Author Topic: WinPatrol automatically shuts down after 52 Minutes System Uptime  (Read 2244 times)
Offline germy
« on: September 28, 2015, 04:03:31 PM »
I am not sure when it happened for the first time that my WinPatrol Icon (blue) vanished from the systray and the "WinPatrol.exe *32" process from the Windows Task Manager. It now happens regularly after about 52 minutes system uptime. If I then logout and login again, WP starts working again (I don't know whether for another 52 minutes or shorter).
It could be that WinPatrol PLUS v 30.5.2014.0:30.5.2014.0 was the last stable and fully functioning version on my system. (Could I locate the exact point in time of the first WP malfunction in the WinPatrol Report Log?) I cannot think of a remarkable event other than the change of WP version that could have caused the defect.
I am astonished that WP cannot defend itself better and I would like to know how this can happen and what I could do to cure the situation.
I should not hide the fact that although WP is started as HKLM_RUN it vanishes only in one of my Standard User Accounts. It stays alive in the Admin and a second Standard User Account.
Of course I should try to repair the defective account, all the more so as this is not the only defect of this account. However, I would like to learn from the situation first and see whether WP can be cured.
Intel Core i3 540, 8 GB RAM, 2 SATA-HDD with 640 GB each, Win7 64-Bit, MSE, WinPatrol PLUS, Fx 40.0.3 with NoScript, Tb 38.2.0 (POP3)
Re: WinPatrol automatically shuts down after 52 Minutes System Uptime
« Reply #1 on: September 28, 2015, 06:15:44 PM »
Not sure it fair to blame WinPatrol if the whole user account is having problems. And are you sure WinPatrol stopped or just the system tray.
If me, I might uninstall WinPatrol, reboot, then install it again.
Offline germy
« Reply #2 on: September 29, 2015, 02:20:33 PM »
As I said before, the "WinPatrol.exe *32" process vanishes from the Windows Task Manager at the same time.
I do not intend to blame anything or anybody. I am only concerned that a software that is designed to defend itself against being closed, does shut down regularly and I wonder what lies behind that time interval of 52 minutes.
Of course I have tried several times to uninstall and reinstall WinPatrol - with the same result.
« Reply #3 on: September 29, 2015, 04:04:32 PM »
Well, of course we have no way of knowing that unless you say so.
I do agree, however, that it is disconcerting that it is getting shutdown, but sadly, I have no other suggestions. WP has been very reliable on all my systems and uninstalling/reinstalling has always fixed any problems in those rare events I had problems.
Unless someone here has more ideas, I might suggest you contact support@winpatrol.com with this problem. And then please post back with an update so we all might learn something.
Offline germy
« Reply #4 on: November 19, 2015, 03:13:56 PM »
I thought I had posted that I would report back on the outcome of my contacting WinPatrol Support on this matter. But I cannot find this posting any more. Anyway, here are the results of that consultation:
As to the reason for my problem I was told that there is a “clean-up” process that runs around 1 hour after start-up that could result in the issue I was seeing. Upgrading to the latest version  should fix the problem.
I was told that WinPatrol 33.6.2015.18 was available which is more stable than the version I was running. So I uninstalled my version and installed the proposed one. That solved the problem.
In the context of this E-Mail consultation with WinPatrol Support I asked two additional questions. The answers may be of some interest here:
  • The makers of WinPatrol prefer to have WinPatrol PLUS in HKCU run instead of HKLM run because it is installed on a user by user basis.
  • They stopped using the -expressboot parameter because they found some problems in the way that code was written that was leading to repeat alerts. The savings at start-up were negligible so they decided to simply remove it from the product.
