Author Topic: May 2022 Windows 10 Version 1809 Non-Security Optional Preview "C" Release  (Read 228 times)
Microsoft released KB5014022 (OS Build 17763.2989), the monthly “C” release preview cumulative updates with non-security improvements and fixes for Windows 10 version 1809.
The improvements include the following:
  • Addresses an issue that might run an AnyCPU application as a 32-bit process.
  • Addresses an issue that affects remote procedure calls (RPC) to the Win32_User or Win32_Group WMI class. The domain member that runs the RPC contacts the primary domain controller (PDC). When multiple RPCs occur simultaneously on many domain members, this might overwhelm the PDC.
  • Addresses an issue that occurs when adding a trusted user, group, or computer that has a one-way trust in place. The error message, “The object selected doesn't match the type of destination source” appears.
  • Addresses a known issue that might cause Windows server computers to log event ID 40 in the System event log whenever you update or refresh a Group Policy on a server or client. The event Description is, ”The event logging service encountered an error when attempting to apply one or more policy settings.”
  • Addresses a memory leak issue that affects Windows systems that are in use 24 hours each day of the week.
  • Addresses an issue that causes print failures when a low integrity level (LowIL) application prints to a null port.
  • Addresses an issue that might cause the Remote Desktop client application to stop working when you end a session.
  • Addresses an issue that might cause camera redirection to fail over Remote Desktop Protocol (RDP) in Remote Desktop (RD), Azure Virtual Desktop (formerly Windows Virtual Desktop) and Microsoft Defender Application Guard scenarios.
  • Addresses an issue that prevents Azure Desired State Configuration (DSC) scenarios that have multiple partial configurations from working as expected.
  • Addresses an issue that fails to display the Application Counters section in the performance reports of the Performance Monitor tool.
  • Addresses an issue that prevents BitLocker from encrypting when you use the silent encryption option.
  • Addresses a reliability issue in the Terminal Services Gateway (TS Gateway) service that randomly causes clients to disconnect.
  • Addresses an issue in which the Cluster Windows Management Instrumentation (WMI) provider (ClustWMI.dll) generates high CPU usage in WMIPRVSE.EXE.
  • Addresses an issue that might cause a system to stop responding when a user signs out if Microsoft OneDrive is in use.
  • Addresses a known issue that might prevent recovery discs (CD or DVD) from starting if you created them using the Backup and Restore (Windows 7) app in Control Panel. This issue occurs after installing Windows updates released January 11, 2022 or later.
Note: You must install the August 10, 2021 SSU (KB5005112) before installing the LCU.
Update:  To get the update, go to Settings > Update & Security > Windows Update.  The link to download and install the update can be found in the Optional updates available area.  To get the standalone package for this update, go to the Microsoft Update Catalog website.
Windows 10 update history
