computer hacked
Let it run. Give it time. It seems that it got stuck, but actually it is running. Normally, it will not take more than 10-15 minutes.
mare_wbpa
I got to where I clicked on fix then I had to restart, Now I can't find the log
If you let it run correctly, then the fixlog.txt will be in your Downloads folder.
If you still can't see it, then you can repeat the procedure, with downloading the fixlist, and then running FRST tool selecting the FIX button.
Mary Ann, it's late for me right now. I'll see you tomorrow. Hopefully, you will have the fixlog.txt ready for me to review.
mare_wbpa
Is this it
Fix result of Farbar Recovery Scan Tool (x64) Version: 23.06.2024
Ran by mary ann (30-06-2024 15:33:19) Run:2
Running from C:\Users\mary ann\Downloads
Loaded Profiles: mary ann
Boot Mode: Normal
fixlist content:
createrestorepoint:
closeprocesses:
DeleteKey: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\McAfee.wps
DeleteKey: HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\PC Cleaner_is1
DeleteKey: HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{35ED3F83-4BDC-4c44-8EC6-6A8301C7413A}
DeleteKey: HKU\SID\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4947c51a-26a9-4ed0-9a7b-c21e5ae0e71a}_is1
DeleteKey: HKU\SID\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WaveBrowser
emptytemp:
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\McAfee.wps => not found
HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\PC Cleaner_is1 => not found
HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{35ED3F83-4BDC-4c44-8EC6-6A8301C7413A} => not found
"HKU\SID\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4947c51a-26a9-4ed0-9a7b-c21e5ae0e71a}_is1" => not found
"HKU\SID\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WaveBrowser" => not found
FlushDNS => completed
BITS transfer queue => 786432 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 9600886 B
Java, Discord, Steam htmlcache, WinHttpAutoProxySvc/winhttp *.cache => 0 B
Windows/system/drivers => 595325 B
Edge => 0 B
Chrome => 0 B
Firefox => 96969007 B
Opera => 0 B
Default => 0 B
ProgramData => 0 B
Public => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 10336 B
NetworkService => 10336 B
mary ann => 321399 B
RecycleBin => 0 B
EmptyTemp: => 103.3 MB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 15:33:31 ====
mare_wbpa
createrestorepoint:
closeprocesses:
emptytemp:
Hi, Mary Ann.
You run the fix twice, thus why the Not found indications in the fixlog.txt.
Now, I would like you to go to your Settings: Press the Windows logo key on your keyboard, together with the letter i.
Then, from the menu at the left, click on Apps.
Now, click on Installed apps.
Let me know if you were able to do this.
mare_wbpa
Idid that but it was just apps, not all apps installrd apps came up
Go through all these apps, and let me know if you see McAfee among them.
mare_wbpa
I went thru them 3 times. No McAfee
Thanks, Mary Ann.
Before I shut down for today, I would like you to run FRST tool, as you did before, and give me the two logs created (Addition and FRST) to review.
Remember to click on the SCAN button.
mare_wbpa
mare_wbpa
You have to be specific cause I'm pretty computer illerate
mare_wbpa
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 01.07.2024
Ran by mary ann (administrator) on LAPTOP-4EQFBMN3 (HP HP Laptop 17-cn2xxx) (01-07-2024 16:54:34)
Running from C:\Users\mary ann\Downloads\FRST64(1).exe
Platform: Microsoft Windows 11 Home Version 23H2 22631.3737 (X64) Language: English (United States)
Default browser: FF
Boot Mode: Normal
==================== Processes (Whitelisted) =================
(If an entry is included in the fixlist, the process will be closed. The file will not be moved.)
(AVG Technologies USA, LLC -> Gen Digital Inc.) C:\Program Files\AVG\Antivirus\AVGUI.exe <4>
(C:\Program Files (x86)\ExpressVPN\bootstrap\amd64\nssm.exe ->) (EXPRSVPN LLC -> ExpressVPN) C:\Program Files (x86)\ExpressVPN\expressvpnd\expressvpnd.exe
(C:\Program Files\AVG\Antivirus\AVGSvc.exe ->) (AVG Technologies USA, LLC -> Gen Digital Inc.) C:\Program Files\AVG\Antivirus\aswEngSrv.exe
(C:\Program Files\WindowsApps\AD2F1837.HPSystemEventUtility_1.5.15.0_x64__v10z8vjag6ke6\SystemEventUtility\HPSystemEventUtilityBackground.exe ->) (ED346674-0FA1-4272-85CE-3187C9C86E26 -> HP Inc.) C:\Program Files\WindowsApps\AD2F1837.HPSystemEventUtility_1.5.15.0_x64__v10z8vjag6ke6\SystemEventUtility\HPSystemEventUtilityHost.exe
(C:\Program Files\WindowsApps\MicrosoftTeams_24151.2105.2943.2101_x64__8wekyb3d8bbwe\msteams.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files (x86)\Microsoft\EdgeWebView\Application\126.0.2592.81\msedgewebview2.exe <12>
(C:\Users\mary ann\AppData\Local\Apps\2.0\QN4P3DWA.NPN\VQCN9APE.Z4M\scre..tion_25b0fbb6ef7eb094_0018.0001_51e59eb280deee18\ScreenConnect.ClientService.exe ->) (Connectwise, LLC -> ScreenConnect Software) C:\Users\mary ann\AppData\Local\Apps\2.0\QN4P3DWA.NPN\VQCN9APE.Z4M\scre..tion_25b0fbb6ef7eb094_0018.0001_51e59eb280deee18\ScreenConnect.WindowsClient.exe
(DriverStore\FileRepository\hpcustomcapcomp.inf_amd64_e37f0d22409571ae\x64\NetworkCap.exe ->) (HP Inc. -> HP Inc.) C:\Windows\System32\DriverStore\FileRepository\hpcustomcapcomp.inf_amd64_e37f0d22409571ae\x64\BridgeCommunication.exe
(DriverStore\FileRepository\ipf_cpu.inf_amd64_ac13c23bf8b4219a\ipf_uf.exe ->) (Intel Corporation -> Intel Corporation) C:\Windows\System32\DriverStore\FileRepository\ipf_cpu.inf_amd64_ac13c23bf8b4219a\ipf_helper.exe
(ED346674-0FA1-4272-85CE-3187C9C86E26 -> HP Inc) C:\Program Files\WindowsApps\AD2F1837.myHP_34.52424.589.0_x64__v10z8vjag6ke6\win32\HP.ContextAware.exe
(ED346674-0FA1-4272-85CE-3187C9C86E26 -> HP Inc.) C:\Program Files\WindowsApps\AD2F1837.HPSystemEventUtility_1.5.15.0_x64__v10z8vjag6ke6\SystemEventUtility\HPSystemEventUtilityBackground.exe
(ED346674-0FA1-4272-85CE-3187C9C86E26 -> HP Inc.) C:\Program Files\WindowsApps\AD2F1837.OMENCommandCenter_1101.2406.3.0_x64__v10z8vjag6ke6\OmenCommandCenterApp\OmenCommandCenterBackground.exe
(explorer.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe <11>
(explorer.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files\Microsoft Office\root\Office16\ONENOTEM.EXE
(explorer.exe ->) (Storage Appliance Corporation -> Storage Appliance Corp.) C:\ProgramData\OfficeGuardianV2N\Reminder\SacReminder.exe
(EXPRSVPN LLC -> ExpressVPN) C:\Program Files (x86)\ExpressVPN\expressvpn-ui\ExpressVPNNotificationService.exe
(SECOMN64.exe ->) (Sound Research Corporation -> Sound Research, Corp.) C:\Windows\System32\SECOCL64.exe
(services.exe ->) (AVG Technologies USA, LLC -> AVG Technologies CZ, s.r.o.) C:\Program Files\AVG\Antivirus\aswidsagent.exe
(services.exe ->) (AVG Technologies USA, LLC -> AVG Technologies CZ, s.r.o.) C:\Program Files\AVG\Antivirus\wsc_proxy.exe
(services.exe ->) (AVG Technologies USA, LLC -> Gen Digital Inc.) C:\Program Files\AVG\Antivirus\afwServ.exe
(services.exe ->) (AVG Technologies USA, LLC -> Gen Digital Inc.) C:\Program Files\AVG\Antivirus\AVGSvc.exe
(services.exe ->) (AVG Technologies USA, LLC -> Gen Digital Inc.) C:\Program Files\AVG\Antivirus\avgToolsSvc.exe
(services.exe ->) (Connectwise, LLC -> ) C:\Users\mary ann\AppData\Local\Apps\2.0\QN4P3DWA.NPN\VQCN9APE.Z4M\scre..tion_25b0fbb6ef7eb094_0018.0001_51e59eb280deee18\ScreenConnect.ClientService.exe
(services.exe ->) (EXPRSVPN LLC -> ExpressVPN) C:\Program Files (x86)\ExpressVPN\bootstrap\amd64\nssm.exe
(services.exe ->) (HP Inc. -> HP Inc.) C:\Program Files\HPCommRecovery\HPCommRecovery.exe
(services.exe ->) (HP Inc. -> HP Inc.) C:\Windows\System32\DriverStore\FileRepository\hpanalyticscomp.inf_amd64_7dcf4ebd9d1b4772\x64\TouchpointAnalyticsClientService.exe
(services.exe ->) (HP Inc. -> HP Inc.) C:\Windows\System32\DriverStore\FileRepository\hpcustomcapcomp.inf_amd64_e37f0d22409571ae\x64\AppHelperCap.exe
(services.exe ->) (HP Inc. -> HP Inc.) C:\Windows\System32\DriverStore\FileRepository\hpcustomcapcomp.inf_amd64_e37f0d22409571ae\x64\DiagsCap.exe
(services.exe ->) (HP Inc. -> HP Inc.) C:\Windows\System32\DriverStore\FileRepository\hpcustomcapcomp.inf_amd64_e37f0d22409571ae\x64\NetworkCap.exe
(services.exe ->) (HP Inc. -> HP Inc.) C:\Windows\System32\DriverStore\FileRepository\hpcustomcapcomp.inf_amd64_e37f0d22409571ae\x64\SysInfoCap.exe
(services.exe ->) (HP Inc. -> HP Inc; HP Development Company, L.P.) C:\Program Files\HP\HP One Agent\hp-one-agent-service.exe
(services.exe ->) (Intel Corporation -> Intel Corporation) C:\Windows\System32\DriverStore\FileRepository\dal.inf_amd64_af50fdb80983f7bc\jhi_service.exe
(services.exe ->) (Intel Corporation -> Intel Corporation) C:\Windows\System32\DriverStore\FileRepository\dtt_sw.inf_amd64_191d9fb378307f35\ipfsvc.exe
(services.exe ->) (Intel Corporation -> Intel Corporation) C:\Windows\System32\DriverStore\FileRepository\igcc_dch.inf_amd64_a687edda40db3316\OneApp.IGCC.WinService.exe
(services.exe ->) (Intel Corporation -> Intel Corporation) C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_0db786bd9a6ade98\IntelCpHDCPSvc.exe
(services.exe ->) (Intel Corporation -> Intel Corporation) C:\Windows\System32\DriverStore\FileRepository\ipf_cpu.inf_amd64_ac13c23bf8b4219a\ipf_uf.exe
(services.exe ->) (Intel Corporation -> Intel Corporation) C:\Windows\System32\DriverStore\FileRepository\mewmiprov.inf_amd64_ab7d4ea1d12c01d4\WMIRegistrationService.exe
(services.exe ->) (Intel Corporation -> Intel) C:\Windows\System32\DriverStore\FileRepository\intcoed.inf_amd64_29fd1afabcf5470c\AS\IAS\IntelAudioService.exe
(services.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files\Common Files\microsoft shared\ClickToRun\OfficeClickToRun.exe
(services.exe ->) (Microsoft Windows Hardware Compatibility Publisher -> Realtek Semiconductor Corp.) C:\Windows\RtkBtManServ.exe
(services.exe ->) (Realtek Semiconductor Corp. -> Realtek Semiconductor) C:\Windows\System32\DriverStore\FileRepository\realtekservice.inf_amd64_e4e95354d5d4b4dd\RtkAudUService64.exe <3>
(services.exe ->) (Sound Research Corporation -> Sound Research, Corp.) C:\Windows\System32\SECOMN64.exe
(services.exe ->) (Storage Appliance Corporation -> Storage Appliance Corp.) C:\ProgramData\OfficeGuardianV2N\UACProxy.exe
(services.exe ->) (Storage Appliance Corporation -> Storage Appliance Corporation) C:\ProgramData\OfficeGuardianV2N\Reminder\SacNetAgent.exe
(services.exe ->) (Synaptics Incorporated -> Synaptics Incorporated) C:\Windows\System32\SynTPEnhService.exe
(sihost.exe ->) (EB51A5DA-0E72-4863-82E4-EA21C1F8DFE3 -> Intel Corporation) C:\Program Files\WindowsApps\AppUp.IntelGraphicsExperience_1.100.5536.0_x64__8j3eq9eme6ctt\GCP.ML.BackgroundSysTray\IGCCTray.exe
(sihost.exe ->) (ED346674-0FA1-4272-85CE-3187C9C86E26 -> ) C:\Program Files\WindowsApps\AD2F1837.myHP_34.52424.589.0_x64__v10z8vjag6ke6\win32\DesktopExtension.exe
(sihost.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files\WindowsApps\Microsoft.Windows.DevHome_0.1501.533.0_x64__8wekyb3d8bbwe\DevHome.PI.exe
(svchost.exe ->) (EB51A5DA-0E72-4863-82E4-EA21C1F8DFE3 -> Intel Corporation) C:\Program Files\WindowsApps\AppUp.IntelGraphicsExperience_1.100.5536.0_x64__8j3eq9eme6ctt\IGCC.exe
(svchost.exe ->) (ED346674-0FA1-4272-85CE-3187C9C86E26 -> ) C:\Program Files\WindowsApps\AD2F1837.myHP_34.52424.589.0_x64__v10z8vjag6ke6\HP.myHP.exe
(svchost.exe ->) (HP Inc. -> HP Inc.) C:\Program Files\HP\OmenInstallMonitor\OmenInstallMonitor.exe
(svchost.exe ->) (HP Inc. -> HP Inc.) C:\Program Files\HP\Overlay\OverlayHelper.exe
(svchost.exe ->) (HP Inc. -> HP Inc.) C:\Program Files\HP\SystemOptimizer\SystemOptimizer.exe
(svchost.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files\Microsoft Office\root\Office16\SDXHelper.exe
(svchost.exe ->) (Microsoft Windows -> Microsoft Corporation) C:\Program Files\WindowsApps\MicrosoftWindows.Client.WebExperience_524.13200.20.0_x64__cw5n1h2txyewy\Dashboard\WidgetService.exe
(svchost.exe ->) (Microsoft Windows -> Microsoft Corporation) C:\Windows\ImmersiveControlPanel\SystemSettings.exe
(svchost.exe ->) (Microsoft Windows -> Microsoft Corporation) C:\Windows\System32\dllhost.exe
(svchost.exe ->) (Microsoft Windows -> Microsoft Corporation) C:\Windows\System32\LocationNotificationWindows.exe
(svchost.exe ->) (Microsoft Windows -> Microsoft Corporation) C:\Windows\System32\smartscreen.exe
(svchost.exe ->) (Microsoft Windows -> Microsoft Corporation) C:\Windows\UUS\Packages\Preview\amd64\MoUsoCoreWorker.exe
(SynTPEnhService.exe ->) (Synaptics Incorporated -> Synaptics Incorporated) C:\Windows\System32\SynTPEnh.exe
==================== Registry (Whitelisted) ===================
(If an entry is included in the fixlist, the registry item will be restored to default or removed. The file will not be moved.)
HKLM\...\Run: [RtkAudUService] => C:\windows\System32\DriverStore\FileRepository\realtekservice.inf_amd64_e4e95354d5d4b4dd\RtkAudUService64.exe [1987544 2024-05-27] (Realtek Semiconductor Corp. -> Realtek Semiconductor)
HKLM\...\Run: [AVGUI.exe] => C:\Program Files\AVG\Antivirus\AvLaunch.exe [464320 2024-06-26] (AVG Technologies USA, LLC -> Gen Digital Inc.)
HKLM\...\Run: [HPOneAgentService] => C:\Program Files\HP\HP One Agent\hp-one-agent-service.exe [1605136 2024-05-20] (HP Inc. -> HP Inc; HP Development Company, L.P.)
HKLM-x32\...\Run: [ExpressVPNNotificationService] => C:\Program Files (x86)\ExpressVPN\expressvpn-ui\ExpressVPNNotificationServiceStarter.exe [380784 2022-08-16] (EXPRSVPN LLC -> ExpressVPN)
HKLM\SOFTWARE\Microsoft\Windows Defender: [DisableAntiSpyware] Restriction <==== ATTENTION
HKLM\SOFTWARE\Microsoft\Windows Defender: [DisableAntiVirus] Restriction <==== ATTENTION
HKU\S-1-5-21-808705873-2307071823-1975692619-1001\...\Run: [HPSEU_Host_Launcher] => C:\System.sav\util\HPSEU\HpseuHostLauncher.exe [539152 2024-04-24] (HP Inc. -> HP Inc.)
HKU\S-1-5-21-808705873-2307071823-1975692619-1001\...\Run: [MicrosoftEdgeAutoLaunch_999B8E90B693400311D9758E783E7FCC] => "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --no-startup-window --win-session-start [3883576 2024-06-27] (Microsoft Corporation -> Microsoft Corporation)
HKU\S-1-5-21-808705873-2307071823-1975692619-1001\...\Run: [SacReminderHDDV2N] => C:\ProgramData\OfficeGuardianV2N\reminder\SacReminder.exe [862032 2010-11-18] (Storage Appliance Corporation -> Storage Appliance Corp.)
HKU\S-1-5-21-808705873-2307071823-1975692619-1001\...\MountPoints2: {cb5214c5-ba6e-11ee-9675-cc5ef8f272ec} - "D:\GHScrabbleInstall.exe"
HKLM\...\Windows x64\Print Processors\Canon MG2500 series Print Processor: C:\Windows\System32\spool\prtprocs\x64\CNMPDBX.DLL [30208 2023-07-07] (Microsoft Windows Hardware Compatibility Publisher -> CANON INC.)
HKLM\...\Print\Monitors\Canon BJ Language Monitor MG2500 series: C:\windows\system32\CNMLMBX.DLL [391168 2023-07-07] (Microsoft Windows Hardware Compatibility Publisher -> CANON INC.)
HKLM\Software\Microsoft\Active Setup\Installed Components: [{48F69C39-1356-4A7B-A899-70E3539D4982}] -> C:\Program Files\AVG\Browser\Application\126.0.25497.127\Installer\chrmstp.exe [2024-07-01] (AVG Technologies USA, LLC -> Gen Digital Inc.)
HKLM\Software\Microsoft\Active Setup\Installed Components: [{8A69D345-D564-463c-AFF1-A69D9E530F96}] -> C:\Program Files\Google\Chrome\Application\126.0.6478.127\Installer\chrmstp.exe [2024-06-26] (Google LLC -> Google LLC)
Startup: C:\Users\mary ann\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Send to OneNote.lnk [2024-01-10]
ShortcutTarget: Send to OneNote.lnk -> C:\Program Files\Microsoft Office\root\Office16\ONENOTEM.EXE (Microsoft Corporation -> Microsoft Corporation)
HKLM\SOFTWARE\Policies\Mozilla\Firefox: Restriction <==== ATTENTION
==================== Scheduled Tasks (Whitelisted) =================
Task: {040010EA-1BBC-447B-9090-3BB096E813B3} - \McAfee\WPS\McAfee Cloud Configuration Check -> No File <==== ATTENTION
Task: {1A8D192A-E602-4692-A574-CA6BD75D59A7} - \McAfee\WPS\McAfee Hotfix -> No File <==== ATTENTION
Task: {2108BDB0-9C3A-4ED1-AD6E-9B0E548EF94F} - \McAfee\WPS\McAfee Scheduled Tracker Remover -> No File <==== ATTENTION
Task: {681F2B7E-072A-4EAA-85E1-8819F061C123} - \McAfee\WPS\McAfee PC Optimizer Task -> No File <==== ATTENTION
Task: {68370CD0-6967-45A7-AE10-414612E86E20} - \McAfee\WPS\McAfee Scheduled AV Scan -> No File <==== ATTENTION
Task: {72D83402-547D-4D39-8E88-C50F51A9D6DE} - \McAfee\WPS\McAfee restart of PC -> No File <==== ATTENTION
Task: {8057C08C-800D-4493-9F4F-2B5D30E99E61} - \McAfee\WPS\McAfee Anti-tracker notification -> No File <==== ATTENTION
Task: {AFC537DA-7894-48F4-BFA1-C58EFE38A190} - \McAfee\WPS\McAfee Message Check -> No File <==== ATTENTION
Task: {BE36AFFD-9B2B-429F-88D2-9607ED6EA43E} - \McAfee\WPS\McAfee Virus Definition Update -> No File <==== ATTENTION
Task: {DE988299-04E9-47DF-A3C4-016A3ADEA8F1} - \McAfee\WPS\McAfee Windows Notification Token -> No File <==== ATTENTION
Task: {EAEA0964-16A6-458B-BD62-1B45C21DF280} - \McAfee\WPS\McAfee Health Check -> No File <==== ATTENTION
Task: {FE923434-2E65-4870-8746-8E2BB7D1881B} - \McAfee\wps\McAfee Updater -> No File <==== ATTENTION
Task: {0DF0C6B6-575F-4680-B6AC-B1A7705BD1B8} - System32\Tasks\AVG Secure Browser Heartbeat Task (Hourly) => C:\Program Files\AVG\Browser\Application\AVGBrowser.exe [3154536 2024-06-25] (AVG Technologies USA, LLC -> Gen Digital Inc.)
Task: {97169D64-028B-4D24-A1E1-32CFE50BCEFA} - System32\Tasks\AVG Secure Browser Heartbeat Task (Logon) => C:\Program Files\AVG\Browser\Application\AVGBrowser.exe [3154536 2024-06-25] (AVG Technologies USA, LLC -> Gen Digital Inc.)
Task: {F3CF72D0-BA0B-4D08-9A68-C3B197B53B39} - System32\Tasks\AVG\Antivirus Emergency Update => C:\Program Files\AVG\Antivirus\AvEmUpdate.exe [5131704 2024-06-26] (AVG Technologies USA, LLC -> Gen Digital Inc.)
Task: {97A9314E-F50B-4E91-BEE4-CE020216906C} - System32\Tasks\AVG\AVG Antivirus Patcher => C:\Program Files\Common Files\AVG\Icarus\avg-av\icarus.exe [8027576 2024-06-20] (AVG Technologies USA, LLC -> Gen Digital Inc.)
Task: {9F2FF50B-9FD5-4F95-B1A2-B7CC463BF101} - System32\Tasks\AVG\Overseer => C:\Program Files\Common Files\AVG\Overseer\overseer.exe [2181560 2024-01-12] (AVG Technologies USA, LLC -> AVG Technologies)
Task: {FEB83023-3CE9-4DD1-9ED1-2B388C7BF3C1} - System32\Tasks\AVGBrowserProtectS-1-5-21-808705873-2307071823-1975692619-1001 => C:\Program Files\AVG\Browser\Application\AVGBrowserProtect.exe [1690040 2024-04-23] (AVG Technologies USA, LLC -> Gen Digital Inc.)
Task: {9AAD71D1-07E2-45D3-883B-237BF6E09ADE} - System32\Tasks\AVGUpdateTaskMachineCore => C:\Program Files (x86)\AVG\Browser\Update\AVGBrowserUpdate.exe [209224 2024-03-02] (AVG Technologies USA, LLC -> AVG Technologies)
Task: {0194822B-53DE-4043-A680-1B0E4CD02BB0} - System32\Tasks\AVGUpdateTaskMachineUA => C:\Program Files (x86)\AVG\Browser\Update\AVGBrowserUpdate.exe [209224 2024-03-02] (AVG Technologies USA, LLC -> AVG Technologies)
Task: {F3F2D9EB-1B0C-4EA5-8DA6-89267E4CF512} - System32\Tasks\GoogleSystem\GoogleUpdater\GoogleUpdaterTaskSystem128.0.6537.0{8D9A1D6A-B4AD-436B-A14F-D5A9B784B54F} => C:\Program Files (x86)\Google\GoogleUpdater\128.0.6537.0\updater.exe [4623976 2024-06-13] (Google LLC -> Google LLC)
Task: {3F7DEAE6-2942-47F5-9639-EBAA31964D8D} - System32\Tasks\Hewlett-Packard\HP Support Assistant\HP Support Assistant Update Notice => C:\Program Files (x86)\HP\HP Support Framework\Resources\BingPopup\BingPopup.exe [703536 2024-05-13] (HP Inc. -> HP Inc.) -> C:\Program Files (x86)\HP\HP Support Framework\\/show
Task: {577E5A4B-3BE3-475E-9CF9-E9EDAFD48E35} - System32\Tasks\Hewlett-Packard\HP Support Assistant\HP Support Solutions Framework Report => C:\Program Files (x86)\HP\HP Support Framework\Resources\HPSFReport.exe [138328 2024-05-13] (HP Inc. -> HP Inc.)
Task: {6ABFFDA9-1E94-45A8-91C1-951A89882612} - System32\Tasks\Hewlett-Packard\HP Support Assistant\WarrantyChecker => C:\Program Files (x86)\HP\HP Support Framework\Resources\HPWarrantyCheck\HPWarrantyChecker.exe [1161744 2024-05-13] (HP Inc. -> HP Inc.)
Task: {4C8C4A6C-ADEB-4F6B-933D-DB060D0B5D2F} - System32\Tasks\Hewlett-Packard\HP Support Assistant\WarrantyChecker_DeviceScan => C:\Program Files (x86)\HP\HP Support Framework\Resources\HPWarrantyCheck\HPWarrantyChecker.exe [1161744 2024-05-13] (HP Inc. -> HP Inc.)
Task: {CC570B68-43FB-4442-89FF-BA3D6B507FE2} - System32\Tasks\HP\Consent Manager Launcher => C:\windows\system32\sc.exe [98304 2022-05-07] (Microsoft Windows -> Microsoft Corporation) -> start hptouchpointanalyticsservice
Task: {D39C6D05-2383-47BB-A52D-A759C725F23B} - System32\Tasks\HPOneAgentRepairTask => C:\ProgramData\Package Cache\{E3864E7A-058C-4AC3-8331-E2E4F64C69A4}\HPOneAgent.exe [1169488 2024-06-28] (HP Inc. -> HP Inc.)
Task: {96D7D190-A26F-459B-9B87-2B8EB778A6FE} - System32\Tasks\Microsoft\Office\Office Automatic Updates 2.0 => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [28512448 2024-06-26] (Microsoft Corporation -> Microsoft Corporation)
Task: {E2ED2915-6A6A-4A21-9B0D-0EC191A3C108} - System32\Tasks\Microsoft\Office\Office ClickToRun Service Monitor => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [28512448 2024-06-26] (Microsoft Corporation -> Microsoft Corporation)
Task: {4AC748C1-C3C1-409C-998D-F92623BEE18A} - System32\Tasks\Microsoft\Office\Office Feature Updates => C:\Program Files\Microsoft Office\root\Office16\sdxhelper.exe [309696 2024-06-29] (Microsoft Corporation -> Microsoft Corporation)
Task: {9FBC6A36-A083-4D4E-AEF5-BEA44BBB75A1} - System32\Tasks\Microsoft\Office\Office Feature Updates Logon => C:\Program Files\Microsoft Office\root\Office16\sdxhelper.exe [309696 2024-06-29] (Microsoft Corporation -> Microsoft Corporation)
Task: {E41C9B4A-648A-4FDA-8482-56F61968C260} - System32\Tasks\Microsoft\Office\Office Performance Monitor => C:\Program Files\Microsoft Office\root\vfs\ProgramFilesCommonX64\Microsoft Shared\OFFICE16\operfmon.exe [169408 2024-06-29] (Microsoft Corporation -> Microsoft Corporation)
Task: {D876E5B7-2851-4C88-AF4B-1C662D57E990} - System32\Tasks\Microsoft\Windows\Application Experience\PcaWallpaperAppDetect => C:\windows\system32\rundll32.exe [73728 2024-05-14] (Microsoft Windows -> Microsoft Corporation) -> %windir%\system32\PcaSvc.dll,PcaWallpaperAppDetect
Task: {E0F10DCF-44AD-40E8-9370-FB5DA59F93FB} - System32\Tasks\Microsoft\Windows\UpdateOrchestrator\USO_UxBroker => %systemroot%\system32\MusNotification.exe  (No File)
Task: {F4907934-B6EB-4C2A-81EE-1492B2971241} - System32\Tasks\Mozilla\Firefox Background Update 80E4E1F205DA295 => C:\Users\mary ann\AppData\Local\Mozilla Firefox\firefox.exe [676936 2024-06-26] (Mozilla Corporation -> Mozilla Corporation) -> C:\ProgramData\Mozilla-1de4eec8-1241-4177-a864-e594e8d1fb38\updates\80E4E1F205DA295\--MOZ_LOG sync,prependheader,timestamp,append,maxsize:1,Dump:5 --MOZ_LOG_FILE C:\ProgramData\Mozilla-1de4eec8-1241-4177-a864-e594e8d1fb38\updates\80E4E1F205DA295\backgroundupdate.moz_log --backgroundtask backgroundup (the data entry has 4 more characters).
Task: {1AC12C42-DC1C-4FF7-85AB-74E9CBEE60BC} - System32\Tasks\Mozilla\Firefox Background Update S-1-5-21-808705873-2307071823-1975692619-1001 80E4E1F205DA295 => C:\Users\mary ann\AppData\Local\Mozilla Firefox\firefox.exe [676936 2024-06-26] (Mozilla Corporation -> Mozilla Corporation) -> C:\ProgramData\Mozilla-1de4eec8-1241-4177-a864-e594e8d1fb38\updates\80E4E1F205DA295\--MOZ_LOG sync,prependheader,timestamp,append,maxsize:1,Dump:5 --MOZ_LOG_FILE C:\ProgramData\Mozilla-1de4eec8-1241-4177-a864-e594e8d1fb38\updates\80E4E1F205DA295\backgroundupdate.moz_log --backgroundtask backgroundup (the data entry has 4 more characters).
Task: {95878FD7-7EAF-4EFD-BF0F-F68E2E844724} - System32\Tasks\Mozilla\Firefox Default Browser Agent 80E4E1F205DA295 => C:\Users\mary ann\AppData\Local\Mozilla Firefox\default-browser-agent.exe [34888 2024-06-26] (Mozilla Corporation -> Mozilla Foundation)
Task: {E974BB8A-19B5-4689-89F8-A316CDCE34D0} - System32\Tasks\OmenInstallMonitor => C:\Program Files\HP\OmenInstallMonitor\OmenInstallMonitor.exe [69592 2024-06-19] (HP Inc. -> HP Inc.)
Task: {2F6183DD-A23C-49B3-8DBA-0D378EF5D9CC} - System32\Tasks\OmenInstallMonitorCustomEvent => C:\Program Files\HP\OmenInstallMonitor\OmenInstallMonitor.exe [69592 2024-06-19] (HP Inc. -> HP Inc.)
Task: {2828F2E3-D7F1-4D01-8017-06BF8792260B} - System32\Tasks\OmenOverlay => C:\Program Files\HP\Overlay\OverlayHelper.exe [66512 2024-06-19] (HP Inc. -> HP Inc.)
Task: {0BB65447-B206-4778-BAF8-8177469E73F8} - System32\Tasks\OmenOverlayCustomEvent => C:\Program Files\HP\Overlay\OverlayHelper.exe [66512 2024-06-19] (HP Inc. -> HP Inc.)
Task: {958F91D5-AC88-4238-B9FC-E3C4C39CF7C0} - System32\Tasks\SystemOptimizer => C:\Program Files\HP\SystemOptimizer\SystemOptimizer.exe [158160 2024-06-19] (HP Inc. -> HP Inc.)
Task: {49A5861A-A5A6-4D86-9AB5-9207E35F3E3C} - System32\Tasks\SystemOptimizerCustomEvent => C:\Program Files\HP\SystemOptimizer\SystemOptimizer.exe [158160 2024-06-19] (HP Inc. -> HP Inc.)
==================== Internet (Whitelisted) ====================
(If an item is included in the fixlist, if it is a registry item it will be removed or restored to default.)
Tcpip\Parameters: [DhcpNameServer] 192.168.1.1
Tcpip\..\Interfaces\{76589a44-f848-4698-a640-9c4b72e3128b}: [DhcpNameServer] 192.168.1.1
Edge:
Edge Profile: C:\Users\mary ann\AppData\Local\Microsoft\Edge\User Data\Default [2024-07-01]
Edge Extension: (Google Docs Offline) - C:\Users\mary ann\AppData\Local\Microsoft\Edge\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2024-03-26]
Edge Extension: (Edge relevant text changes) - C:\Users\mary ann\AppData\Local\Microsoft\Edge\User Data\Default\Extensions\jmjflgjpcpepeafmmgdpfkogkghcpiha [2024-01-24]
FireFox:
FF DefaultProfile: 5h3lizib.default
FF ProfilePath: C:\Users\mary ann\AppData\Roaming\Mozilla\Firefox\Profiles\5h3lizib.default [2024-06-30]
FF ProfilePath: C:\Users\mary ann\AppData\Roaming\Mozilla\Firefox\Profiles\lopv9txo.default-release [2024-07-01]
FF Notifications: Mozilla\Firefox\Profiles\lopv9txo.default-release -> hxxps://www.truthfinder.com
FF Extension: (Capital One Shopping: Save Now) - C:\Users\mary ann\AppData\Roaming\Mozilla\Firefox\Profiles\lopv9txo.default-release\Extensions\{aff8af88-06a9-4eee-b383-3af08c47b8c8}.xpi [2024-04-05]
FF Plugin: @microsoft.com/SharePoint,version=14.0 -> C:\Program Files\Microsoft Office\root\Office16\NPSPWRAP.DLL [2024-04-05] (Microsoft Corporation -> Microsoft Corporation)
FF Plugin-x32: @microsoft.com/SharePoint,version=14.0 -> C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\NPSPWRAP.DLL [2024-04-05] (Microsoft Corporation -> Microsoft Corporation)
FF Plugin-x32: @update.avgbrowser.com/AVG Browser;version=3 -> C:\Program Files (x86)\AVG\Browser\Update\1.8.1650.5\npAvgBrowserUpdate3.dll [2024-03-02] (AVG Technologies USA, LLC -> AVG Technologies)
FF Plugin-x32: @update.avgbrowser.com/AVG Browser;version=9 -> C:\Program Files (x86)\AVG\Browser\Update\1.8.1650.5\npAvgBrowserUpdate3.dll [2024-03-02] (AVG Technologies USA, LLC -> AVG Technologies)
Chrome:
CHR Profile: C:\Users\mary ann\AppData\Local\Google\Chrome\User Data\Default [2024-07-01]
CHR HomePage: Default -> bing.com
CHR StartupUrls: Default -> "hxxps://www.google.com/"
CHR DefaultSearchURL: Default -> hxxps://www.bing.com/search?EID=MBHSE&FORM=__PARAM__DF&PC=__PARAM__&q={searchTerms}
CHR DefaultSuggestURL: Default -> hxxps://www.bing.com/osjson.aspx?FORM=__PARAM__DF&PC=__PARAM__&query={searchTerms}
CHR Extension: (Microsoft Bing Homepage & Search Engine) - C:\Users\mary ann\AppData\Local\Google\Chrome\User Data\Default\Extensions\cflanjgoamglnnocilcllegbbbfogfjc [2024-06-26]
CHR Extension: (Google Docs Offline) - C:\Users\mary ann\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2024-07-01]
CHR Extension: (Chrome Web Store Payments) - C:\Users\mary ann\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2024-02-24]
CHR HKU\S-1-5-21-808705873-2307071823-1975692619-1001\SOFTWARE\Google\Chrome\Extensions\...\Chrome\Extension: [cflanjgoamglnnocilcllegbbbfogfjc]
==================== Services (Whitelisted) ===================
S2 avg; C:\Program Files (x86)\AVG\Browser\Update\AVGBrowserUpdate.exe [209224 2024-03-02] (AVG Technologies USA, LLC -> AVG Technologies)
R2 AVG Antivirus; C:\Program Files\AVG\Antivirus\AVGSvc.exe [802744 2024-06-26] (AVG Technologies USA, LLC -> Gen Digital Inc.)
R2 AVG Firewall; C:\Program Files\AVG\Antivirus\afwServ.exe [2360248 2024-06-26] (AVG Technologies USA, LLC -> Gen Digital Inc.)
R2 AVG Tools; C:\Program Files\AVG\Antivirus\avgToolsSvc.exe [1239992 2024-06-26] (AVG Technologies USA, LLC -> Gen Digital Inc.)
R3 avgbIDSAgent; C:\Program Files\AVG\Antivirus\aswidsagent.exe [9077176 2024-06-26] (AVG Technologies USA, LLC -> AVG Technologies CZ, s.r.o.)
S3 avgm; C:\Program Files (x86)\AVG\Browser\Update\AVGBrowserUpdate.exe [209224 2024-03-02] (AVG Technologies USA, LLC -> AVG Technologies)
S3 AVGSecureBrowserElevationService; C:\Program Files\AVG\Browser\Application\126.0.25497.127\elevation_service.exe [1773384 2024-06-25] (AVG Technologies USA, LLC -> Gen Digital Inc.)
R2 AVGWscReporter; C:\Program Files\AVG\Antivirus\wsc_proxy.exe [109480 2024-01-12] (AVG Technologies USA, LLC -> AVG Technologies CZ, s.r.o.)
R2 ClickToRunSvc; C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe [14023752 2024-06-21] (Microsoft Corporation -> Microsoft Corporation)
R2 dptftcs; C:\windows\System32\DriverStore\FileRepository\dtt_sw.inf_amd64_191d9fb378307f35\ipfsvc.exe [557096 2023-06-23] (Intel Corporation -> Intel Corporation)
R2 ExpressVPNService; C:\Program Files (x86)\ExpressVPN\bootstrap\amd64\nssm.exe [439664 2022-08-16] (EXPRSVPN LLC -> ExpressVPN)
R2 HP Comm Recover; C:\Program Files\HPCommRecovery\HPCommRecovery.exe [893984 2022-08-15] (HP Inc. -> HP Inc.)
R2 hp-one-agent-service; C:\Program Files\HP\HP One Agent\hp-one-agent-service.exe [1605136 2024-05-20] (HP Inc. -> HP Inc; HP Development Company, L.P.)
R2 HPAppHelperCap; C:\windows\System32\DriverStore\FileRepository\hpcustomcapcomp.inf_amd64_e37f0d22409571ae\x64\AppHelperCap.exe [928808 2024-06-02] (HP Inc. -> HP Inc.)
R2 HPDiagsCap; C:\windows\System32\DriverStore\FileRepository\hpcustomcapcomp.inf_amd64_e37f0d22409571ae\x64\DiagsCap.exe [927792 2024-06-02] (HP Inc. -> HP Inc.)
R2 HPNetworkCap; C:\windows\System32\DriverStore\FileRepository\hpcustomcapcomp.inf_amd64_e37f0d22409571ae\x64\NetworkCap.exe [923584 2024-06-02] (HP Inc. -> HP Inc.)
R2 HPSysInfoCap; C:\windows\System32\DriverStore\FileRepository\hpcustomcapcomp.inf_amd64_e37f0d22409571ae\x64\SysInfoCap.exe [928704 2024-06-02] (HP Inc. -> HP Inc.)
R2 HpTouchpointAnalyticsService; C:\windows\System32\DriverStore\FileRepository\hpanalyticscomp.inf_amd64_7dcf4ebd9d1b4772\x64\TouchpointAnalyticsClientService.exe [569008 2024-05-07] (HP Inc. -> HP Inc.)
S3 IDriverT; C:\Program Files (x86)\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe [73728 2004-10-22] (Macrovision Corporation) [File not signed]
S2 Intel(R) Platform License Manager Service; C:\windows\System32\DriverStore\FileRepository\iclsclient.inf_amd64_4e9e8c349f3a1aca\lib\PlatformLicenseManagerService.exe [741584 2023-10-25] (Intel Corporation -> Intel(R) Corporation)
R2 IntelAudioService; C:\windows\System32\DriverStore\FileRepository\intcoed.inf_amd64_29fd1afabcf5470c\AS\IAS\IntelAudioService.exe [530520 2023-10-18] (Intel Corporation -> Intel)
R2 ipfsvc; C:\windows\System32\DriverStore\FileRepository\ipf_cpu.inf_amd64_ac13c23bf8b4219a\ipf_uf.exe [2999912 2023-06-27] (Intel Corporation -> Intel Corporation)
R2 SacNetAgentService_C57C4F854F53; C:\ProgramData\OfficeGuardianV2N\Reminder\SacNetAgent.exe [163664 2010-11-18] (Storage Appliance Corporation -> Storage Appliance Corporation)
R2 ScreenConnect Client (875745c2-2c6c-44d9-94e6-f9f7739195dd); C:\Users\mary ann\AppData\Local\Apps\2.0\QN4P3DWA.NPN\VQCN9APE.Z4M\scre..tion_25b0fbb6ef7eb094_0018.0001_51e59eb280deee18\ScreenConnect.ClientService.exe [95520 2024-06-26] (Connectwise, LLC -> )
S3 WdNisSvc; C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24020.7-0\NisSrv.exe [3191272 2024-03-12] (Microsoft Windows Publisher -> Microsoft Corporation)
S3 WinDefend; C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24020.7-0\MsMpEng.exe [133688 2024-03-12] (Microsoft Windows Publisher -> Microsoft Corporation)
R2 CFUACProxy_officeguardianv2n; "C:\ProgramData\OfficeGuardianV2N\UACProxy.exe" -s "-pC:\ProgramData\OfficeGuardianV2N"
===================== Drivers (Whitelisted) ===================
R0 avgArDisk; C:\windows\System32\drivers\avgArDisk.sys [20544 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R1 avgArPot; C:\windows\System32\drivers\avgArPot.sys [229952 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R1 avgbidsdriver; C:\windows\System32\drivers\avgbidsdriver.sys [380992 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R0 avgbidsh; C:\windows\System32\drivers\avgbidsh.sys [292936 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R0 avgbuniv; C:\windows\System32\drivers\avgbuniv.sys [84544 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R0 avgElam; C:\windows\System32\drivers\avgElam.sys [27760 2024-02-24] (Microsoft Windows Early Launch Anti-malware Publisher -> Gen Digital Inc.)
R1 avgKbd; C:\windows\System32\drivers\avgKbd.sys [28736 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R1 avgMonFlt; C:\windows\System32\drivers\avgMonFlt.sys [271944 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R1 avgNetHub; C:\windows\System32\drivers\avgNetHub.sys [548928 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R1 avgRdr; C:\windows\System32\drivers\avgRdr2.sys [97856 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R0 avgRvrt; C:\windows\System32\drivers\avgRvrt.sys [69184 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R1 avgSnx; C:\windows\System32\drivers\avgSnx.sys [942536 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R1 avgSP; C:\windows\System32\drivers\avgSP.sys [1195992 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R3 avgStm; C:\windows\System32\drivers\avgStm.sys [203736 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
R0 avgVmm; C:\windows\System32\drivers\avgVmm.sys [306648 2024-06-26] (Microsoft Windows Hardware Compatibility Publisher -> Gen Digital Inc.)
S3 BthHFEnum; C:\windows\System32\drivers\bthhfenum.sys [184320 2023-04-21] (Microsoft Corporation) [File not signed]
S3 BTHMODEM; C:\windows\System32\drivers\bthmodem.sys [106496 2023-04-21] (Microsoft Corporation) [File not signed]
S3 CtaChildDriver; C:\windows\System32\drivers\CtaChildDriver.sys [55776 2023-02-14] (Intel Corporation -> )
R3 expressvpntun; C:\windows\System32\drivers\expressvpn-tun.sys [56552 2022-08-16] (Express VPN International Ltd. -> ExpressVPN)
R0 fse; C:\windows\System32\drivers\fse.sys [218608 2024-06-12] (Microsoft Windows -> Microsoft Corporation)
S3 GSCAuxDriver; C:\windows\System32\DriverStore\FileRepository\gscauxdriver.inf_amd64_3b711bdc1649d583\GSCAuxDriverx64.sys [109040 2023-02-14] (Intel Corporation -> Intel Corporation)
S3 GSCx64; C:\windows\System32\DriverStore\FileRepository\gscheci.inf_amd64_3658d9d706e4cea6\TeeDriverGSCW8x64.sys [278584 2023-02-14] (Intel Corporation -> Intel Corporation)
R3 HPCustomCapDriver; C:\windows\System32\DriverStore\FileRepository\hpcustomcapdriver.inf_amd64_a955fa431e522f5e\x64\hpcustomcapdriver.sys [26648 2022-06-23] (HP Inc. -> HP Inc.)
R2 HpReadHWData; C:\windows\system32\drivers\HpReadHWData.sys [53368 2024-01-14] (HP Inc. -> Windows (R) Win 7 DDK provider)
R3 iaLPSS2_GPIO2_ADL; C:\windows\System32\DriverStore\FileRepository\ialpss2_gpio2_adl.inf_amd64_bda8110c074a36f5\iaLPSS2_GPIO2_ADL.sys [141312 2023-07-24] (Intel Corporation -> Intel Corporation)
R3 iaLPSS2_I2C_ADL; C:\windows\System32\DriverStore\FileRepository\ialpss2_i2c_adl.inf_amd64_c4c17f8529a3943d\iaLPSS2_I2C_ADL.sys [211456 2023-07-24] (Intel Corporation -> Intel Corporation)
S3 iaLPSS2_SPI_ADL; C:\windows\System32\DriverStore\FileRepository\ialpss2_spi_adl.inf_amd64_334c460fea9b11a4\iaLPSS2_SPI_ADL.sys [171608 2022-12-15] (Intel Corporation -> Intel Corporation)
S3 iaLPSS2_UART2_ADL; C:\windows\System32\DriverStore\FileRepository\ialpss2_uart2_adl.inf_amd64_43d5df63d19fde70\iaLPSS2_UART2_ADL.sys [329320 2022-12-15] (Intel Corporation -> Intel Corporation)
R3 IntelGNA; C:\windows\System32\DriverStore\FileRepository\gna.inf_amd64_04d4eecc5838a558\gna.sys [88776 2022-08-29] (Intel Corporation -> Intel Corporation)
S3 Intel_NF_I2C; C:\windows\System32\DriverStore\FileRepository\intel_nf_i2c_child.inf_amd64_a329fd450939b60d\Intel_NF_I2C.sys [222688 2023-02-14] (Intel Corporation -> Intel Corporation)
R3 ipf_acpi; C:\windows\System32\DriverStore\FileRepository\ipf_acpi.inf_amd64_4c3f63d0ffe9d9b8\ipf_acpi.sys [88632 2023-06-27] (Intel Corporation -> Intel Corporation)
R3 ipf_cpu; C:\windows\System32\DriverStore\FileRepository\ipf_cpu.inf_amd64_ac13c23bf8b4219a\ipf_cpu.sys [85560 2023-06-27] (Intel Corporation -> Intel Corporation)
R3 ipf_lf; C:\windows\System32\DriverStore\FileRepository\ipf_cpu.inf_amd64_ac13c23bf8b4219a\ipf_lf.sys [481896 2023-06-27] (Intel Corporation -> Intel Corporation)
S3 LT6911Au; C:\windows\System32\DriverStore\FileRepository\lt6911au.inf_amd64_62449180becc5735\LT6911Au.sys [66728 2023-03-23] (Intel Corporation -> Intel(R) Corporation)
S3 rtux64w10; C:\windows\System32\DriverStore\FileRepository\rtux64w10.inf_amd64_03831aeaaa2c730e\rtux64w10.sys [683520 2022-05-07] (Microsoft Windows -> Realtek Corporation)
S3 scsiscan; C:\windows\system32\DRIVERS\scsiscan.sys [57344 2024-01-12] (Microsoft Windows -> Microsoft Corporation)
S3 vmbusproxy; C:\windows\system32\drivers\vmbusproxy.sys [94208 2024-01-12] (Microsoft Windows -> )
S3 WdBoot; C:\windows\system32\drivers\wd\WdBoot.sys [20928 2024-03-12] (Microsoft Windows Early Launch Anti-malware Publisher -> Microsoft Corporation)
S3 WdFilter; C:\windows\system32\drivers\wd\WdFilter.sys [603416 2024-03-12] (Microsoft Windows -> Microsoft Corporation)
S3 WdNisDrv; C:\windows\System32\drivers\wd\WdNisDrv.sys [105752 2024-03-12] (Microsoft Windows -> Microsoft Corporation)
==================== NetSvcs (Whitelisted) ===================
==================== One month (created) (Whitelisted) =========
(If an entry is included in the fixlist, the file/folder will be moved.)
2024-07-01 16:54 - 2024-07-01 16:54 - 000000000 ____D C:\Users\mary ann\Downloads\FRST-OlderVersion
2024-07-01 11:26 - 2024-07-01 11:26 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(17).txt
2024-07-01 11:19 - 2024-07-01 11:19 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist.txt
2024-07-01 11:19 - 2024-07-01 11:19 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(16).txt
2024-06-30 18:38 - 2024-06-30 18:38 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(15).txt
2024-06-30 18:37 - 2024-06-30 18:37 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(14).txt
2024-06-30 18:32 - 2024-06-30 18:32 - 000001684 _____ C:\Users\mary ann\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\FRST64 - Shortcut (2).lnk
2024-06-30 18:31 - 2024-06-30 18:31 - 000001537 _____ C:\Users\mary ann\Desktop\FRST64(2) - Shortcut ().lnk
2024-06-30 16:29 - 2024-06-30 16:29 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(13).txt
2024-06-30 16:22 - 2024-06-30 16:22 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(12).txt
2024-06-30 16:19 - 2024-06-30 16:19 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist-7.txt
2024-06-30 16:19 - 2024-06-30 16:19 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist-6.txt
2024-06-30 16:18 - 2024-06-30 16:18 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist-5.txt
2024-06-30 16:14 - 2024-06-30 16:14 - 000000000 _____ C:\Users\mary ann\Downloads\New Text Document (2).txt
2024-06-30 16:12 - 2024-06-30 16:12 - 000001027 _____ C:\Users\mary ann\Desktop\FRST64(1) - Shortcut.lnk
2024-06-30 16:08 - 2024-06-27 19:25 - 002395648 _____ (Farbar) C:\Users\mary ann\Documents\FRST64(1).exe
2024-06-30 16:04 - 2024-06-30 16:04 - 000000000 ____D C:\Users\mary ann\Downloads\New folder (2)
2024-06-30 16:02 - 2024-06-30 16:02 - 000000000 ____D C:\Users\mary ann\Downloads\New folder
2024-06-30 16:01 - 2024-06-30 16:01 - 000000000 _____ C:\Users\mary ann\Downloads\New Text Document.txt
2024-06-30 15:56 - 2024-06-27 19:11 - 002395648 _____ (Farbar) C:\Users\mary ann\Documents\FRST64.exe
2024-06-30 15:45 - 2024-06-30 15:45 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(11).txt
2024-06-30 15:44 - 2024-06-30 15:44 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(10).txt
2024-06-30 15:43 - 2024-06-30 15:43 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(9).txt
2024-06-30 15:31 - 2024-06-30 15:31 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(8).txt
2024-06-30 15:27 - 2024-06-30 15:27 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(7).txt
2024-06-30 15:27 - 2024-06-30 15:27 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(6).txt
2024-06-30 15:27 - 2024-06-30 15:27 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(5).txt
2024-06-30 15:26 - 2024-06-30 15:26 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(4).txt
2024-06-30 15:26 - 2024-06-30 15:26 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(3).txt
2024-06-30 15:02 - 2024-06-30 18:38 - 000002179 _____ C:\Users\mary ann\Downloads\Fixlog.txt
2024-06-30 15:01 - 2024-06-30 15:01 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(2).txt
2024-06-30 14:57 - 2024-06-30 14:57 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist(1).txt
2024-06-30 14:54 - 2024-06-30 14:54 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist-4.txt
2024-06-30 14:53 - 2024-06-30 14:53 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist-3.txt
2024-06-30 14:53 - 2024-06-30 14:53 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist-2.txt
2024-06-30 14:53 - 2024-06-30 14:53 - 000000543 _____ C:\Users\mary ann\Downloads\fixlist-1.txt
2024-06-29 20:54 - 2024-06-29 20:54 - 000003332 _____ C:\windows\system32\Tasks\SystemOptimizerCustomEvent
2024-06-29 20:54 - 2024-06-29 20:54 - 000002892 _____ C:\windows\system32\Tasks\SystemOptimizer
2024-06-29 16:52 - 2024-06-29 16:52 - 012365296 _____ (McAfee, LLC) C:\Users\mary ann\Downloads\MCPR.exe
2024-06-29 16:50 - 2024-06-29 16:50 - 000002334 _____ C:\Users\mary ann\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\McAfee LLC.lnk
2024-06-29 16:49 - 2024-06-29 16:49 - 002397032 _____ (LogMeIn, Inc.) C:\Users\mary ann\Downloads\Support-LogMeInRescue.exe
2024-06-29 15:01 - 2024-06-29 15:01 - 000223878 _____ C:\Users\mary ann\Downloads\MicrosoftProgram_Install_and_Uninstall.meta.diagcab
2024-06-28 15:58 - 2024-06-29 17:40 - 000038421 _____ C:\Users\mary ann\Downloads\Addition.txt
2024-06-28 15:57 - 2024-07-01 16:54 - 000036640 _____ C:\Users\mary ann\Downloads\FRST.txt
2024-06-28 15:57 - 2024-07-01 16:54 - 000000000 ____D C:\FRST
2024-06-28 15:28 - 2024-06-30 18:32 - 000001512 _____ C:\Users\mary ann\Desktop\FRST64 - Shortcut (2).lnk
2024-06-28 11:47 - 2024-06-30 15:54 - 000001512 _____ C:\Users\mary ann\Desktop\FRST64 - Shortcut.lnk
2024-06-27 19:25 - 2024-07-01 16:54 - 002395648 _____ (Farbar) C:\Users\mary ann\Downloads\FRST64(1).exe
2024-06-26 18:11 - 2024-06-26 18:10 - 000314816 _____ (Gen Digital Inc.) C:\windows\system32\avgBoot.exe
2024-06-26 18:11 - 2024-06-26 17:54 - 000000568 _____ C:\windows\SysWOW64\user.config
2024-06-26 18:09 - 2024-06-26 18:09 - 000234888 _____ (AVG Technologies CZ, s.r.o.) C:\Users\mary ann\Downloads\avg_antivirus_free_setup (1).exe
2024-06-26 18:09 - 2024-06-26 18:09 - 000234888 _____ (AVG Technologies CZ, s.r.o.) C:\Users\mary ann\Desktop\avg_antivirus_free_setup (1).exe
2024-06-26 15:20 - 2024-06-30 11:32 - 000000000 ____D C:\Users\mary ann\AppData\Local\Deployment
2024-06-26 15:20 - 2024-06-26 15:20 - 000000568 _____ C:\windows\system32\user.config
2024-06-26 15:20 - 2024-06-26 15:20 - 000000000 ____D C:\Users\mary ann\AppData\Local\Apps\2.0
2024-06-26 15:19 - 2024-06-26 15:19 - 000086304 _____ C:\Users\mary ann\Downloads\support.Client.exe
2024-06-26 12:02 - 2024-07-01 16:07 - 000000000 ____D C:\Users\mary ann\AppData\Local\Mozilla Firefox
2024-06-20 08:33 - 2024-06-20 08:33 - 000000000 _____ C:\Users\mary ann\Downloads\6Hp4nfE6.htm
2024-06-12 19:40 - 2024-06-12 19:40 - 000024821 _____ C:\windows\SysWOW64\IntegratedServicesRegionPolicySet.json
2024-06-12 19:37 - 2024-06-12 19:37 - 000024821 _____ C:\windows\system32\IntegratedServicesRegionPolicySet.json
2024-06-12 19:22 - 2024-06-12 19:30 - 000000000 ___HD C:\$WinREAgent
2024-06-07 13:58 - 2024-06-07 14:00 - 000000000 ____D C:\ProgramData\PC Cleaner
2024-06-07 13:58 - 2024-06-07 13:58 - 007867760 _____ (PC Helpsoft ) C:\Users\mary ann\Downloads\PC_Cleaner_setup.exe
2024-06-02 15:49 - 2024-06-02 15:49 - 000000000 ____D C:\Program Files\Common Files\DESIGNER
==================== One month (modified) ==================
2024-07-01 16:43 - 2022-05-07 01:24 - 000000000 ____D C:\ProgramData\regid.1991-06.com.microsoft
2024-07-01 16:08 - 2024-01-10 15:05 - 000000000 ____D C:\ProgramData\Mozilla-1de4eec8-1241-4177-a864-e594e8d1fb38
2024-07-01 16:06 - 2022-11-03 00:39 - 000855938 _____ C:\windows\system32\PerfStringBackup.INI
2024-07-01 16:06 - 2022-05-07 01:22 - 000000000 ____D C:\windows\INF
2024-07-01 16:04 - 2024-04-23 13:30 - 000004172 _____ C:\windows\system32\Tasks\User_Feed_Synchronization-{B7E812A0-8F9B-484B-BB1A-FEA794A52B0F}
2024-07-01 16:04 - 2024-01-14 19:12 - 000000000 ____D C:\Users\mary ann\AppData\Local\OGH
2024-07-01 16:04 - 2024-01-10 12:04 - 000000000 ____D C:\Users\mary ann\AppData\Local\D3DSCache
2024-07-01 16:04 - 2022-05-07 01:24 - 000000000 ____D C:\windows\SystemTemp
2024-07-01 16:02 - 2022-11-03 00:32 - 000000006 ____H C:\windows\Tasks\SA.DAT
2024-07-01 16:02 - 2022-05-07 01:24 - 000000000 ____D C:\windows\ServiceState
2024-07-01 16:01 - 2022-11-03 00:32 - 000012288 ___SH C:\DumpStack.log.tmp
2024-07-01 15:10 - 2024-01-12 17:23 - 000000000 ____D C:\ProgramData\AVG
2024-07-01 15:10 - 2022-05-07 01:17 - 001048576 _____ C:\windows\system32\config\BBI
2024-07-01 14:51 - 2024-03-02 09:45 - 000002328 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AVG Secure Browser.lnk
2024-07-01 14:51 - 2024-03-02 09:45 - 000002293 _____ C:\Users\Public\Desktop\AVG Secure Browser.lnk
2024-07-01 14:18 - 2022-11-03 00:32 - 000000000 ____D C:\windows\system32\SleepStudy
2024-07-01 11:46 - 2022-05-07 01:24 - 000000000 ____D C:\windows\AppReadiness
2024-07-01 11:43 - 2023-09-01 10:25 - 000000000 ____D C:\ProgramData\Package Cache
2024-07-01 09:44 - 2024-01-12 18:07 - 000000000 ____D C:\Users\mary ann\AppData\Local\AVG
2024-06-30 18:44 - 2024-01-20 02:40 - 000000752 _____ C:\Users\mary ann\Documents\Downloads - Shortcut.lnk
2024-06-30 18:25 - 2024-02-28 23:14 - 000000000 ____D C:\Users\mary ann\AppData\Roaming\Microsoft\MMC
2024-06-30 18:04 - 2024-01-10 12:02 - 000000000 ____D C:\Users\mary ann\AppData\Local\Packages
2024-06-30 09:14 - 2022-11-03 00:35 - 000000000 ____D C:\ProgramData\Packages
2024-06-30 09:14 - 2022-05-07 01:24 - 000000000 ___HD C:\Program Files\WindowsApps
2024-06-29 20:54 - 2024-01-30 23:02 - 000003356 _____ C:\windows\system32\Tasks\OmenInstallMonitorCustomEvent
2024-06-29 20:54 - 2024-01-30 23:02 - 000003296 _____ C:\windows\system32\Tasks\OmenOverlayCustomEvent
2024-06-29 20:54 - 2024-01-30 12:38 - 000002754 _____ C:\windows\system32\Tasks\HPOneAgentRepairTask
2024-06-29 20:54 - 2024-01-25 15:43 - 000000000 ____D C:\windows\system32\Tasks\AVAST Software
2024-06-29 20:54 - 2024-01-14 19:14 - 000002916 _____ C:\windows\system32\Tasks\OmenInstallMonitor
2024-06-29 20:54 - 2024-01-14 19:14 - 000002856 _____ C:\windows\system32\Tasks\OmenOverlay
2024-06-29 20:54 - 2024-01-10 12:06 - 000003062 _____ C:\windows\system32\Tasks\OneDrive Reporting Task-S-1-5-21-808705873-2307071823-1975692619-1001
2024-06-29 20:54 - 2024-01-10 12:06 - 000002858 _____ C:\windows\system32\Tasks\OneDrive Standalone Update Task-S-1-5-21-808705873-2307071823-1975692619-1001
2024-06-29 20:54 - 2023-09-01 10:53 - 000002854 _____ C:\windows\system32\Tasks\OneDrive Standalone Update Task-S-1-5-21-808705873-2307071823-1975692619-500
2024-06-29 20:54 - 2023-04-21 14:32 - 000000000 ____D C:\Program Files\HP
2024-06-29 20:54 - 2022-11-03 00:32 - 000003464 _____ C:\windows\system32\Tasks\MicrosoftEdgeUpdateTaskMachineUA
2024-06-29 20:54 - 2022-11-03 00:32 - 000003240 _____ C:\windows\system32\Tasks\MicrosoftEdgeUpdateTaskMachineCore
2024-06-29 20:53 - 2023-04-21 14:33 - 000000000 ____D C:\Program Files\Microsoft Office
2024-06-29 17:51 - 2024-01-10 12:02 - 000000000 ____D C:\Users\mary ann
2024-06-29 17:20 - 2024-01-13 15:58 - 000000000 ____D C:\Users\mary ann\AppData\Local\CrashDumps
2024-06-29 17:14 - 2023-04-21 14:27 - 000001623 _____ C:\windows\system32\config\VSMIDK
2024-06-29 17:11 - 2022-05-07 01:24 - 000000000 ___HD C:\windows\ELAMBKUP
2024-06-29 10:26 - 2022-11-03 00:32 - 000002445 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Edge.lnk
2024-06-29 10:26 - 2022-11-03 00:32 - 000002283 _____ C:\Users\Public\Desktop\Microsoft Edge.lnk
2024-06-28 11:28 - 2024-01-10 12:06 - 000002395 _____ C:\Users\mary ann\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\OneDrive.lnk
2024-06-26 18:12 - 2024-01-12 17:25 - 000002006 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AVG AntiVirus Free.lnk
2024-06-26 18:12 - 2024-01-12 17:25 - 000001994 _____ C:\Users\Public\Desktop\AVG AntiVirus Free.lnk
2024-06-26 18:11 - 2024-02-24 13:05 - 000942536 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgSnx.sys
2024-06-26 18:11 - 2024-01-12 17:25 - 000000000 ____D C:\windows\system32\Tasks\AVG
2024-06-26 18:10 - 2024-02-24 13:05 - 000380992 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgbidsdriver.sys
2024-06-26 18:10 - 2024-02-24 13:05 - 000306648 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgVmm.sys
2024-06-26 18:10 - 2024-02-24 13:05 - 000292936 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgbidsh.sys
2024-06-26 18:10 - 2024-02-24 13:05 - 000229952 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgArPot.sys
2024-06-26 18:10 - 2024-02-24 13:05 - 000084544 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgbuniv.sys
2024-06-26 18:10 - 2024-02-24 13:05 - 000028736 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgKbd.sys
2024-06-26 18:10 - 2024-01-12 17:24 - 001195992 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgSP.sys
2024-06-26 18:10 - 2024-01-12 17:24 - 000548928 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgNetHub.sys
2024-06-26 18:10 - 2024-01-12 17:24 - 000271944 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgMonFlt.sys
2024-06-26 18:10 - 2024-01-12 17:24 - 000097856 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgRdr2.sys
2024-06-26 18:10 - 2024-01-12 17:24 - 000069184 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgRvrt.sys
2024-06-26 18:10 - 2024-01-12 17:24 - 000020544 _____ (Gen Digital Inc.) C:\windows\system32\Drivers\avgArDisk.sys
2024-06-26 16:45 - 2024-02-24 14:36 - 000002254 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
2024-06-26 16:45 - 2024-02-24 14:36 - 000002213 _____ C:\Users\Public\Desktop\Google Chrome.lnk
2024-06-26 12:16 - 2024-01-10 15:05 - 000000000 ____D C:\windows\system32\Tasks\Mozilla
2024-06-25 18:35 - 2022-05-07 01:24 - 000000000 ____D C:\windows\LiveKernelReports
2024-06-13 14:46 - 2024-01-12 17:26 - 000000000 ____D C:\windows\system32\MRT
2024-06-13 14:44 - 2024-01-12 17:26 - 199048176 ____C (Microsoft Corporation) C:\windows\system32\MRT.exe
2024-06-12 19:57 - 2022-11-03 00:32 - 000535312 _____ C:\windows\system32\FNTCACHE.DAT
2024-06-12 19:56 - 2024-01-12 17:29 - 000000000 ____D C:\windows\system32\Microsoft-Edge-WebView
2024-06-12 19:56 - 2024-01-12 17:29 - 000000000 ____D C:\windows\InboxApps
2024-06-12 19:56 - 2023-09-01 11:10 - 000000000 ____D C:\windows\TextInput
2024-06-12 19:56 - 2023-09-01 11:10 - 000000000 ____D C:\windows\HoloShell
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ___SD C:\windows\system32\UNP
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ___RD C:\windows\PrintDialog
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ___RD C:\windows\ImmersiveControlPanel
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\UUS
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\SysWOW64\WinMetadata
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\SysWOW64\setup
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\SysWOW64\Dism
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\SystemResources
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\system32\WinMetadata
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\system32\WinBioPlugIns
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\system32\ShellExperiences
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\system32\Sgrm
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\system32\setup
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\system32\PerceptionSimulation
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\system32\oobe
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\system32\migwiz
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\system32\Dism
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\system32\appraiser
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\ShellExperiences
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\ShellComponents
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\BrowserCore
2024-06-12 19:56 - 2022-05-07 01:24 - 000000000 ____D C:\windows\bcastdvr
2024-06-12 19:56 - 2022-05-07 01:17 - 000000000 ____D C:\windows\servicing
2024-06-12 19:49 - 2022-05-07 01:17 - 000000000 ____D C:\windows\CbsTemp
2024-06-12 19:48 - 2022-05-07 02:10 - 000036864 _____ (Microsoft Corporation) C:\windows\system32\OEMDefaultAssociations.dll
2024-06-12 19:48 - 2022-05-07 02:10 - 000024383 _____ C:\windows\system32\OEMDefaultAssociations.xml
2024-06-12 19:48 - 2022-05-07 01:25 - 000077312 _____ (Khronos Group) C:\windows\SysWOW64\opencl.dll
2024-06-12 19:48 - 2022-05-07 01:24 - 000118784 _____ (Khronos Group) C:\windows\system32\opencl.dll
2024-06-12 19:46 - 2022-05-07 01:24 - 000000000 ____D C:\ProgramData\USOPrivate
2024-06-12 19:40 - 2022-11-03 00:34 - 003216384 _____ (Microsoft Corporation) C:\windows\SysWOW64\PrintConfig.dll
==================== SigCheck ============================
(There is no automatic fix for files that do not pass verification.)
==================== End of FRST.txt ========================
mare_wbpa
No, Mary Ann.  You can find it in your Downloads folder in the location in bold below.  Note that it will have the time stamp for today, also shown in bold.
