Author Topic: Had enough yesterday  (Read 21159 times)
Offline mitch
Re: Had enough yesterday
« Reply #15 on: July 29, 2006, 07:31:17 PM »
you should be able to run it again and unless you told it to ignore it should find and allow them to be cleaned?
and have you tried to run it in SAFE mode?
and how much did ccleaner remove?
Offline tim
« Reply #16 on: July 29, 2006, 07:50:11 PM »
do you mean running a complete system scan again? won't that take another hour?
no I haven't tried it in the safe mode, I just followed the instructions on the link :)
Ccleaner removed almost 1gb
"Although extraordinary valor was displayed by the entire corps of Spartans and Thespaians, yet bravest of all was declared the Spartan Dienekes. It is said that on the eve of battle, he was told by a native of Trachis that the Persian archers were so numerous that, when they fired their volleys, the mass of arrows blocked out the sun. Dienekes, however, quite undaunted by this prospect, remarked with a laugh, "Good. Then we'll have our battle in the shade."" - Herodotus, The Histories.  (If you're interested in the battle of Thermopylae, read "Gates of Fire" by Steven Pressfield)
« Reply #17 on: July 29, 2006, 08:15:57 PM »
tim,
Now this is going to take a few scan please follow these instructions carefully, and in the order given
Can you please go and download a plug-in (i.e.:  vx2cleaner.exe) that will assist you in the cleanup of your PC. (if you have not already have done so)
After you have downloaded and installed the VX2 Plug-in as described there,
DO NOT RUN IT YET
please can you clear out your cache folder ie: temporary internet folder.
There are some free programs that you can use that will do that for you if needed like ;)
CCleaner
(Note in CCleaner: go to >options > advanced > Uncheck "Only delete files in Windows Temp folders older than 48 hours"). Then open Ad-Aware SE use the WebUpDate to ensure that you have the latest Definitions File
ie: SE1R116 24.07.2006  then close Ad-Aware SE.
Now please save and close any open programs and disconnect from the internet.
(For broadband/cable users, it is recommended that you disconnect the cable connection)
Then
Please Reboot (i.e.: Re-start your PC)
 Then open Ad-Aware SE but nothing else.
Please can you un-tick this option if you have it ticked
"Include negligible objects information".
To do this Open Ad-aware SE
Click “settings” (the Gear)
then Click “Tweaks“,
 then click Scanning engine,
then un-tick "Include negligible objects information".
And then click the proceed button.
Now please scan doing a  "Full Scan".
When the scan has finished select Next. In the Scanning Results window select the "Scan Summary" tab. tick the box next to a "target family’" you wish to remove. Click next, Click OK.
then rescan and do the same thing till you have removed all the "target family's"
Then please run the VX2 cleaner by Selecting the VX2 Cleaner plug-in  and click “Run Plug-in” Select “Clean System”
Then please Reboot (i.e.: Re-start your PC)
Then after your PC has restarted please open Ad-Aware SE, but nothing else and
scan doing a  "Full Scan". then and once the scan has finished mark and remove items then Reboot (i.e.: Re-start your PC)
Then re-scan  doing a  "Full Scan" and then post your log file here by using the Add-Reply Feature
Offline tim
« Reply #18 on: July 30, 2006, 11:33:03 AM »
there was no Add-Reply feature... where is it?
« Reply #19 on: July 30, 2006, 12:35:11 PM »
If NoAdware is still on your system, go to Add/Remove programs and uninstall it.
As to running ewido in safe mode, yes, that is an excelent idea -- regardless of whether it takes an hour or more.  The object here is to clean your machine and get your computer secure again.
Post the ewido log along with the fresh Ad-Aware log that GR@PH;<'S requested.  Be sure to run the Ad-Aware log in normal mode.
Tim, just click on the button and paste your log so we can see what is still remaining.
Offline tim
« Reply #20 on: July 30, 2006, 01:12:31 PM »
right, will do. this will prolly take at least 1½h before I reply again with the log.
« Reply #21 on: July 30, 2006, 01:25:13 PM »
Take your time, Tim.  Although it is Sunday, there will be someone around at one time or another today to take a look at your logs.
Offline tim
« Reply #22 on: July 30, 2006, 07:09:54 PM »
The logs for the ewido- and aaw scans still contains huge amounts of data..  :(
Should I post it anyway?
« Reply #23 on: July 30, 2006, 07:26:05 PM »
Did you quarantine what was found with ewido?  If not, please do so.  I updated the ewido instructions this morning. Here's the link:  http://www.landzdown.com/index.php?topic=1133.0
 But the answer is yes, please post the logs.  It may take a couple-three replies, but will give us helpful information.
Thanks for asking.  :rose:
Offline tim
« Reply #24 on: July 30, 2006, 09:15:19 PM »
Actually, everytime I use ewido it ends with a freezing of the quarantine-process.. everything is set to be put in quarantine, but a s a I click "Apply All Actions" button, ewido freezes. But SOME files are put in quarantine, as when I restart ewido it tells me that ~1/3 of the infected files found is in quarantine, so it seems like the quarantine process is actually cancelled (maybe due to error while putting a specific file in quarantine) .
What to do about that?
Offline tim
« Reply #25 on: July 30, 2006, 09:16:48 PM »
and how do I start ewido in safe mode? :p
Offline mitch
« Reply #26 on: July 30, 2006, 09:18:30 PM »
How to start a computer in safe mode:
http://www.consumer-forum.co.za/index.php?act=ST&f=23&t=66&
and here is another site in case the first is busy or you want a different format:
http://service1.symantec.com/SUPPORT/tsgeninfo.nsf/docid/2001052409420406
and another with screenshots for all windows versions:
http://www.bleepingcomputer.com/forums/index.php?s=18686f08df5fdc9555693877ca107a65&showtutorial=61
Offline tim
« Reply #27 on: July 31, 2006, 12:21:30 AM »
ewido scan first (safe mode).
ewido anti-spyware - Scan Report
 + Created at:   02:24:57 2006-07-31
 + Scan result:
C:\Documents and Settings\Jenny\Lokala inställningar\Temporary Internet Files\Content.IE5\MJQXWVA5\AppWrap[2].exe -> Adware.AdURL : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Altnet -> Adware.Altnet : Error during cleaning.
HKLM\SOFTWARE\Altnet\Dashboard -> Adware.Altnet : Error during cleaning.
HKLM\SOFTWARE\Altnet\Dashboard\Settings -> Adware.Altnet : Error during cleaning.
C:\WINDOWS\TGVuYSBIdWx0bWFu\command.exe -> Adware.CommAd : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_0 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_0\Level_0 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_0\Level_0\Seqn_1068 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_1 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_1\Level_0 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_1\Level_0\Seqn_4492 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_2 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_2\Level_0 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_2\Level_0\Seqn_1068 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_3 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_3\Level_0 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Loct_3\Level_0\Seqn_1068 -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Services -> Adware.Cydoor : Cleaned with backup (quarantined).
HKU\S-1-5-21-842925246-682003330-702790348-1005\Software\Kazaa\Promotions\Cydoor\Adwr_329\Services\Queue -> Adware.Cydoor : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\Config.xml -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\db -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\db\Aliases.dbs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\db\Sites.dbs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\dwld -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\dwld\WhiteList.xip -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\persist.dbs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\report -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\report\aggr_storage.xml -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\report\send_storage.xml -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\res2 -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\cs\res2\WhiteList.dbs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\shprrprt.log -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Application Data\ShopperReports\shprrprt_1150650106.log -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\cs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\cs\Config.xml -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\cs\db -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\cs\dwld -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\cs\dwld\WhiteList.xip -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\cs\persist.dbs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\cs\report -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\cs\report\aggr_storage.xml -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\cs\report\send_storage.xml -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\cs\res1 -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\cs\res1\WhiteList.dbs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Application Data\ShopperReports\shprrprt.log -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\Config.xml -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\db -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\db\Aliases.dbs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\db\Sites.dbs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\dwld -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\dwld\WhiteList.xip -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\persist.dbs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\report -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\report\aggr_storage.xml -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\report\send_storage.xml -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\res1 -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\cs\res1\WhiteList.dbs -> Adware.HotBar : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Application Data\ShopperReports\shprrprt.log -> Adware.HotBar : Cleaned with backup (quarantined).
HKLM\SOFTWARE\HbTools -> Adware.HotBar : Error during cleaning.
HKLM\SOFTWARE\ShopperReports -> Adware.HotBar : Error during cleaning.
C:\Documents and Settings\Erik\Lokala inställningar\Temporary Internet Files\Content.IE5\CXUVS5UJ\ac3[1].txt -> Adware.IEHelper : Cleaned with backup (quarantined).
C:\WINDOWS\system32\aaa00000.dll -> Adware.IEHelper : Cleaned with backup (quarantined).
C:\WINDOWS\system32\oye3681c.dll -> Adware.IEHelper : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temp\temp.fr3AAC -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temp\temp.fr65E4 -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temp\temp.frE9D2 -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temp\temp.frF962 -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temporary Internet Files\Content.IE5\896ZW9UN\Installer[1].exe -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\Installer3.exe -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\WINDOWS\system32\chadmin.dll -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\WINDOWS\system32\daprop.dll -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\WINDOWS\system32\dfusic.dll -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\WINDOWS\system32\fcclient.dll -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\WINDOWS\system32\iMssvcs.dll -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\WINDOWS\system32\ir0ul5d91.dll -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\WINDOWS\system32\jt6s07j7e.dll -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\WINDOWS\system32\ktrsl7971.dll -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\WINDOWS\system32\mnjdbc10.dll -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\WINDOWS\system32\pjrfdisk.dll -> Adware.Look2Me : Cleaned with backup (quarantined).
C:\warebundlenewer.exe -> Adware.Look2Me : Cleaned with backup (quarantined).
[672] C:\WINDOWS\system32\ldbdivx.dll -> Adware.Look2Me : Error during cleaning.
[764] C:\WINDOWS\system32\ldbdivx.dll -> Adware.Look2Me : Error during cleaning.
C:\Documents and Settings\Erik\Lokala inställningar\Temporary Internet Files\Content.IE5\CXUVS5UJ\loader[1].exe -> Downloader.Adload.de : Cleaned with backup (quarantined).
C:\drsmartload.exe -> Downloader.Adload.de : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temporary Internet Files\Content.IE5\CXUVS5UJ\ac3_0010[1].exe -> Downloader.Small : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temporary Internet Files\Content.IE5\WDYB4D6N\al3[1].txt -> Downloader.Small : Cleaned with backup (quarantined).
C:\WINDOWS\system32\w00365c0.dll -> Downloader.Small : Cleaned with backup (quarantined).
C:\ac3_0010.exe -> Downloader.Small : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temporary Internet Files\Content.IE5\CXUVS5UJ\MTE3NDI6ODoxNg[1].exe -> Downloader.Small.buy : Cleaned with backup (quarantined).
C:\MTE3NDI6ODoxNg.exe -> Downloader.Small.buy : Cleaned with backup (quarantined).
C:\__delete_on_reboot__M_T_E_3_N_D_I_6_O_D_o_x_N_g_._e_x_e_ -> Downloader.Small.buy : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temporary Internet Files\Content.IE5\896ZW9UN\stub_113_4_0_4_0[1].exe -> Downloader.TSUpdate.o : Cleaned with backup (quarantined).
C:\stub_113_4_0_4_0newer.exe -> Downloader.TSUpdate.o : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temporary Internet Files\Content.IE5\CPMJ89MF\drsmartload45a[1].exe -> Downloader.VB.aiw : Cleaned with backup (quarantined).
C:\drsmartload45a7i.exe -> Downloader.VB.aiw : Cleaned with backup (quarantined).
C:\nwnmef_7.exe_tobedeleted -> Downloader.VB.aiy : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Whatever It Takes (2000) [Comedy].exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\When A Killer Calls DVDRip RMVB.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\When a Stranger Calls (2006) DVDRip XviD.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\When a Stranger Calls.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\White Oleander DVDRip Xvid.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Whole Tomato Visual Assist.X v10.2.1444.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Why We Fight (2005).exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wichio Browser v5.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wieser RIP Vinyl v3.38.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WikMail 1473.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wilcom ES Digitizer 8.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Will Rock.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\William Shakespeare - 49 Books.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Willie Nelson, I Love Country 1985.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Willing Webcam 2.7.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Willing Webcam v1.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Willing Webcam v3.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Willing Webcam v3.5.20060714.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Win 2003 Optimize Tool v1.44.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinAMP Pro 5.112.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinASO Registry Optimizer 2.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinASO Registry Optimizer 2.5.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinASO Registry Optimizer v2.0.6.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinASO Registry Optimizer.v2.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinAVI DVD Copy v4.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinAVI Video Converter 7.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinAVI Video Converter v7.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinAce 2.20.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinAmp 5.01 FULL.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinAmp 5.01.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinAmp 501 Full.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinAntiVirus Pro 2006 2.0.225.2 Full.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinAvi Video Converter 7.5 Final.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinBit 1.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinBoost 4.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinBoost 4.50.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinBoost v.4.66.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinDVD Platinium v7.0.B27.191.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinDVD Platinum 7 Release 8.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinDVD Platinum 7.0 B27.191.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinDVD Platinum 7.0.B27.130.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinDVD Recorder 5 Platinum.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinDates v5.01.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinDriver 7.02.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinErrs 1.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinExtra BOSS Pro v1.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinFonie Mobile 2.0.6.8.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinGO Folder Alias v1.6.74.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinGraphic v2.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinGuard Pro 2005 v5.88.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinLock Remote Administrator 1.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinMPG Video Convert v6.3.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinMPG Video Convert v6.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinMag Secret v1.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinPatrol 6.0.0.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinPatrol 9.8.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinPatrol PLUS 9.8.1.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinPatrol v6.0.0.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinPatrol v9.7.0.18.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinPopup Gold v5.13.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinProxy 6.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinQuota v2.0.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRAR 3.42 regged.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRAR 3.51.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRAR 3.6 Beta.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRAR 3.60 Beta 4 Enterprise Edition OEM.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRAR 3.60 beta 2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRAR and DosRAR v3.51 Spanish.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRAR beta 7 (Executive Edition).exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRAR v3.42 regged.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRescue XP 1.08.32.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRescue XP 1.08.33.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRescue XP v1.08.33.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinRoute Firewall v5.1.3.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinSSHD v4.10.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinShadow v2.0.2.187.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinTools net Pro v7.1.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinTools.net Classic v3.3.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinTools.net Professional v5.6.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinTrace Remover v6.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinUtilities 1.6.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinUtilities v1.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinUtilities v2.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinUtilities v5.1 (Retail).exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinUtilities v5.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXMedia DVD MPEG AVI Audio Converter v.4.06.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXMedia DVD MPEG AVI Converter v3.1.36.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXMedia DVD Ripper v2.5.18C.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXP Manager 4.89.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXP Manager 4.91.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXP Manager 4.91.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXP Manager 4.94.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXP Manager 4.97.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXP Manager 4.98.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXP Manager v4.92.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXP Manager v4.93.3.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXP Manager v4.94.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXP Manager v4.96.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinXP Special Collection.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinZip 10.0 Build 6667.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinZip 10.0 Build 6685.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinZip 8.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinZip 9.0 Final Corporate.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinZip Pro 10.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WinZip Pro v10.0.6685.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winamp 5 RC 10 FULL.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winamp 5 RC 8.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winamp 5.22 Pro + keygen.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winamp 5.23 - Pro.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winamp Pro 5.22 Cracked-CFF.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winamp Pro v5.111.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winamp Pro v5.112.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winamp Pro v5.22.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winamp v5.02.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winamp v5.21 Pro.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winamp v5.22 + Keygen.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winavi video converter 7.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winboost v4.52.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WindowBlinds 5.0 Beta 2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows And Internet Cleaner PRO v3.22.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Arcade.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Genuine Advantage KB905474 cracked.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Genuine Advantage Validation v1.5.530.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Live Messenger 8.0.0787.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Media Player 10.00.00.3923.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Media Player 11 (cracked).exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Media Recorder (WMR PRO).exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Media player 11.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Vista 5365.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Vista Wallpaper Pack.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Vista XP Genuine AIO.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Vista build 5365 32õ.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows XP And Office CD Key Finder v1.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows XP PowerPacker 1.0 RC8 Beta 4.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows XP Pro + SP2 [Bootable ISO].exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows XP Pro RUS.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows XP Pro SP3 (MS Office 2003) + SP 3 - iSO.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows XP Pro Upgrade With SP2 Corporate.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows XP Professional &quot;Retail&quot; w   SP2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows XP Professional (Corporate) w SP2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows XP WallPapers.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows Xp-sp3 Full 2006-sico.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windows messenger line 8 patch.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Windrow Manager v2.0.17.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wings Over Europe Cold War Gone Hot.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winguard Pro 2006 6.0.11.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winnow Cleaner 3.4.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Winzip 8.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wipe It v3.01.02.00.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wire Pilot 1.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wise-FTP 4 v4.0.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WodSSHServer ActiveX v1.3.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wojtek Siudmak (Gallery).exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wolf Creek.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wolfenstein  Enemy Territory.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wolfenstein - Enemy Territory - Multiplayer.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wolfenstein - Enemy Territory.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Woman Calender v6.02.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Womble MPEG Video Wizard DVD v03.2006.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wondershare PPT2DVD v3.8.2.218.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Word Link v1.0.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WordRecovery v3.0.0611.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\WorkgroupShare v2.1.0.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Workplace Angel v0.3.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\World (ClipArt) Part 4.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\World (ClipArt) Part 5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\World Class Leader Board.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\World Cup 2006 Wallpapers.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\World Of Warcraft.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\World Online TV 4.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\World Saver 3D Screensaver v3.3.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Worms 3D iSO.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Worms 4  Mayhem.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Worms Fort Under Siege.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Writers Cafe v1.22.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wrong Turn.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wtools32 v1.6.28.198.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Wtools32 v1.7.6.216 Win2K XP.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Www File Share Pro 3.20.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\X Codec Pack 1.8.0.141.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\X-Chat 2.4.5b.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\X-Chat v2.6.1A.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\X-Men  The Last Stand.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\X-Men 3   The Official Game PC DVD.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\X-Men III The Last Stand.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\X-Men The Official Game-RELOADED iSO.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\X-NetStat Professional 5.3 Full.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\X-Plane v7.21.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\X-Setup Pro v8.1.100.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\X-Ways Forensics v11.8 SR-9.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XE Lan Scanner v1.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XM Easy Personal FTP Server 5.0.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XMultimediaDiary v1.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XP Codec Pack 1.3.4.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XP Disk Cleaner v2.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XP Password Recover.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XP Repair Pro 2.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XP Repair Pro 2006 v3.0.20.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XP Tools 5.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XP Tools 5.6.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XP Tools v5.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XP Visual Tools v1.8.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XPCSpy Pro v2.59.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XPCSpy Pro v2.61.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XPepius v3.0.3.560.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XPepius v3.0.459.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XT Spy Standard v2.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XYplorer v5.00.0015.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xara 3D 6.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xara 3D V6.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft Audio Converter 2.1.42.1108.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft Audio Converter v2.1.44.0310.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft DVD Audio Ripper v2.0.52.526.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft DVD Ripper Platinum 4.0.28.1201.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft DVD Ripper Platinum 4.0.51.0619.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft DVD To iPod Suite v2.1.55.1107B.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft PSP Video Converter v2.1.59.0316B.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft RM Converter v2.1.55.1025b.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft RM Converter v2.1.55.1205b.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft Video Converter 3.1.5 build-0430b.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft Video Converter 3.15.0522.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft Video Converter v3.1.5.0430.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft WMA MP3 Converter 2.1.42.1208.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xilisoft WMA MP3 Converter v2.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xlight FTP Server Professional v1.15.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XnView v1.68.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XoftSpy 4.12.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XoftSpy 4.19.133.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XoftSpy 4.21.142.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XoftSpy v4.15.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XoftSpy v4.17.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XoftSpy v4.21.142.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XoftSpySE 4.26.185.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xoftspy V4.18.128.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xoftspy v4.23.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xpand Rally.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xpepius 3.0.3 Build 560.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xplorer2 Professional v1.5.0..exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xpy 0.8.10.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\XtraTools 2006 v05.09.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xtreme Beach Soccer.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Xtreme Translator Enterprise v1.7.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Yahoo Widgets Engine 3.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Yonc v1.24.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\You Me And Dupree CAM.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\You, Me and Dupree (2006).exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\You, Me and Dupree(733mb)XviD.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Young Models XXX DVDRip.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Your Uninstaller 2006 PRO v5.0.0.232.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Your Uninstaller 2006 PRO ver.5.0.0.232.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Your Uninstaller! 2006 v5.0.0.206.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Your Uninstaller! 2006 v5.0.0.230.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zathura DVDRip.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zazel XXX DVDRip.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zealot All Video Converter v1.1.19.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zealot All Video Joiner 2.7.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zealot All Video Joiner v1.0.8.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zealot All Video Sound Extractor v1.0.4.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zealot All Video Splitter 2.3.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zealot All Video Splitter 2.8.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zealot All Video Splitter v1.0.6.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zealot All Video Splitter v1.0.7.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zealot All Video Splitter v1.1.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zealot All Video Splitter v1.1.4.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zealotsoft Programs AIO.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zend Studio Client 4.0.0 for Windows.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZeroG Install Anywhere Enterprise.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZillaFTP V2.4.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZipScan 2.2c.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZipZag v1.53.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zmei Mail Sender 1.01.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zmei Mail Sender v1.04.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zone Alarm.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zone Labs IMsecure Pro v1.0.1.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Anti-Spyware 6.5.700.000.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Anti-Spyware 6.5.722.000.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Internet Security Suite 6.5.700.000 final.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Pro 3.1.395.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Pro 3.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Pro 5.0.754.004 Beta.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Pro 5.5.062.011.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Pro v6.5.700.000.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Pro v6.5.700.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Pro.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Wireless Security 5.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm Wireless Security V5.5.094.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm v4.0.146.029.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneAlarm with Antivirus 6.5.700.000 final.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneLabs IMsecure 1.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoneLabs ZoneAlarm Pro v5.5.094.000.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zoner 3D Photo Maker v.1.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zoner Draw Enterprise v.5.0.15.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zoom Player Pro 5.00 Technology Preview 6.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zoom Player VMW Professional 4.51.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zoom Studio v2.20.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\ZoomIt v1.12.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\Zork 3.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\abylon BASIC 6.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\abylon CRYPTDRIVE 6.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\abylon CRYPTMAIL 6.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\abylon ENTERPRISE 6.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\abylon KEYSAFE 6.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\abylon LOGON 6.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\abylon SHAREDDRIVE 6.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\abylon SHREDDER 6.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\avast! Professional Edition 4.6.731.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\cabelas big game hunter 2006.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\d artiste Character Modeling Ballistic Publishing.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\dotTrace Profiler v1.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\dvd stuff AIO.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\e-Paint v2.0.12a.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\eCover Engineer 4   Samples and Templates.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\eCover v1.0.5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\eDonkey 2000 1.4.5 Pro Final.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\eFlowPDF Professional Edition 1.0.583.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\eMule 0.30d.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\eTrust PestPatrol Anti-Spyware 5.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\eWallet Pro 4.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\febooti ieZoom toolbar 1.4.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\file renamer 1.56.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\graphic cook book.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\iDo Wedding Couple Edition v7.6.0.2263.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\iGrafx 2005 v10.0.4.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\iHateSpam Universal Desktop Edition v4.0.404.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\iOpus STARR PC.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\iPod Video Converter v2.1.55.1107b.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\iTinySoft Total Video Converter 2.52.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\iTunes for Windows 4.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\iView MediaPro v3.11.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\iolo Search and Recover v1.0b.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\iso buster.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\mIRC Power Pack 8.00 RC6.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\mceContacts v1.2.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\mst Defrag v1.8.30.58.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\myLite Desktops v2.0.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\n-Track Studio 4.21.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\nLite v1.0 RC5.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\nVIDIA Latest Drivers v52.16.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\new anydvd 6.0.1.1, 2006 06 09.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\qdContacts 1.1.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\securecopy 4.05.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\super fast clone dvd copy full.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\uTorrent 1.5.1 Beta Build 465.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\vBulletin 2.2.6.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\webcamXP 2006 2.25.325.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Shared\_\xzxzxzxzxzxz.exe -> Dropper.VB.lu : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temporary Internet Files\Content.IE5\896ZW9UN\drsmartload46a[1].exe -> Hijacker.VB.fg : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Lokala inställningar\Temporary Internet Files\Content.IE5\896ZW9UN\drsmartload849a[1].exe -> Hijacker.VB.fg : Cleaned with backup (quarantined).
C:\drsmartload46a7i.exe -> Hijacker.VB.fg : Cleaned with backup (quarantined).
C:\drsmartload849a7i.exe -> Hijacker.VB.fg : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Skrivbord\WinAntiVirusPro2006FreeInstall_se.exe -> Not-A-Virus.Downloader.Win32.WinFixer.f : Cleaned with backup (quarantined).
C:\Program\Network Monitor\netmon.exe -> Not-A-Virus.Monitor.Win32.NetMon.a : Cleaned with backup (quarantined).
:mozilla.181:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.247realmedia : Cleaned with backup (quarantined).
:mozilla.93:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.247realmedia : Cleaned with backup (quarantined).
:mozilla.106:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.113:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.114:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.115:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.116:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.148:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.182:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.183:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.184:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.69:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Cookies\jenny@msninvite.112.2o7[1].txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Cookies\jenny@msnportal.112.2o7[1].txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.156:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Adjuggler : Cleaned with backup (quarantined).
:mozilla.57:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Adjuggler : Cleaned with backup (quarantined).
:mozilla.58:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Adjuggler : Cleaned with backup (quarantined).
:mozilla.59:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Adjuggler : Cleaned with backup (quarantined).
:mozilla.115:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Adrevolver : Cleaned with backup (quarantined).
:mozilla.116:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Adrevolver : Cleaned with backup (quarantined).
:mozilla.117:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Adrevolver : Cleaned with backup (quarantined).
:mozilla.118:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Adrevolver : Cleaned with backup (quarantined).
:mozilla.119:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Adrevolver : Cleaned with backup (quarantined).
:mozilla.120:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Adrevolver : Cleaned with backup (quarantined).
:mozilla.113:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Adserver : Cleaned with backup (quarantined).
:mozilla.114:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Adserver : Cleaned with backup (quarantined).
:mozilla.117:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Adtech : Cleaned with backup (quarantined).
:mozilla.118:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Adtech : Cleaned with backup (quarantined).
:mozilla.199:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Adtech : Cleaned with backup (quarantined).
:mozilla.200:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.tx
"Although extraordinary valor was displayed by the entire corps of Spartans and Thespaians, yet bravest of all was declared the Spartan Dienekes. It is said that on the eve of battle, he was told by a native of Trachis that the Persian archers were so numerous that, when they fired their volleys, the mass of arrows blocked out the sun. Dienekes, however, quite undaunted by this prospect, remarked with a laugh, "Good. Then we'll have our battle in the shade."" - Herodotus, The Histories.  (If you're interested in the battle of Thermopylae, read "Gates of Fire" by Steven Pressfield)
Offline tim
Re: Had enough yesterday
« Reply #28 on: July 31, 2006, 12:22:59 AM »
:mozilla.30:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Adtech : Cleaned with backup (quarantined).
:mozilla.31:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Adtech : Cleaned with backup (quarantined).
:mozilla.8:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Adtech : Cleaned with backup (quarantined).
:mozilla.9:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Adtech : Cleaned with backup (quarantined).
:mozilla.109:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.110:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.111:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.112:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.11:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.13:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.14:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.17:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.32:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.33:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.34:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.35:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.36:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.37:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.38:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.39:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.40:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.40:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.41:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.41:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.42:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Advertising : Cleaned with backup (quarantined).
:mozilla.28:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Atdmt : Cleaned with backup (quarantined).
:mozilla.48:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Atdmt : Cleaned with backup (quarantined).
:mozilla.50:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Atdmt : Cleaned with backup (quarantined).
:mozilla.63:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Atdmt : Cleaned with backup (quarantined).
:mozilla.9:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Atdmt : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Cookies\erik@atdmt[1].txt -> TrackingCookie.Atdmt : Cleaned with backup (quarantined).
:mozilla.409:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Bfast : Cleaned with backup (quarantined).
:mozilla.140:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Burstnet : Cleaned with backup (quarantined).
:mozilla.142:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Burstnet : Cleaned with backup (quarantined).
:mozilla.426:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Burstnet : Cleaned with backup (quarantined).
:mozilla.427:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Burstnet : Cleaned with backup (quarantined).
:mozilla.164:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.165:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.166:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.167:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.168:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.169:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.52:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.53:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.54:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.55:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.56:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.57:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.63:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.64:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.65:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.73:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.74:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.76:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.77:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.78:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.79:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.87:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.88:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.89:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.90:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.282:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Clickbank : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Cookies\jenny@ad1.clickhype[1].txt -> TrackingCookie.Clickhype : Cleaned with backup (quarantined).
:mozilla.226:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Com : Cleaned with backup (quarantined).
:mozilla.43:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Cpvfeed : Cleaned with backup (quarantined).
:mozilla.261:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Cqcounter : Cleaned with backup (quarantined).
:mozilla.328:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Cqcounter : Cleaned with backup (quarantined).
:mozilla.10:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Doubleclick : Cleaned with backup (quarantined).
:mozilla.119:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Doubleclick : Cleaned with backup (quarantined).
:mozilla.43:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Doubleclick : Cleaned with backup (quarantined).
:mozilla.75:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Doubleclick : Cleaned with backup (quarantined).
:mozilla.7:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Doubleclick : Cleaned with backup (quarantined).
:mozilla.452:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Esomniture : Cleaned with backup (quarantined).
:mozilla.424:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Estat : Cleaned with backup (quarantined).
:mozilla.124:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Euroclick : Cleaned with backup (quarantined).
:mozilla.222:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Euroclick : Cleaned with backup (quarantined).
:mozilla.371:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Euroclick : Cleaned with backup (quarantined).
:mozilla.12:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.15:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.16:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.180:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.181:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.182:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.183:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.189:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.21:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.315:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.316:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.317:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.318:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.195:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Fastclick : Cleaned with backup (quarantined).
:mozilla.196:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Fastclick : Cleaned with backup (quarantined).
:mozilla.218:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Fastclick : Cleaned with backup (quarantined).
:mozilla.59:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Fastclick : Cleaned with backup (quarantined).
:mozilla.60:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Fastclick : Cleaned with backup (quarantined).
:mozilla.61:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Fastclick : Cleaned with backup (quarantined).
:mozilla.62:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Fastclick : Cleaned with backup (quarantined).
:mozilla.63:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Fastclick : Cleaned with backup (quarantined).
:mozilla.64:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Fastclick : Cleaned with backup (quarantined).
:mozilla.86:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Fastclick : Cleaned with backup (quarantined).
:mozilla.255:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Googleadservices : Cleaned with backup (quarantined).
:mozilla.256:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Googleadservices : Cleaned with backup (quarantined).
:mozilla.324:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Googleadservices : Cleaned with backup (quarantined).
:mozilla.137:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.138:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.139:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.255:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.257:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.273:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.274:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.275:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.386:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.489:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.70:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.73:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Hitbox : Cleaned with backup (quarantined).
:mozilla.132:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Hotlog : Cleaned with backup (quarantined).
:mozilla.260:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Ivwbox : Cleaned with backup (quarantined).
:mozilla.399:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Linksynergy : Cleaned with backup (quarantined).
:mozilla.400:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Linksynergy : Cleaned with backup (quarantined).
:mozilla.233:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Liveperson : Cleaned with backup (quarantined).
:mozilla.234:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Liveperson : Cleaned with backup (quarantined).
:mozilla.235:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Liveperson : Cleaned with backup (quarantined).
:mozilla.492:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Liveperson : Cleaned with backup (quarantined).
:mozilla.493:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Liveperson : Cleaned with backup (quarantined).
:mozilla.494:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Liveperson : Cleaned with backup (quarantined).
:mozilla.335:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Mediaplex : Cleaned with backup (quarantined).
:mozilla.40:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Mediaplex : Cleaned with backup (quarantined).
:mozilla.41:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Mediaplex : Cleaned with backup (quarantined).
:mozilla.45:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Mediaplex : Cleaned with backup (quarantined).
:mozilla.47:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Mediaplex : Cleaned with backup (quarantined).
:mozilla.50:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Mediaplex : Cleaned with backup (quarantined).
:mozilla.76:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Myaffiliateprogram : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Cookies\jenny@need2find[1].txt -> TrackingCookie.Need2find : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Cookies\lena@need2find[1].txt -> TrackingCookie.Need2find : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Cookies\nina@need2find[2].txt -> TrackingCookie.Need2find : Cleaned with backup (quarantined).
:mozilla.303:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Overture : Cleaned with backup (quarantined).
:mozilla.304:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Overture : Cleaned with backup (quarantined).
:mozilla.37:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Overture : Cleaned with backup (quarantined).
:mozilla.64:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Paycounter : Cleaned with backup (quarantined).
:mozilla.231:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Questionmarket : Cleaned with backup (quarantined).
:mozilla.232:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Questionmarket : Cleaned with backup (quarantined).
:mozilla.434:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Questionmarket : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Cookies\jenny@ads.realcastmedia[1].txt -> TrackingCookie.Realcastmedia : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Cookies\jenny@stats1.reliablestats[2].txt -> TrackingCookie.Reliablestats : Cleaned with backup (quarantined).
:mozilla.170:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Revenue : Cleaned with backup (quarantined).
:mozilla.313:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Revenue : Cleaned with backup (quarantined).
:mozilla.144:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Serving-sys : Cleaned with backup (quarantined).
:mozilla.145:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Serving-sys : Cleaned with backup (quarantined).
:mozilla.146:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Serving-sys : Cleaned with backup (quarantined).
:mozilla.147:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Serving-sys : Cleaned with backup (quarantined).
:mozilla.34:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexcounter : Cleaned with backup (quarantined).
:mozilla.35:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexcounter : Cleaned with backup (quarantined).
:mozilla.12:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.14:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.15:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.16:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.17:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.18:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.19:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.20:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.21:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.22:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.23:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.24:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.25:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sexlist : Cleaned with backup (quarantined).
:mozilla.29:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sextracker : Cleaned with backup (quarantined).
:mozilla.30:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Sextracker : Cleaned with backup (quarantined).
:mozilla.223:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Smartadserver : Cleaned with backup (quarantined).
:mozilla.226:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Smartadserver : Cleaned with backup (quarantined).
:mozilla.227:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Smartadserver : Cleaned with backup (quarantined).
:mozilla.67:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Smartadserver : Cleaned with backup (quarantined).
:mozilla.72:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Smartadserver : Cleaned with backup (quarantined).
:mozilla.75:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Smartadserver : Cleaned with backup (quarantined).
:mozilla.117:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.138:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.139:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.140:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.140:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.141:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.141:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.142:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.143:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.149:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.269:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.270:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.271:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Statcounter : Cleaned with backup (quarantined).
:mozilla.139:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Tacoda : Cleaned with backup (quarantined).
:mozilla.141:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Tacoda : Cleaned with backup (quarantined).
:mozilla.420:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Tacoda : Cleaned with backup (quarantined).
:mozilla.421:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Tacoda : Cleaned with backup (quarantined).
:mozilla.294:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Targetnet : Cleaned with backup (quarantined).
:mozilla.15:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.16:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.19:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.20:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.21:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.21:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.22:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.22:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.22:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.23:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.23:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.24:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.25:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.26:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.29:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.32:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.33:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.34:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.38:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.39:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.40:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.41:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.41:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.42:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.42:C:\Documents and Settings\Nina\Application Data\Mozilla\Firefox\Profiles\d9i48kz6.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Cookies\erik@tradedoubler[1].txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.108:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Trafficmp : Cleaned with backup (quarantined).
:mozilla.109:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Trafficmp : Cleaned with backup (quarantined).
:mozilla.110:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Trafficmp : Cleaned with backup (quarantined).
:mozilla.111:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Trafficmp : Cleaned with backup (quarantined).
:mozilla.112:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Trafficmp : Cleaned with backup (quarantined).
:mozilla.454:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Trafficmp : Cleaned with backup (quarantined).
:mozilla.455:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Trafficmp : Cleaned with backup (quarantined).
:mozilla.193:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Tribalfusion : Cleaned with backup (quarantined).
:mozilla.27:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Tribalfusion : Cleaned with backup (quarantined).
:mozilla.58:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Tribalfusion : Cleaned with backup (quarantined).
:mozilla.74:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Tribalfusion : Cleaned with backup (quarantined).
:mozilla.7:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Tribalfusion : Cleaned with backup (quarantined).
:mozilla.163:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Valueclick : Cleaned with backup (quarantined).
:mozilla.249:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Valueclick : Cleaned with backup (quarantined).
:mozilla.360:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Valueclick : Cleaned with backup (quarantined).
:mozilla.71:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Valueclick : Cleaned with backup (quarantined).
:mozilla.95:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Valueclick : Cleaned with backup (quarantined).
:mozilla.192:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Weborama : Cleaned with backup (quarantined).
:mozilla.382:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Weborama : Cleaned with backup (quarantined).
:mozilla.383:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Weborama : Cleaned with backup (quarantined).
:mozilla.112:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Webtrendslive : Cleaned with backup (quarantined).
:mozilla.12:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Webtrendslive : Cleaned with backup (quarantined).
:mozilla.204:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Webtrendslive : Cleaned with backup (quarantined).
:mozilla.236:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Webtrendslive : Cleaned with backup (quarantined).
:mozilla.288:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Webtrendslive : Cleaned with backup (quarantined).
:mozilla.50:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Webtrendslive : Cleaned with backup (quarantined).
:mozilla.123:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.125:C:\Documents and Settings\Lena\Application Data\Mozilla\Firefox\Profiles\hgvap44u.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.14:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.17:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.18:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.196:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.19:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.20:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.21:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.248:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.249:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.250:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.25:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.26:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.27:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.30:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.31:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.32:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.33:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.34:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
C:\Documents and Settings\Erik\Cookies\erik@ad.yieldmanager[1].txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Cookies\jenny@ad.yieldmanager[1].txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Cookies\jenny@ad.yieldmanager[2].txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
C:\Documents and Settings\Jenny\Cookies\jenny@yieldmanager[2].txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Cookies\lena@ad.yieldmanager[1].txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
C:\Documents and Settings\Lena\Cookies\lena@yieldmanager[1].txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
C:\Documents and Settings\Nina\Cookies\nina@ad.yieldmanager[1].txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
C:\Documents and Settings\Tim\Cookies\tim@ad.yieldmanager[2].txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.172:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
:mozilla.173:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\775fxpou.Standardanvändare\cookies.txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
:mozilla.191:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
:mozilla.192:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
:mozilla.194:C:\Documents and Settings\Jenny\Application Data\Mozilla\Firefox\Profiles\aifiqiwc.default\cookies.txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
:mozilla.58:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
:mozilla.59:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
:mozilla.60:C:\Documents and Settings\Tim\Application Data\Mozilla\Firefox\Profiles\xpce5dqg.default\cookies.txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
:mozilla.89:C:\Documents and Settings\Erik\Application Data\Mozilla\Firefox\Profiles\tatu7mlo.default\cookies.txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
::Report end
Offline tim
« Reply #29 on: July 31, 2006, 12:24:46 AM »
here's the aaw-scan (normal mode), started after the ewido scan in safe mode.
Ad-Aware SE Build 1.06r1
Logfile Created on:den 31 juli 2006 02:37:59
Created with Ad-Aware SE Personal, free for private use.
Using definitions file:SE1R116 24.07.2006
References detected during the scan:
Adware.Look2Me(TAC index:7):4 total references
AltnetBDE(TAC index:4):1 total references
CmdServices(TAC index:4):33 total references
iSearch Toolbar(TAC index:4):1 total references
MRU List(TAC index:0):8 total references
Other(TAC index:5):2 total references
Possible Browser Hijack attempt(TAC index:3):6 total references
Targetsaver(TAC index:8):3 total references
Tracking Cookie(TAC index:3):3 total references
win32.Trojan.Dnschanger(TAC index:10):2 total references
VX2(TAC index:10):7 total references
Ad-Aware SE Settings
Set : Search for negligible risk entries
Set : Safe mode (always request confirmation)
Set : Scan active processes
Set : Scan registry
Set : Deep-scan registry
Set : Scan my IE Favorites for banned URLs
Set : Scan my Hosts file
Extended Ad-Aware SE Settings
Set : Unload recognized processes & modules during scan
Set : Scan registry for all users instead of current user only
Set : Always try to unload modules before deletion
Set : During removal, unload Explorer and IE if necessary
Set : Let Windows remove files in use at next reboot
Set : Delete quarantined objects after restoring
Set : Include basic Ad-Aware settings in log file
Set : Include additional Ad-Aware settings in log file
Set : Include reference summary in log file
Set : Include alternate data stream details in log file
Set : Play sound at scan completion if scan locates critical objects
2006-07-31 02:37:59 - Scan started. (Full System Scan)
Listing running processes
#:1 [smss.exe]
    FilePath           : \SystemRoot\System32\
    ProcessID          : 428
    ThreadCreationTime : 2006-07-31 00:34:01
    BasePriority       : Normal
#:2 [winlogon.exe]
    FilePath           : \??\C:\WINDOWS\system32\
    ProcessID          : 508
    ThreadCreationTime : 2006-07-31 00:34:03
    BasePriority       : High
 Adware.Look2Me Object Recognized!
    Type               : Process
    Data               : dnj2011oe.dll
    TAC Rating         : 7
    Category           : Adware
    Comment            : iieshare.dll.dmp
    Object             : C:\WINDOWS\system32\
Warning! Adware.Look2Me Object found in memory(C:\WINDOWS\system32\dnj2011oe.dll)
#:3 [services.exe]
    FilePath           : C:\WINDOWS\system32\
    ProcessID          : 556
    FileVersion        : 5.1.2600.0 (xpclient.010817-1148)
    ProductVersion     : 5.1.2600.0
    ProductName        : Operativsystemet Microsoft® Windows®
    CompanyName        : Microsoft Corporation
    FileDescription    : Tjänst- och styrenhetsprogram
    InternalName       : services.exe
    LegalCopyright     : © Microsoft Corporation. Med ensamrätt.
    OriginalFilename   : services.exe
#:4 [lsass.exe]
    ProcessID          : 568
    FileVersion        : 5.1.2600.1106 (xpsp1.020828-1920)
    ProductVersion     : 5.1.2600.1106
    ProductName        : Microsoft® Windows® Operating System
    FileDescription    : LSA Shell (Export Version)
    InternalName       : lsass.exe
    LegalCopyright     : © Microsoft Corporation. All rights reserved.
    OriginalFilename   : lsass.exe
#:5 [ati2evxx.exe]
    FilePath           : C:\WINDOWS\System32\
    ProcessID          : 708
    ThreadCreationTime : 2006-07-31 00:34:04
#:6 [svchost.exe]
    ProcessID          : 720
    FileDescription    : Generic Host Process for Win32 Services
    InternalName       : svchost.exe
    OriginalFilename   : svchost.exe
#:7 [svchost.exe]
    ProcessID          : 888
    ThreadCreationTime : 2006-07-31 00:35:26
#:8 [svchost.exe]
    ProcessID          : 928
#:9 [lexbces.exe]
    ProcessID          : 1100
    ThreadCreationTime : 2006-07-31 00:35:28
    FileVersion        : 7.4
    ProductVersion     : 7.4
    ProductName        : MarkVision for Windows (32 bit)
    CompanyName        : Lexmark International, Inc.
    FileDescription    : LexBce Service
    InternalName       : LexBce Service
    LegalCopyright     : (C) 1993 - 2002 Lexmark International, Inc.
    OriginalFilename   : LexBceS.exe
#:10 [spoolsv.exe]
    ProcessID          : 1116
    FileVersion        : 5.1.2600.0 (XPClient.010817-1148)
    FileDescription    : Spooler SubSystem App
    InternalName       : spoolsv.exe
    OriginalFilename   : spoolsv.exe
#:11 [ccsetmgr.exe]
    FilePath           : C:\Program\Delade filer\Symantec Shared\
    ProcessID          : 1232
    FileVersion        : 103.0.7.2
    ProductVersion     : 103.0.7.2
    ProductName        : Client and Host Security Platform
    CompanyName        : Symantec Corporation
    FileDescription    : Symantec Settings Manager Service
    InternalName       : ccSetMgr
    LegalCopyright     : Copyright (c) 2000-2004 Symantec Corporation. All rights reserved.
    OriginalFilename   : ccSetMgr.exe
#:12 [lexpps.exe]
    ProcessID          : 1244
    FileVersion        : 7.4
    FileDescription    : LEXPPS.EXE
    InternalName       : LEXPPS
    OriginalFilename   : LEXPPS.EXE
    Comments           : MarkVision for Windows '95 New P2P Server  (32-bit)
#:13 [ctsvccda.exe]
    ProcessID          : 1256
    FileVersion        : 1.0.1.0
    ProductVersion     : 1.0.0.0
    ProductName        : Creative Service for CDROM Access
    CompanyName        : Creative Technology Ltd
    FileDescription    : Creative Service for CDROM Access
    InternalName       : CTsvcCDAEXE
    LegalCopyright     : Copyright (c) Creative Technology Ltd., 1999. All rights reserved.
    OriginalFilename   : CTsvcCDA.EXE
#:14 [mdm.exe]
    FilePath           : C:\Program\Delade filer\Microsoft Shared\VS7Debug\
    ProcessID          : 1292
    FileVersion        : 7.00.9064.9150
    ProductVersion     : 7.00.9064.9150
    ProductName        : Microsoft Development Environment
    FileDescription    : Machine Debug Manager
    InternalName       : mdm.exe
    LegalCopyright     : Copyright (C) Microsoft Corp. 1997-2000
    OriginalFilename   : mdm.exe
#:15 [navapsvc.exe]
    FilePath           : C:\Program\Norton AntiVirus\
    ProcessID          : 1328
    FileVersion        : 11.0.16.2
    ProductVersion     : 11.0.16
    ProductName        : Norton AntiVirus
    FileDescription    : Norton AntiVirus Auto-Protect Service
    InternalName       : NAVAPSVC
    LegalCopyright     : Norton AntiVirus 2005 for Windows 98/ME/2000/XP Copyright © 2004 Symantec Corporation. All rights reserved.
    OriginalFilename   : NAVAPSVC.EXE
#:16 [npfmntor.exe]
    FilePath           : C:\Program\Norton AntiVirus\IWP\
    ProcessID          : 1360
    ThreadCreationTime : 2006-07-31 00:35:29
    FileDescription    : Norton AntiVirus Firewall Install Monitor
    InternalName       : NPFMonitor
    OriginalFilename   : NPFMonitor.EXE
#:17 [sndsrvc.exe]
    ProcessID          : 1520
    FileVersion        : 5.5.1.6
    ProductVersion     : 5.5
    ProductName        : Symantec Security Drivers
    FileDescription    : Network Driver Service
    InternalName       : SndSrvc
    LegalCopyright     : Copyright 2002, 2003, 2004 Symantec Corporation
    OriginalFilename   : SndSrvc.exe
#:18 [spbbcsvc.exe]
    FilePath           : C:\Program\Delade filer\Symantec Shared\SPBBC\
    ProcessID          : 1544
    ThreadCreationTime : 2006-07-31 00:35:30
    FileVersion        : 1,0,1,47
    ProductVersion     : 1,0,1,47
    ProductName        : SPBBC
    FileDescription    : SPBBC Service
    InternalName       : SPBBCSvc
    LegalCopyright     : Copyright (c) 2004 Symantec Corporation. All rights reserved.
    OriginalFilename   : SPBBCSvc.exe
#:19 [svchost.exe]
    ProcessID          : 1572
#:20 [symlcsvc.exe]
    FilePath           : C:\Program\Delade filer\Symantec Shared\CCPD-LC\
    ProcessID          : 1584
    FileVersion        : 1, 8, 54, 419
    ProductVersion     : 1, 8, 54, 419
    ProductName        : Symantec Core Component
    FileDescription    : Symantec Core Component
    InternalName       : symlcsvc
    LegalCopyright     : Copyright (C) 2003
    OriginalFilename   : symlcsvc.exe
#:21 [ccevtmgr.exe]
    ProcessID          : 1752
    ThreadCreationTime : 2006-07-31 00:35:32
    FileDescription    : Symantec Event Manager Service
    InternalName       : ccEvtMgr
    OriginalFilename   : ccEvtMgr.exe
#:22 [rundll32.exe]
    ProcessID          : 408
    ThreadCreationTime : 2006-07-31 00:35:39
    FileDescription    : Kör en DLL-fil som ett program
    InternalName       : rundll
    OriginalFilename   : RUNDLL.EXE
    Type               : Process
    Data               : kgdir.dll
    TAC Rating         : 7
    Category           : Adware
Warning! Adware.Look2Me Object found in memory(C:\WINDOWS\system32\kgdir.dll)
#:23 [explorer.exe]
    ProcessID          : 856
    ThreadCreationTime : 2006-07-31 00:35:42
    FileVersion        : 6.00.2800.1106 (xpsp1.020828-1920)
    ProductVersion     : 6.00.2800.1106
    FileDescription    : Utforskaren
    InternalName       : explorer
    OriginalFilename   : EXPLORER.EXE
    Type               : Process
    Data               : kgdir.dll
    TAC Rating         : 7
    Category           : Adware
#:24 [directcd.exe]
    FilePath           : C:\Program\Roxio\Easy CD Creator 5\DirectCD\
    ProcessID          : 2112
    ThreadCreationTime : 2006-07-31 00:35:50
    FileVersion        : 5.3.2.34
    ProductVersion     : 5.3.2.34
    ProductName        : DirectCD
    CompanyName        : Roxio
    FileDescription    : DirectCD Application
    InternalName       : DirectCD
    LegalCopyright     : Copyright (c) 2001,2002, Roxio, Inc.
    OriginalFilename   : Directcd.exe
#:25 [point32.exe]
    FilePath           : C:\Program\Microsoft IntelliPoint\
    ProcessID          : 2172
    ThreadCreationTime : 2006-07-31 00:35:54
#:26 [bcmsmmsg.exe]
    ProcessID          : 2180
    ThreadCreationTime : 2006-07-31 00:35:55
    FileVersion        :  3.5.24 02/24/2003 18:29:41
    ProductVersion     :  3.5.24 02/24/2003 18:29:41
    ProductName        : BCM Modem Messaging Applet
    CompanyName        : Broadcom Corporation
    FileDescription    : Modem Messaging Applet
    InternalName       : smdmstat.exe
    LegalCopyright     : Copyright © Broadcom Corporation 1998-2000
    OriginalFilename   : smdmstat.exe
#:27 [ccapp.exe]
    ProcessID          : 2196
    FileDescription    : Symantec User Session
    InternalName       : ccApp
    OriginalFilename   : ccApp.exe
#:28 [diagent.exe]
    FilePath           : C:\Program\Creative\SBLive\Diagnostics\
    ProcessID          : 2228
    ThreadCreationTime : 2006-07-31 00:35:59
    FileVersion        : 1, 1, 4, 0
    ProductVersion     : 1.01.04
    ProductName        : Creative Diagnostics Agent
    FileDescription    : Creative Diagnostics Agent
    InternalName       : Creative Diagnostics Agent
    LegalCopyright     : Copyright (C) 2002 Creative Technology Ltd
    OriginalFilename   : diagent.exe
#:29 [ituneshelper.exe]
    FilePath           : C:\Program\iTunes\
    ProcessID          : 2236
    FileVersion        : 4.7.1.30
    ProductVersion     : 4.7.1.30
    ProductName        : iTunes
    CompanyName        : Apple Computer, Inc.
    FileDescription    : iTunesHelper Module
    InternalName       : iTunesHelper
    LegalCopyright     : © 2003-2004 Apple Computer, Inc. All Rights Reserved.
    OriginalFilename   : iTunesHelper.exe
#:30 [ipodservice.exe]
    FilePath           : C:\Program\iPod\bin\
    ProcessID          : 2300
    ThreadCreationTime : 2006-07-31 00:36:07
    FileDescription    : iPodService Module
    InternalName       : iPodService
    OriginalFilename   : iPodService.exe
#:31 [tgcmd.exe]
    FilePath           : C:\Program\Telia\Supportassistent\bin\
    ProcessID          : 2412
    ThreadCreationTime : 2006-07-31 00:36:09
    FileVersion        : 5,6,1039,0
    ProductVersion     : 5,6,1039,0
    ProductName        : Support.com Scheduler and Command Dispatcher
    CompanyName        : SupportSoft, Inc.
    FileDescription    : Support.com Scheduler and Command Dispatcher
    InternalName       : TGCMD
    LegalCopyright     : Copyright 1997-2069 SupportSoft
    OriginalFilename   : TGCMD.EXE
#:32 [sweetim.exe]
    FilePath           : C:\Program\Macrogaming\SweetIM\
    ProcessID          : 2424
    ThreadCreationTime : 2006-07-31 00:36:10
    FileVersion        : 1, 1, 0, 151
    ProductVersion     : 1.1.0.151
    ProductName        : MacroGaming SweetIM
    CompanyName        : MacroGaming LTD.
    FileDescription    : SweetIM MSN Messenger Enhancer
    InternalName       : SweetIM
    LegalCopyright     : Copyright © 2005
    OriginalFilename   : SweetIM.exe
#:33 [application launcher.exe]
    FilePath           : C:\Program\Sony Ericsson\Mobile2\Application Launcher\
    ProcessID          : 2472
    ThreadCreationTime : 2006-07-31 00:36:11
    FileVersion        : 1.1.1.3
    ProductVersion     : 1.1.1.3
    ProductName        : Application Launcher
    CompanyName        : Sony Ericsson Mobile Communications AB
    FileDescription    : Application Launcher
    InternalName       : Application Launcher
    LegalCopyright     : Copyright (c) 2005 Popwire AB. All rights reserved.
    OriginalFilename   : Application Launcher.exe
#:34 [dfndrfg_7.exe]
    FilePath           : C:\
    ProcessID          : 2492
    ThreadCreationTime : 2006-07-31 00:36:12
    FileVersion        : 1.00.0164
    ProductVersion     : 1.00.0164
    ProductName        : Project1
    CompanyName        : &%&%&%&%%&%&%%&%
    InternalName       : dfndrfg_7
    OriginalFilename   : dfndrfg_7.exe
#:35 [kybrdfg_7.exe]
    FilePath           : C:\
    ProcessID          : 2500
    ThreadCreationTime : 2006-07-31 00:36:13
    FileVersion        : 1.00.0116
    ProductVersion     : 1.00.0116
    CompanyName        : #$*&$*&#&$&*$&#&*$&*#$&*
    InternalName       : kybrdfg_7
    OriginalFilename   : kybrdfg_7.exe
#:36 [nwnmfg_7.exe]
    FilePath           : C:\
    ProcessID          : 2516
    FileVersion        : 1.00.0347
    ProductVersion     : 1.00.0347
    CompanyName        : &#&*&$*#&*$&*#&$*&*&$*&#*&#*
    InternalName       : nwnmfg_7
    OriginalFilename   : nwnmfg_7.exe
#:37 [ctfmon.exe]
    ProcessID          : 2540
    ThreadCreationTime : 2006-07-31 00:36:14
    FileDescription    : CTF Loader
    InternalName       : CTFMON
    OriginalFilename   : CTFMON.EXE
#:38 [logitechdesktopmessenger.exe]
    FilePath           : C:\Program\Logitech\Desktop Messenger\8876480\Program\
    ProcessID          : 2556
    ThreadCreationTime : 2006-07-31 00:36:15
    FileVersion        : 2.30.04
    ProductVersion     : 2.30.04
    ProductName        : Logitech Desktop Messenger
    CompanyName        : Logitech
    FileDescription    : Logitech Desktop Messenger
    InternalName       : SyncExt
    LegalCopyright     : Copyright (C) Logitech 2000-2005. All rights reserved
    OriginalFilename   : SyncExt.dll
    Comments           : About:
 www.logitech.com/ldm
Privacy Policy:
 http://privacy.logitech.com
#:39 [capabilitymanager.exe]
    FilePath           : C:\Program\Delade filer\Teleca Shared\
    ProcessID          : 2656
    ThreadCreationTime : 2006-07-31 00:36:19
    FileVersion        : 0.0.1.48
    ProductVersion     : 0.0.1.48
    ProductName        : CapabilityManager
    CompanyName        : Teleca Software Solutions AB
    FileDescription    : Capability Manager
    InternalName       : CapabilityManager.exe
    LegalCopyright     : Copyright © 2004 Teleca Software Solutions AB. All rights reserved.
    OriginalFilename   : CapabilityManager.exe
    Comments           : This is a generic version of this component
#:40 [wuauclt.exe]
    ProcessID          : 2664
    FileVersion        : 5.4.3790.2182 built by: srv03_rtm(ntvbl04)
    ProductVersion     : 5.4.3790.2182
    FileDescription    : Automatiska uppdateringar
    InternalName       : wuauclt.exe
    OriginalFilename   : wuauclt.exe
#:41 [setpoint.exe]
    FilePath           : C:\Program\Logitech\SetPoint\
    ProcessID          : 2824
    ThreadCreationTime : 2006-07-31 00:36:30
    FileVersion        : 2.30.399
    ProductVersion     : 2.30.399
    ProductName        : Logitech SetPoint
    CompanyName        : Logitech Inc.
    FileDescription    : Logitech SetPoint Event Manager
    InternalName       : SetPoint
    LegalCopyright     : (C) 1998-2005 Logitech. All rights reserved.
    LegalTrademarks    : Logitech® and SetPoint® are registered trademarks of Logitech Inc.
    OriginalFilename   : SetPoint.exe
    Comments           : Created by the Productivity Software team
#:42 [msnmsgr.exe]
    FilePath           : C:\Program\MSN Messenger\
    ProcessID          : 2856
    ThreadCreationTime : 2006-07-31 00:36:34
    FileVersion        : 7.5.0324
    ProductVersion     : 7.5.0324
    ProductName        : MSN Messenger
    FileDescription    : MSN Messenger
    InternalName       : msnmsgr
    LegalCopyright     : Copyright (c) Microsoft Corporation 1997-2004
    LegalTrademarks    : Microsoft(R) is a registered trademark of Microsoft Corporation in the U.S. and/or other countries.
    OriginalFilename   : msnmsgr.exe
#:43 [khalmnpr.exe]
    FilePath           : C:\Program\Delade filer\Logitech\KHAL\
    ProcessID          : 2956
    ThreadCreationTime : 2006-07-31 00:36:49
    FileVersion        : 2.30.314
    ProductVersion     : 2.30.314
    ProductName        : Productivity Software Common Files
    FileDescription    : Logitech KHAL Main Process
    InternalName       : KHAL
    OriginalFilename   : KHALMNPR.EXE
#:44 [ad-aware.exe]
    FilePath           : C:\Program\Lavasoft\Ad-Aware SE Personal\
    ProcessID          : 3208
    ThreadCreationTime : 2006-07-31 00:37:01
    FileVersion        : 6.2.0.236
    ProductVersion     : SE 106
    ProductName        : Lavasoft Ad-Aware SE
    CompanyName        : Lavasoft Sweden
    FileDescription    : Ad-Aware SE Core application
    InternalName       : Ad-Aware.exe
    LegalCopyright     : Copyright © Lavasoft AB Sweden
    OriginalFilename   : Ad-Aware.exe
    Comments           : All Rights Reserved
#:45 [msmsgs.exe]
    FilePath           : C:\Program\Messenger\
    ProcessID          : 3280
    ThreadCreationTime : 2006-07-31 00:37:13
    FileVersion        : 4.7.3001
    ProductVersion     : Version 4.7.3001
    ProductName        : Messenger
    FileDescription    : Windows Messenger
    InternalName       : msmsgs
    LegalCopyright     : Copyright (c) Microsoft Corporation 2004
    OriginalFilename   : msmsgs.exe
Memory scan result:
New critical objects: 0
Objects found so far: 11
Started registry scan
 AltnetBDE Object Recognized!
    Type               : Regkey
    Data               :
    TAC Rating         : 4
    Category           : Data Miner
    Comment            :
    Rootkey            : HKEY_LOCAL_MACHINE
    Object             : software\altnet
Registry Scan result:
New critical objects: 1
Objects found so far: 12
Started deep registry scan
Possible Browser Hijack attempt : Software\Microsoft\Internet Explorer\MainSearch Page.findthewebsiteyouneed.com
 Possible Browser Hijack attempt Object Recognized!
    Type               : RegData
    Data               : "http://searchbar.findthewebsiteyouneed.com"
    TAC Rating         : 4
    Comment            : Possible Browser Hijack attempt
    Object             : Software\Microsoft\Internet Explorer\Main
    Value              : Search Page
Possible Browser Hijack attempt : Software\Microsoft\Internet Explorer\SearchSearchAssistant.findthewebsiteyouneed.com
    Type               : RegData
    TAC Rating         : 4
    Object             : Software\Microsoft\Internet Explorer\Search
    Value              : SearchAssistant
Possible Browser Hijack attempt : S-1-5-21-842925246-682003330-702790348-1005\Software\Microsoft\Internet Explorer\MainSearch Page.findthewebsiteyouneed.com
    Type               : RegData
    TAC Rating         : 4
    Rootkey            : HKEY_USERS
    Object             : S-1-5-21-842925246-682003330-702790348-1005\Software\Microsoft\Internet Explorer\Main
    Value              : Search Page
Possible Browser Hijack attempt : S-1-5-21-842925246-682003330-702790348-1005\Software\Microsoft\Internet Explorer\MainStart Page.findthewebsiteyouneed.com
    Type               : RegData
    Data               : "http://www.findthewebsiteyouneed.com"
    TAC Rating         : 4
    Value              : Start Page
Possible Browser Hijack attempt : S-1-5-21-842925246-682003330-702790348-1005\Software\Microsoft\Internet Explorer\MainSearch Bar.findthewebsiteyouneed.com
    Type               : RegData
    TAC Rating         : 4
    Value              : Search Bar
Possible Browser Hijack attempt : S-1-5-21-842925246-682003330-702790348-1005\Software\Microsoft\Internet Explorer\MainDefault_Search_URL.findthewebsiteyouneed.com
    Type               : RegData
    TAC Rating         : 4
    Value              : Default_Search_URL
Deep registry scan result:
New critical objects: 6
Objects found so far: 18
Started Tracking Cookie scan
 Tracking Cookie Object Recognized!
    Type               : IECache Entry
    Data               : erik@tradedoubler[1].txt
    TAC Rating         : 3
    Comment            : Hits:8
    Value              : Cookie:erik@tradedoubler.com/
    Data               : erik@offers.worldadvertisingdirect[1].txt
    TAC Rating         : 3
    Comment            : Hits:5
    Value              : Cookie:erik@offers.worldadvertisingdirect.com/
    Data               : erik@atdmt[1].txt
    TAC Rating         : 3
    Comment            : Hits:1
    Value              : Cookie:erik@atdmt.com/
Tracking cookie scan result:
New critical objects: 3
Objects found so far: 21
Deep scanning and examining files (C:)
 CmdServices Object Recognized!
    Type               : File
    Data               : cmdinst.exe
    TAC Rating         : 4
    Category           : Adware
    Comment            :
    Object             : C:\Documents and Settings\Erik\Lokala inställningar\Temp\
    FileVersion        : 1.0.1
    CompanyName        :
    FileDescription    : Command Desktop Setup
    LegalCopyright     :
    Comments           : This installation was built with Inno Setup: http://www.innosetup.com
 Targetsaver Object Recognized!
    Type               : File
    Data               : tsinstall_4_0_4_0_b4.exe
    TAC Rating         : 8
    Category           : Malware
    Comment            :
    Type               : File
    Data               : installer[1].exe
    TAC Rating         : 4
    Category           : Adware
    Comment            :
    Object             : C:\Documents and Settings\Erik\Lokala inställningar\Temporary Internet Files\Content.IE5\CXUVS5UJ\
    FileVersion        : 1.0.1
    CompanyName        :
    LegalCopyright     :
    Type               : File
    Data               : A0102046.dll
    TAC Rating         : 4
    Category           : Adware
    Comment            :
    Object             : C:\System Volume Information\_restore{CD341A10-079F-4AEC-AC06-18A32F0A0564}\RP134\
 VX2 Object Recognized!
    Type               : File
    Data               : A0102050.dll
    TAC Rating         : 10
    Category           : Malware
    Comment            :
    Type               : File
    Data               : A0102051.dll
    TAC Rating         : 10
    Category           : Malware
    Comment            :
    Type               : File
    Data               : A0102068.dll
    TAC Rating         : 10
    Category           : Malware
    Comment            :
 iSearch Toolbar Object Recognized!
    Type               : File
    Data               : A0102085.dll
    TAC Rating         : 4
    Category           : Malware
    Comment            :
    FileVersion        : 2.1.3.466
    Type               : File
    Data               : A0102088.dll
    TAC Rating         : 10
    Category           : Malware
    Comment            :
    Type               : File
    Data               : A0102099.exe
    TAC Rating         : 8
    Category           : Malware
    Comment            :
    FileVersion        : 4, 0, 4, 0
    ProductVersion     : 4, 0, 4, 0
    LegalCopyright     : Copyright (C) 2005
    Type               : File
    Data               : A0102102.exe
    TAC Rating         : 4
    Category           : Adware
    Comment            :
    Type               : File
    Data               : A0102449.exe
    TAC Rating         : 10
    Category           : Malware
    Comment            :
    Type               : File
    Data               : A0102452.dll
    TAC Rating         : 10
    Category           : Malware
    Comment            :
    Type               : File
    Data               : A0102460.exe
    TAC Rating         : 10
    Category           : Malware
    Comment            :
    Type               : File
    Data               : A0102463.exe
    TAC Rating         : 4
    Category           : Adware
    Comment            :
 win32.Trojan.Dnschanger Object Recognized!
    Type               : File
    Data               : A0102465.exe
    TAC Rating         : 10
    Category           : Monitoring Tool
    Comment            :
    Object  &n
"Although extraordinary valor was displayed by the entire corps of Spartans and Thespaians, yet bravest of all was declared the Spartan Dienekes. It is said that on the eve of battle, he was told by a native of Trachis that the Persian archers were so numerous that, when they fired their volleys, the mass of arrows blocked out the sun. Dienekes, however, quite undaunted by this prospect, remarked with a laugh, "Good. Then we'll have our battle in the shade."" - Herodotus, The Histories.  (If you're interested in the battle of Thermopylae, read "Gates of Fire" by Steven Pressfield)
