Author Topic: Windows Update does work ??  (Read 12147 times)
Offline pops
Re: Windows Update does work ??
« Reply #15 on: November 02, 2016, 07:32:39 PM »
Just finished updating the six updates (I skipped 3118401).  Thanks so much.
Here are the other two pages.
The page dated 4/12/2016 only has six updates (I put a extra link is at the top 375KB, by mistake).
The page dated 5/10/2016 has 14 total.  It one you don't see is for IE9 for Windows Vista (KB3154070)  size 12.9 MB.
'I can see the light at the end of the tunnel.'
« Reply #16 on: November 03, 2016, 01:08:47 PM »
April 2016 if I ignore the NET 3 , there are a total of 5 updates. I'll have to search because I don't see any NET framework 3 patches in April.
This is April's security bulletin and it is NET 4, not 3
https://technet.microsoft.com/library/security/MS16-041
Critical
3145739 https://www.microsoft.com/en-us/download/details.aspx?id=51871
3146963 https://www.microsoft.com/en-us/download/details.aspx?id=51879
Important
3146706 https://www.microsoft.com/en-us/download/details.aspx?id=51823
3149090 https://www.microsoft.com/en-us/download/details.aspx?id=51878
Other
3147071 https://www.microsoft.com/en-us/download/details.aspx?id=51825
If the last one doesn't install, hide it. I had to search and ended up seeing installation problems and breaking things (Win 7). I'm not sure if it causes any problems in Vista.
Please give me a KB number for the NET framework 3 patch. It probably is not from April.
« Reply #17 on: November 03, 2016, 01:18:54 PM »
This might be the NET 3. It is from March 2016 and the KB is 3135987
https://www.microsoft.com/en-us/download/details.aspx?id=51477
Offline pops
« Reply #19 on: November 04, 2016, 05:59:39 PM »
1)  During my updates the two updates below showed the message:
"The update does not apply to your system".
3156016 and 3153199
2)  Under your Important list:
The first two (3150220 and 3153171) showed the same id=52059
Other than that, I got all the updates installed!  I didn't use the 3 (hide) at the end.
« Reply #20 on: November 04, 2016, 10:48:02 PM »
KB3153171 https://www.microsoft.com/en-us/download/details.aspx?id=52222
I have to assume that perhaps the two that said not applicable have been replaced by other updates. I'll need to look around in June, July, August, September and October so that might take some time.
In the meantime, after you install KB3153171 reboot then check for updates. Post what happens.
Looking at the bulletin for the Critical update 16-055
https://technet.microsoft.com/library/security/MS16-055
there are 3 updates listed. You got two of the three to install. 3156016 says something about 3D. Perhaps your computer doesn't have a card capable of this so that's why it doesn't apply. I really don't know why it was offered and then said it doesn't apply.
« Reply #21 on: November 04, 2016, 11:15:10 PM »
3153199 was replaced in June 2016 by 3161664
https://www.microsoft.com/en-us/download/details.aspx?id=52877
So if that has been installed, that's the reason the older update is not applicable for your computer.
I'm still trying to figure out 3156016.
Offline pops
« Reply #22 on: November 05, 2016, 01:50:13 PM »
1)  I updated KB3153171.  It worked.
2)  see the results (jpg) below.
3)  I tried the install KB3153199 and I got the answer below:
  "The update does not apply to your system."
« Reply #23 on: November 05, 2016, 02:15:07 PM »
Don't try to install 3153199 it has been replaced.
I posted this
You need 3161664.
I still haven't a clue about 3156016. I spent time looking over all the newer graphics updates from June, July, August, September and October but none mentioned that is was a replacement for the one you have a problem with.
I also googled 3156016 but didn't find much for Vista.
Offline pops
« Reply #24 on: November 06, 2016, 11:56:40 AM »
I tried 3161664 again, and I still get the message:
  "This update does not apply to your system".
I don't know what's happen.??
« Reply #25 on: November 06, 2016, 08:37:24 PM »
Then skip the two that give this message. Run Check for updates and post what happens.
Offline pops
« Reply #26 on: November 07, 2016, 02:42:31 PM »
Here are the screens:
1. shows my laptop is 'up to date'.
2. shows all of the updates that you helped me to update.
« Reply #27 on: November 07, 2016, 04:23:09 PM »
Great. Now you are set for tomorrow and November's updates/patches.
