computer hacked
mare_wbpa
mare_wbpa
I noticed that  there is a McAfee LLC in my list of apps. i thought that I had McAfee completely cleaned out.
Mary Ann, please wait for DR M's instructions.
mare_wbpa
mare_wbpa
Hi, Mary Ann.
I saw that you called McAfee to assist you remove the program. From a quick look I took in your logs, it seems that several tools have been used during the remote procedure.
I'll repeat here the following, and please have it in mind while we are dealing with the cleaning procedure here:
Do not do anything if there is something you don't understand. Just ask me here.
Do not download anything, unless I ask you to do so.
Is that fine with you? Please, let me know, before we move on.
mare_wbpa
You're the boss. Lead on
Quote from: mare_wbpa on June 30, 2024, 05:57:29 PMYou're the boss. Lead on
Good. 🙂
So, let's take it from the beginning:
1. FRST fix
Please do the following to run a FRST fix.
  • Download the attached fixlist.txt (see at the end of my reply, the attached file has a clip icon beside it), and save it at the same place where FRST tool is. Right now, it's in your Downloads folder.
  • Right-click on FRST64 in your Downloads folder, to run it as administrator. When the tool opens, click "yes" to the disclaimer.
  • When finished, it will produce a log fixlog.txt in your Downloads folder.
  • Post the log in your next reply.
In your next reply please post:
  • The fixlog.txt
mare_wbpa
I'm doing simething. i'm not getting yes when I rt click
When you right click, you will choose Run as administrator.
mare_wbpa
I should download fixlist with clip then whhat
Quote from: mare_wbpa on June 30, 2024, 06:56:46 PMI should download fixlist with clip then whhat
Mary Ann, everything is listed in my instructions above.
Quote from: DR M on June 30, 2024, 06:11:31 PM1. FRST fix
The second bullet tells you what you do after downloading the fixlist.txt.
mare_wbpa
Can you please be more specific?
What did you do?
What do you mean you got locked out?
mare_wbpa
I download fixlst text then get stuck there
