Author Topic: Windows 11 Insider DEV Channel  (Read 17509 times)
Re: Windows 11 Insider DEV Channel
« Reply #15 on: October 14, 2021, 04:14:43 PM »
Announcing Windows 11 Insider Preview Build 22478 | Windows Insider Blog
Note The build expiration for Dev Channel builds starting with Build 22468 to be 9/15/2022 continues. Previous Dev Channel builds from the RS_PRERELEASE branch will expire on 10/31/2021.
Fixes
[Start]
  • Keyboard focus will no longer get lost if you press ESC after opening the user profile flyout in Start.
  • Updated the prompt text when pinning something from a UWP app to Start, so it now says simply “Do you want to pin this to Start?”.
[Taskbar]
  • Addressed an issue that was causing Notification Center to get stuck in a state in recent builds where it would stop launching.
  • The plus icon for adding a new Desktop will now display properly when hovering over the Task View icon in the Taskbar when using Arabic and Hebrew languages.
  • After bringing up an app’s jump list from the Taskbar, right clicking on the app name should now show the correct icon for Pin to Start (a pin icon).
  • Left and right clicking Taskbar at the same time should no longer crash explorer.exe.
[File Explorer]
  • Fixed an issue where the command bar was doing unnecessary calculations when navigating to folders, causing an unexpected increase in performance. This is also believed to be the root cause of performance issues when using drag to select files, as well as using the arrow keys to navigate in certain folders.
  • The “Show hidden items” option should no longer get out of sync when multiple File Explorer windows are open.
[Widgets]
The following two issues have been addressed with Microsoft Edge version 95, currently live for Microsoft Edge Insiders, and as such we’re removing them from the known issues list:
  • The widgets board may appear empty.
  • Widgets may be displayed in the wrong size on external monitors.
[Search]
  • The recent searches flyout when hovering over the search icon in the Taskbar should no longer immediately dismiss on invocation if an admin window is in focus.
[Input]
  • Setting focus to the search box in File Explorer shouldn’t make the touch keyboard invoke and immediately dismiss now when using a tablet with the Taskbar set to auto-hide.
  • Fixed an issue causing the handwriting panel to not insert text when using it to write Chinese.
  • Mitigated a memory leak that could occur in ctfmon, causing unexpected resource usage over time.
  • Addressed an issue for a small number of users that was causing TextInputHost.exe crashes when setting focus on any text field.
[Settings]
  • Fixed an issue that was causing Settings to crash when radio buttons were updated, for example if you connected an additional audio endpoint while the Sound page in Settings was open.
  • Improved performance of loading the themes displayed in Personalization Settings.
  • If a non-admin user changes their display language in Language Settings, we’ll no longer show the clickable sign-out button there as it was popping a UAC dialog and causing confusion.
  • The Windows Update entry at the top of the System page in Settings should no longer be misaligned with the other options (when shown) in languages like German.
  • The Braille options in Settings for Narrator users should now be in sync with the actual state of the Braille input/output mode.
  • Made a change to help address an issue where “Media streaming options” in the Network and Sharing Center would unexpectedly revert to default settings after an upgrade.
  • Improved Quick Settings launch reliability. This change should also help address the issue causing the window to not fully render (just a thin rectangle).
  • Addressed an issue where if you clicked on the media controls area in Quick Settings, it wasn’t bringing the app displayed to the foreground in certain cases.
  • Fixed an issue where the colors for items in Quick Settings could get stuck and not reflect the proper color for that state, particularly when using a contrast theme.
  • Updated the Quick Settings page for managing audio endpoints from “Volume” to “Sound output”.
  • Opening the page for managing audio endpoints in Quick Settings should no longer cause a brief cut in audio playback when multiple devices are listed.
[Windowing]
  • Mitigated an issue related to using ALT + Tab very quickly that could make explorer.exe crash.
  • Holding down ALT and pressing F4 after pressing ALT + Tab will no longer crash explorer.exe.
  • When using the Arabic or Hebrew display languages, dragging an app window to a different Desktop should show the thumbnail moving in the correct direction now.
[Other]
  • Fixed a casing issue that was causing LP.cab files to be unexpectedly removed in certain cases, which could lead you your display language changing until you added the desired display language back in Settings.
  • Addressed an issue that was causing some users to see a bugcheck with error “KERNEL_SECURITY_CHECK_ERROR”.
  • Mitigated an issue that was causing the SysMain service to use an unexpected amount of power in recent builds.
  • If the display order is missing in BCD settings that should no longer cause an upgrade failure.
  • Fixed an issue that was causing captions to draw at the wrong offset in certain apps.
  • Mitigated an issue that was causing crashes related to audiosrv.dll.
  • If going through OOBE with an Arabic or Hebrew display language, the volume and accessibility buttons should display on the correct side of the screen now.
« Reply #17 on: October 20, 2021, 05:44:03 PM »
Announcing Windows 11 Insider Preview Build 22483
Fixes
[Search]
  • Fixed an issue that was causing Search to appear black and not display any content below the search box.
[Settings]
  • Searching for “display” will now return Display Settings.
[Other]
  • Trying to access the Linux entry for WSL in File Explorer’s navigation pane should no longer pop up an error saying “wsl.localhost is unavailable, insufficient resources exist” on ARM64 PCs.
  • Fixed an issue that was causing cellular data to not work on certain devices in recent Dev Channel builds.
  • Addressed an issue with NTFS when the USN journal was enabled, where it was doing extra unnecessary action with each write, impacting I/O performance.
  • Made some small improvements to keyboard navigation and screen reader usage of Performance Monitor.
  • Webview2 processes should now be properly grouped with the application using it in Task Manager’s Processes tab.
  • Fixed an issue that was causing the Publisher column in Task Manager to not retrieve publisher names.
« Reply #18 on: October 22, 2021, 04:24:15 PM »
From Announcing Windows 11 Insider Preview Build 22483 | Windows Insider Blog
"UPDATE 10/22: We are starting to roll out Cumulative Update Build 22483.1011 (KB5007484). This update does not include anything new and is designed to test our servicing pipeline for builds in the Dev Channel."
« Reply #19 on: October 27, 2021, 04:17:14 PM »
Announcing Windows 11 Insider Preview Build 22489 | Windows Insider Blog
Fixes
[Taskbar]
  • App icons on secondary monitors should draw more reliably now instead of being blank.
  • Stopped an explorer.exe crash that was happening sometimes when using the Desktops flyout context menu.
  • Fixed an explorer.exe crash that was happening sometimes when dismissing the Desktops flyout.
[File Explorer]
  • Pin to Quick Access is a top-level option now when right clicking a drive in File Explorer.
  • We improved context menu launch performance.
  • Made a few fixes to help improve explorer.exe reliability when using File Explorer.
[Windowing]
  • Closing windows in Task View should look less jumpy now.
  • Did some work to help address an issue that was causing flickering in the app window when resizing certain apps in recent Dev Channel builds.
[Settings]
  • Addressed an issue that was causing Settings to crash in certain cases after going to Windows Update.
  • Added a space that was missing in the search results when searching for Touch Keyboard settings.
  • Fixed a Settings crash when trying to customize options in Wheel Settings.
  • If animations are turned off, dismissing a notification using the X will no longer have an animation.
  • Fixed an issue that was causing the media controls to not show up in Quick Settings sometimes when music was playing recently. Also believed to have impacted hardware media key usage.
  • The tooltip for the Wi-Fi option in Quick Settings should no longer fly to the top of the screen.
[Other]
  • Mitigated an underlying issue that was causing the Processes tab in Task Manager to be blank sometimes. This is also believed to be the same root cause causing UAC to open very slowly recently.
  • Addressed an issue Xbox Game Pass games are failing to install with error 0x00000001.
  • Fixed an issue where get-winevent in PowerShell was failing with an InvalidOperationException (Issue #60740).
  • Mitigated a high hitting mousocoreworker.exe crash in the last few flights.
  • Did some work to try and improve the layout of the text in notification buttons in cases where there’s both an icon and text.
  • The Get Started app will no longer crash if the Tips app has been uninstalled.
  • Fixed an issue causing some devices to bugcheck with SYSTEM_SERVICE_EXCPTION when updating on previous builds.
  • Made an underlying change to help fix an issue causing some users to see an unexpected “bad image” error message dialog on boot.
« Reply #20 on: November 03, 2021, 04:40:45 PM »
Announcing Windows 11 Insider Preview Build 22494
Fixes
[Taskbar]
  • Tooltips should no longer appear in random places on the Taskbar after sliding your mouse over volume, battery, network, or other icons in the Taskbar corner.
  • Addressed an underlying issue that was leading to come unexpected duplication of certain icons in the Taskbar corner.
[File Explorer]
  • Addressed an issue that was causing the context menu to crash for some people if you tried to scroll it.
  • Did some work to help address an issue where in certain areas of the screen the context menu submenus would draw on top of the context menu instead of beside it (for example, if you hovered over New).
  • The context menu icons should be less blurry on systems with multiple monitors with mixed DPI now.
  • Addressed an issue that could cause selecting Open With in the context menu to unexpectedly just open the file in certain cases rather than actually opening the Open With dialog.
  • Renaming files on the desktop is back up and running in this flight.
  • Made another adjustment to the command bar underlying logic to help improve performance of command actions in File Explorer.
[Search]
  • Fixed a recent issue that was causing the indexer database to become too fragmented, leading to the indexer unexpectedly consuming a large amount of memory and CPU for a prolonged period of time. This was particularly noticeable for people that have large Outlook mailboxes.
[Input]
  • Mitigated an issue that was causing certain apps to hang when trying to drag something with the Shift or Ctrl key held down.
  • Fixed an issue that was causing the touch keyboard to not appear on tablets when tapping the text field if you were to try to reset your PIN from the login screen.
  • Improved reliability of the Pen menu.
[Windowing]
  • Fixed a few explorer.exe crashes related to using windowing features (snap, ALT + Tab, and Desktops).
  • If you open Task View on a system with multiple monitors, the background should now be acrylic on both monitors.
  • Addressed a couple UI issues with the window thumbnails in Task View and ALT + Tab, notably that the close button might get cut off if the app window was too thin.
[Settings]
  • Addressed an issue where Facial Recognition (Windows Hello) might be unexpectedly greyed out in Sign-in Settings in certain cases until closing and opening Settings.
  • Fixed an issue where Storage Sense wasn’t cleaning up C:\Windows\SystemTemp.
  • Standard users (aka non-admins) should now be able to change the time zone in Settings if Location access is not granted, rather than the dropdown going blank.
[Other]
  • Fixed an issue causing links to Windows Update, Recovery and For developers to show under the main Windows Update Settings page.
  • Fixed a bug where images had a yellow tonality in Adobe Photoshop, Adobe Lightroom and Adobe Lightroom Classic when in HDR mode.
  • Mitigated an issue related to DHCP that was causing unexpected power usage while the screen was off in recent builds for some Insiders.
  • Did some work to help address an issue where Service Host: WinHTTP Web Proxy Auto-Discovery Service would unexpectedly utilize a lot of CPU.
  • Fixed an issue that could cause some devices to have a black screen when coming out of sleep (where the lock screen wouldn’t display).
  • Addressed an underlying issue that was causing some users with ARM64 PCs to experience an increase in Microsoft Teams crashes in the last few Dev Channel builds.
  • We have increased the padding for selected items as seen by clicking Show More Options in the File Explorer context menu, or the menu options in Task Manager.
  • WSL: Fixed error 0x8007010b when accessing Linux distributions via `\\wsl.localhost` or `\\wsl$` (Issue #6995).
« Reply #21 on: November 10, 2021, 04:17:44 PM »
Announcing Windows 11 Insider Preview Build 22499 | Windows Insider Blog.
Also note a new ISO with this build for Windows Insiders is available at msft.it/6017knzR5.
[Input]
  • Clipboard history should be back up and running properly once you’re on this build.
  • Clicking gifs in the emoji panel will now actually insert them into supporting apps, unlike in the previous build.
  • Updated the backend dictionaries for several languages – the touch keyboard’s text suggestions and autocorrect should be more accurate now.
  • If you change your accent color the accents in the emoji panel should follow suit now, instead of getting stuck with the old color.
  • Fixed an IME crash that was happening sometimes for people who had chosen to use the previous version of the Pinyin IME.
  • Mitigated an explorer.exe crash that was happening sometimes recently related to touch keyboard usage.
[Windowing]
  • Made another fix to address an issue where explorer.exe would crash if you pressed ALT + F4 while ALT + Tab was open.
[Settings]
  • Fixed a Settings crash that could happen when trying to check remote sound properties while accessing a PC over Remote Desktop.
[Other]
  • Fixed an issue that was causing some clipping / unexpected zoom when going through OOBE on some ultrawide monitors.
  • The apostrophe in the error message when your fingerprint isn’t recognized on the login screen should display correctly now.
  • When taking a screenshot of a UWP app by pressing the New button in Snipping Tool, Snipping Tool should come into the foreground once the snip is done.
  • Fixed an issue that was causing some Insider PCs to bugcheck when coming out of sleep recently, with an error message saying “SYSTEM_THREAD_EXCEPTION_NOT_HANDLED”.
  • Fixed a deadlock that could happen related to MediaPlaybackCommandManager, resulting in certain apps not being able to play media sometimes.
  • Addressed an issue that was causing reports in Reliability Monitor to unexpectedly be blank with just an empty rectangle when going to see more info.
  • Did some work to help address an issue resulting in certain games having some lag that was only noticeable when the window was in focus. As a reminder if needed, please refer to the following documentation for filing actionable game perf feedback.
NOTE: Some fixes noted here in Insider Preview builds from the active development branch may make their way into the servicing updates for the released version of Windows 11 that became generally available on October 5th.
« Reply #22 on: November 12, 2021, 04:14:06 PM »
UPDATE 11/12: We are starting to roll out Cumulative Update Build 22499.1010 (KB5008400). This update does not include anything new and is designed to test our servicing pipeline for builds in the Dev Channel.
« Reply #23 on: November 17, 2021, 06:15:43 PM »
Announcing Windows 11 Insider Preview Build 22504
Due to the U.S. Thanksgiving holiday, no new builds to the Dev Channel next week.
Fixes:
[Start]
  • Fixed an issue believed to be the root cause of icons not displaying correctly in the Recommended section of Start (showing the wrong or a generic icon) sometimes.
  • If you open Start and immediate press Shift + F10 or the context menu key, the context menu should be aligned with the search box now.
[Taskbar]
  • Fixed an issue leading to an explorer.exe crash in recent builds if there were issues loading the battery icon in the Taskbar.
  • Made some changes to help the clock in the Taskbar update more reliably, including addressing a recent issue where it wasn’t updating at all over Remote Desktop.
  • Mitigated a positioning issue that could cause the date and time to get clipped off the end of the Taskbar.
  • If you’ve updated the critical and low battery level notification definitions, the battery icon in the Taskbar will now align with that, rather than using the default values to show a warning.
  • Right clicking the date and time in the Taskbar will now dismiss the Notification Center if it’s open, so that you can see the context menu options.
[Input]
  • Keyboard lights (for example, for caps lock) should work properly again now with this build.
  • We’ve made a few more tweaks to our emoji search keywords based on feedback, including improving results for day, night, and face with raised eyebrow. Please continue sharing feedback with us about this under Input and Language > Emoji Panel in the Feedback Hub.
  • Fixed an issue that was causing the kaomoji list in WIN + . to be blank when accessed while using a Chinese IME.
  • Fixed an issue with the emoji panel search results that could lead to a single gif being displayed repeatedly with certain queries.
  • Mitigated an issue resulting in IMEs not working with certain games.
  • Addressed an issue where the options under Settings > Personalization > Typing to change the settings “Show text suggestions & add a spacebar after I choose a text suggestions” for the touch keyboard might unexpectedly not display.
  • If you make a long pause while using voice typing (WIN + H), it should be able to resume listening more reliability now.
  • Fixed some inconsistencies between actual listening status and the microphone visual in voice typing.
  • Text should no longer be unexpectedly duplicated if the caret is moved while using voice typing.
[Windowing]
  • Selecting snap layout options should no longer randomly put windows on your other monitor sometimes.
[Settings]
  • The brightness and volume sliders in Quick Settings should no longer randomly become invisible.
  • Fixed an issue preventing Adjusting active hours from being set to manually.
  • Addressed an issue which could result in the touch keyboard occluding the password entry field when connecting to a network in Quick Settings.
[Other]
  • Fixed a scaling issue that was causing the update prompt dialog (and other dialogs of that style) to get cut off and not draw correctly after the DPI changed.
  • Improved the positioning of the context menu when right clicking the bottom corner of the desktop.
  • Mitigated an issue related to TCPIP which could result in bug checks when waking a device.
  • Fixed an issue where high priority notifications (such as an alarm) would sometimes unexpectedly dismiss without you engaging with it, leading to it randomly reappearing the next time a normal priority notification came in.
« Reply #24 on: November 19, 2021, 05:21:06 PM »
From Announcing Windows 11 Insider Preview Build 22504:
UPDATE 11/19: We are starting to roll out Cumulative Update Build 22504.1010 (KB5008697). This update does not include anything new and is designed to test our servicing pipeline for builds in the Dev Channel.
« Reply #25 on: December 01, 2021, 04:17:18 PM »
Announcing Windows 11 Insider Preview Build 22509
This build includes a set of improvements that make browsing the web in Microsoft Edge with Narrator easier.  It also includes new layout options for Start, clock and date that will now show on secondary monitors, and Settings changes.  See the blog post for details.
Fixes:
[Taskbar]
  • The Start, Search, Task View, Widgets, and Chat icons in the Taskbar should no longer be unexpectedly large when the system scaling is set to 125%.
  • Pressing the Windows key plus (the number corresponding to an app icon’s position in the Taskbar) should cycle now through the app’s windows if you repeatedly press the number instead of stopping at the last window.
  • When Narrator focus is set to the Task View button and the Desktops flyout appears, Narrator will now let you know information about the Desktops.
  • Fixed an explorer.exe crash some Insiders were experiencing in recent flights related to updating badges in the Taskbar.
[Input]
  • Handwriting should be working again now when the language is set to Chinese.
  • Mitigated an issue related to the mouse that was causing some Insiders to experience a bugcheck during hibernation sometimes in recent flights (making it appear as if the computer had rebooted).
  • Updated the Chinese Simplified IME candidates to be center aligned with the candidate window height has been customized.
  • Fixed touch keyboard invocation in PowerShell so it should work now.
[Windowing]
  • Hovering your mouse back and forth between different desktops in Task View will no longer result in the displayed thumbnails and content area unexpectedly shrinking.
  • CompactOverlay should be working again in this build (aka the option that some apps use to create a small always on top window).
  • Fixed a race condition that was causing explorer.exe to crash sometimes when closing a snap group of 3 or more windows in Task View.
  • Removed the unexpected tilt animation when clicking down on a corner of the New Desktop button.
  • Made a tweak to address an underlying issue that was causing the context menu to animation down to the mouse instead of away from the mouse when right clicking a Desktop in Task View.
  • Fixed a high hitting DWM crash in recent flights.
[Settings]
  • Fixed some overlapping text for certain languages on the Installed Apps page in Settings.
  • Clicking the Uninstall button when using the Installed Apps page in grid view will now show a confirmation dialog.
  • Changed the new ms-settings:installed-apps URI to now be ms-settings:appsfeatures, to address scenarios where existing links expect the latter to lead to the list of installed apps, for example, when selecting the App Settings option after right clicking a UWP app in Start.
[Other]
  • Fixed an issue that was causing some Insiders to see error 0x8007001f when trying to upgrade to recent Dev Channel builds.
  • Fixed an issue where some PCs are unable to install new builds, or other updates with an error code 0x80070002.
  • Fixed an issue causing some devices to roll back with error code 0xc1900101-0x4001c when installing new builds.
  • Did some work to help address an issue leading to the Wi-Fi connection getting lost after resuming from sleep.
« Reply #26 on: December 03, 2021, 05:00:10 PM »
Update to Announcing Windows 11 Insider Preview Build 22509:
"UPDATE 12/3: We are starting to roll out Cumulative Update Build 22509.1011 (KB5008918). This update does not include anything new and is designed to test our servicing pipeline for builds in the Dev Channel."
« Reply #27 on: December 07, 2021, 04:38:41 PM »
Redesigned Notepad for Windows 11 begins rolling out to Windows Insiders | Windows Insider Blog.
The update includes:
  • A completely updated UI that aligns with the new visual design of Windows 11, including rounded corners, Mica, and more.
  • Dark mode:  By default, Notepad will adapt to your system theme preferences, but you can change this option yourself in the brand-new settings page which is the new home for font options as well.
  • A redesigned find and replace as well as support for multi-level undo
« Reply #28 on: December 08, 2021, 04:16:34 PM »
Announcing Windows 11 Insider Preview Build 22518 | Windows Insider Blog
Note:
  • This build will not be offered to ARM64 PCs due to an issue that causes these devices to rollback when attempting to update to this build. We’re working on a fix.
See the blog post for the description of the new features.
Fixes
[Taskbar]
  • Fixed an explorer.exe crash related to having websites pinned to the Taskbar.
[Search]
  • Did some work to help address an issue where an invisible window frame for the recent searches flyout could end up stuck on the screen, consuming input in that area.
  • When you’re hovering over items in the recent searches flyout, truncated text in the flyout (for example, when using the accessibility setting to make text larger) will now have a tooltip so you can see the full text.
  • Improved visibility of the text in the recent searches flyout if a contrast mode was enabled.
  • The recent searches flyout now has an accessible name when a screen reader sets focus to it, instead of just saying button.
  • Fixed an issue which was causing the search icon in the recent searches icon to become a garbage character for people using the Chinese display language.
  • Fixed a high hitting Search crash.
  • Did some work to help reduce the likelihood of keystrokes getting dropped if you start your search by pressing the Windows key and start typing.
  • If you use Search to run commands, the “Run as administrator” and “Open file location” options should be visible again for you to select on the side of the search window. In addition, CTRL + Shift + Enter should work again now for commands.
[File Explorer]
  • Mitigated an issue that could lead to not being able to add network drives as a source in Media Player.
  • Fixed an issue that could lead to seeing an unexpected blank icon after compressing a file, instead of the one corresponding to your default app for handling that file type.
  • Right clicking on a folder and then quickly closing and reopening the File Explorer window should no longer lead to an explorer.exe crash when the “run as a separate process” option is enabled.
  • Removed some unexpected characters in the dialog when moving user account folders to another location.
  • If you right click on files like .htm in File Explorer, the icon next to Microsoft Edge Canary, Beta or Dev should now display correctly (if installed) under Open With, instead of showing a generic icon.
  • Addressed an issue that could lead to icons for app entries (like Windows Terminal) in the context menu going missing / being invisible sometimes.
  • Improved the consistency of the background color of the command bar and menu dropdowns when a contrast mode was enabled.
  • Made some more little improvements to help with File Explorer folder navigation performance.
[Input]
  • If you’ve pressed WIN + Period and have navigated to the emoji or gifs section with a search term, when you go back to the main page, we will now clear out the search query so you can start fresh.
  • The IME candidate window should now appear more reliably when typing into Search immediately after booting your PC.
  • Fixed an issue where u-mode/v-mode/name-mode wasn’t not showing candidates when typing with the Simplified Chinese IME.
  • Fixed an issue where the Japanese IME was unexpectedly displaying candidates in horizontal mode instead of vertical mode.
  • Fixed an issue where the IME toolbar might randomly show on the lock screen.
  • Addressed an issue where the keyboard focus wouldn’t always be in the right place after pressing WIN + Period, depending on where you’d left focus the last time the window was used.
  • When personalizing your family emoji in the emoji panel, the UI should no longer unexpectedly dismiss when you click the white space.
  • Clicking on your personalized family emoji in the most recently used list in the emoji panel should no longer unexpectedly invoke the customization UI.
  • If you try to start voice typing (WIN + H) without setting focus to a text box first, the popup suggesting you move focus should work again now.
[Windowing]
  • Fixed issue where snap group thumbnails weren’t updating in real time in Task View after you moved a group window to a different Desktop.
[Settings]
  • Fixed an issue that was causing Settings to crash when going to open options for added languages for some Insiders.
  • Fixed a few issues on the Text Input page under Personalization, including:
    • The preview image for your current set up should be showing now.
    • Added a few keywords to help search for this page.
    • Improved read out of the page for screen reader users.
  • Searching for the word widgets should return to the corresponding Settings page with that toggle now.
[Other]
  • Mitigated an issue believed to be causing Insiders with certain devices to be experiencing bug checks with the error SYSTEM_SERVICE_EXCEPTION in recent flights.
  • Fixed an issue where users updating from Builds 22000.xxx, or earlier, to newer Dev Channel builds using the latest Dev Channel ISO would receive the following warning message: The build you are trying to install is Flight Signed. To continue installing, enable flight signing.
  • Removed some excess padding on the left of the boot logo, which was causing it to look off-center compared to the progress wheel.
  • Addressed an issue where UAC was unexpectedly showing “Unknown program” when trying to elevate certain programs, despite them having proper names.
  • Fixed an issue leading to Narrator unexpectedly saying “No item in view” sometimes when tabbing to win32 text boxes.
  • Fixed a crash that was leading to login issues in OOBE (if you were to reset your PC), and well as issues resetting your PIN from the lock screen in the last 2 flights.
  • Fixed an issue leading to acrylic unexpectedly not working in certain places in the preview flight.
  • Mitigated an issue leading to some people unexpectedly seeing “Something went wrong” when trying to click the “stop recording” button when recording a message in Voice Recorder.
« Reply #29 on: December 10, 2021, 04:11:02 PM »
From Announcing Windows 11 Insider Preview Build 22518 | Windows Insider Blog:
UPDATE 12/10: We are starting to roll out Cumulative Update Build 22518.1012 (KB5009380). This update does not include anything new and is designed to test our servicing pipeline for builds in the Dev Channel.
