Author Topic: avast's Browser Cleanup saying WinPatrol's setup is "Yontoo"  (Read 2245 times)
This morning, when I ran avast's Browser Cleanup utility, it warned me that
"Browser Cleanup has detected one or more toolbar protectors on your system:
 - Yontoo
It is strongly recommended to completely remove them from your system, otherwise Browser Cleanup may not be able to remove the unwanted toolbars.
Do you want to completely remove these protectors
Opening up the Avast-Browser-Cleanup.log , I found the following allegation:
Protector found:     "Yontoo" : [ "c:\\progra~3\\instal~1\\{6a206~1\\setup.exe" ]
Sifting through my directory structure, I was able to reveal the full path/filename as
C:\ProgramData\InstallMate\{6A206A04-6BC1-411B-AA04-4E52EDEEADF2}\setup.exe
which is part of the WinPatrol 32.0.2014.5 installer/uninstaller:
Copyright © 2014 Ruiware, LLC
The files in this folder are required for a clean update or removal
of the above product. Please do not delete them.
I have reported this at the avast forum:  https://forum.avast.com/index.php?topic=174069.0
Re: avast's Browser Cleanup saying WinPatrol's setup is "Yontoo"
« Reply #1 on: July 24, 2015, 05:16:19 PM »
AdwareCleaner was detecting InstallMate at one time also.
http://www.herdprotect.com/setup.exe-23c184f98f650f6d13acdb7d3576588254466e97.aspx
Offline Bret Lowry
  • WinPatrol Developer
  • Visiting Experts
« Reply #2 on: July 25, 2015, 02:40:42 AM »
At some point in time, someone used InstallMate to create an installer for some malware.
Ever since then, InstallMate has been suffering from false positive problems because many antimalware companies simply see a trace and label it malware w/o making the full determination if the true malware is installed.
I believe this is also why Symantec has a false positive on the WinPatrol installer every single release.
Thanks,
Bret.
« Reply #3 on: July 25, 2015, 11:11:03 AM »
Bret,
Thanks for the response.
As noted, I posted this information at the avast forum, so as to alert "the powers that be" --- as well as other avast/WinPatrol users --- of the situation, lest they follow the Browser Cleanup Tool's suggestion to completely remove the alleged "Yontoo", which would then void WinPatrol's uninstaller from future use.
But instead of thanking me, or even acknowledging that I might be correct in my analysis, I was instead met with denial, condescension and sarcasm, such as:
Yontoo is malware and it not part of WinPatrol.  Follow the instructions in "Logs to assist in cleaning malware "
So I have chosen not to say/pursue anything more there.   I posted here so that any others impacted by this issue, who have the foresight to come here, will find a reference..
« Reply #4 on: July 27, 2015, 09:13:28 AM »
Well, it looks like someone at avast has finally taken me seriously, and the F/P has been fixed:
https://forum.avast.com/index.php?topic=174075.msg1237175#msg1237175
« Reply #5 on: July 27, 2015, 03:15:28 PM »
They should have listened to you in the first place!
