Pale Moon Version 33.2.0 Released with Security Updates
Started by Corrine, June 18, 2024, 01:43:53 PM
Pale Moon has been updated to version 33.2.0.  This is a development, stability and security release.
New features:
  • Implemented the missing parts of the html5 <dialog> element, including modal handling and custom backdrops.
  • Implemented courser, user-configurable granularity for the canvas poisoning anti-fingerprinting measure. See implementation notes.
  • Implemented new CSS viewport units svw, svh, svmin, svmax, lvw, lvh, lvmin, lvmax, dvw, dvh, dvmin and dvmax.
  • Implemented new CSS logical viewport units vb, vi, svb, svi, lvb, lvi, dvb and dvi.
Changes/fixes:
  • Removed the archaic and wholly outdated FIPS security module code.
  • Removed the archaic DBM support code for storing of passwords in DBM format files.
  • Removed the -moz prefix from -moz-fit-content, aligning with the current CSS standard fit-content value.
  • Updated our build system by adopting parts of the old autoconf 2.13 as maintained code. autoconf 2.13 is no longer a build requirement. If you build from source, you may want to review your dependencies with this change.
  • Fixed issues when building with GCC 14.* and Clang 16.*.
  • Fixed issues with emoji sequence clusters causing incorrect rendering of emoji glyphs in some cases.
  • Made some arguments to the legacy XPathEvaluator/XPathExpression interfaces optional for web compatibility.
  • Fixed a crash when reporting JavaScript module exporting errors.
  • Updated checking of special cookie prefixes to be case-insensitive in accordance with the current RFC 6265 (bis-11+).
  • Fixed issues with external protocol handlers.
  • Fixed an issue where autocomplete pop-ups would stay open in some circumstances.
  • Fixed an issue with potentially bad file names being entered by the user to "Save As...".
  • Fixed several crashes and race conditions.
  • Security issues addressed: CVE-2024-5699, CVE-2024-5702 DiD, CVE-2024-5690, CVE-2024-5698 DiD, CVE-2024-5688 DiD, CVE-2024-5692 and several other security issues (some more DiD) that do not have CVE numbers assigned to them.
