LandzDown Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Home
Help
Search
Members
View the memberlist
Search For Members
Login
Register
LandzDown Forum
Software & More
General Software News, Updates & Discussions
Windows 11 Insider DEV Channel
« previous
next »
Print
Pages:
1
3
4
5
Go Down
Author
Topic: Windows 11 Insider DEV Channel (Read 30266 times)
The Mystical Rose
Administrator
Hero Member
"Stronger than the past, united in our goal."
Re: Windows 11 Insider DEV Channel
Reply #60 on:
May 20, 2022, 06:34:17 PM »
UPDATE 5/20:
We are starting to roll out Cumulative Update Build 25120.1010 (KB5015039). This update does not include anything new and is designed to test our servicing pipeline for builds in the Dev Channel.
Logged
Take a walk through the
"Security Garden"
-- Where Everything is Coming up
Roses
The Mystical Rose
Administrator
Hero Member
Reply #61 on:
May 25, 2022, 04:35:32 PM »
Announcing Windows 11 Insider Preview Build 25126
This update will allow you to view all supported Microsoft 365 Office products licensed to your account and you can view details about your product or install Office by clicking the “View Details” button. This information is shown on the
Microsoft account management page
and you will now be able to view these datils in Windows 11 via
Settings > Accounts
. Note: the feature isn't available to all Insiders. Feedback will be monitored before making it available to all Insiders in the Dev Channel.
Changes and Improvements
Fixes
[General]
We fixed the issue causing some Insiders to experience a bugcheck with error DRIVER_IRQL_NOT_LESS_OR_EQUAL in pci.sys causing a rollback trying to install the latest builds in the Dev Channel.
We did work to mitigate the issue causing the Program Compatibility Assistant Service to use an unexpectedly large amount of CPU for some Insiders after upgrading to the latest Insider Preview builds in the Dev Channel.
[Start menu]
If the touch keyboard is docked it should no longer unexpectedly dismiss when trying to edit the name of a folder in Start.
[Search]
Fixed a high hitting explorer.exe crash that could happen when using Search.
[Settings]
The preview image under Personalization > Lock Screen should no longer be backwards when using an Arabic or Hebrew display language.
[Task Manager]
If explorer.exe has hung, that should no longer hang Task Manager.
Fixed an issue where the context menus weren’t following the same mode (light or dark) as Task Manager itself for some Insiders.
Fixed a typo in the “Minimize on use” tooltip.
If you’ve hidden the graphs on the side of the Performance page, the color of the circles used instead should now match the graph in the summary view.
Addressed an issue where the Not Responding status for certain apps wasn’t being reflected on the Processes page.
[Windows Sandbox]
Removed the Lock option in Start menu as it didn’t work.
[Other]
Fixed an issue where using “Open All Active Printers” from the printer icon in the system tray would unexpectedly open File Explorer when there were no active queues.
Logged
"Security Garden"
Roses
The Mystical Rose
Administrator
Hero Member
Reply #62 on:
June 02, 2022, 04:50:55 PM »
Announcing Windows 11 Insider Preview Build 25131
Microsoft Store Update (Version 22205.1401.3.0)
An update to Microsoft Store for Windows Insiders in the Dev Channel is beginning to be rolled out with the following changes and improvements:
Native Arm64 support
: We’ve improved the Microsoft Store app experience on ARM64 devices. You’ll see faster and better performance when you use the app.
Improved app updates:
We improved automatic updates for your apps. We’ll skip over apps that you have open, so you don’t lose any important work. You can update the apps later in the Microsoft Store.
Improved Android apps support for the pop-pup store experience:
When you’re browsing the web, you might discover a new app. If it’s available in the Microsoft Store, we’ll show you a pop-up experience to help you install it. This experience now supports free Android apps (depending on device compatibility and age rating).
Faster navigation:
We have improved the browsing experience.
Fixes
[General]
Fixed an issue causing some Insider PCs with certain AMD processors to bugcheck and roll back when attempting to upgrade to last week’s flight. This issue is also believed to be the cause of some Insiders experiencing a bugcheck after enabling SVM in the bios on their PCs in the last build.
Fixed an issue which was causing some Insiders with secondary accounts on their PC to not be able to upgrade to the latest builds.
[File Explorer]
The new folder icon used in the command bar should be consistent with the one used in the context menu now.
Fixed an issue which could lead to File Explorer hanging when browsing folders with lots of .mkv files.
Fixed an issue which was causing searching from Home to not return any results sometimes from the Open or Save dialog (when doing it from File Explorer returned results).
[Search]
Searching for something like %appdata% should now show a proper folder icon and not just a blank square.
When selecting “Open file location” for a search result, it should now select the file in the folder again now, and not just open the folder.
[Settings]
Searching for “default” will now return the default apps Settings page as the first result, and not require you to click “show all results” in order to see it.
Fixed an issue where the “Listen to this device” audio option would stop working after a reboot until being unchecked and rechecked.
Narrator will now read out the position of the radio buttons in the
Settings
Accessibility
Color filters
page to make it easier to navigate.
[Other]
Hovering over “Do you like what you see?” when using Windows Spotlight on the lock screen should no longer display a shadow which extends to the bottom of the screen.
Fixed an issue which was leading to certain frame rate monitoring applications impacting game performance.
Fixed an issue that could cause rounded corners to unexpectedly become pixelated at certain scale factors.
Logged
"Security Garden"
Roses
The Mystical Rose
Administrator
Hero Member
Reply #63 on:
June 09, 2022, 08:13:15 PM »
Announcing Windows 11 Insider Preview Build 25136 | Windows Insider Blog
What's New in this Build: File Explorer Tabs & Navigation Updates and Dynamic Widgets content on the taskbar. See the blog post for information as well as the Feedback Hub links.
[Input]
We are beginning to roll out the ability for Insiders to report animated gifs they feel are inappropriate from the emoji panel (WIN + .)
Fixes
[General]
Addressed an issue which was leading to some PCs being erroneously detected as tablets. When this happened, compact mode and the option to hide checkboxes in File Explorer wouldn’t take effect.
Fixed an issue causing some Insiders to experience a SYSTEM_SERVICE_EXCEPTION bugcheck in recent Dev Channel builds.
[Taskbar]
Fixed an issue that was sometimes causing taskbar apps to overflow with the system tray icons.
When you hover on an app in the system tray, its notification will no longer flash.
[Start]
Fixed an issue that could cause Start to only show one column of recommended items.
If you’re pinning a large number of apps to Start, it should now refresh to show them more reliably.
[Settings]
Fixed an issue from the previous flight where Disks & Volumes section of
System > Storage
wasn’t displaying any disks or volumes.
[Windowing]
We made a fix to help with a rare issue which was causing title bars to sometimes go transparent or missing sometimes in certain apps.
[Windows Update]
Fixed an issue where Windows Update might unexpectedly show error 0x00000000 when there wasn’t anything wrong.
Fixed an issue which was leading to some devices bugchecking with HYPERVISOR_ERROR when trying to upgrade to a new build.
[Task Manager]
Fixed an issue which was causing Task Manager to crash on launch sometimes after switching between light and dark mode or changing accent color.
[Other]
Fixed an issue which could lead to increased latency or stutter in games when v-sync was used.
Fixed an issue which could cause some PCs to freeze after running the wsl –shutdown command.
Logged
"Security Garden"
Roses
The Mystical Rose
Administrator
Hero Member
Reply #64 on:
June 15, 2022, 05:53:31 PM »
Announcing Windows 11 Insider Preview Build 25140
ISOs for this build can be
downloaded here
[General]
Euphemia typeface covers most languages that use the Canadian Syllabic script including various Cree orthographies, Inuktitut, and the Carrier/Dakelh script (dulkw’ahke). In the latest Insider builds, we’ve updated this font to improve the legibility and screen rendering of over 200 characters at various sizes. We’ve also added new glyphs to support Unicode 14 characters for the Nattilik language of the Canadian arctic.
Fixes
[File Explorer]
Fixed an issue which was leading some people to unexpectedly see error 0x80070026 when copying files from network drives.
Fixed an issue where the active tab color didn’t match the command bar below it.
Fixed an issue where dragging to rearrange tabs wasn’t working sometimes.
Fixed an issue which could cause artifacts in the windows thumbnail preview in the taskbar if File Explorer was maximized and you used WIN + M to minimize it.
[Settings]
If you go to rename a drive label in System > Storage > Disks & Volumes, the current drive name will now be prepopulated in the dialog.
[Input]
Fixed an issue where selecting English (New Zealand) in OOBE was unexpectedly leading to the Arabic (101) keyboard getting selected.
Setting language bar hotkeys for switching input directly to specific non-IME input method should work now.
Some languages don’t support
the speech recognition FOD
. When an admin user tried to install one of those languages using
the new Install-Language CopyToSettings command
, some settings such as new user account locale, Input (Keyboard), and UPLL (User Preferred Language List) were not getting updated. This issue has now been fixed.
Fixed an issue causing Batang, BatangChe, Gungsuh, and GungsuhChe fonts to not render Korean correctly when using Office online apps when these fonts were not locally present on your PC.
[Task Manager]
Fixed a crash that could happen when switching modes in pages other than the Processes page.
We made a small adjustment to the intensity of the colors used in the heatmap on the Processes page.
[Other]
Fixed an issue where calls to
CopyAcceleratorTable
and
CreateAcceleratorTable
would fail if the LPACCEL parameter was the address of an odd numbered index into an array of ACCEL structs.
Fixed an issue with x64 emulation on ARM64 which could result in certain apps crashing on launch with error code 0xc0000409.
Fixed an issue causing audio to stop playing in certain apps after a minute.
Logged
"Security Garden"
Roses
The Mystical Rose
Administrator
Hero Member
Reply #65 on:
June 22, 2022, 04:20:30 PM »
Announcing Windows 11 Insider Preview Build 25145
This build includes a few new features rolling out including an update for Narrator Braille driver support, OneDrive storage alert and subscription management in Settings, and Local Administrator Password Solution. See the blog post for details.
[General]
Every Microsoft customer should be able to use our products knowing we will protect their privacy and give them the information and tools needed to audit all usage of their private resources. The new App usage history features, which began rolling out to Insiders with
Build 25140
, gives users a 7-day history of resource access for Location, Camera, Microphone, Phone Calls, Messaging, Contacts, Pictures, Videos, Music library, Screenshots and apps through the Settings experience. You can find this new information under
Settings > Privacy & security > App permissions
(simply click on one of the app permissions categories such as microphone and look at “Recent activity”).
[Suggested Actions]
Suggested Actions, which began rolling out with
Build 25115
, is now available to all Windows Insiders in the in the U.S., Canada, and Mexico.
[File Explorer]
Middle clicking a folder in the body of File Explorer will now open it in a new tab.
Fixes
[General]
Fixed an issue causing Windows Insiders on Surface Pro X devices to hit a black screen when attempting to resume from hibernate.
Fixed a bugcheck that some Insiders were experiencing with SYSTEM_THREAD_EXCEPTION_NOT_HANDLED related to USBs.
Fixed a bugcheck with error 0x1CA SYNTHETIC_WATCHDOG_TIMEOUT that could happen sporadically on some PCs after left idling for some time. This could happen when a laptop lid was closed, making it appear that the laptop had rebooted while sleeping.
Fixed an issue from the last two builds that was leading to InventorySvc consuming an unexpectedly high volume of memory the longer it was running.
[File Explorer]
The row of tabs should now be included in the keyboard focus cycle when pressing Tab or F6. Once focus is in the tab row, you can use left or right arrow keys to navigate through them.
Fixed an issue where the tab order when using CTRL + Tab would be wrong if you’d rearranged the tabs in File Explorer.
[Start]
Narrator will now read the dialog that opens when uninstalling an app from its context menu in Start and those options correctly.
The animation when selecting the More button in Start’s Recommended section in right-to-left (RTL) languages should now appear correctly.
[Taskbar]
When dismissing notification center using your keyboard, its closing animation will now show correctly.
[Settings]
Typing a number in the Settings search box when using an Arabic display language should no longer show boxes.
Fixed an issue causing Settings to crash when going to Bluetooth & Devices > Printers & Scanners in the last few builds.
Fixed a couple crashes that some Insiders were experiencing in the last few builds when opening the Wi-Fi section of Quick Settings, or after connecting or disconnecting from networks in the Wi-Fi section in Quick Settings.
Fixed an issue that was causing the Wi-Fi option in Quick Settings and the Wi-Fi section in Settings to sometimes take a few seconds to appear.
Using touch to rearrange the items in Quick Settings when in edit mode should no longer lead to Quick Settings unexpectedly dismissing sometimes.
[Input]
Added the SOM currency sign (U+20C0) to the Courier New font family.
[Task Manager]
Pressing CTRL + Page Up and CTRL + Page Down should work again now to navigate through pages in Task Manager.
[Other]
Fixed a rare issue that could lead to certain apps to sporadically crash on launch.
Logged
"Security Garden"
Roses
The Mystical Rose
Administrator
Hero Member
Reply #66 on:
June 24, 2022, 04:22:44 PM »
UPDATE 6/24:
We are starting to roll out Cumulative Update Build 25145.1011 (KB5016159). This update does not include anything new and is designed to test our servicing pipeline for builds in the Dev Channel.
Logged
"Security Garden"
Roses
Print
Pages:
1
3
4
5
Go Up
« previous
next »
LandzDown Forum
Software & More
