I need your help
Started by Andreas, June 25, 2018, 05:08:57 PM
QuoteIt appears to have helped at least 65 people solve the same issue.
The number 65 didn't change. I will be back tomorrow. Thank you. :)
Let's see if the Troubleshooter will fix the issue.
1.  Click Start > Settings > Update & Security
2.  Select Troubleshoot from the left-hand column
3.  Scroll down to the "Windows Store Apps" and run the troubleshooter.
Good morning. :)
Troubleshooting as well as resetting the Mail application didn't help.
What helped: Settings > Privacy > Email > Allow apps to access your email ON.
It was OFF before.
I uninstalled the cleaning tools and installed Unchecky.
THANK YOU!
You are very welcome, Panos.
Since you installed the latest version update, double-check that System Restore is turned on.
Done.
Protection ON for the Recovery too?
Take a look at the size of the recovery partition and see if thee is enough space available.
