1.3.0 - Microsoft Corporation)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.5977 - Realtek Semiconductor Corp.)
Revo Uninstaller 2.0.4 (HKLM\...\{A28DBDA2-3CC7-4ADC-8BFE-66D7743C6C97}_is1) (Version: 2.0.4 - VS Revo Group, Ltd.)
Shared C Run-time for x64 (HKLM\...\{EF79C448-6946-4D71-8134-03407888C054}) (Version: 10.0.0 - McAfee)
Skins (HKLM-x32\...\{BE6F906F-9F86-5CED-E122-8C6A162295B8}) (Version: 2009.0714.2132.36830 - ATI) Hidden
Smart View (HKLM-x32\...\{1800D8A5-F7B2-4C20-868E-1CF55CBBDF21}) (Version: 1.0.0.0 - Samsung )
VC80CRTRedist - 8.0.50727.6195 (HKLM-x32\...\{933B4015-4618-4716-A828-5289FC03165F}) (Version: 1.2.0 - DivX, Inc) Hidden
Visual Studio 2012 x64 Redistributables (HKLM\...\{8C775E70-A791-4DA8-BCC3-6AB7136F4484}) (Version: 14.0.0.1 - AVG Technologies)
Visual Studio 2012 x86 Redistributables (HKLM-x32\...\{98EFF19A-30AB-4E4B-B943-F06B1C63EBF8}) (Version: 14.0.0.1 - AVG Technologies CZ, s.r.o.)
Windows 7 USB/DVD Download Tool (HKLM-x32\...\{CCF298AF-9CE1-4B26-B251-486E98A34789}) (Version: 1.0.30 - Microsoft Corporation)
Windows Live Essentials (HKLM-x32\...\WinLiveSuite) (Version: 16.4.3528.0331 - Microsoft Corporation)
WinPatrol (HKLM-x32\...\{6A206A04-6BC1-411B-AA04-4E52EDEEADF2}) (Version: 35.5.2017.8 - Ruiware)
==================== Custom CLSID (Whitelisted): ==========================
CustomCLSID: HKU\S-1-5-21-3088507388-2561779440-336279174-1001_Classes\CLSID\{144DF3B2-2402-47AE-9583-5A045929A8D4}\InprocServer32 -> C:\Users\Zandra Jones\AppData\Local\Google\Update\1.3.33.5\psuser_64.dll (Google Inc.)
CustomCLSID: HKU\S-1-5-21-3088507388-2561779440-336279174-1001_Classes\CLSID\{E8CF3E55-F919-49D9-ABC0-948E6CB34B9F}\InprocServer32 -> C:\Users\Zandra Jones\AppData\Local\Google\Update\1.3.33.5\psuser_64.dll (Google Inc.)
ShellIconOverlayIdentifiers: [  GoogleDriveBlacklisted] -> {81539FE6-33C7-4CE7-90C7-1C7B8F2F2D42} => C:\Program Files (x86)\Google\Drive\googledrivesync64.dll [2017-11-10] (Google)
ShellIconOverlayIdentifiers: [  GoogleDriveSynced] -> {81539FE6-33C7-4CE7-90C7-1C7B8F2F2D40} => C:\Program Files (x86)\Google\Drive\googledrivesync64.dll [2017-11-10] (Google)
ShellIconOverlayIdentifiers: [  GoogleDriveSyncing] -> {81539FE6-33C7-4CE7-90C7-1C7B8F2F2D41} => C:\Program Files (x86)\Google\Drive\googledrivesync64.dll [2017-11-10] (Google)
ContextMenuHandlers1: [GDContextMenu] -> {BB02B294-8425-42E5-983F-41A1FA970CD6} => C:\Program Files (x86)\Google\Drive\contextmenu64.dll [2017-11-10] (Google)
ContextMenuHandlers3: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2017-11-01] (Malwarebytes)
ContextMenuHandlers4: [GDContextMenu] -> {BB02B294-8425-42E5-983F-41A1FA970CD6} => C:\Program Files (x86)\Google\Drive\contextmenu64.dll [2017-11-10] (Google)
ContextMenuHandlers6: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2017-11-01] (Malwarebytes)
==================== Scheduled Tasks (Whitelisted) =============
Task: {0912AC66-D159-4CCB-A28C-823EB1EC26AA} - System32\Tasks\PCDDataUploadTask => uaclauncher.exe
Task: {0C4A4BC1-96D6-486D-8806-EB314B4EACA8} - System32\Tasks\Microsoft_Hardware_Launch_itype_exe => c:\Program Files\Microsoft Mouse and Keyboard Center\itype.exe
Task: {0D472159-E6AD-4806-ADA2-F6DBE95F14C1} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3088507388-2561779440-336279174-1001Core => C:\Users\Zandra Jones\AppData\Local\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
Task: {0F39A7CB-9D92-4BBA-9998-70CD353DEC4F} - System32\Tasks\avast! Windows 10 Start Menu helper => c:\program files\avast software\avast\asww10mon.exe
Task: {102F2FFB-FD2D-478A-B79A-A839AB4D75C0} - System32\Tasks\PCDEventLauncherTask => C:\Program Files\Dell\SupportAssist\sessionchecker.exe [2017-09-14] (PC-Doctor, Inc.)
Task: {170EB9D8-719B-4155-8B5F-74009FB4E4B1} - System32\Tasks\Microsoft_Hardware_Launch_mousekeyboardcenter_exe => c:\Program Files\Microsoft Mouse and Keyboard Center\mousekeyboardcenter.exe
Task: {1FD008B6-AF0F-4DAA-A8E2-549F777C24CB} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3088507388-2561779440-336279174-1001Core1d257f2e90f2360 => C:\Users\Zandra Jones\AppData\Local\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
Task: {21487CF5-4D44-44CE-A6C5-7A69D8080853} - System32\Tasks\CCleaner Update => C:\Program Files\CCleaner\CCUpdate.exe [2018-02-07] (Piriform Ltd)
Task: {29D00292-898C-4C63-A491-B8B365C06F8C} - System32\Tasks\Microsoft\Windows\Media Center\OCURDiscovery => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {2BDE0B8E-EE7E-4E91-A2C0-B1F208E0A799} - System32\Tasks\{C0476A34-F800-4082-80B8-06A5881A8772} => C:\Program Files\Samsung\AllShare Play\utils\AllShare Play Launcher.exe
Task: {2C32800D-AE70-4A76-9109-905747CF2D38} - System32\Tasks\{E243D6FF-7B98-427F-9FAB-757360A6CD7C} => C:\Program Files (x86)\Dell DataSafe Local Backup\dslauncher.exe
Task: {321866D3-0505-4846-AB5B-3FCEAD0A49F7} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW2 => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {34B00750-D709-412A-8BAF-7B130059F0C6} - System32\Tasks\SafeZone scheduled Autoupdate 1472031917 => C:\Program Files\AVAST Software\SZBrowser\launcher.exe
Task: {3537F9E7-AA15-4798-86C3-5DB55B13EB34} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2018-02-07] (Piriform Ltd)
Task: {3D19D11B-49C9-4CDA-85EA-D70C901DAE4B} - System32\Tasks\Microsoft_Hardware_Launch_rundll32_exe => rundll32.exe url.dll,OpenURL hxxp://go.microsoft.com/fwlink/?LinkID=259868
Task: {3D46B47E-0437-4DC1-867B-679D9892D2E3} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-09-01] (Google Inc.)
Task: {462255AB-D0F7-46E4-AFA5-DB5A316AE2E6} - System32\Tasks\Microsoft\Windows\Media Center\ConfigureInternetTimeService => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {47E2ACEB-48FD-4D8D-8177-7B7A94DF0A80} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-09-01] (Google Inc.)
Task: {58F188A1-FA5F-4C63-ADB1-DA33C36758BC} - System32\Tasks\Microsoft\Windows\Media Center\StartRecording => C:\WINDOWS\ehome\ehrec.exe
Task: {62C2B198-AA5D-4C06-BE1B-6FD31373BA84} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3088507388-2561779440-336279174-1001UA1d257f2e919aba3 => C:\Users\Zandra Jones\AppData\Local\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
Task: {67D8A46B-F180-4B82-B02E-1E5449214F67} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscovery => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {79ECBC3C-BF1F-40D9-88D0-2BA8828E2FB1} - System32\Tasks\Microsoft\Windows\Media Center\ActivateWindowsSearch => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {7A3426B8-A4B5-403E-9C95-F2C5EF92EC36} - System32\Tasks\{BC1ABFC7-DB18-4FED-896E-524DA1D42312} => C:\PROGRAM FILES\Samsung\ALLSHARE PLAY\AllShare Play.exe
Task: {7F150686-162D-4CDC-B32D-A88A2289DB4F} - System32\Tasks\SystemToolsDailyTest => uaclauncher.exe
Task: {7FA5537F-56B3-40E2-BF0F-6D79940A1312} - System32\Tasks\Microsoft\Windows\RemovalTools\MRT_HB => C:\WINDOWS\system32\MRT.exe [2018-02-14] (Microsoft Corporation)
Task: {8280BC8D-D74A-45B3-BCD0-C6B65F044F78} - System32\Tasks\Microsoft\Windows\Media Center\SqlLiteRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
Task: {9006B5B4-2CD2-4EA2-A536-F36C47548B74} - System32\Tasks\Microsoft\Windows\Media Center\ReindexSearchRoot => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {92123202-CBF1-495B-8055-23460EE6022F} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate_scheduled => C:\WINDOWS\ehome\mcupdate.exe
Task: {9415F5C1-3199-40B7-9349-1915E2CE1BA8} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3088507388-2561779440-336279174-1001UA => C:\Users\Zandra Jones\AppData\Local\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
Task: {9612741C-F97B-465B-921F-A8D6135049AF} - System32\Tasks\Microsoft\Windows\Media Center\PvrRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
Task: {98FA7339-BAF1-454E-B36C-82F4FB9E8076} - System32\Tasks\{C3C93E17-639A-4341-9879-86D11DA52C76} => C:\Program Files\Samsung\AllShare Play\utils\AllShare Play Launcher.exe
Task: {993BCBFB-C42E-435C-B5DF-9323D5E068D6} - System32\Tasks\Microsoft_Hardware_Launch_ipoint_exe => c:\Program Files\Microsoft Mouse and Keyboard Center\ipoint.exe
Task: {9C74DE15-EE9A-43AB-A7F8-23066DE5EB4A} - System32\Tasks\Microsoft\Windows\Media Center\UpdateRecordPath => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {9FF0303B-ECB4-4708-AEB0-20A5C06B1BB3} - System32\Tasks\Microsoft\Windows\Media Center\PvrScheduleTask => C:\WINDOWS\ehome\mcupdate.exe
Task: {A1DFAFB7-6806-472B-889F-F54B028617FC} - System32\Tasks\{7074008F-FE52-4C0A-B099-29504B41D9A6} => C:\Windows\system32\pcalua.exe -a C:\KMPlayer\KMPSetup.exe -d C:\KMPlayer
Task: {A5DF891A-4572-4CE0-9E51-27009E4F448E} - System32\Tasks\Microsoft\Windows\Media Center\OCURActivate => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {A7417A2D-72FD-455E-B318-9D0C937FB584} - \Microsoft\Windows\Setup\gwx\launchtrayprocess -> No File <==== ATTENTION
Task: {B0B31395-98EC-4A20-851B-57BFC35CA00B} - System32\Tasks\Microsoft\Windows\Media Center\MediaCenterRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
Task: {B150B550-070F-4A27-B114-051CB7AF4E6D} - System32\Tasks\Microsoft\Windows\Media Center\ObjectStoreRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
Task: {B43C0282-4D61-4804-9418-252CD2DC5776} - \Microsoft\Windows\Setup\GWXTriggers\Logon-5d -> No File <==== ATTENTION
Task: {B63129CD-CFA3-4FB5-A996-65397F47E8B5} - System32\Tasks\Dell SupportAssistAgent AutoUpdate => C:\Program Files (x86)\Dell\SupportAssistAgent\bin\SupportAssist.exe [2016-04-22] (Dell Inc.)
Task: {BAEE3BE7-3D67-43EA-966E-C85362DCD3DF} - System32\Tasks\Microsoft\Windows\Media Center\RegisterSearch => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {C416F4C0-5921-461C-9054-58C8E5147C5D} - System32\Tasks\Microsoft\Windows\Media Center\InstallPlayReady => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {CA01C437-E86C-4C40-BD3F-13173CB0D84D} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW1 => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {CB26BB53-82AA-48B6-BFC7-F1EAA255AAF8} - \Microsoft\Windows\Setup\GWXTriggers\Time-5d -> No File <==== ATTENTION
Task: {CD3E91CC-3D7A-4AAA-80A3-9D3D02560EBA} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate => C:\WINDOWS\ehome\mcupdate.exe
Task: {D80A8235-937F-4D3C-8EEF-83B002DC4CB1} - System32\Tasks\Microsoft\Windows\Media Center\PeriodicScanRetry => C:\WINDOWS\ehome\MCUpdate.exe
Task: {DD20F6C5-D2F8-4D53-B216-CB729A7DAA65} - \Microsoft\Windows\Setup\gwx\refreshgwxconfigandcontent -> No File <==== ATTENTION
Task: {E2921403-41C2-455F-9952-D124C039A276} - System32\Tasks\Microsoft\Windows\Media Center\ehDRMInit => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {E3C7177B-520C-4010-8919-1CFCA73FA354} - System32\Tasks\Microsoft_Hardware_Launch_devicecenter_exe => c:\Program Files\Microsoft Device Center\devicecenter.exe
Task: {EF9F64AB-2671-4424-89EE-3B2CF7077510} - System32\Tasks\Adobe Flash Player Updater => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2018-02-13] (Adobe Systems Incorporated)
Task: {F287DD07-3AD4-4D33-820C-D68F3A061233} - System32\Tasks\{DA4D08D6-4C31-451E-ACB7-5AA3559D8A55} => C:\WINDOWS\system32\pcalua.exe -a C:\ProgramData\DivX\Setup\DivXSetup.exe -c /uninstall
Task: {F51FFF07-9F8E-41A7-85B5-F626E35DB726} - System32\Tasks\Microsoft\Windows\Media Center\RecordingRestart => C:\WINDOWS\ehome\ehrec.exe
Task: {F68E4D4F-CCC6-40BE-89FF-E3FCB261E0F4} - System32\Tasks\{486C982E-4AAB-4DAC-861F-9FCA2AA38D65} => C:\Program Files (x86)\Nero\Nero 10\Nero ControlCenter\NCC.exe
Task: {FC094CBF-B0B8-403A-87D3-A5A877C32A57} - System32\Tasks\Microsoft\Windows\Media Center\DispatchRecoveryTasks => C:\WINDOWS\ehome\ehPrivJob.exe
Task: {FD4EFA28-90AD-48B4-8CF8-8E0CF3F31C44} - System32\Tasks\PCDoctorBackgroundMonitorTask => C:\Program Files\Dell\SupportAssist\uaclauncher.exe [2017-09-14] (PC-Doctor, Inc.)
(If an entry is included in the fixlist, the task (.job) file will be moved. The file which is running by the task will not be moved.)
Task: C:\WINDOWS\Tasks\CreateExplorerShellUnelevatedTask.job => C:\WINDOWS\explorer.exe
Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3088507388-2561779440-336279174-1001Core.job => C:\Users\Zandra Jones\AppData\Local\Google\Update\GoogleUpdate.exe
Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3088507388-2561779440-336279174-1001UA.job => C:\Users\Zandra Jones\AppData\Local\Google\Update\GoogleUpdate.exe
Task: C:\WINDOWS\Tasks\User_Feed_Synchronization-{F17A9A8F-97E5-4CC2-8883-6453D56C06B1}.job => C:\Windows\system32\msfeedssync.exe
==================== Shortcuts & WMI ========================
(The entries could be listed to be restored or removed.)
==================== Loaded Modules (Whitelisted) ==============
2017-09-29 09:41 - 2017-09-29 09:41 - 000184432 _____ () C:\WINDOWS\SYSTEM32\inputhost.dll
2018-02-14 12:25 - 2018-02-10 00:36 - 001804288 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Core.dll
2018-02-14 12:25 - 2018-02-10 00:39 - 011044864 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\CortanaApi.dll
2017-10-16 06:38 - 2017-12-21 22:16 - 002301384 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\SelfProtectionSdk.dll
2017-10-16 06:38 - 2017-12-21 22:16 - 002358728 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\MwacLib.dll
2018-03-06 01:00 - 2018-03-08 22:50 - 005403648 _____ () C:\Program Files\Pale Moon\mozjs.dll
2017-03-23 07:49 - 2017-03-23 07:49 - 001232408 _____ () C:\Users\Zandra Jones\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\cp39zz57.default-1478596356892\extensions\support@lastpass.com\platform\WINNT_x86_64-msvc\components\lpxpcom_x86_64.dll
2018-03-08 18:40 - 2018-03-08 18:40 - 000173568 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11802.1001.8.0_x64__8wekyb3d8bbwe\WinStore.Preview.dll
2018-03-08 18:40 - 2018-03-08 18:40 - 002250240 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11802.1001.8.0_x64__8wekyb3d8bbwe\Microsoft.UI.Xaml.dll
2018-03-08 18:40 - 2018-03-08 18:40 - 007910912 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsStore_11802.1001.8.0_x64__8wekyb3d8bbwe\WinStore.Entertainment.Mobile.dll
==================== Alternate Data Streams (Whitelisted) =========
(If an entry is included in the fixlist, only the ADS will be removed.)
AlternateDataStreams: C:\ProgramData\Temp:5C321E34 [127]
==================== Safe Mode (Whitelisted) ===================
(If an entry is included in the fixlist, it will be removed from the registry. The "AlternateShell" will be restored.)
==================== Association (Whitelisted) ===============
(If an entry is included in the fixlist, the registry item will be restored to default or removed.)
==================== Internet Explorer trusted/restricted ===============
(If an entry is included in the fixlist, it will be removed from the registry.)
IE trusted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\download.microsoft.com -> hxxp://download.microsoft.com
IE trusted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\update.microsoft.com -> hxxp://update.microsoft.com
IE trusted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\update.microsoft.com -> hxxps://update.microsoft.com
IE trusted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\windowsupdate.microsoft.com -> hxxp://windowsupdate.microsoft.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\008i.com -> 008i.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\008k.com -> 008k.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\00hq.com -> 00hq.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\0190-dialers.com -> 0190-dialers.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\01i.info -> 01i.info
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\02pmnzy5eo29bfk4.com -> 02pmnzy5eo29bfk4.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\0411dd.com -> 0411dd.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\0511zfhl.com -> 0511zfhl.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\05p.com -> 05p.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\0632qyw.com -> 0632qyw.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\07ic5do2myz3vzpk.com -> 07ic5do2myz3vzpk.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\08nigbmwk43i01y6.com -> 08nigbmwk43i01y6.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\093qpeuqpmz6ebfa.com -> 093qpeuqpmz6ebfa.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\0calories.net -> 0calories.net
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\0cj.net -> 0cj.net
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\0scan.com -> 0scan.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\1-britney-spears-nude.com -> 1-britney-spears-nude.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\1-domains-registrations.com -> 1-domains-registrations.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\1-se.com -> 1-se.com
IE restricted site: HKU\S-1-5-21-3088507388-2561779440-336279174-1001\...\1001movie.com -> 1001movie.com
There are 6092 more sites.
==================== Hosts content: ===============================
(If needed Hosts: directive could be included in the fixlist to reset Hosts.)
2009-07-13 22:34 - 2016-01-27 19:19 - 000000824 _____ C:\WINDOWS\system32\Drivers\etc\hosts
==================== Other Areas ============================
(Currently there is no automatic fix for this section.)
HKU\S-1-5-21-3088507388-2561779440-336279174-1001\Control Panel\Desktop\\Wallpaper -> C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper
DNS Servers: 209.18.47.62 - 209.18.47.61
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System => (ConsentPromptBehaviorAdmin: 2) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer => (SmartScreenEnabled: RequireAdmin)
Windows Firewall is enabled.
==================== MSCONFIG/TASK MANAGER disabled items ==
MSCONFIG\Services: !SASCORE => 2
MSCONFIG\Services: DellUpdate => 3
MSCONFIG\Services: NOBU => 3
MSCONFIG\Services: SeagateDashboardService => 3
HKLM\...\StartupApproved\Run: => "SecurityHealth"
HKLM\...\StartupApproved\Run: => "Malwarebytes TrayApp"
==================== FirewallRules (Whitelisted) ===============
(If an entry is included in the fixlist, it will be removed from the registry. The file will not be moved unless listed separately.)
FirewallRules: [{0A547180-E414-4BC6-A41F-140CC5213A4B}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
FirewallRules: [{EDC75E0F-AEE5-45F4-AA7C-A151EE69A377}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
FirewallRules: [{83A325BC-9128-4798-B3BA-68290AC1EBB2}] => (Allow) LPort=1900
FirewallRules: [{0BC5E8E1-2CCC-4EE3-AA0E-47EBCFD175DC}] => (Allow) LPort=2869
FirewallRules: [{7C72896C-15F9-40DA-921C-505EBDA1939C}] => (Allow) C:\Program Files (x86)\Windows Live\Contacts\wlcomm.exe
FirewallRules: [{B3D41E57-479A-447B-B735-C7EDCDAACFCB}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
FirewallRules: [{859FDBE4-1D6B-489D-8B4A-E73B558BEE4D}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
FirewallRules: [{BC31D070-219A-4BC9-9C84-1E7ED630D7C6}] => (Allow) C:\Windows\SysWOW64\muzapp.exe
FirewallRules: [{CED80F5B-8A17-47F9-84C3-B1C5F319C98B}] => (Allow) C:\Windows\SysWOW64\muzapp.exe
FirewallRules: [{C6D41869-7588-4153-A979-3BDC265D6779}] => (Allow) LPort=8743
FirewallRules: [{D73B931B-3AD1-480C-AF7C-07F53A640E5A}] => (Allow) LPort=8643
FirewallRules: [{65AE8B1C-5027-42F7-A196-F8C51511CC78}] => (Allow) LPort=7676
FirewallRules: [{5D5BA35F-24F5-48E4-B770-8166404560A6}] => (Allow) LPort=7679
FirewallRules: [{A2D3E1CD-BBF5-432C-A8DA-56814257FFB8}] => (Allow) LPort=24234
FirewallRules: [{CD1FFB88-E3B9-4225-B22D-F2F38D715465}] => (Allow) LPort=7900
FirewallRules: [{F464709D-7BD1-4606-8254-3AD1C76D4580}] => (Allow) LPort=1900
FirewallRules: [TCP Query User{AE4B5790-C0B8-47BD-90D4-F1AD72B4F71A}C:\windows\system32\mmc.exe] => (Block) C:\windows\system32\mmc.exe
FirewallRules: [UDP Query User{D1556019-873B-4678-A4D1-E57E1D1D8801}C:\windows\system32\mmc.exe] => (Block) C:\windows\system32\mmc.exe
FirewallRules: [TCP Query User{1349A276-E0A2-4890-ADC6-09BC7CDCD5FC}C:\program files (x86)\smart view\smart view.exe] => (Allow) C:\program files (x86)\smart view\smart view.exe
FirewallRules: [UDP Query User{75200682-61AB-41E4-9BDA-ACA740B7168F}C:\program files (x86)\smart view\smart view.exe] => (Allow) C:\program files (x86)\smart view\smart view.exe
FirewallRules: [TCP Query User{4B59E323-4EDC-4BE8-BC31-D6A52BB6DAF7}C:\program files (x86)\smart view\smart view.exe] => (Block) C:\program files (x86)\smart view\smart view.exe
FirewallRules: [UDP Query User{C5020F66-9A60-40BF-9332-5FEDEA388359}C:\program files (x86)\smart view\smart view.exe] => (Block) C:\program files (x86)\smart view\smart view.exe
FirewallRules: [TCP Query User{9C2FAC92-CB8E-4122-976A-BE3C8010D2A9}C:\program files (x86)\mozilla firefox\firefox.exe] => (Allow) C:\program files (x86)\mozilla firefox\firefox.exe
FirewallRules: [UDP Query User{00356B11-0505-45C6-AF3D-350292A67DBA}C:\program files (x86)\mozilla firefox\firefox.exe] => (Allow) C:\program files (x86)\mozilla firefox\firefox.exe
==================== Restore Points =========================
22-02-2018 19:24:41 Scheduled Checkpoint
28-02-2018 03:23:24 Windows Modules Installer
10-03-2018 02:10:47 Scheduled Checkpoint
==================== Faulty Device Manager Devices =============
==================== Event log errors: =========================
Application errors:
Error: (03/11/2018 12:57:44 PM) (Source: Application Error) (EventID: 1000) (User: )
Description: Faulting application name: mbamservice.exe, version: 3.1.0.595, time stamp: 0x59f745cb
Faulting module name: mbamservice.exe, version: 3.1.0.595, time stamp: 0x59f745cb
Exception code: 0xc0000005
Fault offset: 0x00000000001c6e66
Faulting process id: 0x604
Faulting application start time: 0x01d3b95a1328a721
Faulting application path: C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe
Faulting module path: C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe
Report Id: 44b2f777-e745-4322-bc32-87c1b4ebc2e3
Faulting package full name:
Faulting package-relative application ID:
Error: (03/11/2018 06:26:35 AM) (Source: Application Error) (EventID: 1000) (User: )
Description: Faulting application name: esetonlinescanner_enu.exe, version: 2.0.19.0, time stamp: 0x59e88dff
Faulting module name: esetonlinescanner_enu.exe, version: 2.0.19.0, time stamp: 0x59e88dff
Exception code: 0xc0000409
Fault offset: 0x001a9165
Faulting process id: 0x208c
Faulting application start time: 0x01d3b91c6734df76
Faulting application path: C:\Users\Zandra Jones\Desktop\esetonlinescanner_enu.exe
Faulting module path: C:\Users\Zandra Jones\Desktop\esetonlinescanner_enu.exe
Report Id: 1df28ddb-cd1b-46a8-9d05-89f14050d70b
Error: (03/11/2018 05:15:17 AM) (Source: Application Hang) (EventID: 1002) (User: )
Description: The program SearchUI.exe version 10.0.16299.248 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: 1a94
Start Time: 01d3b91952fb1f53
Termination Time: 4294967295
Application Path: C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe
Report Id: 4a4e2f26-855f-444c-bb8b-77faccb25810
Faulting package full name: Microsoft.Windows.Cortana_1.9.6.16299_neutral_neutral_cw5n1h2txyewy
Faulting package-relative application ID: CortanaUI
Error: (03/11/2018 05:14:46 AM) (Source: Microsoft-Windows-Immersive-Shell) (EventID: 2484) (User: ZANDRAJONES-PC)
Description: Package Microsoft.Windows.Cortana_1.9.6.16299_neutral_neutral_cw5n1h2txyewy+CortanaUI was terminated because it took too long to suspend.
Error: (03/11/2018 03:17:43 AM) (Source: Dell System Detect) (EventID: 0) (User: )
Description: <Exception><Type>System.Xml.XmlException</Type><Message><![CDATA[The '/' character, hexadecimal value 0x2F, cannot be included in a name.]]></Message><Source><![CDATA[System.Xml]]></Source><StackTrace><![CDATA[   at System.Xml.XmlDocument.CheckName(String name)
   at System.Xml.XmlElement..ctor(XmlName name, Boolean empty, XmlDocument doc)
   at System.Xml.XmlDocument.CreateElement(String prefix, String localName, String namespaceURI)
   at System.Xml.XmlDocument.CreateElement(String name)
   at eSupport.Common.Client.Core.LastUpdatedHelper.SetLastUpdatedValue(String type, String value)]]></StackTrace><SysInfo STag="1CHPHS1" SMBIOSMajVer="2" SMBIOSMinVer="6" SMBIOSBIOSVer="A06" SMBIOSPresent="True" Rel_Date="20120329000000.000000+000" DSDVersion="" Vendor="Dell Inc." PName="Inspiron 570" Ident_Num="ZANDRAJONES-PC" TimeZone="(UTC-05:00) Eastern Time (US & Canada)" OSName="Microsoft Windows 10 Home"/><Method>UpdateLastUpdatedConfig</Method><HostIP>192.168.0.2</HostIP></Exception>
Error: (03/11/2018 03:17:42 AM) (Source: Dell System Detect) (EventID: 0) (User: )
Error: (03/11/2018 03:16:13 AM) (Source: MsiInstaller) (EventID: 11714) (User: ZANDRAJONES-PC)
Description: Product: Dell SupportAssistAgent -- Error 1714. The older version of Dell SupportAssistAgent cannot be removed.  Contact your technical support group.  System Error 1612.
Error: (03/10/2018 08:27:05 AM) (Source: Application Error) (EventID: 1000) (User: )
Faulting process id: 0x8ac
Faulting application start time: 0x01d3b85d548375de
Report Id: d87baf95-7255-4323-bf83-ed78ec3d87a7
System errors:
Error: (03/11/2018 05:49:23 AM) (Source: Service Control Manager) (EventID: 7000) (User: )
Description: The eapihdrv service failed to start due to the following error:
This driver has been blocked from loading
Error: (03/11/2018 05:49:23 AM) (Source: Application Popup) (EventID: 1060) (User: )
Description: \??\C:\Users\ZANDRA~1\AppData\Local\Temp\ehdrv.sys
Windows Defender:
Date: 2018-03-10 16:06:32.476
Description:
Windows Defender Antivirus scan has been stopped before completion.
Scan ID: {AFA0A7D0-8F23-4C89-BD1E-EB71BCB2A4E7}
Scan Type: Antimalware
Scan Parameters: Quick Scan
Date: 2018-03-09 13:36:15.470
Description:
Scan ID: {9A6D5089-48C9-4A6D-B226-9E38B3C02FD4}
Date: 2018-02-28 17:27:27.266
Description:
Scan ID: {FE74DE2D-88A8-463F-A59C-FB894B524091}
Date: 2018-02-18 11:15:05.625
Description:
Scan ID: {89F1B914-C8FF-43CF-AB3B-FD874A0717EB}
Date: 2018-02-18 08:25:18.422
Description:
Scan ID: {EA18EB9A-594D-45E2-830F-B7637FE61BC6}
Date: 2018-02-24 19:35:00.806
Description:
Windows Defender Antivirus has encountered an error trying to load signatures and will attempt reverting back to a known-good set of signatures.
Signatures Attempted: Current
Error Code: 0x80070003
Error description: The system cannot find the path specified.
Signature version: 0.0.0.0;0.0.0.0
Engine version: 0.0.0.0
Date: 2018-02-07 08:57:22.628
Description:
Signatures Attempted: Backup
Error Code: 0x80004004
Error description: Operation aborted
Signature version: 1.261.807.0;1.261.807.0
Engine version: 1.1.14500.5
Date: 2018-02-07 08:57:08.233
Description:
Signature version: 1.261.855.0;1.261.855.0
Date: 2018-01-27 00:04:18.059
Description:
Windows Defender Antivirus has encountered an error trying to update signatures.
New Signature Version:
Previous Signature Version: 1.261.333.0
Update Source: Microsoft Malware Protection Center
Signature Type: AntiVirus
Update Type: Full
Current Engine Version:
Previous Engine Version: 1.1.14500.5
Error code: 0x80072ee2
Error description: The operation timed out
Date: 2018-01-27 00:04:18.058
Description:
Signature Type: AntiSpyware
Update Type: Full
CodeIntegrity:
Date: 2018-03-06 18:54:10.499
Description:
Code Integrity determined that a process (\Device\HarddiskVolume3\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe) attempted to load \Device\HarddiskVolume3\Program Files\Malwarebytes\Anti-Malware\mbae64.dll that did not meet the Store signing level requirements.
Date: 2018-03-06 18:54:09.517
Description:
Date: 2018-03-06 18:54:08.974
Description:
Date: 2018-03-06 18:54:08.749
Description:
Date: 2018-03-06 18:54:07.808
Description:
Date: 2018-03-06 18:39:16.640
Description:
Date: 2018-03-06 18:39:15.920
Description:
Date: 2018-03-06 18:38:50.644
Description:
==================== Memory info ===========================
Processor: AMD Athlon(tm) II X2 250 Processor
Percentage of memory in use: 66%
Total physical RAM: 3838.97 MB
Available physical RAM: 1289.59 MB
Total Virtual: 7678.97 MB
Available Virtual: 3622.22 MB
==================== Drives ================================
Drive c: (OS) (Fixed) (Total:378 GB) (Free:287.66 GB) NTFS
Drive e: (RECOVERY) (Fixed) (Total:72.91 GB) (Free:44.31 GB) NTFS
\\?\Volume{b0e8e044-4397-11e1-8784-806e6f6e6963}\ (RECOVERY) (Fixed) (Total:14.81 GB) (Free:5.35 GB) NTFS
==================== MBR & Partition Table ==================
Disk: 0 (MBR Code: Windows 7/8/10) (Size: 465.8 GB) (Disk ID: 78766FB1)
Partition 1: (Not Active) - (Size=39 MB) - (Type=DE)
Partition 2: (Active) - (Size=14.8 GB) - (Type=07 NTFS)
Partition 3: (Not Active) - (Size=378 GB) - (Type=07 NTFS)
Partition 4: (Not Active) - (Size=72.9 GB) - (Type=07 NTFS)
==================== End of Addition.txt ============================
Hi, Nissi1.
The FRST.txt log got cut off.  Please open it and locate the line below.  Copy/paste the remainder of the log, please.
Offline Nissi1
My Apologies.
2018-02-14 12:24 - 2018-02-10 02:03 - 000849304 _____ (Microsoft Corporation) C:\WINDOWS\system32\LicensingWinRT.dll
2018-02-14 12:24 - 2018-02-10 02:03 - 000722616 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppwinob.dll
2018-02-14 12:24 - 2018-02-10 02:03 - 000706600 _____ (Microsoft Corporation) C:\WINDOWS\system32\EditionUpgradeManagerObj.dll
2018-02-14 12:24 - 2018-02-10 02:03 - 000098712 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceReactivation.dll
2018-02-14 12:24 - 2018-02-10 02:02 - 000628632 _____ (Microsoft Corporation) C:\WINDOWS\system32\msvcp_win.dll
2018-02-14 12:24 - 2018-02-10 01:22 - 001930224 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\KernelBase.dll
2018-02-14 12:24 - 2018-02-10 01:18 - 001384288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVP9DEC.dll
2018-02-14 12:24 - 2018-02-10 01:17 - 000211864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aepic.dll
2018-02-14 12:24 - 2018-02-10 01:15 - 001145624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ucrtbase.dll
2018-02-14 12:24 - 2018-02-10 01:10 - 000422592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\policymanager.dll
2018-02-14 12:24 - 2018-02-10 01:09 - 000559976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\StructuredQuery.dll
2018-02-14 12:24 - 2018-02-10 01:09 - 000354200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CloudExperienceHostCommon.dll
2018-02-14 12:24 - 2018-02-10 01:08 - 000592792 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wimgapi.dll
2018-02-14 12:24 - 2018-02-10 01:07 - 000284112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wintrust.dll
2018-02-14 12:24 - 2018-02-10 01:07 - 000061024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wldp.dll
2018-02-14 12:24 - 2018-02-10 01:05 - 001246432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioEng.dll
2018-02-14 12:24 - 2018-02-10 01:05 - 000718232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LicensingWinRT.dll
2018-02-14 12:24 - 2018-02-10 01:05 - 000654456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EditionUpgradeManagerObj.dll
2018-02-14 12:24 - 2018-02-10 01:05 - 000551672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mf.dll
2018-02-14 12:24 - 2018-02-10 01:05 - 000193248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsensorgroup.dll
2018-02-14 12:24 - 2018-02-10 01:05 - 000079256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DeviceReactivation.dll
2018-02-14 12:24 - 2018-02-10 01:03 - 000505160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msvcp_win.dll
2018-02-14 12:24 - 2018-02-10 00:50 - 001313792 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallService.dll
2018-02-14 12:24 - 2018-02-10 00:50 - 000496128 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatehandlers.dll
2018-02-14 12:24 - 2018-02-10 00:49 - 001664512 _____ (Microsoft Corporation) C:\WINDOWS\system32\GdiPlus.dll
2018-02-14 12:24 - 2018-02-10 00:49 - 000848896 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusUpdateHandlers.dll
2018-02-14 12:24 - 2018-02-10 00:49 - 000211456 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusNotificationUx.exe
2018-02-14 12:24 - 2018-02-10 00:49 - 000107520 _____ (Microsoft Corporation) C:\WINDOWS\system32\musdialoghandlers.dll
2018-02-14 12:24 - 2018-02-10 00:48 - 002890240 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.Resources.dll
2018-02-14 12:24 - 2018-02-10 00:48 - 000033280 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mskssrv.sys
2018-02-14 12:24 - 2018-02-10 00:48 - 000025088 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseAppMgmtClient.dll
2018-02-14 12:24 - 2018-02-10 00:47 - 000331264 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserexport.exe
2018-02-14 12:24 - 2018-02-10 00:47 - 000140800 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
2018-02-14 12:24 - 2018-02-10 00:47 - 000055808 _____ (Microsoft Corporation) C:\WINDOWS\system32\virtdisk.dll
2018-02-14 12:24 - 2018-02-10 00:47 - 000046080 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hidparse.sys
2018-02-14 12:24 - 2018-02-10 00:47 - 000043520 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcimage.dll
2018-02-14 12:24 - 2018-02-10 00:47 - 000033792 _____ (Microsoft Corporation) C:\WINDOWS\system32\wups2.dll
2018-02-14 12:24 - 2018-02-10 00:47 - 000002560 _____ (Microsoft Corporation) C:\WINDOWS\system32\tzres.dll
2018-02-14 12:24 - 2018-02-10 00:46 - 001470976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GdiPlus.dll
2018-02-14 12:24 - 2018-02-10 00:46 - 001008640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallService.dll
2018-02-14 12:24 - 2018-02-10 00:46 - 000199168 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserDeviceRegistration.dll
2018-02-14 12:24 - 2018-02-10 00:46 - 000173568 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryUpgrade.dll
2018-02-14 12:24 - 2018-02-10 00:46 - 000162304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\IndexedDbLegacy.dll
2018-02-14 12:24 - 2018-02-10 00:46 - 000135680 _____ (Microsoft Corporation) C:\WINDOWS\system32\shsetup.dll
2018-02-14 12:24 - 2018-02-10 00:46 - 000082432 _____ (Microsoft Corporation) C:\WINDOWS\system32\MshtmlDac.dll
2018-02-14 12:24 - 2018-02-10 00:46 - 000026112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\setup16.exe
2018-02-14 12:24 - 2018-02-10 00:45 - 000675328 _____ (Microsoft Corporation) C:\WINDOWS\system32\webplatstorageserver.dll
2018-02-14 12:24 - 2018-02-10 00:45 - 000306688 _____ (Microsoft Corporation) C:\WINDOWS\system32\FSClient.dll
2018-02-14 12:24 - 2018-02-10 00:45 - 000288256 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsku.dll
2018-02-14 12:24 - 2018-02-10 00:45 - 000016384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EnterpriseAppMgmtClient.dll
2018-02-14 12:24 - 2018-02-10 00:44 - 000579072 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Payments.dll
2018-02-14 12:24 - 2018-02-10 00:44 - 000302592 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseAppMgmtSvc.dll
2018-02-14 12:24 - 2018-02-10 00:44 - 000276992 _____ (Microsoft Corporation) C:\WINDOWS\system32\shutdownux.dll
2018-02-14 12:24 - 2018-02-10 00:44 - 000048640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\virtdisk.dll
2018-02-14 12:24 - 2018-02-10 00:44 - 000002560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tzres.dll
2018-02-14 12:24 - 2018-02-10 00:43 - 000570368 _____ (Microsoft Corporation) C:\WINDOWS\system32\TileDataRepository.dll
2018-02-14 12:24 - 2018-02-10 00:43 - 000247296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winsku.dll
2018-02-14 12:24 - 2018-02-10 00:43 - 000181248 _____ (Microsoft Corporation) C:\WINDOWS\system32\twext.dll
2018-02-14 12:24 - 2018-02-10 00:43 - 000110080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shsetup.dll
2018-02-14 12:24 - 2018-02-10 00:43 - 000106496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakradiag.dll
2018-02-14 12:24 - 2018-02-10 00:43 - 000086528 _____ (Microsoft Corporation) C:\WINDOWS\system32\cldapi.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000950784 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasgcw.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000837632 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Security.Authentication.Web.Core.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000634880 _____ (Microsoft Corporation) C:\WINDOWS\system32\efswrt.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000459776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webplatstorageserver.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000286720 _____ (Microsoft Corporation) C:\WINDOWS\system32\dnsrslvr.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000234496 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkDesktopSettings.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000184832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\authz.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000160768 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockScreenContent.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000160256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UserDeviceRegistration.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000130048 _____ (Microsoft Corporation) C:\WINDOWS\system32\rshx32.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000112640 _____ (Microsoft Corporation) C:\WINDOWS\system32\IdCtrls.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000098304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\updatepolicy.dll
2018-02-14 12:24 - 2018-02-10 00:42 - 000024064 _____ (Microsoft Corporation) C:\WINDOWS\system32\regsvr32.exe
2018-02-14 12:24 - 2018-02-10 00:41 - 001495552 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.desktop.dll
2018-02-14 12:24 - 2018-02-10 00:41 - 000466432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\efswrt.dll
2018-02-14 12:24 - 2018-02-10 00:41 - 000405504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Payments.dll
2018-02-14 12:24 - 2018-02-10 00:41 - 000255488 _____ (Microsoft Corporation) C:\WINDOWS\system32\edputil.dll
2018-02-14 12:24 - 2018-02-10 00:41 - 000221184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netplwiz.dll
2018-02-14 12:24 - 2018-02-10 00:41 - 000124928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sendmail.dll
2018-02-14 12:24 - 2018-02-10 00:40 - 004498432 _____ (Microsoft Corporation) C:\WINDOWS\system32\xpsrchvw.exe
2018-02-14 12:24 - 2018-02-10 00:40 - 000856576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasgcw.dll
2018-02-14 12:24 - 2018-02-10 00:40 - 000691200 _____ (Microsoft Corporation) C:\WINDOWS\system32\dsreg.dll
2018-02-14 12:24 - 2018-02-10 00:40 - 000526336 _____ (Microsoft Corporation) C:\WINDOWS\system32\authui.dll
2018-02-14 12:24 - 2018-02-10 00:40 - 000298496 _____ (Microsoft Corporation) C:\WINDOWS\system32\netplwiz.dll
2018-02-14 12:24 - 2018-02-10 00:40 - 000232960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edputil.dll
2018-02-14 12:24 - 2018-02-10 00:40 - 000177152 _____ (Microsoft Corporation) C:\WINDOWS\system32\EditionUpgradeHelper.dll
2018-02-14 12:24 - 2018-02-10 00:39 - 002209280 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.onecore.dll
2018-02-14 12:24 - 2018-02-10 00:39 - 000315904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sysdm.cpl
2018-02-14 12:24 - 2018-02-10 00:39 - 000157696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twext.dll
2018-02-14 12:24 - 2018-02-10 00:39 - 000096256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\IdCtrls.dll
2018-02-14 12:24 - 2018-02-10 00:39 - 000020992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\regsvr32.exe
2018-02-14 12:24 - 2018-02-10 00:38 - 003169280 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
2018-02-14 12:24 - 2018-02-10 00:38 - 001968640 _____ (Microsoft Corporation) C:\WINDOWS\system32\FntCache.dll
2018-02-14 12:24 - 2018-02-10 00:38 - 001353728 _____ (Microsoft Corporation) C:\WINDOWS\system32\usercpl.dll
2018-02-14 12:24 - 2018-02-10 00:38 - 000598528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Security.Authentication.Web.Core.dll
2018-02-14 12:24 - 2018-02-10 00:38 - 000174592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EditionUpgradeHelper.dll
2018-02-14 12:24 - 2018-02-10 00:37 - 003419136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xpsrchvw.exe
2018-02-14 12:24 - 2018-02-10 00:36 - 001230848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\usercpl.dll
2018-02-14 12:24 - 2018-02-10 00:36 - 000915968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TokenBroker.dll
2018-02-14 12:24 - 2018-02-10 00:36 - 000403968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sppcomapi.dll
2018-02-14 12:24 - 2018-02-10 00:36 - 000141824 _____ (Microsoft Corporation) C:\WINDOWS\system32\FontProvider.dll
2018-02-14 12:24 - 2018-02-10 00:36 - 000076288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cldapi.dll
2018-02-14 12:24 - 2018-02-10 00:35 - 000667136 _____ (Microsoft Corporation) C:\WINDOWS\system32\FrameServer.dll
2018-02-14 12:24 - 2018-02-10 00:35 - 000455680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\authui.dll
2018-02-14 12:24 - 2018-02-10 00:34 - 000464384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Core.TextInput.dll
2018-02-14 12:24 - 2018-02-10 00:33 - 001570816 _____ (Microsoft Corporation) C:\WINDOWS\system32\RecoveryDrive.exe
2018-02-14 12:24 - 2018-02-10 00:33 - 000217088 _____ (Microsoft Corporation) C:\WINDOWS\system32\WebClnt.dll
2018-02-14 12:24 - 2018-02-10 00:33 - 000125952 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxSysprep.dll
2018-02-14 12:24 - 2018-02-10 00:33 - 000093696 _____ (Microsoft Corporation) C:\WINDOWS\system32\davclnt.dll
2018-02-14 12:24 - 2018-02-10 00:32 - 000073216 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\npfs.sys
2018-02-14 12:24 - 2018-02-10 00:32 - 000050176 _____ (Microsoft Corporation) C:\WINDOWS\system32\pcalua.exe
2018-02-14 12:24 - 2018-02-10 00:31 - 000190464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WebClnt.dll
2018-02-14 12:24 - 2018-02-10 00:31 - 000078848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\davclnt.dll
2018-02-14 12:24 - 2018-02-08 23:35 - 004959688 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmpltfm.dll
2018-02-14 12:24 - 2018-02-08 23:35 - 001234888 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmpal.dll
2018-02-14 12:24 - 2018-02-08 23:35 - 001002952 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmcodecs.dll
2018-02-14 12:24 - 2018-02-08 23:35 - 000892872 _____ (Microsoft Corporation) C:\WINDOWS\system32\ortcengine.dll
2018-02-14 12:24 - 2018-02-08 23:35 - 000065992 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmmvrortc.dll
2018-02-14 12:24 - 2018-02-01 23:36 - 003903944 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmpltfm.dll
2018-02-14 12:24 - 2018-02-01 23:36 - 000921032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmpal.dll
2018-02-14 12:24 - 2018-02-01 23:36 - 000854976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmcodecs.dll
2018-02-14 12:24 - 2018-02-01 23:36 - 000649672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ortcengine.dll
2018-02-14 12:24 - 2018-02-01 23:36 - 000054720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmmvrortc.dll
2018-02-13 02:34 - 2018-02-13 02:34 - 000004412 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater
==================== One Month Modified files and folders ========
(If an entry is included in the fixlist, the file/folder will be moved.)
2018-03-11 18:37 - 2013-10-28 06:59 - 000000000 ____D C:\Users\Zandra Jones\AppData\LocalLow\LastPass
2018-03-11 18:35 - 2017-12-16 12:54 - 000000000 ____D C:\WINDOWS\system32\SleepStudy
2018-03-11 13:44 - 2016-11-18 09:43 - 000000000 ____D C:\Users\Zandra Jones\AppData\LocalLow\Mozilla
2018-03-11 10:28 - 2014-06-18 14:01 - 000000000 __RDL C:\Users\Zandra Jones\OneDrive
2018-03-11 05:23 - 2017-09-29 09:46 - 000000000 ____D C:\WINDOWS\DeliveryOptimization
2018-03-11 05:17 - 2017-12-16 12:57 - 001286656 _____ C:\WINDOWS\system32\PerfStringBackup.INI
2018-03-11 05:13 - 2017-12-16 13:20 - 000000006 ____H C:\WINDOWS\Tasks\SA.DAT
2018-03-11 05:12 - 2017-09-29 04:45 - 000786432 _____ C:\WINDOWS\system32\config\BBI
2018-03-09 21:39 - 2017-09-29 09:46 - 000000000 ____D C:\WINDOWS\AppReadiness
2018-03-09 20:37 - 2017-09-29 09:44 - 000000000 ____D C:\WINDOWS\INF
2018-03-09 19:58 - 2017-09-29 09:46 - 000000000 ___HD C:\Program Files\WindowsApps
2018-03-09 07:23 - 2017-06-11 10:03 - 000000000 ____D C:\Users\Zandra Jones\AppData\Local\ESET
2018-03-08 22:50 - 2013-10-27 03:51 - 000000000 ____D C:\Program Files\Pale Moon
2018-03-07 20:32 - 2012-08-23 14:43 - 000000000 ____D C:\Users\Zandra Jones\AppData\LocalLow\Temp
2018-03-04 07:08 - 2018-01-07 06:02 - 000000000 ____D C:\Users\Zandra Jones\AppData\Local\PlaceholderTileLogoFolder
2018-03-04 03:29 - 2017-12-16 13:03 - 000000000 ____D C:\Users\Zandra Jones\AppData\Local\Packages
2018-03-01 18:56 - 2017-09-29 09:46 - 000000000 ___RD C:\Program Files\Windows Defender
2018-03-01 03:55 - 2017-12-16 13:02 - 000000000 ____D C:\Users\Zandra Jones
2018-02-28 19:40 - 2017-09-29 09:46 - 000000000 ____D C:\WINDOWS\rescache
2018-02-28 03:24 - 2017-09-29 09:37 - 000000000 ____D C:\WINDOWS\CbsTemp
2018-02-24 20:34 - 2012-08-23 14:39 - 000000000 ____D C:\Program Files (x86)\Mozilla Maintenance Service
2018-02-23 20:07 - 2017-12-16 13:20 - 000003936 _____ C:\WINDOWS\System32\Tasks\CCleaner Update
2018-02-23 03:11 - 2017-09-29 09:46 - 000000000 ____D C:\WINDOWS\LiveKernelReports
2018-02-21 11:54 - 2016-12-19 12:04 - 000000000 ____D C:\Program Files (x86)\Mozilla Firefox
2018-02-21 11:54 - 2012-08-23 14:39 - 000001144 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Firefox.lnk
2018-02-17 07:26 - 2016-02-28 10:27 - 000000000 ___RD C:\Users\Zandra Jones\3D Objects
2018-02-17 07:26 - 2015-12-31 09:45 - 000000000 __RHD C:\Users\Public\AccountPictures
2018-02-17 07:24 - 2017-12-16 12:54 - 000232296 _____ C:\WINDOWS\system32\FNTCACHE.DAT
2018-02-17 07:22 - 2017-09-29 09:46 - 000000000 ____D C:\WINDOWS\TextInput
2018-02-17 07:22 - 2017-09-29 09:46 - 000000000 ____D C:\WINDOWS\system32\oobe
2018-02-17 07:22 - 2017-09-29 09:46 - 000000000 ____D C:\WINDOWS\system32\appraiser
2018-02-17 07:22 - 2017-09-29 09:46 - 000000000 ____D C:\WINDOWS\ShellExperiences
2018-02-17 07:22 - 2017-09-29 09:46 - 000000000 ____D C:\WINDOWS\bcastdvr
2018-02-17 06:43 - 2014-06-03 23:22 - 000000000 ____D C:\Users\Zandra Jones\AppData\Local\ElevatedDiagnostics
2018-02-17 06:35 - 2017-07-20 18:51 - 000000000 ____D C:\WINDOWS\SysWOW64\RTCOM
2018-02-14 12:37 - 2013-07-12 01:15 - 000000000 ____D C:\WINDOWS\system32\MRT
2018-02-14 12:34 - 2017-10-10 19:46 - 130067560 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT-KB890830.exe
2018-02-14 12:34 - 2014-01-20 09:13 - 130067560 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
2018-02-14 12:33 - 2017-09-29 09:41 - 001043352 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecConfig.efi
2018-02-14 12:28 - 2017-09-29 09:41 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MshtmlDac.dll
2018-02-13 02:34 - 2017-09-29 09:46 - 000000000 ____D C:\WINDOWS\SysWOW64\Macromed
2018-02-13 02:34 - 2017-09-29 09:46 - 000000000 ____D C:\WINDOWS\system32\Macromed
2018-02-13 02:34 - 2014-10-20 09:23 - 000000000 ____D C:\Users\Zandra Jones\AppData\Local\Adobe
2018-02-12 19:50 - 2014-01-26 07:04 - 001348096 _____ (Adobe Systems Incorporated) C:\Users\Zandra Jones\Downloads\uninstall_flash_player.exe
2018-02-10 16:26 - 2015-08-16 16:31 - 000001362 _____ C:\Users\Public\Documents\Microsoft document.txt
==================== Files in the root of some directories =======
2012-08-23 23:02 - 2012-08-23 23:02 - 000129536 _____ () C:\Users\Public\AlexaNSISPlugin.4528.dll
2013-10-26 08:05 - 2014-02-08 05:50 - 013024768 _____ (LastPass) C:\Program Files (x86)\Common Files\lpuninstall.exe
2012-10-08 17:01 - 2015-12-31 02:56 - 000029184 ___SH () C:\Users\Zandra Jones\AppData\Roaming\Thumbs.db
2012-10-05 21:21 - 2013-10-26 23:29 - 000022402 _____ () C:\Users\Zandra Jones\AppData\Roaming\UserTile.png
2014-03-08 09:44 - 2015-08-02 08:43 - 000049152 _____ () C:\Users\Zandra Jones\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
2016-08-20 11:00 - 2016-08-20 11:00 - 000000453 _____ () C:\Users\Zandra Jones\AppData\Local\LMIR0001.tmp.bat
2016-08-20 11:00 - 2016-08-20 11:00 - 000000378 _____ () C:\Users\Zandra Jones\AppData\Local\LMIR0001.tmp_r.bat
2014-03-11 19:33 - 2016-11-14 19:25 - 000007632 _____ () C:\Users\Zandra Jones\AppData\Local\Resmon.ResmonCfg
2015-07-04 17:15 - 2015-07-04 17:15 - 000043682 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx0a4c
2015-07-08 02:08 - 2015-07-08 02:08 - 000253196 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx1719
2015-05-19 02:43 - 2015-05-19 02:43 - 000247298 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx294d
2015-07-08 02:08 - 2015-07-08 02:08 - 000253196 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx31e2
2015-07-12 19:52 - 2015-07-12 19:52 - 000043494 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx40c8
2015-07-20 07:29 - 2015-07-20 07:29 - 000043494 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx4329
2015-07-08 02:08 - 2015-07-08 02:08 - 000253196 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx4a2b
2015-07-25 02:54 - 2015-07-25 02:54 - 000043494 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx5a37
2015-07-08 02:08 - 2015-07-08 02:08 - 000253196 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx62e9
2015-07-08 02:08 - 2015-07-08 02:08 - 000253196 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx6aaf
2015-07-12 19:43 - 2015-07-12 19:43 - 000043494 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx6da4
2015-07-08 02:08 - 2015-07-08 02:08 - 000253196 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx729e
2015-05-19 02:43 - 2015-05-19 02:43 - 000247298 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx80da
2015-07-22 22:47 - 2015-07-22 22:47 - 000043494 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx846e
2015-05-19 02:43 - 2015-05-19 02:43 - 000247298 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx8877
2015-05-19 02:43 - 2015-05-19 02:43 - 000247298 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx893c
2015-07-08 02:08 - 2015-07-08 02:08 - 000253196 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx8ead
2015-07-05 22:46 - 2015-07-05 22:47 - 000043682 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx9bcf
2015-07-12 19:41 - 2015-07-12 19:41 - 000043494 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx9cba
2015-07-08 02:08 - 2015-07-08 02:08 - 000253196 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivx9f0a
2015-07-13 14:13 - 2015-07-13 14:13 - 000043494 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivxa145
2015-07-08 02:08 - 2015-07-08 02:08 - 000253196 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivxb09e
2015-07-26 04:41 - 2015-07-26 04:41 - 000043494 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivxb1db
2015-07-18 13:52 - 2015-07-18 13:52 - 000043494 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivxb493
2015-07-13 16:16 - 2015-07-13 16:16 - 000043494 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivxcacb
2015-07-08 02:08 - 2015-07-08 02:08 - 000253196 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivxdbbe
2015-07-02 14:23 - 2015-07-02 14:23 - 000043682 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivxef2f
2015-07-04 09:42 - 2015-07-04 09:42 - 000043682 _____ () C:\Users\Zandra Jones\AppData\Local\Tempdivxef40
==================== Bamital & volsnap ======================
(There is no automatic fix for files that do not pass verification.)
C:\WINDOWS\system32\winlogon.exe => File is digitally signed
C:\WINDOWS\system32\wininit.exe => File is digitally signed
C:\WINDOWS\explorer.exe => File is digitally signed
C:\WINDOWS\SysWOW64\explorer.exe => File is digitally signed
C:\WINDOWS\system32\svchost.exe => File is digitally signed
C:\WINDOWS\SysWOW64\svchost.exe => File is digitally signed
C:\WINDOWS\system32\services.exe => File is digitally signed
C:\WINDOWS\system32\User32.dll => File is digitally signed
C:\WINDOWS\SysWOW64\User32.dll => File is digitally signed
C:\WINDOWS\system32\userinit.exe => File is digitally signed
C:\WINDOWS\SysWOW64\userinit.exe => File is digitally signed
C:\WINDOWS\system32\rpcss.dll => File is digitally signed
C:\WINDOWS\system32\dnsapi.dll => File is digitally signed
C:\WINDOWS\SysWOW64\dnsapi.dll => File is digitally signed
C:\WINDOWS\system32\Drivers\volsnap.sys => File is digitally signed
LastRegBack: 2018-03-08 19:30
==================== End of FRST.txt ============================
