Windows 10 Release Preview
Started by Corrine, July 28, 2022, 05:19:30 PM
Releasing Windows 10 Build 19045.6156 to the Release Preview Channel
Releasing Windows 10 22H2 Build 19045.6156 (KB5062649) to the Release Preview Channel for Insiders who are on Windows 10, version 22H2.
This update includes the following features and improvements (items bolded in brackets indicate the area of the change being documented):
  • Update resolves an issue impacting the Windows 10 Extended Security Updates (ESU) enrollment wizard. Some users experienced a problem where clicking "Enroll now" caused the wizard window to open, begin loading, and then close unexpectedly. This occurred due to incomplete app registration, which prevented the wizard from loading correctly. This update addresses that issue to ensure a smoother enrollment experience.
  • [Mobile Operator Profiles] Updated: Country and Operator Settings Asset (COSA) profiles.
  • [Secure Boot] New! Adds the ability to deploy SKUSiPolicy VBS Anti-rollback protections through the Secure Boot AvailableUpdates registry key.
  • [Stability issue] Fixed: This update addresses an issue observed in rare cases after installing the May 2025 security update and subsequent updates causing devices to experience stability issues. Some devices became unresponsive and stopped responding in specific scenarios.
[UPDATE 7/15] We are releasing Build 19045.6159 (KB5062649) to Windows Insiders who are on Windows 10, version 22H2. It is a small update that addresses some issues with the update itself.
Releasing Windows 10 Build 19045.6276 to the Release Preview Channel
This release is for Windows Insiders who are on Windows 10, version 22H2.
  • [Common Controls] Fixed: An issue that affects how certain supplementary characters appear in Windows textboxes.
  • [Multimedia] Fixed: An issue where mf.dll failed to enumerate redirected web camera devices on Remote Desktop Services (RDS) environments.
  • [Windows Hello] Fixed: An issue in which Narrator reads the incorrect name for the "Enhance Facial Recognition Protection" check box under the Facial Recognition setting.
  • [Family Safety] Fixed: An issue where the "Ask to Use" approval flow was not being triggered for blocked apps. With this fix, the approval flow now appears as expected when a blocked app is accessed.
  • [Portable Devices] Fixed: An issue where the Removeable Storage Access policy may not work properly.
  • [Input and Composition] Fixed: An issue with the Chinese Simplified Input Method Editor (IME). Some extended characters were shown as empty boxes.
  • [Licensing] New! This update adds a new feature that allows customers using the Windows 10 keyless Commercial ESU solution—alongside a Windows 365 subscription—to block outbound network traffic. This enhancement supports compliance with Zero Exhaust policies.
  • [Search pane] Fixed: An issue that might cause the Windows Search pane to not show the preview pane correctly.
  • [Windows Backup for Organizations] New! Windows Backup for Organizations is now generally available! Experience seamless device transitions with enterprise-grade backup and restore. Whether you're refreshing your organization's devices, upgrading to Windows 11, or deploying AI-powered PCs, this solution helps sustain productivity with minimal disruption, ensuring business continuity and organizational resilience.
Build 19045.6280 (KB5063842) is being released today as a small update to the above Build.  It addresses some issues with the update itself.
Releasing Windows 10 Build 19045.6388 to the Release Preview Channel
This Build is for Insiders who are on Windows 10, version 22H2.
  • This update includes a small set of general improvements and fixes that improve the overall experience for customers and their devices on Windows 10.
Releasing Windows 10 Build 19045.6390 (KB5066198) to the Release Preview Channel
This is an update to the previous release which had some issues with the update.
