Windows Insider Canary Channel
Started by Corrine, March 08, 2023, 08:02:39 PM
Announcing Windows 11 Insider Preview Build 27749 (Canary Channel)
Changes and Improvements
[Narrator]
  • We have added a new shortcut "Narrator key + control + X" to copy what Narrator last spoke to clipboard. It follows the pattern of using "Narrator key + X" which repeats the last spoken phrase out loud and is a good way to memorize similar shortcuts. You can use these shortcuts to review and copy what Narrator spoke, useful in cases you want to quickly copy some content or descriptions or codes/numbers for use.
  • Narrator will now auto-read contents of a mail in the new Outlook app similar to behavior in Outlook classic.
Fixes
[File Explorer]
  • Fixed an issue which was causing the items in the navigation pane to become very spread out (with unexpected padding between each item) for some people.
  • Fixed an underlying issue which was causing RAW images taken in portrait mode to unexpectedly display in landscape mode thumbnails.
[Taskbar & System Tray]
  • Made a change so you will now see a search box if the taskbar auto-hides when the setting for search on the taskbar is set to "Search box" (rather than an icon).
[Input]
  • Updated the mouse option "Show location of pointer when I press the CTRL key", so that the circles displayed are now DPI-aware, and aren't really small on high DPI monitors.
[Narrator]
  • We have addressed a performance issue where Narrator would slow down after 15 minutes of continuous use with a single application. If you continue to experience any performance delays, do report using Feedback Hub.
  • Fixed an issue where Narrator would add an additional announcement "contains style" whenever its focus is on text that has styling attributes such as bullets, numbers across applications such as Microsoft Edge, Teams, Outlook, etc.
  • Fixed an issue where few dialogs in Narrator were not adopting the 200% text scaling setting in Windows.
[Task Manager]
  • Fixed an issue causing Task Manager to show a 0 count for apps and processes.
[Audio]
  • Fixed an underlying issue that could lead to the audio on certain audio devices unexpectedly going to 100% on boot or after sleep.
  • Fixed a blank entry in Settings > Privacy, which was crashing Settings if you clicked it.
[Other]
  • Mitigated an issue resulting in Git not working for Insiders with Arm PCs in the previous flight.
  • Fixed an issue causing some insiders to see a bugcheck with KERNEL_MODE_HEAP_CORRUPTION in the previous flight.
  • Fixed an underlying issue which could potentially lead to not being able to join a domain.
  • Fixed an issue where DirectAccess wasn't working and might stay stuck in a connecting state.
Announcing Windows 11 Insider Preview Build 27754 (Canary Channel)
Modernized Windows Hello
At Microsoft, we are committed to security and enhancing user experiences. As part of this commitment, we launched enhanced passkey features in September 2023 and are now revamping the Windows Hello user experience. This represents a significant update to Windows Hello, aligning it with contemporary Windows visual design standards. The primary focus is on making authentication intuitive and seamless.
Modernized Windows Hello Visual Communication: The updated Windows Hello visuals are designed to facilitate fast and clear communication and appear on the Windows Sign-in screen as well as other authentication flows such as passkey, Microsoft Store and many more.
Revamped Windows Hello credential user experience for passkeys and the new administrator protection experience: We redesigned Windows security credential user experiences for passkey creating a cleaner experience that supports secured and quick authentication. Users will now be able to switch between authentication options and select passkey/devices more intuitively.
This experience will also apply for the new administrator protection feature coming to Windows 11, version 24H2 and higher and currently in preview with Windows Insiders in the most recent Canary Channel builds. For more information on administrator protection – you can check out this blog post that highlights our investments in adminlesss experiences in Windows from Microsoft Ignite.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Security and Privacy > Passwordless experience.
[General]
  • If you hold Shift and CTRL when clicking on a jump list item in Start menu or taskbar, this will now launch that item as admin, just like if you were to do Shift + CTRL and click the app icon itself. For example, if you right-click on Windows Terminal, and hold Shift and CTRL when you click PowerShell, it would open a PowerShell window as admin.
  • We've updated the previews that show when you mouse-over/hover over apps on the taskbar. We have also improved the animations for when these previews show on the taskbar based on Insider feedback.
  • We are trying out a more simplified system tray to highlight the date/time in a shortened form and to show the notifications bell icon based on DND status. Without the notification bell icon, you can get to your notifications by clicking the date and time to Notification Center. You can revert to the long form of the date/time and bell icon visuals by toggling the values in the Settings via Settings > Date and Time under "Show time and day in the system tray" and Settings > System > Notifications under "Notifications". These settings are also accessible through the context menu shown by right clicking the system tray clock/bell icon button.
Fixes
[General]
  • Fixed the issue with applying policy for the Digital Markets Act in EEA regions in Build 27749.
  • Fixed an issue where an update failing and rolling back could potentially result in a duplicate Windows entry in the boot menu.
[File Explorer]
  • Did some work so the search box in File Explorer shouldn't draw off the end of the window anymore.
  • Fixed an issue on secondary monitors for left aligned taskbar users, where the widgets text in the taskbar might overlap the date and time.
[Input]
  • Fixed an underlying issue which could cause the mouse to unlock from a game window on a system with multiple monitors after opening and closing Game Bar, so you couldn't use it within the game.
[Other]
  • Fixed an underlying issue causing some apps used for remoting into other PCs to crash in the latest Canary builds.
  • Fixed an issue causing some Insiders to see bugchecks with SYSTEM THREAD EXCEPTION NOT HANDLED in the latest Canary builds.
  • Fixed an issue where sfc /scannow was unexpectedly showing errors every time it was run.
  • Fixed an underlying issue which could lead to Registry Editor going unresponsive if you pressed Alt after clicking on the license information in the About section.
Announcing Windows 11 Insider Preview Build 27758 (Canary Channel)
Fixes
[File Explorer]
[Taskbar]
  • Fixed an issue where right clicking on app icons in the taskbar might crash explorer.exe in the previous flight.
[Input]
  • Fixed an issue for some people where the mouse cursor would become invisible when hovering over text fields in certain apps.
[Desktop]
  • Fixed an issue where your desktop background might not show correctly sometimes with multiple monitors (showing big black areas).
[Task Manager]
  • We are beginning to roll out a fix for the issue where if you resized Task Manager to be larger while settings was open, the Mica background wouldn't align with the new window size.
[Narrator]
  • Fixed an issue in the previous flight which caused Narrator to crash on launch if you used one of the natural voices (like Jenny).
[Audio]
  • Fixed an underlying issue which could lead to USB audio devices going to sleep after 1 minute of idle time, and not waking up until the PC was rebooted.
  • Fixed an underlying issue which could lead you to unexpectedly hear a mute or unmute noise in certain headsets.
[Settings]
  • Fixed an issue which could cause Settings to crash when selecting your default audio device.
[Other]
  • Fixed an issue which could cause an unexpected black line along the top border of a window.
Announcing Windows 11 Insider Preview Build 27764 (Canary Channel)
[Start menu]
  • When right-clicking on apps pinned to the Start menu, jump lists will be shown for apps that have them such as PowerPoint.
[Dynamic Lighting]
  • When no compatible devices are attached, the Dynamic Lighting settings page will now show a placeholder message and Brightness and Effects controls are disabled.
  • On the Dynamic Lighting settings page, we have added Forward, Backward, Outward and Inward direction options to the Wave effect, and added the Forward direction option to the Gradient effect.
[Input]
  • We are beginning to roll out a change where we now hide the IME toolbar when apps are in full screen mode for those who have the IME toolbar enabled and type in Chinese or Japanese.
[Narrator]
  • We have added new functionalities to Narrator scan mode. Skip past links (N') allows you to navigate to the text after a link. This is most helpful when navigating through long emails, news articles, and wiki pages. Jump to lists (L') allows you to quickly access a list on a web page or a document. To try these new features, you need to turn on Narrator first (Win key + Ctrl + Enter), then turn scan mode ON by pressing Caps Lock + Spacebar and finally use the new shortcuts – 'N' and 'L'. Please note that scan mode is 'ON' by default on most web pages (like news articles, wiki page, etc.).
[Speech in Windows]
  • We have improved our speech-to-text and text-to-speech experience on Windows. Users of Narrator, voice access, live captions, live translations, and voice typing might see a message asking them to update their language files manually. The language files will be released separately through Microsoft Store.
Fixes
[General]
  • Fixed an issue causing some Insiders to see a bugcheck with error PAGE_FAULT_IN_NONPAGED_AREA while using their PC starting with Build 27754.
[File Explorer]
  • We did some work to help address an issue where File Explorer might hang when browsing a folder with lots of media in it.
[Input]
  • Fixed an issue where if pointer trails were enabled, the mouse cursor may become invisible with a black box behind it.
[Task Manager]
  • Fixed an issue where some HDDs were being incorrectly listed as SSD on the Performance page.
[Display]
  • Fixed an issue which could result in lag and screen tearing on secondary monitors with full screen windows.
[Other]
  • Fixed an underlying issue which could lead to Excel sometimes hanging on launch when opening certain files.
Announcing Windows 11 Insider Preview Build 27766 (Canary Channel)
[General]
  • This update includes a small set of general improvements and fixes that improve the overall experience for Insiders running this build on their PCs.
Fixes
[General]
  • We fixed the issue where if you roll back from Build 27764 to an earlier build (including if the upgrade failed), you would see an "Your organization used App Control for Business to block this app" dialog when attempting to use or install certain third-party apps on your PC due to an incorrect policy being enforced.
  • As of the latest Insider Preview builds in the Canary Channel, the main issues causing Insiders to experience an increase in rollbacks (with error code 0xc190010) when attempting to upgrade have been addressed. As a reminder, 0xc190010 is a generic error code that has multiple root causes, so if you're continuing to experience issues, please file feedback (WIN + F) to investigate.
  • Fixed an underlying issue which was causing some Insiders in Canary to experience frequent explorer.exe crashes after they clean installed or reset their PC.
Announcing Windows 11 Insider Preview Build 27768 (Canary Channel)
[General]
[File Explorer]
  • We've added a New Folder option in the context menu when right-clicking locations in the navigation pane.
[Settings]
  • The ability to change time zones is available again under Settings > Time & Language > Date & Time for standard (non-admin) users.
Fixes
[File Explorer]
  • Fixed an issue where the date/time properties of files were unexpectedly updated in some cases after copying them.
  • Fixed an issue where File Explorer may sometimes lose focus on the search box while typing.
  • Fixed an issue where when you did a search it may unexpectedly trigger the search happening repeatedly.
  • Fixed an issue where the Details Pane icons weren't responding correctly to theme changes, making it hard to see if you switched from dark to light or vice versa.
  • Fixed a black flash in File Explorer that appeared when duplicating a tab.
[Input]
  • Fixed an issue which could lead to the mouse cursor unexpectedly stuttering when you moved it around sometimes.
[Graphics]
  • Fixed an underlying issue which could result in some games appearing oversaturated when using Auto HDR.
[Other]
  • Fixed an issue causing some Insiders in Canary to experience bugchecks with error PAGE_FAULT_IN_NONPAGED_AREA.
Announcing Windows 11 Insider Preview Build 27774 (Canary Channel)
[General]
[Windows Setup]
  • When installing Windows from installation media, you will now see a confirmation dialog when formatting or deleting partitions.
[Administrator protection]
  • Administrator protection can now be enabled from Windows Security settings under the Account Protection tab. This allows users to enable this feature without requiring help from IT admins. It also allows Windows home users to enable Administrator protection via Windows Security settings. Changing this setting requires a Windows reboot.
  • With administrator protection enabled, the prompt requesting the user's authorization for elevating untrusted and unsigned applications now comes with expanded color-coded regions which will now extend down over the app description.
Fixes
[General]
  • Fixed an underlying issue causing accent colored window borders to not be not displayed when enabled, shadows around windows not displaying when enabled, and window launching (and other) animations to show even though the setting to show animations is turned off in the latest Canary builds.
[Other]
  • Fixed an underlying issue which was causing the Xbox app to fail to launch with a "Please try again" error sometimes in the last two Canary builds.
Announcing Windows 11 Insider Preview Build 27783 (Canary Channel)
What's new with Build 27783
Shared Content in File Explorer Home
File Explorer will now provide you with quick access to files that have been shared with you. If you are signed into Windows with your Microsoft account, you will be able to view files that have been shared with your account, such as email, Teams chat, etc. If you are a commercial customer who is signed-in with your Microsoft Entra ID account, you will additionally be able to view files that they have shared with others. You can access this feature by launching File Explorer Home and clicking on the 'Shared' tab item.
You will also be able to view a broader set of file types in their Recent, Favorites, and Shared sections on the homepage. For example, if you've recently opened/edited files in Designer, Loop, Power BI, Forms, etc. these files will now be available in your Recent list.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Files Folders and Online Storage > File Explorer.
[General]
[Magnifier]
  • We're adding a new keyboard shortcut CTRL + ALT + Minus for Magnifier users to quickly toggle between the current zoom and 1X zoom.
  • In addition to the keyboard shortcut CTRL + ALT + Minus to quickly toggle between the current zoom and 1X zoom, we have also added buttons in Magnifier to reset zoom to fit to screen and reset zoom to your last/preferred magnification.
Fixes
  • Fixed an issue which was causing the taskbar preview windows to not display sometimes when hovering over open apps in the taskbar.
[Input]
  • Fixed an issue for Pinyin IME users, where switching between windows (like with ALT + Tab) may unexpectedly switch the IME from Chinese to English.
[Windowing]
  • Fixed an underlying issue which could lead to unexpected app window freezes for some people when using ALT + Tab between certain types of apps.
[Graphics]
  • Fixed an issue causing Settings to crash when going to Settings > System > Display > Graphics for some people.
[Remote Desktop]
  • Fixed an issue causing MTSC.exe for Remote Desktop to fail on the previous build with error 0x80080005.
  • Fixed an issue which was causing Remote Desktop to show significant display / rendering issues when connecting to certain other computers.
[Other]
  • Fixed an underlying issue which was causing an explorer.exe memory leak in recent Canary Channel builds, leading to performance issues over time.
  • Fixed an issue where the shutdown /r/ /fw command wasn't working sometimes.
Announcing Windows 11 Insider Preview Build 27788 (Canary Channel)
What's new with Build 27788
Windows MIDI Services Public Preview
We're excited to release the first in-box public preview of Windows MIDI Services, our complete rewrite of MIDI on Windows with a focus on a great experience for musicians and a strong foundation for future expansion and enhancement.
MIDI is the standard, first released in 1983, that is used to synchronize synthesizers and drum machines in almost all modern electronic music. It's used to record and play back note information, control stage lights and effects, keep mixers in a large venue in sync, and so much more. Although it is not itself audio, the MIDI protocol is essential to making music and was heavily used in the rise of hip-hop and other genres. MIDI 2.0 is the first major update to the core MIDI protocol since 1983, offering everything that modern musicians need today, like increased speed and fidelity, better control of instruments, modern bi-directional conversations and negotiation between instruments, discovery, better USB timing, and more.
Windows MIDI Services is our new MIDI stack which handles not only MIDI 2.0 but also brings our MIDI 1.0 implementation up to modern expectations. It works on 64-bit operating systems on all supported processors, including Arm64. Windows MIDI Services offers the following benefits:
  • Full support of the MIDI 2.0 Standard, including high-speed data transmission, higher-fidelity messages, increased resolution for controller values, and full in-service MIDI 2.0 endpoint discovery and protocol negotiation.
  • Faster transports, leading to better timing and reduced jitter.
  • Faster USB MIDI driver with full support for both MIDI 1.0 and MIDI 2.0.
  • Every endpoint is now multi-client, meaning multiple apps can use a device at the same time.
  • Better endpoint and port
  • In-service scheduling of outgoing timestamped messages, and timestamped incoming messages, for apps using the new Windows MIDI Services App SDK.
  • Built-in loopback and app-to-app MIDI
  • Automatic translation between MIDI 1.0 and MIDI 2.0 based on API, application, and device needs.
  • Much more device metadata available to applications.
  • Better device add/update/remove notifications.
  • Backwards compatibility with our WinMM (MME) MIDI 1.0 API (and WinRT MIDI 1.0 in the future) enabling applications to light up with new features without any changes, and even access MIDI 2.0 devices at a MIDI 1.0 feature level.
  • Open source. The MIDI Service, all its transports, all the tools, the tests, and the SDK are all MIT-licensed open source, and have been developed in concert with hardware and software partners around the world.
New USB MIDI 2.0 Class Driver: The new USB MIDI 2.0 Class Driver, graciously provided to Microsoft by AMEI (Association of Musical Electronics Industry of Japan) and written by AmeNote, is a high-speed USB MIDI driver which works with both the new USB MIDI 2.0 devices, as well as with class-compliant USB MIDI 1.0 devices. By default, for compatibility, this is enabled only for USB MIDI 2.0 devices and a handful of USB MIDI 1.0 devices. However, you may manually assign this driver to any class-compliant USB MIDI 1.0 device yourself to gain the better transfer mechanisms. We also have several built-in transports for things that were not previously available without third-party drivers. Learn more about the built-in transports here.
Windows MIDI Services App SDK and Tools: Applications using Windows MIDI Services do so through the Windows MIDI Services App SDK, shipped out-of-band. Current preview releases are available on our GitHub repo releases page. Please note that these are unsigned releases and so will give you a warning when you download and install. In addition to installing the required runtime components, the SDK runtime installer includes these tools:
  • Windows MIDI Services Console (midi.exe): The all-around console tool for sending messages, checking the state of MIDI, monitoring incoming messages, sending System Exclusive, and much more.
  • MIDI Diagnostics (mididiag.exe): A tech support tool which provides information about the state of MIDI on the PC.
  • MIDI Kernel Streaming Endpoint Info (midiksinfo.exe): A hardware developer-focused tool which provides information about the KS (Kernel Streaming) endpoints.
  • MIDI multicast dynamic DNS Info (midimdnsinfo.exe): A tool to support the upcoming Network MIDI 2.0 transport.
The Windows MIDI Services App SDK also includes the MIDI Settings app – a desktop application for managing endpoints, renaming endpoints and ports, creating loopback devices, managing your network MIDI 2.0 connections, and more.
In addition, we're currently working on our Network MIDI 2.0 transport, recently demonstrated at the NAMM Show in California, the virtual patch-bay to enable routing between endpoints, and a rewrite of our BLE MIDI 1.0 transport. This will all ship in a future version of Windows MIDI Services.
We look forward to having Windows Insiders who dabble in music creation try out the Windows MIDI Services Public Preview and MIDI 2.0. Try out using existing applications that use the WinMM MIDI 1.0 function with the new Windows MIDI Services installed. Additionally, any MIDI 1.0 devices with specific IHV drivers. You can also join the discussion here on Discord if you have questions or are looking to help! You will find a list of known issues documented here.
Ability to seamlessly resume OneDrive files in 1-click from your phone to PC
We are gradually rolling out the ability to seamlessly resume working on OneDrive files from your phone (iOS and Android) on your Windows 11 PC with a single click. With this feature, you will get a notification asking you if you want to pick up where you left off editing a OneDrive file like a Word doc that you last viewed or edited on your phone within a 5-minute time window preceding unlocking your PC.
Upon clicking on this notification, the same file that you were viewing or editing previously on your phone will open in your default browser on your PC.
Here are some important details about how this feature works:
  • This feature works only when signing into OneDrive with a Microsoft account. Work and school accounts are not supported. And you need to be using the same Microsoft account signing into OneDrive on your phone and signing into your Windows 11 PC.
  • This feature supports Word docs, Excel spreadsheets, PowerPoint presentations, OneNote notebooks/pages, and PDFs.
  • The OneDrive file must be opened on your phone when your PC is locked. If you then unlock your PC within 5 minutes of accessing the file on your phone, you will receive the resume notification as noted above.
  • For the best experience using this feature, you should be logged into OneDrive in your default browser on your PC.
This feature can be managed and turned off via Settings > Apps > Resume.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Devices and Drivers -> Linked Phone.
[File Explorer]
  • When "Restore previous folder windows at logon" is enabled in File Explorer, we will also now restore all the extra tabs which you previously had open in each File Explorer window. As part of this work, we have also updated the logic for the "Automatically save my restartable apps and restart them when I sign back in" setting via Settings > Accounts > Sign in options, so that when you enable this, we will automatically enable the File Explorer specific setting for you too.
  • We're adding a new option to snooze or turn off the "Start backup" reminder in the File Explorer address bar, for those that aren't already backing up their Documents, Pictures, or Desktop folders. This option is available when you right-click "Start backup".
[Settings]
  • We are starting to roll out the Settings homepage for commercial customers on PCs managed by an IT administrator. The feature will show some existing cards relevant to enterprise-managed PCs like "Recommended settings" and "Bluetooth devices" as well as two new enterprise-specific device info and accessibility preferences cards. For commercial customers who also use their Microsoft account on their managed PC, there will also be a new accounts card indicating the presence of both work and school and Microsoft account types. We are starting the rollout of this gradually with managed commercial PCs who have both work and school, and Microsoft accounts presently seeing this experience first.
Fixes
[General]
  • Fixed an issue in Build 27783 which was causing multiple surfaces (including the taskbar, search, Settings, and lock screen) to cyclically crash for a small number of Insiders.
[Other]
  • Fixed an issue which was causing some Insiders to have a SYSTEM_SERVICE_EXCEPTION bugcheck in Build 27783.
  • Fixed an issue where the description for virtual NICs wasn't displayed correctly in ncpa.cpl, it showed garbled characters.
  • Fixed an underlying issue which could cause scanning apps to not detect a scanner, although one was connected.
  • Improved the colors used in MMC when items are selected, both generally, and when contrast modes are enabled.
Announcing Windows 11 Insider Preview Build 27802 (Canary Channel)
What's new with Build 27802
Improving the battery iconography in Windows 11
Introducing new and improved battery icons in Windows 11! These icons have been designed to communicate the battery status of your PC with just a quick glance. Key changes include colored icons to indicate charging states, simplified overlays that don't block the progress bar, and an option to turn on battery percentage.
When your battery icon is green, this shows that your PC is charging and in a good state. A yellow battery icon will let you know that your PC using battery in energy saving mode – this automatically happens when your battery is less than or equal to 20% to preserve power. When the battery icon is red, you have a critically low battery and should plug in your PC as soon as possible. You will see these new battery icons on the taskbar in the system tray, in the quick settings flyout, and in Settings. The new battery icons will begin showing on the Lock screen in a future flight.
As always, your PC's battery status and more will also be available to you when you hover over the battery icon in the system tray and under Settings > System > Power & battery where you can also adjust the battery level percentage in which energy saver mode kicks on for your PC.
Along with the updates to the battery icon, we are also introducing the ability to show your battery percentage next to the battery icon in the system tray – a highly requested feature by Insiders and customers. To enable this, go to Settings > Power & battery and toggle on the "Battery Percentage" setting.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Desktop Environment > System Tray.
  • We are rolling out the ability to share files directly from the jump lists on the taskbar, which appears when you right-click on an app with a jump list like Notepad the taskbar.
[Spotlight on the desktop]
  • We're beginning to roll out some changes to the Desktop Spotlight icon interaction model for Windows Insiders. You can now quickly and easily discover more information about your background image by simply hovering over or clicking on the "Learn about this picture" icon on your desktop.
Fixes
[General]
  • We fixed the issue causing Insiders to see an error trying to install Build 27788 (0x8007000d) along with a failed .NET update (0x80073712). This issue should not occur with Build 27798.
[File Explorer]
  • Fixed an issue where if you opened a File Explorer window and minimized it, it might not be rendered correctly when you restore it.
  • Fixed an issue when using multiple monitors, where the distance between the date and time and edge of the screen wasn't consistent.
[Input]
  • Fixed an issue where if you were using a non-default mouse color (enabled in Settings > Accessibility > Mouse pointer and touch), it may unexpectedly revert back to white when you encountered a UAC dialog.
[Lock Screen]
  • Fixed an issue which was causing the login screen to crash when clicking the "sign-in options" link for some Insiders.
[Administrator Protection]
  • Fixed a rare issue when Administrator Protection was enabled, which could cause you to see a resource loader cache error loading the MUI file on sign in.
  • Removed extraneous space between Dynamic Lock and Administrator Protection under Account Protection in Windows Security.
  • Fixed an issue where Administrator Protection wasn't showing in the results if you searched from the taskbar.
[Audio]
  • Fixed an issue causing a small percentage of Insiders to not be able to hear audio in the last couple builds due to a background audio crash.
[Remote Desktop]
  • Fixed an issue in the last two Canary Channel builds where if you used remote desktop to connect to your PC and then tried to sign into the computer locally, it would sit at a black screen.
[Other]
  • Fixed an underlying issue causing some Insiders to see a bugcheck with WIN32K_CRITICAL_FAILURE in recent builds.
  • Fixed an underlying issue causing some Insiders to see a bugcheck with KERNEL_SECURITY_CHECK_FAILURE in recent builds.
  • Fixed an issue where SFC /scannow is showing errors every time it was run.
Announcing Windows 11 Insider Preview Build 27808 (Canary Channel)
[Task Manager]
  • We are beginning to roll out a change to the way Task Manager calculates CPU utilization for the Processes, Performance, and Users pages. Task Manager will now use the standard metrics to display CPU workload consistently across all pages and aligning with industry standards and third-party tools. For backward compatibility, a new optional column called CPU Utility is available (hidden by default) on the Details tab showing the previous CPU value used on the Processes page.
Fixes
[Gaming]
  • Fixed an issue leading to some popular games like Roblox potentially having a bugcheck (green screen) on launch on Build 27802.
[Printing]
  • Fixed an issue where printing from some apps might cause a bugcheck (green screen) on Build 27802.
[Search]
  • Fixed an issue causing the search window to be blank for some Insiders recently when searching from the taskbar, due to a background crash.
[Graphics]
  • Fixed an underlying issue which could lead to Settings crashing when adding a color profile in Settings > System > Display.
  • Fixed an issue which could cause color profiles to not load correctly after waking your PC from sleep.
[Power and Battery]
  • Fixed an issue where the colors in the new battery icon weren't displayed correctly when you have your mode in Personalization > Colors set to certain options with Custom.
[BitLocker]
  • We did some work to improve the performance of loading early boot UI including the BitLocker PIN, BitLocker Recovery key, and boot menu screens.
  • Fixed an issue for a small number of Insiders which was causing a BitLocker loop in Build 27802.
  • Fixed an issue in recent flights where if you tried to run Get-BitLockerVolume, it unexpectedly showed an error.
[Other]
  • We believe one of the underlying changes in the previous flight addressed the issue causing reports that Hyper-V, and other features which rely on Hyper-V (such as WSL) weren't working properly. If you continue having issues, please don't hesitate to file a new piece of feedback in the Feedback Hub.
Announcing Windows 11 Insider Preview Build 27813 (Canary Channel)
[General]
[Other]
  • We are removing the Location History feature, an API used by Cortana to access 24 hours of device history when location was enabled. With the removal of the Location History feature, location data will no longer be saved locally, and the corresponding settings are also being removed from Settings > Privacy & security > Location page.
Fixes
[Audio]
[Settings]
  • Fixed an issue where in Settings > System > Display > Color Management, it might not display the expected color profile list for the selected monitor.
Announcing Windows 11 Insider Preview Build 27818 (Canary Channel)
[General]
[Windows Security]
  • We are beginning to roll out a change in the Windows Security app where will show more details such as manufacturer and manufacturer version for Pluton TPM chips if your PC has one under Device security > Security processor details.
[Other]
  • Suggested actions that appear when you copy a phone number or future date in Windows 11 are now deprecated. We are disabling this feature.
Fixes
[General]
  • Fixed a d3d9.dll crash which was causing multiple apps to fail to launch starting with Build 27802 for some Insiders.
[File Explorer]
  • Did some more work to improve the performance of extracting zipped files in File Explorer, particularly where you're unzipping a large number of small files.
  • Fixed an issue where File Explorer Home might not load correctly and just show random floating text saying "Name".
  • Fixed an issue with the taskbar app window previews, where the corners of the flyout weren't drawn with the correct radius in certain cases.
  • Fixed an issue where the underlines under app icons in the taskbar may get stuck showing even if the app had been closed.
[Input]
  • Fixed a high hitting ctmon.exe crash, which could impact the ability to type.
[Settings]
  • Fixed an underlying issue which could result in Settings failing to launch with "The instruction at 0x00007FFEDEBDC003 referenced memory at 0x0000000000000010. The memory could not be read". If impacted, you might also see a similar error message with RuntimeBroker.exe.
  • Fixed an issue for Japanese users, where the name displayed at the top of Settings > Accounts showed First Name Last Name instead of Last Name First Name.
[Graphics]
  • Fixed an issue which could cause sluggish video when using multiple monitors after changing from Second Screen Only to Duplicate display mode in the latest Canary builds.
  • Made a couple of fixes to address issues which could cause Settings > System > Display > Graphics to crash.
  • "Fixed an underlying issue which could lead to certain games failing to launch after an upgrade, saying DirectX function CreateComputePipelineState failed with E_INVALIDARG or StorePipeline failed with E_UNEXPECTED.
[Admin Protection]
  • Fixed an issue which could cause Visual Studio Code to not be able to be installed when Admin Protection was enabled.
[Remote Desktop]
  • Fixed an issue which could lead to Remote Desktop freezing when connecting.
[Other]
  • Fixed an underlying issue which was causing certain apps to fail to open with an error saying "The application was unable to load a required virtual machine component".
Announcing Windows 11 Insider Preview Build 27823 (Canary Channel)
[General]
Fixes
[File Explorer]
  • Fixed an issue where File Explorer might be blank and not render if you ALT + Tab to it from a minimized state in the latest Canary builds.
  • Fixed an issue where the see more menu "..." in the command bar was drawing in the wrong direction at some resolutions.
  • As part of our ongoing commitment to improving File Explorer accessibility, this release includes increased support for the text scaling (via Settings > Accessibility > Text size) across File Explorer, File Open/Save dialogs and the copy dialogs.
[Input]
  • Fixed an issue which could cause a ctfmon.exe crash when copying content from certain apps.
  • Fixed an issue where GetRawInputData was unexpectedly failing to read data in some cases, with lastWin32Errror invalid handle error.
[Login and Lock]
  • Fixed an issue where clicking Sign in Options was crashing for some Insiders.
[Settings]
  • Fixed an issue which could cause Settings to crash when interacting with Bluetooth & Devices > Cameras.
  • Fixed an issue causing some unexpected space at the top of System > Sound, and some other Settings pages.
[Printing]
  • Fixed an issue where non-admin users couldn't uninstall printers that they'd added.
  • Fixed an issue which was causing some Insiders to unexpectedly see a message saying a Send to OneNote driver for printing wasn't working.
[Other]
  • Fixed an issue which was causing certain apps to fail to install in Builds 27813+.
  • Fixed an underlying issue which was causing some Insiders to unexpectedly get bugchecks with UNSUPPORTED_PROCESSOR when upgrading or clean installing the latest builds.
  • Fixed an issue where when using CopyPixels the pixels may be unexpectedly inverted in certain cases.
  • Fixed an issue in the latest Canary builds where traffic routing might not work correctly when network adapters were connected.
Announcing Windows 11 Insider Preview Build 27842 (Canary Channel)
[General]
  • The improved battery iconography in Windows 11 may disappear for Windows Insiders in the current flights. We're beginning to re-roll this change out to Windows Insiders.
  • We're previewing a new, more streamlined UI for unexpected restarts which better aligns with Windows 11 design principles and supports our goal of getting users back into productivity as fast as possible. We've simplified your experience while preserving the technical information on the screen. As a reminder, for Windows Insiders this appears as a "green screen". This is currently rolling out to Windows Insiders on Windows 11, version 24H2 and higher in the Beta, Dev, and Canary Channels.
[Windows Security]
  • We are beginning to roll out (again) a change in the Windows Security app where will show more details such as manufacturer and manufacturer version for Pluton TPM chips if your PC has one under Device security > Security processor details.
[Other]
  • Support for the Visual Studio Graphics Analyzer's shader debugging feature is being removed. In this build, attempting to use it may crash Visual Studio or the analysis session. It is recommended that customers use alternative graphics debuggers such as PIX for D3D12 or RenderDoc.
  • We're removing the bypassnro.cmd script from the build to enhance security and user experience of Windows 11. This change ensures that all users exit setup with internet connectivity and a Microsoft Account.
Fixes
[General]
  • Fixed the issue causing the toggle to get the latest updates as they are available via Settings > Windows Update to not render correctly and automatically turn off by itself.
  • Fixed an issue in the latest builds causing some Insiders to see a bugcheck with WHEA_UNCORRECTABLE_ERROR doing various actions on their PC.
  • Fixed an issue impacting explorer.exe reliability in the latest builds.
  • Fixed an issue where when using Hebrew or Arabic as your display language, if you pressed WIN + T then arrow keys, focus through the taskbar icons would move in the opposite direction.
  • Fixed an issue which could cause lsass.exe to unexpectedly use a lot of CPI, impacting performance, after enabling Administrator Protection.
[Input]
  • Fixed a high hitting ctfmon.exe crash, which could impact the ability to type.
  • Fixed an issue in the latest builds causing DWM to crash when inking (which could lead to you seeing a black screen flash).
[Login and Lock]
  • Updated the web sign-in icon slightly to better align with the other icons when selecting a sign in option on the login screen.
[Windows Security]
  • Fixed an issue where the Smart App Control icon wasn't displaying correctly in the Windows Security app.
[Display and Graphics]
  • Fixed an issue where external graphics cards connected over Thunderbolt were unexpectedly not discoverable in some cases.
  • Fixed an issue where some JPG images weren't displaying, although they could display correctly on older builds.
  • Fixed an issue where you might need to press the Windows key plus P twice in order to switch topologies.
[Other]
  • Fixed an issue where the IP Helper Service was failing to start in the latest builds. This may have caused issues with some apps.
  • Fixed an issue causing midisrv.exe crashes in the latest builds.
  • Fixed an issue which was causing the Run dialog to not show an autocomplete dropdown if you started typing a file path.
