Pale Moon Version 33.0.2 Released with Security Update
Started by Corrine, March 26, 2024, 01:02:42 PM
Pale Moon has been updated to version 33.0.2.  This update is a minor security and stability release.
Changes/Fixes:
  • Fixed an issue with attributes on duplicate html tags.
  • Aligned the behavior of internal pointer structures to be more uniform. DiD
  • Security issue addressed: CVE-2024-2610
Notes:
DiD: This means that a fix is "Defense-in-Depth": It is a fix that does not apply to a (potentially) actively exploitable vulnerability in Pale Moon, but prevents future vulnerabilities caused by the same code, e.g. when surrounding code changes, exposing the problem, or when new attack vectors are discovered.
Release Cycle
