Malware which seems to Primarily Affect PaleMoon (Blue Screen, Audio Alert, etc)
Started by Nissi1, March 07, 2018, 07:17:12 AM
Nissi1
Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
Action ended 10:53:51: InstallODBC. Return value 0.
MSI (s) (60:B0) [10:53:51:720]: Doing action: RegisterTypeLibraries
Action 10:53:51: RegisterTypeLibraries. Registering type libraries
Action start 10:53:51: RegisterTypeLibraries.
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
Action ended 10:53:51: RegisterTypeLibraries. Return value 0.
MSI (s) (60:B0) [10:53:51:720]: Doing action: SelfRegModules
Action 10:53:51: SelfRegModules. Registering modules
Action start 10:53:51: SelfRegModules.
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
Action ended 10:53:51: SelfRegModules. Return value 1.
MSI (s) (60:B0) [10:53:51:720]: Doing action: RegisterComPlus
Action 10:53:51: RegisterComPlus. Registering COM+ Applications and Components
Action start 10:53:51: RegisterComPlus.
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2205 2:  3: Complus
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action ended 10:53:51: RegisterComPlus. Return value 0.
MSI (s) (60:B0) [10:53:51:720]: Doing action: InstallServices
Action 10:53:51: InstallServices. Installing new services
Action start 10:53:51: InstallServices.
MSI (s) (60:B0) [10:53:51:720]: Detected older ServiceInstall table schema
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2205 2:  3: ServiceInstall
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
Action ended 10:53:51: InstallServices. Return value 1.
MSI (s) (60:B0) [10:53:51:720]: Doing action: StartServices
Action 10:53:51: StartServices. Starting services
Action start 10:53:51: StartServices.
MSI (s) (60:B0) [10:53:51:737]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:B0) [10:53:51:737]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action ended 10:53:51: StartServices. Return value 1.
MSI (s) (60:B0) [10:53:51:738]: Doing action: RegisterUser
Action 10:53:51: RegisterUser. Registering user
Action start 10:53:51: RegisterUser.
Action ended 10:53:51: RegisterUser. Return value 0.
MSI (s) (60:B0) [10:53:51:740]: Doing action: RegisterProduct
Action 10:53:51: RegisterProduct. Registering product
Action start 10:53:51: RegisterProduct.
Action ended 10:53:51: RegisterProduct. Return value 1.
MSI (s) (60:B0) [10:53:51:742]: Doing action: PublishComponents
Action 10:53:51: PublishComponents. Publishing qualified components
Action start 10:53:51: PublishComponents.
MSI (s) (60:B0) [10:53:51:742]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:B0) [10:53:51:742]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action ended 10:53:51: PublishComponents. Return value 0.
MSI (s) (60:B0) [10:53:51:742]: Doing action: MsiPublishAssemblies
Action 10:53:51: MsiPublishAssemblies. Publishing assembly information
Action start 10:53:51: MsiPublishAssemblies.
MSI (s) (60:B0) [10:53:51:742]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:B0) [10:53:51:742]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action ended 10:53:51: MsiPublishAssemblies. Return value 0.
MSI (s) (60:B0) [10:53:51:742]: Doing action: PublishFeatures
Action 10:53:51: PublishFeatures. Publishing product features
Action start 10:53:51: PublishFeatures.
Action ended 10:53:51: PublishFeatures. Return value 1.
MSI (s) (60:B0) [10:53:51:742]: Doing action: PublishProduct
Action 10:53:51: PublishProduct. Publishing product information
Action start 10:53:51: PublishProduct.
MSI (s) (60:B0) [10:53:51:742]: Using cached product context: machine assigned for product: ECC9C29D0F5E521479A750093F22B547
1: Publishing product information
Action ended 10:53:51: PublishProduct. Return value 1.
MSI (s) (60:B0) [10:53:51:758]: Doing action: Nero_CA_DeleteGlobalFileAssociationDbCommit
Action 10:53:51: Nero_CA_DeleteGlobalFileAssociationDbCommit.
Action start 10:53:51: Nero_CA_DeleteGlobalFileAssociationDbCommit.
Nero_CA_DeleteGlobalFileAssociationDbCommit:
Action ended 10:53:51: Nero_CA_DeleteGlobalFileAssociationDbCommit. Return value 1.
MSI (s) (60:B0) [10:53:51:758]: Doing action: Nero_CA_FixRepairCmdLine
Action 10:53:51: Nero_CA_FixRepairCmdLine.
Action start 10:53:51: Nero_CA_FixRepairCmdLine.
MSI (s) (60:B0) [10:53:51:758]: Creating MSIHANDLE (1615) of type 790542 for thread 8112
MSI (s) (60:34) [10:53:51:773]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIE61D.tmp, Entrypoint: CA_FixRepairCmdLine
MSI (s) (60!F4) [10:53:51:820]: Creating MSIHANDLE (1616) of type 790531 for thread 11252
CA_FixRepairCmdLine: CustomActions.cpp : 700 :  Succeeded
MSI (s) (60!F4) [10:53:51:820]: Closing MSIHANDLE (1616) of type 790531 for thread 11252
MSI (s) (60:34) [10:53:51:820]: Closing MSIHANDLE (1615) of type 790542 for thread 8112
Action ended 10:53:51: Nero_CA_FixRepairCmdLine. Return value 1.
MSI (s) (60:B0) [10:53:51:820]: Skipping action: ScheduleReboot (condition is false)
MSI (s) (60:B0) [10:53:51:820]: Doing action: InstallFinalize
Action 10:53:51: InstallFinalize.
Action start 10:53:51: InstallFinalize.
InstallFinalize:
MSI (s) (60:B0) [10:53:51:820]: Running Script: C:\WINDOWS\Installer\MSIE4F2.tmp
MSI (s) (60:B0) [10:53:51:820]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (60:B0) [10:53:51:820]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:B0) [10:53:51:838]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:B0) [10:53:51:842]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (60:B0) [10:53:51:842]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1254839994,LangId=0,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (60:B0) [10:53:51:842]: Executing op: ProductInfo(ProductKey={D92C9CCE-E5F0-4125-977A-0590F3225B74},ProductName=SyncUP,PackageName=Nero.mhubdell.msi,Language=0,Version=167918632,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={D5723832-302A-4BB1-BE36-434859360ADB},,,InstanceType=0,LUASetting=1,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (s) (60:B0) [10:53:51:842]: Executing op: DialogInfo(Type=0,Argument=0)
MSI (s) (60:B0) [10:53:51:842]: Executing op: DialogInfo(Type=1,Argument=SyncUP)
MSI (s) (60:B0) [10:53:51:842]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (60:B0) [10:53:51:842]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (60:B0) [10:53:51:842]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (60:B0) [10:53:51:842]: Executing op: ActionStart(Name=InstallInitialize,,)
Action 10:53:51: InstallInitialize.
MSI (s) (60:B0) [10:53:51:842]: Executing op: ProductUnregister(UpgradeCode={CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0})
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74}
MSI (s) (60:B0) [10:53:51:842]: Note: 1: 1402 2: UNKNOWN\Products\ECC9C29D0F5E521479A750093F22B547\Transforms 3: 2
MSI (s) (60:B0) [10:53:51:842]: Scheduling file 'C:\Windows\Installer\11a49.msi' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:B0) [10:53:51:874]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\Software\Microsoft\Windows\CurrentVersion\Uninstall\{D92C9CCE-E5F0-4125-977A-0590F3225B74} 3: 2
MSI (s) (60:B0) [10:53:51:874]: Note: 1: 1402 2: UNKNOWN\Products\ECC9C29D0F5E521479A750093F22B547\Usage 3: 2
MSI (s) (60:B0) [10:53:51:874]: Executing op: ProductCPDisplayInfoUnregister()
MSI (s) (60:B0) [10:53:51:874]: Executing op: ProductUnpublish(PackageKey={D5723832-302A-4BB1-BE36-434859360ADB})
MSI (s) (60:B0) [10:53:51:874]: Using cached product context: machine assigned for product: ECC9C29D0F5E521479A750093F22B547
MSI (s) (60:B0) [10:53:51:874]: Transforms are not secure.
MSI (s) (60:B0) [10:53:51:874]: Processing cached transform: C:\WINDOWS\Installer\{D92C9CCE-E5F0-4125-977A-0590F3225B74}\1033.mst
MSI (s) (60:B0) [10:53:51:874]: Scheduling file 'C:\WINDOWS\Installer\{D92C9CCE-E5F0-4125-977A-0590F3225B74}\1033.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:B0) [10:53:51:874]: Registering cached transform: C:\WINDOWS\Installer\{D92C9CCE-E5F0-4125-977A-0590F3225B74}\1033.mst
MSI (s) (60:B0) [10:53:51:874]: Executing op: UpgradeCodeUnpublish(UpgradeCode={CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0})
MSI (s) (60:B0) [10:53:51:874]: Executing op: IconRemove(Icon=ARPPRODUCTICON.exe,)
1: ARPPRODUCTICON.exe
MSI (s) (60:B0) [10:53:51:889]: Scheduling file 'C:\WINDOWS\Installer\{D92C9CCE-E5F0-4125-977A-0590F3225B74}\ARPPRODUCTICON.exe' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:B0) [10:53:51:889]: Executing op: ProductUnpublishClient(,,)
MSI (s) (60:B0) [10:53:51:889]: Note: 1: 1402 2: UNKNOWN\Installer\Products\ECC9C29D0F5E521479A750093F22B547 3: 2
MSI (s) (60:B0) [10:53:51:889]: Executing op: SourceListUnpublish(,)
MSI (s) (60:B0) [10:53:51:889]: Note: 1: 1402 2: UNKNOWN\Installer\Products\ECC9C29D0F5E521479A750093F22B547\SourceList 3: 2
MSI (s) (60:B0) [10:53:51:889]: Executing op: ActionStart(Name=Nero_CA_DeleteGlobalFileAssociationDbRollback,,)
Action 10:53:51: Nero_CA_DeleteGlobalFileAssociationDbRollback.
MSI (s) (60:B0) [10:53:51:889]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteGlobalFileAssociationDbRollback,ActionType=1281,Source=BinaryData,Target=CA_DeleteGlobalFileAssociationDb,CustomActionData=Nero 10)
MSI (s) (60:B0) [10:53:51:889]: Executing op: ActionStart(Name=Nero_CA_CreateGlobalFileAssociationDb,,)
Action 10:53:51: Nero_CA_CreateGlobalFileAssociationDb.
MSI (s) (60:B0) [10:53:51:889]: Executing op: CustomActionSchedule(Action=Nero_CA_CreateGlobalFileAssociationDb,ActionType=1025,Source=BinaryData,Target=CA_CreateGlobalFileAssociationDb,)
MSI (s) (60:B0) [10:53:51:905]: Creating MSIHANDLE (1617) of type 790536 for thread 8112
MSI (s) (60:58) [10:53:51:905]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIE6AB.tmp, Entrypoint: CA_CreateGlobalFileAssociationDb
MSI (s) (60:58) [10:53:51:958]: Closing MSIHANDLE (1617) of type 790536 for thread 8112
MSI (s) (60:B0) [10:53:51:958]: Executing op: ActionStart(Name=ISChainPackageRollback,,)
Action 10:53:51: ISChainPackageRollback.
MSI (s) (60:B0) [10:53:51:958]: Executing op: CustomActionSchedule(Action=ISChainPackageRollback,ActionType=1281,Source=BinaryData,Target=ISChainPackagesCleanup,)
MSI (s) (60:B0) [10:53:51:958]: Executing op: ActionStart(Name=ISChainPackageCommit,,)
Action 10:53:51: ISChainPackageCommit.
MSI (s) (60:B0) [10:53:51:958]: Executing op: CustomActionSchedule(Action=ISChainPackageCommit,ActionType=1537,Source=BinaryData,Target=ISChainPackagesCleanup,)
MSI (s) (60:B0) [10:53:51:958]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
Action 10:53:51: ProcessComponents. Updating component registration
MSI (s) (60:B0) [10:53:51:958]: Executing op: ProgressTotal(Total=21,Type=1,ByteEquivalent=24000)
MSI (s) (60:B0) [10:53:51:958]: Executing op: UnregisterSharedComponentProvider(Component={0B1B62FF-E704-4B3D-9261-C3D6379A3969},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:958]: Executing op: ComponentUnregister(ComponentId={0B1B62FF-E704-4B3D-9261-C3D6379A3969},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {0B1B62FF-E704-4B3D-9261-C3D6379A3969}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={2E6746AA-C783-4918-A405-36FE2B13FDF0},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={2E6746AA-C783-4918-A405-36FE2B13FDF0},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {2E6746AA-C783-4918-A405-36FE2B13FDF0}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={DCCB873F-FC72-4AE3-8727-F60AF836FEA8},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={DCCB873F-FC72-4AE3-8727-F60AF836FEA8},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {DCCB873F-FC72-4AE3-8727-F60AF836FEA8}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={A3B6E5AE-E4B6-46C7-B77A-F8B3CD9034DB},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={A3B6E5AE-E4B6-46C7-B77A-F8B3CD9034DB},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {A3B6E5AE-E4B6-46C7-B77A-F8B3CD9034DB}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={10725F0E-036E-4168-A9D8-78CB4D01F5B5},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={10725F0E-036E-4168-A9D8-78CB4D01F5B5},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {10725F0E-036E-4168-A9D8-78CB4D01F5B5}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={C8C2B555-72EC-49FE-9E06-DBC491F16DE1},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={C8C2B555-72EC-49FE-9E06-DBC491F16DE1},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {C8C2B555-72EC-49FE-9E06-DBC491F16DE1}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={7D771EC1-86D8-4597-915E-B60E0B091C6B},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={7D771EC1-86D8-4597-915E-B60E0B091C6B},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {7D771EC1-86D8-4597-915E-B60E0B091C6B}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={DA427D9A-D879-4B01-88AE-B777EBEA3146},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={DA427D9A-D879-4B01-88AE-B777EBEA3146},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {DA427D9A-D879-4B01-88AE-B777EBEA3146}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={C5B573D3-B70D-47A0-8CF8-979346423392},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={C5B573D3-B70D-47A0-8CF8-979346423392},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {C5B573D3-B70D-47A0-8CF8-979346423392}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={E10FEB28-E198-450F-A777-04140FA01A16},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={E10FEB28-E198-450F-A777-04140FA01A16},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {E10FEB28-E198-450F-A777-04140FA01A16}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={50A4A856-3F34-43A8-978E-1E415D61D8CE},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={50A4A856-3F34-43A8-978E-1E415D61D8CE},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {50A4A856-3F34-43A8-978E-1E415D61D8CE}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={E5E9DEC8-4247-44DE-A991-99B19AC534CF},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={E5E9DEC8-4247-44DE-A991-99B19AC534CF},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {E5E9DEC8-4247-44DE-A991-99B19AC534CF}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={104A7ACA-1309-4F56-A8D1-15EDAD3590A6},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={104A7ACA-1309-4F56-A8D1-15EDAD3590A6},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {104A7ACA-1309-4F56-A8D1-15EDAD3590A6}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={86D363CC-7873-4E4C-B7F7-67200853AD9E},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={86D363CC-7873-4E4C-B7F7-67200853AD9E},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {86D363CC-7873-4E4C-B7F7-67200853AD9E}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={9FE088FA-57D9-433C-9CBC-807025ACBB61},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={9FE088FA-57D9-433C-9CBC-807025ACBB61},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {9FE088FA-57D9-433C-9CBC-807025ACBB61}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={96DA072D-C3C7-4B45-9B8A-67660D66DD57},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={96DA072D-C3C7-4B45-9B8A-67660D66DD57},,BinaryType=0,PreviouslyPinned=1)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {96DA072D-C3C7-4B45-9B8A-67660D66DD57}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={4CAD5589-E55D-40C1-9593-185CD249EB0F},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={4CAD5589-E55D-40C1-9593-185CD249EB0F},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {4CAD5589-E55D-40C1-9593-185CD249EB0F}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={C0D520F3-AF25-4DC5-B488-502E065D561D},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={C0D520F3-AF25-4DC5-B488-502E065D561D},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {C0D520F3-AF25-4DC5-B488-502E065D561D}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={AD8F0807-F6DC-4000-9317-8B6621C3EDDF},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={AD8F0807-F6DC-4000-9317-8B6621C3EDDF},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {AD8F0807-F6DC-4000-9317-8B6621C3EDDF}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={E36F6346-19E4-47E7-A360-B8CF7B465730},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={E36F6346-19E4-47E7-A360-B8CF7B465730},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {E36F6346-19E4-47E7-A360-B8CF7B465730}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={8935F466-A062-4C45-B4F3-33ADF99AE2FE},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={8935F466-A062-4C45-B4F3-33ADF99AE2FE},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {8935F466-A062-4C45-B4F3-33ADF99AE2FE}
MSI (s) (60:B0) [10:53:52:005]: Executing op: ActionStart(Name=UnpublishFeatures,Description=Unpublishing product features,Template=Feature: [1])
Action 10:53:52: UnpublishFeatures. Unpublishing product features
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=HelpChm,Parent=Main,Absent=2,)
UnpublishFeatures: Feature: HelpChm
MSI (s) (60:B0) [10:53:52:005]: Note: 1: 1402 2: UNKNOWN\Installer\Features\ECC9C29D0F5E521479A750093F22B547 3: 2
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=ControlCenterHelpChm,Parent=HelpChm,Absent=2,Component=[YLX&GNT3@bx*%nG^^nIYacv2%SwQ?]yidzU$VNv)
UnpublishFeatures: Feature: ControlCenterHelpChm
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=MobileSyncHelpChm,Parent=HelpChm,Absent=2,Component=36&6vcq9D9y@,aelhJ2G,uXSCeW1$9V('lOA't7u)
UnpublishFeatures: Feature: MobileSyncHelpChm
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=Main,,Absent=2,)
UnpublishFeatures: Feature: Main
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=HiddenFeatures,Parent=Main,Absent=2,)
UnpublishFeatures: Feature: HiddenFeatures
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=BDCoreApp,Parent=HiddenFeatures,Absent=2,Component=BPszoqpw(@(rNT&TfdB_m@R]]~Z`h=]rZpbA%NNo)
UnpublishFeatures: Feature: BDCoreApp
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=Common,Parent=HiddenFeatures,Absent=2,Component=n-B@(CGo$9Dc^IjxWrPcyX+QXDjF4@r!YvH}OG8DVCg_@nW+n8qbzZE?ot,(!Z{{ffA`~@5H=t2TNOL,ugLk`8USX8pPGzH+CQ{p{L?+rUkA,?`Hcikrg]U3BxM+Th]aS@]Yea`IJ3wz)
UnpublishFeatures: Feature: Common
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=ControlCenterApp,Parent=HiddenFeatures,Absent=2,Component=jEWTi{jLk?nRs=hP-QNqRiXCPej2G=-ewf'o_,LJ)
UnpublishFeatures: Feature: ControlCenterApp
MSI (s) (60:B0) [10:53:52:021]: Executing op: FeatureUnpublish(Feature=CoreComponentsApp,Parent=HiddenFeatures,Absent=2,Component=^7]0orc,,@5hVPNw5`W=@l3Vh%Dl$?))+MWwL%~V)
UnpublishFeatures: Feature: CoreComponentsApp
MSI (s) (60:B0) [10:53:52:021]: Note: 1: 1402 2: UNKNOWN\Installer\Features\ECC9C29D0F5E521479A750093F22B547 3: 2
MSI (s) (60:B0) [10:53:52:021]: Executing op: FeatureUnpublish(Feature=MobileSyncApp,Parent=Main,Absent=2,Component=(9NDqLGd4=`_qL)^pq+*r&*wA-7Ch9X(~w85XkPk)
UnpublishFeatures: Feature: MobileSyncApp
MSI (s) (60:B0) [10:53:52:021]: Executing op: FeatureUnpublish(Feature=MovieThemePackBasicApp,Parent=HiddenFeatures,Absent=2,Component=J`}tr%=J.=Yho)b3^_Zks?'8(?.HRAP&v4uBcCU^)
UnpublishFeatures: Feature: MovieThemePackBasicApp
MSI (s) (60:B0) [10:53:52:021]: Executing op: FeatureUnpublish(Feature=UpdateApp,Parent=Main,Absent=2,Component=^a@DSYv%2A`NAK-{ws~Z'WaH[)Om[9s[N1Lm[zJG)
UnpublishFeatures: Feature: UpdateApp
MSI (s) (60:B0) [10:53:52:021]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
Action 10:53:52: RemoveODBC. Removing ODBC components
MSI (s) (60:B0) [10:53:52:021]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (60:B0) [10:53:52:021]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (60:B0) [10:53:52:021]: Executing op: ActionStart(Name=RemoveRegistryValues,Description=Removing system registry values,Template=Key: [1], Name: [2])
Action 10:53:52: RemoveRegistryValues. Removing system registry values
MSI (s) (60:B0) [10:53:52:021]: Executing op: ProgressTotal(Total=36,Type=1,ByteEquivalent=13200)
MSI (s) (60:B0) [10:53:52:021]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\,,BinaryType=0,,)
MSI (s) (60:B0) [10:53:52:021]: Executing op: RegRemoveValue(Name=NUPD,Value={6A536445-D10A-4006-8AA5-2FFCEF1A1101},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: NUPD
MSI (s) (60:B0) [10:53:52:021]: Executing op: RegRemoveValue(Name=NPMOVB,Value={403096B5-2B75-4FAE-BC57-6535C9E50B79},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: NPMOVB
MSI (s) (60:B0) [10:53:52:021]: Executing op: RegRemoveValue(Name=NL0,Value={F9C0E428-CC5A-48D4-80BB-7C13D783251B},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: NL0
MSI (s) (60:B0) [10:53:52:021]: Executing op: RegRemoveValue(Name=NL,Value={F9C0E428-CC5A-48D4-80BB-7C13D783251B},)
MSI (s) (60:B0) [10:53:52:037]: Executing op: RegRemoveValue(Name=NCC0,Value={3DEBC5B2-FD93-4492-A6B3-4F2C7943F34C},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: NCC0
MSI (s) (60:B0) [10:53:52:038]: Executing op: RegRemoveValue(Name=NCC,Value={3DEBC5B2-FD93-4492-A6B3-4F2C7943F34C},)
MSI (s) (60:B0) [10:53:52:040]: Executing op: RegRemoveValue(Name=NBDCORE,Value={E662C6C7-F7AE-455D-AF35-8FA0A484DE90},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: NBDCORE
MSI (s) (60:B0) [10:53:52:041]: Executing op: RegRemoveValue(Name=MH4DELL.MINOR,Value={DF7EBE00-B52E-4BB2-AA7D-7CB21312AB21},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: MH4DELL.MINOR
MSI (s) (60:B0) [10:53:52:042]: Executing op: RegRemoveValue(Name=MH4DELL.MAJOR,Value={DF7EBE00-B52E-4BB2-AA7D-7CB21312AB21},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: MH4DELL.MAJOR
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=MH4DELL,Value={DF7EBE00-B52E-4BB2-AA7D-7CB21312AB21},)
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=DF,Value={68734CD9-6B24-477E-8C73-70822DF403D6},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: DF
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=CHM_NCC,Value={DB1A16FB-84D6-4824-A7E5-26B7BB9B1CA7},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: CHM_NCC
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=CHM_MH4DELL.MINOR,Value={C5C7CA84-97DC-41E4-860F-D9A435E7BF7B},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: CHM_MH4DELL.MINOR
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=CHM_MH4DELL.MAJOR,Value={C5C7CA84-97DC-41E4-860F-D9A435E7BF7B},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: CHM_MH4DELL.MAJOR
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=CHM_MH4DELL,Value={C5C7CA84-97DC-41E4-860F-D9A435E7BF7B},)
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Shared,,BinaryType=0,,)
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=SendUsageStatistics,Value=[NERO.SENDUSAGESTATISTICS.EE698257_A789_474D_A546_5E5AAA5B180D],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Shared, Name: SendUsageStatistics
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(,,)
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{237CCB62-8454-43E3-B158-3ACD0134852E},,BinaryType=0,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{237CCB62-8454-43E3-B158-3ACD0134852E}, Name:
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name={CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0},Value=[ProductName],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{237CCB62-8454-43E3-B158-3ACD0134852E}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{6DFB899F-17A2-48F0-A533-ED8D6866CF38},,BinaryType=0,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{6DFB899F-17A2-48F0-A533-ED8D6866CF38}, Name:
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{6DFB899F-17A2-48F0-A533-ED8D6866CF38}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A},,BinaryType=0,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}, Name:
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name={CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0},Value=[ProductName],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F},,BinaryType=0,,)
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}, Name:
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0},,BinaryType=0,,)
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name=ProductCode,Value=[ProductCode],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}, Name: ProductCode
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name=NERO.INSTALLER_CATEGORY,Value=#[NERO.INSTALLER_CATEGORY],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}, Name: NERO.INSTALLER_CATEGORY
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name=NERO.PRODUCT_LINE,Value=[NERO.PRODUCT_LINE],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}, Name: NERO.PRODUCT_LINE
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name=ProductName,Value=[ProductName],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}, Name: ProductName
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name=ProductVersion,Value=[ProductVersion],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}, Name: ProductVersion
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{40F06490-8C14-43AA-99D3-EEEFDBAC3CFC},,BinaryType=0,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{40F06490-8C14-43AA-99D3-EEEFDBAC3CFC}, Name:
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{40F06490-8C14-43AA-99D3-EEEFDBAC3CFC}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7},,BinaryType=0,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}, Name:
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:074]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{65BB0407-4CC8-4DC7-952E-3EEFDF05602A},,BinaryType=0,,)
MSI (s) (60:B0) [10:53:52:074]: Executing op: RegRemoveValue(Name={CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0},Value=[ProductName],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{65BB0407-4CC8-4DC7-952E-3EEFDF05602A}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:074]: Executing op: RegRemoveValue(,,)
MSI (s) (60:B0) [10:53:52:074]: Executing op: ActionStart(Name=RemoveFolders,Description=Removing folders,Template=Folder: [1])
Action 10:53:52: RemoveFolders. Removing folders
MSI (s) (60:B0) [10:53:52:074]: Executing op: FolderRemove(Folder=C:\ProgramData\Nero\Nero 10\OnlineServices\,Foreign=0)
RemoveFolders: Folder: C:\ProgramData\Nero\Nero 10\OnlineServices\
MSI (s) (60:B0) [10:53:52:074]: Executing op: ActionStart(Name=PublishProduct,Description=Publishing product information,)
Action 10:53:52: PublishProduct. Publishing product information
MSI (s) (60:B0) [10:53:52:074]: Executing op: CleanupConfigData()
MSI (s) (60:B0) [10:53:52:074]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=0,Remove=1)
MSI (s) (60:B0) [10:53:52:074]: Note: 1: 1402 2: UNKNOWN\Installer\Products\ECC9C29D0F5E521479A750093F22B547\Patches 3: 2
MSI (s) (60:B0) [10:53:52:074]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=1,Remove=1)
MSI (s) (60:B0) [10:53:52:074]: Executing op: CleanupConfigData(RemovingProduct=1)
MSI (s) (60:B0) [10:53:52:074]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\ECC9C29D0F5E521479A750093F22B547\Patches 3: 2
MSI (s) (60:B0) [10:53:52:074]: Executing op: ActionStart(Name=Nero_CA_DeleteGlobalFileAssociationDbCommit,,)
Action 10:53:52: Nero_CA_DeleteGlobalFileAssociationDbCommit.
MSI (s) (60:B0) [10:53:52:090]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteGlobalFileAssociationDbCommit,ActionType=1537,Source=BinaryData,Target=CA_DeleteGlobalFileAssociationDb,CustomActionData=Nero 10)
MSI (s) (60:B0) [10:53:52:090]: Executing op: ActionStart(Name=InstallFinalize,,)
Action 10:53:52: InstallFinalize.
MSI (s) (60:B0) [10:53:52:090]: Executing op: CleanupTempFiles(TempFiles=C:\WINDOWS\Installer\33a1c1a3.mst)
MSI (s) (60:B0) [10:53:52:090]: Scheduling file 'C:\WINDOWS\Installer\33a1c1a3.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:B0) [10:53:52:090]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=979200)
MSI (s) (60:B0) [10:53:52:105]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:B0) [10:53:52:105]: User policy value 'DisableRollback' is 0
MSI (s) (60:B0) [10:53:52:105]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:B0) [10:53:52:105]: Unlocking Server
MSI (s) (60:B0) [10:53:52:105]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
MSI (s) (60:B0) [10:53:52:105]: Creating MSIHANDLE (1618) of type 790535 for thread 8112
Action ended 10:53:52: InstallFinalize. Return value 1.
MSI (s) (60:B0) [10:53:52:105]: Skipping action: CANOSUS_InstallCommit.EE698257_A789_474D_A546_5E5AAA5B180D (condition is false)
MSI (s) (60:B0) [10:53:52:105]: Skipping action: LiLiW_RemoveFiles.EDA67544_39E0_4D88_B650_464D261A4F87 (condition is false)
Action ended 10:53:52: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
Property(S): ProductCode = {D92C9CCE-E5F0-4125-977A-0590F3225B74}
Property(S): Installed = 2011/08/29 09:20:22
Property(S): IS_CHAINER_POST_COMMANDLINE = /l"C:\Users\ZANDRA~1\AppData\Local\Temp\MSI1b9f9.LOG" /qb /x{523B2B1B-D8DB-4B41-90FF-C4D799E2758A};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{237CCB62-8454-43E3-B158-3ACD0134852E};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{6DFB899F-17A2-48F0-A533-ED8D6866CF38};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\""
Property(S): Nero.RefCnt_Dummy.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): Nero.RefCnt_AllOtherFiles3.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): Nero.RefCnt_AllOtherFiles2.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): Nero.RefCnt_AllOtherFiles1.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): Nero.RefCnt_AllOtherFiles.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): Nero.RefCnt_RegNeroLanguage.F41DFC5A_891C_48E4_A24B_33C93A9B7A1B = 2
Property(S): Nero.RefCnt_Update = 1
Property(S): Nero.RefCnt_Ref_Update = 1
Property(S): Nero.RefCnt_Ref_MovieThemePackBasic = 1
Property(S): Nero.RefCnt_MovieThemePackBasic = 1
Property(S): Nero.RefCnt_Ref_MobileSync = 1
Property(S): Nero.RefCnt_MobileSync = 1
Property(S): Nero.RefCnt_Ref_CoreComponents = 1
Property(S): Nero.RefCnt_CoreComponents = 1
Property(S): Nero.RefCnt_Ref_ControlCenter = 1
Property(S): Nero.RefCnt_ControlCenter = 1
Property(S): Nero.RefCnt_InstallReg = 1
Property(S): Nero.RefCnt_Ref_BDCore = 1
Property(S): Nero.RefCnt_BDCore = 1
Property(S): Nero.RefCnt_Ref_MobileSyncHelpChm = 0
Property(S): Nero.RefCnt_Ref_ControlCenterHelpChm = 1
Property(S): Nero.RefCnt_MobileSyncHelpChm = 0
Property(S): Nero.RefCnt_ControlCenterHelpChm = 1
Property(S): Nero.RefCnt___InstallReg65 = 0
Property(S): Nero.RefCnt___BDCore65 = 0
Property(S): Nero.RefCnt___ControlCenter65 = 0
Property(S): Nero.RefCnt___ControlCenterHelpChm65 = 0
Property(S): Nero.RefCnt___CoreComponents65 = 0
Property(S): Nero.RefCnt___MobileSync65 = 0
Property(S): Nero.RefCnt___MobileSyncHelpChm65 = 0
Property(S): Nero.RefCnt___MovieThemePackBasic65 = 0
Property(S): Nero.RefCnt___Ref_BDCore65 = 0
Property(S): Nero.RefCnt___Ref_ControlCenter65 = 0
Property(S): Nero.RefCnt___Ref_ControlCenterHelpChm65 = 0
Property(S): Nero.RefCnt___Ref_CoreComponents65 = 0
Property(S): Nero.RefCnt___Ref_MobileSync65 = 0
Property(S): Nero.RefCnt___Ref_MobileSyncHelpChm65 = 0
Property(S): Nero.RefCnt___Ref_MovieThemePackBasic65 = 0
Property(S): Nero.RefCnt___Ref_Update65 = 0
Property(S): Nero.RefCnt___Update65 = 0
Property(S): Nero.RefCnt___RegNeroLanguage.F41DFC5A_891C_48E4_A24B_33C93A9B7A1B65 = 0
Property(S): Nero.RefCnt___Dummy.EE698257_A789_474D_A546_5E5AAA5B180D65 = 0
Property(S): Nero.Package_NPMOVB = 10.2.10200.0.0
Property(S): Nero.Package_NL0 = 2.0.20000.9.12
Property(S): Nero.Package_NL = 2.0.20000.9.12
Property(S): Nero.Package_NCC0 = 10.6.12500.0.5
Property(S): Nero.Package_NCC = 10.6.12500.0.5
Property(S): Nero.Package_NBDCORE = 7.3.10000.0.0
Property(S): Nero.Package_CHM_NCC = 10.2.10800
Property(S): Nero.ProductCode_NUPD = {65BB0407-4CC8-4DC7-952E-3EEFDF05602A}
Property(S): Nero.ProductCode_NPMOVB = {F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}
Property(S): Nero.ProductCode_NL0 = {2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}
Property(S): Nero.ProductCode_NL = {2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}
Property(S): Nero.ProductCode_NCC0 = {6DFB899F-17A2-48F0-A533-ED8D6866CF38}
Property(S): Nero.ProductCode_NCC = {6DFB899F-17A2-48F0-A533-ED8D6866CF38}
Property(S): Nero.ProductCode_NBDCORE = {237CCB62-8454-43E3-B158-3ACD0134852E}
Property(S): Nero.ProductCode_MH4DELL.MINOR = {40F06490-8C14-43AA-99D3-EEEFDBAC3CFC}
Property(S): Nero.ProductCode_MH4DELL.MAJOR = {40F06490-8C14-43AA-99D3-EEEFDBAC3CFC}
Property(S): Nero.ProductCode_MH4DELL = {40F06490-8C14-43AA-99D3-EEEFDBAC3CFC}
Property(S): Nero.ProductCode_DF = {C3580AC4-C827-4332-B935-9A282ED5BB97}
Property(S): Nero.ProductCode_CHM_NCC = {523B2B1B-D8DB-4B41-90FF-C4D799E2758A}
Property(S): Nero.ProductCode_CHM_MH4DELL.MINOR = {9084C3D8-90BD-40C8-8252-30D0C41FD449}
Property(S): Nero.ProductCode_CHM_MH4DELL.MAJOR = {9084C3D8-90BD-40C8-8252-30D0C41FD449}
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): Preselected = 1
Property(S): UILevel = 5
Property(S): OriginalDatabase = C:\Windows\Installer\11a49.msi
Property(S): DATABASE = C:\Windows\Installer\11a49.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.3.14393.0
Property(S): MsiNetAssemblySupport = 4.6.1586.0
Property(S): Date = 6/11/2017
Property(S): Time = 10:53:52
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 23
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 1033
Property(S): ComputerName = ZANDRAJONES-PC
Property(S): UserLanguageID = 1033
Property(S): UserSID = S-1-5-21-3088507388-2561779440-336279174-1001
Property(S): LogonUser = Zandra Jones
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 5094
Property(S): PhysicalMemory = 3839
Property(S): Intel = 16
Property(S): Msix64 = 16
Property(S): MsiAMD64 = 16
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): FontsFolder = C:\WINDOWS\Fonts\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): MyPicturesFolder = C:\Users\Zandra Jones\Pictures\
Property(S): LocalAppDataFolder = C:\Users\Zandra Jones\AppData\Local\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): SendToFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): VersionNT = 603
Property(S): Nero_CA_DeleteGlobalFileAssociationDbCommit = Nero 10
Property(S): Nero_CA_DeleteGlobalFileAssociationDbRollback = Nero 10
Property(S): NERO = C:\Program Files (x86)\Nero\
Property(S): RecentFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): TARGETDIR = C:\
Property(S): ALLUSERSPROFILE = C:\ProgramData\
Property(S): PrintHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): PersonalFolder = C:\Users\Zandra Jones\Documents\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): NetHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Nero\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Nero\Database\
Property(S): FavoritesFolder = C:\Users\Zandra Jones\Favorites\
Property(S): AppDataFolder = C:\Users\Zandra Jones\AppData\Roaming\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): INSTALLDIR = C:\Program Files (x86)\Nero\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): TempFolder = C:\Users\ZANDRA~1\AppData\Local\Temp\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): RemoteAdminTS = 1
Property(S): SystemFolder = C:\WINDOWS\SysWOW64\
Property(S): System64Folder = C:\WINDOWS\system32\
Property(S): WindowsVolume = C:\
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 9600
Property(S): VersionNT64 = 603
Property(S): VersionMsi = 5.00
Property(S): VersionDatabase = 405
Property(S): MsiSystemRebootPending = 1
Property(S): Nero.ProductCode_CHM_MH4DELL = {9084C3D8-90BD-40C8-8252-30D0C41FD449}
Property(S): REMOVE = ALL
Property(S): CURRENTDIRECTORY = C:\Program Files\VS Revo Group\Revo Uninstaller
Property(S): USERPROFILE = C:\Users\Zandra Jones\
Property(S): WindowsFolder = C:\WINDOWS\
Property(S): CLIENTUILEVEL = 0
Property(S): LiLiW_RemoveKey.EDA67544_39E0_4D88_B650_464D261A4F87 = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?
Property(S): LiLiW_CommitKey.EDA67544_39E0_4D88_B650_464D261A4F87 = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?
Property(S): LiLiW_AcceptEula.EDA67544_39E0_4D88_B650_464D261A4F87 = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?
Property(S): NERO.userAcknowledgedEula = NO
Property(S): NewProperty3.EDA67544_39E0_4D88_B650_464D261A4F87 = 0
Property(S): ISVROOT_PORT_NO.EDA67544_39E0_4D88_B650_464D261A4F87 = 0
Property(S): IS_PRINT_DIALOG = LicenseAgreement.EDA67544_39E0_4D88_B650_464D261A4F87
Property(S): IS_SQLSERVER_AUTHENTICATION.EDA67544_39E0_4D88_B650_464D261A4F87 = 0
Property(S): IS_SQLSERVER_USERNAME.EDA67544_39E0_4D88_B650_464D261A4F87 = sa
Property(S): NERO.ADVRCNTR_FILENAME = AdvrCntr5.dll
Property(S): NERO.ERROR_CODE = 0
Property(S): NERO.IS_KEY_NEW = YES
Property(S): NERO.IS_KEY_VALID = NO
Property(S): NERO.LicenseLim_EnableUsageStatistics = YES
Property(S): NERO.licenseModuleIncluded.D39B4B65_3692_4292_833F_2C81D15845EB = YES
Property(S): NewProperty1.EDA67544_39E0_4D88_B650_464D261A4F87 = 0
Property(S): NewProperty2.EDA67544_39E0_4D88_B650_464D261A4F87 = 0
Property(S): SecureCustomProperties.EDA67544_39E0_4D88_B650_464D261A4F87 = NERO.IS_EULA_ACCEPTED;NERO.USER_KEY
Property(S): SetupType.EDA67544_39E0_4D88_B650_464D261A4F87 = Typical
Property(S): ARPURLINFOABOUT = http://www.nero.com/
Property(S): CLIENTPROCESSID = 496
Property(S): PRODUCTLANGUAGE = 0
Property(S): NERO.USER_KEY = 4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44
Property(S): SetupType = Typical
Property(S): NERO.IS_EULA_ACCEPTED = NO
Property(S): INSTALLDIR.F41DFC5A_891C_48E4_A24B_33C93A9B7A1B = C:\
Property(S): NERO_10.EE698257_A789_474D_A546_5E5AAA5B180D = C:\ProgramData\Nero\Nero 10\
Property(S): NERO1.EE698257_A789_474D_A546_5E5AAA5B180D = C:\ProgramData\Nero\
Property(S): ONLINESERVICES.EE698257_A789_474D_A546_5E5AAA5B180D = C:\ProgramData\Nero\Nero 10\OnlineServices\
Property(S): NERO.SENDUSAGESTATISTICS.EE698257_A789_474D_A546_5E5AAA5B180D = ?
Property(S): Nero.UsageStatsIncluded.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): SecureCustomProperties.EE698257_A789_474D_A546_5E5AAA5B180D = NERO.SENDUSAGESTATISTICS.EE698257_A789_474D_A546_5E5AAA5B180D;NERO.SENDUSAGESTATISTICS.EE698257_A789_474D_A546_5E5AAA5B180D
Property(S): USERNAME = AutoBVT
Property(S): COMPANYNAME = Microsoft
Property(S): ACTION = INSTALL
Property(S): EXECUTEACTION = INSTALL
Property(S): ROOTDRIVE = C:\
Property(S): SUPPORTDIR = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\
Property(S): NERO.ADVRCNTR_PATH = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll
Property(S): SECONDSEQUENCE = 1
Property(S): NERO.ACTION_DATA = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?
Property(S): ProductState = 5
Property(S): TRANSFORMS = C:\Windows\Installer\{D92C9CCE-E5F0-4125-977A-0590F3225B74}\1033.mst
Property(S): PackageCode = {D5723832-302A-4BB1-BE36-434859360ADB}
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): NERO.INSTALL_DESKTOPSHORTCUT = 1
Property(S): _IsMaintenance = Change
Property(S): RestartManagerOption = CloseRestart
Property(S): _IsSetupTypeMin = Typical
Property(S): Display_IsBitmapDlg = 1
Property(S): REBOOT = ReallySuppress
Property(S): ALLUSERS = 1
Property(S): ARPNOREPAIR = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DWUSINTERVAL = 30
Property(S): DWUSLINK = CEFBD0FFA9DCB0D8FEAC5098AEBB978FEEAC878FFEEBA7A8CECB77AFDE6C40C8C98CA0BFE9AC
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): ErrorDialog = SetupError
Property(S): INSTALLLEVEL = 100
Property(S): ISVROOT_PORT_NO = 0
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PREVENT_DOWNGRADE_EXIT = A newer version of this application is already installed on this computer. If you wish to install this version, please uninstall the newer version first. Click OK to exit the wizard.
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): InstallChoice = AR
Property(S): MSIDISABLERMRESTART = 0
Property(S): MSIRMSHUTDOWN = 2
Property(S): Manufacturer = Nero AG
Property(S): NERO.CDNUMBER = 20110829132945703
Property(S): NERO.INSTALLER_CATEGORY = 10
Property(S): NERO.INSTALL_AUTOPLAY = 1
Property(S): NERO.LANGUAGES_INSTALL = zh-TW,cs-CZ,da-DK,de-DE,el-GR,en-US,es-ES,fi-FI,fr-FR,hu-HU,it-IT,ja-JP,ko-KR,nl-NL,nb-NO,pl-PL,pt-BR,pt-PT,ru-RU,sv-SE,th-TH,tr-TR,zh-CN
Property(S): NERO.LANGUAGE_CURRENT = en-US
Property(S): NERO.PRODUCT_LINE = NeroX
Nissi1
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: BindImage
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: Font
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: Class
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: TypeLib
Action start 10:53:56: InstallValidate.
MSI (s) (60:30) [10:53:56:239]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI (s) (60:30) [10:53:56:257]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: BindImage
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: Font
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: Class
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:30) [10:53:56:259]: Note: 1: 2727 2:
MSI (s) (60:30) [10:53:56:262]: Note: 1: 2727 2:
MSI (s) (60:30) [10:53:56:263]: Doing action: RemoveExistingProducts
Action ended 10:53:56: InstallValidate. Return value 1.
MSI (s) (60:30) [10:53:56:264]: Skipping RemoveExistingProducts action: current configuration is maintenance mode or an uninstall
Action start 10:53:56: RemoveExistingProducts.
MSI (s) (60:30) [10:53:56:264]: Skipping action: Nero_CA_SetMediaPackage (condition is false)
MSI (s) (60:30) [10:53:56:264]: Skipping action: Nero_CAData_RestoreMediaPackage (condition is false)
MSI (s) (60:30) [10:53:56:264]: Doing action: InstallInitialize
Action ended 10:53:56: RemoveExistingProducts. Return value 0.
MSI (s) (60:30) [10:53:56:264]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:30) [10:53:56:264]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:30) [10:53:56:264]: BeginTransaction: Locking Server
MSI (s) (60:30) [10:53:56:265]: Transforming table Property.
MSI (s) (60:30) [10:53:56:268]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:30) [10:53:56:271]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
MSI (s) (60:30) [10:53:56:271]: SRSetRestorePoint skipped for this transaction.
MSI (s) (60:30) [10:53:56:275]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:30) [10:53:56:278]: Server not locked: locking for product {523B2B1B-D8DB-4B41-90FF-C4D799E2758A}
Action start 10:53:56: InstallInitialize.
MSI (s) (60:30) [10:53:56:321]: PROPERTY CHANGE: Deleting ProductToBeRegistered property. Its current value is '1'.
MSI (s) (60:30) [10:53:56:322]: Note: 1: 2205 2:  3: Class
MSI (s) (60:30) [10:53:56:322]: Note: 1: 2228 2:  3: Class 4: SELECT `CLSID` FROM `Class` WHERE `Icon_`=? AND `Class`.`Attributes`=1
MSI (s) (60:30) [10:53:56:322]: Note: 1: 2228 2:  3: Class 4: SELECT `Component`,`CLSID` FROM `Component`,`Class` WHERE `Component`=`Component_` AND `Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:30) [10:53:56:322]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:30) [10:53:56:322]: Note: 1: 2228 2:  3: Extension 4: SELECT `Component`,`Extension` FROM `Component`,`Extension`,`ProgId` WHERE `Component`.`Component`=`Extension`.`Component_` AND `ProgId`.`ProgId`=`Extension`.`ProgId_` AND `ProgId`.`Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:30) [10:53:56:322]: 'NeroHelpIcon.BBDB24D3_07A5_496B_AA18_6A3ED03D6698' icon will be removed.
MSI (s) (60:30) [10:53:56:322]: Doing action: Nero_CA_DeleteLocalFileAssociationDb
Action ended 10:53:56: InstallInitialize. Return value 1.
Action start 10:53:56: Nero_CA_DeleteLocalFileAssociationDb.
MSI (s) (60:30) [10:53:56:327]: Doing action: Nero_CA_GatherOriginalFileAssociation
Action ended 10:53:56: Nero_CA_DeleteLocalFileAssociationDb. Return value 1.
Action start 10:53:56: Nero_CA_GatherOriginalFileAssociation.
MSI (s) (60:30) [10:53:56:333]: Skipping action: Nero_CA_RestoreMediaPackage (condition is false)
MSI (s) (60:30) [10:53:56:333]: Skipping action: AllocateRegistrySpace (condition is false)
MSI (s) (60:30) [10:53:56:333]: Doing action: ProcessComponents
Action ended 10:53:56: Nero_CA_GatherOriginalFileAssociation. Return value 1.
Action start 10:53:56: ProcessComponents.
MSI (s) (60:30) [10:53:56:348]: Doing action: UnpublishComponents
Action ended 10:53:56: ProcessComponents. Return value 1.
MSI (s) (60:30) [10:53:56:349]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:30) [10:53:56:349]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: UnpublishComponents.
MSI (s) (60:30) [10:53:56:349]: Doing action: MsiUnpublishAssemblies
Action ended 10:53:56: UnpublishComponents. Return value 0.
MSI (s) (60:30) [10:53:56:351]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:30) [10:53:56:351]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: MsiUnpublishAssemblies.
MSI (s) (60:30) [10:53:56:352]: Doing action: UnpublishFeatures
Action ended 10:53:56: MsiUnpublishAssemblies. Return value 0.
Action start 10:53:56: UnpublishFeatures.
MSI (s) (60:30) [10:53:56:354]: Doing action: StopServices
Action ended 10:53:56: UnpublishFeatures. Return value 1.
MSI (s) (60:30) [10:53:56:355]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:30) [10:53:56:355]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 10:53:56: StopServices.
MSI (s) (60:30) [10:53:56:355]: Doing action: DeleteServices
Action ended 10:53:56: StopServices. Return value 1.
MSI (s) (60:30) [10:53:56:356]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:30) [10:53:56:356]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 10:53:56: DeleteServices.
MSI (s) (60:30) [10:53:56:356]: Doing action: UnregisterComPlus
Action ended 10:53:56: DeleteServices. Return value 1.
MSI (s) (60:30) [10:53:56:356]: Note: 1: 2205 2:  3: Complus
MSI (s) (60:30) [10:53:56:356]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
Action start 10:53:56: UnregisterComPlus.
MSI (s) (60:30) [10:53:56:357]: Doing action: SelfUnregModules
Action ended 10:53:56: UnregisterComPlus. Return value 0.
MSI (s) (60:30) [10:53:56:357]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:30) [10:53:56:357]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
Action start 10:53:56: SelfUnregModules.
MSI (s) (60:30) [10:53:56:357]: Doing action: UnregisterTypeLibraries
Action ended 10:53:56: SelfUnregModules. Return value 1.
MSI (s) (60:30) [10:53:56:369]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:30) [10:53:56:369]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
Action start 10:53:56: UnregisterTypeLibraries.
MSI (s) (60:30) [10:53:56:369]: Doing action: RemoveODBC
Action ended 10:53:56: UnregisterTypeLibraries. Return value 0.
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:389]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:389]: Note: 1: 2711 2: ODBCDriverManager
Action start 10:53:56: RemoveODBC.
MSI (s) (60:30) [10:53:56:394]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (60:30) [10:53:56:399]: Doing action: UnregisterFonts
Action ended 10:53:56: RemoveODBC. Return value 1.
MSI (s) (60:30) [10:53:56:400]: Note: 1: 2205 2:  3: Font
MSI (s) (60:30) [10:53:56:400]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
Action start 10:53:56: UnregisterFonts.
MSI (s) (60:30) [10:53:56:400]: Doing action: RemoveRegistryValues
Action ended 10:53:56: UnregisterFonts. Return value 1.
Action start 10:53:56: RemoveRegistryValues.
MSI (s) (60:30) [10:53:56:402]: Doing action: UnregisterClassInfo
Action ended 10:53:56: RemoveRegistryValues. Return value 1.
MSI (s) (60:30) [10:53:56:402]: Note: 1: 2205 2:  3: Class
MSI (s) (60:30) [10:53:56:402]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: UnregisterClassInfo.
MSI (s) (60:30) [10:53:56:402]: Doing action: UnregisterExtensionInfo
Action ended 10:53:56: UnregisterClassInfo. Return value 0.
MSI (s) (60:30) [10:53:56:404]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:30) [10:53:56:404]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: UnregisterExtensionInfo.
MSI (s) (60:30) [10:53:56:404]: Doing action: UnregisterProgIdInfo
Action ended 10:53:56: UnregisterExtensionInfo. Return value 0.
MSI (s) (60:30) [10:53:56:405]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:30) [10:53:56:405]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: UnregisterProgIdInfo.
MSI (s) (60:30) [10:53:56:405]: Doing action: UnregisterMIMEInfo
Action ended 10:53:56: UnregisterProgIdInfo. Return value 0.
MSI (s) (60:30) [10:53:56:405]: Note: 1: 2205 2:  3: MIME
MSI (s) (60:30) [10:53:56:405]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: UnregisterMIMEInfo.
MSI (s) (60:30) [10:53:56:405]: Doing action: RemoveIniValues
Action ended 10:53:56: UnregisterMIMEInfo. Return value 0.
MSI (s) (60:30) [10:53:56:406]: Note: 1: 2205 2:  3: IniFile
MSI (s) (60:30) [10:53:56:406]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
Action start 10:53:56: RemoveIniValues.
MSI (s) (60:30) [10:53:56:406]: Doing action: RemoveShortcuts
Action ended 10:53:56: RemoveIniValues. Return value 1.
Action start 10:53:56: RemoveShortcuts.
MSI (s) (60:30) [10:53:56:410]: Doing action: RemoveEnvironmentStrings
Action ended 10:53:56: RemoveShortcuts. Return value 1.
MSI (s) (60:30) [10:53:56:411]: Note: 1: 2205 2:  3: Environment
MSI (s) (60:30) [10:53:56:411]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
Action start 10:53:56: RemoveEnvironmentStrings.
MSI (s) (60:30) [10:53:56:411]: Doing action: RemoveDuplicateFiles
Action ended 10:53:56: RemoveEnvironmentStrings. Return value 1.
Action start 10:53:56: RemoveDuplicateFiles.
MSI (s) (60:30) [10:53:56:411]: Doing action: RemoveFiles
Action ended 10:53:56: RemoveDuplicateFiles. Return value 1.
Action start 10:53:56: RemoveFiles.
MSI (s) (60:30) [10:53:56:424]: Counted 16 foreign folders to be removed.
MSI (s) (60:30) [10:53:56:424]: Removing foreign folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\
MSI (s) (60:30) [10:53:56:425]: Removing foreign folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\
MSI (s) (60:30) [10:53:56:426]: Removing foreign folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\
MSI (s) (60:30) [10:53:56:427]: Doing action: RemoveFolders
Action ended 10:53:56: RemoveFiles. Return value 1.
Action start 10:53:56: RemoveFolders.
MSI (s) (60:30) [10:53:56:427]: Doing action: CreateFolders
Action ended 10:53:56: RemoveFolders. Return value 0.
Action start 10:53:56: CreateFolders.
MSI (s) (60:30) [10:53:56:428]: Doing action: MoveFiles
Action ended 10:53:56: CreateFolders. Return value 0.
Action start 10:53:56: MoveFiles.
MSI (s) (60:30) [10:53:56:429]: Doing action: InstallFiles
Action ended 10:53:56: MoveFiles. Return value 1.
MSI (s) (60:30) [10:53:56:431]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
MSI (s) (60:30) [10:53:56:431]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
MSI (s) (60:30) [10:53:56:432]: Note: 1: 2205 2:  3: MsiSFCBypass
MSI (s) (60:30) [10:53:56:432]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
MSI (s) (60:30) [10:53:56:432]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (60:30) [10:53:56:432]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
Action start 10:53:56: InstallFiles.
MSI (s) (60:30) [10:53:56:433]: Doing action: PatchFiles
Action ended 10:53:56: InstallFiles. Return value 1.
Action start 10:53:56: PatchFiles.
MSI (s) (60:30) [10:53:56:433]: Doing action: DuplicateFiles
Action ended 10:53:56: PatchFiles. Return value 1.
Action start 10:53:56: DuplicateFiles.
MSI (s) (60:30) [10:53:56:434]: Doing action: BindImage
Action ended 10:53:56: DuplicateFiles. Return value 1.
Action start 10:53:56: BindImage.
MSI (s) (60:30) [10:53:56:434]: Doing action: CreateShortcuts
Action ended 10:53:56: BindImage. Return value 1.
MSI (s) (60:30) [10:53:56:435]: Note: 1: 2205 2:  3: MsiShortcutProperty
MSI (s) (60:30) [10:53:56:436]: Note: 1: 2205 2:  3: MsiShortcutProperty
Action start 10:53:56: CreateShortcuts.
MSI (s) (60:30) [10:53:56:436]: Doing action: RegisterClassInfo
Action ended 10:53:56: CreateShortcuts. Return value 1.
MSI (s) (60:30) [10:53:56:436]: Note: 1: 2205 2:  3: Class
MSI (s) (60:30) [10:53:56:436]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:53:56: RegisterClassInfo.
MSI (s) (60:30) [10:53:56:437]: Doing action: RegisterExtensionInfo
Action ended 10:53:56: RegisterClassInfo. Return value 0.
MSI (s) (60:30) [10:53:56:438]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:30) [10:53:56:438]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:53:56: RegisterExtensionInfo.
MSI (s) (60:30) [10:53:56:438]: Doing action: RegisterProgIdInfo
Action ended 10:53:56: RegisterExtensionInfo. Return value 0.
MSI (s) (60:30) [10:53:56:438]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:30) [10:53:56:438]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:53:56: RegisterProgIdInfo.
MSI (s) (60:30) [10:53:56:439]: Doing action: RegisterMIMEInfo
Action ended 10:53:56: RegisterProgIdInfo. Return value 0.
MSI (s) (60:30) [10:53:56:439]: Note: 1: 2205 2:  3: MIME
MSI (s) (60:30) [10:53:56:439]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:53:56: RegisterMIMEInfo.
MSI (s) (60:30) [10:53:56:439]: Doing action: WriteRegistryValues
Action ended 10:53:56: RegisterMIMEInfo. Return value 0.
Action start 10:53:56: WriteRegistryValues.
MSI (s) (60:30) [10:53:56:440]: Doing action: WriteIniValues
Action ended 10:53:56: WriteRegistryValues. Return value 1.
MSI (s) (60:30) [10:53:56:440]: Note: 1: 2205 2:  3: IniFile
MSI (s) (60:30) [10:53:56:440]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
Action start 10:53:56: WriteIniValues.
MSI (s) (60:30) [10:53:56:440]: Doing action: WriteEnvironmentStrings
Action ended 10:53:56: WriteIniValues. Return value 1.
MSI (s) (60:30) [10:53:56:441]: Note: 1: 2205 2:  3: Environment
MSI (s) (60:30) [10:53:56:441]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
Action start 10:53:56: WriteEnvironmentStrings.
MSI (s) (60:30) [10:53:56:441]: Doing action: RegisterFonts
Action ended 10:53:56: WriteEnvironmentStrings. Return value 1.
MSI (s) (60:30) [10:53:56:441]: Note: 1: 2205 2:  3: Font
MSI (s) (60:30) [10:53:56:441]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
Action start 10:53:56: RegisterFonts.
MSI (s) (60:30) [10:53:56:441]: Doing action: InstallODBC
Action ended 10:53:56: RegisterFonts. Return value 1.
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2711 2: ODBCDriverManager
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
Action start 10:53:56: InstallODBC.
MSI (s) (60:30) [10:53:56:442]: Doing action: RegisterTypeLibraries
Action ended 10:53:56: InstallODBC. Return value 0.
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
Action start 10:53:56: RegisterTypeLibraries.
MSI (s) (60:30) [10:53:56:442]: Doing action: SelfRegModules
Action ended 10:53:56: RegisterTypeLibraries. Return value 0.
MSI (s) (60:30) [10:53:56:443]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:30) [10:53:56:443]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
Action start 10:53:56: SelfRegModules.
MSI (s) (60:30) [10:53:56:443]: Doing action: RegisterComPlus
Action ended 10:53:56: SelfRegModules. Return value 1.
MSI (s) (60:30) [10:53:56:443]: Note: 1: 2205 2:  3: Complus
MSI (s) (60:30) [10:53:56:443]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action start 10:53:56: RegisterComPlus.
MSI (s) (60:30) [10:53:56:444]: Doing action: InstallServices
Action ended 10:53:56: RegisterComPlus. Return value 0.
MSI (s) (60:30) [10:53:56:444]: Detected older ServiceInstall table schema
MSI (s) (60:30) [10:53:56:444]: Note: 1: 2205 2:  3: ServiceInstall
MSI (s) (60:30) [10:53:56:444]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
Action start 10:53:56: InstallServices.
MSI (s) (60:30) [10:53:56:444]: Doing action: StartServices
Action ended 10:53:56: InstallServices. Return value 1.
MSI (s) (60:30) [10:53:56:445]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:30) [10:53:56:445]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 10:53:56: StartServices.
MSI (s) (60:30) [10:53:56:445]: Doing action: RegisterUser
Action ended 10:53:56: StartServices. Return value 1.
Action start 10:53:56: RegisterUser.
MSI (s) (60:30) [10:53:56:446]: Doing action: RegisterProduct
Action ended 10:53:56: RegisterUser. Return value 0.
Action start 10:53:56: RegisterProduct.
MSI (s) (60:30) [10:53:56:448]: Doing action: PublishComponents
Action ended 10:53:56: RegisterProduct. Return value 1.
MSI (s) (60:30) [10:53:56:449]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:30) [10:53:56:449]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action start 10:53:56: PublishComponents.
MSI (s) (60:30) [10:53:56:449]: Doing action: MsiPublishAssemblies
Action ended 10:53:56: PublishComponents. Return value 0.
MSI (s) (60:30) [10:53:56:450]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:30) [10:53:56:450]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action start 10:53:56: MsiPublishAssemblies.
MSI (s) (60:30) [10:53:56:451]: Doing action: PublishFeatures
Action ended 10:53:56: MsiPublishAssemblies. Return value 0.
Action start 10:53:56: PublishFeatures.
MSI (s) (60:30) [10:53:56:451]: Doing action: PublishProduct
Action ended 10:53:56: PublishFeatures. Return value 1.
Action start 10:53:56: PublishProduct.
MSI (s) (60:30) [10:53:56:456]: Doing action: Nero_CA_UninstallSetAssociationsRollback
Action ended 10:53:56: PublishProduct. Return value 1.
Action start 10:53:56: Nero_CA_UninstallSetAssociationsRollback.
MSI (s) (60:30) [10:53:56:462]: Doing action: Nero_CA_UninstallSetAssociations
Action ended 10:53:56: Nero_CA_UninstallSetAssociationsRollback. Return value 1.
Action start 10:53:56: Nero_CA_UninstallSetAssociations.
MSI (s) (60:30) [10:53:56:467]: Skipping action: Nero_CA_InstallSetAssociationsRollback (condition is false)
MSI (s) (60:30) [10:53:56:467]: Skipping action: Nero_CA_InstallSetAssociations (condition is false)
MSI (s) (60:30) [10:53:56:467]: Doing action: Nero_CA_DeleteAssociationsBackup
Action ended 10:53:56: Nero_CA_UninstallSetAssociations. Return value 1.
Action start 10:53:56: Nero_CA_DeleteAssociationsBackup.
MSI (s) (60:30) [10:53:56:472]: Doing action: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore
Action ended 10:53:56: Nero_CA_DeleteAssociationsBackup. Return value 1.
Action start 10:53:56: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore.
MSI (s) (60:30) [10:53:56:477]: Skipping action: ScheduleReboot (condition is false)
MSI (s) (60:30) [10:53:56:477]: Doing action: InstallFinalize
Action ended 10:53:56: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore. Return value 1.
Action start 10:53:56: InstallFinalize.
MSI (s) (60:30) [10:53:56:479]: Running Script: C:\WINDOWS\Installer\MSIF7F4.tmp
MSI (s) (60:30) [10:53:56:479]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (60:30) [10:53:56:486]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:30) [10:53:56:494]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:30) [10:53:56:499]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1254839997,LangId=0,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (60:30) [10:53:56:500]: Executing op: ProductInfo(ProductKey={523B2B1B-D8DB-4B41-90FF-C4D799E2758A},ProductName=Nero ControlCenter 10 Help (CHM),PackageName=Nero.ControlCenterHelpChm.msi,Language=0,Version=167914032,Assignment=1,ObsoleteArg=0,ProductIcon=NeroHelpIcon.BBDB24D3_07A5_496B_AA18_6A3ED03D6698,PackageMediaPath=\applications\controlcenterhelpchm\,PackageCode={1A7F010E-8947-468D-A021-92CE03780E30},,,InstanceType=0,LUASetting=1,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (s) (60:30) [10:53:56:500]: Executing op: DialogInfo(Type=0,Argument=0)
MSI (s) (60:30) [10:53:56:502]: Executing op: DialogInfo(Type=1,Argument=Nero ControlCenter 10 Help (CHM))
MSI (s) (60:30) [10:53:56:502]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (60:30) [10:53:56:502]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (60:30) [10:53:56:502]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (60:30) [10:53:56:502]: Executing op: ActionStart(Name=InstallInitialize,,)
MSI (s) (60:30) [10:53:56:504]: Executing op: ProductUnregister(UpgradeCode={DB1A16FB-84D6-4824-A7E5-26B7BB9B1CA7})
MSI (s) (60:30) [10:53:56:504]: Note: 1: 1402 2: UNKNOWN\Products\B1B2B325BD8D14B409FF4C7D992E57A8\Transforms 3: 2
MSI (s) (60:30) [10:53:56:505]: Note: 1: 1402 2: UNKNOWN\Products\B1B2B325BD8D14B409FF4C7D992E57A8\Transforms 3: 2
MSI (s) (60:30) [10:53:56:505]: Scheduling file 'C:\Windows\Installer\11a7e.msi' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:30) [10:53:56:518]: Note: 1: 1402 2: UNKNOWN\Products\B1B2B325BD8D14B409FF4C7D992E57A8\Usage 3: 2
MSI (s) (60:30) [10:53:56:519]: Executing op: ProductCPDisplayInfoUnregister()
MSI (s) (60:30) [10:53:56:520]: Executing op: ProductUnpublish(PackageKey={1A7F010E-8947-468D-A021-92CE03780E30})
MSI (s) (60:30) [10:53:56:521]: Transforms are not secure.
MSI (s) (60:30) [10:53:56:521]: Processing cached transform: C:\WINDOWS\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst
MSI (s) (60:30) [10:53:56:521]: Scheduling file 'C:\WINDOWS\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:30) [10:53:56:522]: Registering cached transform: C:\WINDOWS\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst
MSI (s) (60:30) [10:53:56:524]: Executing op: UpgradeCodeUnpublish(UpgradeCode={DB1A16FB-84D6-4824-A7E5-26B7BB9B1CA7})
MSI (s) (60:30) [10:53:56:525]: Executing op: IconRemove(Icon=NeroHelpIcon.BBDB24D3_07A5_496B_AA18_6A3ED03D6698,)
MSI (s) (60:30) [10:53:56:526]: Scheduling file 'C:\WINDOWS\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\NeroHelpIcon.BBDB24D3_07A5_496B_AA18_6A3ED03D6698' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:30) [10:53:56:526]: Executing op: ProductUnpublishClient(,,)
MSI (s) (60:30) [10:53:56:527]: Note: 1: 1402 2: UNKNOWN\Installer\Products\B1B2B325BD8D14B409FF4C7D992E57A8 3: 2
MSI (s) (60:30) [10:53:56:527]: Executing op: SourceListUnpublish(,)
MSI (s) (60:30) [10:53:56:527]: Note: 1: 1402 2: UNKNOWN\Installer\Products\B1B2B325BD8D14B409FF4C7D992E57A8\SourceList 3: 2
MSI (s) (60:30) [10:53:56:527]: Executing op: ActionStart(Name=Nero_CA_DeleteLocalFileAssociationDb,,)
MSI (s) (60:30) [10:53:56:528]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteLocalFileAssociationDb,ActionType=1281,Source=BinaryData,Target=CA_DeleteLocalFileAssociationDb,CustomActionData={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:531]: Executing op: ActionStart(Name=Nero_CA_GatherOriginalFileAssociation,,)
MSI (s) (60:30) [10:53:56:532]: Executing op: CustomActionSchedule(Action=Nero_CA_GatherOriginalFileAssociation,ActionType=1025,Source=BinaryData,Target=CA_GatherOriginalFileAssociation,)
MSI (s) (60:EC) [10:53:56:539]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIF8D1.tmp, Entrypoint: CA_GatherOriginalFileAssociation
MSI (s) (60:30) [10:53:56:590]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (60:30) [10:53:56:590]: Executing op: ProgressTotal(Total=59,Type=1,ByteEquivalent=24000)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={4C55C4F6-8B7C-41DD-963F-C3F340B169A1},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={4C55C4F6-8B7C-41DD-963F-C3F340B169A1},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={C91EE7D0-690C-4FA5-BD7A-667140F49EE9},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={C91EE7D0-690C-4FA5-BD7A-667140F49EE9},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={D55AD2A4-9731-4D1F-A070-7C08867D813D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={D55AD2A4-9731-4D1F-A070-7C08867D813D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={8DCD6DDA-2280-4B9C-BF66-F26217843DF3},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={8DCD6DDA-2280-4B9C-BF66-F26217843DF3},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={D01133F7-1526-41D5-AF6D-25C4C0FBEBD5},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={D01133F7-1526-41D5-AF6D-25C4C0FBEBD5},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={CF0271AA-9CBC-4F2E-AD25-1136EBC92CC8},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={CF0271AA-9CBC-4F2E-AD25-1136EBC92CC8},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={9E37A2A9-36F8-4D66-9029-6895CE475D9D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={9E37A2A9-36F8-4D66-9029-6895CE475D9D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={025A5A13-B6C5-440D-A058-76D5AA5598E7},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={025A5A13-B6C5-440D-A058-76D5AA5598E7},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={EFAD83DA-049E-446F-A382-B3DCBC7FA605},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={EFAD83DA-049E-446F-A382-B3DCBC7FA605},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={79FCE4CF-A773-4485-B031-FA09A4317D5D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={79FCE4CF-A773-4485-B031-FA09A4317D5D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={65B993B5-2D5E-495B-ADC8-A2ACEF850B01},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={65B993B5-2D5E-495B-ADC8-A2ACEF850B01},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={9AB16FC7-C8A7-4F09-B46C-75EDF559962A},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={9AB16FC7-C8A7-4F09-B46C-75EDF559962A},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={D0C09419-71D8-42D4-8224-F097F744B90D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={D0C09419-71D8-42D4-8224-F097F744B90D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={7E4E808C-7249-4AF9-9C80-254015916A8F},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={7E4E808C-7249-4AF9-9C80-254015916A8F},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={0CE41F0D-8F7E-43DD-8EDC-EDF1E96865D1},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={0CE41F0D-8F7E-43DD-8EDC-EDF1E96865D1},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={5874CFEF-9288-47AB-9B5D-29AAEA5A5B55},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={5874CFEF-9288-47AB-9B5D-29AAEA5A5B55},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={09BE3DEA-1718-47C8-B918-AC17F3DD49D7},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={09BE3DEA-1718-47C8-B918-AC17F3DD49D7},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={33BEB47B-65E6-4FDB-A294-707418381E7C},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={33BEB47B-65E6-4FDB-A294-707418381E7C},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={01AF3CDE-6B53-46B2-BA91-ABFD2AA93340},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={01AF3CDE-6B53-46B2-BA91-ABFD2AA93340},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={C5C90634-AEA8-4B78-A465-0094E9AC9790},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={C5C90634-AEA8-4B78-A465-0094E9AC9790},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={F9EAA970-0D45-4A5E-AEC4-450C3D4979E2},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={F9EAA970-0D45-4A5E-AEC4-450C3D4979E2},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={4E4FBA41-75BB-459C-B667-5E0C4DE5F00B},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={4E4FBA41-75BB-459C-B667-5E0C4DE5F00B},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={42ED05DD-A455-453C-BB05-C0974A7CB0A2},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={42ED05DD-A455-453C-BB05-C0974A7CB0A2},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={D0916F10-C695-4D27-9A24-7B58047CF3C5},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={D0916F10-C695-4D27-9A24-7B58047CF3C5},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={6D94768F-E5EA-4D1A-8EF9-A7652DB48DD9},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={6D94768F-E5EA-4D1A-8EF9-A7652DB48DD9},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={3D79EBE8-F5A7-4D96-9CF6-0BFB653EA2B9},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={3D79EBE8-F5A7-4D96-9CF6-0BFB653EA2B9},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={B418197E-135F-459C-A384-57279CFC28B2},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={B418197E-135F-459C-A384-57279CFC28B2},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={2176B58A-2510-4F90-A2F7-E406022FC8B3},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={2176B58A-2510-4F90-A2F7-E406022FC8B3},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={48D24AB2-E2EF-4DF8-8223-42F4A1B30231},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={48D24AB2-E2EF-4DF8-8223-42F4A1B30231},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={79CF1702-F789-4A2B-B16A-D8B7BAF2680D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={79CF1702-F789-4A2B-B16A-D8B7BAF2680D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={3EC88457-7AFC-461B-B966-F4A0DD06FBA2},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={3EC88457-7AFC-461B-B966-F4A0DD06FBA2},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={09263913-2E40-46F2-A171-E0B06ECA5177},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={09263913-2E40-46F2-A171-E0B06ECA5177},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={F77CA61A-7784-4450-AEB4-BE95BEEF364D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={F77CA61A-7784-4450-AEB4-BE95BEEF364D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={75664931-926A-45D0-BFE4-7EF44348E026},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={75664931-926A-45D0-BFE4-7EF44348E026},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={DD9DC842-C8E4-4119-B4A1-A54A79862466},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={DD9DC842-C8E4-4119-B4A1-A54A79862466},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={8DA73776-B486-46AD-A544-58C3C1A0990F},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={8DA73776-B486-46AD-A544-58C3C1A0990F},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={354D75FB-31BE-44B6-B1BE-F1CD4854547F},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={354D75FB-31BE-44B6-B1BE-F1CD4854547F},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={A1EC3F58-7B4E-4999-9BA9-EF404E70DA6B},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={A1EC3F58-7B4E-4999-9BA9-EF404E70DA6B},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={E9EE0783-28DE-49C1-B37E-571BDDA76653},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={E9EE0783-28DE-49C1-B37E-571BDDA76653},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={42DA5A33-F57F-4980-A70A-0D03D7E9B04F},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={42DA5A33-F57F-4980-A70A-0D03D7E9B04F},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={3085A40D-FA8C-4B10-BF37-D611743BA52C},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={3085A40D-FA8C-4B10-BF37-D611743BA52C},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={1662FE81-23E2-4470-9259-BC556D6DB24C},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={1662FE81-23E2-4470-9259-BC556D6DB24C},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={76A1BE2C-1EEE-4E8C-9416-927A0C4FF5B4},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={76A1BE2C-1EEE-4E8C-9416-927A0C4FF5B4},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={97F412BD-5FDF-4659-B8FC-F2C2F8FA7AA9},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={97F412BD-5FDF-4659-B8FC-F2C2F8FA7AA9},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={580F208E-2FCB-4440-875B-795B420A52EE},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={580F208E-2FCB-4440-875B-795B420A52EE},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={F45CEA63-31DD-428F-84F4-1F06E66AB0FE},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={F45CEA63-31DD-428F-84F4-1F06E66AB0FE},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={94C403CB-1BC8-4DFF-B22C-0C60A9E34AFE},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={94C403CB-1BC8-4DFF-B22C-0C60A9E34AFE},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={A747EF43-5D34-4549-A26D-589DE6747443},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={A747EF43-5D34-4549-A26D-589DE6747443},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={B089AA32-07DD-411D-881A-434E77E2622F},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={B089AA32-07DD-411D-881A-434E77E2622F},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={F99D9C57-C536-4D7D-8D4E-F511F9FA1FFD},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={F99D9C57-C536-4D7D-8D4E-F511F9FA1FFD},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={A549D487-2C1E-4E83-A46B-82C193C36466},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={A549D487-2C1E-4E83-A46B-82C193C36466},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={216A14EE-E2A5-4363-BFF7-E163001D2B51},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={216A14EE-E2A5-4363-BFF7-E163001D2B51},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={B5BC2EFA-480D-4C4C-830E-2F0D9701D92A},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={B5BC2EFA-480D-4C4C-830E-2F0D9701D92A},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={527A7481-9B49-4B2C-A0A7-130E51F66113},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={527A7481-9B49-4B2C-A0A7-130E51F66113},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={0D80221D-20E3-41BB-8341-641EF31B0C4D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={0D80221D-20E3-41BB-8341-641EF31B0C4D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={F2E848CA-5C88-4A07-9018-47FFB7A464D4},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={F2E848CA-5C88-4A07-9018-47FFB7A464D4},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={3EABB463-C74E-4C14-8832-36646C1889A0},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={3EABB463-C74E-4C14-8832-36646C1889A0},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={20E9642F-BD10-434E-8115-A2DA4F41CD49},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={20E9642F-BD10-434E-8115-A2DA4F41CD49},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={DCBBEFB3-F30F-4ADA-98B0-3A7DE7279960},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={DCBBEFB3-F30F-4ADA-98B0-3A7DE7279960},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: ActionStart(Name=UnpublishFeatures,Description=Unpublishing product features,Template=Feature: [1])
MSI (s) (60:30) [10:53:56:652]: Executing op: FeatureUnpublish(Feature=Help,Parent=Documentation,Absent=2,Component=+'IU@OOG29amCEw{j]s[t_I_i9jpZA4V{ML7U=*t{J]Xm^ewk@i[of%@&?j7wDtXU^5YA@N0-mGJi'3w1+2sk{dO19*@R&hQ-,iml,?UkT32NAB='H5!PWDiJJCqZaCOs@1^^$X5j$YZGj?i!K[0s9n(W[mS?wLsz8g%v$7U~90]BxoflFn$SiX5OcVy$=dIX5&)O$'F7%$dHXk!Y?Cm6Q`T^VD!Vm&fYF-8JAW9,Cu49Mc1hss*l0%fP9W?koX&vvJ'WLWZP!S6+@UzJ]8tl{*VER20'Wn!n9t-8iv]$PAl`uTLD2ny%?J8^c_taqLCnY2.&hQ~(?iPd[*qnM4nJ8]^4JP[aADQ!LMi9jtOI_$V!1nFf=t)~TzpHw^8GC?XhC^l9@r@8XW8),PV~yMCyyz^u?B-?y&a,$lqmNH2A7TdG=[Zu{&W=6p&7{DS9NHP9=Al_jXB%R@]`8q%lNzll@fC5MDcOm]h_HOi7TPax@n-Ccy!@Bad3c{sb~%aG=z}j_0G`.=bU?4i-9sXXAXUE6%&lMkb@.JJ?Ah,(AZlrRw[dvh31@c0Ou`@p?%ON*dKDEB'aJ238Vc9U=.r+g[U2NH]Nayx%{22m=xT)qa%TbEN^p(Vxd+?z91_r-XZPKn@$67gM76=M=@tEYwfL'R0Y^B7p+kPw8o8?~?^-LoHafmTUW're=)D[kg.,3
Nissi1
Basic,PackageName=Nero.MovieThemePackBasic.msi,Language=0,Version=167913432,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,PackageMediaPath=\applications\moviethemebase\,PackageCode={B9F7A147-EE44-48AE-B20E-9D2DCE597782},,,InstanceType=0,LUASetting=1,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (s) (60:80) [10:54:01:471]: Executing op: DialogInfo(Type=0,Argument=0)
MSI (s) (60:80) [10:54:01:471]: Executing op: DialogInfo(Type=1,Argument=Nero 10 Movie ThemePack Basic)
MSI (s) (60:80) [10:54:01:471]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (60:80) [10:54:01:471]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (60:80) [10:54:01:471]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (60:80) [10:54:01:471]: Executing op: ActionStart(Name=InstallInitialize,,)
MSI (s) (60:80) [10:54:01:471]: Executing op: ProductUnregister(UpgradeCode={403096B5-2B75-4FAE-BC57-6535C9E50B79})
MSI (s) (60:80) [10:54:01:471]: Note: 1: 1402 2: UNKNOWN\Products\F228BC5F563B1D34CB0CF4ADA102717A\Transforms 3: 2
MSI (s) (60:80) [10:54:01:471]: Scheduling file 'C:\Windows\Installer\11a68.msi' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:80) [10:54:01:487]: Note: 1: 1402 2: UNKNOWN\Products\F228BC5F563B1D34CB0CF4ADA102717A\Usage 3: 2
MSI (s) (60:80) [10:54:01:487]: Executing op: ProductCPDisplayInfoUnregister()
MSI (s) (60:80) [10:54:01:502]: Executing op: ProductUnpublish(PackageKey={B9F7A147-EE44-48AE-B20E-9D2DCE597782})
MSI (s) (60:80) [10:54:01:502]: Transforms are not secure.
MSI (s) (60:80) [10:54:01:502]: Processing cached transform: C:\WINDOWS\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst
MSI (s) (60:80) [10:54:01:502]: Scheduling file 'C:\WINDOWS\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:80) [10:54:01:502]: Registering cached transform: C:\WINDOWS\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst
MSI (s) (60:80) [10:54:01:502]: Executing op: UpgradeCodeUnpublish(UpgradeCode={403096B5-2B75-4FAE-BC57-6535C9E50B79})
MSI (s) (60:80) [10:54:01:502]: Executing op: IconRemove(Icon=ARPPRODUCTICON.exe,)
MSI (s) (60:80) [10:54:01:502]: Scheduling file 'C:\WINDOWS\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\ARPPRODUCTICON.exe' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:80) [10:54:01:502]: Executing op: ProductUnpublishClient(,,)
MSI (s) (60:80) [10:54:01:502]: Note: 1: 1402 2: UNKNOWN\Installer\Products\F228BC5F563B1D34CB0CF4ADA102717A 3: 2
MSI (s) (60:80) [10:54:01:502]: Executing op: SourceListUnpublish(,)
MSI (s) (60:80) [10:54:01:502]: Note: 1: 1402 2: UNKNOWN\Installer\Products\F228BC5F563B1D34CB0CF4ADA102717A\SourceList 3: 2
MSI (s) (60:80) [10:54:01:502]: Executing op: ActionStart(Name=Nero_CA_DeleteLocalFileAssociationDb,,)
MSI (s) (60:80) [10:54:01:502]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteLocalFileAssociationDb,ActionType=1281,Source=BinaryData,Target=CA_DeleteLocalFileAssociationDb,CustomActionData={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:502]: Executing op: ActionStart(Name=Nero_CA_GatherOriginalFileAssociation,,)
MSI (s) (60:80) [10:54:01:502]: Executing op: CustomActionSchedule(Action=Nero_CA_GatherOriginalFileAssociation,ActionType=1025,Source=BinaryData,Target=CA_GatherOriginalFileAssociation,)
MSI (s) (60:18) [10:54:01:518]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIC40.tmp, Entrypoint: CA_GatherOriginalFileAssociation
MSI (s) (60:80) [10:54:01:587]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (60:80) [10:54:01:587]: Executing op: ProgressTotal(Total=26,Type=1,ByteEquivalent=24000)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={830F4E82-C3B5-435E-B222-32C14FADE457},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={830F4E82-C3B5-435E-B222-32C14FADE457},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={3D0D5769-9BA7-45AD-BC10-39DDD3617773},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={3D0D5769-9BA7-45AD-BC10-39DDD3617773},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={B101FDE4-F9BB-49AA-996B-084909DB96F6},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={B101FDE4-F9BB-49AA-996B-084909DB96F6},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={92A17853-A67A-45F0-B907-3A929E2B3451},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={92A17853-A67A-45F0-B907-3A929E2B3451},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={E188209D-8296-4E7B-96AE-45101016EF83},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={E188209D-8296-4E7B-96AE-45101016EF83},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={DA28E544-350E-4F41-BA5E-509A510E593D},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={DA28E544-350E-4F41-BA5E-509A510E593D},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:603]: Executing op: UnregisterSharedComponentProvider(Component={A4C7D6DE-E580-DC6F-0F65-4699280BDB33},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:603]: Executing op: ComponentUnregister(ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:603]: Executing op: UnregisterSharedComponentProvider(Component={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:603]: Executing op: ComponentUnregister(ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:603]: Executing op: UnregisterSharedComponentProvider(Component={15E094C0-005F-545E-81E2-07844E5D20B1},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:603]: Executing op: ComponentUnregister(ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:603]: Executing op: UnregisterSharedComponentProvider(Component={D13C6428-8956-226D-33F9-26F53CE30D1B},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:603]: Executing op: ComponentUnregister(ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:603]: Executing op: UnregisterSharedComponentProvider(Component={1576B8C0-0B36-D81C-3900-37913359A63F},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:603]: Executing op: ComponentUnregister(ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={B8ADEBD5-5118-95C1-E313-212540C0C56E},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={B8ADEBD5-5118-95C1-E313-212540C0C56E},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={4C7676B1-12BC-9863-FF30-CF1CDB92F312},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={4C7676B1-12BC-9863-FF30-CF1CDB92F312},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={AC1C4126-6960-AA9B-59A5-55F40E7FB03A},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={AC1C4126-6960-AA9B-59A5-55F40E7FB03A},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={C18E125E-E561-0E66-F15C-6F91E16C637B},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={4EADF80B-B16E-746D-D9A9-DEE246D70A87},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={4EADF80B-B16E-746D-D9A9-DEE246D70A87},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={A5457750-0E51-152E-0AC4-E9DDB7EA34A4},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={87331945-56BB-50A0-6D03-2BEEF3A567ED},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={C3BDB529-95E0-803B-A494-4EA09714F195},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={C3BDB529-95E0-803B-A494-4EA09714F195},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={FC0C980E-E8BC-C999-029E-D6AD60453094},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:634]: Executing op: UnregisterSharedComponentProvider(Component={4C4F1A46-D98F-4176-83F0-1F38CF332AC4},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:634]: Executing op: ComponentUnregister(ComponentId={4C4F1A46-D98F-4176-83F0-1F38CF332AC4},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:634]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\NeroContentLicenseCheck.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:634]: Executing op: ActionStart(Name=UnpublishFeatures,Description=Unpublishing product features,Template=Feature: [1])
MSI (s) (60:80) [10:54:01:634]: Executing op: FeatureUnpublish(Feature=Content,,Absent=2,Component=P^?QqaZ'7AniU7(mX@JRU(t,oQq0PA'EcZYt=ze7zXbT@IyJ&9I`=&6pY!'h)
MSI (s) (60:80) [10:54:01:634]: Note: 1: 1402 2: UNKNOWN\Installer\Features\F228BC5F563B1D34CB0CF4ADA102717A 3: 2
MSI (s) (60:80) [10:54:01:634]: Executing op: FeatureUnpublish(Feature=Smart3D,Parent=Content,Absent=2,Component=2gJ-RCcP`9F7u*gbQ09DP+8Fd=C0.XfzCx.^J3[Ki[sX@Hk&}XDE&=,GAg*)k.{'9)kRwh1mXb''U'ZJXTrB`4flo_rgyTwK+Dr6=1e5g5oM^'xS-hVUuo`O)
MSI (s) (60:80) [10:54:01:634]: Executing op: FeatureUnpublish(Feature=Audio,Parent=Content,Absent=2,Component=.Qs]7_(UI=b'X+pH)K,Mv)zy@%hl{?`D04FCBtQdJ)^z]+B+qo~hA=Yk@_a4-%%rw$L,gHF)CO0U_w_M)
MSI (s) (60:80) [10:54:01:634]: Executing op: FeatureUnpublish(Feature=MovieWizard,Parent=Content,Absent=2,Component=io`ta~[Tb?$-3P?ENV9xtDa%*6Xn,CnSxLRPDuwany*9lB3U(.rQ@lwqo*d+(-Gu)_?sNn%?,bVEYpN8)
MSI (s) (60:80) [10:54:01:634]: Executing op: FeatureUnpublish(Feature=Standard2D,Parent=Content,Absent=2,Component=!.l-W%4cP=aqh~VxmI+B!AM@A%AdKMnbovq(`5JS+[%-^v}[m)jqKCpNHyj]${dYeM~qszYGfZ6yq+E]AnRNS&s]vA^IQVum@_Au.OLvgZ'36QPhJT[[X84X(zd!z,HTliM))s`9VE^W?!4=]V7vplpbc)k{@~j7gju$^Y6Ev6ZvyocaSD%,)
MSI (s) (60:80) [10:54:01:634]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
MSI (s) (60:80) [10:54:01:634]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (60:80) [10:54:01:634]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (60:80) [10:54:01:634]: Executing op: ActionStart(Name=RemoveRegistryValues,Description=Removing system registry values,Template=Key: [1], Name: [2])
MSI (s) (60:80) [10:54:01:634]: Executing op: ProgressTotal(Total=15,Type=1,ByteEquivalent=13200)
MSI (s) (60:80) [10:54:01:634]: Executing op: RegOpenKey(,Key=CLSID\{E446A471-9C57-4EA3-81A5-4A38C4E21018}\InprocServer32,,BinaryType=0,,)
MSI (s) (60:80) [10:54:01:634]: Executing op: RegRemoveValue(Name=ThreadingModel,Value=Both,)
MSI (s) (60:80) [10:54:01:634]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\Software\Classes\CLSID\{E446A471-9C57-4EA3-81A5-4A38C4E21018}\InprocServer32 3: 2
MSI (s) (60:80) [10:54:01:634]: Executing op: RegOpenKey(,Key=CLSID\{E3860894-1DAE-44BA-9DD9-BE425838D7D4}\InprocServer32,,BinaryType=0,,)
MSI (s) (60:80) [10:54:01:634]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\Software\Classes\CLSID\{E3860894-1DAE-44BA-9DD9-BE425838D7D4}\InprocServer32 3: 2
MSI (s) (60:80) [10:54:01:634]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Nero\Nero 10\Installer\Applications\{403096B5-2B75-4FAE-BC57-6535C9E50B79},,BinaryType=0,,)
MSI (s) (60:80) [10:54:01:634]: Executing op: RegRemoveValue(Name=NERO.APPID,Value=#[NERO.APPID],)
MSI (s) (60:80) [10:54:01:634]: Executing op: RegRemoveValue(Name=Nero.MainComponent,Value=[Nero.MainComponent],)
MSI (s) (60:80) [10:54:01:634]: Executing op: RegRemoveValue(Name=PackageName,Value=[Nero.PackageName],)
MSI (s) (60:80) [10:54:01:650]: Executing op: RegRemoveValue(Name=ProductCode,Value=[ProductCode],)
MSI (s) (60:80) [10:54:01:650]: Executing op: RegRemoveValue(Name=NERO.PRODUCT_LINE,Value=[NERO.PRODUCT_LINE],)
MSI (s) (60:80) [10:54:01:651]: Executing op: RegRemoveValue(Name=ProductName,Value=[ProductName],)
MSI (s) (60:80) [10:54:01:651]: Executing op: RegRemoveValue(Name=ProductVersion,Value=[ProductVersion],)
MSI (s) (60:80) [10:54:01:652]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\Applications\{403096B5-2B75-4FAE-BC57-6535C9E50B79}\UserProperties,,BinaryType=0,,)
MSI (s) (60:80) [10:54:01:652]: Executing op: RegRemoveValue(Name=ARPNOREPAIR,Value=[ARPNOREPAIR],)
MSI (s) (60:80) [10:54:01:653]: Executing op: RegRemoveValue(Name=NERO.INSTALL_AUTOPLAY,Value=[NERO.INSTALL_AUTOPLAY],)
MSI (s) (60:80) [10:54:01:653]: Executing op: RegRemoveValue(Name=NERO.INSTALL_DESKTOPSHORTCUT,Value=[NERO.INSTALL_DESKTOPSHORTCUT],)
MSI (s) (60:80) [10:54:01:654]: Executing op: RegRemoveValue(Name=NERO.INSTALL_EXTENSIONS,Value=[NERO.INSTALL_EXTENSIONS],)
MSI (s) (60:80) [10:54:01:655]: Executing op: RegRemoveValue(Name=INSTALLDIR,Value=[INSTALLDIR],)
MSI (s) (60:80) [10:54:01:655]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Nero\Nero 10\Installer\Packages\{403096B5-2B75-4FAE-BC57-6535C9E50B79},,BinaryType=0,,)
MSI (s) (60:80) [10:54:01:656]: Executing op: RegRemoveValue(Name=NPMOVB,Value=[UpgradeCode],)
MSI (s) (60:80) [10:54:01:656]: Executing op: ActionStart(Name=UnregisterClassInfo,Description=Unregister class servers,Template=Class ID: [1])
MSI (s) (60:80) [10:54:01:656]: Executing op: RegClassInfoUnregister(Feature=Content,Component={4C4F1A46-D98F-4176-83F0-1F38CF332AC4},FileName=TOKEN,ClsId={E3860894-1DAE-44BA-9DD9-BE425838D7D4},,,,Context=InprocServer32,,,,,,,,,,)
MSI (s) (60:80) [10:54:01:656]: Note: 1: 1402 2: UNKNOWN32\CLSID\{E3860894-1DAE-44BA-9DD9-BE425838D7D4}\InprocServer32 3: 2
MSI (s) (60:80) [10:54:01:656]: Note: 1: 1402 2: UNKNOWN32\CLSID\{E3860894-1DAE-44BA-9DD9-BE425838D7D4} 3: 2
MSI (s) (60:80) [10:54:01:656]: Executing op: RegClassInfoUnregister(Feature=Content,Component={4C4F1A46-D98F-4176-83F0-1F38CF332AC4},FileName=TOKEN,ClsId={E446A471-9C57-4EA3-81A5-4A38C4E21018},,,,Context=InprocServer32,,,,,,,,,,)
MSI (s) (60:80) [10:54:01:656]: Note: 1: 1402 2: UNKNOWN32\CLSID\{E446A471-9C57-4EA3-81A5-4A38C4E21018}\InprocServer32 3: 2
MSI (s) (60:80) [10:54:01:672]: Note: 1: 1402 2: UNKNOWN32\CLSID\{E446A471-9C57-4EA3-81A5-4A38C4E21018} 3: 2
MSI (s) (60:80) [10:54:01:672]: Executing op: ActionStart(Name=RemoveFiles,Description=Removing files,Template=File: [1], Directory: [9])
MSI (s) (60:80) [10:54:01:672]: Executing op: ProgressTotal(Total=244,Type=1,ByteEquivalent=175000)
MSI (s) (60:80) [10:54:01:672]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Slideshow\)
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow43.frm.tm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow43.frm.sm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow43.frm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow169.frm.tm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow169.frm.sm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow169.frm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.shp.1.tif,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.SD.4.3.tpl,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.SD.16.9.tpl,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.ret.sm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.ret.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.prev.sm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.prev.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.next.sm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.next.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.bg.jpg,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\OldFilm\)
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm43.frm.tm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm43.frm.sm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm43.frm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm169.frm.tm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm169.frm.sm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm169.frm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm.SD.4.3.tpl,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.SD.16.9.tpl,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.ret.sm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.ret.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.prev.sm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.prev.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.next.sm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.next.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.bkg.jpg,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Movement\)
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement43.frm.tm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement43.frm.sm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement43.frm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement169.frm.tm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement169.frm.sm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement169.frm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.shp.3.tif,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.shp.1.tif,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.SD.4.3.tpl,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.SD.16.9.tpl,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.ret.sm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.ret.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Movement.prev.sm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Movement.prev.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Movement.next.sm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Movement.next.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Movement.bkg.jpg,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Slideshow\)
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.shp.1.tif,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.ret.sm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.ret.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.prev.sm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.prev.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.next.sm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.next.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.HD.16.9.tpl,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.frm.tm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.frm.sm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.frm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.bg.jpg,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\OldFilm\)
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.ret.sm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.ret.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.prev.sm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.prev.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.next.sm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.next.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.HD.16.9.tpl,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.frm.tm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=OldFilm.frm.sm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=OldFilm.frm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=OldFilm.bkg.jpg,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:719]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Movement\)
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.shp.3.tif,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.shp.1.tif,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.ret.sm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.ret.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.prev.sm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.prev.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.next.sm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.next.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.HD.16.9.tpl,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.frm.tm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.frm.sm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.frm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.bkg.jpg,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\MovingWalls\)
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Trans_S.png,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Trans_G.png,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Refl.jpg,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans3.ntds,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans3.3dsn,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans2.ntds,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans2.3dsn,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans1.ntds,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans1.3dsn,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_outro.ntds,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_outro.3dsn,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_intro.ntds,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_intro.3dsn,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=Dirt_S.png,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:734]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\MovingWalls\)
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=Trans_S.png,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=Trans_G.png,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=Refl.jpg,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans3.ntds,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans3.3dsn,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans2.ntds,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans2.3dsn,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans1.ntds,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans1.3dsn,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_outro.ntds,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_outro.3dsn,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_intro.ntds,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_intro.3dsn,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=Dirt_S.png,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\MovieWizard\Slideshow1\)
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=slideshow1_thumbnail_4_3.png,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=slideshow1_thumbnail_16_9.png,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=slideshow1_start_audio.mpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=slideshow1_preview.mpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=slideshow1_HD.jpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:750]: Executing op: FileRemove(,FileName=slideshow1_end_audio.mpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:751]: Executing op: FileRemove(,FileName=slideshow1_4_3.nmwtmh,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:751]: Executing op: FileRemove(,FileName=slideshow1_4_3.nmwt,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:752]: Executing op: FileRemove(,FileName=slideshow1_4_3.jpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:752]: Executing op: FileRemove(,FileName=slideshow1_16_9.nmwtmh,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:753]: Executing op: FileRemove(,FileName=slideshow1_16_9.nmwt,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:753]: Executing op: FileRemove(,FileName=slideshow1_16_9.jpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:754]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\MovieWizard\OldFilm\)
MSI (s) (60:80) [10:54:01:754]: Executing op: FileRemove(,FileName=oldfilm_thumbnail_4_3.png,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:754]: Executing op: FileRemove(,FileName=oldfilm_thumbnail_16_9.png,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:754]: Executing op: FileRemove(,FileName=oldfilm_start_audio.mpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:755]: Executing op: FileRemove(,FileName=oldfilm_preview.mpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:755]: Executing op: FileRemove(,FileName=oldfilm_HD.jpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_frame_HD.png,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_frame_4_3.png,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_frame_16_9.png,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_end_audio.mpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_4_3.nmwtmh,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_4_3.nmwt,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_4_3.jpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_16_9.nmwtmh,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_16_9.nmwt,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_16_9.jpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\MovieWizard\MovingWalls\)
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_thumbnail_4_3.png,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_thumbnail_16_9.png,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_start_audio.mpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_preview.mpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_end_audio.mpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_4_3.nmwtmh,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_4_3.nmwt,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_16_9.nmwtmh,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_16_9.nmwt,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_thumbnail_4_3.png,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_thumbnail_16_9.png,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_start_HD.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_start_audio.mpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_start_4_3.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_start_16_9.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_preview.mpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\)
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MovieThemePackBasic.dll,,ComponentId={E188209D-8296-4E7B-96AE-45101016EF83})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=NeroContentLicenseCheck.dll,,ComponentId={4C4F1A46-D98F-4176-83F0-1F38CF332AC4})
MSI (s) (60:80) [10:54:01:772]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\MovieWizard\MovingWalls\)
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=MH_movingwalls_end_HD.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=MH_movingwalls_end_4_3.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=MH_movingwalls_end_16_9.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:772]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\MovieWizard\)
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=categories.nlot,,ComponentId={B101FDE4-F9BB-49AA-996B-084909DB96F6})
MSI (s) (60:80) [10:54:01:772]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Audio\slideshow1_nsla\)
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_outro.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_intro.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_30.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_29.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_28.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_27.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_26.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_25.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_24.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_23.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_22.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_21.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_20.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_19.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_18.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_17.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_16.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_15.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_14.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_13.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_12.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_11.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_10.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_09.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_08.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_07.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_06.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_05.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_04.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_03.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_02.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_01.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Audio\oldfilm_nsla\)
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_outro.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_intro.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_31.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_30.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_29.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_28.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_27.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_26.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_25.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_24.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_23.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_22.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_21.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_20.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_19.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_18.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_17.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_16.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_15.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_14.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:803]: Executing op: FileRemove(,FileName=sample_13.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_12.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_11.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_10.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_09.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_08.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_07.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_06.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_05.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_04.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_03.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_02.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_01.nsls,,ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33})
MSI (s) (60:80) [10:54:01:819]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Audio\movingwalls_nsla\)
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_15.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_14.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_13.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_12.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_11.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_10.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_09.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_08.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_07.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_06.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_05.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_04.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_03.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_02.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:819]: Executing op: FileRemove(,FileName=sample_01.nsls,,ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9})
MSI (s) (60:80) [10:54:01:835]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Audio\)
MSI (s) (60:80) [10:54:01:835]: Executing op: FileRemove(,FileName=slideshow1.nsla,,ComponentId={3D0D5769-9BA7-45AD-BC10-39DDD3617773})
MSI (s) (60:80) [10:54:01:835]: Executing op: FileRemove(,FileName=oldfilm.nsla,,ComponentId={3D0D5769-9BA7-45AD-BC10-39DDD3617773})
MSI (s) (60:80) [10:54:01:835]: Executing op: FileRemove(,FileName=movingwalls.nsla,,ComponentId={3D0D5769-9BA7-45AD-BC10-39DDD3617773})
MSI (s) (60:80) [10:54:01:835]: Executing op: ActionStart(Name=RemoveFolders,Description=Removing folders,Template=Folder: [1])
MSI (s) (60:80) [10:54:01:835]: Executing op: FolderRemove(Folder=C:\Program Files (x86)\Nero\NeroContent\Audio\,Foreign=0)
MSI (s) (60:80) [10:54:01:835]: Executing op: FolderRemove(Folder=C:\Program Files (x86)\Nero\NeroContent\MovieWizard\,Foreign=0)
MSI (s) (60:80) [10:54:01:835]: Executing op: FolderRemove(Folder=C:\Program Files (x86)\Nero\NeroContent\Smart3D\,Foreign=0)
MSI (s) (60:80) [10:54:01:835]: Executing op: FolderRemove(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\,Foreign=0)
MSI (s) (60:80) [10:54:01:835]: Executing op: FolderRemove(Folder=C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\,Foreign=0)
MSI (s) (60:80) [10:54:01:835]: Executing op: FolderRemove(Folder=C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\,Foreign=0)
MSI (s) (60:80) [10:54:01:835]: Executing op: FolderRemove(Folder=C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\,Foreign=0)
MSI (s) (60:80) [10:54:01:835]: Executing op: FolderRemove(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\,Foreign=0)
MSI (s) (60:80) [10:54:01:835]: Executing op: FolderRemove(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\,Foreign=0)
MSI (s) (60:80) [10:54:01:835]: Executing op: ActionStart(Name=PublishProduct,Description=Publishing product information,)
MSI (s) (60:80) [10:54:01:835]: Executing op: CleanupConfigData()
MSI (s) (60:80) [10:54:01:835]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=0,Remove=1)
MSI (s) (60:80) [10:54:01:835]: Note: 1: 1402 2: UNKNOWN\Installer\Products\F228BC5F563B1D34CB0CF4ADA102717A\Patches 3: 2
MSI (s) (60:80) [10:54:01:835]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=1,Remove=1)
MSI (s) (60:80) [10:54:01:835]: Executing op: CleanupConfigData(RemovingProduct=1)
MSI (s) (60:80) [10:54:01:835]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\F228BC5F563B1D34CB0CF4ADA102717A\Patches 3: 2
MSI (s) (60:80) [10:54:01:835]: Executing op: ActionStart(Name=Nero_CA_UninstallSetAssociationsRollback,,)
MSI (s) (60:80) [10:54:01:835]: Executing op: CustomActionSchedule(Action=Nero_CA_UninstallSetAssociationsRollback,ActionType=1281,Source=BinaryData,Target=CA_UninstallSetAssociationsRollback,)
MSI (s) (60:80) [10:54:01:852]: Executing op: ActionStart(Name=Nero_CA_UninstallSetAssociations,,)
MSI (s) (60:80) [10:54:01:853]: Executing op: CustomActionSchedule(Action=Nero_CA_UninstallSetAssociations,ActionType=1025,Source=BinaryData,Target=CA_UninstallSetAssociations,)
MSI (s) (60:8C) [10:54:01:857]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSID98.tmp, Entrypoint: CA_UninstallSetAssociations
MSI (s) (60:80) [10:54:01:919]: Executing op: ActionStart(Name=Nero_CA_DeleteAssociationsBackup,,)
CA_UninstallSetAssociations: CustomActions.cpp : 1016 :  Succeeded
MSI (s) (60:80) [10:54:01:919]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteAssociationsBackup,ActionType=1537,Source=BinaryData,Target=CA_DeleteAssociationsBackup,CustomActionData={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}|)
MSI (s) (60:80) [10:54:01:935]: Executing op: ActionStart(Name=Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore,,)
MSI (s) (60:80) [10:54:01:935]: Executing op: CustomActionSchedule(Action=Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore,ActionType=1537,Source=BinaryData,Target=CA_MergeLocalFileAssociationDbToGlobalAndRestore,CustomActionData={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:935]: Executing op: ActionStart(Name=InstallFinalize,,)
MSI (s) (60:80) [10:54:01:935]: Executing op: CleanupTempFiles(TempFiles=C:\WINDOWS\Installer\33a1c1a9.mst)
MSI (s) (60:80) [10:54:01:935]: Scheduling file 'C:\WINDOWS\Installer\33a1c1a9.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:80) [10:54:01:935]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=43522000)
MSI (s) (60:80) [10:54:01:954]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:80) [10:54:01:973]: User policy value 'DisableRollback' is 0
MSI (s) (60:80) [10:54:01:973]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:80) [10:54:01:973]: Unlocking Server
MSI (s) (60:80) [10:54:01:973]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
Action ended 10:54:01: InstallFinalize. Return value 1.
Action ended 10:54:01: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): UpgradeCode = {403096B5-2B75-4FAE-BC57-6535C9E50B79}
Property(S): ROOTDRIVE = C:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): UILevel = 3
Property(S): OriginalDatabase = C:\Windows\Installer\11a68.msi
Property(S): ProductCode = {F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}
Property(S): DATABASE = C:\Windows\Installer\11a68.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.3.14393.0
Property(S): MsiNetAssemblySupport = 4.6.1586.0
Property(S): Date = 6/11/2017
Property(S): Time = 10:54:01
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 23
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 1033
Property(S): ComputerName = ZANDRAJONES-PC
Property(S): UserLanguageID = 1033
Property(S): UserSID = S-1-5-21-3088507388-2561779440-336279174-1001
Property(S): LogonUser = Zandra Jones
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 5078
Property(S): PhysicalMemory = 3839
Property(S): Intel = 16
Property(S): Msix64 = 16
Property(S): MsiAMD64 = 16
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): Installed = 2010/10/07 12:23:02
Property(S): RecentFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): WindowsVolume = C:\
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 9600
Property(S): VersionNT64 = 603
Property(S): VersionMsi = 5.00
Property(S): VersionDatabase = 200
Nissi1
MSI (s) (60!8C) [10:53:51:357]: Closing MSIHANDLE (1530) of type 790540 for thread 6284
MSI (s) (60!8C) [10:53:51:357]: Closing MSIHANDLE (1529) of type 790541 for thread 6284
MSI (s) (60!8C) [10:53:51:357]: Creating MSIHANDLE (1575) of type 790531 for thread 6284
CA_CountComponentRefs: CustomActions.cpp : 597 :  Succeeded
MSI (s) (60!8C) [10:53:51:357]: Closing MSIHANDLE (1575) of type 790531 for thread 6284
MSI (s) (60:A4) [10:53:51:357]: Closing MSIHANDLE (1528) of type 790542 for thread 8112
Action ended 10:53:51: Nero_CA_CountComponentRefs. Return value 1.
MSI (s) (60:B0) [10:53:51:357]: Doing action: ISChainPackagePrepare
Action 10:53:51: ISChainPackagePrepare.
Action start 10:53:51: ISChainPackagePrepare.
MSI (s) (60:B0) [10:53:51:372]: Creating MSIHANDLE (1576) of type 790542 for thread 8112
MSI (s) (60:98) [10:53:51:372]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIE482.tmp, Entrypoint: ISChainPackages
MSI (s) (60!58) [10:53:51:403]: Creating MSIHANDLE (1577) of type 790541 for thread 11352
MSI (s) (60!58) [10:53:51:403]: Creating MSIHANDLE (1578) of type 790540 for thread 11352
MSI (s) (60!58) [10:53:51:403]: Creating MSIHANDLE (1579) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:403]: Closing MSIHANDLE (1579) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:403]: Creating MSIHANDLE (1580) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1581) of type 790531 for thread 11352
InstallShield 10:53:51: Marking chained package NCC for removal
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1581) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1582) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1582) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1583) of type 790531 for thread 11352
InstallShield 10:53:51: Properties: "NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\""
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1583) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1580) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1584) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1584) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1585) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1586) of type 790531 for thread 11352
InstallShield 10:53:51: Marking chained package NL for removal
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1586) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1587) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1587) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1588) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1588) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1585) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1589) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1589) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1590) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1591) of type 790531 for thread 11352
InstallShield 10:53:51: Marking chained package NBDCORE for removal
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1591) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1592) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1592) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1593) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1593) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Closing MSIHANDLE (1590) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1594) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:419]: Creating MSIHANDLE (1595) of type 790531 for thread 11352
InstallShield 10:53:51: Marking chained package NPMOVB for removal
MSI (s) (60!58) [10:53:51:435]: Closing MSIHANDLE (1595) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:435]: Creating MSIHANDLE (1596) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:435]: Closing MSIHANDLE (1596) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:436]: Creating MSIHANDLE (1597) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:436]: Closing MSIHANDLE (1597) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:437]: Closing MSIHANDLE (1594) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:437]: Creating MSIHANDLE (1598) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:438]: Creating MSIHANDLE (1599) of type 790531 for thread 11352
InstallShield 10:53:51: Skipping chained package CHM_MH4DELL removal because it is not installed
MSI (s) (60!58) [10:53:51:439]: Closing MSIHANDLE (1599) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:439]: Closing MSIHANDLE (1598) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:439]: Creating MSIHANDLE (1600) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1600) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Creating MSIHANDLE (1601) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1601) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Creating MSIHANDLE (1602) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Creating MSIHANDLE (1603) of type 790531 for thread 11352
InstallShield 10:53:51: Skipping chained package MH4DELL removal because it is not installed
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1603) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1602) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Creating MSIHANDLE (1604) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1604) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Creating MSIHANDLE (1605) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1605) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Creating MSIHANDLE (1606) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Creating MSIHANDLE (1607) of type 790531 for thread 11352
InstallShield 10:53:51: Marking chained package CHM_NCC for removal
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1607) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Creating MSIHANDLE (1608) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1608) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Creating MSIHANDLE (1609) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1609) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1606) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Creating MSIHANDLE (1610) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Creating MSIHANDLE (1611) of type 790531 for thread 11352
InstallShield 10:53:51: Skipping chained package NUPD removal because it is not installed
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1611) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1610) of type 790531 for thread 11352
MSI (s) (60!58) [10:53:51:441]: PROPERTY CHANGE: Adding IS_CHAINER_POST_COMMANDLINE property. Its value is '/l"C:\Users\ZANDRA~1\AppData\Local\Temp\MSI1b9f9.LOG" /qb /x{523B2B1B-D8DB-4B41-90FF-C4D799E2758A};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{237CCB62-8454-43E3-B158-3ACD0134852E};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{6DFB899F-17A2-48F0-A533-ED8D6866CF38};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\""'.
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1578) of type 790540 for thread 11352
MSI (s) (60!58) [10:53:51:441]: Closing MSIHANDLE (1577) of type 790541 for thread 11352
MSI (s) (60:98) [10:53:51:441]: Closing MSIHANDLE (1576) of type 790542 for thread 8112
Action ended 10:53:51: ISChainPackagePrepare. Return value 1.
MSI (s) (60:B0) [10:53:51:441]: Doing action: InstallInitialize
Action 10:53:51: InstallInitialize.
Action start 10:53:51: InstallInitialize.
MSI (s) (60:B0) [10:53:51:457]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:B0) [10:53:51:457]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:B0) [10:53:51:457]: Embedded Chainer - Searching for a valid Embedded Chainer to run
MSI (s) (60:B0) [10:53:51:457]: Embedded Chainer - Scheduled to run after install
MSI (s) (60:B0) [10:53:51:457]: BeginTransaction: Locking Server
MSI (s) (60:B0) [10:53:51:457]: Transforming table Property.
MSI (s) (60:B0) [10:53:51:457]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (s) (60:B0) [10:53:51:457]: SRSetRestorePoint skipped for this transaction.
MSI (s) (60:B0) [10:53:51:457]: Server not locked: locking for product {D92C9CCE-E5F0-4125-977A-0590F3225B74}
MSI (s) (60:B0) [10:53:51:457]: Using cached product context: machine assigned for product: ECC9C29D0F5E521479A750093F22B547
MSI (s) (60:B0) [10:53:51:457]: Note: 1: 1402 2: UNKNOWN\Media 3: 2
Action 10:53:51: GenerateScript. Generating script operations for action:
GenerateScript: InstallInitialize
MSI (s) (60:B0) [10:53:51:472]: PROPERTY CHANGE: Deleting ProductToBeRegistered property. Its current value is '1'.
MSI (s) (60:B0) [10:53:51:472]: Using cached product context: machine assigned for product: ECC9C29D0F5E521479A750093F22B547
MSI (s) (60:B0) [10:53:51:472]: Note: 1: 2205 2:  3: Class
MSI (s) (60:B0) [10:53:51:472]: Note: 1: 2228 2:  3: Class 4: SELECT `CLSID` FROM `Class` WHERE `Icon_`=? AND `Class`.`Attributes`=1
MSI (s) (60:B0) [10:53:51:472]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:B0) [10:53:51:472]: Note: 1: 2228 2:  3: Shortcut 4: SELECT `Component`,`Shortcut`,`Target` FROM `Component`,`Shortcut` WHERE `Component`=`Component_` AND `Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:B0) [10:53:51:472]: Note: 1: 2228 2:  3: Class 4: SELECT `Component`,`CLSID` FROM `Component`,`Class` WHERE `Component`=`Component_` AND `Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:B0) [10:53:51:472]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:B0) [10:53:51:472]: Note: 1: 2228 2:  3: Extension 4: SELECT `Component`,`Extension` FROM `Component`,`Extension`,`ProgId` WHERE `Component`.`Component`=`Extension`.`Component_` AND `ProgId`.`ProgId`=`Extension`.`ProgId_` AND `ProgId`.`Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:B0) [10:53:51:472]: 'ARPPRODUCTICON.exe' icon will be removed.
Action ended 10:53:51: InstallInitialize. Return value 1.
MSI (s) (60:B0) [10:53:51:472]: Skipping action: CANOSUS_InstallPrepare.EE698257_A789_474D_A546_5E5AAA5B180D (condition is false)
MSI (s) (60:B0) [10:53:51:472]: Doing action: Nero_ClrEula.EDA67544_39E0_4D88_B650_464D261A4F87
Action 10:53:51: Nero_ClrEula.EDA67544_39E0_4D88_B650_464D261A4F87.
Action start 10:53:51: Nero_ClrEula.EDA67544_39E0_4D88_B650_464D261A4F87.
MSI (s) (60:B0) [10:53:51:472]: PROPERTY CHANGE: Adding NERO.IS_EULA_ACCEPTED property. Its value is 'NO'.
Action ended 10:53:51: Nero_ClrEula.EDA67544_39E0_4D88_B650_464D261A4F87. Return value 1.
MSI (s) (60:B0) [10:53:51:472]: Doing action: LiLiW_ExtractFiles.EDA67544_39E0_4D88_B650_464D261A4F87
Action 10:53:51: LiLiW_ExtractFiles.EDA67544_39E0_4D88_B650_464D261A4F87.
Action start 10:53:51: LiLiW_ExtractFiles.EDA67544_39E0_4D88_B650_464D261A4F87.
MSI (s) (60:B0) [10:53:51:472]: Skipping action due to msidbCustomActionTypeFirstSequence option.
Action ended 10:53:51: LiLiW_ExtractFiles.EDA67544_39E0_4D88_B650_464D261A4F87. Return value 0.
MSI (s) (60:B0) [10:53:51:472]: Skipping action: LiLiW_SilentlySelectKey.EDA67544_39E0_4D88_B650_464D261A4F87 (condition is false)
MSI (s) (60:B0) [10:53:51:472]: Skipping action: LiLiW_CheckKey.EDA67544_39E0_4D88_B650_464D261A4F87 (condition is false)
MSI (s) (60:B0) [10:53:51:472]: Skipping action: Nero_LicenseInvalid.EDA67544_39E0_4D88_B650_464D261A4F87 (condition is false)
MSI (s) (60:B0) [10:53:51:472]: Doing action: LiLiW_CreateCAData.EDA67544_39E0_4D88_B650_464D261A4F87
Action 10:53:51: LiLiW_CreateCAData.EDA67544_39E0_4D88_B650_464D261A4F87.
Action start 10:53:51: LiLiW_CreateCAData.EDA67544_39E0_4D88_B650_464D261A4F87.
MSI (s) (60:B0) [10:53:51:488]: Creating MSIHANDLE (1612) of type 790542 for thread 8112
MSI (s) (60:7C) [10:53:51:488]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIE512.tmp, Entrypoint: _MSICreateCAData@4
MSI (s) (60!A8) [10:53:51:541]: Creating MSIHANDLE (1613) of type 790531 for thread 11432
MSI (s) (60!A8) [10:53:51:541]: PROPERTY CHANGE: Adding NERO.ACTION_DATA property. Its value is 'C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?'.
MSI (s) (60!A8) [10:53:51:541]: Creating MSIHANDLE (1614) of type 790531 for thread 11432
Nero custom action returned LiLiW error code 0.
MSI (s) (60!A8) [10:53:51:541]: Closing MSIHANDLE (1614) of type 790531 for thread 11432
MSI (s) (60!A8) [10:53:51:541]: Closing MSIHANDLE (1613) of type 790531 for thread 11432
MSI (s) (60:7C) [10:53:51:541]: Closing MSIHANDLE (1612) of type 790542 for thread 8112
Action ended 10:53:51: LiLiW_CreateCAData.EDA67544_39E0_4D88_B650_464D261A4F87. Return value 1.
MSI (s) (60:B0) [10:53:51:557]: Doing action: LiLiW_CAData_RemoveKey.EDA67544_39E0_4D88_B650_464D261A4F87
Action 10:53:51: LiLiW_CAData_RemoveKey.EDA67544_39E0_4D88_B650_464D261A4F87.
Action start 10:53:51: LiLiW_CAData_RemoveKey.EDA67544_39E0_4D88_B650_464D261A4F87.
MSI (s) (60:B0) [10:53:51:557]: PROPERTY CHANGE: Adding LiLiW_RemoveKey.EDA67544_39E0_4D88_B650_464D261A4F87 property. Its value is 'C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?'.
Action ended 10:53:51: LiLiW_CAData_RemoveKey.EDA67544_39E0_4D88_B650_464D261A4F87. Return value 1.
MSI (s) (60:B0) [10:53:51:557]: Doing action: LiLiW_CAData_CommitKey.EDA67544_39E0_4D88_B650_464D261A4F87
Action 10:53:51: LiLiW_CAData_CommitKey.EDA67544_39E0_4D88_B650_464D261A4F87.
Action start 10:53:51: LiLiW_CAData_CommitKey.EDA67544_39E0_4D88_B650_464D261A4F87.
MSI (s) (60:B0) [10:53:51:557]: PROPERTY CHANGE: Adding LiLiW_CommitKey.EDA67544_39E0_4D88_B650_464D261A4F87 property. Its value is 'C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?'.
Action ended 10:53:51: LiLiW_CAData_CommitKey.EDA67544_39E0_4D88_B650_464D261A4F87. Return value 1.
MSI (s) (60:B0) [10:53:51:557]: Doing action: LiLiW_CAData_AcceptEula.EDA67544_39E0_4D88_B650_464D261A4F87
Action 10:53:51: LiLiW_CAData_AcceptEula.EDA67544_39E0_4D88_B650_464D261A4F87.
Action start 10:53:51: LiLiW_CAData_AcceptEula.EDA67544_39E0_4D88_B650_464D261A4F87.
MSI (s) (60:B0) [10:53:51:557]: PROPERTY CHANGE: Adding LiLiW_AcceptEula.EDA67544_39E0_4D88_B650_464D261A4F87 property. Its value is 'C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?'.
Action ended 10:53:51: LiLiW_CAData_AcceptEula.EDA67544_39E0_4D88_B650_464D261A4F87. Return value 1.
MSI (s) (60:B0) [10:53:51:557]: Doing action: Nero_CA_DeleteGlobalFileAssociationDbRollback
Action 10:53:51: Nero_CA_DeleteGlobalFileAssociationDbRollback.
Action start 10:53:51: Nero_CA_DeleteGlobalFileAssociationDbRollback.
Nero_CA_DeleteGlobalFileAssociationDbRollback:
Action ended 10:53:51: Nero_CA_DeleteGlobalFileAssociationDbRollback. Return value 1.
MSI (s) (60:B0) [10:53:51:573]: Doing action: Nero_CA_CreateGlobalFileAssociationDb
Action 10:53:51: Nero_CA_CreateGlobalFileAssociationDb.
Action start 10:53:51: Nero_CA_CreateGlobalFileAssociationDb.
Nero_CA_CreateGlobalFileAssociationDb:
Action ended 10:53:51: Nero_CA_CreateGlobalFileAssociationDb. Return value 1.
MSI (s) (60:B0) [10:53:51:573]: Doing action: ISChainPackageRollback
Action 10:53:51: ISChainPackageRollback.
Action start 10:53:51: ISChainPackageRollback.
ISChainPackageRollback:
Action ended 10:53:51: ISChainPackageRollback. Return value 1.
MSI (s) (60:B0) [10:53:51:573]: Doing action: ISChainPackageCommit
Action 10:53:51: ISChainPackageCommit.
Action start 10:53:51: ISChainPackageCommit.
ISChainPackageCommit:
Action ended 10:53:51: ISChainPackageCommit. Return value 1.
MSI (s) (60:B0) [10:53:51:588]: Skipping action: AllocateRegistrySpace (condition is false)
MSI (s) (60:B0) [10:53:51:588]: Doing action: ProcessComponents
Action 10:53:51: ProcessComponents. Updating component registration
Action start 10:53:51: ProcessComponents.
1: Updating component registration
Action ended 10:53:51: ProcessComponents. Return value 1.
MSI (s) (60:B0) [10:53:51:588]: Doing action: UnpublishComponents
Action 10:53:51: UnpublishComponents. Unpublishing Qualified Components
Action start 10:53:51: UnpublishComponents.
MSI (s) (60:B0) [10:53:51:588]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:B0) [10:53:51:588]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 10:53:51: UnpublishComponents. Return value 0.
MSI (s) (60:B0) [10:53:51:588]: Doing action: MsiUnpublishAssemblies
Action 10:53:51: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 10:53:51: MsiUnpublishAssemblies.
MSI (s) (60:B0) [10:53:51:604]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:B0) [10:53:51:604]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 10:53:51: MsiUnpublishAssemblies. Return value 0.
MSI (s) (60:B0) [10:53:51:604]: Doing action: UnpublishFeatures
Action 10:53:51: UnpublishFeatures. Unpublishing product features
Action start 10:53:51: UnpublishFeatures.
MSI (s) (60:B0) [10:53:51:604]: Using cached product context: machine assigned for product: ECC9C29D0F5E521479A750093F22B547
UnpublishFeatures: Feature: Unpublishing product features
Action ended 10:53:51: UnpublishFeatures. Return value 1.
MSI (s) (60:B0) [10:53:51:604]: Doing action: StopServices
Action 10:53:51: StopServices. Stopping services
Action start 10:53:51: StopServices.
Nissi1
Nissi1
I realize 2 posts are the same but I made sure I checked them before posting and they were different.   I even pasted the 2nd report on a note sheet to be sure but when I pasted it again it was identical to the one above it (Twilight Zone music.)  I've been at this for 2 days, perhaps I and my computer have gone bonkers! :-\  I will try once again making the report shorter than the first time.
Also, my spell check no longer works.
MSI (s) (60:B0) [10:53:51:604]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:B0) [10:53:51:604]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action ended 10:53:51: StopServices. Return value 1.
MSI (s) (60:B0) [10:53:51:604]: Doing action: DeleteServices
Action 10:53:51: DeleteServices. Deleting services
Action start 10:53:51: DeleteServices.
Action ended 10:53:51: DeleteServices. Return value 1.
MSI (s) (60:B0) [10:53:51:604]: Doing action: UnregisterComPlus
Action 10:53:51: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 10:53:51: UnregisterComPlus.
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2205 2:  3: Complus
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
Action ended 10:53:51: UnregisterComPlus. Return value 0.
MSI (s) (60:B0) [10:53:51:620]: Doing action: SelfUnregModules
Action 10:53:51: SelfUnregModules. Unregistering modules
Action start 10:53:51: SelfUnregModules.
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
Action ended 10:53:51: SelfUnregModules. Return value 1.
MSI (s) (60:B0) [10:53:51:620]: Doing action: UnregisterTypeLibraries
Action 10:53:51: UnregisterTypeLibraries. Unregistering type libraries
Action start 10:53:51: UnregisterTypeLibraries.
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
Action ended 10:53:51: UnregisterTypeLibraries. Return value 0.
MSI (s) (60:B0) [10:53:51:620]: Doing action: RemoveODBC
Action 10:53:51: RemoveODBC. Removing ODBC components
Action start 10:53:51: RemoveODBC.
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2711 2: ODBC
Nissi1
1: Removing ODBC components
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2711 2: ODBCDriverManager64
Action ended 10:53:51: RemoveODBC. Return value 1.
MSI (s) (60:B0) [10:53:51:620]: Doing action: UnregisterFonts
Action 10:53:51: UnregisterFonts. Unregistering fonts
Action start 10:53:51: UnregisterFonts.
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2205 2:  3: Font
MSI (s) (60:B0) [10:53:51:620]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
Action ended 10:53:51: UnregisterFonts. Return value 1.
MSI (s) (60:B0) [10:53:51:620]: Doing action: RemoveRegistryValues
Action 10:53:51: RemoveRegistryValues. Removing system registry values
Action start 10:53:51: RemoveRegistryValues.
RemoveRegistryValues: Key: Removing system registry values, Name:
Action ended 10:53:51: RemoveRegistryValues. Return value 1.
MSI (s) (60:B0) [10:53:51:642]: Doing action: UnregisterClassInfo
Action 10:53:51: UnregisterClassInfo. Unregister class servers
Action start 10:53:51: UnregisterClassInfo.
MSI (s) (60:B0) [10:53:51:642]: Note: 1: 2205 2:  3: Class
MSI (s) (60:B0) [10:53:51:642]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 10:53:51: UnregisterClassInfo. Return value 0.
MSI (s) (60:B0) [10:53:51:642]: Doing action: UnregisterExtensionInfo
Action 10:53:51: UnregisterExtensionInfo. Unregistering extension servers
Action start 10:53:51: UnregisterExtensionInfo.
MSI (s) (60:B0) [10:53:51:642]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:B0) [10:53:51:642]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 10:53:51: UnregisterExtensionInfo. Return value 0.
MSI (s) (60:B0) [10:53:51:642]: Doing action: UnregisterProgIdInfo
Action 10:53:51: UnregisterProgIdInfo. Unregistering program identifiers
Action start 10:53:51: UnregisterProgIdInfo.
MSI (s) (60:B0) [10:53:51:642]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:B0) [10:53:51:642]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 10:53:51: UnregisterProgIdInfo. Return value 0.
MSI (s) (60:B0) [10:53:51:642]: Doing action: UnregisterMIMEInfo
Action 10:53:51: UnregisterMIMEInfo. Unregistering MIME info
Action start 10:53:51: UnregisterMIMEInfo.
MSI (s) (60:B0) [10:53:51:642]: Note: 1: 2205 2:  3: MIME
MSI (s) (60:B0) [10:53:51:642]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 10:53:51: UnregisterMIMEInfo. Return value 0.
MSI (s) (60:B0) [10:53:51:642]: Doing action: RemoveIniValues
Action 10:53:51: RemoveIniValues. Removing INI file entries
Action start 10:53:51: RemoveIniValues.
MSI (s) (60:B0) [10:53:51:657]: Note: 1: 2205 2:  3: IniFile
MSI (s) (60:B0) [10:53:51:657]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
Action ended 10:53:51: RemoveIniValues. Return value 1.
MSI (s) (60:B0) [10:53:51:657]: Doing action: RemoveShortcuts
Action 10:53:51: RemoveShortcuts. Removing shortcuts
Action start 10:53:51: RemoveShortcuts.
MSI (s) (60:B0) [10:53:51:657]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:B0) [10:53:51:657]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action ended 10:53:51: RemoveShortcuts. Return value 0.
MSI (s) (60:B0) [10:53:51:657]: Doing action: RemoveEnvironmentStrings
Action 10:53:51: RemoveEnvironmentStrings. Updating environment strings
Action start 10:53:51: RemoveEnvironmentStrings.
MSI (s) (60:B0) [10:53:51:657]: Note: 1: 2205 2:  3: Environment
MSI (s) (60:B0) [10:53:51:657]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
Action ended 10:53:51: RemoveEnvironmentStrings. Return value 1.
MSI (s) (60:B0) [10:53:51:657]: Doing action: RemoveDuplicateFiles
Action 10:53:51: RemoveDuplicateFiles. Removing duplicated files
Action start 10:53:51: RemoveDuplicateFiles.
Action ended 10:53:51: RemoveDuplicateFiles. Return value 1.
MSI (s) (60:B0) [10:53:51:657]: Doing action: RemoveFiles
Action 10:53:51: RemoveFiles. Removing files
Action start 10:53:51: RemoveFiles.
MSI (s) (60:B0) [10:53:51:657]: Note: 1: 2205 2:  3: RemoveFile
Action ended 10:53:51: RemoveFiles. Return value 0.
MSI (s) (60:B0) [10:53:51:657]: Doing action: RemoveFolders
Action 10:53:51: RemoveFolders. Removing folders
Action start 10:53:51: RemoveFolders.
RemoveFolders: Folder: Removing folders
Action ended 10:53:51: RemoveFolders. Return value 1.
MSI (s) (60:B0) [10:53:51:673]: Doing action: CreateFolders
Action 10:53:51: CreateFolders. Creating folders
Action start 10:53:51: CreateFolders.
Action ended 10:53:51: CreateFolders. Return value 1.
MSI (s) (60:B0) [10:53:51:673]: Doing action: MoveFiles
Action 10:53:51: MoveFiles. Moving files
Action start 10:53:51: MoveFiles.
Action ended 10:53:51: MoveFiles. Return value 1.
MSI (s) (60:B0) [10:53:51:673]: Doing action: InstallFiles
Action 10:53:51: InstallFiles. Copying new files
Action start 10:53:51: InstallFiles.
MSI (s) (60:B0) [10:53:51:673]: Dumping binary patch manager data...
MSI (s) (60:B0) [10:53:51:673]: Note: 1: 2262 2: Media 3: -2147287038
MSI (s) (60:B0) [10:53:51:673]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
MSI (s) (60:B0) [10:53:51:673]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
MSI (s) (60:B0) [10:53:51:673]: Note: 1: 2205 2:  3: MsiSFCBypass
MSI (s) (60:B0) [10:53:51:673]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
MSI (s) (60:B0) [10:53:51:673]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (60:B0) [10:53:51:673]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
Action ended 10:53:51: InstallFiles. Return value 1.
MSI (s) (60:B0) [10:53:51:673]: Doing action: PatchFiles
Action 10:53:51: PatchFiles. Patching files
Action start 10:53:51: PatchFiles.
Action ended 10:53:51: PatchFiles. Return value 1.
MSI (s) (60:B0) [10:53:51:673]: Doing action: DuplicateFiles
Action 10:53:51: DuplicateFiles. Creating duplicate files
Action start 10:53:51: DuplicateFiles.
Action ended 10:53:51: DuplicateFiles. Return value 1.
MSI (s) (60:B0) [10:53:51:689]: Skipping action: CANOSUS_InstallRollback.EE698257_A789_474D_A546_5E5AAA5B180D (condition is false)
MSI (s) (60:B0) [10:53:51:689]: Skipping action: CANOSUS_InstallExecute.EE698257_A789_474D_A546_5E5AAA5B180D (condition is false)
MSI (s) (60:B0) [10:53:51:689]: Skipping action: LiLiW_RemoveKey.EDA67544_39E0_4D88_B650_464D261A4F87 (condition is false)
MSI (s) (60:B0) [10:53:51:689]: Skipping action: LiLiW_CommitKey.EDA67544_39E0_4D88_B650_464D261A4F87 (condition is false)
MSI (s) (60:B0) [10:53:51:689]: Skipping action: LiLiW_AcceptEula.EDA67544_39E0_4D88_B650_464D261A4F87 (condition is false)
MSI (s) (60:B0) [10:53:51:689]: Doing action: BindImage
Action 10:53:51: BindImage. Binding executables
Action start 10:53:51: BindImage.
Action ended 10:53:51: BindImage. Return value 1.
MSI (s) (60:B0) [10:53:51:689]: Doing action: CreateShortcuts
Action 10:53:51: CreateShortcuts. Creating shortcuts
Action start 10:53:51: CreateShortcuts.
MSI (s) (60:B0) [10:53:51:689]: Using cached product context: machine assigned for product: ECC9C29D0F5E521479A750093F22B547
MSI (s) (60:B0) [10:53:51:689]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:B0) [10:53:51:689]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action ended 10:53:51: CreateShortcuts. Return value 0.
MSI (s) (60:B0) [10:53:51:689]: Doing action: RegisterClassInfo
Action 10:53:51: RegisterClassInfo. Registering class servers
Action start 10:53:51: RegisterClassInfo.
MSI (s) (60:B0) [10:53:51:689]: Note: 1: 2205 2:  3: Class
MSI (s) (60:B0) [10:53:51:689]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 10:53:51: RegisterClassInfo. Return value 0.
MSI (s) (60:B0) [10:53:51:689]: Doing action: RegisterExtensionInfo
Action 10:53:51: RegisterExtensionInfo. Registering extension servers
Action start 10:53:51: RegisterExtensionInfo.
MSI (s) (60:B0) [10:53:51:689]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:B0) [10:53:51:689]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 10:53:51: RegisterExtensionInfo. Return value 0.
MSI (s) (60:B0) [10:53:51:689]: Doing action: RegisterProgIdInfo
Action 10:53:51: RegisterProgIdInfo. Registering program identifiers
Action start 10:53:51: RegisterProgIdInfo.
MSI (s) (60:B0) [10:53:51:704]: Using cached product context: machine assigned for product: ECC9C29D0F5E521479A750093F22B547
MSI (s) (60:B0) [10:53:51:704]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:B0) [10:53:51:704]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 10:53:51: RegisterProgIdInfo. Return value 0.
MSI (s) (60:B0) [10:53:51:704]: Doing action: RegisterMIMEInfo
Action 10:53:51: RegisterMIMEInfo. Registering MIME info
Action start 10:53:51: RegisterMIMEInfo.
MSI (s) (60:B0) [10:53:51:704]: Note: 1: 2205 2:  3: MIME
MSI (s) (60:B0) [10:53:51:704]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action ended 10:53:51: RegisterMIMEInfo. Return value 0.
MSI (s) (60:B0) [10:53:51:704]: Doing action: WriteRegistryValues
Action 10:53:51: WriteRegistryValues. Writing system registry values
Action start 10:53:51: WriteRegistryValues.
Action ended 10:53:51: WriteRegistryValues. Return value 1.
MSI (s) (60:B0) [10:53:51:704]: Doing action: WriteIniValues
Action 10:53:51: WriteIniValues. Writing INI file values
Action start 10:53:51: WriteIniValues.
MSI (s) (60:B0) [10:53:51:704]: Note: 1: 2205 2:  3: IniFile
MSI (s) (60:B0) [10:53:51:704]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
Action ended 10:53:51: WriteIniValues. Return value 1.
MSI (s) (60:B0) [10:53:51:704]: Doing action: WriteEnvironmentStrings
Action 10:53:51: WriteEnvironmentStrings. Updating environment strings
Action start 10:53:51: WriteEnvironmentStrings.
MSI (s) (60:B0) [10:53:51:704]: Note: 1: 2205 2:  3: Environment
MSI (s) (60:B0) [10:53:51:704]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
Action ended 10:53:51: WriteEnvironmentStrings. Return value 1.
MSI (s) (60:B0) [10:53:51:704]: Doing action: RegisterFonts
Action 10:53:51: RegisterFonts. Registering fonts
Action start 10:53:51: RegisterFonts.
MSI (s) (60:B0) [10:53:51:704]: Note: 1: 2205 2:  3: Font
MSI (s) (60:B0) [10:53:51:704]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
Action ended 10:53:51: RegisterFonts. Return value 1.
MSI (s) (60:B0) [10:53:51:720]: Doing action: InstallODBC
Action 10:53:51: InstallODBC. Installing ODBC components
Action start 10:53:51: InstallODBC.
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2711 2: ODBCDriverManager
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
Action ended 10:53:51: InstallODBC. Return value 0.
MSI (s) (60:B0) [10:53:51:720]: Doing action: RegisterTypeLibraries
Action 10:53:51: RegisterTypeLibraries. Registering type libraries
Action start 10:53:51: RegisterTypeLibraries.
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
Action ended 10:53:51: RegisterTypeLibraries. Return value 0.
MSI (s) (60:B0) [10:53:51:720]: Doing action: SelfRegModules
Action 10:53:51: SelfRegModules. Registering modules
Action start 10:53:51: SelfRegModules.
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
Action ended 10:53:51: SelfRegModules. Return value 1.
MSI (s) (60:B0) [10:53:51:720]: Doing action: RegisterComPlus
Action 10:53:51: RegisterComPlus. Registering COM+ Applications and Components
Action start 10:53:51: RegisterComPlus.
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2205 2:  3: Complus
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action ended 10:53:51: RegisterComPlus. Return value 0.
MSI (s) (60:B0) [10:53:51:720]: Doing action: InstallServices
Action 10:53:51: InstallServices. Installing new services
Action start 10:53:51: InstallServices.
MSI (s) (60:B0) [10:53:51:720]: Detected older ServiceInstall table schema
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2205 2:  3: ServiceInstall
MSI (s) (60:B0) [10:53:51:720]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
Action ended 10:53:51: InstallServices. Return value 1.
MSI (s) (60:B0) [10:53:51:720]: Doing action: StartServices
Action 10:53:51: StartServices. Starting services
Action start 10:53:51: StartServices.
MSI (s) (60:B0) [10:53:51:737]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:B0) [10:53:51:737]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action ended 10:53:51: StartServices. Return value 1.
MSI (s) (60:B0) [10:53:51:738]: Doing action: RegisterUser
Action 10:53:51: RegisterUser. Registering user
Action start 10:53:51: RegisterUser.
Action ended 10:53:51: RegisterUser. Return value 0.
MSI (s) (60:B0) [10:53:51:740]: Doing action: RegisterProduct
Action 10:53:51: RegisterProduct. Registering product
Action start 10:53:51: RegisterProduct.
Action ended 10:53:51: RegisterProduct. Return value 1.
MSI (s) (60:B0) [10:53:51:742]: Doing action: PublishComponents
Action 10:53:51: PublishComponents. Publishing qualified components
Action start 10:53:51: PublishComponents.
MSI (s) (60:B0) [10:53:51:742]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:B0) [10:53:51:742]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action ended 10:53:51: PublishComponents. Return value 0.
MSI (s) (60:B0) [10:53:51:742]: Doing action: MsiPublishAssemblies
Action 10:53:51: MsiPublishAssemblies. Publishing assembly information
Action start 10:53:51: MsiPublishAssemblies.
MSI (s) (60:B0) [10:53:51:742]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:B0) [10:53:51:742]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action ended 10:53:51: MsiPublishAssemblies. Return value 0.
MSI (s) (60:B0) [10:53:51:742]: Doing action: PublishFeatures
Action 10:53:51: PublishFeatures. Publishing product features
Action start 10:53:51: PublishFeatures.
Action ended 10:53:51: PublishFeatures. Return value 1.
MSI (s) (60:B0) [10:53:51:742]: Doing action: PublishProduct
Action 10:53:51: PublishProduct. Publishing product information
Action start 10:53:51: PublishProduct.
MSI (s) (60:B0) [10:53:51:742]: Using cached product context: machine assigned for product: ECC9C29D0F5E521479A750093F22B547
1: Publishing product information
Action ended 10:53:51: PublishProduct. Return value 1.
MSI (s) (60:B0) [10:53:51:758]: Doing action: Nero_CA_DeleteGlobalFileAssociationDbCommit
Action 10:53:51: Nero_CA_DeleteGlobalFileAssociationDbCommit.
Action start 10:53:51: Nero_CA_DeleteGlobalFileAssociationDbCommit.
Nero_CA_DeleteGlobalFileAssociationDbCommit:
Action ended 10:53:51: Nero_CA_DeleteGlobalFileAssociationDbCommit. Return value 1.
MSI (s) (60:B0) [10:53:51:758]: Doing action: Nero_CA_FixRepairCmdLine
Action 10:53:51: Nero_CA_FixRepairCmdLine.
Action start 10:53:51: Nero_CA_FixRepairCmdLine.
MSI (s) (60:B0) [10:53:51:758]: Creating MSIHANDLE (1615) of type 790542 for thread 8112
MSI (s) (60:34) [10:53:51:773]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIE61D.tmp, Entrypoint: CA_FixRepairCmdLine
MSI (s) (60!F4) [10:53:51:820]: Creating MSIHANDLE (1616) of type 790531 for thread 11252
CA_FixRepairCmdLine: CustomActions.cpp : 700 :  Succeeded
MSI (s) (60!F4) [10:53:51:820]: Closing MSIHANDLE (1616) of type 790531 for thread 11252
MSI (s) (60:34) [10:53:51:820]: Closing MSIHANDLE (1615) of type 790542 for thread 8112
Action ended 10:53:51: Nero_CA_FixRepairCmdLine. Return value 1.
MSI (s) (60:B0) [10:53:51:820]: Skipping action: ScheduleReboot (condition is false)
MSI (s) (60:B0) [10:53:51:820]: Doing action: InstallFinalize
Action 10:53:51: InstallFinalize.
Action start 10:53:51: InstallFinalize.
InstallFinalize:
MSI (s) (60:B0) [10:53:51:820]: Running Script: C:\WINDOWS\Installer\MSIE4F2.tmp
MSI (s) (60:B0) [10:53:51:820]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (60:B0) [10:53:51:820]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:B0) [10:53:51:838]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:B0) [10:53:51:842]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (60:B0) [10:53:51:842]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1254839994,LangId=0,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (60:B0) [10:53:51:842]: Executing op: ProductInfo(ProductKey={D92C9CCE-E5F0-4125-977A-0590F3225B74},ProductName=SyncUP,PackageName=Nero.mhubdell.msi,Language=0,Version=167918632,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={D5723832-302A-4BB1-BE36-434859360ADB},,,InstanceType=0,LUASetting=1,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (s) (60:B0) [10:53:51:842]: Executing op: DialogInfo(Type=0,Argument=0)
MSI (s) (60:B0) [10:53:51:842]: Executing op: DialogInfo(Type=1,Argument=SyncUP)
MSI (s) (60:B0) [10:53:51:842]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (60:B0) [10:53:51:842]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (60:B0) [10:53:51:842]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (60:B0) [10:53:51:842]: Executing op: ActionStart(Name=InstallInitialize,,)
MSI (s) (60:B0) [10:53:51:842]: Executing op: ProductUnregister(UpgradeCode={CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0})
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74}
MSI (s) (60:B0) [10:53:51:842]: Note: 1: 1402 2: UNKNOWN\Products\ECC9C29D0F5E521479A750093F22B547\Transforms 3: 2
MSI (s) (60:B0) [10:53:51:842]: Scheduling file 'C:\Windows\Installer\11a49.msi' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:B0) [10:53:51:874]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\Software\Microsoft\Windows\CurrentVersion\Uninstall\{D92C9CCE-E5F0-4125-977A-0590F3225B74} 3: 2
MSI (s) (60:B0) [10:53:51:874]: Note: 1: 1402 2: UNKNOWN\Products\ECC9C29D0F5E521479A750093F22B547\Usage 3: 2
MSI (s) (60:B0) [10:53:51:874]: Executing op: ProductCPDisplayInfoUnregister()
MSI (s) (60:B0) [10:53:51:874]: Executing op: ProductUnpublish(PackageKey={D5723832-302A-4BB1-BE36-434859360ADB})
MSI (s) (60:B0) [10:53:51:874]: Using cached product context: machine assigned for product: ECC9C29D0F5E521479A750093F22B547
MSI (s) (60:B0) [10:53:51:874]: Transforms are not secure.
MSI (s) (60:B0) [10:53:51:874]: Processing cached transform: C:\WINDOWS\Installer\{D92C9CCE-E5F0-4125-977A-0590F3225B74}\1033.mst
MSI (s) (60:B0) [10:53:51:874]: Scheduling file 'C:\WINDOWS\Installer\{D92C9CCE-E5F0-4125-977A-0590F3225B74}\1033.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:B0) [10:53:51:874]: Registering cached transform: C:\WINDOWS\Installer\{D92C9CCE-E5F0-4125-977A-0590F3225B74}\1033.mst
MSI (s) (60:B0) [10:53:51:874]: Executing op: UpgradeCodeUnpublish(UpgradeCode={CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0})
MSI (s) (60:B0) [10:53:51:874]: Executing op: IconRemove(Icon=ARPPRODUCTICON.exe,)
1: ARPPRODUCTICON.exe
MSI (s) (60:B0) [10:53:51:889]: Scheduling file 'C:\WINDOWS\Installer\{D92C9CCE-E5F0-4125-977A-0590F3225B74}\ARPPRODUCTICON.exe' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:B0) [10:53:51:889]: Executing op: ProductUnpublishClient(,,)
MSI (s) (60:B0) [10:53:51:889]: Note: 1: 1402 2: UNKNOWN\Installer\Products\ECC9C29D0F5E521479A750093F22B547 3: 2
MSI (s) (60:B0) [10:53:51:889]: Executing op: SourceListUnpublish(,)
MSI (s) (60:B0) [10:53:51:889]: Note: 1: 1402 2: UNKNOWN\Installer\Products\ECC9C29D0F5E521479A750093F22B547\SourceList 3: 2
MSI (s) (60:B0) [10:53:51:889]: Executing op: ActionStart(Name=Nero_CA_DeleteGlobalFileAssociationDbRollback,,)
MSI (s) (60:B0) [10:53:51:889]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteGlobalFileAssociationDbRollback,ActionType=1281,Source=BinaryData,Target=CA_DeleteGlobalFileAssociationDb,CustomActionData=Nero 10)
MSI (s) (60:B0) [10:53:51:889]: Executing op: ActionStart(Name=Nero_CA_CreateGlobalFileAssociationDb,,)
MSI (s) (60:B0) [10:53:51:889]: Executing op: CustomActionSchedule(Action=Nero_CA_CreateGlobalFileAssociationDb,ActionType=1025,Source=BinaryData,Target=CA_CreateGlobalFileAssociationDb,)
MSI (s) (60:B0) [10:53:51:905]: Creating MSIHANDLE (1617) of type 790536 for thread 8112
MSI (s) (60:58) [10:53:51:905]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIE6AB.tmp, Entrypoint: CA_CreateGlobalFileAssociationDb
MSI (s) (60:58) [10:53:51:958]: Closing MSIHANDLE (1617) of type 790536 for thread 8112
MSI (s) (60:B0) [10:53:51:958]: Executing op: ActionStart(Name=ISChainPackageRollback,,)
MSI (s) (60:B0) [10:53:51:958]: Executing op: CustomActionSchedule(Action=ISChainPackageRollback,ActionType=1281,Source=BinaryData,Target=ISChainPackagesCleanup,)
MSI (s) (60:B0) [10:53:51:958]: Executing op: ActionStart(Name=ISChainPackageCommit,,)
MSI (s) (60:B0) [10:53:51:958]: Executing op: CustomActionSchedule(Action=ISChainPackageCommit,ActionType=1537,Source=BinaryData,Target=ISChainPackagesCleanup,)
MSI (s) (60:B0) [10:53:51:958]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (60:B0) [10:53:51:958]: Executing op: ProgressTotal(Total=21,Type=1,ByteEquivalent=24000)
MSI (s) (60:B0) [10:53:51:958]: Executing op: UnregisterSharedComponentProvider(Component={0B1B62FF-E704-4B3D-9261-C3D6379A3969},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:958]: Executing op: ComponentUnregister(ComponentId={0B1B62FF-E704-4B3D-9261-C3D6379A3969},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {0B1B62FF-E704-4B3D-9261-C3D6379A3969}
Nissi1
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={2E6746AA-C783-4918-A405-36FE2B13FDF0},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={2E6746AA-C783-4918-A405-36FE2B13FDF0},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {2E6746AA-C783-4918-A405-36FE2B13FDF0}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={DCCB873F-FC72-4AE3-8727-F60AF836FEA8},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={DCCB873F-FC72-4AE3-8727-F60AF836FEA8},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {DCCB873F-FC72-4AE3-8727-F60AF836FEA8}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={A3B6E5AE-E4B6-46C7-B77A-F8B3CD9034DB},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={A3B6E5AE-E4B6-46C7-B77A-F8B3CD9034DB},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {A3B6E5AE-E4B6-46C7-B77A-F8B3CD9034DB}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={10725F0E-036E-4168-A9D8-78CB4D01F5B5},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={10725F0E-036E-4168-A9D8-78CB4D01F5B5},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {10725F0E-036E-4168-A9D8-78CB4D01F5B5}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={C8C2B555-72EC-49FE-9E06-DBC491F16DE1},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={C8C2B555-72EC-49FE-9E06-DBC491F16DE1},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {C8C2B555-72EC-49FE-9E06-DBC491F16DE1}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={7D771EC1-86D8-4597-915E-B60E0B091C6B},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={7D771EC1-86D8-4597-915E-B60E0B091C6B},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {7D771EC1-86D8-4597-915E-B60E0B091C6B}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={DA427D9A-D879-4B01-88AE-B777EBEA3146},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={DA427D9A-D879-4B01-88AE-B777EBEA3146},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {DA427D9A-D879-4B01-88AE-B777EBEA3146}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={C5B573D3-B70D-47A0-8CF8-979346423392},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={C5B573D3-B70D-47A0-8CF8-979346423392},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {C5B573D3-B70D-47A0-8CF8-979346423392}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={E10FEB28-E198-450F-A777-04140FA01A16},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={E10FEB28-E198-450F-A777-04140FA01A16},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {E10FEB28-E198-450F-A777-04140FA01A16}
MSI (s) (60:B0) [10:53:51:974]: Executing op: UnregisterSharedComponentProvider(Component={50A4A856-3F34-43A8-978E-1E415D61D8CE},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:974]: Executing op: ComponentUnregister(ComponentId={50A4A856-3F34-43A8-978E-1E415D61D8CE},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {50A4A856-3F34-43A8-978E-1E415D61D8CE}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={E5E9DEC8-4247-44DE-A991-99B19AC534CF},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={E5E9DEC8-4247-44DE-A991-99B19AC534CF},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {E5E9DEC8-4247-44DE-A991-99B19AC534CF}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={104A7ACA-1309-4F56-A8D1-15EDAD3590A6},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={104A7ACA-1309-4F56-A8D1-15EDAD3590A6},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {104A7ACA-1309-4F56-A8D1-15EDAD3590A6}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={86D363CC-7873-4E4C-B7F7-67200853AD9E},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={86D363CC-7873-4E4C-B7F7-67200853AD9E},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {86D363CC-7873-4E4C-B7F7-67200853AD9E}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={9FE088FA-57D9-433C-9CBC-807025ACBB61},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={9FE088FA-57D9-433C-9CBC-807025ACBB61},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {9FE088FA-57D9-433C-9CBC-807025ACBB61}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={96DA072D-C3C7-4B45-9B8A-67660D66DD57},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={96DA072D-C3C7-4B45-9B8A-67660D66DD57},,BinaryType=0,PreviouslyPinned=1)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {96DA072D-C3C7-4B45-9B8A-67660D66DD57}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={4CAD5589-E55D-40C1-9593-185CD249EB0F},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={4CAD5589-E55D-40C1-9593-185CD249EB0F},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {4CAD5589-E55D-40C1-9593-185CD249EB0F}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={C0D520F3-AF25-4DC5-B488-502E065D561D},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={C0D520F3-AF25-4DC5-B488-502E065D561D},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {C0D520F3-AF25-4DC5-B488-502E065D561D}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={AD8F0807-F6DC-4000-9317-8B6621C3EDDF},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={AD8F0807-F6DC-4000-9317-8B6621C3EDDF},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {AD8F0807-F6DC-4000-9317-8B6621C3EDDF}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={E36F6346-19E4-47E7-A360-B8CF7B465730},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={E36F6346-19E4-47E7-A360-B8CF7B465730},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {E36F6346-19E4-47E7-A360-B8CF7B465730}
MSI (s) (60:B0) [10:53:51:989]: Executing op: UnregisterSharedComponentProvider(Component={8935F466-A062-4C45-B4F3-33ADF99AE2FE},ProductCode={D92C9CCE-E5F0-4125-977A-0590F3225B74})
MSI (s) (60:B0) [10:53:51:989]: Executing op: ComponentUnregister(ComponentId={8935F466-A062-4C45-B4F3-33ADF99AE2FE},,BinaryType=0,)
1: {D92C9CCE-E5F0-4125-977A-0590F3225B74} 2: {8935F466-A062-4C45-B4F3-33ADF99AE2FE}
MSI (s) (60:B0) [10:53:52:005]: Executing op: ActionStart(Name=UnpublishFeatures,Description=Unpublishing product features,Template=Feature: [1])
Action 10:53:52: UnpublishFeatures. Unpublishing product features
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=HelpChm,Parent=Main,Absent=2,)
UnpublishFeatures: Feature: HelpChm
MSI (s) (60:B0) [10:53:52:005]: Note: 1: 1402 2: UNKNOWN\Installer\Features\ECC9C29D0F5E521479A750093F22B547 3: 2
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=ControlCenterHelpChm,Parent=HelpChm,Absent=2,Component=[YLX&GNT3@bx*%nG^^nIYacv2%SwQ?]yidzU$VNv)
UnpublishFeatures: Feature: ControlCenterHelpChm
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=MobileSyncHelpChm,Parent=HelpChm,Absent=2,Component=36&6vcq9D9y@,aelhJ2G,uXSCeW1$9V('lOA't7u)
UnpublishFeatures: Feature: MobileSyncHelpChm
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=Main,,Absent=2,)
UnpublishFeatures: Feature: Main
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=HiddenFeatures,Parent=Main,Absent=2,)
UnpublishFeatures: Feature: HiddenFeatures
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=BDCoreApp,Parent=HiddenFeatures,Absent=2,Component=BPszoqpw(@(rNT&TfdB_m@R]]~Z`h=]rZpbA%NNo)
UnpublishFeatures: Feature: BDCoreApp
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=Common,Parent=HiddenFeatures,Absent=2,Component=n-B@(CGo$9Dc^IjxWrPcyX+QXDjF4@r!YvH}OG8DVCg_@nW+n8qbzZE?ot,(!Z{{ffA`~@5H=t2TNOL,ugLk`8USX8pPGzH+CQ{p{L?+rUkA,?`Hcikrg]U3BxM+Th]aS@]Yea`IJ3wz)
UnpublishFeatures: Feature: Common
MSI (s) (60:B0) [10:53:52:005]: Executing op: FeatureUnpublish(Feature=ControlCenterApp,Parent=HiddenFeatures,Absent=2,Component=jEWTi{jLk?nRs=hP-QNqRiXCPej2G=-ewf'o_,LJ)
UnpublishFeatures: Feature: ControlCenterApp
MSI (s) (60:B0) [10:53:52:021]: Executing op: FeatureUnpublish(Feature=CoreComponentsApp,Parent=HiddenFeatures,Absent=2,Component=^7]0orc,,@5hVPNw5`W=@l3Vh%Dl$?))+MWwL%~V)
UnpublishFeatures: Feature: CoreComponentsApp
MSI (s) (60:B0) [10:53:52:021]: Note: 1: 1402 2: UNKNOWN\Installer\Features\ECC9C29D0F5E521479A750093F22B547 3: 2
MSI (s) (60:B0) [10:53:52:021]: Executing op: FeatureUnpublish(Feature=MobileSyncApp,Parent=Main,Absent=2,Component=(9NDqLGd4=`_qL)^pq+*r&*wA-7Ch9X(~w85XkPk)
UnpublishFeatures: Feature: MobileSyncApp
MSI (s) (60:B0) [10:53:52:021]: Executing op: FeatureUnpublish(Feature=MovieThemePackBasicApp,Parent=HiddenFeatures,Absent=2,Component=J`}tr%=J.=Yho)b3^_Zks?'8(?.HRAP&v4uBcCU^)
UnpublishFeatures: Feature: MovieThemePackBasicApp
MSI (s) (60:B0) [10:53:52:021]: Executing op: FeatureUnpublish(Feature=UpdateApp,Parent=Main,Absent=2,Component=^a@DSYv%2A`NAK-{ws~Z'WaH[)Om[9s[N1Lm[zJG)
UnpublishFeatures: Feature: UpdateApp
MSI (s) (60:B0) [10:53:52:021]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
Action 10:53:52: RemoveODBC. Removing ODBC components
MSI (s) (60:B0) [10:53:52:021]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (60:B0) [10:53:52:021]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (60:B0) [10:53:52:021]: Executing op: ActionStart(Name=RemoveRegistryValues,Description=Removing system registry values,Template=Key: [1], Name: [2])
Action 10:53:52: RemoveRegistryValues. Removing system registry values
MSI (s) (60:B0) [10:53:52:021]: Executing op: ProgressTotal(Total=36,Type=1,ByteEquivalent=13200)
MSI (s) (60:B0) [10:53:52:021]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\,,BinaryType=0,,)
MSI (s) (60:B0) [10:53:52:021]: Executing op: RegRemoveValue(Name=NUPD,Value={6A536445-D10A-4006-8AA5-2FFCEF1A1101},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: NUPD
MSI (s) (60:B0) [10:53:52:021]: Executing op: RegRemoveValue(Name=NPMOVB,Value={403096B5-2B75-4FAE-BC57-6535C9E50B79},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: NPMOVB
MSI (s) (60:B0) [10:53:52:021]: Executing op: RegRemoveValue(Name=NL0,Value={F9C0E428-CC5A-48D4-80BB-7C13D783251B},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: NL0
MSI (s) (60:B0) [10:53:52:021]: Executing op: RegRemoveValue(Name=NL,Value={F9C0E428-CC5A-48D4-80BB-7C13D783251B},)
MSI (s) (60:B0) [10:53:52:037]: Executing op: RegRemoveValue(Name=NCC0,Value={3DEBC5B2-FD93-4492-A6B3-4F2C7943F34C},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: NCC0
MSI (s) (60:B0) [10:53:52:038]: Executing op: RegRemoveValue(Name=NCC,Value={3DEBC5B2-FD93-4492-A6B3-4F2C7943F34C},)
MSI (s) (60:B0) [10:53:52:040]: Executing op: RegRemoveValue(Name=NBDCORE,Value={E662C6C7-F7AE-455D-AF35-8FA0A484DE90},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: NBDCORE
MSI (s) (60:B0) [10:53:52:041]: Executing op: RegRemoveValue(Name=MH4DELL.MINOR,Value={DF7EBE00-B52E-4BB2-AA7D-7CB21312AB21},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: MH4DELL.MINOR
MSI (s) (60:B0) [10:53:52:042]: Executing op: RegRemoveValue(Name=MH4DELL.MAJOR,Value={DF7EBE00-B52E-4BB2-AA7D-7CB21312AB21},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: MH4DELL.MAJOR
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=MH4DELL,Value={DF7EBE00-B52E-4BB2-AA7D-7CB21312AB21},)
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=DF,Value={68734CD9-6B24-477E-8C73-70822DF403D6},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: DF
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=CHM_NCC,Value={DB1A16FB-84D6-4824-A7E5-26B7BB9B1CA7},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: CHM_NCC
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=CHM_MH4DELL.MINOR,Value={C5C7CA84-97DC-41E4-860F-D9A435E7BF7B},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: CHM_MH4DELL.MINOR
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=CHM_MH4DELL.MAJOR,Value={C5C7CA84-97DC-41E4-860F-D9A435E7BF7B},)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Packages\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}\, Name: CHM_MH4DELL.MAJOR
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=CHM_MH4DELL,Value={C5C7CA84-97DC-41E4-860F-D9A435E7BF7B},)
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Shared,,BinaryType=0,,)
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name=SendUsageStatistics,Value=[NERO.SENDUSAGESTATISTICS.EE698257_A789_474D_A546_5E5AAA5B180D],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Shared, Name: SendUsageStatistics
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(,,)
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{237CCB62-8454-43E3-B158-3ACD0134852E},,BinaryType=0,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{237CCB62-8454-43E3-B158-3ACD0134852E}, Name:
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegRemoveValue(Name={CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0},Value=[ProductName],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{237CCB62-8454-43E3-B158-3ACD0134852E}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{6DFB899F-17A2-48F0-A533-ED8D6866CF38},,BinaryType=0,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{6DFB899F-17A2-48F0-A533-ED8D6866CF38}, Name:
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{6DFB899F-17A2-48F0-A533-ED8D6866CF38}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:043]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A},,BinaryType=0,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}, Name:
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name={CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0},Value=[ProductName],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F},,BinaryType=0,,)
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}, Name:
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0},,BinaryType=0,,)
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name=ProductCode,Value=[ProductCode],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}, Name: ProductCode
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name=NERO.INSTALLER_CATEGORY,Value=#[NERO.INSTALLER_CATEGORY],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}, Name: NERO.INSTALLER_CATEGORY
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name=NERO.PRODUCT_LINE,Value=[NERO.PRODUCT_LINE],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}, Name: NERO.PRODUCT_LINE
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name=ProductName,Value=[ProductName],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}, Name: ProductName
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegRemoveValue(Name=ProductVersion,Value=[ProductVersion],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\Suites\{CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}, Name: ProductVersion
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{40F06490-8C14-43AA-99D3-EEEFDBAC3CFC},,BinaryType=0,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{40F06490-8C14-43AA-99D3-EEEFDBAC3CFC}, Name:
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{40F06490-8C14-43AA-99D3-EEEFDBAC3CFC}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:058]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7},,BinaryType=0,,)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}, Name:
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:074]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\References\{65BB0407-4CC8-4DC7-952E-3EEFDF05602A},,BinaryType=0,,)
MSI (s) (60:B0) [10:53:52:074]: Executing op: RegRemoveValue(Name={CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0},Value=[ProductName],)
RemoveRegistryValues: Key: \SOFTWARE\Nero\Nero 10\Installer\References\{65BB0407-4CC8-4DC7-952E-3EEFDF05602A}, Name: {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
MSI (s) (60:B0) [10:53:52:074]: Executing op: RegRemoveValue(,,)
MSI (s) (60:B0) [10:53:52:074]: Executing op: ActionStart(Name=RemoveFolders,Description=Removing folders,Template=Folder: [1])
Action 10:53:52: RemoveFolders. Removing folders
MSI (s) (60:B0) [10:53:52:074]: Executing op: FolderRemove(Folder=C:\ProgramData\Nero\Nero 10\OnlineServices\,Foreign=0)
RemoveFolders: Folder: C:\ProgramData\Nero\Nero 10\OnlineServices\
MSI (s) (60:B0) [10:53:52:074]: Executing op: ActionStart(Name=PublishProduct,Description=Publishing product information,)
Action 10:53:52: PublishProduct. Publishing product information
MSI (s) (60:B0) [10:53:52:074]: Executing op: CleanupConfigData()
MSI (s) (60:B0) [10:53:52:074]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=0,Remove=1)
MSI (s) (60:B0) [10:53:52:074]: Note: 1: 1402 2: UNKNOWN\Installer\Products\ECC9C29D0F5E521479A750093F22B547\Patches 3: 2
MSI (s) (60:B0) [10:53:52:074]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=1,Remove=1)
MSI (s) (60:B0) [10:53:52:074]: Executing op: CleanupConfigData(RemovingProduct=1)
MSI (s) (60:B0) [10:53:52:074]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\ECC9C29D0F5E521479A750093F22B547\Patches 3: 2
MSI (s) (60:B0) [10:53:52:074]: Executing op: ActionStart(Name=Nero_CA_DeleteGlobalFileAssociationDbCommit,,)
Action 10:53:52: Nero_CA_DeleteGlobalFileAssociationDbCommit.
MSI (s) (60:B0) [10:53:52:090]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteGlobalFileAssociationDbCommit,ActionType=1537,Source=BinaryData,Target=CA_DeleteGlobalFileAssociationDb,CustomActionData=Nero 10)
MSI (s) (60:B0) [10:53:52:090]: Executing op: ActionStart(Name=InstallFinalize,,)
Action 10:53:52: InstallFinalize.
MSI (s) (60:B0) [10:53:52:090]: Executing op: CleanupTempFiles(TempFiles=C:\WINDOWS\Installer\33a1c1a3.mst)
MSI (s) (60:B0) [10:53:52:090]: Scheduling file 'C:\WINDOWS\Installer\33a1c1a3.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:B0) [10:53:52:090]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=979200)
MSI (s) (60:B0) [10:53:52:105]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:B0) [10:53:52:105]: User policy value 'DisableRollback' is 0
MSI (s) (60:B0) [10:53:52:105]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:B0) [10:53:52:105]: Unlocking Server
MSI (s) (60:B0) [10:53:52:105]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
MSI (s) (60:B0) [10:53:52:105]: Creating MSIHANDLE (1618) of type 790535 for thread 8112
Action ended 10:53:52: InstallFinalize. Return value 1.
MSI (s) (60:B0) [10:53:52:105]: Skipping action: CANOSUS_InstallCommit.EE698257_A789_474D_A546_5E5AAA5B180D (condition is false)
MSI (s) (60:B0) [10:53:52:105]: Skipping action: LiLiW_RemoveFiles.EDA67544_39E0_4D88_B650_464D261A4F87 (condition is false)
Action ended 10:53:52: INSTALL. Return value 1.
Nissi1
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {CAE5C0DF-E6CE-471B-8D68-66A76FCF1EC0}
Property(S): ProductCode = {D92C9CCE-E5F0-4125-977A-0590F3225B74}
Property(S): Installed = 2011/08/29 09:20:22
Property(S): IS_CHAINER_POST_COMMANDLINE = /l"C:\Users\ZANDRA~1\AppData\Local\Temp\MSI1b9f9.LOG" /qb /x{523B2B1B-D8DB-4B41-90FF-C4D799E2758A};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{237CCB62-8454-43E3-B158-3ACD0134852E};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\"" /qb /x{6DFB899F-17A2-48F0-A533-ED8D6866CF38};"NERO.IS_CHAINED=\"YES\" REBOOT=\"ReallySuppress\" MSIRESTARTMANAGERCONTROL=\"Disable\""
Property(S): Nero.RefCnt_Dummy.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): Nero.RefCnt_AllOtherFiles3.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): Nero.RefCnt_AllOtherFiles2.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): Nero.RefCnt_AllOtherFiles1.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): Nero.RefCnt_AllOtherFiles.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): Nero.RefCnt_RegNeroLanguage.F41DFC5A_891C_48E4_A24B_33C93A9B7A1B = 2
Property(S): Nero.RefCnt_Update = 1
Property(S): Nero.RefCnt_Ref_Update = 1
Property(S): Nero.RefCnt_Ref_MovieThemePackBasic = 1
Property(S): Nero.RefCnt_MovieThemePackBasic = 1
Property(S): Nero.RefCnt_Ref_MobileSync = 1
Property(S): Nero.RefCnt_MobileSync = 1
Property(S): Nero.RefCnt_Ref_CoreComponents = 1
Property(S): Nero.RefCnt_CoreComponents = 1
Property(S): Nero.RefCnt_Ref_ControlCenter = 1
Property(S): Nero.RefCnt_ControlCenter = 1
Property(S): Nero.RefCnt_InstallReg = 1
Property(S): Nero.RefCnt_Ref_BDCore = 1
Property(S): Nero.RefCnt_BDCore = 1
Property(S): Nero.RefCnt_Ref_MobileSyncHelpChm = 0
Property(S): Nero.RefCnt_Ref_ControlCenterHelpChm = 1
Property(S): Nero.RefCnt_MobileSyncHelpChm = 0
Property(S): Nero.RefCnt_ControlCenterHelpChm = 1
Property(S): Nero.RefCnt___InstallReg65 = 0
Property(S): Nero.RefCnt___BDCore65 = 0
Property(S): Nero.RefCnt___ControlCenter65 = 0
Property(S): Nero.RefCnt___ControlCenterHelpChm65 = 0
Property(S): Nero.RefCnt___CoreComponents65 = 0
Property(S): Nero.RefCnt___MobileSync65 = 0
Property(S): Nero.RefCnt___MobileSyncHelpChm65 = 0
Property(S): Nero.RefCnt___MovieThemePackBasic65 = 0
Property(S): Nero.RefCnt___Ref_BDCore65 = 0
Property(S): Nero.RefCnt___Ref_ControlCenter65 = 0
Property(S): Nero.RefCnt___Ref_ControlCenterHelpChm65 = 0
Property(S): Nero.RefCnt___Ref_CoreComponents65 = 0
Property(S): Nero.RefCnt___Ref_MobileSync65 = 0
Property(S): Nero.RefCnt___Ref_MobileSyncHelpChm65 = 0
Property(S): Nero.RefCnt___Ref_MovieThemePackBasic65 = 0
Property(S): Nero.RefCnt___Ref_Update65 = 0
Property(S): Nero.RefCnt___Update65 = 0
Property(S): Nero.RefCnt___RegNeroLanguage.F41DFC5A_891C_48E4_A24B_33C93A9B7A1B65 = 0
Property(S): Nero.RefCnt___Dummy.EE698257_A789_474D_A546_5E5AAA5B180D65 = 0
Property(S): Nero.Package_NPMOVB = 10.2.10200.0.0
Property(S): Nero.Package_NL0 = 2.0.20000.9.12
Property(S): Nero.Package_NL = 2.0.20000.9.12
Property(S): Nero.Package_NCC0 = 10.6.12500.0.5
Property(S): Nero.Package_NCC = 10.6.12500.0.5
Property(S): Nero.Package_NBDCORE = 7.3.10000.0.0
Property(S): Nero.Package_CHM_NCC = 10.2.10800
Property(S): Nero.ProductCode_NUPD = {65BB0407-4CC8-4DC7-952E-3EEFDF05602A}
Property(S): Nero.ProductCode_NPMOVB = {F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}
Property(S): Nero.ProductCode_NL0 = {2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}
Property(S): Nero.ProductCode_NL = {2436F2A8-4B7E-4B6C-AE4E-604C84AA6A4F}
Property(S): Nero.ProductCode_NCC0 = {6DFB899F-17A2-48F0-A533-ED8D6866CF38}
Property(S): Nero.ProductCode_NCC = {6DFB899F-17A2-48F0-A533-ED8D6866CF38}
Property(S): Nero.ProductCode_NBDCORE = {237CCB62-8454-43E3-B158-3ACD0134852E}
Property(S): Nero.ProductCode_MH4DELL.MINOR = {40F06490-8C14-43AA-99D3-EEEFDBAC3CFC}
Property(S): Nero.ProductCode_MH4DELL.MAJOR = {40F06490-8C14-43AA-99D3-EEEFDBAC3CFC}
Property(S): Nero.ProductCode_MH4DELL = {40F06490-8C14-43AA-99D3-EEEFDBAC3CFC}
Property(S): Nero.ProductCode_DF = {C3580AC4-C827-4332-B935-9A282ED5BB97}
Property(S): Nero.ProductCode_CHM_NCC = {523B2B1B-D8DB-4B41-90FF-C4D799E2758A}
Property(S): Nero.ProductCode_CHM_MH4DELL.MINOR = {9084C3D8-90BD-40C8-8252-30D0C41FD449}
Property(S): Nero.ProductCode_CHM_MH4DELL.MAJOR = {9084C3D8-90BD-40C8-8252-30D0C41FD449}
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): Preselected = 1
Property(S): UILevel = 5
Property(S): OriginalDatabase = C:\Windows\Installer\11a49.msi
Property(S): DATABASE = C:\Windows\Installer\11a49.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.3.14393.0
Property(S): MsiNetAssemblySupport = 4.6.1586.0
Property(S): Date = 6/11/2017
Property(S): Time = 10:53:52
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 23
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 1033
Property(S): ComputerName = ZANDRAJONES-PC
Property(S): UserLanguageID = 1033
Property(S): UserSID = S-1-5-21-3088507388-2561779440-336279174-1001
Property(S): LogonUser = Zandra Jones
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 5094
Property(S): PhysicalMemory = 3839
Property(S): Intel = 16
Property(S): Msix64 = 16
Property(S): MsiAMD64 = 16
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): FontsFolder = C:\WINDOWS\Fonts\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): MyPicturesFolder = C:\Users\Zandra Jones\Pictures\
Property(S): LocalAppDataFolder = C:\Users\Zandra Jones\AppData\Local\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): SendToFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): VersionNT = 603
Property(S): Nero_CA_DeleteGlobalFileAssociationDbCommit = Nero 10
Property(S): Nero_CA_DeleteGlobalFileAssociationDbRollback = Nero 10
Property(S): NERO = C:\Program Files (x86)\Nero\
Property(S): RecentFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): TARGETDIR = C:\
Property(S): ALLUSERSPROFILE = C:\ProgramData\
Property(S): PrintHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): PersonalFolder = C:\Users\Zandra Jones\Documents\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): NetHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Nero\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Nero\Database\
Property(S): FavoritesFolder = C:\Users\Zandra Jones\Favorites\
Property(S): AppDataFolder = C:\Users\Zandra Jones\AppData\Roaming\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): INSTALLDIR = C:\Program Files (x86)\Nero\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): TempFolder = C:\Users\ZANDRA~1\AppData\Local\Temp\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): RemoteAdminTS = 1
Property(S): SystemFolder = C:\WINDOWS\SysWOW64\
Property(S): System64Folder = C:\WINDOWS\system32\
Property(S): WindowsVolume = C:\
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 9600
Property(S): VersionNT64 = 603
Property(S): VersionMsi = 5.00
Property(S): VersionDatabase = 405
Property(S): MsiSystemRebootPending = 1
Property(S): Nero.ProductCode_CHM_MH4DELL = {9084C3D8-90BD-40C8-8252-30D0C41FD449}
Property(S): REMOVE = ALL
Property(S): CURRENTDIRECTORY = C:\Program Files\VS Revo Group\Revo Uninstaller
Property(S): USERPROFILE = C:\Users\Zandra Jones\
Property(S): WindowsFolder = C:\WINDOWS\
Property(S): CLIENTUILEVEL = 0
Property(S): LiLiW_RemoveKey.EDA67544_39E0_4D88_B650_464D261A4F87 = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?
Property(S): LiLiW_CommitKey.EDA67544_39E0_4D88_B650_464D261A4F87 = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?
Property(S): LiLiW_AcceptEula.EDA67544_39E0_4D88_B650_464D261A4F87 = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?
Property(S): NERO.userAcknowledgedEula = NO
Property(S): NewProperty3.EDA67544_39E0_4D88_B650_464D261A4F87 = 0
Property(S): ISVROOT_PORT_NO.EDA67544_39E0_4D88_B650_464D261A4F87 = 0
Property(S): IS_PRINT_DIALOG = LicenseAgreement.EDA67544_39E0_4D88_B650_464D261A4F87
Property(S): IS_SQLSERVER_AUTHENTICATION.EDA67544_39E0_4D88_B650_464D261A4F87 = 0
Property(S): IS_SQLSERVER_USERNAME.EDA67544_39E0_4D88_B650_464D261A4F87 = sa
Property(S): NERO.ADVRCNTR_FILENAME = AdvrCntr5.dll
Property(S): NERO.ERROR_CODE = 0
Property(S): NERO.IS_KEY_NEW = YES
Property(S): NERO.IS_KEY_VALID = NO
Property(S): NERO.LicenseLim_EnableUsageStatistics = YES
Property(S): NERO.licenseModuleIncluded.D39B4B65_3692_4292_833F_2C81D15845EB = YES
Property(S): NewProperty1.EDA67544_39E0_4D88_B650_464D261A4F87 = 0
Property(S): NewProperty2.EDA67544_39E0_4D88_B650_464D261A4F87 = 0
Property(S): SecureCustomProperties.EDA67544_39E0_4D88_B650_464D261A4F87 = NERO.IS_EULA_ACCEPTED;NERO.USER_KEY
Property(S): SetupType.EDA67544_39E0_4D88_B650_464D261A4F87 = Typical
Property(S): ARPURLINFOABOUT = http://www.nero.com/
Property(S): CLIENTPROCESSID = 496
Property(S): PRODUCTLANGUAGE = 0
Property(S): NERO.USER_KEY = 4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44
Property(S): SetupType = Typical
Property(S): NERO.IS_EULA_ACCEPTED = NO
Property(S): INSTALLDIR.F41DFC5A_891C_48E4_A24B_33C93A9B7A1B = C:\
Property(S): NERO_10.EE698257_A789_474D_A546_5E5AAA5B180D = C:\ProgramData\Nero\Nero 10\
Property(S): NERO1.EE698257_A789_474D_A546_5E5AAA5B180D = C:\ProgramData\Nero\
Property(S): ONLINESERVICES.EE698257_A789_474D_A546_5E5AAA5B180D = C:\ProgramData\Nero\Nero 10\OnlineServices\
Property(S): NERO.SENDUSAGESTATISTICS.EE698257_A789_474D_A546_5E5AAA5B180D = ?
Property(S): Nero.UsageStatsIncluded.EE698257_A789_474D_A546_5E5AAA5B180D = 1
Property(S): SecureCustomProperties.EE698257_A789_474D_A546_5E5AAA5B180D = NERO.SENDUSAGESTATISTICS.EE698257_A789_474D_A546_5E5AAA5B180D;NERO.SENDUSAGESTATISTICS.EE698257_A789_474D_A546_5E5AAA5B180D
Property(S): USERNAME = AutoBVT
Property(S): COMPANYNAME = Microsoft
Property(S): ACTION = INSTALL
Property(S): EXECUTEACTION = INSTALL
Property(S): ROOTDRIVE = C:\
Property(S): SUPPORTDIR = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\
Property(S): NERO.ADVRCNTR_PATH = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll
Property(S): SECONDSEQUENCE = 1
Property(S): NERO.ACTION_DATA = C:\Users\ZANDRA~1\AppData\Local\Temp\D39B4B65_3692_4292_833F_2C81D15845EB__2.0.7.6\AdvrCntr5.dll?10?4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44?NO????en-US?
Property(S): ProductState = 5
Property(S): TRANSFORMS = C:\Windows\Installer\{D92C9CCE-E5F0-4125-977A-0590F3225B74}\1033.mst
Property(S): PackageCode = {D5723832-302A-4BB1-BE36-434859360ADB}
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): NERO.INSTALL_DESKTOPSHORTCUT = 1
Property(S): _IsMaintenance = Change
Property(S): RestartManagerOption = CloseRestart
Property(S): _IsSetupTypeMin = Typical
Property(S): Display_IsBitmapDlg = 1
Property(S): REBOOT = ReallySuppress
Property(S): ALLUSERS = 1
Property(S): ARPNOREPAIR = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DWUSINTERVAL = 30
Property(S): DWUSLINK = CEFBD0FFA9DCB0D8FEAC5098AEBB978FEEAC878FFEEBA7A8CECB77AFDE6C40C8C98CA0BFE9AC
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): ErrorDialog = SetupError
Property(S): INSTALLLEVEL = 100
Property(S): ISVROOT_PORT_NO = 0
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PREVENT_DOWNGRADE_EXIT = A newer version of this application is already installed on this computer. If you wish to install this version, please uninstall the newer version first. Click OK to exit the wizard.
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): InstallChoice = AR
Property(S): MSIDISABLERMRESTART = 0
Property(S): MSIRMSHUTDOWN = 2
Property(S): Manufacturer = Nero AG
Property(S): NERO.CDNUMBER = 20110829132945703
Property(S): NERO.INSTALLER_CATEGORY = 10
Property(S): NERO.INSTALL_AUTOPLAY = 1
Property(S): NERO.LANGUAGES_INSTALL = zh-TW,cs-CZ,da-DK,de-DE,el-GR,en-US,es-ES,fi-FI,fr-FR,hu-HU,it-IT,ja-JP,ko-KR,nl-NL,nb-NO,pl-PL,pt-BR,pt-PT,ru-RU,sv-SE,th-TH,tr-TR,zh-CN
Property(S): NERO.LANGUAGE_CURRENT = en-US
Property(S): NERO.PRODUCT_LINE = NeroX
Property(S): Nero.GenerationName = Nero 10
Property(S): Nero.IsPathOk = YES
Property(S): Nero.TemplateRev = 183431
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = SyncUP
Property(S): ProductVersion = 10.2.15400
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): SecureCustomProperties = INSTALLDIR;ISFOUNDNEWERPRODUCTVERSION;IS_MINOR_UPGRADE;ARPNOREPAIR;NERO.INSTALL_DESKTOPSHORTCUT;NERO.INCLUDED_KEY;NERO.INSTALL_AUTOPLAY;NERO.INSTALL_EXTENSIONS;NERO.INSTALLER_CATEGORY;NERO.IS_EULA_ACCEPTED;NERO.LANGUAGE_CURRENT;NERO.PRODUCT_LINE;REBOOT;REINSTALL;REINSTALLMODE;SUPPORTDIR;TRANSFORMS;ISFOUND.DELL.MOBILESYNC
Property(S): ISReleaseFlags = BDCore,controlcenter,MobileSync,moviethemebase,BDCorehelpchm,controlcenterhelpchm,MobileSynchelpchm,moviethemebasehelpchm,Common,HelpChm,MobileSync,BDCore
Property(S): SETUPEXENAME = setup.exe
Property(S): MsiLogFileLocation = C:\Users\ZANDRA~1\AppData\Local\Temp\MSI1b9f9.LOG
Property(S): ARPINSTALLLOCATION = C:\Program Files (x86)\Nero\
Property(S): NERO.INCLUDED_KEY = 4X25-8095-M521-MUAX-XM9P-1T0A-0TPL-3U44
MSI (s) (60:B0) [10:53:52:206]: Closing MSIHANDLE (1175) of type 790542 for thread 8112
MSI (s) (60:B0) [10:53:52:206]: Attempting to delete file C:\WINDOWS\Installer\33a1c1a3.mst
MSI (s) (60:B0) [10:53:52:243]: Attempting to delete file C:\WINDOWS\Installer\33a1c1a3.mst
MSI (s) (60:B0) [10:53:52:243]: Unable to delete the file outside of the engine. LastError = 2
MSI (s) (60:B0) [10:53:52:243]: MainEngineThread is returning 0
MSI (s) (60:D8) [10:53:52:243]: RESTART MANAGER: Session closed.
=== Verbose logging started: 6/11/2017  10:53:52  Build type: SHIP UNICODE 5.00.10011.00  Calling process: C:\Users\ZANDRA~1\AppData\Local\Temp\MSIE858.tmp ===
MSI (c) (18:98) [10:53:52:604]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (18:F4) [10:53:52:626]: Resetting cached policy values
MSI (c) (18:F4) [10:53:52:626]: Machine policy value 'Debug' is 0
MSI (c) (18:F4) [10:53:52:626]: ******* RunEngine:
Nissi1
******* Product: C:\Windows\Installer\11a7e.msi
           ******* Action:
           ******* CommandLine: **********
MSI (c) (18:F4) [10:53:52:626]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (18:F4) [10:53:55:638]: Failed to grab execution mutex. System error 258.
MSI (c) (18:F4) [10:53:55:654]: Cloaking enabled.
MSI (c) (18:F4) [10:53:55:654]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (18:F4) [10:53:55:654]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (60:9C) [10:53:55:654]: Running installation inside multi-package transaction C:\Windows\Installer\11a49.msi
MSI (s) (60:9C) [10:53:55:654]: Grabbed execution mutex.
MSI (s) (60:30) [10:53:55:654]: Resetting cached policy values
MSI (s) (60:30) [10:53:55:654]: Machine policy value 'Debug' is 0
MSI (s) (60:30) [10:53:55:654]: ******* RunEngine:
           ******* Action:
MSI (s) (60:30) [10:53:55:670]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (60:30) [10:53:55:701]: MSCOREE not loaded loading copy from system32
MSI (s) (60:30) [10:53:55:722]: End dialog not enabled
MSI (s) (60:30) [10:53:55:722]: Original package ==> C:\Windows\Installer\11a7e.msi
MSI (s) (60:30) [10:53:55:722]: Package we're running from ==> C:\Windows\Installer\11a7e.msi
MSI (s) (60:30) [10:53:55:754]: APPCOMPAT: Uninstall Flags override found.
MSI (s) (60:30) [10:53:55:754]: APPCOMPAT: Uninstall VersionNT override found.
MSI (s) (60:30) [10:53:55:754]: APPCOMPAT: Uninstall ServicePackLevel override found.
MSI (s) (60:30) [10:53:55:754]: APPCOMPAT: looking for appcompat database entry with ProductCode '{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}'.
MSI (s) (60:30) [10:53:55:754]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (60:30) [10:53:55:770]: Machine policy value 'DisablePatch' is 0
MSI (s) (60:30) [10:53:55:770]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (60:30) [10:53:55:770]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (60:30) [10:53:55:770]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (60:30) [10:53:55:770]: Looking for file transform: C:\Windows\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst
MSI (s) (60:30) [10:53:55:786]: File will have security applied from OpCode.
MSI (s) (60:30) [10:53:55:801]: Original transform ==> C:\Windows\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst
MSI (s) (60:30) [10:53:55:801]: Transform we're running from ==> C:\WINDOWS\Installer\33a1c1a5.mst
MSI (s) (60:30) [10:53:55:801]: SOFTWARE RESTRICTION POLICY: Verifying transform --> 'C:\Windows\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst' against software restriction policy
MSI (s) (60:30) [10:53:55:801]: SOFTWARE RESTRICTION POLICY: C:\Windows\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst has a digital signature
MSI (s) (60:30) [10:53:55:823]: SOFTWARE RESTRICTION POLICY: C:\Windows\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst is permitted to run at the 'unrestricted' authorization level.
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: _Tables 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: _Columns 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Media 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: File 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: TRANSFORM: 'PatchPackage' table is missing or empty.  No pre-transform fixup necessary.
MSI (s) (60:30) [10:53:55:823]: TRANSFORM: Applying regular transform to database.
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: ActionText 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: AdminExecuteSequence 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: AdminUISequence 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: AdvtExecuteSequence 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: AdvtUISequence 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: AppSearch 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Feature 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Binary 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: CheckBox 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Component 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Icon 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: ComboBox 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Directory 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Control 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Dialog 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: ControlCondition 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: ControlEvent 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: CustomAction 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: ModuleSignature 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Error 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: EventMapping 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: FeatureComponents 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: InstallExecuteSequence 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: InstallUISequence 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: LaunchCondition 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: ListBox 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: ListView 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: ModuleComponents 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: MsiFileHash 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: RadioButton 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Registry 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: RegLocator 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: RemoveFile 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Shortcut 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: TextStyle 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: UIText 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: Upgrade 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: _Validation 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: ISComponentExtended 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: ISCustomActionReference 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: _MsiPatchTransformView 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: #_BaselineCost 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: #_BaselineFile 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: #_BaselineData 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: #_PatchCache 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: MsiPatchCertificate 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: MsiDigitalCertificate 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: APPCOMPAT: looking for appcompat database entry with ProductCode '{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}'.
MSI (s) (60:30) [10:53:55:823]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (60:30) [10:53:55:823]: Transforms are not secure.
MSI (s) (60:30) [10:53:55:823]: Transforming table Property.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\ZANDRA~1\AppData\Local\Temp\MSI1b9f9.LOG'.
MSI (s) (60:30) [10:53:55:823]: Command Line: NERO.IS_CHAINED=YES REBOOT=ReallySuppress MSIRESTARTMANAGERCONTROL=Disable ISCHAINER=1 REMOVE=ALL CURRENTDIRECTORY=C:\WINDOWS\system32 CLIENTUILEVEL=2 CLIENTPROCESSID=8728
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{1A7F010E-8947-468D-A021-92CE03780E30}'.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding TRANSFORMS property. Its value is 'C:\Windows\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst'.
MSI (s) (60:30) [10:53:55:823]: Product Code passed to Engine.Initialize:           '{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}'
MSI (s) (60:30) [10:53:55:823]: Product Code from property table before transforms: '{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}'
MSI (s) (60:30) [10:53:55:823]: Product Code from property table after transforms:  '{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}'
MSI (s) (60:30) [10:53:55:823]: Product registered: entering maintenance mode
MSI (s) (60:30) [10:53:55:823]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI (s) (60:30) [10:53:55:823]: Product {523B2B1B-D8DB-4B41-90FF-C4D799E2758A} is admin assigned: LocalSystem owns the publish key.
MSI (s) (60:30) [10:53:55:823]: Product {523B2B1B-D8DB-4B41-90FF-C4D799E2758A} is managed.
MSI (s) (60:30) [10:53:55:823]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding ProductState property. Its value is '5'.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI (s) (60:30) [10:53:55:823]: Package name retrieved from configuration data: 'Nero.ControlCenterHelpChm.msi'
MSI (s) (60:30) [10:53:55:823]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (60:30) [10:53:55:823]: Machine policy value 'DisableMsi' is 0
MSI (s) (60:30) [10:53:55:823]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:30) [10:53:55:823]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:30) [10:53:55:823]: Running product '{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}' with elevated privileges: Product is assigned.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding NERO.IS_CHAINED property. Its value is 'YES'.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding REBOOT property. Its value is 'ReallySuppress'.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding MSIRESTARTMANAGERCONTROL property. Its value is 'Disable'.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding ISCHAINER property. Its value is '1'.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding REMOVE property. Its value is 'ALL'.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\WINDOWS\system32'.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '2'.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '8728'.
MSI (s) (60:30) [10:53:55:823]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (60:30) [10:53:55:823]: RESTART MANAGER: Disabled by MSIRESTARTMANAGERCONTROL property; Windows Installer will use the built-in FilesInUse functionality.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (s) (60:30) [10:53:55:823]: TRANSFORMS property is now: C:\Windows\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '0'.
MSI (s) (60:30) [10:53:55:823]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (60:30) [10:53:55:823]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming
MSI (s) (60:30) [10:53:55:839]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Favorites
MSI (s) (60:30) [10:53:55:839]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (60:30) [10:53:55:839]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Documents
MSI (s) (60:30) [10:53:55:839]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (60:30) [10:53:55:839]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (60:30) [10:53:55:839]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (60:30) [10:53:55:855]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (60:30) [10:53:55:855]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (60:30) [10:53:55:855]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Local
MSI (s) (60:30) [10:53:55:855]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Pictures
MSI (s) (60:30) [10:53:55:855]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (60:30) [10:53:55:855]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (60:30) [10:53:55:870]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu
MSI (s) (60:30) [10:53:55:870]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (60:30) [10:53:55:870]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (60:30) [10:53:55:870]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (60:30) [10:53:55:886]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
MSI (s) (60:30) [10:53:55:886]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Desktop
MSI (s) (60:30) [10:53:55:886]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (s) (60:30) [10:53:55:886]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (s) (60:30) [10:53:55:886]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (60:30) [10:53:55:901]: MSI_LUA: Setting AdminUser property to 1 because the product is already installed managed and per-machine
MSI (s) (60:30) [10:53:55:901]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (60:30) [10:53:55:901]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (s) (60:30) [10:53:55:901]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (60:30) [10:53:55:901]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'AutoBVT'.
MSI (s) (60:30) [10:53:55:901]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Microsoft'.
MSI (s) (60:30) [10:53:55:901]: PROPERTY CHANGE: Adding Installed property. Its value is '2011/03/04 11:06:00'.
MSI (s) (60:30) [10:53:55:901]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\11a7e.msi'.
MSI (s) (60:30) [10:53:55:901]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Windows\Installer\11a7e.msi'.
MSI (s) (60:30) [10:53:55:901]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (s) (60:30) [10:53:55:901]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:30) [10:53:55:901]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:30) [10:53:55:901]: User policy value 'DisableRollback' is 0
MSI (s) (60:30) [10:53:55:901]: PROPERTY CHANGE: Adding UILevel property. Its value is '3'.
=== Logging started: 6/11/2017  10:53:55 ===
MSI (s) (60:30) [10:53:55:901]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:30) [10:53:55:920]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
MSI (s) (60:30) [10:53:55:924]: APPCOMPAT: [DetectVersionLaunchCondition] Launch condition already passes.
MSI (s) (60:30) [10:53:55:924]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (60:30) [10:53:55:924]: Doing action: INSTALL
Action start 10:53:55: INSTALL.
MSI (s) (60:30) [10:53:55:924]: Running ExecuteSequence
MSI (s) (60:30) [10:53:55:924]: Skipping action: ISSetAllUsers (condition is false)
MSI (s) (60:30) [10:53:55:924]: Doing action: AppSearch
Action start 10:53:55: AppSearch.
MSI (s) (60:30) [10:53:55:924]: PROPERTY CHANGE: Modifying BROWSERPATH property. Its current value is 'c:\program files\internet explorer\iexplore.exe'. Its new value: 'C:\Program Files (x86)\Mozilla Firefox\firefox.exe'.
MSI (s) (60:30) [10:53:55:924]: Skipping action: LaunchConditions (condition is false)
MSI (s) (60:30) [10:53:55:924]: Doing action: FindRelatedProducts
Action ended 10:53:55: AppSearch. Return value 1.
MSI (s) (60:30) [10:53:55:924]: Skipping FindRelatedProducts action: not run in maintenance mode
Action start 10:53:55: FindRelatedProducts.
MSI (s) (60:30) [10:53:55:924]: Skipping action: ISPreventDowngrade (condition is false)
MSI (s) (60:30) [10:53:55:924]: Skipping action: CCPSearch (condition is false)
MSI (s) (60:30) [10:53:55:924]: Skipping action: RMCCPSearch (condition is false)
MSI (s) (60:30) [10:53:55:924]: Doing action: ValidateProductID
Action ended 10:53:55: FindRelatedProducts. Return value 0.
Action start 10:53:55: ValidateProductID.
MSI (s) (60:30) [10:53:55:924]: Skipping action: Nero_CA_SetExtensions (condition is false)
MSI (s) (60:30) [10:53:55:924]: Skipping action: Nero_CA_SetDesktopShortcuts (condition is false)
MSI (s) (60:30) [10:53:55:924]: Skipping action: Nero_CA_SetAutoplay (condition is false)
MSI (s) (60:30) [10:53:55:924]: Skipping action: Nero_CA_SetUserProperties (condition is false)
MSI (s) (60:30) [10:53:55:924]: Doing action: Nero_CAD_DeleteLocalFileAssociationDb
Action ended 10:53:55: ValidateProductID. Return value 1.
MSI (s) (60:30) [10:53:55:924]: PROPERTY CHANGE: Adding Nero_CA_DeleteLocalFileAssociationDb property. Its value is '{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}'.
Action start 10:53:55: Nero_CAD_DeleteLocalFileAssociationDb.
MSI (s) (60:30) [10:53:55:924]: Doing action: Nero_CA_GenerateFileAssociationList
Action ended 10:53:55: Nero_CAD_DeleteLocalFileAssociationDb. Return value 1.
MSI (s) (60:64) [10:53:55:939]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIF66C.tmp, Entrypoint: CA_GenerateFileAssociationList
Action start 10:53:55: Nero_CA_GenerateFileAssociationList.
MSI (s) (60:30) [10:53:56:040]: Doing action: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore
Action ended 10:53:56: Nero_CA_GenerateFileAssociationList. Return value 1.
MSI (s) (60:30) [10:53:56:040]: PROPERTY CHANGE: Adding Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore property. Its value is '{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}'.
Action start 10:53:56: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore.
MSI (s) (60:30) [10:53:56:040]: Doing action: Nero_CAD_DeleteAssociationsBackup
Action ended 10:53:56: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore. Return value 1.
MSI (s) (60:30) [10:53:56:040]: PROPERTY CHANGE: Adding Nero_CA_DeleteAssociationsBackup property. Its value is '{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}|'.
Action start 10:53:56: Nero_CAD_DeleteAssociationsBackup.
MSI (s) (60:30) [10:53:56:040]: Doing action: Nero_CAD_Install_SetAssociations
Action ended 10:53:56: Nero_CAD_DeleteAssociationsBackup. Return value 1.
Action start 10:53:56: Nero_CAD_Install_SetAssociations.
MSI (s) (60:30) [10:53:56:040]: Doing action: Nero_CAD_Install_SetAssociationsRollback
Action ended 10:53:56: Nero_CAD_Install_SetAssociations. Return value 1.
Action start 10:53:56: Nero_CAD_Install_SetAssociationsRollback.
MSI (s) (60:30) [10:53:56:040]: Doing action: Nero_CAD_Uninstall_SetAssociations
Action ended 10:53:56: Nero_CAD_Install_SetAssociationsRollback. Return value 1.
Action start 10:53:56: Nero_CAD_Uninstall_SetAssociations.
MSI (s) (60:30) [10:53:56:040]: Doing action: Nero_CAD_Uninstall_SetAssociationsRollback
Action ended 10:53:56: Nero_CAD_Uninstall_SetAssociations. Return value 1.
Action start 10:53:56: Nero_CAD_Uninstall_SetAssociationsRollback.
MSI (s) (60:30) [10:53:56:040]: Doing action: CostInitialize
Action ended 10:53:56: Nero_CAD_Uninstall_SetAssociationsRollback. Return value 1.
MSI (s) (60:30) [10:53:56:055]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI (s) (60:30) [10:53:56:055]: Note: 1: 1324 2: Nero Help 3: 1
MSI (s) (60:30) [10:53:56:055]: Note: 1: 1324 2: Nero ControlCenter 3: 1
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (60:30) [10:53:56:055]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (60:30) [10:53:56:055]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:30) [10:53:56:055]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (60:30) [10:53:56:055]: Note: 1: 2205 2:  3: __MsiPatchFileList
MSI (s) (60:30) [10:53:56:055]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
Action start 10:53:56: CostInitialize.
MSI (s) (60:30) [10:53:56:055]: Skipping action: ResolveSource (condition is false)
MSI (s) (60:30) [10:53:56:055]: Doing action: FileCost
Action ended 10:53:56: CostInitialize. Return value 1.
MSI (s) (60:30) [10:53:56:055]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:30) [10:53:56:055]: Note: 1: 2205 2:  3: Class
MSI (s) (60:30) [10:53:56:055]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:30) [10:53:56:055]: Note: 1: 2205 2:  3: TypeLib
Action start 10:53:56: FileCost.
MSI (s) (60:30) [10:53:56:055]: Doing action: IsolateComponents
Action ended 10:53:56: FileCost. Return value 1.
Action start 10:53:56: IsolateComponents.
MSI (s) (60:30) [10:53:56:055]: Doing action: setUserProfileNT
Action ended 10:53:56: IsolateComponents. Return value 0.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Zandra Jones'.
Action start 10:53:56: setUserProfileNT.
MSI (s) (60:30) [10:53:56:055]: Skipping action: SetAllUsersProfileNT (condition is false)
MSI (s) (60:30) [10:53:56:055]: Doing action: setAllUsersProfile2K
Action ended 10:53:56: setUserProfileNT. Return value 1.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
Action start 10:53:56: setAllUsersProfile2K.
MSI (s) (60:30) [10:53:56:055]: Doing action: CostFinalize
Action ended 10:53:56: setAllUsersProfile2K. Return value 1.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (60:30) [10:53:56:055]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding NERO_CONTROLCENTER_HELP_CHM property. Its value is 'C:\Program Files (x86)\Nero\Help'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding COMP_INSTALL_DIR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding CS_CZ.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\cs-CZ'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding DA_DK.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\da-DK'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding DE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\de'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding DE_DE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\de-DE'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding EL_GR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\el-GR'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding EN_GB.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\en-GB'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding EN_US.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\en-US'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding ES.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\es'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding ES_ES.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\es-ES'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding FI_FI.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\fi-FI'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding FR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\fr'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding FR_FR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\fr-FR'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding HU_HU.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\hu-HU'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding IT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\it'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding IT_IT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\it-IT'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding JA_JP.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\ja-JP'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding KO_KR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\ko-KR'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding NB_NO.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\nb-NO'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding NL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\nl'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding NL_NL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\nl-NL'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding PL_PL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\pl-PL'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding PT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\pt'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding PT_BR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\pt-BR'.
MSI (s) (60:30) [10:53:56:055]: PROPERTY CHANGE: Adding PT_PT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\pt-PT'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding RU_RU.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\ru-RU'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding SV_SE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\sv-SE'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding TH_TH.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\th-TH'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding TR_TR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\tr-TR'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ZH.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\zh'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ZH_CN.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\zh-CN'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ZH_HK.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\zh-HK'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ZH_TW.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its value is 'C:\Program Files (x86)\Nero\Help\zh-TW'.
MSI (s) (60:30) [10:53:56:071]: Note: 1: 2205 2:  3: Condition
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Zandra Jones'. Its new value: 'C:\Users\Zandra Jones\'.
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: 'C:\WINDOWS\SysWOW64\' will substitute 20 characters in 'C:\WINDOWS\system32\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 1).
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying System64Folder property. Its current value is 'C:\WINDOWS\system32\'. Its new value: 'C:\WINDOWS\SysWOW64\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding System16Folder property. Its value is 'C:\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ScNeroFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ScProductFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ScManualsFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ScControlCenterManualsFolder property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\'.
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: 'C:\Program Files (x86)\' will substitute 17 characters in 'C:\Program Files\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying ProgramFiles64Folder property. Its current value is 'C:\Program Files\'. Its new value: 'C:\Program Files (x86)\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding GlobalAssemblyCache property. Its value is 'C:\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ISMyCompanyDir property. Its value is 'C:\Program Files (x86)\My Company Name\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ISMyProductDir property. Its value is 'C:\Program Files (x86)\My Company Name\My Product Name\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding NERO property. Its value is 'C:\Program Files (x86)\Nero\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding NERO_PRODUCT property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying NERO_CONTROLCENTER_HELP_CHM property. Its current value is 'C:\Program Files (x86)\Nero\Help'. Its new value: 'C:\Program Files (x86)\Nero\Help\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying COMP_INSTALL_DIR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help'. Its new value: 'C:\Program Files (x86)\Nero\Help\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying ZH_TW.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\zh-TW'. Its new value: 'C:\Program Files (x86)\Nero\Help\zh-TW\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying ZH_HK.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\zh-HK'. Its new value: 'C:\Program Files (x86)\Nero\Help\zh-HK\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying ZH_CN.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\zh-CN'. Its new value: 'C:\Program Files (x86)\Nero\Help\zh-CN\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying ZH.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\zh'. Its new value: 'C:\Program Files (x86)\Nero\Help\zh\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying TR_TR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\tr-TR'. Its new value: 'C:\Program Files (x86)\Nero\Help\tr-TR\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying TH_TH.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\th-TH'. Its new value: 'C:\Program Files (x86)\Nero\Help\th-TH\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying SV_SE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\sv-SE'. Its new value: 'C:\Program Files (x86)\Nero\Help\sv-SE\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying RU_RU.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\ru-RU'. Its new value: 'C:\Program Files (x86)\Nero\Help\ru-RU\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying PT_PT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\pt-PT'. Its new value: 'C:\Program Files (x86)\Nero\Help\pt-PT\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying PT_BR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\pt-BR'. Its new value: 'C:\Program Files (x86)\Nero\Help\pt-BR\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying PT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\pt'. Its new value: 'C:\Program Files (x86)\Nero\Help\pt\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying PL_PL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\pl-PL'. Its new value: 'C:\Program Files (x86)\Nero\Help\pl-PL\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying NL_NL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\nl-NL'. Its new value: 'C:\Program Files (x86)\Nero\Help\nl-NL\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying NL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\nl'. Its new value: 'C:\Program Files (x86)\Nero\Help\nl\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying NB_NO.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\nb-NO'. Its new value: 'C:\Program Files (x86)\Nero\Help\nb-NO\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying KO_KR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\ko-KR'. Its new value: 'C:\Program Files (x86)\Nero\Help\ko-KR\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying JA_JP.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\ja-JP'. Its new value: 'C:\Program Files (x86)\Nero\Help\ja-JP\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying IT_IT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\it-IT'. Its new value: 'C:\Program Files (x86)\Nero\Help\it-IT\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying IT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\it'. Its new value: 'C:\Program Files (x86)\Nero\Help\it\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying HU_HU.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\hu-HU'. Its new value: 'C:\Program Files (x86)\Nero\Help\hu-HU\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying FR_FR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\fr-FR'. Its new value: 'C:\Program Files (x86)\Nero\Help\fr-FR\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying FR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\fr'. Its new value: 'C:\Program Files (x86)\Nero\Help\fr\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying FI_FI.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\fi-FI'. Its new value: 'C:\Program Files (x86)\Nero\Help\fi-FI\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying ES_ES.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\es-ES'. Its new value: 'C:\Program Files (x86)\Nero\Help\es-ES\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying ES.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\es'. Its new value: 'C:\Program Files (x86)\Nero\Help\es\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying EN_US.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\en-US'. Its new value: 'C:\Program Files (x86)\Nero\Help\en-US\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying EN_GB.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\en-GB'. Its new value: 'C:\Program Files (x86)\Nero\Help\en-GB\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying EL_GR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\el-GR'. Its new value: 'C:\Program Files (x86)\Nero\Help\el-GR\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying DE_DE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\de-DE'. Its new value: 'C:\Program Files (x86)\Nero\Help\de-DE\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying DE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\de'. Its new value: 'C:\Program Files (x86)\Nero\Help\de\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying DA_DK.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\da-DK'. Its new value: 'C:\Program Files (x86)\Nero\Help\da-DK\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying CS_CZ.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 property. Its current value is 'C:\Program Files (x86)\Nero\Help\cs-CZ'. Its new value: 'C:\Program Files (x86)\Nero\Help\cs-CZ\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ISYourDataBaseDir property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\Database\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding DATABASEDIR property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\Database\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: 'C:\Program Files (x86)\' will substitute 17 characters in 'C:\Program Files\Common Files\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying CommonFiles64Folder property. Its current value is 'C:\Program Files\Common Files\'. Its new value: 'C:\Program Files (x86)\Common Files\'.
MSI (s) (60:30) [10:53:56:071]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:
Nissi1
\ProgramData'. Its new value: 'C:\ProgramData\'.
MSI (s) (60:30) [10:53:56:071]: Target path resolution complete. Dumping Directory table...
MSI (s) (60:30) [10:53:56:071]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: TARGETDIR   , Object: C:\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: WindowsFolder   , Object: C:\WINDOWS\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: USERPROFILE   , Object: C:\Users\Zandra Jones\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: TemplateFolder   , Object: C:\ProgramData\Microsoft\Windows\Templates\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: TempFolder   , Object: C:\Users\ZANDRA~1\AppData\Local\Temp\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: SystemFolder   , Object: C:\WINDOWS\SysWOW64\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: System64Folder   , Object: C:\WINDOWS\SysWOW64\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: System16Folder   , Object: C:\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: StartupFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: StartMenuFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: SendToFolder   , Object: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ProgramMenuFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ScNeroFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ScProductFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ScManualsFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ScControlCenterManualsFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ProgramFiles64Folder   , Object: C:\Program Files (x86)\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: PersonalFolder   , Object: C:\Users\Zandra Jones\Documents\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: LocalAppDataFolder   , Object: C:\Users\Zandra Jones\AppData\Local\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: GlobalAssemblyCache   , Object: C:\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: FontsFolder   , Object: C:\WINDOWS\Fonts\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: FavoritesFolder   , Object: C:\Users\Zandra Jones\Favorites\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: DesktopFolder   , Object: C:\Users\Public\Desktop\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ProgramFilesFolder   , Object: C:\Program Files (x86)\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ISMyCompanyDir   , Object: C:\Program Files (x86)\My Company Name\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ISMyProductDir   , Object: C:\Program Files (x86)\My Company Name\My Product Name\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: NERO   , Object: C:\Program Files (x86)\Nero\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: NERO_PRODUCT   , Object: C:\Program Files (x86)\Nero\Nero 10\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: INSTALLDIR   , Object: C:\Program Files (x86)\Nero\Nero 10\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: NERO_CONTROLCENTER_HELP_CHM   , Object: C:\Program Files (x86)\Nero\Help\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: COMP_INSTALL_DIR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ZH_TW.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\zh-TW\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ZH_HK.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\zh-HK\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ZH_CN.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\zh-CN\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ZH.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\zh\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: TR_TR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\tr-TR\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: TH_TH.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\th-TH\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: SV_SE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\sv-SE\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: RU_RU.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\ru-RU\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: PT_PT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\pt-PT\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: PT_BR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\pt-BR\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: PT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\pt\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: PL_PL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\pl-PL\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: NL_NL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\nl-NL\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: NL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\nl\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: NB_NO.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\nb-NO\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: KO_KR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\ko-KR\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: JA_JP.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\ja-JP\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: IT_IT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\it-IT\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: IT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\it\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: HU_HU.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\hu-HU\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: FR_FR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\fr-FR\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: FR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\fr\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: FI_FI.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\fi-FI\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ES_ES.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\es-ES\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ES.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\es\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: EN_US.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\en-US\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: EN_GB.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\en-GB\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: EL_GR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\el-GR\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: DE_DE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\de-DE\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: DE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\de\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: DA_DK.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\da-DK\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: CS_CZ.BBDB24D3_07A5_496B_AA18_6A3ED03D6698   , Object: C:\Program Files (x86)\Nero\Help\cs-CZ\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ISYourDataBaseDir   , Object: C:\Program Files (x86)\Nero\Nero 10\Database\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: DATABASEDIR   , Object: C:\Program Files (x86)\Nero\Nero 10\Database\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: CommonFilesFolder   , Object: C:\Program Files (x86)\Common Files\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ISCommonFilesFolder   , Object: C:\Program Files (x86)\Common Files\InstallShield\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ISUpdateServiceFolder   , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: CommonFiles64Folder   , Object: C:\Program Files (x86)\Common Files\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: CommonAppDataFolder   , Object: C:\ProgramData\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: AdminToolsFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
MSI (s) (60:30) [10:53:56:071]: Dir (target): Key: ALLUSERSPROFILE   , Object: C:\ProgramData\
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\zh-TW\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\zh-HK\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\zh-CN\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\zh\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\tr-TR\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\th-TH\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\sv-SE\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\ru-RU\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\pt-PT\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\pt-BR\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:071]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\pt\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\pl-PL\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
Action start 10:53:56: CostFinalize.
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\nl-NL\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\nl\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\nb-NO\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\ko-KR\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\ja-JP\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\it-IT\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\it\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\hu-HU\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\fr-FR\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\fr\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\fi-FI\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\es-ES\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\es\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\en-US\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\en-GB\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\el-GR\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\de-DE\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\de\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:086]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\da-DK\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\cs-CZ\nerohelplang.dll.mui' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroHelpLang.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\HelpBase.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_zh-TW.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_zh-CN.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_tr-TR.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_th-TH.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_sv-SE.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_ru-RU.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_pt-PT.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_pt-BR.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_pl-PL.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_nl-NL.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_nb-NO.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_ko-KR.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_ja-JP.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_it-IT.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:102]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_hu-HU.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:118]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_fr-FR.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:119]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_fi-FI.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:120]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_es-ES.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:121]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_en-US.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:121]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_en-GB.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:122]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_el-GR.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:123]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_de-DE.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:123]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_da-DK.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:124]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\Help\NeroControlCenter_cs-CZ.chm' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:30) [10:53:56:124]: Skipping action: Nero_CA_DetectInstallationLocation (condition is false)
MSI (s) (60:30) [10:53:56:124]: Doing action: Nero_CA_PrepareShortCuts
Action ended 10:53:56: CostFinalize. Return value 1.
MSI (s) (60:48) [10:53:56:132]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIF738.tmp, Entrypoint: CA_PrepareShortCuts
Action start 10:53:56: Nero_CA_PrepareShortCuts.
CA_PrepareShortCuts: CustomActions.cpp : 1535 :  CommonDesktop: C:\Users\Public\Desktop\
CA_PrepareShortCuts: CustomActions.cpp : 1536 :  UserDesktop  : C:\Users\Zandra Jones\Desktop\
CA_PrepareShortCuts: CustomActions.cpp : 1607 :  Succeeded
MSI (s) (60:30) [10:53:56:221]: Skipping action: Nero_CA_CheckProductConflicts (condition is false)
MSI (s) (60:30) [10:53:56:221]: Skipping action: Nero_CA_CheckRebootPending (condition is false)
MSI (s) (60:30) [10:53:56:221]: Doing action: MigrateFeatureStates
Action ended 10:53:56: Nero_CA_PrepareShortCuts. Return value 1.
MSI (s) (60:30) [10:53:56:223]: Skipping MigrateFeatureStates action: not run in maintenance mode
Action start 10:53:56: MigrateFeatureStates.
MSI (s) (60:30) [10:53:56:224]: Doing action: SetARPINSTALLLOCATION
Action ended 10:53:56: MigrateFeatureStates. Return value 0.
MSI (s) (60:30) [10:53:56:224]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\'.
Action start 10:53:56: SetARPINSTALLLOCATION.
MSI (s) (60:30) [10:53:56:225]: Doing action: SetODBCFolders
Action ended 10:53:56: SetARPINSTALLLOCATION. Return value 1.
MSI (s) (60:30) [10:53:56:225]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:30) [10:53:56:225]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
MSI (s) (60:30) [10:53:56:225]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:30) [10:53:56:225]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
Action start 10:53:56: SetODBCFolders.
MSI (s) (60:30) [10:53:56:225]: Doing action: InstallValidate
Action ended 10:53:56: SetODBCFolders. Return value 0.
MSI (s) (60:30) [10:53:56:226]: Feature: Help; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Feature: Documentation; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Feature: Application; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __RegInstaller65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_trTR.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_thTH.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_ptPT.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_nbNO.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_huHU.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_fiFI.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_enGB.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_elGR.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_daDK.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_zhTW.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_zhCN.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_svSE.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_ruRU.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_ptBR.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_plPL.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_nlNL.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_koKR.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_jaJP.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_itIT.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_frFR.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_esES.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_enUS.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_deDE.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: __NeroControlCenterHelp_csCZ.chm65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_csCZ.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_daDK.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_deDE.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_elGR.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_enGB.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_enUS.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_esES.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_fiFI.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_frFR.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_huHU.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_itIT.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_jaJP.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_koKR.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_nbNO.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_nlNL.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_plPL.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_ptBR.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_ptPT.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_ruRU.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_svSE.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_thTH.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_trTR.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_zhCN.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: NeroControlCenterHelp_zhTW.chm; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: RegInstaller; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: DetectInstallLocation.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_cs_CZ.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_da_DK.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_de.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_de_DE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_el_GR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_en_GB.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_en_US.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_es.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_es_ES.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_fi_FI.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_fr.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_fr_FR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_hu_HU.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_it.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_it_IT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_ja_JP.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_ko_KR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_nb_NO.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_nl.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_nl_NL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_pl_PL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_pt.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_pt_BR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_pt_PT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_ru_RU.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:226]: Component: nerohelplang_dll_mui_sv_SE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:227]: Component: nerohelplang_dll_mui_th_TH.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:227]: Component: nerohelplang_dll_mui_tr_TR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:227]: Component: nerohelplang_dll_mui_zh.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:227]: Component: nerohelplang_dll_mui_zh_CN.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:227]: Component: nerohelplang_dll_mui_zh_HK.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:227]: Component: nerohelplang_dll_mui_zh_TW.BBDB24D3_07A5_496B_AA18_6A3ED03D6698; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: BindImage
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: Font
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: Class
MSI (s) (60:30) [10:53:56:227]: Note: 1: 2205 2:  3: TypeLib
Action start 10:53:56: InstallValidate.
MSI (s) (60:30) [10:53:56:239]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI (s) (60:30) [10:53:56:257]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: BindImage
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: Font
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: Class
MSI (s) (60:30) [10:53:56:258]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:30) [10:53:56:259]: Note: 1: 2727 2:
MSI (s) (60:30) [10:53:56:262]: Note: 1: 2727 2:
MSI (s) (60:30) [10:53:56:263]: Doing action: RemoveExistingProducts
Action ended 10:53:56: InstallValidate. Return value 1.
MSI (s) (60:30) [10:53:56:264]: Skipping RemoveExistingProducts action: current configuration is maintenance mode or an uninstall
Action start 10:53:56: RemoveExistingProducts.
MSI (s) (60:30) [10:53:56:264]: Skipping action: Nero_CA_SetMediaPackage (condition is false)
MSI (s) (60:30) [10:53:56:264]: Skipping action: Nero_CAData_RestoreMediaPackage (condition is false)
MSI (s) (60:30) [10:53:56:264]: Doing action: InstallInitialize
Action ended 10:53:56: RemoveExistingProducts. Return value 0.
MSI (s) (60:30) [10:53:56:264]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:30) [10:53:56:264]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:30) [10:53:56:264]: BeginTransaction: Locking Server
MSI (s) (60:30) [10:53:56:265]: Transforming table Property.
MSI (s) (60:30) [10:53:56:268]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:30) [10:53:56:271]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
MSI (s) (60:30) [10:53:56:271]: SRSetRestorePoint skipped for this transaction.
MSI (s) (60:30) [10:53:56:275]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:30) [10:53:56:278]: Server not locked: locking for product {523B2B1B-D8DB-4B41-90FF-C4D799E2758A}
Action start 10:53:56: InstallInitialize.
MSI (s) (60:30) [10:53:56:321]: PROPERTY CHANGE: Deleting ProductToBeRegistered property. Its current value is '1'.
MSI (s) (60:30) [10:53:56:322]: Note: 1: 2205 2:  3: Class
MSI (s) (60:30) [10:53:56:322]: Note: 1: 2228 2:  3: Class 4: SELECT `CLSID` FROM `Class` WHERE `Icon_`=? AND `Class`.`Attributes`=1
MSI (s) (60:30) [10:53:56:322]: Note: 1: 2228 2:  3: Class 4: SELECT `Component`,`CLSID` FROM `Component`,`Class` WHERE `Component`=`Component_` AND `Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:30) [10:53:56:322]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:30) [10:53:56:322]: Note: 1: 2228 2:  3: Extension 4: SELECT `Component`,`Extension` FROM `Component`,`Extension`,`ProgId` WHERE `Component`.`Component`=`Extension`.`Component_` AND `ProgId`.`ProgId`=`Extension`.`ProgId_` AND `ProgId`.`Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:30) [10:53:56:322]: 'NeroHelpIcon.BBDB24D3_07A5_496B_AA18_6A3ED03D6698' icon will be removed.
MSI (s) (60:30) [10:53:56:322]: Doing action: Nero_CA_DeleteLocalFileAssociationDb
Action ended 10:53:56: InstallInitialize. Return value 1.
Action start 10:53:56: Nero_CA_DeleteLocalFileAssociationDb.
MSI (s) (60:30) [10:53:56:327]: Doing action: Nero_CA_GatherOriginalFileAssociation
Action ended 10:53:56: Nero_CA_DeleteLocalFileAssociationDb. Return value 1.
Action start 10:53:56: Nero_CA_GatherOriginalFileAssociation.
MSI (s) (60:30) [10:53:56:333]: Skipping action: Nero_CA_RestoreMediaPackage (condition is false)
MSI (s) (60:30) [10:53:56:333]: Skipping action: AllocateRegistrySpace (condition is false)
MSI (s) (60:30) [10:53:56:333]: Doing action: ProcessComponents
Action ended 10:53:56: Nero_CA_GatherOriginalFileAssociation. Return value 1.
Action start 10:53:56: ProcessComponents.
MSI (s) (60:30) [10:53:56:348]: Doing action: UnpublishComponents
Action ended 10:53:56: ProcessComponents. Return value 1.
MSI (s) (60:30) [10:53:56:349]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:30) [10:53:56:349]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: UnpublishComponents.
MSI (s) (60:30) [10:53:56:349]: Doing action: MsiUnpublishAssemblies
Action ended 10:53:56: UnpublishComponents. Return value 0.
MSI (s) (60:30) [10:53:56:351]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:30) [10:53:56:351]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: MsiUnpublishAssemblies.
MSI (s) (60:30) [10:53:56:352]: Doing action: UnpublishFeatures
Action ended 10:53:56: MsiUnpublishAssemblies. Return value 0.
Action start 10:53:56: UnpublishFeatures.
MSI (s) (60:30) [10:53:56:354]: Doing action: StopServices
Action ended 10:53:56: UnpublishFeatures. Return value 1.
MSI (s) (60:30) [10:53:56:355]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:30) [10:53:56:355]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 10:53:56: StopServices.
MSI (s) (60:30) [10:53:56:355]: Doing action: DeleteServices
Action ended 10:53:56: StopServices. Return value 1.
MSI (s) (60:30) [10:53:56:356]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:30) [10:53:56:356]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 10:53:56: DeleteServices.
MSI (s) (60:30) [10:53:56:356]: Doing action: UnregisterComPlus
Action ended 10:53:56: DeleteServices. Return value 1.
MSI (s) (60:30) [10:53:56:356]: Note: 1: 2205 2:  3: Complus
MSI (s) (60:30) [10:53:56:356]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
Action start 10:53:56: UnregisterComPlus.
MSI (s) (60:30) [10:53:56:357]: Doing action: SelfUnregModules
Action ended 10:53:56: UnregisterComPlus. Return value 0.
MSI (s) (60:30) [10:53:56:357]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:30) [10:53:56:357]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
Action start 10:53:56: SelfUnregModules.
MSI (s) (60:30) [10:53:56:357]: Doing action: UnregisterTypeLibraries
Action ended 10:53:56: SelfUnregModules. Return value 1.
MSI (s) (60:30) [10:53:56:369]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:30) [10:53:56:369]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
Action start 10:53:56: UnregisterTypeLibraries.
MSI (s) (60:30) [10:53:56:369]: Doing action: RemoveODBC
Action ended 10:53:56: UnregisterTypeLibraries. Return value 0.
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:30) [10:53:56:388]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:389]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:389]: Note: 1: 2711 2: ODBCDriverManager
Action start 10:53:56: RemoveODBC.
MSI (s) (60:30) [10:53:56:394]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (60:30) [10:53:56:399]: Doing action: UnregisterFonts
Action ended 10:53:56: RemoveODBC. Return value 1.
MSI (s) (60:30) [10:53:56:400]: Note: 1: 2205 2:  3: Font
MSI (s) (60:30) [10:53:56:400]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
Action start 10:53:56: UnregisterFonts.
MSI (s) (60:30) [10:53:56:400]: Doing action: RemoveRegistryValues
Action ended 10:53:56: UnregisterFonts. Return value 1.
Action start 10:53:56: RemoveRegistryValues.
MSI (s) (60:30) [10:53:56:402]: Doing action: UnregisterClassInfo
Action ended 10:53:56: RemoveRegistryValues. Return value 1.
MSI (s) (60:30) [10:53:56:402]: Note: 1: 2205 2:  3: Class
MSI (s) (60:30) [10:53:56:402]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: UnregisterClassInfo.
MSI (s) (60:30) [10:53:56:402]: Doing action: UnregisterExtensionInfo
Action ended 10:53:56: UnregisterClassInfo. Return value 0.
MSI (s) (60:30) [10:53:56:404]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:30) [10:53:56:404]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: UnregisterExtensionInfo.
MSI (s) (60:30) [10:53:56:404]: Doing action: UnregisterProgIdInfo
Action ended 10:53:56: UnregisterExtensionInfo. Return value 0.
MSI (s) (60:30) [10:53:56:405]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:30) [10:53:56:405]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: UnregisterProgIdInfo.
MSI (s) (60:30) [10:53:56:405]: Doing action: UnregisterMIMEInfo
Action ended 10:53:56: UnregisterProgIdInfo. Return value 0.
MSI (s) (60:30) [10:53:56:405]: Note: 1: 2205 2:  3: MIME
MSI (s) (60:30) [10:53:56:405]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:53:56: UnregisterMIMEInfo.
MSI (s) (60:30) [10:53:56:405]: Doing action: RemoveIniValues
Action ended 10:53:56: UnregisterMIMEInfo. Return value 0.
MSI (s) (60:30) [10:53:56:406]: Note: 1: 2205 2:  3: IniFile
MSI (s) (60:30) [10:53:56:406]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
Action start 10:53:56: RemoveIniValues.
MSI (s) (60:30) [10:53:56:406]: Doing action: RemoveShortcuts
Action ended 10:53:56: RemoveIniValues. Return value 1.
Action start 10:53:56: RemoveShortcuts.
MSI (s) (60:30) [10:53:56:410]: Doing action: RemoveEnvironmentStrings
Action ended 10:53:56: RemoveShortcuts. Return value 1.
MSI (s) (60:30) [10:53:56:411]: Note: 1: 2205 2:  3: Environment
MSI (s) (60:30) [10:53:56:411]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
Action start 10:53:56: RemoveEnvironmentStrings.
MSI (s) (60:30) [10:53:56:411]: Doing action: RemoveDuplicateFiles
Action ended 10:53:56: RemoveEnvironmentStrings. Return value 1.
Action start 10:53:56: RemoveDuplicateFiles.
MSI (s) (60:30) [10:53:56:411]: Doing action: RemoveFiles
Action ended 10:53:56: RemoveDuplicateFiles. Return value 1.
Action start 10:53:56: RemoveFiles.
MSI (s) (60:30) [10:53:56:424]: Counted 16 foreign folders to be removed.
MSI (s) (60:30) [10:53:56:424]: Removing foreign folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\
MSI (s) (60:30) [10:53:56:425]: Removing foreign folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\
MSI (s) (60:30) [10:53:56:426]: Removing foreign folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\
MSI (s) (60:30) [10:53:56:427]: Doing action: RemoveFolders
Action ended 10:53:56: RemoveFiles. Return value 1.
Action start 10:53:56: RemoveFolders.
MSI (s) (60:30) [10:53:56:427]: Doing action: CreateFolders
Action ended 10:53:56: RemoveFolders. Return value 0.
Action start 10:53:56: CreateFolders.
MSI (s) (60:30) [10:53:56:428]: Doing action: MoveFiles
Action ended 10:53:56: CreateFolders. Return value 0.
Action start 10:53:56: MoveFiles.
MSI (s) (60:30) [10:53:56:429]: Doing action: InstallFiles
Action ended 10:53:56: MoveFiles. Return value 1.
MSI (s) (60:30) [10:53:56:431]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
MSI (s) (60:30) [10:53:56:431]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
MSI (s) (60:30) [10:53:56:432]: Note: 1: 2205 2:  3: MsiSFCBypass
MSI (s) (60:30) [10:53:56:432]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE
Nissi1
MSI (s) (60:30) [10:53:56:432]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
MSI (s) (60:30) [10:53:56:432]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (60:30) [10:53:56:432]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
Action start 10:53:56: InstallFiles.
MSI (s) (60:30) [10:53:56:433]: Doing action: PatchFiles
Action ended 10:53:56: InstallFiles. Return value 1.
Action start 10:53:56: PatchFiles.
MSI (s) (60:30) [10:53:56:433]: Doing action: DuplicateFiles
Action ended 10:53:56: PatchFiles. Return value 1.
Action start 10:53:56: DuplicateFiles.
MSI (s) (60:30) [10:53:56:434]: Doing action: BindImage
Action ended 10:53:56: DuplicateFiles. Return value 1.
Action start 10:53:56: BindImage.
MSI (s) (60:30) [10:53:56:434]: Doing action: CreateShortcuts
Action ended 10:53:56: BindImage. Return value 1.
MSI (s) (60:30) [10:53:56:435]: Note: 1: 2205 2:  3: MsiShortcutProperty
MSI (s) (60:30) [10:53:56:436]: Note: 1: 2205 2:  3: MsiShortcutProperty
Action start 10:53:56: CreateShortcuts.
MSI (s) (60:30) [10:53:56:436]: Doing action: RegisterClassInfo
Action ended 10:53:56: CreateShortcuts. Return value 1.
MSI (s) (60:30) [10:53:56:436]: Note: 1: 2205 2:  3: Class
MSI (s) (60:30) [10:53:56:436]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:53:56: RegisterClassInfo.
MSI (s) (60:30) [10:53:56:437]: Doing action: RegisterExtensionInfo
Action ended 10:53:56: RegisterClassInfo. Return value 0.
MSI (s) (60:30) [10:53:56:438]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:30) [10:53:56:438]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:53:56: RegisterExtensionInfo.
MSI (s) (60:30) [10:53:56:438]: Doing action: RegisterProgIdInfo
Action ended 10:53:56: RegisterExtensionInfo. Return value 0.
MSI (s) (60:30) [10:53:56:438]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:30) [10:53:56:438]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:53:56: RegisterProgIdInfo.
MSI (s) (60:30) [10:53:56:439]: Doing action: RegisterMIMEInfo
Action ended 10:53:56: RegisterProgIdInfo. Return value 0.
MSI (s) (60:30) [10:53:56:439]: Note: 1: 2205 2:  3: MIME
MSI (s) (60:30) [10:53:56:439]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:53:56: RegisterMIMEInfo.
MSI (s) (60:30) [10:53:56:439]: Doing action: WriteRegistryValues
Action ended 10:53:56: RegisterMIMEInfo. Return value 0.
Action start 10:53:56: WriteRegistryValues.
MSI (s) (60:30) [10:53:56:440]: Doing action: WriteIniValues
Action ended 10:53:56: WriteRegistryValues. Return value 1.
MSI (s) (60:30) [10:53:56:440]: Note: 1: 2205 2:  3: IniFile
MSI (s) (60:30) [10:53:56:440]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
Action start 10:53:56: WriteIniValues.
MSI (s) (60:30) [10:53:56:440]: Doing action: WriteEnvironmentStrings
Action ended 10:53:56: WriteIniValues. Return value 1.
MSI (s) (60:30) [10:53:56:441]: Note: 1: 2205 2:  3: Environment
MSI (s) (60:30) [10:53:56:441]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
Action start 10:53:56: WriteEnvironmentStrings.
MSI (s) (60:30) [10:53:56:441]: Doing action: RegisterFonts
Action ended 10:53:56: WriteEnvironmentStrings. Return value 1.
MSI (s) (60:30) [10:53:56:441]: Note: 1: 2205 2:  3: Font
MSI (s) (60:30) [10:53:56:441]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
Action start 10:53:56: RegisterFonts.
MSI (s) (60:30) [10:53:56:441]: Doing action: InstallODBC
Action ended 10:53:56: RegisterFonts. Return value 1.
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2711 2: ODBCDriverManager
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
Action start 10:53:56: InstallODBC.
MSI (s) (60:30) [10:53:56:442]: Doing action: RegisterTypeLibraries
Action ended 10:53:56: InstallODBC. Return value 0.
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:30) [10:53:56:442]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
Action start 10:53:56: RegisterTypeLibraries.
MSI (s) (60:30) [10:53:56:442]: Doing action: SelfRegModules
Action ended 10:53:56: RegisterTypeLibraries. Return value 0.
MSI (s) (60:30) [10:53:56:443]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:30) [10:53:56:443]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
Action start 10:53:56: SelfRegModules.
MSI (s) (60:30) [10:53:56:443]: Doing action: RegisterComPlus
Action ended 10:53:56: SelfRegModules. Return value 1.
MSI (s) (60:30) [10:53:56:443]: Note: 1: 2205 2:  3: Complus
MSI (s) (60:30) [10:53:56:443]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action start 10:53:56: RegisterComPlus.
MSI (s) (60:30) [10:53:56:444]: Doing action: InstallServices
Action ended 10:53:56: RegisterComPlus. Return value 0.
MSI (s) (60:30) [10:53:56:444]: Detected older ServiceInstall table schema
MSI (s) (60:30) [10:53:56:444]: Note: 1: 2205 2:  3: ServiceInstall
MSI (s) (60:30) [10:53:56:444]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
Action start 10:53:56: InstallServices.
MSI (s) (60:30) [10:53:56:444]: Doing action: StartServices
Action ended 10:53:56: InstallServices. Return value 1.
MSI (s) (60:30) [10:53:56:445]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:30) [10:53:56:445]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 10:53:56: StartServices.
MSI (s) (60:30) [10:53:56:445]: Doing action: RegisterUser
Action ended 10:53:56: StartServices. Return value 1.
Action start 10:53:56: RegisterUser.
MSI (s) (60:30) [10:53:56:446]: Doing action: RegisterProduct
Action ended 10:53:56: RegisterUser. Return value 0.
Action start 10:53:56: RegisterProduct.
MSI (s) (60:30) [10:53:56:448]: Doing action: PublishComponents
Action ended 10:53:56: RegisterProduct. Return value 1.
MSI (s) (60:30) [10:53:56:449]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:30) [10:53:56:449]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action start 10:53:56: PublishComponents.
MSI (s) (60:30) [10:53:56:449]: Doing action: MsiPublishAssemblies
Action ended 10:53:56: PublishComponents. Return value 0.
MSI (s) (60:30) [10:53:56:450]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:30) [10:53:56:450]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action start 10:53:56: MsiPublishAssemblies.
MSI (s) (60:30) [10:53:56:451]: Doing action: PublishFeatures
Action ended 10:53:56: MsiPublishAssemblies. Return value 0.
Action start 10:53:56: PublishFeatures.
MSI (s) (60:30) [10:53:56:451]: Doing action: PublishProduct
Action ended 10:53:56: PublishFeatures. Return value 1.
Action start 10:53:56: PublishProduct.
MSI (s) (60:30) [10:53:56:456]: Doing action: Nero_CA_UninstallSetAssociationsRollback
Action ended 10:53:56: PublishProduct. Return value 1.
Action start 10:53:56: Nero_CA_UninstallSetAssociationsRollback.
MSI (s) (60:30) [10:53:56:462]: Doing action: Nero_CA_UninstallSetAssociations
Action ended 10:53:56: Nero_CA_UninstallSetAssociationsRollback. Return value 1.
Action start 10:53:56: Nero_CA_UninstallSetAssociations.
MSI (s) (60:30) [10:53:56:467]: Skipping action: Nero_CA_InstallSetAssociationsRollback (condition is false)
MSI (s) (60:30) [10:53:56:467]: Skipping action: Nero_CA_InstallSetAssociations (condition is false)
MSI (s) (60:30) [10:53:56:467]: Doing action: Nero_CA_DeleteAssociationsBackup
Action ended 10:53:56: Nero_CA_UninstallSetAssociations. Return value 1.
Action start 10:53:56: Nero_CA_DeleteAssociationsBackup.
MSI (s) (60:30) [10:53:56:472]: Doing action: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore
Action ended 10:53:56: Nero_CA_DeleteAssociationsBackup. Return value 1.
Action start 10:53:56: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore.
MSI (s) (60:30) [10:53:56:477]: Skipping action: ScheduleReboot (condition is false)
MSI (s) (60:30) [10:53:56:477]: Doing action: InstallFinalize
Action ended 10:53:56: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore. Return value 1.
Action start 10:53:56: InstallFinalize.
MSI (s) (60:30) [10:53:56:479]: Running Script: C:\WINDOWS\Installer\MSIF7F4.tmp
MSI (s) (60:30) [10:53:56:479]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (60:30) [10:53:56:486]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:30) [10:53:56:494]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:30) [10:53:56:499]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1254839997,LangId=0,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (60:30) [10:53:56:500]: Executing op: ProductInfo(ProductKey={523B2B1B-D8DB-4B41-90FF-C4D799E2758A},ProductName=Nero ControlCenter 10 Help (CHM),PackageName=Nero.ControlCenterHelpChm.msi,Language=0,Version=167914032,Assignment=1,ObsoleteArg=0,ProductIcon=NeroHelpIcon.BBDB24D3_07A5_496B_AA18_6A3ED03D6698,PackageMediaPath=\applications\controlcenterhelpchm\,PackageCode={1A7F010E-8947-468D-A021-92CE03780E30},,,InstanceType=0,LUASetting=1,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (s) (60:30) [10:53:56:500]: Executing op: DialogInfo(Type=0,Argument=0)
MSI (s) (60:30) [10:53:56:502]: Executing op: DialogInfo(Type=1,Argument=Nero ControlCenter 10 Help (CHM))
MSI (s) (60:30) [10:53:56:502]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (60:30) [10:53:56:502]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (60:30) [10:53:56:502]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (60:30) [10:53:56:502]: Executing op: ActionStart(Name=InstallInitialize,,)
MSI (s) (60:30) [10:53:56:504]: Executing op: ProductUnregister(UpgradeCode={DB1A16FB-84D6-4824-A7E5-26B7BB9B1CA7})
MSI (s) (60:30) [10:53:56:504]: Note: 1: 1402 2: UNKNOWN\Products\B1B2B325BD8D14B409FF4C7D992E57A8\Transforms 3: 2
MSI (s) (60:30) [10:53:56:505]: Note: 1: 1402 2: UNKNOWN\Products\B1B2B325BD8D14B409FF4C7D992E57A8\Transforms 3: 2
MSI (s) (60:30) [10:53:56:505]: Scheduling file 'C:\Windows\Installer\11a7e.msi' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:30) [10:53:56:518]: Note: 1: 1402 2: UNKNOWN\Products\B1B2B325BD8D14B409FF4C7D992E57A8\Usage 3: 2
MSI (s) (60:30) [10:53:56:519]: Executing op: ProductCPDisplayInfoUnregister()
MSI (s) (60:30) [10:53:56:520]: Executing op: ProductUnpublish(PackageKey={1A7F010E-8947-468D-A021-92CE03780E30})
MSI (s) (60:30) [10:53:56:521]: Transforms are not secure.
MSI (s) (60:30) [10:53:56:521]: Processing cached transform: C:\WINDOWS\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst
MSI (s) (60:30) [10:53:56:521]: Scheduling file 'C:\WINDOWS\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:30) [10:53:56:522]: Registering cached transform: C:\WINDOWS\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst
MSI (s) (60:30) [10:53:56:524]: Executing op: UpgradeCodeUnpublish(UpgradeCode={DB1A16FB-84D6-4824-A7E5-26B7BB9B1CA7})
MSI (s) (60:30) [10:53:56:525]: Executing op: IconRemove(Icon=NeroHelpIcon.BBDB24D3_07A5_496B_AA18_6A3ED03D6698,)
MSI (s) (60:30) [10:53:56:526]: Scheduling file 'C:\WINDOWS\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\NeroHelpIcon.BBDB24D3_07A5_496B_AA18_6A3ED03D6698' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:30) [10:53:56:526]: Executing op: ProductUnpublishClient(,,)
MSI (s) (60:30) [10:53:56:527]: Note: 1: 1402 2: UNKNOWN\Installer\Products\B1B2B325BD8D14B409FF4C7D992E57A8 3: 2
MSI (s) (60:30) [10:53:56:527]: Executing op: SourceListUnpublish(,)
MSI (s) (60:30) [10:53:56:527]: Note: 1: 1402 2: UNKNOWN\Installer\Products\B1B2B325BD8D14B409FF4C7D992E57A8\SourceList 3: 2
MSI (s) (60:30) [10:53:56:527]: Executing op: ActionStart(Name=Nero_CA_DeleteLocalFileAssociationDb,,)
MSI (s) (60:30) [10:53:56:528]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteLocalFileAssociationDb,ActionType=1281,Source=BinaryData,Target=CA_DeleteLocalFileAssociationDb,CustomActionData={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:531]: Executing op: ActionStart(Name=Nero_CA_GatherOriginalFileAssociation,,)
MSI (s) (60:30) [10:53:56:532]: Executing op: CustomActionSchedule(Action=Nero_CA_GatherOriginalFileAssociation,ActionType=1025,Source=BinaryData,Target=CA_GatherOriginalFileAssociation,)
MSI (s) (60:EC) [10:53:56:539]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIF8D1.tmp, Entrypoint: CA_GatherOriginalFileAssociation
MSI (s) (60:30) [10:53:56:590]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (60:30) [10:53:56:590]: Executing op: ProgressTotal(Total=59,Type=1,ByteEquivalent=24000)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={4C55C4F6-8B7C-41DD-963F-C3F340B169A1},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={4C55C4F6-8B7C-41DD-963F-C3F340B169A1},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={C91EE7D0-690C-4FA5-BD7A-667140F49EE9},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={C91EE7D0-690C-4FA5-BD7A-667140F49EE9},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={D55AD2A4-9731-4D1F-A070-7C08867D813D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={D55AD2A4-9731-4D1F-A070-7C08867D813D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={8DCD6DDA-2280-4B9C-BF66-F26217843DF3},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={8DCD6DDA-2280-4B9C-BF66-F26217843DF3},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={D01133F7-1526-41D5-AF6D-25C4C0FBEBD5},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={D01133F7-1526-41D5-AF6D-25C4C0FBEBD5},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={CF0271AA-9CBC-4F2E-AD25-1136EBC92CC8},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={CF0271AA-9CBC-4F2E-AD25-1136EBC92CC8},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={9E37A2A9-36F8-4D66-9029-6895CE475D9D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={9E37A2A9-36F8-4D66-9029-6895CE475D9D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={025A5A13-B6C5-440D-A058-76D5AA5598E7},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={025A5A13-B6C5-440D-A058-76D5AA5598E7},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={EFAD83DA-049E-446F-A382-B3DCBC7FA605},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={EFAD83DA-049E-446F-A382-B3DCBC7FA605},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={79FCE4CF-A773-4485-B031-FA09A4317D5D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={79FCE4CF-A773-4485-B031-FA09A4317D5D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:590]: Executing op: UnregisterSharedComponentProvider(Component={65B993B5-2D5E-495B-ADC8-A2ACEF850B01},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:590]: Executing op: ComponentUnregister(ComponentId={65B993B5-2D5E-495B-ADC8-A2ACEF850B01},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={9AB16FC7-C8A7-4F09-B46C-75EDF559962A},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={9AB16FC7-C8A7-4F09-B46C-75EDF559962A},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={D0C09419-71D8-42D4-8224-F097F744B90D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={D0C09419-71D8-42D4-8224-F097F744B90D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={7E4E808C-7249-4AF9-9C80-254015916A8F},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={7E4E808C-7249-4AF9-9C80-254015916A8F},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={0CE41F0D-8F7E-43DD-8EDC-EDF1E96865D1},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={0CE41F0D-8F7E-43DD-8EDC-EDF1E96865D1},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={5874CFEF-9288-47AB-9B5D-29AAEA5A5B55},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={5874CFEF-9288-47AB-9B5D-29AAEA5A5B55},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={09BE3DEA-1718-47C8-B918-AC17F3DD49D7},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={09BE3DEA-1718-47C8-B918-AC17F3DD49D7},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={33BEB47B-65E6-4FDB-A294-707418381E7C},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={33BEB47B-65E6-4FDB-A294-707418381E7C},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={01AF3CDE-6B53-46B2-BA91-ABFD2AA93340},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={01AF3CDE-6B53-46B2-BA91-ABFD2AA93340},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={C5C90634-AEA8-4B78-A465-0094E9AC9790},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={C5C90634-AEA8-4B78-A465-0094E9AC9790},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={F9EAA970-0D45-4A5E-AEC4-450C3D4979E2},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={F9EAA970-0D45-4A5E-AEC4-450C3D4979E2},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={4E4FBA41-75BB-459C-B667-5E0C4DE5F00B},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={4E4FBA41-75BB-459C-B667-5E0C4DE5F00B},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={42ED05DD-A455-453C-BB05-C0974A7CB0A2},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={42ED05DD-A455-453C-BB05-C0974A7CB0A2},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={D0916F10-C695-4D27-9A24-7B58047CF3C5},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={D0916F10-C695-4D27-9A24-7B58047CF3C5},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={6D94768F-E5EA-4D1A-8EF9-A7652DB48DD9},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={6D94768F-E5EA-4D1A-8EF9-A7652DB48DD9},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={3D79EBE8-F5A7-4D96-9CF6-0BFB653EA2B9},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={3D79EBE8-F5A7-4D96-9CF6-0BFB653EA2B9},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={B418197E-135F-459C-A384-57279CFC28B2},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={B418197E-135F-459C-A384-57279CFC28B2},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:605]: Executing op: UnregisterSharedComponentProvider(Component={2176B58A-2510-4F90-A2F7-E406022FC8B3},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:605]: Executing op: ComponentUnregister(ComponentId={2176B58A-2510-4F90-A2F7-E406022FC8B3},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={48D24AB2-E2EF-4DF8-8223-42F4A1B30231},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={48D24AB2-E2EF-4DF8-8223-42F4A1B30231},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={79CF1702-F789-4A2B-B16A-D8B7BAF2680D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={79CF1702-F789-4A2B-B16A-D8B7BAF2680D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={3EC88457-7AFC-461B-B966-F4A0DD06FBA2},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={3EC88457-7AFC-461B-B966-F4A0DD06FBA2},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={09263913-2E40-46F2-A171-E0B06ECA5177},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={09263913-2E40-46F2-A171-E0B06ECA5177},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={F77CA61A-7784-4450-AEB4-BE95BEEF364D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={F77CA61A-7784-4450-AEB4-BE95BEEF364D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={75664931-926A-45D0-BFE4-7EF44348E026},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={75664931-926A-45D0-BFE4-7EF44348E026},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={DD9DC842-C8E4-4119-B4A1-A54A79862466},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={DD9DC842-C8E4-4119-B4A1-A54A79862466},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:621]: Executing op: UnregisterSharedComponentProvider(Component={8DA73776-B486-46AD-A544-58C3C1A0990F},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:621]: Executing op: ComponentUnregister(ComponentId={8DA73776-B486-46AD-A544-58C3C1A0990F},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={354D75FB-31BE-44B6-B1BE-F1CD4854547F},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={354D75FB-31BE-44B6-B1BE-F1CD4854547F},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={A1EC3F58-7B4E-4999-9BA9-EF404E70DA6B},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={A1EC3F58-7B4E-4999-9BA9-EF404E70DA6B},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={E9EE0783-28DE-49C1-B37E-571BDDA76653},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={E9EE0783-28DE-49C1-B37E-571BDDA76653},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={42DA5A33-F57F-4980-A70A-0D03D7E9B04F},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={42DA5A33-F57F-4980-A70A-0D03D7E9B04F},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={3085A40D-FA8C-4B10-BF37-D611743BA52C},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={3085A40D-FA8C-4B10-BF37-D611743BA52C},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={1662FE81-23E2-4470-9259-BC556D6DB24C},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={1662FE81-23E2-4470-9259-BC556D6DB24C},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={76A1BE2C-1EEE-4E8C-9416-927A0C4FF5B4},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={76A1BE2C-1EEE-4E8C-9416-927A0C4FF5B4},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={97F412BD-5FDF-4659-B8FC-F2C2F8FA7AA9},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={97F412BD-5FDF-4659-B8FC-F2C2F8FA7AA9},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={580F208E-2FCB-4440-875B-795B420A52EE},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={580F208E-2FCB-4440-875B-795B420A52EE},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={F45CEA63-31DD-428F-84F4-1F06E66AB0FE},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={F45CEA63-31DD-428F-84F4-1F06E66AB0FE},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={94C403CB-1BC8-4DFF-B22C-0C60A9E34AFE},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={94C403CB-1BC8-4DFF-B22C-0C60A9E34AFE},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={A747EF43-5D34-4549-A26D-589DE6747443},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={A747EF43-5D34-4549-A26D-589DE6747443},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={B089AA32-07DD-411D-881A-434E77E2622F},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={B089AA32-07DD-411D-881A-434E77E2622F},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={F99D9C57-C536-4D7D-8D4E-F511F9FA1FFD},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={F99D9C57-C536-4D7D-8D4E-F511F9FA1FFD},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:637]: Executing op: UnregisterSharedComponentProvider(Component={A549D487-2C1E-4E83-A46B-82C193C36466},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:637]: Executing op: ComponentUnregister(ComponentId={A549D487-2C1E-4E83-A46B-82C193C36466},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={216A14EE-E2A5-4363-BFF7-E163001D2B51},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={216A14EE-E2A5-4363-BFF7-E163001D2B51},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={B5BC2EFA-480D-4C4C-830E-2F0D9701D92A},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={B5BC2EFA-480D-4C4C-830E-2F0D9701D92A},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={527A7481-9B49-4B2C-A0A7-130E51F66113},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={527A7481-9B49-4B2C-A0A7-130E51F66113},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={0D80221D-20E3-41BB-8341-641EF31B0C4D},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={0D80221D-20E3-41BB-8341-641EF31B0C4D},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={F2E848CA-5C88-4A07-9018-47FFB7A464D4},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={F2E848CA-5C88-4A07-9018-47FFB7A464D4},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={3EABB463-C74E-4C14-8832-36646C1889A0},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={3EABB463-C74E-4C14-8832-36646C1889A0},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={20E9642F-BD10-434E-8115-A2DA4F41CD49},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={20E9642F-BD10-434E-8115-A2DA4F41CD49},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: UnregisterSharedComponentProvider(Component={DCBBEFB3-F30F-4ADA-98B0-3A7DE7279960},ProductCode={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:56:652]: Executing op: ComponentUnregister(ComponentId={DCBBEFB3-F30F-4ADA-98B0-3A7DE7279960},,BinaryType=0,)
MSI (s) (60:30) [10:53:56:652]: Executing op: ActionStart(Name=UnpublishFeatures,Description=Unpublishing product features,Template=Feature: [1])
MSI (s) (60:30) [10:53:56:652]: Executing op: FeatureUnpublish(Feature=Help,Parent=Documentation,Absent=2,Component=+'IU@OOG29amCEw{j]s[t_I_i9jpZA4V{ML7U=*t{J]Xm^ewk@i[of%@&?j7wDtXU^5YA@N0-mGJi'3w1+2sk{dO19*@R&hQ-,iml,?UkT32NAB='H5!PWDiJJCqZaCOs@1^^$X5j$YZGj?i!K[0s9n(W[mS?wLsz8g%v$7U~90]BxoflFn$SiX5OcVy$=dIX5&)O$'F7%$dHXk!Y?Cm6Q`T^VD!Vm&fYF-8JAW9,Cu49Mc1hss*l0%fP9W?koX&vvJ'WLWZP!S6+@UzJ]8tl{*VER20'Wn!n9t-8iv]$PAl`uTLD2ny%?J8^c_taqLCnY2.&hQ~(?iPd[*qnM4nJ8]^4JP[aADQ!LMi9jtOI_$V!1nFf=t)~TzpHw^8GC?XhC^l9@r@8XW8),PV~yMCyyz^u?B-?y&a,$lqmNH2A7TdG=[Zu{&W=6p&7{DS9NHP9=Al_jXB%R@]`8q%lNzll@fC5MDcOm]h_HOi7TPax@n-Ccy!@Bad3c{sb~%aG=z}j_0G`.=bU?4i-9sXXAXUE6%&lMkb@.JJ?Ah,(AZlrRw[dvh31@c0Ou`@p?%ON*dKDEB'aJ238Vc9U=.r+g[U2NH]Nayx%{22m=xT)qa%TbEN^p(Vxd+?z91_r-XZPKn@$67gM76=M=@tEYwfL'R0Y^B7p+kPw8o8?~?^-LoHafmTUW're=)D[kg.,3$(r82.5ip-*=XU24kCIRwPN!W&]%x``?Hd}r8(hLaJ2md3t6ptd?xRyk+hzKmB!]EQ9hQ&^??]E}!?,)]A6BXZ3azf-@]v?g(TMaE2w?Y4*4J`~9}P5WCWT?`@&_t-Nf=o8A1(RIO)6Y1c*x4pX],r[==_l`g@M$P_=VbADRLUx91N{IEaI`ZusbfUw_sCI9rQC{$$2oqzPc,nWY3k(At[vrFT7~fzJ5xi^Hko==)iRXZ7Nlb9?Hngal6ow8]y%1AjxU73_&77yD~{u@avZj(6v*Fzt3R
MSI (s) (60:30) [10:53:56:652]: Note: 1: 1402 2: UNKNOWN\Installer\Features\B1B2B325BD8D14B409FF4C7D992E57A8 3: 2
MSI (s) (60:30) [10:53:56:652]: Executing op: FeatureUnpublish(Feature=Documentation,,Absent=2,)
MSI (s) (60:30) [10:53:56:652]: Executing op: FeatureUnpublish(Feature=Application,,Absent=2,Component=+7[6Ka0Lk@iF.bHrFCwn)
MSI (s) (60:30) [10:53:56:652]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
MSI (s) (60:30) [10:53:56:652]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (60:30) [10:53:56:652]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (60:30) [10:53:56:652]: Executing op: ActionStart(Name=RemoveRegistryValues,Description=Removing system registry values,Template=Key: [1], Name: [2])
MSI (s) (60:30) [10:53:56:652]: Executing op: ProgressTotal(Total=13,Type=1,ByteEquivalent=13200)
MSI (s) (60:30) [10:53:56:652]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Nero\Nero 10\Installer\Applications\{DB1A16FB-84D6-4824-A7E5-26B7BB9B1CA7},,BinaryType=0,,)
MSI (s) (60:30) [10:53:56:652]: Executing op: RegRemoveValue(Name=NERO.APPID,Value=#[NERO.APPID],)
MSI (s) (60:30) [10:53:56:652]: Executing op: RegRemoveValue(Name=Nero.MainComponent,Value=[Nero.MainComponent],)
MSI (s) (60:30) [10:53:56:669]: Executing op: RegRemoveValue(Name=PackageName,Value=[Nero.PackageName],)
MSI (s) (60:30) [10:53:56:669]: Executing op: RegRemoveValue(Name=ProductCode,Value=[ProductCode],)
MSI (s) (60:30) [10:53:56:672]: Executing op: RegRemoveValue(Name=NERO.PRODUCT_LINE,Value=[NERO.PRODUCT_LINE],)
MSI (s) (60:30) [10:53:56:673]: Executing op: RegRemoveValue(Name=ProductName,Value=[ProductName],)
MSI (s) (60:30) [10:53:56:674]: Executing op: RegRemoveValue(Name=ProductVersion,Value=[ProductVersion],)
MSI (s) (60:30) [10:53:56:674]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\Applications\{DB1A16FB-84D6-4824-A7E5-26B7BB9B1CA7}\UserProperties,,BinaryType=0,,)
MSI (s) (60:30) [10:53:56:674]: Executing op: RegRemoveValue(Name=ARPNOREPAIR,Value=[ARPNOREPAIR],)
MSI (s) (60:30) [10:53:56:674]: Executing op: RegRemoveValue(Name=NERO.INSTALL_AUTOPLAY,Value=[NERO.INSTALL_AUTOPLAY],)
MSI (s) (60:30) [10:53:56:674]: Executing op: RegRemoveValue(Name=NERO.INSTALL_DESKTOPSHORTCUT,Value=[NERO.INSTALL_DESKTOPSHORTCUT],)
MSI (s) (60:30) [10:53:56:674]: Executing op: RegRemoveValue(Name=NERO.INSTALL_EXTENSIONS,Value=[NERO.INSTALL_EXTENSIONS],)
MSI (s) (60:30) [10:53:56:674]: Executing op: RegRemoveValue(Name=INSTALLDIR,Value=[INSTALLDIR],)
MSI (s) (60:30) [10:53:56:674]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Nero\Nero 10\Installer\Packages\{DB1A16FB-84D6-4824-A7E5-26B7BB9B1CA7},,BinaryType=0,,)
MSI (s) (60:30) [10:53:56:674]: Executing op: RegRemoveValue(Name=CHM_NCC,Value=[UpgradeCode],)
MSI (s) (60:30) [10:53:56:674]: Executing op: ActionStart(Name=RemoveShortcuts,Description=Removing shortcuts,Template=Shortcut: [1])
MSI (s) (60:30) [10:53:56:674]: Executing op: SetTargetFolder(Folder=23\Nero\Nero 10\Nero Help\Nero ControlCenter\)
MSI (s) (60:30) [10:53:56:674]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
MSI (s) (60:30) [10:53:56:674]: Executing op: ShortcutRemove(Name=Czech)
MSI (s) (60:30) [10:53:56:706]: Executing op: ShortcutRemove(Name=German)
MSI (s) (60:30) [10:53:56:706]: Executing op: ShortcutRemove(Name=English (US))
MSI (s) (60:30) [10:53:56:721]: Executing op: ShortcutRemove(Name=Spanish)
MSI (s) (60:30) [10:53:56:721]: Executing op: ShortcutRemove(Name=French)
MSI (s) (60:30) [10:53:56:721]: Executing op: ShortcutRemove(Name=Italian)
MSI (s) (60:30) [10:53:56:721]: Executing op: ShortcutRemove(Name=Japanese)
MSI (s) (60:30) [10:53:56:721]: Executing op: ShortcutRemove(Name=Korean)
MSI (s) (60:30) [10:53:56:721]: Executing op: ShortcutRemove(Name=Dutch)
MSI (s) (60:30) [10:53:56:721]: Executing op: ShortcutRemove(Name=Polish)
MSI (s) (60:30) [10:53:56:753]: Executing op: ShortcutRemove(Name=Russian)
MSI (s) (60:30) [10:53:56:806]: Executing op: ShortcutRemove(Name=Swedish)
MSI (s) (60:30) [10:53:56:822]: Executing op: ShortcutRemove(Name=Chinese (Simplified))
MSI (s) (60:30) [10:53:56:837]: Executing op: ShortcutRemove(Name=Chinese (Traditional))
MSI (s) (60:30) [10:53:56:879]: Executing op: ShortcutRemove(Name=Danish)
MSI (s) (60:30) [10:53:56:943]: Executing op: ShortcutRemove(Name=Greek)
MSI (s) (60:30) [10:53:56:969]: Executing op: ShortcutRemove(Name=ENGLIS~1|English (UK))
MSI (s) (60:30) [10:53:56:990]: Executing op: ShortcutRemove(Name=Finnish)
MSI (s) (60:30) [10:53:57:024]: Executing op: ShortcutRemove(Name=Hungarian)
MSI (s) (60:30) [10:53:57:045]: Executing op: ShortcutRemove(Name=Norwegian)
MSI (s) (60:30) [10:53:57:084]: Executing op: ShortcutRemove(Name=Portuguese (Brazil))
MSI (s) (60:30) [10:53:57:116]: Executing op: ShortcutRemove(Name=Portuguese (Portugal))
MSI (s) (60:30) [10:53:57:150]: Executing op: ShortcutRemove(Name=Thai)
MSI (s) (60:30) [10:53:57:178]: Executing op: ShortcutRemove(Name=Turkish)
MSI (s) (60:30) [10:53:57:191]: Executing op: ActionStart(Name=RemoveFiles,Description=Removing files,Template=File: [1], Directory: [9])
MSI (s) (60:30) [10:53:57:193]: Executing op: ProgressTotal(Total=58,Type=1,ByteEquivalent=175000)
MSI (s) (60:30) [10:53:57:195]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\)
MSI (s) (60:30) [10:53:57:195]: Executing op: FileRemove(,FileName=NeroControlCenter_cs-CZ.chm,,ComponentId={4C55C4F6-8B7C-41DD-963F-C3F340B169A1})
MSI (s) (60:30) [10:53:57:200]: Executing op: FileRemove(,FileName=NeroControlCenter_da-DK.chm,,ComponentId={C91EE7D0-690C-4FA5-BD7A-667140F49EE9})
MSI (s) (60:30) [10:53:57:207]: Executing op: FileRemove(,FileName=NeroControlCenter_de-DE.chm,,ComponentId={D55AD2A4-9731-4D1F-A070-7C08867D813D})
MSI (s) (60:30) [10:53:57:208]: Executing op: FileRemove(,FileName=NeroControlCenter_el-GR.chm,,ComponentId={8DCD6DDA-2280-4B9C-BF66-F26217843DF3})
MSI (s) (60:30) [10:53:57:208]: Executing op: FileRemove(,FileName=NeroControlCenter_en-GB.chm,,ComponentId={D01133F7-1526-41D5-AF6D-25C4C0FBEBD5})
MSI (s) (60:30) [10:53:57:208]: Executing op: FileRemove(,FileName=NeroControlCenter_en-US.chm,,ComponentId={CF0271AA-9CBC-4F2E-AD25-1136EBC92CC8})
MSI (s) (60:30) [10:53:57:209]: Executing op: FileRemove(,FileName=NeroControlCenter_es-ES.chm,,ComponentId={9E37A2A9-36F8-4D66-9029-6895CE475D9D})
MSI (s) (60:30) [10:53:57:209]: Executing op: FileRemove(,FileName=NeroControlCenter_fi-FI.chm,,ComponentId={025A5A13-B6C5-440D-A058-76D5AA5598E7})
MSI (s) (60:30) [10:53:57:210]: Executing op: FileRemove(,FileName=NeroControlCenter_fr-FR.chm,,ComponentId={EFAD83DA-049E-446F-A382-B3DCBC7FA605})
MSI (s) (60:30) [10:53:57:210]: Executing op: FileRemove(,FileName=NeroControlCenter_hu-HU.chm,,ComponentId={79FCE4CF-A773-4485-B031-FA09A4317D5D})
MSI (s) (60:30) [10:53:57:211]: Executing op: FileRemove(,FileName=NeroControlCenter_it-IT.chm,,ComponentId={65B993B5-2D5E-495B-ADC8-A2ACEF850B01})
MSI (s) (60:30) [10:53:57:211]: Executing op: FileRemove(,FileName=NeroControlCenter_ja-JP.chm,,ComponentId={9AB16FC7-C8A7-4F09-B46C-75EDF559962A})
MSI (s) (60:30) [10:53:57:211]: Executing op: FileRemove(,FileName=NeroControlCenter_ko-KR.chm,,ComponentId={D0C09419-71D8-42D4-8224-F097F744B90D})
MSI (s) (60:30) [10:53:57:212]: Executing op: FileRemove(,FileName=NeroControlCenter_nb-NO.chm,,ComponentId={7E4E808C-7249-4AF9-9C80-254015916A8F})
MSI (s) (60:30) [10:53:57:212]: Executing op: FileRemove(,FileName=NeroControlCenter_nl-NL.chm,,ComponentId={0CE41F0D-8F7E-43DD-8EDC-EDF1E96865D1})
MSI (s) (60:30) [10:53:57:213]: Executing op: FileRemove(,FileName=NeroControlCenter_pl-PL.chm,,ComponentId={5874CFEF-9288-47AB-9B5D-29AAEA5A5B55})
MSI (s) (60:30) [10:53:57:213]: Executing op: FileRemove(,FileName=NeroControlCenter_pt-BR.chm,,ComponentId={09BE3DEA-1718-47C8-B918-AC17F3DD49D7})
MSI (s) (60:30) [10:53:57:213]: Executing op: FileRemove(,FileName=NeroControlCenter_pt-PT.chm,,ComponentId={33BEB47B-65E6-4FDB-A294-707418381E7C})
MSI (s) (60:30) [10:53:57:214]: Executing op: FileRemove(,FileName=NeroControlCenter_ru-RU.chm,,ComponentId={01AF3CDE-6B53-46B2-BA91-ABFD2AA93340})
MSI (s) (60:30) [10:53:57:214]: Executing op: FileRemove(,FileName=NeroControlCenter_sv-SE.chm,,ComponentId={C5C90634-AEA8-4B78-A465-0094E9AC9790})
MSI (s) (60:30) [10:53:57:215]: Executing op: FileRemove(,FileName=NeroControlCenter_th-TH.chm,,ComponentId={F9EAA970-0D45-4A5E-AEC4-450C3D4979E2})
MSI (s) (60:30) [10:53:57:215]: Executing op: FileRemove(,FileName=NeroControlCenter_tr-TR.chm,,ComponentId={4E4FBA41-75BB-459C-B667-5E0C4DE5F00B})
MSI (s) (60:30) [10:53:57:215]: Executing op: FileRemove(,FileName=NeroControlCenter_zh-CN.chm,,ComponentId={42ED05DD-A455-453C-BB05-C0974A7CB0A2})
MSI (s) (60:30) [10:53:57:216]: Executing op: FileRemove(,FileName=NeroControlCenter_zh-TW.chm,,ComponentId={D0916F10-C695-4D27-9A24-7B58047CF3C5})
MSI (s) (60:30) [10:53:57:216]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\)
MSI (s) (60:30) [10:53:57:216]: Executing op: FileRemove(,FileName=HelpBase.dll,,ComponentId={3D79EBE8-F5A7-4D96-9CF6-0BFB653EA2B9})
MSI (s) (60:30) [10:53:57:216]: Executing op: FileRemove(,FileName=NeroHelpLang.dll,,ComponentId={B418197E-135F-459C-A384-57279CFC28B2})
MSI (s) (60:30) [10:53:57:217]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\cs-CZ\)
MSI (s) (60:30) [10:53:57:217]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={2176B58A-2510-4F90-A2F7-E406022FC8B3})
MSI (s) (60:30) [10:53:57:217]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\da-DK\)
MSI (s) (60:30) [10:53:57:218]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={48D24AB2-E2EF-4DF8-8223-42F4A1B30231})
MSI (s) (60:30) [10:53:57:218]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\de\)
MSI (s) (60:30) [10:53:57:218]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={79CF1702-F789-4A2B-B16A-D8B7BAF2680D})
MSI (s) (60:30) [10:53:57:218]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\de-DE\)
MSI (s) (60:30) [10:53:57:219]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={3EC88457-7AFC-461B-B966-F4A0DD06FBA2})
MSI (s) (60:30) [10:53:57:219]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\el-GR\)
MSI (s) (60:30) [10:53:57:219]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={09263913-2E40-46F2-A171-E0B06ECA5177})
MSI (s) (60:30) [10:53:57:219]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\en-GB\)
MSI (s) (60:30) [10:53:57:220]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={F77CA61A-7784-4450-AEB4-BE95BEEF364D})
MSI (s) (60:30) [10:53:57:220]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\en-US\)
MSI (s) (60:30) [10:53:57:220]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={75664931-926A-45D0-BFE4-7EF44348E026})
MSI (s) (60:30) [10:53:57:220]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\es\)
MSI (s) (60:30) [10:53:57:220]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={DD9DC842-C8E4-4119-B4A1-A54A79862466})
MSI (s) (60:30) [10:53:57:222]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\es-ES\)
MSI (s) (60:30) [10:53:57:223]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={8DA73776-B486-46AD-A544-58C3C1A0990F})
MSI (s) (60:30) [10:53:57:223]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\fi-FI\)
MSI (s) (60:30) [10:53:57:223]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={354D75FB-31BE-44B6-B1BE-F1CD4854547F})
MSI (s) (60:30) [10:53:57:224]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\fr\)
MSI (s) (60:30) [10:53:57:224]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={A1EC3F58-7B4E-4999-9BA9-EF404E70DA6B})
MSI (s) (60:30) [10:53:57:224]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\fr-FR\)
MSI (s) (60:30) [10:53:57:224]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={E9EE0783-28DE-49C1-B37E-571BDDA76653})
MSI (s) (60:30) [10:53:57:225]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\hu-HU\)
MSI (s) (60:30) [10:53:57:225]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={42DA5A33-F57F-4980-A70A-0D03D7E9B04F})
MSI (s) (60:30) [10:53:57:226]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\it\)
MSI (s) (60:30) [10:53:57:227]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={3085A40D-FA8C-4B10-BF37-D611743BA52C})
MSI (s) (60:30) [10:53:57:227]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\it-IT\)
MSI (s) (60:30) [10:53:57:227]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={1662FE81-23E2-4470-9259-BC556D6DB24C})
MSI (s) (60:30) [10:53:57:227]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\ja-JP\)
MSI (s) (60:30) [10:53:57:227]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={76A1BE2C-1EEE-4E8C-9416-927A0C4FF5B4})
MSI (s) (60:30) [10:53:57:228]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\ko-KR\)
MSI (s) (60:30) [10:53:57:228]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={97F412BD-5FDF-4659-B8FC-F2C2F8FA7AA9})
MSI (s) (60:30) [10:53:57:228]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\nb-NO\)
MSI (s) (60:30) [10:53:57:228]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={580F208E-2FCB-4440-875B-795B420A52EE})
MSI (s) (60:30) [10:53:57:229]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\nl\)
MSI (s) (60:30) [10:53:57:229]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={F45CEA63-31DD-428F-84F4-1F06E66AB0FE})
MSI (s) (60:30) [10:53:57:229]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\nl-NL\)
MSI (s) (60:30) [10:53:57:229]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={94C403CB-1BC8-4DFF-B22C-0C60A9E34AFE})
MSI (s) (60:30) [10:53:57:229]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\pl-PL\)
MSI (s) (60:30) [10:53:57:230]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={A747EF43-5D34-4549-A26D-589DE6747443})
MSI (s) (60:30) [10:53:57:230]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\pt\)
MSI (s) (60:30) [10:53:57:230]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={B089AA32-07DD-411D-881A-434E77E2622F})
MSI (s) (60:30) [10:53:57:230]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\pt-BR\)
MSI (s) (60:30) [10:53:57:230]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={F99D9C57-C536-4D7D-8D4E-F511F9FA1FFD})
MSI (s) (60:30) [10:53:57:231]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\pt-PT\)
MSI (s) (60:30) [10:53:57:231]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={A549D487-2C1E-4E83-A46B-82C193C36466})
MSI (s) (60:30) [10:53:57:231]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\ru-RU\)
MSI (s) (60:30) [10:53:57:232]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={216A14EE-E2A5-4363-BFF7-E163001D2B51})
MSI (s) (60:30) [10:53:57:232]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\sv-SE\)
MSI (s) (60:30) [10:53:57:232]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={B5BC2EFA-480D-4C4C-830E-2F0D9701D92A})
MSI (s) (60:30) [10:53:57:232]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\th-TH\)
MSI (s) (60:30) [10:53:57:232]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={527A7481-9B49-4B2C-A0A7-130E51F66113})
MSI (s) (60:30) [10:53:57:233]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\tr-TR\)
MSI (s) (60:30) [10:53:57:233]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={0D80221D-20E3-41BB-8341-641EF31B0C4D})
MSI (s) (60:30) [10:53:57:234]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\zh\)
MSI (s) (60:30) [10:53:57:234]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={F2E848CA-5C88-4A07-9018-47FFB7A464D4})
MSI (s) (60:30) [10:53:57:234]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\zh-CN\)
MSI (s) (60:30) [10:53:57:234]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={3EABB463-C74E-4C14-8832-36646C1889A0})
MSI (s) (60:30) [10:53:57:234]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\zh-HK\)
MSI (s) (60:30) [10:53:57:235]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={20E9642F-BD10-434E-8115-A2DA4F41CD49})
MSI (s) (60:30) [10:53:57:235]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\Help\zh-TW\)
MSI (s) (60:30) [10:53:57:235]: Executing op: FileRemove(,FileName=nerohelplang.dll.mui,,ComponentId={DCBBEFB3-F30F-4ADA-98B0-3A7DE7279960})
MSI (s) (60:30) [10:53:57:235]: Executing op: ProgressTotal(Total=16,Type=1,ByteEquivalent=175000)
MSI (s) (60:30) [10:53:57:235]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:236]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:237]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:240]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:241]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:242]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:243]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:244]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:245]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:246]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:247]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:248]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:250]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:251]: Executing op: FolderRemove(Folder=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\,Foreign=1)
MSI (s) (60:30) [10:53:57:252]: Executing op: ActionStart(Name=PublishProduct,Description=Publishing product information,)
Nissi1
MSI (s) (60:30) [10:53:57:252]: Executing op: CleanupConfigData()
MSI (s) (60:30) [10:53:57:252]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=0,Remove=1)
MSI (s) (60:30) [10:53:57:253]: Note: 1: 1402 2: UNKNOWN\Installer\Products\B1B2B325BD8D14B409FF4C7D992E57A8\Patches 3: 2
MSI (s) (60:30) [10:53:57:253]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=1,Remove=1)
MSI (s) (60:30) [10:53:57:253]: Executing op: CleanupConfigData(RemovingProduct=1)
MSI (s) (60:30) [10:53:57:253]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\B1B2B325BD8D14B409FF4C7D992E57A8\Patches 3: 2
MSI (s) (60:30) [10:53:57:253]: Executing op: ActionStart(Name=Nero_CA_UninstallSetAssociationsRollback,,)
MSI (s) (60:30) [10:53:57:259]: Executing op: CustomActionSchedule(Action=Nero_CA_UninstallSetAssociationsRollback,ActionType=1281,Source=BinaryData,Target=CA_UninstallSetAssociationsRollback,)
MSI (s) (60:30) [10:53:57:262]: Executing op: ActionStart(Name=Nero_CA_UninstallSetAssociations,,)
MSI (s) (60:30) [10:53:57:263]: Executing op: CustomActionSchedule(Action=Nero_CA_UninstallSetAssociations,ActionType=1025,Source=BinaryData,Target=CA_UninstallSetAssociations,)
MSI (s) (60:54) [10:53:57:284]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIFBA1.tmp, Entrypoint: CA_UninstallSetAssociations
MSI (s) (60:30) [10:53:57:513]: Executing op: ActionStart(Name=Nero_CA_DeleteAssociationsBackup,,)
CA_UninstallSetAssociations: CustomActions.cpp : 1016 :  Succeeded
MSI (s) (60:30) [10:53:57:514]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteAssociationsBackup,ActionType=1537,Source=BinaryData,Target=CA_DeleteAssociationsBackup,CustomActionData={523B2B1B-D8DB-4B41-90FF-C4D799E2758A}|)
MSI (s) (60:30) [10:53:57:526]: Executing op: ActionStart(Name=Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore,,)
MSI (s) (60:30) [10:53:57:527]: Executing op: CustomActionSchedule(Action=Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore,ActionType=1537,Source=BinaryData,Target=CA_MergeLocalFileAssociationDbToGlobalAndRestore,CustomActionData={523B2B1B-D8DB-4B41-90FF-C4D799E2758A})
MSI (s) (60:30) [10:53:57:530]: Executing op: ActionStart(Name=InstallFinalize,,)
MSI (s) (60:30) [10:53:57:531]: Executing op: CleanupTempFiles(TempFiles=C:\WINDOWS\Installer\33a1c1a5.mst)
MSI (s) (60:30) [10:53:57:531]: Scheduling file 'C:\WINDOWS\Installer\33a1c1a5.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:30) [10:53:57:532]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=14537600)
MSI (s) (60:30) [10:53:57:552]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:30) [10:53:57:564]: User policy value 'DisableRollback' is 0
MSI (s) (60:30) [10:53:57:564]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:30) [10:53:57:564]: Unlocking Server
MSI (s) (60:30) [10:53:57:567]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
Action ended 10:53:57: InstallFinalize. Return value 1.
Action ended 10:53:57: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {DB1A16FB-84D6-4824-A7E5-26B7BB9B1CA7}
Property(S): ProductCode = {523B2B1B-D8DB-4B41-90FF-C4D799E2758A}
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): Installed = 2011/03/04 11:06:00
Property(S): CostingComplete = 1
Property(S): ROOTDRIVE = C:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): UILevel = 3
Property(S): OriginalDatabase = C:\Windows\Installer\11a7e.msi
Property(S): DATABASE = C:\Windows\Installer\11a7e.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.3.14393.0
Property(S): MsiNetAssemblySupport = 4.6.1586.0
Property(S): Date = 6/11/2017
Property(S): Time = 10:53:57
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 23
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 1033
Property(S): ComputerName = ZANDRAJONES-PC
Property(S): UserLanguageID = 1033
Property(S): UserSID = S-1-5-21-3088507388-2561779440-336279174-1001
Property(S): LogonUser = Zandra Jones
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 5077
Property(S): PhysicalMemory = 3839
Property(S): Intel = 16
Property(S): Msix64 = 16
Property(S): MsiAMD64 = 16
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): MyPicturesFolder = C:\Users\Zandra Jones\Pictures\
Property(S): RecentFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): VersionNT = 603
Property(S): Nero_CA_DeleteAssociationsBackup = {523B2B1B-D8DB-4B41-90FF-C4D799E2758A}|
Property(S): Nero_CA_DeleteLocalFileAssociationDb = {523B2B1B-D8DB-4B41-90FF-C4D799E2758A}
Property(S): Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore = {523B2B1B-D8DB-4B41-90FF-C4D799E2758A}
Property(S): TARGETDIR = C:\
Property(S): ALLUSERSPROFILE = C:\ProgramData\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Nero\Nero 10\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Nero\Nero 10\Database\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FavoritesFolder = C:\Users\Zandra Jones\Favorites\
Property(S): FontsFolder = C:\WINDOWS\Fonts\
Property(S): GlobalAssemblyCache = C:\
Property(S): NERO_PRODUCT = C:\Program Files (x86)\Nero\Nero 10\
Property(S): INSTALLDIR = C:\Program Files (x86)\Nero\Nero 10\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Zandra Jones\AppData\Local\
Property(S): NERO = C:\Program Files (x86)\Nero\
Property(S): NERO_CONTROLCENTER_HELP_CHM = C:\Program Files (x86)\Nero\Help\
Property(S): PersonalFolder = C:\Users\Zandra Jones\Documents\
Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): ScManualsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\
Property(S): ScControlCenterManualsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\Nero Help\Nero ControlCenter\
Property(S): ScProductFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 10\
Property(S): ScNeroFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\
Property(S): SendToFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System16Folder = C:\
Property(S): System64Folder = C:\WINDOWS\SysWOW64\
Property(S): SystemFolder = C:\WINDOWS\SysWOW64\
Property(S): TempFolder = C:\Users\ZANDRA~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = C:\Users\Zandra Jones\
Property(S): WindowsFolder = C:\WINDOWS\
Property(S): NetHoodFolder = C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): COMP_INSTALL_DIR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\
Property(S): CS_CZ.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\cs-CZ\
Property(S): DA_DK.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\da-DK\
Property(S): DE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\de\
Property(S): DE_DE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\de-DE\
Property(S): EL_GR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\el-GR\
Property(S): EN_GB.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\en-GB\
Property(S): EN_US.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\en-US\
Property(S): ES.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\es\
Property(S): ES_ES.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\es-ES\
Property(S): FI_FI.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\fi-FI\
Property(S): FR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\fr\
Property(S): FR_FR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\fr-FR\
Property(S): HU_HU.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\hu-HU\
Property(S): IT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\it\
Property(S): IT_IT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\it-IT\
Property(S): JA_JP.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\ja-JP\
Property(S): KO_KR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\ko-KR\
Property(S): NB_NO.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\nb-NO\
Property(S): NL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\nl\
Property(S): NL_NL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\nl-NL\
Property(S): PL_PL.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\pl-PL\
Property(S): PT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\pt\
Property(S): PT_BR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\pt-BR\
Property(S): PT_PT.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\pt-PT\
Property(S): RU_RU.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\ru-RU\
Property(S): SV_SE.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\sv-SE\
Property(S): TH_TH.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\th-TH\
Property(S): TR_TR.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\tr-TR\
Property(S): ZH.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\zh\
Property(S): ZH_CN.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\zh-CN\
Property(S): ZH_HK.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\zh-HK\
Property(S): ZH_TW.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = C:\Program Files (x86)\Nero\Help\zh-TW\
Property(S): ARPPRODUCTICON = NeroHelpIcon.BBDB24D3_07A5_496B_AA18_6A3ED03D6698
Property(S): IS_INSTALLLOC_FOUND.BBDB24D3_07A5_496B_AA18_6A3ED03D6698 = 0
Property(S): Nero.MainComponent = {3D79EBE8-F5A7-4D96-9CF6-0BFB653EA2B9}
Property(S): ARPURLINFOABOUT = http://www.nero.com/
Property(S): AppDataFolder = C:\Users\Zandra Jones\AppData\Roaming\
Property(S): RemoteAdminTS = 1
Property(S): WindowsVolume = C:\
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 9600
Property(S): VersionNT64 = 603
Property(S): VersionMsi = 5.00
Property(S): VersionDatabase = 200
Property(S): BROWSERPATH = C:\Program Files (x86)\Mozilla Firefox\firefox.exe
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): _IsMaintenance = Change
Property(S): RestartManagerOption = CloseRestart
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): Display_IsBitmapDlg = 1
Property(S): NERO.INSTALL_AUTOPLAY = 0
Property(S): NERO.INSTALL_DESKTOPSHORTCUT = 0
Property(S): NERO.INSTALL_EXTENSIONS = 0
Property(S): ALLUSERS = 1
Property(S): ARPNOMODIFY = 1
Property(S): ARPNOREPAIR = 0
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): AgreeToLicense = No
Property(S): DWUSINTERVAL = 30
Property(S): DWUSLINK = CEDC87AF3EEC9728FEACA09FCECC978F3E1CA78FDEFBD0E8CEFC97BFAEABF0CFBECCF098D9AC
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): PRODUCTLANGUAGE = 0
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): ErrorDialog = SetupError
Property(S): INSTALLLEVEL = 100
Property(S): ISVROOT_PORT_NO = 0
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PREVENT_DOWNGRADE_EXIT = A newer version of this application is already installed on this computer. If you wish to install this version, please uninstall the newer version first. Click OK to exit the wizard.
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): InstallChoice = AR
Property(S): MSIDISABLERMRESTART = 0
Property(S): MSIRMSHUTDOWN = 0
Property(S): MsiSystemRebootPending = 1
Property(S): Manufacturer = Nero AG
Property(S): NERO.APPID = 65599
Property(S): NERO.INSTALLER_CATEGORY = 2
Property(S): NERO.LANGUAGES_INSTALL = zh-TW,cs-CZ,da-DK,de-DE,el-GR,en-US,en-GB,es-ES,fi-FI,fr-FR,hu-HU,it-IT,ja-JP,ko-KR,nl-NL,nb-NO,pl-PL,pt-BR,pt-PT,ru-RU,sv-SE,th-TH,tr-TR,zh-CN
Property(S): NERO.LANGUAGE_CURRENT = en-US
Property(S): NERO.PRODUCT_LINE = NeroX
Property(S): Nero.AppDesc = Nero ControlCenter Help Files (CHM)
Property(S): Nero.AppSubKey = NeroControlCenterHelpChm
Property(S): Nero.GenerationId = 10
Property(S): Nero.GenerationName = Nero 10
Property(S): Nero.InstallDirId = NERO_CONTROLCENTER_HELP_CHM
Property(S): Nero.PackageName = CHM_NCC
Property(S): Nero.TemplateRev = 197263
Property(S): Nero.mediaPath = \controlcenterhelpchm\
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = Nero ControlCenter 10 Help (CHM)
Property(S): ProductVersion = 10.2.10800
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): SecureCustomProperties = INSTALLDIR;ISFOUNDNEWERPRODUCTVERSION;IS_MINOR_UPGRADE;MEDIAPACKAGEPATH;MSIRESTARTMANAGERCONTROL;MSIDISABLERMRESTART;MSIRMSHUTDOWN;NERO.INSTALL_DESKTOPSHORTCUT;NERO.INCLUDED_KEY;NERO.INSTALL_AUTOPLAY;NERO.INSTALL_EXTENSIONS;NERO.INSTALLER_CATEGORY;NERO.IS_EULA_ACCEPTED;NERO.LANGUAGE_CURRENT;NERO.PRODUCT_LINE;NERO.IS_CHAINED;REBOOT;REINSTALL;REINSTALLMODE;SUPPORTDIR;TRANSFORMS
Property(S): ISReleaseFlags = Application,Languages,SystemIntegration
Property(S): MsiLogFileLocation = C:\Users\ZANDRA~1\AppData\Local\Temp\MSI1b9f9.LOG
Property(S): ARPINSTALLLOCATION = C:\Program Files (x86)\Nero\Nero 10\
Property(S): CLIENTPROCESSID = 8728
Property(S): CLIENTUILEVEL = 2
Property(S): CURRENTDIRECTORY = C:\WINDOWS\system32
Property(S): REMOVE = ALL
Property(S): ISCHAINER = 1
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): REBOOT = ReallySuppress
Property(S): NERO.IS_CHAINED = YES
Property(S): ProductState = 5
Property(S): TRANSFORMS = C:\Windows\Installer\{523B2B1B-D8DB-4B41-90FF-C4D799E2758A}\1033.mst
Property(S): PackageCode = {1A7F010E-8947-468D-A021-92CE03780E30}
Property(S): COMPANYNAME = Microsoft
Property(S): USERNAME = AutoBVT
MSI (s) (60:30) [10:53:57:631]: Note: 1: 1724
MSI (s) (60:30) [10:53:57:632]: Product: Nero ControlCenter 10 Help (CHM) -- Removal completed successfully.
MSI (s) (60:30) [10:53:57:633]: Windows Installer removed the product. Product Name: Nero ControlCenter 10 Help (CHM). Product Version: 10.2.10800. Product Language: 1033. Manufacturer: Nero AG. Removal success or error status: 0.
MSI (s) (60:30) [10:53:57:634]: Attempting to delete file C:\WINDOWS\Installer\33a1c1a5.mst
MSI (s) (60:30) [10:53:57:658]: Deferring clean up of packages/files, if any exist
MSI (s) (60:30) [10:53:57:658]: Attempting to delete file C:\WINDOWS\Installer\33a1c1a5.mst
MSI (s) (60:30) [10:53:57:658]: Unable to delete the file outside of the engine. LastError = 2
MSI (s) (60:30) [10:53:57:658]: MainEngineThread is returning 0
=== Logging stopped: 6/11/2017  10:53:57 ===
MSI (c) (18:F4) [10:53:57:665]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
MSI (c) (18:F4) [10:53:57:666]: MainEngineThread is returning 0
=== Verbose logging stopped: 6/11/2017  10:53:57 ===
=== Verbose logging started: 6/11/2017  10:53:57  Build type: SHIP UNICODE 5.00.10011.00  Calling process: C:\Users\ZANDRA~1\AppData\Local\Temp\MSIE858.tmp ===
MSI (c) (18:98) [10:53:57:695]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (18:98) [10:53:57:696]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (18:18) [10:53:57:709]: Resetting cached policy values
MSI (c) (18:18) [10:53:57:709]: Machine policy value 'Debug' is 0
MSI (c) (18:18) [10:53:57:709]: ******* RunEngine:
           ******* Product: C:\Windows\Installer\11a68.msi
           ******* Action:
           ******* CommandLine: **********
MSI (c) (18:18) [10:53:57:709]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (18:18) [10:54:00:716]: Failed to grab execution mutex. System error 258.
MSI (c) (18:18) [10:54:00:716]: Cloaking enabled.
MSI (c) (18:18) [10:54:00:716]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (18:18) [10:54:00:716]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (60:38) [10:54:00:716]: Running installation inside multi-package transaction C:\Windows\Installer\11a49.msi
MSI (s) (60:38) [10:54:00:716]: Grabbed execution mutex.
MSI (s) (60:80) [10:54:00:716]: Resetting cached policy values
MSI (s) (60:80) [10:54:00:716]: Machine policy value 'Debug' is 0
MSI (s) (60:80) [10:54:00:716]: ******* RunEngine:
           ******* Action:
MSI (s) (60:80) [10:54:00:769]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (60:80) [10:54:00:816]: MSCOREE not loaded loading copy from system32
MSI (s) (60:80) [10:54:00:816]: End dialog not enabled
MSI (s) (60:80) [10:54:00:816]: Original package ==> C:\Windows\Installer\11a68.msi
MSI (s) (60:80) [10:54:00:816]: Package we're running from ==> C:\Windows\Installer\11a68.msi
MSI (s) (60:80) [10:54:00:816]: APPCOMPAT: Uninstall Flags override found.
MSI (s) (60:80) [10:54:00:816]: APPCOMPAT: Uninstall VersionNT override found.
MSI (s) (60:80) [10:54:00:816]: APPCOMPAT: Uninstall ServicePackLevel override found.
MSI (s) (60:80) [10:54:00:816]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}'.
MSI (s) (60:80) [10:54:00:816]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (60:80) [10:54:00:832]: Machine policy value 'DisablePatch' is 0
MSI (s) (60:80) [10:54:00:832]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (60:80) [10:54:00:832]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (60:80) [10:54:00:832]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (60:80) [10:54:00:832]: Looking for file transform: C:\Windows\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst
MSI (s) (60:80) [10:54:00:848]: File will have security applied from OpCode.
MSI (s) (60:80) [10:54:00:870]: Original transform ==> C:\Windows\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst
MSI (s) (60:80) [10:54:00:870]: Transform we're running from ==> C:\WINDOWS\Installer\33a1c1a9.mst
MSI (s) (60:80) [10:54:00:870]: SOFTWARE RESTRICTION POLICY: Verifying transform --> 'C:\Windows\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst' against software restriction policy
MSI (s) (60:80) [10:54:00:870]: SOFTWARE RESTRICTION POLICY: C:\Windows\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst has a digital signature
MSI (s) (60:80) [10:54:00:885]: SOFTWARE RESTRICTION POLICY: C:\Windows\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst is permitted to run at the 'unrestricted' authorization level.
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: _Tables 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: _Columns 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Media 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: File 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: TRANSFORM: 'PatchPackage' table is missing or empty.  No pre-transform fixup necessary.
MSI (s) (60:80) [10:54:00:885]: TRANSFORM: Applying regular transform to database.
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: ActionText 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: AdminExecuteSequence 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: AdminUISequence 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: AdvtExecuteSequence 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: AdvtUISequence 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: AppSearch 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Feature 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Binary 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: CheckBox 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Class 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Component 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Icon 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: ComboBox 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Directory 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Control 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Dialog 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: ControlCondition 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: ControlEvent 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: CreateFolder 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: CustomAction 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: ModuleSignature 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Error 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: EventMapping 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: FeatureComponents 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: InstallExecuteSequence 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: InstallUISequence 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: LaunchCondition 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: ListBox 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: ListView 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: ModuleComponents 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: MsiFileHash 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: RadioButton 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Registry 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: RegLocator 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: TextStyle 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: UIText 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: Upgrade 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: _Validation 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: ISComponentExtended 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: ISCustomActionReference 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: ISDFLInfo 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: _MsiPatchTransformView 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: #_BaselineCost 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: #_BaselineFile 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: #_BaselineData 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: #_PatchCache 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: MsiPatchCertificate 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: MsiDigitalCertificate 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}'.
MSI (s) (60:80) [10:54:00:885]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (60:80) [10:54:00:885]: Transforms are not secure.
MSI (s) (60:80) [10:54:00:885]: Transforming table Property.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\ZANDRA~1\AppData\Local\Temp\MSI1b9f9.LOG'.
MSI (s) (60:80) [10:54:00:885]: Command Line: NERO.IS_CHAINED=YES REBOOT=ReallySuppress MSIRESTARTMANAGERCONTROL=Disable ISCHAINER=1 REMOVE=ALL CURRENTDIRECTORY=C:\WINDOWS\system32 CLIENTUILEVEL=2 CLIENTPROCESSID=8728
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{B9F7A147-EE44-48AE-B20E-9D2DCE597782}'.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding TRANSFORMS property. Its value is 'C:\Windows\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst'.
MSI (s) (60:80) [10:54:00:885]: Product Code passed to Engine.Initialize:           '{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}'
MSI (s) (60:80) [10:54:00:885]: Product Code from property table before transforms: '{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}'
MSI (s) (60:80) [10:54:00:885]: Product Code from property table after transforms:  '{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}'
MSI (s) (60:80) [10:54:00:885]: Product registered: entering maintenance mode
MSI (s) (60:80) [10:54:00:885]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI (s) (60:80) [10:54:00:885]: Product {F5CB822F-B365-43D1-BCC0-4FDA1A2017A7} is admin assigned: LocalSystem owns the publish key.
MSI (s) (60:80) [10:54:00:885]: Product {F5CB822F-B365-43D1-BCC0-4FDA1A2017A7} is managed.
MSI (s) (60:80) [10:54:00:885]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding ProductState property. Its value is '5'.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI (s) (60:80) [10:54:00:885]: Package name retrieved from configuration data: 'Nero.MovieThemePackBasic.msi'
MSI (s) (60:80) [10:54:00:885]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (60:80) [10:54:00:885]: Machine policy value 'DisableMsi' is 0
MSI (s) (60:80) [10:54:00:885]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:80) [10:54:00:885]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:80) [10:54:00:885]: Running product '{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}' with elevated privileges: Product is assigned.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding NERO.IS_CHAINED property. Its value is 'YES'.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding REBOOT property. Its value is 'ReallySuppress'.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding MSIRESTARTMANAGERCONTROL property. Its value is 'Disable'.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding ISCHAINER property. Its value is '1'.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding REMOVE property. Its value is 'ALL'.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\WINDOWS\system32'.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '2'.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '8728'.
MSI (s) (60:80) [10:54:00:885]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (60:80) [10:54:00:885]: RESTART MANAGER: Disabled by MSIRESTARTMANAGERCONTROL property; Windows Installer will use the built-in FilesInUse functionality.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (s) (60:80) [10:54:00:885]: TRANSFORMS property is now: C:\Windows\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '0'.
MSI (s) (60:80) [10:54:00:885]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (60:80) [10:54:00:901]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming
MSI (s) (60:80) [10:54:00:901]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Favorites
MSI (s) (60:80) [10:54:00:901]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (60:80) [10:54:00:901]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Documents
MSI (s) (60:80) [10:54:00:901]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (60:80) [10:54:00:901]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (60:80) [10:54:00:916]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (60:80) [10:54:00:916]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (60:80) [10:54:00:916]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (60:80) [10:54:00:916]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Local
MSI (s) (60:80) [10:54:00:916]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Pictures
MSI (s) (60:80) [10:54:00:916]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (60:80) [10:54:00:916]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (60:80) [10:54:00:932]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
MSI (s) (60:80) [10:54:00:932]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (60:80) [10:54:00:932]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (60:80) [10:54:00:932]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (60:80) [10:54:00:950]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\Start Menu
MSI (s) (60:80) [10:54:00:952]: SHELL32::SHGetFolderPath returned: C:\Users\Zandra Jones\Desktop
MSI (s) (60:80) [10:54:00:954]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (s) (60:80) [10:54:00:954]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (s) (60:80) [10:54:00:954]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (60:80) [10:54:00:954]: MSI_LUA: Setting AdminUser property to 1 because the product is already installed managed and per-machine
MSI (s) (60:80) [10:54:00:954]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (60:80) [10:54:00:954]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (s) (60:80) [10:54:00:954]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (60:80) [10:54:00:954]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'AutoBVT'.
MSI (s) (60:80) [10:54:00:954]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Microsoft'.
MSI (s) (60:80) [10:54:00:954]: PROPERTY CHANGE: Adding Installed property. Its value is '2010/10/07 12:23:02'.
MSI (s) (60:80) [10:54:00:954]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\11a68.msi'.
MSI (s) (60:80) [10:54:00:954]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Windows\Installer\11a68.msi'.
MSI (s) (60:80) [10:54:00:954]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (s) (60:80) [10:54:00:954]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:80) [10:54:00:954]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:80) [10:54:00:954]: User policy value 'DisableRollback' is 0
MSI (s) (60:80) [10:54:00:954]: PROPERTY CHANGE: Adding UILevel property. Its value is '3'.
=== Logging started: 6/11/2017  10:54:00 ===
MSI (s) (60:80) [10:54:00:985]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:80) [10:54:00:985]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
MSI (s) (60:80) [10:54:00:985]: APPCOMPAT: [DetectVersionLaunchCondition] Launch condition already passes.
MSI (s) (60:80) [10:54:00:985]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (60:80) [10:54:00:985]: Doing action: INSTALL
Action start 10:54:00: INSTALL.
MSI (s) (60:80) [10:54:00:985]: Running ExecuteSequence
MSI (s) (60:80) [10:54:00:985]: Skipping action: ISSetAllUsers (condition is false)
MSI (s) (60:80) [10:54:00:985]: Doing action: AppSearch
Action start 10:54:00: AppSearch.
MSI (s) (60:80) [10:54:00:985]: PROPERTY CHANGE: Modifying BROWSERPATH property. Its current value is 'c:\program files\internet explorer\iexplore.exe'. Its new value: 'C:\Program Files (x86)\Mozilla Firefox\firefox.exe'.
MSI (s) (60:80) [10:54:00:985]: Skipping action: LaunchConditions (condition is false)
MSI (s) (60:80) [10:54:00:985]: Doing action: FindRelatedProducts
Action ended 10:54:00: AppSearch. Return value 1.
MSI (s) (60:80) [10:54:00:985]: Skipping FindRelatedProducts action: not run in maintenance mode
Action start 10:54:00: FindRelatedProducts.
MSI (s) (60:80) [10:54:00:985]: Skipping action: ISPreventDowngrade (condition is false)
MSI (s) (60:80) [10:54:00:985]: Skipping action: CCPSearch (condition is false)
MSI (s) (60:80) [10:54:00:985]: Skipping action: RMCCPSearch (condition is false)
MSI (s) (60:80) [10:54:00:985]: Doing action: ValidateProductID
Action ended 10:54:00: FindRelatedProducts. Return value 0.
Action start 10:54:00: ValidateProductID.
MSI (s) (60:80) [10:54:00:985]: Skipping action: Nero_CA_SetExtensions (condition is false)
MSI (s) (60:80) [10:54:00:985]: Skipping action: Nero_CA_SetDesktopShortcuts (condition is false)
MSI (s) (60:80) [10:54:00:985]: Skipping action: Nero_CA_SetAutoplay (condition is false)
MSI (s) (60:80) [10:54:00:985]: Skipping action: Nero_CA_SetUserProperties (condition is false)
MSI (s) (60:80) [10:54:00:985]: Doing action: Nero_CAD_DeleteLocalFileAssociationDb
Action ended 10:54:00: ValidateProductID. Return value 1.
MSI (s) (60:80) [10:54:00:985]: PROPERTY CHANGE: Adding Nero_CA_DeleteLocalFileAssociationDb property. Its value is '{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}'.
Action start 10:54:00: Nero_CAD_DeleteLocalFileAssociationDb.
MSI (s) (60:80) [10:54:00:985]: Doing action: Nero_CA_GenerateFileAssociationList
Action ended 10:54:00: Nero_CAD_DeleteLocalFileAssociationDb. Return value 1.
MSI (s) (60:E8) [10:54:01:001]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIA38.tmp, Entrypoint: CA_GenerateFileAssociationList
Action start 10:54:00: Nero_CA_GenerateFileAssociationList.
MSI (s) (60:80) [10:54:01:070]: Doing action: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore
Action ended 10:54:01: Nero_CA_GenerateFileAssociationList. Return value 1.
MSI (s) (60:80) [10:54:01:070]: PROPERTY CHANGE: Adding Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore property. Its value is '{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}'.
Action start 10:54:01: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore.
MSI (s) (60:80) [10:54:01:070]: Doing action: Nero_CAD_DeleteAssociationsBackup
Action ended 10:54:01: Nero_CAD_MergeLocalFileAssociationDbToGlobalAndRestore. Return value 1.
MSI (s) (60:80) [10:54:01:070]: PROPERTY CHANGE: Adding Nero_CA_DeleteAssociationsBackup property. Its value is '{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}|'.
Action start 10:54:01: Nero_CAD_DeleteAssociationsBackup.
MSI (s) (60:80) [10:54:01:070]: Doing action: Nero_CAD_Install_SetAssociations
Action ended 10:54:01: Nero_CAD_DeleteAssociationsBackup. Return value 1.
Action start 10:54:01: Nero_CAD_Install_SetAssociations.
MSI (s) (60:80) [10:54:01:070]: Doing action: Nero_CAD_Install_SetAssociationsRollback
Action ended 10:54:01: Nero_CAD_Install_SetAssociations. Return value 1.
Action start 10:54:01: Nero_CAD_Install_SetAssociationsRollback.
MSI (s) (60:80) [10:54:01:070]: Doing action: Nero_CAD_Uninstall_SetAssociations
Action ended 10:54:01: Nero_CAD_Install_SetAssociationsRollback. Return value 1.
Action start 10:54:01: Nero_CAD_Uninstall_SetAssociations.
MSI (s) (60:80) [10:54:01:070]: Doing action: Nero_CAD_Uninstall_SetAssociationsRollback
Action ended 10:54:01: Nero_CAD_Uninstall_SetAssociations. Return value 1.
Action start 10:54:01: Nero_CAD_Uninstall_SetAssociationsRollback.
MSI (s) (60:80) [10:54:01:070]: Doing action: CostInitialize
Action ended 10:54:01: Nero_CAD_Uninstall_SetAssociationsRollback. Return value 1.
MSI (s) (60:80) [10:54:01:070]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (s) (60:80) [10:54:01:070]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI (s) (60:80) [10:54:01:070]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (60:80) [10:54:01:070]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (60:80) [10:54:01:070]: Note: 1: 2205 2:  3: PatchPackage
MSI (s) (60:80) [10:54:01:070]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (60:80) [10:54:01:070]: Note: 1: 2205 2:  3: __MsiPatchFileList
MSI (s) (60:80) [10:54:01:070]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
Action start 10:54:01: CostInitialize.
MSI (s) (60:80) [10:54:01:086]: Skipping action: ResolveSource (condition is false)
MSI (s) (60:80) [10:54:01:086]: Doing action: FileCost
Action ended 10:54:01: CostInitialize. Return value 1.
MSI (s) (60:80) [10:54:01:086]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:80) [10:54:01:086]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:80) [10:54:01:086]: Note: 1: 2205 2:  3: TypeLib
Action start 10:54:01: FileCost.
MSI (s) (60:80) [10:54:01:086]: Doing action: IsolateComponents
Action ended 10:54:01: FileCost. Return value 1.
Action start 10:54:01: IsolateComponents.
MSI (s) (60:80) [10:54:01:086]: Doing action: setUserProfileNT
Action ended 10:54:01: IsolateComponents. Return value 0.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Zandra Jones'.
Action start 10:54:01: setUserProfileNT.
MSI (s) (60:80) [10:54:01:086]: Skipping action: SetAllUsersProfileNT (condition is false)
MSI (s) (60:80) [10:54:01:086]: Doing action: setAllUsersProfile2K
Action ended 10:54:01: setUserProfileNT. Return value 1.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
Action start 10:54:01: setAllUsersProfile2K.
MSI (s) (60:80) [10:54:01:086]: Doing action: CostFinalize
Action ended 10:54:01: setAllUsersProfile2K. Return value 1.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (60:80) [10:54:01:086]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding SMART3D property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D'.
Nissi1
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding AUDIO property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Audio'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding MOVIEWIZARD property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding STANDARD2D property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding CONTENT_PACK_BASE_DIR property. Its value is 'C:\Program Files (x86)\Nero\NeroContent'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _24CFE834C76B4F6987AC58D563593FC5 property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Audio\movingwalls_nsla'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _AC8A68EFFC2D4D25AAA0384E2B4B91A4 property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Audio\oldfilm_nsla'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _422AE2E4A86D48A09F91523B7851F097 property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Audio\slideshow1_nsla'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _DDBAFAAB8CD94096A2D8C92FD3AEADBE property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\MovingWalls'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _06CD8A166C7145FE9968183A70A191DC property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\OldFilm'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _FCDAB9BD86B24530912B860B63967352 property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\Slideshow1'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _5FE23C7D36F5473188A6DEF41E840A6C property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _A384339D049443119A845059E6673E1E property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _44225752A7854E158523D3F2082B3147 property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\MovingWalls'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _6951875C8E0E44288D34383F087AD2CE property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _04FA6424B4D64411A91974F6800FC99E property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\MovingWalls'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _F44BBEC9DB4242DD87260C130A11364F property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _214B79D549344F3B8180698D7739C937 property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Movement'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _D9352A49F30E437AB4881AD615C5115A property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\OldFilm'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _F0254BC6E7DB4E22B65B700B589ECA4D property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Slideshow'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _4E0ABE6DA6CD40198A39C791D3B1DDF3 property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _A8FC11ED064B4065A0CA4C4CA3AB98E6 property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Movement'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _E3A68969D2AE4B35AE3CDE3E6D33CE19 property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\OldFilm'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding _CFC2AE216EB7495D8A422FB00B5EC54F property. Its value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Slideshow'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding COMP_INSTALL_DIR.E455A55D_C7C4_4A4C_8F90_B137097E5BCF property. Its value is 'C:\Program Files (x86)\Nero\NeroContent'.
MSI (s) (60:80) [10:54:01:086]: Note: 1: 2205 2:  3: Condition
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Zandra Jones'. Its new value: 'C:\Users\Zandra Jones\'.
MSI (s) (60:80) [10:54:01:086]: WIN64DUALFOLDERS: 'C:\WINDOWS\SysWOW64\' will substitute 20 characters in 'C:\WINDOWS\system32\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 1).
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Modifying System64Folder property. Its current value is 'C:\WINDOWS\system32\'. Its new value: 'C:\WINDOWS\SysWOW64\'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding System16Folder property. Its value is 'C:\'.
MSI (s) (60:80) [10:54:01:086]: WIN64DUALFOLDERS: 'C:\Program Files (x86)\' will substitute 17 characters in 'C:\Program Files\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Modifying ProgramFiles64Folder property. Its current value is 'C:\Program Files\'. Its new value: 'C:\Program Files (x86)\'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding GlobalAssemblyCache property. Its value is 'C:\'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
MSI (s) (60:80) [10:54:01:086]: WIN64DUALFOLDERS: 'C:\Program Files (x86)\' will substitute 17 characters in 'C:\Program Files\Common Files\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:086]: PROPERTY CHANGE: Modifying CommonFiles64Folder property. Its current value is 'C:\Program Files\Common Files\'. Its new value: 'C:\Program Files (x86)\Common Files\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Adding ISMyCompanyDir property. Its value is 'C:\Program Files (x86)\My Company Name\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Adding ISMyProductDir property. Its value is 'C:\Program Files (x86)\My Company Name\My Product Name\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Adding NERO property. Its value is 'C:\Program Files (x86)\Nero\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Adding NERO_PRODUCT property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Adding ISYourDataBaseDir property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\Database\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Adding DATABASEDIR property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\Database\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying CONTENT_PACK_BASE_DIR property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying COMP_INSTALL_DIR.E455A55D_C7C4_4A4C_8F90_B137097E5BCF property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying STANDARD2D property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _4E0ABE6DA6CD40198A39C791D3B1DDF3 property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _CFC2AE216EB7495D8A422FB00B5EC54F property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Slideshow'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Slideshow\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _E3A68969D2AE4B35AE3CDE3E6D33CE19 property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\OldFilm'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\OldFilm\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _A8FC11ED064B4065A0CA4C4CA3AB98E6 property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Movement'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Movement\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _F44BBEC9DB4242DD87260C130A11364F property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _F0254BC6E7DB4E22B65B700B589ECA4D property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Slideshow'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Slideshow\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _D9352A49F30E437AB4881AD615C5115A property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\OldFilm'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\OldFilm\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _214B79D549344F3B8180698D7739C937 property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Movement'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Movement\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying SMART3D property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _5FE23C7D36F5473188A6DEF41E840A6C property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _6951875C8E0E44288D34383F087AD2CE property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _04FA6424B4D64411A91974F6800FC99E property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\MovingWalls'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\MovingWalls\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _A384339D049443119A845059E6673E1E property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _44225752A7854E158523D3F2082B3147 property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\MovingWalls'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\MovingWalls\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying MOVIEWIZARD property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _FCDAB9BD86B24530912B860B63967352 property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\Slideshow1'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\Slideshow1\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _06CD8A166C7145FE9968183A70A191DC property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\OldFilm'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\OldFilm\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _DDBAFAAB8CD94096A2D8C92FD3AEADBE property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\MovingWalls'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\MovingWalls\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying AUDIO property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Audio'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Audio\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _422AE2E4A86D48A09F91523B7851F097 property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Audio\slideshow1_nsla'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Audio\slideshow1_nsla\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _AC8A68EFFC2D4D25AAA0384E2B4B91A4 property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Audio\oldfilm_nsla'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Audio\oldfilm_nsla\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying _24CFE834C76B4F6987AC58D563593FC5 property. Its current value is 'C:\Program Files (x86)\Nero\NeroContent\Audio\movingwalls_nsla'. Its new value: 'C:\Program Files (x86)\Nero\NeroContent\Audio\movingwalls_nsla\'.
MSI (s) (60:80) [10:54:01:101]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
MSI (s) (60:80) [10:54:01:101]: Target path resolution complete. Dumping Directory table...
MSI (s) (60:80) [10:54:01:101]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: TARGETDIR   , Object: C:\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: WindowsFolder   , Object: C:\WINDOWS\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: USERPROFILE   , Object: C:\Users\Zandra Jones\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: TemplateFolder   , Object: C:\ProgramData\Microsoft\Windows\Templates\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: TempFolder   , Object: C:\Users\ZANDRA~1\AppData\Local\Temp\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: SystemFolder   , Object: C:\WINDOWS\SysWOW64\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: System64Folder   , Object: C:\WINDOWS\SysWOW64\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: System16Folder   , Object: C:\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: StartupFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: StartMenuFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: SendToFolder   , Object: C:\Users\Zandra Jones\AppData\Roaming\Microsoft\Windows\SendTo\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: ProgramMenuFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: ProgramFiles64Folder   , Object: C:\Program Files (x86)\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: PersonalFolder   , Object: C:\Users\Zandra Jones\Documents\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: MyPicturesFolder   , Object: C:\Users\Zandra Jones\Pictures\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: LocalAppDataFolder   , Object: C:\Users\Zandra Jones\AppData\Local\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: GlobalAssemblyCache   , Object: C:\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: FontsFolder   , Object: C:\WINDOWS\Fonts\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: FavoritesFolder   , Object: C:\Users\Zandra Jones\Favorites\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: DesktopFolder   , Object: C:\Users\Public\Desktop\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: CommonFilesFolder   , Object: C:\Program Files (x86)\Common Files\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: ISCommonFilesFolder   , Object: C:\Program Files (x86)\Common Files\InstallShield\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: ISUpdateServiceFolder   , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: CommonFiles64Folder   , Object: C:\Program Files (x86)\Common Files\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: CommonAppDataFolder   , Object: C:\ProgramData\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: AppDataFolder   , Object: C:\Users\Zandra Jones\AppData\Roaming\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: AdminToolsFolder   , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: ProgramFilesFolder   , Object: C:\Program Files (x86)\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: ISMyCompanyDir   , Object: C:\Program Files (x86)\My Company Name\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: ISMyProductDir   , Object: C:\Program Files (x86)\My Company Name\My Product Name\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: NERO   , Object: C:\Program Files (x86)\Nero\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: NERO_PRODUCT   , Object: C:\Program Files (x86)\Nero\Nero 10\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: INSTALLDIR   , Object: C:\Program Files (x86)\Nero\Nero 10\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: ISYourDataBaseDir   , Object: C:\Program Files (x86)\Nero\Nero 10\Database\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: DATABASEDIR   , Object: C:\Program Files (x86)\Nero\Nero 10\Database\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: CONTENT_PACK_BASE_DIR   , Object: C:\Program Files (x86)\Nero\NeroContent\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: COMP_INSTALL_DIR.E455A55D_C7C4_4A4C_8F90_B137097E5BCF   , Object: C:\Program Files (x86)\Nero\NeroContent\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: STANDARD2D   , Object: C:\Program Files (x86)\Nero\NeroContent\Standard2D\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _4E0ABE6DA6CD40198A39C791D3B1DDF3   , Object: C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _CFC2AE216EB7495D8A422FB00B5EC54F   , Object: C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Slideshow\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _E3A68969D2AE4B35AE3CDE3E6D33CE19   , Object: C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\OldFilm\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _A8FC11ED064B4065A0CA4C4CA3AB98E6   , Object: C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Movement\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _F44BBEC9DB4242DD87260C130A11364F   , Object: C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _F0254BC6E7DB4E22B65B700B589ECA4D   , Object: C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Slideshow\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _D9352A49F30E437AB4881AD615C5115A   , Object: C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\OldFilm\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _214B79D549344F3B8180698D7739C937   , Object: C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Movement\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: SMART3D   , Object: C:\Program Files (x86)\Nero\NeroContent\Smart3D\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _5FE23C7D36F5473188A6DEF41E840A6C   , Object: C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _6951875C8E0E44288D34383F087AD2CE   , Object: C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _04FA6424B4D64411A91974F6800FC99E   , Object: C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\MovingWalls\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _A384339D049443119A845059E6673E1E   , Object: C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _44225752A7854E158523D3F2082B3147   , Object: C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\MovingWalls\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: MOVIEWIZARD   , Object: C:\Program Files (x86)\Nero\NeroContent\MovieWizard\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _FCDAB9BD86B24530912B860B63967352   , Object: C:\Program Files (x86)\Nero\NeroContent\MovieWizard\Slideshow1\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _06CD8A166C7145FE9968183A70A191DC   , Object: C:\Program Files (x86)\Nero\NeroContent\MovieWizard\OldFilm\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _DDBAFAAB8CD94096A2D8C92FD3AEADBE   , Object: C:\Program Files (x86)\Nero\NeroContent\MovieWizard\MovingWalls\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: AUDIO   , Object: C:\Program Files (x86)\Nero\NeroContent\Audio\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _422AE2E4A86D48A09F91523B7851F097   , Object: C:\Program Files (x86)\Nero\NeroContent\Audio\slideshow1_nsla\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _AC8A68EFFC2D4D25AAA0384E2B4B91A4   , Object: C:\Program Files (x86)\Nero\NeroContent\Audio\oldfilm_nsla\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: _24CFE834C76B4F6987AC58D563593FC5   , Object: C:\Program Files (x86)\Nero\NeroContent\Audio\movingwalls_nsla\
MSI (s) (60:80) [10:54:01:101]: Dir (target): Key: ALLUSERSPROFILE   , Object: C:\ProgramData\
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\NeroContentLicenseCheck.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Slideshow\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\OldFilm\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Movement\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Slideshow\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\OldFilm\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Movement\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\MovingWalls\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\MovingWalls\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\Slideshow1\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\OldFilm\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\MovingWalls\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Audio\slideshow1_nsla\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Audio\oldfilm_nsla\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Audio\movingwalls_nsla\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\MovieThemePackBasic.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Standard2D\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:101]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\MovieWizard\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:117]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Audio\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:117]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\Smart3D\' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
Action start 10:54:01: CostFinalize.
MSI (s) (60:80) [10:54:01:117]: Skipping action: Nero_CA_DetectContentPackLocation (condition is false)
MSI (s) (60:80) [10:54:01:117]: Doing action: Nero_CA_PrepareShortCuts
Action ended 10:54:01: CostFinalize. Return value 1.
MSI (s) (60:6C) [10:54:01:117]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIAB6.tmp, Entrypoint: CA_PrepareShortCuts
Action start 10:54:01: Nero_CA_PrepareShortCuts.
CA_PrepareShortCuts: CustomActions.cpp : 1505 :  NERO.INSTALL_DESKTOPSHORTCUT: YES
CA_PrepareShortCuts: CustomActions.cpp : 1515 :  Shortcut table does not exist. Nothing to do.
CA_PrepareShortCuts: CustomActions.cpp : 1607 :  Succeeded
MSI (s) (60:80) [10:54:01:186]: Skipping action: Nero_CA_CheckProductConflicts (condition is false)
MSI (s) (60:80) [10:54:01:186]: Skipping action: Nero_CA_CheckRebootPending (condition is false)
MSI (s) (60:80) [10:54:01:186]: Doing action: MigrateFeatureStates
Action ended 10:54:01: Nero_CA_PrepareShortCuts. Return value 1.
MSI (s) (60:80) [10:54:01:186]: Skipping MigrateFeatureStates action: not run in maintenance mode
Action start 10:54:01: MigrateFeatureStates.
MSI (s) (60:80) [10:54:01:186]: Doing action: SetARPINSTALLLOCATION
Action ended 10:54:01: MigrateFeatureStates. Return value 0.
MSI (s) (60:80) [10:54:01:186]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Program Files (x86)\Nero\Nero 10\'.
Action start 10:54:01: SetARPINSTALLLOCATION.
MSI (s) (60:80) [10:54:01:186]: Doing action: SetODBCFolders
Action ended 10:54:01: SetARPINSTALLLOCATION. Return value 1.
MSI (s) (60:80) [10:54:01:186]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:80) [10:54:01:186]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
MSI (s) (60:80) [10:54:01:186]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:80) [10:54:01:186]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
Action start 10:54:01: SetODBCFolders.
MSI (s) (60:80) [10:54:01:186]: Doing action: InstallValidate
Action ended 10:54:01: SetODBCFolders. Return value 0.
Action start 10:54:01: InstallValidate.
MSI (s) (60:80) [10:54:01:202]: Feature: Content; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Feature: Smart3D; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Feature: Audio; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Feature: MovieWizard; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Feature: Standard2D; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: __ContentLicenseChk.E455A55D_C7C4_4A4C_8F90_B137097E5BCF65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: __RegInstaller65; Installed: Null;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: Smart3D; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: Audio; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: MovieWizard; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: Standard2D; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: MovieThemePackBasic.dll; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: RegInstaller; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _4DA30AFCBA94A97BDD7EE5D30161BB94; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _A4C7D6DE580DC6F0F654699280BDB334; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _F55CB8A9D7C65D686AAC6260CDF2175F; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _15E094C005F545E81E207844E5D20B11; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _D13C6428956226D33F926F53CE30D1B6; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _1576B8C0B36D81C390037913359A63F5; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _B8ADEBD511895C1E313212540C0C56E0; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _4C7676B12BC9863FF30CF1CDB92F312B; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _41856C64B0FC6E4DA968D0EA5A99E6B5; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _AC1C4126960AA9B59A555F40E7FB03A2; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _C18E125E5610E66F15C6F91E16C637B2; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _4EADF80B16E746DD9A9DEE246D70A87F; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _A5457750E51152E0AC4E9DDB7EA34A4E; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _BC80E137894FEC3CDA2DC39CDAEDBA2F; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _873319456BB50A06D032BEEF3A567ED4; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _C3BDB5295E0803BA4944EA09714F1951; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _FC0C980E8BCC999029ED6AD604530944; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _A29ADFF91B0D3184EE798CD4E3E883D3; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: _A4F94E51A5B3AD67BF00EB7CE8C161C0; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Component: ContentLicenseChk.E455A55D_C7C4_4A4C_8F90_B137097E5BCF; Installed: Local;   Request: Absent;   Action: Absent
MSI (s) (60:80) [10:54:01:202]: Note: 1: 2205 2:  3: BindImage
MSI (s) (60:80) [10:54:01:202]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:80) [10:54:01:202]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:80) [10:54:01:202]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:80) [10:54:01:202]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:80) [10:54:01:202]: Note: 1: 2205 2:  3: Font
MSI (s) (60:80) [10:54:01:202]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:80) [10:54:01:202]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:80) [10:54:01:202]: Note: 1: 2205 2:  3: _RemoveFilePath
MSI (s) (60:80) [10:54:01:217]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (60:80) [10:54:01:217]: Note: 1: 2205 2:  3: BindImage
MSI (s) (60:80) [10:54:01:217]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:80) [10:54:01:217]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:80) [10:54:01:217]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:80) [10:54:01:217]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:80) [10:54:01:217]: Note: 1: 2205 2:  3: Font
MSI (s) (60:80) [10:54:01:217]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:80) [10:54:01:217]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:80) [10:54:01:217]: Note: 1: 2727 2:
MSI (s) (60:80) [10:54:01:217]: Doing action: RemoveExistingProducts
Action ended 10:54:01: InstallValidate. Return value 1.
MSI (s) (60:80) [10:54:01:217]: Skipping RemoveExistingProducts action: current configuration is maintenance mode or an uninstall
Action start 10:54:01: RemoveExistingProducts.
MSI (s) (60:80) [10:54:01:217]: Skipping action: Nero_CA_SetMediaPackage (condition is false)
MSI (s) (60:80) [10:54:01:217]: Skipping action: Nero_CAData_RestoreMediaPackage (condition is false)
MSI (s) (60:80) [10:54:01:217]: Doing action: InstallInitialize
Action ended 10:54:01: RemoveExistingProducts. Return value 0.
MSI (s) (60:80) [10:54:01:217]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:80) [10:54:01:217]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (60:80) [10:54:01:217]: BeginTransaction: Locking Server
MSI (s) (60:80) [10:54:01:233]: Transforming table Property.
MSI (s) (60:80) [10:54:01:233]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:80) [10:54:01:233]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
MSI (s) (60:80) [10:54:01:233]: SRSetRestorePoint skipped for this transaction.
MSI (s) (60:80) [10:54:01:250]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:80) [10:54:01:255]: Server not locked: locking for product {F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}
Action start 10:54:01: InstallInitialize.
MSI (s) (60:80) [10:54:01:271]: PROPERTY CHANGE: Deleting ProductToBeRegistered property. Its current value is '1'.
MSI (s) (60:80) [10:54:01:271]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:80) [10:54:01:271]: Note: 1: 2228 2:  3: Shortcut 4: SELECT `Component`,`Shortcut`,`Target` FROM `Component`,`Shortcut` WHERE `Component`=`Component_` AND `Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:80) [10:54:01:271]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:80) [10:54:01:271]: Note: 1: 2228 2:  3: Extension 4: SELECT `Component`,`Extension` FROM `Component`,`Extension`,`ProgId` WHERE `Component`.`Component`=`Extension`.`Component_` AND `ProgId`.`ProgId`=`Extension`.`ProgId_` AND `ProgId`.`Icon_`=? AND  (`Component`.`Installed` <> 0 AND `Component`.`Action` <> 0)
MSI (s) (60:80) [10:54:01:271]: 'ARPPRODUCTICON.exe' icon will be removed.
MSI (s) (60:80) [10:54:01:271]: Doing action: Nero_CA_DeleteLocalFileAssociationDb
Action ended 10:54:01: InstallInitialize. Return value 1.
Action start 10:54:01: Nero_CA_DeleteLocalFileAssociationDb.
MSI (s) (60:80) [10:54:01:271]: Doing action: Nero_CA_GatherOriginalFileAssociation
Action ended 10:54:01: Nero_CA_DeleteLocalFileAssociationDb. Return value 1.
Action start 10:54:01: Nero_CA_GatherOriginalFileAssociation.
MSI (s) (60:80) [10:54:01:286]: Skipping action: Nero_CA_RestoreMediaPackage (condition is false)
MSI (s) (60:80) [10:54:01:286]: Skipping action: AllocateRegistrySpace (condition is false)
MSI (s) (60:80) [10:54:01:286]: Doing action: ProcessComponents
Action ended 10:54:01: Nero_CA_GatherOriginalFileAssociation. Return value 1.
Action start 10:54:01: ProcessComponents.
MSI (s) (60:80) [10:54:01:286]: Doing action: UnpublishComponents
Action ended 10:54:01: ProcessComponents. Return value 1.
MSI (s) (60:80) [10:54:01:286]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:80) [10:54:01:286]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:01: UnpublishComponents.
MSI (s) (60:80) [10:54:01:286]: Doing action: MsiUnpublishAssemblies
Action ended 10:54:01: UnpublishComponents. Return value 0.
MSI (s) (60:80) [10:54:01:286]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:80) [10:54:01:286]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:01: MsiUnpublishAssemblies.
MSI (s) (60:80) [10:54:01:286]: Doing action: UnpublishFeatures
Action ended 10:54:01: MsiUnpublishAssemblies. Return value 0.
Action start 10:54:01: UnpublishFeatures.
MSI (s) (60:80) [10:54:01:286]: Doing action: StopServices
Action ended 10:54:01: UnpublishFeatures. Return value 1.
MSI (s) (60:80) [10:54:01:286]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:80) [10:54:01:286]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 10:54:01: StopServices.
MSI (s) (60:80) [10:54:01:286]: Doing action: DeleteServices
Action ended 10:54:01: StopServices. Return value 1.
Action start 10:54:01: DeleteServices.
MSI (s) (60:80) [10:54:01:286]: Doing action: UnregisterComPlus
Action ended 10:54:01: DeleteServices. Return value 1.
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2205 2:  3: Complus
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
Action start 10:54:01: UnregisterComPlus.
MSI (s) (60:80) [10:54:01:302]: Doing action: SelfUnregModules
Action ended 10:54:01: UnregisterComPlus. Return value 0.
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
Action start 10:54:01: SelfUnregModules.
MSI (s) (60:80) [10:54:01:302]: Doing action: UnregisterTypeLibraries
Action ended 10:54:01: SelfUnregModules. Return value 1.
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
Action start 10:54:01: UnregisterTypeLibraries.
MSI (s) (60:80) [10:54:01:302]: Doing action: RemoveODBC
Action ended 10:54:01: UnregisterTypeLibraries. Return value 0.
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2711 2: ODBCDriverManager
Action start 10:54:01: RemoveODBC.
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (60:80) [10:54:01:302]: Doing action: UnregisterFonts
Action ended 10:54:01: RemoveODBC. Return value 1.
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2205 2:  3: Font
MSI (s) (60:80) [10:54:01:302]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
Action start 10:54:01: UnregisterFonts.
MSI (s) (60:80) [10:54:01:302]: Doing action: RemoveRegistryValues
Action ended 10:54:01: UnregisterFonts. Return value 1.
Action start 10:54:01: RemoveRegistryValues.
MSI (s) (60:80) [10:54:01:302]: Doing action: UnregisterClassInfo
Action ended 10:54:01: RemoveRegistryValues. Return value 1.
Action start 10:54:01: UnregisterClassInfo.
MSI (s) (60:80) [10:54:01:318]: Doing action: UnregisterExtensionInfo
Action ended 10:54:01: UnregisterClassInfo. Return value 1.
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:01: UnregisterExtensionInfo.
MSI (s) (60:80) [10:54:01:318]: Doing action: UnregisterProgIdInfo
Action ended 10:54:01: UnregisterExtensionInfo. Return value 0.
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:01: UnregisterProgIdInfo.
MSI (s) (60:80) [10:54:01:318]: Doing action: UnregisterMIMEInfo
Action ended 10:54:01: UnregisterProgIdInfo. Return value 0.
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2205 2:  3: MIME
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:01: UnregisterMIMEInfo.
MSI (s) (60:80) [10:54:01:318]: Doing action: RemoveIniValues
Action ended 10:54:01: UnregisterMIMEInfo. Return value 0.
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2205 2:  3: IniFile
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
Action start 10:54:01: RemoveIniValues.
MSI (s) (60:80) [10:54:01:318]: Doing action: RemoveShortcuts
Action ended 10:54:01: RemoveIniValues. Return value 1.
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
Action start 10:54:01: RemoveShortcuts.
MSI (s) (60:80) [10:54:01:318]: Doing action: RemoveEnvironmentStrings
Action ended 10:54:01: RemoveShortcuts. Return value 0.
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2205 2:  3: Environment
MSI (s) (60:80) [10:54:01:318]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
Action start 10:54:01: RemoveEnvironmentStrings.
MSI (s) (60:80) [10:54:01:318]: Doing action: RemoveDuplicateFiles
Action ended 10:54:01: RemoveEnvironmentStrings. Return value 1.
Action start 10:54:01: RemoveDuplicateFiles.
MSI (s) (60:80) [10:54:01:333]: Doing action: RemoveFiles
Action ended 10:54:01: RemoveDuplicateFiles. Return value 1.
MSI (s) (60:80) [10:54:01:333]: Note: 1: 2205 2:  3: RemoveFile
Action start 10:54:01: RemoveFiles.
MSI (s) (60:80) [10:54:01:355]: Note: 1: 2205 2:  3: RemoveFile
MSI (s) (60:80) [10:54:01:355]: Doing action: RemoveFolders
Action ended 10:54:01: RemoveFiles. Return value 0.
Action start 10:54:01: RemoveFolders.
MSI (s) (60:80) [10:54:01:355]: Doing action: CreateFolders
Action ended 10:54:01: RemoveFolders. Return value 1.
Action start 10:54:01: CreateFolders.
MSI (s) (60:80) [10:54:01:355]: Doing action: MoveFiles
Action ended 10:54:01: CreateFolders. Return value 1.
Action start 10:54:01: MoveFiles.
MSI (s) (60:80) [10:54:01:355]: Doing action: InstallFiles
Action ended 10:54:01: MoveFiles. Return value 1.
MSI (s) (60:80) [10:54:01:371]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
MSI (s) (60:80) [10:54:01:371]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
MSI (s) (60:80) [10:54:01:371]: Note: 1: 2205 2:  3: MsiSFCBypass
MSI (s) (60:80) [10:54:01:371]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
MSI (s) (60:80) [10:54:01:371]: Note: 1: 2205 2:  3: MsiPatchHeaders
MSI (s) (60:80) [10:54:01:371]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
Action start 10:54:01: InstallFiles.
MSI (s) (60:80) [10:54:01:371]: Doing action: PatchFiles
Action ended 10:54:01: InstallFiles. Return value 1.
Action start 10:54:01: PatchFiles.
MSI (s) (60:80) [10:54:01:371]: Doing action: DuplicateFiles
Action ended 10:54:01: PatchFiles. Return value 1.
Action start 10:54:01: DuplicateFiles.
MSI (s) (60:80) [10:54:01:371]: Doing action: BindImage
Action ended 10:54:01: DuplicateFiles. Return value 1.
Action start 10:54:01: BindImage.
MSI (s) (60:80) [10:54:01:371]: Doing action: CreateShortcuts
Action ended 10:54:01: BindImage. Return value 1.
MSI (s) (60:80) [10:54:01:371]: Note: 1: 2205 2:  3: Shortcut
MSI (s) (60:80) [10:54:01:371]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action start 10:54:01: CreateShortcuts.
MSI (s) (60:80) [10:54:01:387]: Doing action: RegisterClassInfo
Action ended 10:54:01: CreateShortcuts. Return value 0.
Nissi1
Action start 10:54:01: RegisterClassInfo.
MSI (s) (60:80) [10:54:01:387]: Doing action: RegisterExtensionInfo
Action ended 10:54:01: RegisterClassInfo. Return value 1.
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: Extension
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:54:01: RegisterExtensionInfo.
MSI (s) (60:80) [10:54:01:387]: Doing action: RegisterProgIdInfo
Action ended 10:54:01: RegisterExtensionInfo. Return value 0.
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: ProgId
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:54:01: RegisterProgIdInfo.
MSI (s) (60:80) [10:54:01:387]: Doing action: RegisterMIMEInfo
Action ended 10:54:01: RegisterProgIdInfo. Return value 0.
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: MIME
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
Action start 10:54:01: RegisterMIMEInfo.
MSI (s) (60:80) [10:54:01:387]: Doing action: WriteRegistryValues
Action ended 10:54:01: RegisterMIMEInfo. Return value 0.
Action start 10:54:01: WriteRegistryValues.
MSI (s) (60:80) [10:54:01:387]: Doing action: WriteIniValues
Action ended 10:54:01: WriteRegistryValues. Return value 1.
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: IniFile
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
Action start 10:54:01: WriteIniValues.
MSI (s) (60:80) [10:54:01:387]: Doing action: WriteEnvironmentStrings
Action ended 10:54:01: WriteIniValues. Return value 1.
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: Environment
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
Action start 10:54:01: WriteEnvironmentStrings.
MSI (s) (60:80) [10:54:01:387]: Doing action: RegisterFonts
Action ended 10:54:01: WriteEnvironmentStrings. Return value 1.
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: Font
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
Action start 10:54:01: RegisterFonts.
MSI (s) (60:80) [10:54:01:387]: Doing action: InstallODBC
Action ended 10:54:01: RegisterFonts. Return value 1.
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2711 2: ODBCDriverManager
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: ODBCDriver
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: ODBCTranslator
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: ODBCDataSource
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
Action start 10:54:01: InstallODBC.
MSI (s) (60:80) [10:54:01:387]: Doing action: RegisterTypeLibraries
Action ended 10:54:01: InstallODBC. Return value 0.
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: TypeLib
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
Action start 10:54:01: RegisterTypeLibraries.
MSI (s) (60:80) [10:54:01:387]: Doing action: SelfRegModules
Action ended 10:54:01: RegisterTypeLibraries. Return value 0.
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: SelfReg
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
Action start 10:54:01: SelfRegModules.
MSI (s) (60:80) [10:54:01:387]: Doing action: RegisterComPlus
Action ended 10:54:01: SelfRegModules. Return value 1.
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: Complus
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action start 10:54:01: RegisterComPlus.
MSI (s) (60:80) [10:54:01:387]: Doing action: InstallServices
Action ended 10:54:01: RegisterComPlus. Return value 0.
MSI (s) (60:80) [10:54:01:387]: Detected older ServiceInstall table schema
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: ServiceInstall
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
Action start 10:54:01: InstallServices.
MSI (s) (60:80) [10:54:01:387]: Doing action: StartServices
Action ended 10:54:01: InstallServices. Return value 1.
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2205 2:  3: ServiceControl
MSI (s) (60:80) [10:54:01:387]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 10:54:01: StartServices.
MSI (s) (60:80) [10:54:01:387]: Doing action: RegisterUser
Action ended 10:54:01: StartServices. Return value 1.
Action start 10:54:01: RegisterUser.
MSI (s) (60:80) [10:54:01:402]: Doing action: RegisterProduct
Action ended 10:54:01: RegisterUser. Return value 0.
Action start 10:54:01: RegisterProduct.
MSI (s) (60:80) [10:54:01:402]: Doing action: PublishComponents
Action ended 10:54:01: RegisterProduct. Return value 1.
MSI (s) (60:80) [10:54:01:402]: Note: 1: 2205 2:  3: PublishComponent
MSI (s) (60:80) [10:54:01:402]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action start 10:54:01: PublishComponents.
MSI (s) (60:80) [10:54:01:402]: Doing action: MsiPublishAssemblies
Action ended 10:54:01: PublishComponents. Return value 0.
MSI (s) (60:80) [10:54:01:402]: Note: 1: 2205 2:  3: MsiAssembly
MSI (s) (60:80) [10:54:01:402]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
Action start 10:54:01: MsiPublishAssemblies.
MSI (s) (60:80) [10:54:01:402]: Doing action: PublishFeatures
Action ended 10:54:01: MsiPublishAssemblies. Return value 0.
Action start 10:54:01: PublishFeatures.
MSI (s) (60:80) [10:54:01:402]: Doing action: PublishProduct
Action ended 10:54:01: PublishFeatures. Return value 1.
Action start 10:54:01: PublishProduct.
MSI (s) (60:80) [10:54:01:402]: Doing action: Nero_CA_UninstallSetAssociationsRollback
Action ended 10:54:01: PublishProduct. Return value 1.
Action start 10:54:01: Nero_CA_UninstallSetAssociationsRollback.
MSI (s) (60:80) [10:54:01:418]: Doing action: Nero_CA_UninstallSetAssociations
Action ended 10:54:01: Nero_CA_UninstallSetAssociationsRollback. Return value 1.
Action start 10:54:01: Nero_CA_UninstallSetAssociations.
MSI (s) (60:80) [10:54:01:418]: Skipping action: Nero_CA_InstallSetAssociationsRollback (condition is false)
MSI (s) (60:80) [10:54:01:418]: Skipping action: Nero_CA_InstallSetAssociations (condition is false)
MSI (s) (60:80) [10:54:01:418]: Doing action: Nero_CA_DeleteAssociationsBackup
Action ended 10:54:01: Nero_CA_UninstallSetAssociations. Return value 1.
Action start 10:54:01: Nero_CA_DeleteAssociationsBackup.
MSI (s) (60:80) [10:54:01:418]: Doing action: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore
Action ended 10:54:01: Nero_CA_DeleteAssociationsBackup. Return value 1.
Action start 10:54:01: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore.
MSI (s) (60:80) [10:54:01:433]: Skipping action: ScheduleReboot (condition is false)
MSI (s) (60:80) [10:54:01:433]: Doing action: InstallFinalize
Action ended 10:54:01: Nero_CA_MergeLocalFileAssociationDbToGlobalAndRestore. Return value 1.
Action start 10:54:01: InstallFinalize.
MSI (s) (60:80) [10:54:01:433]: Running Script: C:\WINDOWS\Installer\MSIB53.tmp
MSI (s) (60:80) [10:54:01:433]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (60:80) [10:54:01:456]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (60:80) [10:54:01:471]: Machine policy value 'DisableRollback' is 0
MSI (s) (60:80) [10:54:01:471]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1254840001,LangId=0,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (60:80) [10:54:01:471]: Executing op: ProductInfo(ProductKey={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7},ProductName=Nero 10 Movie ThemePack Basic,PackageName=Nero.MovieThemePackBasic.msi,Language=0,Version=167913432,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,PackageMediaPath=\applications\moviethemebase\,PackageCode={B9F7A147-EE44-48AE-B20E-9D2DCE597782},,,InstanceType=0,LUASetting=1,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (s) (60:80) [10:54:01:471]: Executing op: DialogInfo(Type=0,Argument=0)
MSI (s) (60:80) [10:54:01:471]: Executing op: DialogInfo(Type=1,Argument=Nero 10 Movie ThemePack Basic)
MSI (s) (60:80) [10:54:01:471]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (60:80) [10:54:01:471]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (60:80) [10:54:01:471]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (60:80) [10:54:01:471]: Executing op: ActionStart(Name=InstallInitialize,,)
MSI (s) (60:80) [10:54:01:471]: Executing op: ProductUnregister(UpgradeCode={403096B5-2B75-4FAE-BC57-6535C9E50B79})
MSI (s) (60:80) [10:54:01:471]: Note: 1: 1402 2: UNKNOWN\Products\F228BC5F563B1D34CB0CF4ADA102717A\Transforms 3: 2
MSI (s) (60:80) [10:54:01:471]: Scheduling file 'C:\Windows\Installer\11a68.msi' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:80) [10:54:01:487]: Note: 1: 1402 2: UNKNOWN\Products\F228BC5F563B1D34CB0CF4ADA102717A\Usage 3: 2
MSI (s) (60:80) [10:54:01:487]: Executing op: ProductCPDisplayInfoUnregister()
MSI (s) (60:80) [10:54:01:502]: Executing op: ProductUnpublish(PackageKey={B9F7A147-EE44-48AE-B20E-9D2DCE597782})
MSI (s) (60:80) [10:54:01:502]: Transforms are not secure.
MSI (s) (60:80) [10:54:01:502]: Processing cached transform: C:\WINDOWS\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst
MSI (s) (60:80) [10:54:01:502]: Scheduling file 'C:\WINDOWS\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:80) [10:54:01:502]: Registering cached transform: C:\WINDOWS\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\1033.mst
MSI (s) (60:80) [10:54:01:502]: Executing op: UpgradeCodeUnpublish(UpgradeCode={403096B5-2B75-4FAE-BC57-6535C9E50B79})
MSI (s) (60:80) [10:54:01:502]: Executing op: IconRemove(Icon=ARPPRODUCTICON.exe,)
MSI (s) (60:80) [10:54:01:502]: Scheduling file 'C:\WINDOWS\Installer\{F5CB822F-B365-43D1-BCC0-4FDA1A2017A7}\ARPPRODUCTICON.exe' for deletion during post-install cleanup (not post-reboot).
MSI (s) (60:80) [10:54:01:502]: Executing op: ProductUnpublishClient(,,)
MSI (s) (60:80) [10:54:01:502]: Note: 1: 1402 2: UNKNOWN\Installer\Products\F228BC5F563B1D34CB0CF4ADA102717A 3: 2
MSI (s) (60:80) [10:54:01:502]: Executing op: SourceListUnpublish(,)
MSI (s) (60:80) [10:54:01:502]: Note: 1: 1402 2: UNKNOWN\Installer\Products\F228BC5F563B1D34CB0CF4ADA102717A\SourceList 3: 2
MSI (s) (60:80) [10:54:01:502]: Executing op: ActionStart(Name=Nero_CA_DeleteLocalFileAssociationDb,,)
MSI (s) (60:80) [10:54:01:502]: Executing op: CustomActionSchedule(Action=Nero_CA_DeleteLocalFileAssociationDb,ActionType=1281,Source=BinaryData,Target=CA_DeleteLocalFileAssociationDb,CustomActionData={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:502]: Executing op: ActionStart(Name=Nero_CA_GatherOriginalFileAssociation,,)
MSI (s) (60:80) [10:54:01:502]: Executing op: CustomActionSchedule(Action=Nero_CA_GatherOriginalFileAssociation,ActionType=1025,Source=BinaryData,Target=CA_GatherOriginalFileAssociation,)
MSI (s) (60:18) [10:54:01:518]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIC40.tmp, Entrypoint: CA_GatherOriginalFileAssociation
MSI (s) (60:80) [10:54:01:587]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (60:80) [10:54:01:587]: Executing op: ProgressTotal(Total=26,Type=1,ByteEquivalent=24000)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={830F4E82-C3B5-435E-B222-32C14FADE457},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={830F4E82-C3B5-435E-B222-32C14FADE457},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={3D0D5769-9BA7-45AD-BC10-39DDD3617773},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={3D0D5769-9BA7-45AD-BC10-39DDD3617773},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={B101FDE4-F9BB-49AA-996B-084909DB96F6},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={B101FDE4-F9BB-49AA-996B-084909DB96F6},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={92A17853-A67A-45F0-B907-3A929E2B3451},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={92A17853-A67A-45F0-B907-3A929E2B3451},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={E188209D-8296-4E7B-96AE-45101016EF83},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={E188209D-8296-4E7B-96AE-45101016EF83},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={DA28E544-350E-4F41-BA5E-509A510E593D},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={DA28E544-350E-4F41-BA5E-509A510E593D},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:587]: Executing op: UnregisterSharedComponentProvider(Component={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:587]: Executing op: ComponentUnregister(ComponentId={4DA30AFC-CBA9-4A97-BDD7-EE5D30161BB9},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:603]: Executing op: UnregisterSharedComponentProvider(Component={A4C7D6DE-E580-DC6F-0F65-4699280BDB33},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:603]: Executing op: ComponentUnregister(ComponentId={A4C7D6DE-E580-DC6F-0F65-4699280BDB33},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:603]: Executing op: UnregisterSharedComponentProvider(Component={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:603]: Executing op: ComponentUnregister(ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:603]: Executing op: UnregisterSharedComponentProvider(Component={15E094C0-005F-545E-81E2-07844E5D20B1},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:603]: Executing op: ComponentUnregister(ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:603]: Executing op: UnregisterSharedComponentProvider(Component={D13C6428-8956-226D-33F9-26F53CE30D1B},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:603]: Executing op: ComponentUnregister(ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:603]: Executing op: UnregisterSharedComponentProvider(Component={1576B8C0-0B36-D81C-3900-37913359A63F},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:603]: Executing op: ComponentUnregister(ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={B8ADEBD5-5118-95C1-E313-212540C0C56E},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={B8ADEBD5-5118-95C1-E313-212540C0C56E},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={4C7676B1-12BC-9863-FF30-CF1CDB92F312},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={4C7676B1-12BC-9863-FF30-CF1CDB92F312},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={AC1C4126-6960-AA9B-59A5-55F40E7FB03A},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={AC1C4126-6960-AA9B-59A5-55F40E7FB03A},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={C18E125E-E561-0E66-F15C-6F91E16C637B},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={4EADF80B-B16E-746D-D9A9-DEE246D70A87},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={4EADF80B-B16E-746D-D9A9-DEE246D70A87},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={A5457750-0E51-152E-0AC4-E9DDB7EA34A4},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={87331945-56BB-50A0-6D03-2BEEF3A567ED},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={C3BDB529-95E0-803B-A494-4EA09714F195},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={C3BDB529-95E0-803B-A494-4EA09714F195},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={FC0C980E-E8BC-C999-029E-D6AD60453094},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:618]: Executing op: UnregisterSharedComponentProvider(Component={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:618]: Executing op: ComponentUnregister(ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:634]: Executing op: UnregisterSharedComponentProvider(Component={4C4F1A46-D98F-4176-83F0-1F38CF332AC4},ProductCode={F5CB822F-B365-43D1-BCC0-4FDA1A2017A7})
MSI (s) (60:80) [10:54:01:634]: Executing op: ComponentUnregister(ComponentId={4C4F1A46-D98F-4176-83F0-1F38CF332AC4},,BinaryType=0,)
MSI (s) (60:80) [10:54:01:634]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Nero\NeroContent\NeroContentLicenseCheck.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
MSI (s) (60:80) [10:54:01:634]: Executing op: ActionStart(Name=UnpublishFeatures,Description=Unpublishing product features,Template=Feature: [1])
MSI (s) (60:80) [10:54:01:634]: Executing op: FeatureUnpublish(Feature=Content,,Absent=2,Component=P^?QqaZ'7AniU7(mX@JRU(t,oQq0PA'EcZYt=ze7zXbT@IyJ&9I`=&6pY!'h)
MSI (s) (60:80) [10:54:01:634]: Note: 1: 1402 2: UNKNOWN\Installer\Features\F228BC5F563B1D34CB0CF4ADA102717A 3: 2
MSI (s) (60:80) [10:54:01:634]: Executing op: FeatureUnpublish(Feature=Smart3D,Parent=Content,Absent=2,Component=2gJ-RCcP`9F7u*gbQ09DP+8Fd=C0.XfzCx.^J3[Ki[sX@Hk&}XDE&=,GAg*)k.{'9)kRwh1mXb''U'ZJXTrB`4flo_rgyTwK+Dr6=1e5g5oM^'xS-hVUuo`O)
MSI (s) (60:80) [10:54:01:634]: Executing op: FeatureUnpublish(Feature=Audio,Parent=Content,Absent=2,Component=.Qs]7_(UI=b'X+pH)K,Mv)zy@%hl{?`D04FCBtQdJ)^z]+B+qo~hA=Yk@_a4-%%rw$L,gHF)CO0U_w_M)
MSI (s) (60:80) [10:54:01:634]: Executing op: FeatureUnpublish(Feature=MovieWizard,Parent=Content,Absent=2,Component=io`ta~[Tb?$-3P?ENV9xtDa%*6Xn,CnSxLRPDuwany*9lB3U(.rQ@lwqo*d+(-Gu)_?sNn%?,bVEYpN8)
MSI (s) (60:80) [10:54:01:634]: Executing op: FeatureUnpublish(Feature=Standard2D,Parent=Content,Absent=2,Component=!.l-W%4cP=aqh~VxmI+B!AM@A%AdKMnbovq(`5JS+[%-^v}[m)jqKCpNHyj]${dYeM~qszYGfZ6yq+E]AnRNS&s]vA^IQVum@_Au.OLvgZ'36QPhJT[[X84X(zd!z,HTliM))s`9VE^W?!4=]V7vplpbc)k{@~j7gju$^Y6Ev6ZvyocaSD%,)
MSI (s) (60:80) [10:54:01:634]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
MSI (s) (60:80) [10:54:01:634]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (60:80) [10:54:01:634]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (60:80) [10:54:01:634]: Executing op: ActionStart(Name=RemoveRegistryValues,Description=Removing system registry values,Template=Key: [1], Name: [2])
MSI (s) (60:80) [10:54:01:634]: Executing op: ProgressTotal(Total=15,Type=1,ByteEquivalent=13200)
MSI (s) (60:80) [10:54:01:634]: Executing op: RegOpenKey(,Key=CLSID\{E446A471-9C57-4EA3-81A5-4A38C4E21018}\InprocServer32,,BinaryType=0,,)
MSI (s) (60:80) [10:54:01:634]: Executing op: RegRemoveValue(Name=ThreadingModel,Value=Both,)
MSI (s) (60:80) [10:54:01:634]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\Software\Classes\CLSID\{E446A471-9C57-4EA3-81A5-4A38C4E21018}\InprocServer32 3: 2
MSI (s) (60:80) [10:54:01:634]: Executing op: RegOpenKey(,Key=CLSID\{E3860894-1DAE-44BA-9DD9-BE425838D7D4}\InprocServer32,,BinaryType=0,,)
MSI (s) (60:80) [10:54:01:634]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\Software\Classes\CLSID\{E3860894-1DAE-44BA-9DD9-BE425838D7D4}\InprocServer32 3: 2
MSI (s) (60:80) [10:54:01:634]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Nero\Nero 10\Installer\Applications\{403096B5-2B75-4FAE-BC57-6535C9E50B79},,BinaryType=0,,)
MSI (s) (60:80) [10:54:01:634]: Executing op: RegRemoveValue(Name=NERO.APPID,Value=#[NERO.APPID],)
MSI (s) (60:80) [10:54:01:634]: Executing op: RegRemoveValue(Name=Nero.MainComponent,Value=[Nero.MainComponent],)
MSI (s) (60:80) [10:54:01:634]: Executing op: RegRemoveValue(Name=PackageName,Value=[Nero.PackageName],)
MSI (s) (60:80) [10:54:01:650]: Executing op: RegRemoveValue(Name=ProductCode,Value=[ProductCode],)
MSI (s) (60:80) [10:54:01:650]: Executing op: RegRemoveValue(Name=NERO.PRODUCT_LINE,Value=[NERO.PRODUCT_LINE],)
MSI (s) (60:80) [10:54:01:651]: Executing op: RegRemoveValue(Name=ProductName,Value=[ProductName],)
MSI (s) (60:80) [10:54:01:651]: Executing op: RegRemoveValue(Name=ProductVersion,Value=[ProductVersion],)
MSI (s) (60:80) [10:54:01:652]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Nero\Nero 10\Installer\Applications\{403096B5-2B75-4FAE-BC57-6535C9E50B79}\UserProperties,,BinaryType=0,,)
MSI (s) (60:80) [10:54:01:652]: Executing op: RegRemoveValue(Name=ARPNOREPAIR,Value=[ARPNOREPAIR],)
MSI (s) (60:80) [10:54:01:653]: Executing op: RegRemoveValue(Name=NERO.INSTALL_AUTOPLAY,Value=[NERO.INSTALL_AUTOPLAY],)
MSI (s) (60:80) [10:54:01:653]: Executing op: RegRemoveValue(Name=NERO.INSTALL_DESKTOPSHORTCUT,Value=[NERO.INSTALL_DESKTOPSHORTCUT],)
MSI (s) (60:80) [10:54:01:654]: Executing op: RegRemoveValue(Name=NERO.INSTALL_EXTENSIONS,Value=[NERO.INSTALL_EXTENSIONS],)
MSI (s) (60:80) [10:54:01:655]: Executing op: RegRemoveValue(Name=INSTALLDIR,Value=[INSTALLDIR],)
MSI (s) (60:80) [10:54:01:655]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Nero\Nero 10\Installer\Packages\{403096B5-2B75-4FAE-BC57-6535C9E50B79},,BinaryType=0,,)
MSI (s) (60:80) [10:54:01:656]: Executing op: RegRemoveValue(Name=NPMOVB,Value=[UpgradeCode],)
MSI (s) (60:80) [10:54:01:656]: Executing op: ActionStart(Name=UnregisterClassInfo,Description=Unregister class servers,Template=Class ID: [1])
MSI (s) (60:80) [10:54:01:656]: Executing op: RegClassInfoUnregister(Feature=Content,Component={4C4F1A46-D98F-4176-83F0-1F38CF332AC4},FileName=TOKEN,ClsId={E3860894-1DAE-44BA-9DD9-BE425838D7D4},,,,Context=InprocServer32,,,,,,,,,,)
MSI (s) (60:80) [10:54:01:656]: Note: 1: 1402 2: UNKNOWN32\CLSID\{E3860894-1DAE-44BA-9DD9-BE425838D7D4}\InprocServer32 3: 2
MSI (s) (60:80) [10:54:01:656]: Note: 1: 1402 2: UNKNOWN32\CLSID\{E3860894-1DAE-44BA-9DD9-BE425838D7D4} 3: 2
MSI (s) (60:80) [10:54:01:656]: Executing op: RegClassInfoUnregister(Feature=Content,Component={4C4F1A46-D98F-4176-83F0-1F38CF332AC4},FileName=TOKEN,ClsId={E446A471-9C57-4EA3-81A5-4A38C4E21018},,,,Context=InprocServer32,,,,,,,,,,)
MSI (s) (60:80) [10:54:01:656]: Note: 1: 1402 2: UNKNOWN32\CLSID\{E446A471-9C57-4EA3-81A5-4A38C4E21018}\InprocServer32 3: 2
MSI (s) (60:80) [10:54:01:672]: Note: 1: 1402 2: UNKNOWN32\CLSID\{E446A471-9C57-4EA3-81A5-4A38C4E21018} 3: 2
MSI (s) (60:80) [10:54:01:672]: Executing op: ActionStart(Name=RemoveFiles,Description=Removing files,Template=File: [1], Directory: [9])
MSI (s) (60:80) [10:54:01:672]: Executing op: ProgressTotal(Total=244,Type=1,ByteEquivalent=175000)
MSI (s) (60:80) [10:54:01:672]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Slideshow\)
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow43.frm.tm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow43.frm.sm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow43.frm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow169.frm.tm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow169.frm.sm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow169.frm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.shp.1.tif,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.SD.4.3.tpl,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.SD.16.9.tpl,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.ret.sm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.ret.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.prev.sm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.prev.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.next.sm.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.next.png,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=Slideshow.bg.jpg,,ComponentId={A4F94E51-1A5B-3AD6-7BF0-0EB7CE8C161C})
MSI (s) (60:80) [10:54:01:672]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\OldFilm\)
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm43.frm.tm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm43.frm.sm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm43.frm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm169.frm.tm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm169.frm.sm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm169.frm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:672]: Executing op: FileRemove(,FileName=OldFilm.SD.4.3.tpl,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.SD.16.9.tpl,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.ret.sm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.ret.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.prev.sm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.prev.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.next.sm.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.next.png,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=OldFilm.bkg.jpg,,ComponentId={A29ADFF9-91B0-D318-4EE7-98CD4E3E883D})
MSI (s) (60:80) [10:54:01:687]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\SD\Movement\)
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement43.frm.tm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement43.frm.sm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement43.frm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement169.frm.tm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement169.frm.sm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement169.frm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.shp.3.tif,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.shp.1.tif,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.SD.4.3.tpl,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.SD.16.9.tpl,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.ret.sm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:687]: Executing op: FileRemove(,FileName=Movement.ret.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Movement.prev.sm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Movement.prev.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Movement.next.sm.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Movement.next.png,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Movement.bkg.jpg,,ComponentId={FC0C980E-E8BC-C999-029E-D6AD60453094})
MSI (s) (60:80) [10:54:01:703]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Slideshow\)
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.shp.1.tif,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.ret.sm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.ret.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.prev.sm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.prev.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.next.sm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.next.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.HD.16.9.tpl,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.frm.tm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.frm.sm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.frm.png,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=Slideshow.bg.jpg,,ComponentId={87331945-56BB-50A0-6D03-2BEEF3A567ED})
MSI (s) (60:80) [10:54:01:703]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\OldFilm\)
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.ret.sm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.ret.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.prev.sm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.prev.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.next.sm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.next.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.HD.16.9.tpl,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:703]: Executing op: FileRemove(,FileName=OldFilm.frm.tm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=OldFilm.frm.sm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=OldFilm.frm.png,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=OldFilm.bkg.jpg,,ComponentId={BC80E137-7894-FEC3-CDA2-DC39CDAEDBA2})
MSI (s) (60:80) [10:54:01:719]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Standard2D\HD\Movement\)
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.shp.3.tif,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.shp.1.tif,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.ret.sm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.ret.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.prev.sm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.prev.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.next.sm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.next.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.HD.16.9.tpl,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.frm.tm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.frm.sm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.frm.png,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Movement.bkg.jpg,,ComponentId={A5457750-0E51-152E-0AC4-E9DDB7EA34A4})
MSI (s) (60:80) [10:54:01:719]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\4_3\MovingWalls\)
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Trans_S.png,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Trans_G.png,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=Refl.jpg,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans3.ntds,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans3.3dsn,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans2.ntds,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans2.3dsn,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans1.ntds,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_trans1.3dsn,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_outro.ntds,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:719]: Executing op: FileRemove(,FileName=movingwalls_outro.3dsn,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_intro.ntds,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_intro.3dsn,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=Dirt_S.png,,ComponentId={C18E125E-E561-0E66-F15C-6F91E16C637B})
MSI (s) (60:80) [10:54:01:734]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Smart3D\IntrosOutros\16_9\MovingWalls\)
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=Trans_S.png,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=Trans_G.png,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=Refl.jpg,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans3.ntds,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans3.3dsn,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans2.ntds,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans2.3dsn,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans1.ntds,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_trans1.3dsn,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_outro.ntds,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_outro.3dsn,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_intro.ntds,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=movingwalls_intro.3dsn,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=Dirt_S.png,,ComponentId={41856C64-4B0F-C6E4-DA96-8D0EA5A99E6B})
MSI (s) (60:80) [10:54:01:734]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\MovieWizard\Slideshow1\)
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=slideshow1_thumbnail_4_3.png,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=slideshow1_thumbnail_16_9.png,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=slideshow1_start_audio.mpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=slideshow1_preview.mpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:734]: Executing op: FileRemove(,FileName=slideshow1_HD.jpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:750]: Executing op: FileRemove(,FileName=slideshow1_end_audio.mpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:751]: Executing op: FileRemove(,FileName=slideshow1_4_3.nmwtmh,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:751]: Executing op: FileRemove(,FileName=slideshow1_4_3.nmwt,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:752]: Executing op: FileRemove(,FileName=slideshow1_4_3.jpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:752]: Executing op: FileRemove(,FileName=slideshow1_16_9.nmwtmh,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:753]: Executing op: FileRemove(,FileName=slideshow1_16_9.nmwt,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:753]: Executing op: FileRemove(,FileName=slideshow1_16_9.jpg,,ComponentId={1576B8C0-0B36-D81C-3900-37913359A63F})
MSI (s) (60:80) [10:54:01:754]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\MovieWizard\OldFilm\)
MSI (s) (60:80) [10:54:01:754]: Executing op: FileRemove(,FileName=oldfilm_thumbnail_4_3.png,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:754]: Executing op: FileRemove(,FileName=oldfilm_thumbnail_16_9.png,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:754]: Executing op: FileRemove(,FileName=oldfilm_start_audio.mpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:755]: Executing op: FileRemove(,FileName=oldfilm_preview.mpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:755]: Executing op: FileRemove(,FileName=oldfilm_HD.jpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_frame_HD.png,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_frame_4_3.png,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_frame_16_9.png,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_end_audio.mpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_4_3.nmwtmh,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_4_3.nmwt,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_4_3.jpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_16_9.nmwtmh,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_16_9.nmwt,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=oldfilm_16_9.jpg,,ComponentId={D13C6428-8956-226D-33F9-26F53CE30D1B})
MSI (s) (60:80) [10:54:01:756]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\MovieWizard\MovingWalls\)
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_thumbnail_4_3.png,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_thumbnail_16_9.png,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_start_audio.mpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_preview.mpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_end_audio.mpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_4_3.nmwtmh,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_4_3.nmwt,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_16_9.nmwtmh,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=movingwalls_16_9.nmwt,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_thumbnail_4_3.png,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_thumbnail_16_9.png,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_start_HD.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_start_audio.mpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_start_4_3.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_start_16_9.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MH_movingwalls_preview.mpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:756]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\)
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=MovieThemePackBasic.dll,,ComponentId={E188209D-8296-4E7B-96AE-45101016EF83})
MSI (s) (60:80) [10:54:01:756]: Executing op: FileRemove(,FileName=NeroContentLicenseCheck.dll,,ComponentId={4C4F1A46-D98F-4176-83F0-1F38CF332AC4})
MSI (s) (60:80) [10:54:01:772]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\MovieWizard\MovingWalls\)
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=MH_movingwalls_end_HD.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=MH_movingwalls_end_4_3.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=MH_movingwalls_end_16_9.jpg,,ComponentId={15E094C0-005F-545E-81E2-07844E5D20B1})
MSI (s) (60:80) [10:54:01:772]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\MovieWizard\)
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=categories.nlot,,ComponentId={B101FDE4-F9BB-49AA-996B-084909DB96F6})
MSI (s) (60:80) [10:54:01:772]: Executing op: SetTargetFolder(Folder=C:\Program Files (x86)\Nero\NeroContent\Audio\slideshow1_nsla\)
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_outro.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_intro.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_30.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_29.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_28.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_27.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_26.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_25.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_24.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_23.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_22.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_21.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_20.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:772]: Executing op: FileRemove(,FileName=sample_19.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_18.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_17.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_16.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_15.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_14.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_13.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_12.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_11.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
MSI (s) (60:80) [10:54:01:788]: Executing op: FileRemove(,FileName=sample_10.nsls,,ComponentId={F55CB8A9-9D7C-65D6-86AA-C6260CDF2175})
