Pale Moon Version 33.7.2 Released with Security Updates
Started by Corrine, June 03, 2025, 12:04:53 PM
Pale Moon has been updated to version 33.7.2.  This is a security update.
Changes/fixes:
  • Addressed PWN2OWN-2025-1 (out of bounds read or write in promise) DiD.
  • Addressed PWN2OWN-2025-2 (out of bounds read or write when using the ExtractLinearSum optimization) DiD.
  • Fixed potential unexpected behavior in embedded protobuf code. DiD.
  • Fixed an issue with potentially uninitialized contrast values when enhanced device contrast values can not be read from the O.S. DiD.
  • Fixed potential sanitization issues with devtools' "Copy as curl" feature. It should be noted that we do not currently offer cross-platform "curl" features, so this is another DiD for this release.
Notes:  *DiD This means that a fix is "Defense-in-Depth": It is a fix that does not apply to a (potentially) actively exploitable vulnerability in Pale Moon, but prevents future vulnerabilities caused by the same code, e.g. when surrounding code changes, exposing the problem, or when new attack vectors are discovered.
Release Cycle
