Author Topic: Lastpass and delay start  (Read 3311 times)
Offline joe935
« on: December 10, 2015, 09:08:26 AM »
there are 2 items in startup:
Install LastPass FF RunOnce ---- "C:\Program Files (x86)\Common Files\lpuninstall.exe" -q -name=LastPass -ffuuid support@lastpass.com
Install LastPass IE RunOnce ---- "C:\Program Files (x86)\Common Files\lpuninstall.exe" -p -name=LastPass -ffuuid support@lastpass.com
When you try to move them both to delay start the second one you move will not end up in delay start.
It looks like Winpatrol thinks they are the same but they are not in that the parameter is different for each. the first has a -Q the second has a -P.
How do I get them both in delay start?
Re: Lastpass and delay start
« Reply #1 on: December 10, 2015, 01:29:25 PM »
I am confused. For one, it says "RunOnce". That means the program should run just once then never again! Did you at one point refuse to let it run?
And it says "lpuninstall". LastPass has the option to install "add-ons" for FF and IE so you can access LastPass from within those browsers. And these RunOnce commands appear to be for the purpose to uninstall those add-ons. I don't see a need to delay start a RunOnce program that will uninstall those add-ons.
Are you still using LastPass? If so, do you want it integrated with your browsers? That is just a convenience feature. It does not need to be integrated.
Offline joe935
« Reply #2 on: December 19, 2015, 09:23:07 AM »
They say run once but they are located in the startup folder so they will run at every boot.
« Reply #3 on: December 19, 2015, 01:47:24 PM »
Again, it says uninstall. Why are you telling it to uninstall? And why do you have them in your startup folder? If you want to use Lastpass, I don't see why you need it in your startup folder unless that is how Lastpass tells itself to start with Windows. But that would not be an uninstall command.
I just looked through the LastPass manual and there is no "lpuninstall" option listed.
And if you want us to help you, you need to answer our questions so we can understand the issue and offer sound and applicable advice.
So I ask again, did you at one point refuse to let it run? Are you still using LastPass? If so, do you want it integrated with your browsers?
Offline joe935
« Reply #4 on: December 24, 2015, 01:25:26 PM »
I did not put them there, they are put there by the install of lastpass.
And yes lastpass is intigrated with both Waterfox and IE 11.
I will try to see if Lastpass forum has an answer as to what they do.
« Reply #5 on: December 24, 2015, 01:43:28 PM »
Please let us know what you find out.
Offline joe935
« Reply #6 on: December 24, 2015, 01:51:44 PM »
Found a post stating "no harm in deleting them" So I have disabled them and the app is running in both IE and Waterfox.
But the question still remains that Winpatrol is not moving two execs with different options to the delay folder.
