Author Topic: Messenger Service  (Read 5134 times)
Offline Kaloho
Messenger Service
« on: October 22, 2005, 10:16:59 PM »
I am getting this annoying popup....I would like for it to stop.  It comes up no matter what I do on the pc.  The pop up blocker usually takes care of it, but it is something that I would like to stop, and figure out what it means and what is causing it to come up.
It says the following...........
Messenger Service
Message from SYSTEM to ALERT on 10/22/2005 6:06:25 PM
STOP!  WINDOWS REQUIRES IMMEDIATE ATTENTION.
Windows has found 47 CRITICAL SYSTEM ERRORS!
To fix the errors please do the following:
1.  Download Registry Repair from: www.fixnow.net
2.  Install Registry Repair
3.  Run Registry Repair
4.  Reboot your computer
FAILURE TO ACT NOW MAY LEAD TO DATA LOSS AND CORRUPTION!
What is this??  Is it some type of spyware or malware or something like that?
btw...this is Skittles here working on Kaloho's pc, before I leave for Sweden.
Offline Kaloho
Re: Messenger Service
« Reply #1 on: October 22, 2005, 10:25:33 PM »
I am actually getting several of these messages up constantly!
This last one says...
Message from System to user (date and time)
Warning:  Your computer may have critical errors in registry and file system.
These errors can lead to computer crashes, instability, slowness, and full system failure.
Immediate repair may be required.
See help file at:  www.spw3.com
To bring up help file, type www.spw3.com into your web browser or press Windows "Start" button, Select Run and type www.spw3.com into box and press ok.
another one says this
Urgen notice from MSOFT
Buffer Overflow in messanger service causes unexpectred computer shutdown, virus infection and remote code execution
Affected Software:
Microsoft Windows NT Workstation
Microsoft Windows NT Server 4.0
Microsoft Windows 2000
Microsoft Windows XP
Microsoft Windows  Win98
Microsoft Windows Server 2003
Non Affected Software"
Microsoft Windows Millennium Edition
Your system IS affected, download the patch from the address below!
www.downloadpatch.net
There is no end to these things.
I KNOW not to do what it is telling me, so no worries there.  But I would like to know how to get rid of this for her.
« Reply #2 on: October 22, 2005, 10:43:05 PM »
I am assuming that this happens only while connected to the internet.  Since your HJT log is being reviewed in another thread (although nothing major jumped out at me, it may to someone else), let's clean out all the temp files because something is causing those popups.
Download CCleaner from the link at the upper right of this page: http://www.filehippo.com/download_ccleaner.html .
Instructions for using CCleaner:
1. Before first use, check under Options > Advanced > UNcheck "Only delete files in Windows Temp folder older than 48 hours".
2. A pop up box will appear advising this process will permanently delete files from your system.
3. To protect logon cookies that you wish to retain, under Options > Cookies.  Select and using the arrow move those cookies to the "Cookies to keep" column.
4. Then select the items you wish to clean up.
In the Windows Tab:
Clean all entries in the "Internet Explorer" section.
Clean all the entries in the "Windows Explorer" section.
Clean all entries in the "System" section.
Clean all entries in the "Advanced" section.
Clean any others that you choose.
In the Applications Tab:
Clean all in the Firefox/Mozilla section if you use it.
Clean all in the Opera section if you use it.
Clean Sun Java in the Internet Section.
5. Click the "Run Cleaner" button and it will scan and clean your system.
6. Click exit.
7. Shutdown/restart the computer.
Offline little eagle
  • Visiting Experts
« Reply #3 on: October 23, 2005, 01:59:58 AM »
Instructions for disabling messenger service here. http://www.microsoft.com/windowsxp/using/security/learnmore/stopspam.mspx
:gwave:
See if that will help.
Offline Skittles
« Reply #4 on: October 23, 2005, 02:31:35 AM »
YESSSSSSSSSSS!! I got it Lil Eagle!!!!  woohoooooooooo
Corrine, I do have CCleaner on her pc already.  Little Eagle and Tate made me get it on her pc the last time!  lol
Altho I probably will need to run it again, to get when we are done with all of the things we will do.
Thanks to both of you!!!!!!!
